2017 NAR GTI Autobahn - CXCB
Veejster
C?ID=284946
Wednesday,11,January,2017,19:52:15:63750
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
VIN: 3VW447AU4HM001660   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 3C 42 44 47 52 55
          5F 75 A9
VIN: 3VW447AU4HM001660   Mileage: 9066km-5633miles
Address 01: Engine (J623-CXCB)       Labels: None
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091D00124464002F1000
   Shop #: WSC 00066 790 00149
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001003
   ROD: N/A
   VCID: 3753D7C18EB482F93E-8062
No ASAM data for: "EV_ECM20TFS0205G0906259L" (VW37)
   Part No SW: 0D9 300 020 L    HW: 02E 927 770 AQ
   Component: DQ250-6V MQB  H54 4902
   Revision: 06354004    Serial number: TFK01605060956
   ROD: EV_TCMDQ250021.rod
   VCID: 1E1D2265014ED3B1DD-804A
   Part No SW: 5Q0 614 517 BK    HW: 5Q0 614 517 AH
   Component: ESC           H62 0736
   Revision: 00000000    Serial number: 61146000000330
   Coding: 01FA6BA15420096D807D020641C36880D62A900140821636164350D1C08903
   Shop #: WSC 01383 790 50316
   VCID: 7BDB0BF1F21C66999A-802E
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0405941843
   Coding: 032C0C
   VCID: 3B5BCBF1B29CA699DA-806E
   Part No SW: 5GM 907 044 C    HW: 5GM 907 044 C
   Component: Climatronic   H04 1601
   Revision: 00001K03
   Coding: 00020014200100010005000012111402
   ASAM Dataset: EV_ACClimaBHBVW37X 006142
   VCID: 44A9B00DCF62D961AB-8010
   Air quality sensor:
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865827061601SQ
   Coding: 00111A464041A2E969E44000111407201800000000000000000000000000
   Shop #: WSC 00066 790 00215
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 7AD50EF5FD265F9181-802E
   Component: WWS    160313  043 0581
   Serial number:         160628183144
   Component: RLHS  042 0105
   Serial number: S3Y16M05D13H20M34S18
   Coding: 06A8DD
   Subsystem 3 - Part No SW: 5Q0 951 605     HW: 5Q0 951 605
   Serial number: 00000000000058959741
   Sun Roof:
   Subsystem 4 - Part No SW: 5GD 959 591     HW: 5GD 959 591
   Component: J245 PS60.036  H06 0150
   Serial number: 03691610252212150843
   Coding: 981E03
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 G    HW: 5Q0 907 572 G
   Component: ACC BOSCH MQB H10 0571
   Coding: 3500008141FFC428949C8045000016
   ASAM Dataset: EV_ACCBOSCHVW416 001005
   ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
   Serial number: 02051641350177
   ROD: EV_DRCONTITEMIC.rod
   VCID: 3851D4FD83AA8D8137-806C
   Serial number: 003GCR04WAR2
   VCID: 47B3A701FE54F2794E-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH0000000000058WEBU
   Coding: 303131
   Subsystem 2 - Part No SW: -----------    HW: 480 000 905 16
   Serial number: 357000000005A6351B1E
   Subsystem 3 - Part No SW: -----------    HW: 480 000 905 16
   Serial number: 35800000000174351B16
   Subsystem 4 - Part No SW: -----------    HW: 480 400 905 16
   Serial number: 3510002AD2076341314M
   Subsystem 5 - Part No SW: -----------    HW: 480 400 905 16
   Serial number: 3520002B32076341D24P
   Subsystem 6 - Part No SW: -----------    HW: 480 400 905 16
   Serial number: 3550002AD207634510F
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 905 16
   Serial number: 3560002AF2076340B2D3
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Revision: FF034034    Serial number: 20160620400545
   Coding: 0410
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 0429700D8FE21961EB-8050
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD091ABD88CF0502886A095000000000000000
   VCID: 2D7FF5A97CE8382954-8078
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 11051610801526
   Coding: 0101000830085900FB00023B9C0F00000001050000000000000000000000
   Shop #: WSC 00066 790 07026
   ROD: EV_GatewConti_013.rod
   VCID: 7CD908EDF71261A193-8028
   Subsystem 2 - Part No SW: 5G0 959 442 S    HW: 5G0 959 442 S  Labels: 3C8-959-537.CLB
   Component: E221__MFL-DC1  H10 0040
   Serial number: 29150001533520025324
   Coding: 35FFFF
   Revision: 00000000    Serial number: 16000096295006
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449E0CD9FC269E11B-8060
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00009.04.16
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086)       Labels: None
   Serial number: 0403591538
   Coding: 01011103
   ROD: EV_HREntryHella.rod
   VCID: 3C59C8EDB792A1A1D3-8068
   Lane Change Assistant 2:
   Serial number: 170616060500LL
   Coding: 003E13200000020000000000
   VCID: 43ABB311CA6CDE5992-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000012816121
   Coding: 011000
   Part No SW: 3Q0 909 144 J    HW: 3Q0 909 144 H
   Component: EPS_MQB_ZFLS  505 5063
   Coding: 8102
   VCID: 3957D1F9B8A09489C8-806C
   Component: MIB2_lite_amp H20 0150
   Revision: 00000001    Serial number: VWZ8Z1GBA01RNM.
   Coding: 2200000000AAAAAA000000000000
   ROD: EV_AMPMst12C1Gen2ALPI.rod
   VCID: 6DFF35A9BC68F82914-8038
   Serial number: 170616060502MO
   Coding: 003E13200C00020000000000
   VCID: 42A5B615D576D75199-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000012806768
   Coding: 091000
   Coding: 021203000B000400
   VCID: 40A1BC1DDB7AC5418F-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 876 A    HW: 3Q0 035 876 A
   Component: MU-S-NS-US    840 0751
   Coding: 027300020000000051220002001808009F0203F401200101C6
   ROD: EV_MUStd4CDELP_VW26.rod
   VCID: 3245E6D565D667D109-8066
   Subsystem 1 - Part No SW: 5GM 919 605     HW: 5GM 919 605
   Component: ABT_Std-2_Nav  H53 1031
   Serial number: VWZ8Z9SJX0067E
   Subsystem 2 - Part No SW: 3G0 919 866 AC    HW: -----------
   Component: NAR 2016/17  --- 0445
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2823A017F5E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160420201269
   VCID: 6BFB3BB1827CF6190A-803E
End-------------------------(Elapsed Time: 04:19)--------------------------
