audi a4 2006 abs faults :18055 and 01314
TORPEDO
Lithuania
C?ID=140986 (NRRT)
hello, can you help me with audi a4 2006 2.5tdi abs coding calculation? I dont know why, but we have fault code 18055 in abs control unit.So i think there are bad coding in esp system, because in airbag 50 and 51 channels are ok. My client put airbag modele from another car and after it abs have this faults
Friday,20,January,2017,13:05:06:58885
VCDS Version: 16.8.4.2 (x64)
VIN: WAUZZZ8E15A439532   License Plate: AUDI
Mileage: 269980km-167757mi   Repair Order:
          67 69 75 76 77
VIN: WAUZZZ8E15A439532   Mileage: 269980km-167757miles
Address 01: Engine        Labels: 059-907-401-AKE.clb
   Part No: 8E0 907 401 AF
   Component: 2.5l V6 TDI G200AG  0030
   Coding: 02007
   Shop #: WSC 00568
   VCID: 69D39DC8139FE70A7E-4ACE
   WAUZZZ8E15A439532     AUX6Z0D0444351
01375 - Valves for Engine Mounting; Stage 1
            38-00 - Output won't Switch or Short to Plus
Readiness: 0 0 X X 1
Address 02: Auto Trans        Labels: 01J-927-156.lbl
   Part No SW: 8E0 910 159 F    HW: 01J 927 156 HT
   Component: V30 01J 2.5lTDI RdW 0030
   Revision: 00000006    Serial number: 00000000844559
   Coding: 0000001
   Shop #: WSC 39173 123 86689
   VCID: 2C5D24DC8CED322245-5102
   Part No SW: 8E0 910 517 B    HW: 8E0 614 517 AT
   Component: ESP8 front      H04 0180
   Coding: 0000001
   Shop #: WSC 06325 000 00000
   VCID: 2649D6F49101087293-8072
            000 -  -
                    Fault Status: 11100000
                    Hex Value: 0x0000
                    Hex Value: 0x4702
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
18055 - Check Coding of ECUs on Powertrain Data Bus
            P1647 - 000 -
                    Hex Value: 0x0000
                    Hex Value: 0x4702
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
   Part No SW: 8E0 959 655 G    HW: 8E0 959 655 G
   Component:    Airbag 9.41  H10 3230
   Revision: 91H10323    Serial number: 0036M0012JGQ
   Coding: 0033622
   VCID: 3B7F17807A83A59ADC-806E
   Subsystem 1 - Serial number: 6332DRB4011D131AD
   Subsystem 2 - Serial number: 6342DRB4010A8DA2S
   Subsystem 3 - Serial number: 6352ARB4003B72AAP
   Subsystem 4 - Serial number: 6362ARB4003B66C9U
   Subsystem 5 - Serial number: 63729RB40059F17BV
   Subsystem 6 - Serial number: 63829RB40059F251L
   Coding: 0000001
TORPEDO
Lithuania
C?ID=140986 (NRRT)
          67 69 75 76 77
   Coding: 02007
   Shop #: WSC 00568
   Coding: 0000001
   Coding: 0000001
            000 -  -
                    Hex Value: 0x0000
                    Hex Value: 0x4702
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
            P1647 - 000 -
                    Hex Value: 0x0000
                    Hex Value: 0x4702
                    Hex Value: 0x00FF
                    Hex Value: 0xFFAB
                    Hex Value: 0x00FF
   Part No: 8E0 820 043 AL
   Component:   A4 Klimaautomat   2728
   Coding: 00000
   Shop #: WSC 06325
   VCID: 6BDFE7C01963F51A0C-5102
            41-10 - Blocked or No Voltage - Intermittent
00716 - Air recirculation Flap Positioning Motor (V113)
            07-00 - Signal too Low
   Part No: 8E0 907 279 L
   Component: int. Lastmodul  ECE 0304
   Coding: 10021
   Shop #: WSC 06325
   VCID: 3B7F17802983A59ADC-4ACE
            30-00 - Open or Short to Plus
   Coding: 0033622
   Part No: 8E0 953 549 Q
   Component: Lenksбulenmodul     0601
   Coding: 04042
   Shop #: WSC 06325
   VCID: 418365684B6FCF4A86-4ACE
   Part No SW: 8E0 920 931 B    HW: 8E0 920 931 B
   Component: KOMBI+WFS 3     H12 0020
   Revision: 0020        Serial number: AUX6Z0D0444351
   Coding: 0004001
   Shop #: WSC 73249 020 01196
   VCID: 2757DBF0950B117AA8-5120
            007 - Short to Ground
   Coding: 0004001
   VCID: 2757DBF0950B117AA8-5102
Address 37: Navigation        Labels: 8E0-035-192-RNSE.clb
   Part No SW: 8H0 035 192     HW: 8H0 035 192
   Component: RNS-E HIGH EU   H53 X---
   Revision:      08S    Serial number: AUZBZ7E0601838
   Coding: 0413113
   Shop #: WSC 23471 512 00000
   VCID: 64CD8CFCA4BDBA624D-515A
                    Reset counter: 65
                    Date: 2017.01.02
                    Time: 17:34:09
                    Voltage: 10.90 V
                    Mileage: 655350 km
                    Count: 2001
                    Clock: 12:47
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
                    Reset counter: 251
                    Date: 2016.12.05
                    Time: 19:02:06
                    Mileage: 655350 km
                    Count: 512
                    Clock: 19:01
                    Reset counter: 55
                    Date: 2017.01.05
                    Time: 12:30:21
                    Bin. Bits:     0000
                    Mileage: 655350 km
                    Count: 501
                    Clock: 14:28
            000 -  -
                    Reset counter: 251
                    Date: 2016.12.05
                    Time: 19:01:55
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BH
   Component: Komfortgerбt T01    2431
   Coding: 06976
   Shop #: WSC 39713
   VCID: 78F5C88C58354E82F1-4ACE
   Subsystem 1 - Part No: 8E1959801B
   Component: Tхrsteuer.FS BRM 0205
   Subsystem 2 - Part No: 8E1959802B
   Component: Tхrsteuer.BF BRM 0205
   Subsystem 3 - Part No: 8E0959801A
   Component: Tхrsteuer.HL BRM 0205
   Subsystem 4 - Part No: 8E0959802A
   Component: Tхrsteuer.HR BRM 0205
01366 - Opened Due to Crash Signal
            36-10 - Open Circuit - Intermittent
   Part No SW: 4F0 910 357 C    HW: 4F0 907 357 C
   Coding: 0000019
   Subsystem 1 - Part No: NOSUBSYSTEM
   Component: AFS-Modul links
   Subsystem 2 - Component: AFS-Modul rechtsH01 0020
02233 - Left Headlight Power Output Stage (J667)
                    Fault Status: 11100100
Address 56: Radio        Labels: 8E0-035-192-RNSE.clb
   Coding: 0413113
   VCID: 64CD8CFCA4BDBA624D-513C
                    Reset counter: 65
                    Date: 2017.01.02
                    Time: 17:34:09
                    Voltage: 10.90 V
                    Mileage: 655350 km
                    Count: 2001
                    Clock: 12:47
                    Reset counter: 251
                    Date: 2016.12.05
                    Time: 19:02:06
                    Mileage: 655350 km
                    Count: 512
                    Clock: 19:01
                    Reset counter: 55
                    Date: 2017.01.05
                    Time: 12:30:21
                    Bin. Bits:     0000
                    Mileage: 655350 km
                    Count: 501
                    Clock: 14:28
            000 -  -
                    Reset counter: 251
                    Date: 2016.12.05
                    Time: 19:01:55
   Part No SW: 8P0 862 335 D    HW: 8P0 862 335 D
   Component: FSE_255x BT     H18 0050
   Revision: 00000001    Serial number: 00000000152171
   Coding: 0001811
   VCID: 37770BB045AB81FA38-5102
                    Reset counter: 75
                    Time Indication: 15
End-------------------------(Elapsed Time: 06:50)--------------------------
NostraJackAss
thanks pal, i try tomorrow :) now coding is 000001 i think this is bad coding
FYI:
Well that coding was taken from kind auto-scan correlations searched for on the net with the same engine, ABS and TCU part #........
That is why auto-scans are important to post and it helps everyone help each other.
United States
Thanks Jack. I came up with the same coding for a 2.5l TDI (PR-T1K) with CVT/01J (PR-G0Z) and FNRG-60 16" (PR-1LA) front brakes.
Ruslan, I do not see a pending registration from you yet. Please fill out this form and make sure to note "Please check my forum status" in the 'Notes or Special Instructions' field of the form per the notes under #2: How to get Verified
