S4 2011 Sport differential: system fault
flipp
Norway
C?ID=119466
Hi there,
just registered an account here and hoping some of you have experienced something similar before.
I'll start with some background info. After owning this S4 for about 6 months and the milage was at approx. 105 000 km, I intermittently started hearing some sublte strange noises when accelerating. I therefore decided to get the car to my local Audi S/RS specialist repair shop, too see if they could find the culprit.
Before delivering my car, there had never been any no warnings/faults in the dashboard. And stupidly of me, I didn't do a fault code scan either. After a couple of hours the repair shop called and said they suddenly experience a dashboard differential warning whenever they started the car (attached picture below). They said the only thing they had done, was to drive the car into their shop, raise the car to have a look under it + scanning for fault codes. As soon as they lowered the car and started it, that differential warning appeared. I picked up the car later that day.
In the following couple of months, the same repair shop has tried 5-6 times to figure out what's going on, without luck. There's several fault codes visible, but the most interesting ones are (1) "invalid data record" and (2) "no signal/communication". This is what they've tried this far:
  • Replaced the differential ECU
  • Replaced the CAN gateway, as that's the one communicating with the diff ECU
  • Ensured wires between gateway and diff ECU is intact
None of the above has made the fault codes disappear. The repair shop suspects the "0312 - invalid data record" is key to solving the issue, but they don't really know what the underlying issues is, why that fault code is present, or how to fix it.
The only thing I've installed and coded in my self after purchasing the car in late 2015, is a Kufatec Fistune DAB+ tuner. Although that was probably around 6 months before this differential fault started. I'm therefore assuming the DAB tuner has nothing to do with this.
Really hoping someone here has some thoughts or even experience something similar before, I would really appreciate any feedback!
Here's from the last scan I've done:
Friday,09,December,2016,23:34:55:16175
VCDS Version: 16.8.4.2 (x64)
VIN: WAUZZZ8K3BA056xxx   License Plate: xxx
Mileage: 107930km-67064mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 0E 0F 10 14 15 16 17 19 22 36 42 46 47 52
          53 55 56 5F 62 6D 72
VIN: WAUZZZ8K3BA056xxx   Mileage: 107930km-67064miles
22-AWD -- Status: Cannot be reached 1100
Address 01: Engine (J623-CAKA)       Labels: 06E-907-551-CAK.clb
   Part No SW: 8K0 907 551 C    HW: 8K0 907 551
   Component: 3.0T SIMOS84  H07 0002
   Revision: --------
   Coding: 010C000C240F0028
   Shop #: WSC 06335 000 00000
   ASAM Dataset: EV_ECM30TFS0218K0907551C 001002
   ROD: EV_ECM30TFS0218K0907551C.rod
   VCID: 3163FDF0601675CA76-8064
Readiness: 0010 0001
Address 02: Auto Trans (J217)       Labels: 0B5-927-156.clb
   Part No SW: 8K1 927 156 J    HW: 0B5 927 156 F
   Component: 0B5 30TFSIRdW H07 0006
   Revision: --H07---    Serial number: 0000000275
   ASAM Dataset: EV_TCMDL501 A02087
   ROD: EV_TCMDL501.rod
   VCID: 3C7DDCC4B75488A2D5-8068
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 BJ    HW: 8K0 907 379 BJ
   Component: ESP8 quattro  H04 0060
   Coding: 290D0A
   Shop #: WSC 74942 141 87527
   VCID: 0201623C9D303E52DF-8056
01324 - Control Module for All Wheel Drive (J492)
                    Reset counter: 186
                    Mileage: 107922 km
                    Date: 2010.01.22
                    Time: 01:06:19
                    Hex Value: 0x00C0
                    Hex Value: 0x4082
                    Hex Value: 0x0028
                    Hex Value: 0x8285
                    Hex Value: 0x00FF
   Part No SW: 8K0 907 064 CQ    HW: 8K0 907 064 CQ
   Component: BCM2 2.0      H05 0431
   Coding: 010200
   VCID: 01036D309836254AC6-8054
   Subsystem 1 - Part No SW: 8T0 959 754 AG    HW: 8T0 959 754 AG
   Component: FBSAUDIB8 IDG  H50 0071
   Serial number: 0810000095103001
   Serial number: 2310000012325002
   Revision: C1000000    Serial number: 01250920100527
   Coding: 66100000
   VCID: 00056834933C2C42C9-8054
                    Reset counter: 225
                    Mileage: 107922 km
                    Date: 2010.01.22
                    Time: 00:52:20
   Component: BCM1 1.0      H30 0392
   Revision: 10030001    Serial number: 00000000663587
   Coding: 260058914034AF212F01000300001D0D0F9CC74802010141000000
   VCID: 3C7DDCC4BF5488A2D5-8068
   Component: WWS 240910  H06 0070
   Serial number: SWF10090240670
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 11071277
   Coding: 025028
   Component: E1 - LDS  H08 0090
   Serial number: 00000000002708103252
Address 0E: Media Player 1 (R41)       Labels: Redir Fail!
   Part No SW: 8X0 035 110     HW: 8X0 035 110
   Component: CDC-MP3-Pana  H41 0440
   Revision: 00000004
   VCID: 6AD12A9C8540C61277-803E
Address 0F: Digital Radio        Labels: None
   Part No SW: KUFATEC DAB+    HW: KUFATEC DAB+
   Component:
   Shop #: WSC 00666 142 74100
   VCID: 75EB09E01CFE19EAEA-8020
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 R    HW: 8K0 919 475 A
   Component: PARKHILFE 8K  H06 0070
   Revision: 11001001    Serial number: 50941027205658
   Coding: 10010D
   VCID: 4895B014FB8CD40241-801C
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 B    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0053
   Revision: 00000000    Serial number: 22091001430002
   Coding: 010181
   VCID: 3973C5D0B066BD8ACE-806C
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 J    HW: 8K0 959 655 J
   Component: AirbagVW-AU10 H41 0610
   Serial number: 003GKD0KSXSW
   Coding: 30353435363030303030554A304C384B3053
   VCID: 448DA424CFA4F062AD-8010
   Serial number: 6334MSME58753772H
   Serial number: 6344MSME5873313EI
   Serial number: 6352QSME4D731E34Q
   Serial number: 6362QSME4871230CF
   Serial number: 63732SME5171372E$
   Serial number: 63832SME53713538Z
   Part No SW: 8K0 953 568 G    HW: 8K0 953 568 G
   Component: Lenks.Modul   H17 0014
   Revision: --------    Serial number: 90304JIH000J8
   Coding: 000033
   VCID: 3E79D6CCA9489AB2FB-806A
   Component: E221 - MFL  H02 0010
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 931     HW: 8K0 920 931
   Component: KOMBIINSTR.   H08 0258
   Revision: 00000000    Serial number: EJE177N9A
   Coding: 0F07110093001008000000
   Shop #: WSC 06335 123 12345
   VCID: 6BDF2F988ABADF1A0C-803E
                    Reset counter: 185
                    Mileage: 107922 km
                    Date: 2010.01.22
                    Time: 00:56:25
   Part No SW: 8T0 907 468 AD    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0117
   Revision: EC000056    Serial number: 5600E1090701CE
   Coding: 00C303
   VCID: 030F6738822A375AD4-8056
   Component: J367-BDM  H07 0170
   Serial number: 10032401170910
                    Reset counter: 185
                    Mileage: 107922 km
                    Date: 2010.01.22
                    Time: 00:53:42
                    Bin. Bits:    10111
                    Voltage: 11.40 V
                    Count: 6
                    Bin. Bits:    10110
                    Time: 25.40 s
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 A    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H10 0025
   Serial number: 001609100001065
   ASAM Dataset: EV_AllWheelDiffeQSPCAN 003016
   VCID: 2E59E68C71286A326B-807A
          B2005 00 [001] -  -
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H06 0074
   Revision: AA000000    Serial number: 00001002113309
   Coding: 00581300000000000000
   VCID: 3B7FDFD8BA5A8F9ADC-806E
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 M    HW: 8K0 959 793 M
   Component: TSG FA        H12 0357
   Revision:             Serial number: 0000011340396
   Coding: 011C02205E00410001
   VCID: 4A918A1CE580261257-801E
   Revision: 00002001    Serial number: 0135741763
   Coding: 0100062020B934808030023280000000
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Part No SW: 8T0 035 223 AN    HW: 8T0 035 223 AK
   Component: DSP Prem      H10 0190
   Revision: 00010001    Serial number: 34804000107100
   VCID: 7AF11ADCF5E0769287-802E
   Part No SW: 8K0 959 792 M    HW: 8K0 959 792 M
   Component: TSG BF        H12 0357
   Revision:             Serial number: 0000011370476
   VCID: 4993B510E0862D0A5E-801C
   Revision: 00000003    Serial number: 00000000750114
   VCID: 346DF4E4970440E21D-8060
   Part No: 8K0 907 357 D
   Coding: 0000005
   VCID: 3669CEEC417852F223-8062
   Part No SW: 4G0 035 053     HW: 4G0 035 053
   Component: Radio U Basic H52 0051
   Revision: AB001007    Serial number: 496I70A7566841
   Coding: 010003010000000001
   VCID: 5BBF7F585A1AAF9AFC-800E
03455 - Function Restriction due to Faults in Other Modules
            000 -  -  - Intermittent
                    Reset counter: 225
                    Mileage: 107922 km
                    Date: 2010.01.22
                    Time: 00:52:30
                    Bin. Bits: 00000000 00000001
   Part No SW: 8T1 035 666 F    HW: 8T1 035 666 E
   Component: H-BN-EU       H49 0107
   Revision: --------    Serial number: 483I%0A7656810
   Coding: 010100010206A1ED45000B1E000000030000
   VCID: 3D7BD1C0A44E81AAE2-8068
   Subsystem 1 - Part No: 8R0 060 884 R
   Component: EUR 2010  1107
   Subsystem 2 - Part No SW: 8F0 919 604     HW: 8F0 919 604
   Component: DU7 High  H43 0084
   Serial number: 9466IU0A0219125
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Serial number: 00000000637789
   Component: CD-Database  1886
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 F    HW: 8K0 959 795 F
   Component: TSG HL        H11 0357
   Revision:             Serial number: 0000108657934
   Coding: 010C02204000210001
   VCID: 458BB920CC9EC96ABA-8010
   Part No SW: 8K9 827 851 A    HW: 8K9 827 851 A
   Component: J605  Master  H50 0330
   Revision: --------    Serial number: 8K9827851A
   Subsystem 1 - Part No SW: 8K9 827 852 A    HW: 8K9 827 852 A
   Component: J756  Slave  H50 0330
   Serial number: 8K9827852A
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Component: TSG HR        H11 0357
   Revision:             Serial number: 0000108657927
End-------------------------(Elapsed Time: 04:25)--------------------------
flipp
Norway
C?ID=119466
Has anyone encountered "invalid record" before? Any thoughts at all, I'm out of options here so anything would be valuable.
Gone But Not Forgotten
FOD strikes again!........
Put all correct stock controllers in car and start over..........
flipp
Norway
C?ID=119466
Have You saved old original modules? Can You connect them back to car and do another one autoscan?
P.S. Maybe this will help a bit.
Thanks so much for replying, really appreciated! :thumbs:
To my knowledge, the differential ECU was stock when this error appeared. Of course I can't guarantee it since this is and aftermarket car.
As briefly mentioned I have mounted a 3rd party DAB module. Would you even consider removing that, or is it completely unlikely that has any effect on this differential error?
When you say "start over" you simply mean performing an auto-scan or should previous errors be deleted first?
Edit: I have the original modules (differential ECU and CAN gateway). They have both been tried installed back in, with no effect sadly :/
flipp
Norway
C?ID=119466
Are the original units you installed with a FOD tune?
I'm a VAGCOM noob so gotta ask the dumb question: what's a FOD tune?
The only module I've installed is Fistune DAB, looks like this one: http://www.advanced-incar.co.uk/products/digital-radio-dab/fistune-3g-audi-style-dab-retrofit/ which I enabled with VAGCOM / adaption coding IIRC, I followed this Fistune install instructions.
Does that answer the FOD tune question?
Differential fault warning appeared about 6 months after reotrofitting Fistune DAB, when the repair shop did a differential fault code scan -- possibly clearing previous fault codes as well, they don't remember the details. At that moment, the differential ECU and CAN gateway were stock and had not been touched AFAIK. Both of these two modules are stock Audi modules for this car, not 3rd party or tuned in any way.
Once again, thanks so much for replying! :thumbs:
Reset counter: 186
Mileage: 107922 km
Date: 2010.01.22
Time: 01:06:19
Hex Value: 0x00C0
Hex Value: 0x4082
Hex Value: 0x0028
Hex Value: 0x8285
Hex Value: 0x00FF
Part No SW: 8K0 907 163 A HW: 8K0 907 163 A <<<<<<<<<<<<<<<< is this module correct for the car?
B2005 00 [001] - -
No valid VIN and NO JPPSG!
http://forums.ross-tech.com/showthr...essional-Problem-Solver-Guide-quot-JPPSG-quot
flipp
Norway
C?ID=119466
B2005 00 [001] - -
I assume so, yes. I've got a scan log (with 0 faults) prior to the differential warning that has that exact part number.
flipp
Norway
C?ID=119466
The last three missing VIN characters seen in the scan log above is 421 (I'd rather not say the whole VIN in one word).
I tried my best describing the issue and related info in my OP inspired by your awesome solver guide. A couple of follow ups:
- I have not checked fuses or battery yet
Did a new scan after unchecking "0F Digital Radio" for module 19 CAN Gateway / Installation List, unplugging the DAB tuner and clearing DTCs. Comparing it to the scan I have before any issues started (not the one in OP), some things are noticable:
- 09: Cent. Elect coding has changed (I've changed DRL and coming home settings)
- 01: Engine readiness from 0010 0001 to 0000 0000 (cause I didnt start engine after clearing DTCs?)
- 03: ABS Brakes from ok to malfunction
- 19: CAN Gateway from ok to status malfunction
- 22: AWD status from ok to cannot be reached, component from "4 Wheel Drive H10 0025" to "4 Wheel Drive H17 0025" and serial number has changed of course
- All VCIDs has changed, possibly cause I've updated VCDS(?)
At first glance it might seem AWD component changed being the most probable issue here, but there is a couple of things worth mentioning:
- repair shop has replaced AWD module trying to solve this issue (I have to old one)
- most importantly: instrument warning started before repair shop replaced AWD module
Complete scan for reference:
Monday,13,March,2017,22:44:20:16175
VCDS Version: 17.1.3.0 (x64)
Mileage: 112290km-69773mi   Repair Order:
VIN: WAUZZZ8K3BA056xxx   Mileage: 112290km-69773miles
   Revision: --------
   VCID: 3163FDF0601675C956-8064
   VCID: 3C7DDCC4B75488A1F5-8068
   Coding: 290D0A
   VCID: 0201623C9D303E51FF-8056
                    Fault Frequency: 13
                    Reset counter: 95
                    Mileage: 111988 km
                    Date: 2017.03.09
                    Time: 13:03:55
                    Hex Value: 0x00C0
                    Hex Value: 0x07A2
                    Hex Value: 0x0028
                    Hex Value: 0x828F
                    Hex Value: 0x00FF
   Coding: 010200
   VCID: 01036D3098362549E6-8054
   Coding: 66100000
   VCID: 00056834933C2C41E9-8054
   VCID: 3C7DDCC4BF5488A1F5-8068
   Coding: 00FD11
   Coding: 025028
   Revision: 00000004
   VCID: 6AD12A9C8540C61157-803E
   Component:
   VCID: 75EB09E01CFE19E9CA-8020
   Coding: 10010D
   VCID: 4895B014FB8CD40161-801C
   Coding: 010181
   VCID: 3973C5D0B066BD89EE-806C
   VCID: 448DA424CFA4F0618D-8010
   Coding: 000033
   VCID: 3E79D6CCA9489AB1DB-806A
   VCID: 6BDF2F988ABADF192C-803E
                    Reset counter: 91
                    Mileage: 111988 km
                    Date: 2017.03.09
                    Time: 10:08:31
   Coding: 00C303
   VCID: 030F6738822A3759F4-8056
                    Reset counter: 91
                    Mileage: 111988 km
                    Date: 2017.03.09
                    Time: 10:08:31
                    Bin. Bits:    10111
                    Voltage: 11.50 V
                    Count: 6
                    Bin. Bits:    10011
                    Time: 25.40 s
   Component: 4 Wheel Drive H17 0025
   Serial number: 002108160001007
   VCID: 2E59E68C71286A314B-807A
          B2005 00 [001] -  -
   VCID: 3B7FDFD8BA5A8F99FC-806E
   VCID: 4A918A1CE580261177-801E
   VCID: 7AF11ADCF5E07691A7-802E
   VCID: 4993B510E0862D097E-801C
   VCID: 346DF4E4970440E13D-8060
   Coding: 0000005
   VCID: 3669CEEC417852F103-8062
   VCID: 5BBF7F585A1AAF99DC-800E
   VCID: 3D7BD1C0A44E81A9C2-8068
   VCID: 458BB920CC9EC9699A-8010
End-------------------------(Elapsed Time: 04:18)--------------------------
Worth mentioning I get a "VCDS: Re-Code Invalid" warning when pressing the "Save coding" button that says "This appears to be an uninitialized control module; valid WSC/Importer/Equipment data may be required." with three options below, that I'm sure you are familiar with. I've clicked the "Yes" button whenever seeing this, resulting in a dialog confirming the coding was accepted.
P.S. I can upload these logs to github.com, source control makes it a lot easier to see the difference in these logs if that sounds good?
[TABLE="class: vinInfoTable"]
[TR]
[TH]Vehicle Identification No.
[/TH]
[TD="colspan: 2"]WAUZZZ8K3BA056XXX
[/TD]
[/TR]
[TR]
[TH]Model
[/TH]
[TD="colspan: 2"]audi s4 av.qu.3.0
A4
[/TD]
[/TR]
[TR]
[TH]Date of production
[/TH]
[TD="colspan: 2"]05.10.2010
[/TD]
[/TR]
[TR]
[TH]Year
[/TH]
[TD="colspan: 2"]2011
[/TD]
[/TR]
[TR]
[TH]Sales type
[/TH]
[TD="colspan: 2"]8K5S4Y
[/TD]
[/TR]
[TR]
[TH]Engine Code
[/TH]
[TD="colspan: 2"]CAKA
[/TD]
[/TR]
[TR]
[TH]Transmission Code
[/TH]
[TD="colspan: 2"]MSE
[/TD]
[/TR]
[TR]
[TH]Axle drive
[/TH]
[TD="colspan: 2"]7A
[/TD]
[/TR]
[TR]
[TH]Equipment
[/TH]
[TD="colspan: 2"] ZM
[/TD]
[/TR]
[TR]
[TH]Roof color
[/TH]
[TD="colspan: 2"]A2
[/TD]
[/TR]
[TR]
[TH]Exterior color / Paint Code
[/TH]
[TD="colspan: 2"]A2 / Y9B
[/TD]
[/TR]
[/TABLE]
Parts seem to check out please check gateway for com issues and investigate all tracks.
Verify the config of your cable......for WSC, Importer # and tester #
flipp
Norway
C?ID=119466
Thanks for double checking the parts installed, good to know the current combo checks out! I'm not knowledgeable enough to know where to start checking the gateway as you suggest, if you've got any articles or relevant forum posts about that, I'd really appreciate it.
The VCDS Tour: Options article recommends leaving WSC, Importer and Equipment as 000s to keep it in stealth mode for individual users. As I haven't had issues with coding not being accepted, would setting WSC etc have any effect?
Eric
HC800000
One does not simply swap control unit and sensors and even fluid in the sport diff. I suggest a good read of SSP 990193 starting page 44, especially page 67.
