18017/P1609/005641 - Crash Shut-Down Activated
gabito
Argentina
C?ID=57962
Hello I have a vw up car that choco jumped the airbag is already repaired but I remain the warning light of the address (steering wheel) in red and when I do the scan I get the dtc p1609, when you read a procedure to delete The dtc but to do it I need the access code I could pass.
Sorry but I do not speak English.
This EPS_TRW_ALow procedure belongs to Piotr Brzezina (User Name "automech" in the Ross-Tech forum). It should resolve DTC P1609 - Crash Shut-Down Activated in vehicles with that steering system installed.
http://forums.ross-tech.com/showthread.php?4988-Skoda-Fabia-MY16-Power-Steering-fault
VIN: 9BWAG4121FT558704 License Plate: OLM553
Mileage: 23690km-14720mi Repair Order: 1122
Address 44: Steering Assist (J500) Labels: 1Sx-909-144-44.clb
Part No SW: 1S1 909 144 P HW: 1S1 909 144 P
Component: EPS_ECU H51 1702
Coding: 0001000001010000
Shop #: WSC 03310 453 00217
ASAM Dataset: EV_SteerAssisNSK 014008
ROD: EV_SteerAssisNSK_VW12.rod
VCID: 4084F8FDDBDE7742EE-8014
0024 - Crash Shut-Down Activated
P1609 00 [137] - -
Reset counter: 35
Mileage: 23694 km
Date: 2017.01.19
Time: 00:32:30
Voltage terminal 15: 13.302 V
Voltage terminal 30: 13.903 V
Engine speed: 0.00 /min
Status: No enabling
johanbrakelen
NL
I have the same problem with a vw polo 6c 2015 the steering assist don't work the faultcode crash shut down and i can erase it,can somebody help me with this problem ??
Please post an Auto-Scan so people can see this problem in context.
johanbrakelen
NL
Tuesday,21,February,2017,15:07:58:48116
VCDS Version: 17.1.3.0 (x64)
Data version: 20170203 DS267.2
VIN: WVWZZZ6RZGY107109   License Plate: DZ866HV
Mileage: 6608km-4106mi   Repair Order:
Chassis Type: 6R (6C0)
Scan: 01 03 08 09 15 17 19 44 5F
VIN: WVWZZZ6RZGY107109   Mileage: 6608km-4106miles
Address 01: Engine (J623-CHYA)       Labels: 04C-906-020-CHY.clb
   Part No SW: 04C 906 057     HW: 04C 907 309 J
   Component: R3 1.0l MPI   H24 9076
   Revision: 31H24000
   Coding: 01110012022400080000
   Shop #: WSC 00788 648 00255
   ASAM Dataset: EV_ECM10MPI01104C906057 001017
   ROD: EV_ECM10MPI_VW26.rod
   VCID: 62C03EAE75F445519F-8036
Readiness: 1010 0001
Address 03: ABS Brakes (J104)       Labels: 6R0-907-37x-ESP90.clb
   Part No SW: 6C0 907 379 K    HW: 6R0 907 379 BA
   Component: ESP9.0i       H03 0004
   Serial number: 08501548150912
   Coding: 21DD2485492333C709150069005A842492CC90000005C9098F00
   ASAM Dataset: EV_Brake1ESP90iBOSCHPQ26 100020
   ROD: EV_Brake1ESP90iBOSCHPQ26.rod
   VCID: 3776BFFA8EF670F918-8062
Address 08: Auto HVAC (J301)       Labels: 6C0-820-045.clb
   Part No SW: 6C0 820 045     HW: 6C0 820 045
   Component: AC Manuell    H03 0108
   Serial number:  1509021B-1327
   Coding: 200000000000100000
   ASAM Dataset: EV_ACManueKMMValeoPQ26 002001
   ROD: EV_ACManueKMMValeoPQ26_VW26.rod
   VCID: 5CBC0056579073A1D5-8008
Address 09: Cent. Elect. (J519)       Labels: Redir Fail!
   Part No SW: 6C0 937 087 C    HW: 6C0 937 087
   Component: BCM PQ26 Me4R H08 0086
   Serial number: 001578002554
   Coding: 00000840401300534F044000400703000000590051010000000000000000
   ASAM Dataset: EV_BCMA0 005005
   ROD: EV_BCMA0_005_VW26.rod
   VCID: 2E589A9E71ACB1314B-807A
   Drivers Door Control Module:
   Subsystem 1 - Part No SW: 6R0 959 801 CA    HW: 6R0 959 801 CA  Labels: 6R0-959-801.CLB
   Component: J386__TSG_FT  003 8620
   Serial number: KU0KU018091552612799
   Coding: 0000A0
   Subsystem 2 - Part No SW: 6R0 959 802 CD    HW: 6R0 959 802 CD  Labels: 6R0-959-802.CLB
   Component: J387__TSG_BT  003 8620
   Serial number: KU0KU017091552608476
   Coding: 1000A0
Address 15: Airbags (J234)       Labels: 6C0-959-655.clb
   Part No SW: 6C0 959 655 E    HW: 6C0 959 655 E
   Component: VW20Airbag00N 001 0360
   Revision: --------    Serial number: 003RH005HVZ6
   Coding: 88C0C000000000005C0000CA000800000000
   ROD: EV_AirbaVW20BPAVW26X.rod
   VCID: 356AB5F294FA82E90A-8060
   Subsystem 1 - Part No SW: -----------    HW: 410 822 001 14
   Component: SideSensor_Df  151 0800
   Serial number: 3575H00AD12BB49273E
   Subsystem 2 - Part No SW: -----------    HW: 410 822 001 14
   Component: SideSensor_Pf  151 0800
   Serial number: 3585H00C112C12814095
   Subsystem 3 - Part No SW: -----------    HW: 442 151 109 15
   Component: SideSensor_Dr  1CA 0148
   Serial number: 3517A00C51C5CD93C2F+
   Subsystem 4 - Part No SW: -----------    HW: 442 150 609 15
   Component: SideSensor_Pr  1CA 0148
   Serial number: 3527A00B71C4E1E0E2F-
   Part No SW: 6C0 920 730 F    HW: 6C0 920 730 F
   Component: KOMBI         101 1420
   Coding: 0724010021000008010808000000000000000000
   VCID: 244C78B62F600B61AD-8070
9582599 - Switches in Instrument Panel
          B1238 07 [009] - Mechanical Failure
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:49:49
Address 19: CAN Gateway (J533)       Labels: 6C0-909-901-V1.clb
   Part No SW: 6C0 909 901     HW: 6C0 937 087
   Component: GW MQB A0     H08 0086
   Revision: --------    Serial number: 001578002554
   Coding: 01000008200A640071000000000000000001010000000000000000000000
   ASAM Dataset: EV_GatewA0Lear 013020
   ROD: EV_GatewA0Lear_VW26.rod
   VCID: 65CA25B264DA32697A-8030
Address 44: Steering Assist (J792)       Labels: 6Rx-909-144-V2.clb
   Part No SW: 6C1 909 144 AG    HW: 6C1 909 144 D
   Component: EPS_TRW_ALow  312 3232
   Serial number: PF9T1135
   Coding: 000600
   ASAM Dataset: EV_SteerAssisUDSTRW 016026
   ROD: EV_SteerAssisUDSTRW_SE26.rod
   VCID: 6DDA5D92BC2A0A2932-8038
1073664 - Steering End Stops Not Learned
          C10AC F0 [137] - Unknown Error Elaboration
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:56:28
1073920 - Steering End Stops Not Learned
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:56:28
6351360 - Crash Shut-Down Activated
          P1609 00 [137] - -
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:56:28
                    Engine speed: 778 /min
                    Vehicle speed: 0.00 km/h
                    System status: ERROR
                    Terminal 15 status: Terminal 15 on
                    Voltage terminal 30: 14.16 V
                    Power steering current consumption: 0.50 A
                    End stage temperature: 15 °C
                    Steering assistance: engine output: 0.00 %
                    Sensor for motor position: 0 °
                    Sensor for motor position: 0 /min
                    Steering assistance: target engine torque: 0.00 Nm
                    Steering torque: -0.17 Nm
                    Steering torque: OK
   Part No SW: 6C0 035 888 B    HW: 6C0 035 888 B
   Component: MU-E--ER      851 6490
   Serial number: 14091500010933
   Coding: 026200003C00000041110001010000001F0000840000010001
   ASAM Dataset: EV_MUEnt4CGen2LGE 001025
   ROD: EV_MUEnt4CGen2LGE_VW12.rod
   VCID: 2B5E938A42BEC4196C-807E
End-------------------------(Elapsed Time: 02:24)--------------------------
Tuesday,21,February,2017,15:24:32:48116
   Revision: 31H24000
   Coding: 0000A0
   Coding: 1000A0
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:49:49
   Coding: 000600
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
          P1609 00 [137] - -
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
                    Engine speed: 0 /min
                    Voltage terminal 30: 12.09 V
                    End stage temperature: 14 °C
                    Steering torque: -0.15 Nm
                    Steering torque: OK
End-------------------------(Elapsed Time: 02:31)--------------------------
Tuesday,21,February,2017,15:29:31:48116
   Revision: 31H24000
   Coding: 0000A0
   Coding: 1000A0
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 12:49:49
   Coding: 000600
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
          P1609 00 [137] - -
                    Reset counter: 7
                    Mileage: 6608 km
                    Date: 2016.12.20
                    Time: 13:13:10
                    Steering torque: OK
End-------------------------(Elapsed Time: 02:30)--------------------------
johanbrakelen
NL
hello,
how can i contact with Piotr Brzezina and how can i send credit to him?
german
Argentina
C?ID=239723
hola ayuda con error p1609 vw suran Saturday,11,March,2017,14:01:43:45710
VCDS Version: Release 17.1.3 Running on Windows 7 x86
Gergerman Toledo
                Address 44: Steering Assist       Labels: None
Control Module Part Number: 5Z1 909 144 D    HW: 5Z1 909 144
  Component and/or Version: EPS_ECU       401 4040
           Software Coding: 000F
            Work Shop Code: WSC 07456 790 50316
              ASAM Dataset: EV_SteerAssisNSKGen2 005107 (VW21)
                       ROD: EV_SteerAssisNSKGen2_005.rod
                      VCID: 3F8D7B2BA6CF32B9D0-806A
0054 - Steering angle sensor
          B1168 54 [137] - Missing Calibration / Basic Setting
                    Mileage: 13909 km
                    Date: 2011.14.05
                    Time: 00:11:08
                    Single Additional Freeze Frame:
0055 - Crash Shut-Down Activated
          P1609 00 [137] - -
                    Mileage: 13909 km
                    Date: 2011.14.05
                    Time: 00:11:08
0051 - Steering angle sensor
          B1168 29 [137] - Signal Implausible
                    Reset counter: 11
                    Mileage: 13909 km
                    Date: 2011.14.05
                    Time: 00:11:08
0043 - Steering angle sensor
                    Mileage: 13909 km
                    Date: 2011.14.05
                    Time: 00:11:08
0047 - Steering End Stops Not Learned
                    Mileage: 13909 km
                    Date: 2011.14.05
                    Time: 00:11:08
