MK7 LCD screen off after 10 sec sticky?
TDIjeff
Vic, Australia
C?ID=207789
My cable should be here tomorrow, but I can't wait to research.
The Disco Media 5.8 in our 2014 golf has a setting in Setup that allows my to tick a box to have the screen go blank after 10 sec. But I have to reselect it every start.
Is there a known bit to make it stick between starts ?
TDIjeff
Vic, Australia
C?ID=207789
Now that I am registered how or where do I try to ask for help with this even if just thinking out aloud on if this would be a coding or an adaption ?
Now that you're a registered user, I've moved this to the "Tweaks" section. I'd suggest posting an Auto-Scan so people can see exactly what modules are installed in this car.
TDIjeff
Vic, Australia
C?ID=207789
I think i have a handle on Coding Vs Adaption but still need to find a few examples of check boxes on the LCD that can be seen in the modules.
I'm still working with Ross-tech on missing LBL and ROD files:
Thursday,17,July,2014,22:52:53:32288
VCDS Version: 14.7.2.0 (x64)
Data version: 20140714
VIN: WVWZZZAUZEW######   License Plate: BETA14.7.2
Mileage: 1469km-912mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 15 16 17 19 42 44 52 55 5F
VIN: WVWZZZAUZEW######   Mileage: 1469km-912miles
Address 01: Engine (J623-CRBC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 DT    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5520
   Revision: 83H22---
   Coding: 011D0012042505082000
   ASAM Dataset: EV_ECM20TDI01104L906021DT 002004
   ROD: EV_ECM20TDI01104L906021DT_SK37.rod
   VCID: 7AD5188EFDA179EACD-802F
   Part No SW: 0D9 300 040 N    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4305
   Revision: 05852204    Serial number: TFK01401081786
   ROD: EV_TCMDQ250021_AU37.rod
   VCID: 226500EE35B1D12AB5-8077
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Revision: 00000000    Serial number: 603440000002A2
   Coding: 01FA8AA12420096E037F060641CC2980512490C0608294F300620038C202
   ROD: EV_Brake1UDSContiMK100IPB_VW37.rod
   VCID: 7BDB1D8AF29B40E2D6-802E
   Part No SW: 5G0 907 044 T    HW: 5G0 907 044 T
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 00120104200100001005000012101800
   ROD: EV_ACClimaBHBVW37X_SE37.rod
   VCID: 3851C286832DABFA7B-806D
   Air quality sensor:
   Part No SW: 5Q0 937 084 AE    HW: 5Q0 937 084 AE
   Component: BCM MQBAB H   H16 0124
   Serial number: 00011404101452
   Coding: 03001A42C24122FB4BE44000000C07081000000000000000000000000000
   ROD: EV_BCMBOSCH_SE37.rod
   Subsystem 1 - Part No SW: 5G2 955 119 A    HW: 5G2 955 119 A
   Component: WWS    140202  042 0551
   Serial number:         140205051417
   Component: RLFS  024 0042
   Serial number: Y14M02D15H03M30S11S7
   Coding: 00A8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 F    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H03 0142
   Revision: --------    Serial number: 39331403704817
   Coding: 0031151011
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3E5DD49EA10995CAB1-806B
   Part No SW: 5Q0 959 655 D    HW: 5Q0 959 655 D
   Serial number: 003F6R04JZWC
   Coding: 98CCC000000000005C00000000C800000065
   VCID: 41A7AF62D0F7EA32CC-8014
   Subsystem 1 - Part No SW: -----------    HW: 480 000 302 14
   Serial number: 35767000000E7905DE04
   Subsystem 2 - Part No SW: -----------    HW: 480 000 302 14
   Serial number: 35867000000079889E0+
   Subsystem 3 - Part No SW: -----------    HW: 480 400 602 14
   Serial number: 3516502BF13013F263C8
   Subsystem 4 - Part No SW: -----------    HW: 480 400 602 14
   Serial number: 35265029913013F1022Q
   Subsystem 5 - Part No SW: -----------    HW: 480 400 302 14
   Serial number: 3556502B512AB1B253CE
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 P    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0135
   Revision: FF027027    Serial number: 20140205500196
   Coding: 0410
   ROD: N/A
   VCID: 3FA3A99AA6039CC2BA-806A
No ASAM data for: "EV_SMLSVALEOMQB" (VW37)
   Part No SW: 5G0 920 861 A    HW: 5G0 920 861 A
   Component: KOMBI         252 2210
   Coding: 27A519082B80000801086A00040000
   VCID: 277311FA5E933402E2-8072
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001606941
   Coding: 030100340B087300EF00024A1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_AU37.rod
   Subsystem 2 - Part No SW: 5G0 959 442 M    HW: 5G0 959 442 M
   Component: E221__MFL-DC1  H06 0101
   Serial number: 29140000108820074051
   Coding: 29FFFF
   Serial number: 1343122503
   Serial number: 27011402090107
   Coding: 003A03208001040000000000
   ROD: EV_DCUDriveSideEWMAXKLO.rod
   VCID: 40A1AA66DBFDE33AC3-8015
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001778845
   Coding: 1D0000
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 0103
   ROD: EV_SteerAssisMQB.rod
   VCID: 354FCBB2943F569260-8060
   Serial number: 26011403110867
   Coding: 003A03208E01040000800000
   ROD: EV_DCUPasseSideEWMAXKLO.rod
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001765921
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E01000B000200
   VCID: 3D5FD392AC0F8ED2A8-8068
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
   Part No SW: 5G0 035 846 A    HW: 5G0 035 846 A
   Component: MU-S-N-ER     040 0430
   Serial number: V1F00602143026
   Coding: 02730008FF00000011510001000900001F0206960100010245
   ROD: EV_MUStd4CPASE_SE37.rod
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5G0 919 605 D    HW: 5G0 919 605 D
   Component: ABT_Std_Nav  H51 0022
   Serial number: VWZ8Z9PJ903H6K
   Engine Control Module 2:
   Subsystem 2 - Part No SW: 5G0 919 866 G    HW: -----------
   Component:  ROW 2014  --- 0027
End---------------------(Elapsed Time: 02:47, Deb=2)-----------------------
Forgot to mention that address-76 Park assist was not found in any of my scans:
;VCDS Version: Beta 14.7.2 (x64)  Data version: 20140714
;SW:5Q0-919-294-F   HW:5Q0-919-294-A ---  Park Assist
;Component:PARKHILFE 8K  H03 0142
;EV_EPHVA18AU3700000	2024
 Coding:0031151011
Audio reduction request	On
Deactivate production mode	0
Park assist activation tone	On
Speaker frequency for front park assist	Stage 6
Speaker frequency for rear park assist	Stage 4
Speaker volume for front park assist	Stage 4
Speaker volume for rear park assist	Stage 6
Switch-off speed for parking assist	15 km/h
