Audi A3 8V MY2015 with installed Android screen reeplacement
FrA1l3
Spain
C?ID=66925
Hello!
I change my basic oem screen 5.8" to a new Android system with 7" touch screen. I left the original LVDS cable disconnected and now I want to know if there is any way to disable the check of the screen so that I do not leave errors in the module 5F.
I have seen several options in the module so I do not check the data ring wire, but I do not know if something will spoil.
I think there should be some option like the cold check of the bulbs.
For example I disabled Byte 20, Bit 0 in module 5F, but it gives me error equally:
Anyway, I show you the autoscan, if you can help me with the autoscan errors that come out I will be very grateful:
Thursday,19,January,2017,08:55:12:65093
VCDS Version: 17.1.1.2 (x64)
Data version: 20170107 DS267.0
VIN: WAUZZZ8V5GAXXXXXX   License Plate: xxxxxx
Mileage: 23226km-14431mi   Repair Order:
Chassis Type: 8V (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F BB BC
VIN: WAUZZZ8V5GAXXXXXX   Mileage: 23226km-14431miles
Address 01: Engine (J623-CJSA)       Labels: 06K-907-425-V1.clb
   Part No SW: 8V0 906 264 H    HW: 06K 907 425 B
   Component: 1.8l R4 TFSI  H13 0005
   Revision: --H13---
   Coding: 0A1900122424010B2000
   Shop #: WSC 06314 790 00021
   ASAM Dataset: EV_ECM18TFS0208V0906264H 001007
   ROD: EV_ECM18TFS0208V0906264H_VW37.rod
   VCID: 41A78D1ED0778F4994-8014
   Part No SW: 3Q0 907 379 AA    HW: 3Q0 907 379 F
   Component: ESC           H42 0623
   Revision: 00000000    Serial number: 63205000001966
   Coding: 12F16AA234292A6E037F060541C82948562C54C0608294F5024100788408
   ROD: EV_Brake1UDSContiMK100IPB_034_VW48.rod
   VCID: 79D725FEF82717899C-802C
Address 08: Auto HVAC (E87)       Labels: 8V0-820-043.clb
   Part No SW: 8V0 820 043 C    HW: 8V0 820 043 C
   Component: AC Automat    H14 0060
   Revision: 20028000    Serial number: 00000000798795
   Coding: 03000014000000011000000000001100
   VCID: 3245D2D265D124D11D-8066
   Serial number: 9688CAD7000000000001
   Part No SW: 5Q0 937 084 AS    HW: 5Q0 937 084 AN
   Serial number: 01061532900399
   Coding: 04140C42C24106FD03844004B31C07A80000000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 0937553EA8C707098C-805C
   Subsystem 1 - Part No SW: 8V1 955 119 A    HW: 8V1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS370 151031  043 0580
   Serial number:         151114203816
   Coding: 0A47F7
   Serial number: 60984252
   Coding: 06006C
   Serial number: 02 09 2015  00001152
   Serial number: 000000000ZY15285372G
   Component: Sirene, DWA  005 0312
   Serial number: 00000000000034048878
   Sun Roof:
   Subsystem 6 - Part No SW: 8V3 959 591 A    HW: 8V3 959 591 A
   Component: J245 PS73.404  H03 0004
   Serial number: 0000FST000NG8CN00000
   Coding: 901E00
   Part No SW: 5Q0 959 655 N    HW: 5Q0 959 655 N
   Component: AirbagVW20    012 0361
   Serial number: 003M2R19FF8G
   Coding: 98CCC0000C0000005C5400CA004800000065
   VCID: 4BBBAF36E23B55197E-801E
   Subsystem 1 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 357670000001CC19B71$
   Subsystem 2 - Part No SW: -----------    HW: 480 002 011 15
   Serial number: 358670000005CC19B711
   Subsystem 3 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3516502C51DCBE14A34Q
   Subsystem 4 - Part No SW: -----------    HW: 480 401 711 15
   Serial number: 3526502AD1DBD610E21M
   Subsystem 5 - Part No SW: -----------    HW: 480 400 611 15
   Serial number: 3556502AB1D25F0552FO
   Pedestrian Protection Driver:
   Subsystem 6 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_D  001 6149
   Serial number: 2286502A11D3F97211CE
   Subsystem 7 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_P  001 6149
   Serial number: 2296502AD1D3F973E10T
   Pedestrian Protection Center:
   Subsystem 8 - Part No SW: -----------    HW: 480 402 810 15
   Component: PedP_Sensor_C  001 6149
   Serial number: 2306502C11D73C637355
   Part No SW: 8V0 953 521 EH    HW: 5Q0 953 549 E
   Component: Lenks. Modul  003 0120
   Revision: --------    Serial number: 22111504400195
   Coding: A408
   ASAM Dataset: EV_SMLSKLOMQB 020001
   ROD: EV_SMLSKLOMQB_SK48.rod
   VCID: 0429440A8FE55A61FF-8050
   Part No SW: 8V0 920 871 R    HW: 8V0 920 871 R
   Component: KOMBI         H03 6423
   Coding: 07AD09002B8000080500AE041000000000000000
   ROD: EV_DashBoardVDDMQBAB_009_AU37.rod
   Part No SW: 5Q0 907 530 AJ    HW: 5Q0 907 530 F
   Component: GW MQB High   128 1243
   Revision: --------    Serial number: 0004211358
   Coding: 030100043F085A005B000248080B00000001010000000000000000000000
   ROD: EV_GatewLear_013.rod
   Subsystem 2 - Part No SW: 8U0 951 528 A    HW: 8U0 951 528 A
   Serial number: 13 11 2015  B0038624
   Subsystem 3 - Part No SW: 5Q0 915 181 H    HW: 5Q0 915 181 H
   Component: J367-BDMConti  H02 1011
   Serial number: 74185704001511251892
   Serial number: 300915BIT20366
   Coding: 001C8A205C00040000001002
   VCID: 43AB8716CA6B9D5986-8016
   Part No SW: 5Q0 909 144 S    HW: 5Q0 909 144 R
   Component: EPS_MQB_ZFLS  125 1063
   Coding: 8103
   VCID: 44A9840ACF659A61BF-8010
   Serial number: 081015BJ708753
   Coding: 001C82205E00040000001002
   VCID: 42A58212D57194518D-8016
   Component: AFS-ECU       H01 0110
   Coding: 019A00002B200200
   VCID: 3FA38BE6A683F9B9E2-806A
   Coding: E00100
   Coding: E00100
   Subsystem 3 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 7050
   Coding: E00100
   Subsystem 4 - Part No SW: 7PP 941 329 M    HW: 7PP 941 329 M  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 7050
   Coding: E00100
[COLOR="#FF0000"]Address 5F: Information Electr. (J794)       Labels: 8V0-035-MIB-STD1.clb
   Part No SW: 8V0 035 864 C    HW: 8V0 035 864 B
   Component: MU-S-N-ER     042 0461
   Serial number: A3F01911150752
   Coding: 01730301FF00000031110001000A00032F0004140000010006
   Shop #: WSC 12345 123 61029
   ASAM Dataset: EV_MUStd4CPASE 002018
   ROD: EV_MUStd4CPASE_AU37.rod
   VCID: 3B5BFFF6B29BE599CE-806E
   Multimedia Operating Unit:
   Subsystem 1 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
   Component: ControlUnit_B  H41 0054
   Serial number: C1000010091500040278
          U1014 00 [009] - -
                    Reset counter: 133
                    Mileage: 22470 km
                    Date: 2016.12.29
                    Time: 19:51:50
                    Voltage terminal 30: 11.9 V
                    Byte_Coding_Condition-byte_8_condition: ERROR
3077 - Telephone baseplate
          B1051 13 [009] - Open Circuit
                    Reset counter: 133
                    Mileage: 22470 km
                    Date: 2016.12.29
                    Time: 19:51:50
6660 - No Communications with Display Unit 1 for Multimedia
          U10E2 00 [009] - -
                    Fault Frequency: 56
                    Reset counter: 170
                    Mileage: 22470 km
                    Date: 2016.12.29
                    Time: 19:51:52
6691 - Data Bus for Control/Display
          U10AD 00 [008] - No Communications
                    Reset counter: 190
                    Mileage: 22790 km
                    Date: 2017.01.06
                    Time: 17:35:16
                    Voltage terminal 30: 12.5 V[/COLOR]
Address BB: Door Rear Drv (J388)       Labels: None
   Serial number: 271015BJP1113A
   Coding: 000C82204000040000001002
   VCID: 45AF990EC45FA369A8-8010
Address BC: Door Rear Pass (J389)       Labels: None
   Serial number: 271015BJ80992A
End-------------------------(Elapsed Time: 03:24)--------------------------
And this is the previous scan for this module before I changed the screen
Tuesday,01,November,2016,16:04:17:65093
VCDS Version: 16.8.3.1
VIN: WAUZZZ8V5GAXXXXXX   Mileage: 19045km-11834miles
   Coding: 01730301FF00000021110001000A00032F0004040100010006
   VCID: 3B5BFFF6B29BE59AA9-806E
   Subsystem 1 - Part No SW: 8V0 919 603 C    HW: 8V0 919 603 C
   Component: DU Std  H49 0014
   Serial number: AUZ8Z9FY30EPHG
   Subsystem 2 - Part No SW: 8V0 919 614 P    HW: 8V0 919 614 P
best regards
