Auto Scan posted. Need info pleas
Dj Chris Roxx
C?ID=209411
I have aftermarket headlight and HID kit. I removed fog lights as well. Flat bottom R8 (not functions are working including horn) with B7 slip ring & control module. And pretty much all fault lights on dash are on. Please check out my scan info and avise me. Thanks Ross-Tech, techs.
VCDS Version: Release 12.12.2
Data version: 20140212
Tuesday,04,March,2014,12:47:24:34624
Chassis Type: 8H (8H - Audi Cabrio B6/B7 (2003 > 2009))
Scan: 01 02 03 08 09 0F 11 15 16 17 18 25 26 36 37 45 46 55 56 57
          63 65 67 73 75 76 77
VIN: WUARL48H46K900514   Mileage: 132170km/82126miles
Address 01: Engine        Labels: 079-910-560-BBK.lbl
   Part No SW: 8H2 910 560     HW: 008 H29 075 60
   Component: 4.2L V8/5V      G   0010
   Revision: --H01---    Serial number: AUX6Z0E0090568
   Coding: 0007714
   Shop #: WSC 00672 785 00200
   VCID: E7DD31ABD5EA1426BAD-5122
16522 - Oxygen (Lambda) Sensor B1 S2
            P0138 - 001 - Signal too High - Intermittent
                    Fault Status: 00100001
                    Mileage: 132165 km
                    RPM: 735 /min
                    Load: 23.9 %
                    Temperature: 99.0°C
                    Temperature: 66.0°C
                    Absolute Pres.: 0.0 mbar
                    Voltage: 13.716 V
16523 - Oxygen (Lambda) Sensor B1 S2
            P0139 - 004 - Response too Slow
                    Mileage: 132169 km
                    RPM: 1436 /min
                    Load: 13.3 %
                    Speed: 38.0 km/h
                    Temperature: 89.0°C
                    Temperature: 34.0°C
                    Voltage: 13.716 V
16420 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
            P0036 - 004 - Malfunction / Open Circuit - Intermittent
                    Fault Frequency: 29
                    Mileage: 132169 km
                    RPM: 1045 /min
                    Load: 29.0 %
                    Temperature: 7.0°C
                    Temperature: 9.0°C
                    Voltage: 13.716 V
Readiness: 0100 0101
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517 Q
   Component: ABS/ESP allrad      4533
   Coding: 04597
   Shop #: WSC 57389
   VCID: 36632CEF12C03DAE71B-5106
            35-00 - -
   Part No: 8E0 820 043 BM
   Component:   A4 Klimaautomat   2832
   Coding: 00100
   Shop #: WSC 00672
   VCID: 6DD1C3832716BE76401-5122
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 F
   Component: int. Lastmodul  USA 0517
   Coding: 01013
   Shop #: WSC 00672
   VCID: 35612BE30FC636B6781-4AE8
            57-00 - Electric Circuit Failure
   Part No SW: 8E0 035 593 D    HW:
   Component: SDAR SIRIUS
   Revision:             Serial number: AUZ4Z7E2015721
   VCID: 2A5B089F8678694EE53-515E
Address 15: Airbags        Labels: 8H0-959-655-84.lbl
   Part No: 8H0 959 655 D
   Component: Airbag 8.4EC        0015
   Coding: 0010105
   VCID: 3B753DDB79E2E0C68E5-5140
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No: 8E0 953 549 Q
   Component: Lenksáulenmodul     0801
   Coding: 00042
   VCID: 41894F334B0E8A16D49-4AE8
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No SW: 8H0 920 980 S    HW: 8H0 920 980 S
   Component: KOMBI+WFS 3     H12 0030
   Revision: 0030        Serial number: AUX6Z0E0090568
   Coding: 0017231
   Shop #: WSC 01115 444 68394
   VCID: 3F8D49CB6DFAFCE6A2D-5122
Address 25: Immobilizer        Labels: 8E0-920-9xx-8E2.lbl
   Coding: 0017231
Address 26: Auto Roof        Labels: 8H0-959-255.lbl
   Part No: 8H0 959 255 B
   Component:  VSG  B6 CABRIO     6593
   VCID: 35612BE35FC636B6781-5140
   Part No: 8H0 959 760
   Component: Sitzmemory EE H06   0010
   Coding: 00002
   Shop #: WSC 00065
   VCID: F4E756E7C43CEFBE0FF-4B00
01447 - Sensor for Driver Seat; Height Adjust (G231)
            36-00 - Open Circuit
Address 37: Navigation        Labels: None
   Part No SW: 8H0 035 192 D    HW: 8H0 035 192 D
   Component: RNS-E US        H70 0040
   Revision:      01S    Serial number: AUZBZ7E2101024
   Coding: 0419637
   VCID: 285FF29798745B5EF37-517C
                    Fault Status: 01101000
                    Reset counter: 188
                    Date: 2004.09.09
                    Time: 16:29:46
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8H0 959 433 E
   Component: Komfortgerát T7B    3320
   Coding: 11788
   Shop #: WSC 00672
   VCID: 36632CEF12C03DAE71B-4AE8
   Subsystem 1 - Part No: 8H1959801B
   Component: Tõrsteuer.FS BRM 3020
   Subsystem 2 - Part No: 8H1959802B
   Component: Tõrsteuer.BF BRM 3020
   Subsystem 3 - Part No: 8H0959801A
   Component: Tõrsteuer.HL BRM 0002
   Subsystem 4 - Part No: 8H0959802A
   Component: Tõrsteuer.HR BRM 0002
00955 - Key 1
            35-10 - - - Intermittent
Address 55: Xenon Range        Labels: 4Z7-907-357.lbl
   Part No: 4Z7 907 357
   Component: dynamische LWR       D09
   Coding: 00070
   Shop #: WSC 00672
   VCID: 04078627149C5F3EBFF-4B1A
            30-00 - Open or Short to Plus
Address 56: Radio        Labels: None
   Coding: 0419637
   VCID: 285FF29798745B5EF37-5140
                    Reset counter: 188
                    Date: 2004.09.09
                    Time: 16:29:46
Address 63: Entry Assist,D        Labels: None
   Part No: 8H0 959 760 A
   Component: EasyEntry F M H13   0010
   Coding: 00006
   Shop #: WSC 00065
   VCID: 35612BE30FC636B6781-4B00
Address 65: Tire Pressure        Labels: 8E0-907-273.lbl
   Part No SW: 8E0 907 273     HW: 8E0 907 273
   Component: Reifendruck 3   H03 0110
   Coding: 0062825
   VCID: E9D93793C3FE2256AC9-5140
                    Fault Status: 11100100
                    (no units): 19.0
                    Voltage: 13.70 V
                    (no units): 61.0
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
02214 - Tire Pressure Warning
                    Fault Frequency: 19
                    (no units): 0.0
                    Temperature: 40.0°C
                    Error Code: 1
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
                        Not Recogn.
Address 73: Entry Assist, P        Labels: None
   Component: EasyEntry BF  H13   0010
   Coding: 00005
   Shop #: WSC 00065
   VCID: 35612BE30FC636B6781-4B1A
Address 76: Park Assist        Labels: 8Z0-919-283.lbl
   Part No: 8Z0 919 283 A
   Component: Parkingsyst. A4 USA D09
   Coding: 00125
   Shop #: WSC 00672
   VCID: 4385453B51129806C65-5122
01545 - Sensor for Parking Aid; Rear Left (G203)
            37-00 - Faulty
01548 - Sensor for Parking Aid; Rear Right (G206)
            37-00 - Faulty
   Part No SW: 8P0 862 335 B    HW: 8P0 862 335 B
   Component: FSE_255x BT     H18 0160
   Revision: 00000001    Serial number: 00000000302542
   Coding: 0000807
                    Fault Frequency: 12
                    Reset counter: 93
                    Time Indication: 15
There's no obvious way to code out fog lights in that module. I suspect Audi used a different module depending on whether the car did or didn't have fog lights. My guess is the only way to pacify that module is to give it dummy loads, or to replace it with a module from a car that didn't have fog lights. If anyone knows different, please chime in.
