Passat CC (2010) ABS fault after Steering assistance flash
sers77
Norway
C?ID=26140
So i had a fault code on (44) Steering assistance and the characteristics was 0, so i flashed 5N1909144R_1401_BP.sgo and character v074B2035N1.
Now there is a fault on ABS and i also have this code on Address (44) Meas Blocks 08, CH 08, window 1 is fault code "2", (window 2) fault code "2" and (window 4) is 16384.
I think that has to do with the DCC-system (Dynamic Chassis Control) but as seen in the scan, there is no fault on that system!?!?
So is there some basic settings that needs to be done or is the BP file (5N1909144R_1401_BP.sgo) not compatible with DCC?
The first flash i did (with 5N1909144N_1101.sgo) couldn´t get the characteristics file to "stick" (after characteristics flash it was still 0).
Tuesday,17,January,2017,16:14:56:07409
VCDS Version: 16.8.4.2 (x64)
VIN: WVWZZZ3CZAE549339   License Plate: PASSAT CC
Mileage: 100270km-62304mi   Repair Order:
Chassis Type: 3C (3C0)
Scan: 01 03 08 09 10 14 15 16 17 19 22 25 42 44 46 47 4F 52 53 55
          62 69 6C 72
VIN: WVWZZZ3CZAE549339   Mileage: 100270km-62304miles
Address 01: Engine (CBA)       Labels: 03L-906-022-CBA.clb
   Part No SW: 03L 906 022 QE    HW: 03L 907 309
   Component: R4 2,0L EDC G000SG  6210
   Revision: 13H03---    Serial number: VWZCZ000000000
   Coding: 0000172
   Shop #: WSC 00490 218 182313
   VCID: 78FB10340BCFBA82F1-802C
   Part No SW: 3C0 614 109 AF    HW: 3C0 614 109 AF
   Component: J104    C4 440 V2   0015
   Revision: --025---    Serial number: 00000705159838
   Coding: 0002320
   Shop #: WSC 05311 123 12345
   VCID: 62CF525CBD534052BF-8036
                    Fault Status: 01101000
                    Reset counter: 155
                    Mileage: 100276 km
                    Date: 2011.06.10
                    Time: 16:08:27
                    Hex Value: 0x0000
                    Voltage: 12.25 V
                    Bin. Bits: 00011111
                    Count: 221
                    Hex Value: 0x0000
   Part No SW: 5K0 907 044 CC    HW: 5K0 907 044 CC
   Component: Climatronic   H15 0709
   Revision: 00003001
   Coding: 0000000002
   Shop #: WSC 05311 115 00000
   VCID: 6ED7366CB18BF4322B-803A
   Part No SW: 3C8 937 049 F    HW: 3C8 937 049 F
   Revision: 00H54000    Serial number: 00000003669868
   Coding: EBE28F0100041A0047978F0017000000001FFB4764400165174000000000
   Shop #: WSC 00490 218 55350
   VCID: 3463E40457279EE21D-8060
   Subsystem 1 - Part No: 3C8 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer 300110 022  0613
   Coding: 00046997
   Shop #: WSC 00490
   Component: RLS     210210 054  0403
   Coding: 00274605
   Shop #: WSC 00490
Address 10: Park/Steer Assist (J446)       Labels: 3C8-919-475.clb
   Part No SW: 3C8 919 475 A    HW: 3C8 919 475
   Component: PARKHILFE 8K  H07 0009
   Revision: --------    Serial number: 08721004801538
   Coding: 310001
   Shop #: WSC 05314 000 00000
   VCID: 326FE21C6D3390D20F-8066
Address 14: Susp. Elect. (J250)       Labels: 3C0-907-376.clb
   Part No SW: 3C0 907 376 A    HW: 3C0 907 376
   Component: DAEMPFUNGS-SG H07 0070
   Revision: 00000000    Serial number: 15021003050001
   Coding: 010180
   VCID: 2759034856F1E57AA8-8072
   Part No SW: 5N0 959 655 J    HW: 5N0 959 655 J
   Component: J234__304 VW10 HI   1916
   Revision: 20013000    Serial number: 003E2P2ZSE3/
   Coding: 0012340
   Shop #: WSC 05311 000 00000
   VCID: 4483B4C407872E62AD-8010
   Subsystem 1 - Serial number: 6332MTS606550210
   Subsystem 2 - Serial number: 6342MTS639630290
   Subsystem 3 - Serial number: 6351HTS654NU76KR
   Subsystem 4 - Serial number: 6361HTS6TF5H86KJ
   Part No SW: 5K0 953 569 T    HW: 5K0 953 569 T
   Revision: --X01---    Serial number: 20120322301240
   Coding: 1182270002
   VCID: 499DA5F0E8A5F30A5E-801C
   Coding: E20000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3C8 920 880 G    HW: 3C8 920 880 G
   Component: KOMBI         H03 0132
   Coding: 140D00
   Shop #: WSC 05314 115 12345
   VCID: 306BE8146B3FA2C279-8064
Address 19: CAN Gateway        Labels: 3C0-907-530-V3.clb
   Part No SW: 3C0 907 530 N    HW: 3C0 907 951
   Component: J533  Gateway   H14 0172
   Revision:   H14       Serial number: 1021G102170198
   Coding: F9AB7F46104003009002
   Shop #: WSC 05314 123 12345
   VCID: 2C53FC648F17C62245-8078
   Part No SW: 0BS 907 554 A    HW: 0BS 907 554 A
   Component: Haldex 4Motion      4013
   Coding: 0000005
   Part No SW: 3C0 959 433 AR    HW: 3C0 959 433 AR
   Component:    IMMO         043 0383
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 7AFF0A3C35C3A89287-802E
   Subsystem 1 - Part No: 3C0 905 861 H
   Component:    ELV          028 0380
   3C0905861H     ELV          028 0380
   Part No SW: 1T0 959 701 AG    HW: 3C0 959 793 A
   Component: TUER-SG FT    002 0307
   Revision: 12101005    Serial number: 0000451781
   Coding: 0000B5
   ROD: EV_DCU42BroseDriveSide.rod
   VCID: 7CF30C24F7F796A295-8028
   Slave Driver:
   Subsystem 1 - Part No SW: 3C8 959 703 C    HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0401
   Serial number: 00000001300562
   Coding: 000090
   Part No SW: 5N1 909 144 K    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.203 1401
   Revision: 1AH03726    Serial number: 00093300194802
   Coding: 0000258
   VCID: 3A7FCA3C75436892C7-806E
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ46 ELV 043 0612
   Coding: 00910A0001860E763606941570084F0B607C01
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   Component: KonzernAmp 8K H06 0340
   Revision: --------    Serial number: BP218109077644
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 67D943489E71257A68-8032
   Part No SW: 1K0 907 532     HW: 3C0 907 951
   Component: EZE_2         H14 0172
   Revision: --------    Serial number: 1021G102170198
   Coding: 01030100
   VCID: 66C74E4C917B3C7253-8032
   Subsystem 1 - Part No SW: 6R0 959 591     HW: 6R0 959 591
   Component: J245/J878  H04 0054
   Serial number: 003400000343
   Coding: 000006
   Part No SW: 1T0 959 702 AC    HW: 3C0 959 792 A
   Component: TUER-SG BT    002 0307
   Revision: 14101005    Serial number: 0000476709
   Coding: 0000B4
   ROD: EV_DCU52BrosePasseSide.rod
   VCID: 79FD1530F8C5A38A8E-802C
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C8 959 704 C    HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0401
   Serial number: 00000001297125
   Coding: 000090
   Part No SW: 3C8 907 801 E    HW: 3C8 907 801 E
   Component: J540 EPB3  VW-15417 0007
   Revision:   010       Serial number: 00000000175112
   Coding: 0000057
   Component: AFS-Steuergeraet    0142
   Coding: 3525832
   Subsystem 1 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    0007
   Coding: 00000053
   Subsystem 2 - Part No: 1K0 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul r    0007
   Coding: 00000053
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 -  -
                    Reset counter: 155
                    Mileage: 100276 km
                    Date: 2011.06.10
                    Time: 16:08:41
                    Voltage: 12.21 V
                        ABS 1
Address 69: Trailer (J345)       Labels: 1K0-907-383-V2.clb
   Component: Anhaenger     H07 0070
   Revision: 3A001001    Serial number: 00000127021014
   Coding: 410D000100000000
   VCID: 306BE814633FA2C279-8064
   Part No SW: 3C8 907 441     HW: 3C8 907 441
   Component: J772__Rearview      0036
   Revision: 00H06000    Serial number: 525PA8-J011279
   Coding: 0030008
   Shop #: WSC 53302 002 1048576
   VCID: 67D943485671257A68-8032
End-------------------------(Elapsed Time: 02:44)--------------------------
TBAx
C?ID=287144
After flashing a _BP to an APA-BS rack, no basic settings have to be performed, so this should not be the issue here.
But, it is possible that the flash reinitialized the the adaption values. Have you checked, that those are still correct?
sers77
Norway
C?ID=26140
Yes, but only the ones who require security access (DSR, Park Steer Assist, TSC, Lane Assist and DCC).
The only one Active in adaption is DCC and when (if) all is well i will activate DSR.
golfi_vend
Tartu, Estonia
C?ID=195131
This is very weird fault. I have had this many times. Change the DSR setting in steering rack 0 to 1 or opposite and than back to original.
Clear fault.
sers77
Norway
C?ID=26140
Hehe, omg if this is the solution :banghead:
It´s not getting easier to erase fault codes :facepalm:
Thank you, and i will try this :thumbs:
sers77
Norway
C?ID=26140
So, golfi_vend... that was 100% correct, but i couldn´t erase it with VCDS (not even with 17.1.2) so i had to use my other tool.
Thank you...!
golfi_vend
Tartu, Estonia
C?ID=195131
Thank you...!
Did you cycle ignition?
sers77
Norway
C?ID=26140
No, but it cleared anyway.
Didn´t cycle ignition with VCDS, but never needed it before (but now i will)...
No retrofits, so far :)
Gone But Not Forgotten
These 0x44 module flash files have all the same PR-codes?
Coding: 0000258
An N an R & a K............hmmmmmm right
golfi_vend
Tartu, Estonia
C?ID=195131
Relax Jack.
This fault also occurs when battery is removed or moon phace is out, not only after reflash.
I had my co-worker to autoscan a B6 and this fault was present. He was very surprised about it. I relaxed him and said, it's normal and i have no idea why this happens, but here's the fix. :)
