2013 S5 abs/esp faults
hans j
Utah
C?ID=60436
I'm just getting into this car, but I haven't seen these faults before so I'm asking for a little help so I don't waste my day.
Customer is complaining about the park brake light, ABS light, and lane assist light being on. He did do the auto hill hold modification two years ago.
I found the location of the G419 under the drivers floor, so I'm going to check for moisture and clogged sunroof drains.
Any thoughts or point me in some direction? I don't see many of these since they are usually in warranty.
Friday,13,January,2017,09:46:47:05734
VCDS Version: 16.8.4.2 (x64)  HEX-NET CB: 0.4321.4
VIN: WAU3GAFR0DA021884   License Plate:
Mileage: 99250km-61671mi   Repair Order:
Chassis Type: FR (8R0)
Scan: 01 03 05 06 08 09 13 14 15 16 17 19 1B 22 36 3C 42 44 46 47
          52 53 56 5F 6C A9
VIN: WAU3GAFR0DA021884   Mileage: 99250km-61671miles
Address 01: Engine (J623-CGXC)       Labels: 06E-907-551-CGW.clb
   Part No SW: 8K5 907 551 E    HW: 4G0 907 551 A
   Component: 3.0l V6 TFSIH07 0002
   Revision: --H07---
   Coding: 1A190034054600060000
   Shop #: WSC 06208 000 00000
   ASAM Dataset: EV_ECM30TFS0218K5907551E 001002
   ROD: EV_ECM30TFS0218K5907551E.rod
   VCID: B83C687E03456D82B1-80EC
6628 - Function Restriction due to Faults in Other Modules
          U1113 00 [045] - -
                    Fault Frequency: 34
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:29
                    Engine speed: 2681.00 /min
                    Normed load value: 47.1 %
                    Vehicle speed: 113 km/h
                    Coolant temperature: 92 °C
                    Intake air temperature: -18 °C
                    Ambient air pressure: 800 mbar
                    Voltage terminal 30: 14.319 V
                    Engine speed: actual: 0 /min
                    MAF_ENVD: 0.00000 mg/stroke
                    Coolant temperature (unfiltered): 7.50 °C
                    Engine: operating status: ES
                    Engine load: 0.000000 %
                    Vehicle speed: actual: 0 km/h
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 CK    HW: 8K0 907 379 CK
   Component: ESP8 quattro  H09 0100
   Coding: 282D1A
   Shop #: WSC 28826 001 104857
   VCID: 8444CC8E070DF9626D-80D0
00493 - ESP-Sensor Unit (G419)
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Hex Value: 0x5E00
                    Hex Value: 0x4006
                    Hex Value: 0x1206
                    Hex Value: 0xB5B4
                    Hex Value: 0x0000
03033 - ESP Sensor Unit 2 (G536)
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Hex Value: 0x5E00
                    Hex Value: 0x4006
                    Hex Value: 0x122A
                    Hex Value: 0xBCB4
                    Hex Value: 0x0000
01324 - Control Module for All Wheel Drive (J492)
            013 - Check DTC Memory
                    Fault Status: 01101101
                    Fault Frequency: 9
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Hex Value: 0x5E00
                    Hex Value: 0x4006
                    Hex Value: 0x120E
                    Hex Value: 0x50B4
                    Hex Value: 0x0000
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Hex Value: 0x5E00
                    Hex Value: 0x4206
                    Hex Value: 0x121A
                    Hex Value: 0x02B4
                    Hex Value: 0x0000
02214 - Tire Pressure Warning
            000 -  -  - Intermittent
                    Reset counter: 135
                    Mileage: 98612 km
                    Date: 2017.01.09
                    Time: 13:16:50
                    Hex Value: 0x6A00
                    Hex Value: 0x4006
                    Hex Value: 0x1221
                    Hex Value: 0x18B8
                    Hex Value: 0x0000
   Part No SW: 8K0 907 064 GP    HW: 8K0 907 064 FP
   Component: BCM2 2.0      H11 0621
   Coding: 0F804000000000000000
   Shop #: WSC 06325 000 00000
   Subsystem 1 - Part No SW: 8K0 959 754 AB    HW: 8K0 959 754 AB
   Serial number: 0512000049350016
   Serial number: 2312000157070009
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 E    HW: 8T0 959 760 E
   Component: MEM-BFS       H10 0076
   Revision: AA000000    Serial number: 00000035621134
   Coding: 00037025002C00000000
   VCID: C5C2118A4CB7006A3A-8090
   Part No SW: 8K1 820 043 T    HW: 8K1 820 043 T
   Revision: C1000000    Serial number: 01050820120420
   Coding: 6602228000
   Shop #: WSC 28826 001 1048576
   VCID: B93A6D7A304F748A4E-80EC
   Part No SW: 8K0 907 063 DJ    HW: 8K0 907 063 DJ
   Revision: 09016001    Serial number: 00000457896401
   Coding: 26000091863CAFF23C0048C300003D0D0F9C9388A2090221000008000000070200020030000000
   VCID: FAB8B27675C9BF9207-80AE
   Subsystem 1 - Part No SW: 8T1 955 119 D    HW: 8J1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 310712  H15 0080
   Serial number: SWF12070315476
   Coding: 00FD11
   Serial number: 20473751
   Coding: 02005D
   Component: E1 - LDS  H03 0031
   Serial number: 00000000001907121791
   Component: USHL4.2  H30 0030
   Serial number: 0000002274555R2EL902
   Subsystem 5 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 6 - Part No SW: 8K5 941 329     HW: 8K5 941 329
H01 0031
   Subsystem 7 - Part No SW: 4H0 907 658     HW: 4H0 907 658
   Serial number: A908C046000000000001
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 8K0 907 561 B    HW: 8K0 907 561 B
   Component: ACC3          H09 0100
   Coding: 00333E
   VCID: B12A555AE83FBCCAF6-80E4
                    Fault Frequency: 23
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
                    Temperature: 240.0°C
                    Voltage: 14.34 V
                    Hex Value: 0x00C5
                    Speed: 111.6 km/h
                    Lateral Accel.: -0.06 m/s^2
                    Fault Frequency: 34
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
                    Voltage: 14.34 V
                    Hex Value: 0x00BE
                    Speed: 111.6 km/h
                    Fault Frequency: 30
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
                    Voltage: 14.34 V
                    Hex Value: 0x00C0
                    Speed: 111.6 km/h
                    Lateral Accel.: -0.04 m/s^2
Address 14: Susp. Elect. (J250)       Labels: None
   Part No SW: 8R0 907 364 C    HW: 8K0 907 364
   Component: DAEMPFUNGS-SG H09 0054
   Revision: 00000000    Serial number: 24071202800001
   Coding: 070181
   VCID: BA38727635497F9247-80EE
                    Fault Frequency: 23
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:29
                    Bin. Bits: 00000000 00000110
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 P    HW: 8K0 959 655 P
   Serial number: 003KJD90HSR7
   Coding: 303343334830303030304A55304C38543053
   VCID: CAD822B66DA9EF12D7-809E
   Subsystem 1 - Part No SW: 8K0 959 339 A    HW: 8K0 959 339 A
   Component: BF-Gewichtss.  H02 0060
   Serial number: 5810000R120000A4DT
   Serial number: 6334MSME6E305632C
   Serial number: 6344MSME6F624E1DZ
   Serial number: 6352QSME5B172540C
   Serial number: 6362QSME072051722
   Serial number: 63732SME1C203C56/
   Serial number: 63832SME1C203A5A0
   Part No SW: 8R0 953 568 S    HW: 8R0 953 568 S
   Component: Lenks.Modul   H07 0171
   Revision: 00000000    Serial number: 20120806000797
   Coding: 00001E
   VCID: D1EA35DA88FFDCCA96-8084
   Component: E221 - MFL  H03 0003
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 984     HW: 8T0 920 984
   Component: KOMBIINSTR.   H35 0553
   Revision: 00100000    Serial number: RB252CW6D
   Coding: 8BBD0100BF01D705020000
   VCID: FCB4B46E7FFD81A215-80A8
   Part No SW: 8R0 907 468 J    HW: 8R0 907 468 D
   Component: GW-BEM 5CAN-M H11 0051
   Revision: 1Z090025    Serial number: 2541Z12717001C
   Coding: 80C303FF00
   VCID: C6C0168671B10B7233-8092
   Serial number: 6675467901
   Part No SW: 8K0 907 144 J    HW: 8K0 907 144 J
   Component: DYNAMIKLENK.  H06 0690
   Revision: 52001005    Serial number: --------------
   Coding: 040000
   VCID: B620664601519BF2A3-80E2
Address 22: AWD (J492)       Labels: 8K0-907-163.clb
   Part No SW: 8K0 907 163 B    HW: 8K0 907 163 A
   Component: 4 Wheel Drive H13 0100
   Serial number: 001107120001028
   VCID: AF2E5322F60BAA3AE0-80FA
10 Faults Found:
0197 - Sensor Units for ESP
          C1024 29 [008] - Signal Implausible
                    Reset counter: 127
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
                    Rotation rate sensor 1: -79.99500 °/s
                    Lateral acceleration sensor 1: -2.26755 g
                    Rotation rate sensor 2: -23.67500 °/s
                    Lateral acceleration sensor 2: -1.97437 g
                    Front left wheel speed: -3482.7 km/h
                    Front right wheel speed: -3405.9 km/h
                    Left rear wheel speed: -3457.1 km/h
                    Right rear wheel speed: -3329.1 km/h
                    Vehicle speed: 107.96 km/h
                    Steering wheel angle: -4764.7 °
0171 - Sensor Units for ESP
                    Reset counter: 127
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
0062 - No Communications with ESP Multi-Axis Sensor Module
          U0125 00 [137] - -
                    Fault Frequency: 25
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
                    Voltage terminal 15: 14.53 V
                    Voltage terminal 30: 14.69 V
                    VPS Voltage: 14.69 V
                    Pump for all-wheel drive: voltage: 0.00 V
                    motor pump voltage terminal B: 0.00 V
                    Pump for all-wheel drive: current: 0.00 A
                    Torque distribution: 0 Nm
                    Torque distribution: specified value: 0 Nm
                    State KomonentenRegler: Permanent Error
                    Control Module temperature: 2 °C
                    Temperature output stage-Data: -4 °C
                    Temperature QCU-Data: 2 °C
                    Thermal load ECU-Data: 0 bar
                    Thermal load of all-wheel drive pump: 0.0 %
                    Oil pressure and oil temperature sensor temperature: 3 °C
0129 - ESP Sensor Module 2
          U10B0 00 [137] - No Communications
                    Fault Frequency: 25
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
0059 - Please Check Fault Codes in Control Module for ABS Brakes
          U1017 00 [137] - -
                    Fault Frequency: 35
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:29
                    Voltage terminal 30: 14.53 V
                    VPS Voltage: 14.53 V
                    Temperature QCU-Data: 3 °C
0252 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Fault Frequency: 37
                    Reset counter: 140
                    Mileage: 96336 km
                    Date: 2016.12.18
                    Time: 08:12:47
                    Voltage terminal 15: 11.56 V
                    Voltage terminal 30: 11.72 V
                    VPS Voltage: 11.72 V
                    Pump for all-wheel drive: voltage: 2.97 V
                    motor pump voltage terminal B: 2.97 V
                    State KomonentenRegler: Initalize
                    Control Module temperature: -1 °C
                    Temperature output stage-Data: -3 °C
                    Temperature QCU-Data: 8 °C
                    Thermal load ECU-Data: 19 bar
                    Oil pressure and oil temperature sensor temperature: 8 °C
0066 - Implausible Data Received from ESP Multi-Axis Sensor Module
          U0432 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 96353 km
                    Date: 2016.12.18
                    Time: 08:23:13
                    Control Module temperature: 5 °C
                    Temperature output stage-Data: -1 °C
                    Temperature QCU-Data: 17 °C
                    Oil pressure and oil temperature sensor temperature: 16 °C
0067 - Implausible Data Received from ESP Multi-Axis Sensor Module
          U0432 00 [008] - -
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 96353 km
                    Date: 2016.12.18
                    Time: 08:23:13
0071 - ESP Sensor Module 2
          U10B1 00 [008] - Implausible Signal
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 96353 km
                    Date: 2016.12.18
                    Time: 08:23:13
0072 - ESP Sensor Module 2
                    Fault Frequency: 22
                    Reset counter: 139
                    Mileage: 96353 km
                    Date: 2016.12.18
                    Time: 08:23:13
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H10 0076
   Revision: AA000000    Serial number: 00000035625251
   Coding: 001B7B25002C00000000
Address 3C: Lane Change (J769)       Labels: 5Q0-907-566.clb
   Part No SW: 8T0 907 566 A    HW: 8T0 907 566
   Component: SWA Master    H17 0040
   Serial number: 0181484581
   Coding: 010211
   Shop #: WSC 06324 000 00000
   VCID: BE307E66216153B27B-80EA
   Lane Change Assistant 2:
   Subsystem 1 - Part No SW: 8T0 907 568 A    HW: 8T0 907 568
   Component: SWA Slave  H17 0040
   Serial number: 0181474227
   Coding: 010211
337166 - Databus
                    Fault Frequency: 34
                    Reset counter: 100
                    Mileage: 96333 km
                    Date: 2016.12.18
                    Time: 08:10:28
733440 - Control Module for Lane-Change Assist
          C1114 F3 [008] - Limited Visibility
                    Mileage: 95535 km
                    Date: 2016.12.09
                    Time: 07:21:21
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8T0 959 793 P    HW: 8T0 959 793 G
   Component: TSG FA        H09 0304
   Coding: 011C13224E00120102
   VCID: D6E0C6C6A111BBF243-8082
Address 44: Steering Assist (J500)       Labels: 8K0-909-144.clb
   Component: RCEPS         H37 0507
   Revision: 00001000    Serial number: 0017730591
   Coding: 010000010001
   ROD: EV_RCEPSAU48X_008.rod
   VCID: B4245C4E1F2D89E29D-80E0
   Revision: 00002001    Serial number: 0180853372
   Coding: 0106069A00FA414580B0003200000000
   Component: GTO BF  H01 0080
   Serial number: 00000000000000550685
   Subsystem 3 - Part No SW: 8R0 959 591 A    HW: 8R0 959 591
   Component: J245EE20SKB13  H03 0220
Address 47: Sound System (J525)       Labels: 8T0-035-223-BOM.clb
   Revision: 00005001    Serial number: 94813005002702
   VCID: AD12492AF407D82AD2-80F8
                    Reset counter: 85
                    Voltage: 11.90 V
                    Temperature: -35.0°C
                    Bin. Bits: 00000100
   Part No SW: 8T0 959 792 P    HW: 8T0 959 792 G
   Component: TSG BF        H09 0304
   VCID: D5E2C1CABC17B0EA4A-8080
   Part No SW: 8K0 907 801 L    HW: 8K0 907 801 J
   Component: EPB-4         H01 0003
   Revision: --------    Serial number: 00000001156924
   ROD: EV_ParkiBrake_VW51.rod
459264 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Fault Frequency: 8
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Voltage terminal 30: 14.5 V
                    Internal Fault ID: 138
                    Vehicle speed: 94 km/h
                    Function light in parking brake button: OFF
                    Red operating lamp: OFF
                    Red warning lamp: OFF
                    Green operating lamp: OFF
                    Yellow warning lamp: OFF
                    Terminal 15 status: On
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
                    ACC requested apply: not active
                    Auto Adjust: not active
                    Internal Parking Brake state: Dynamic
                    Status ParkingBrake left: Open
                    Status ParkingBrake right: Open
463616 - Function Restriction due to Faults in Other Modules
          U1113 00 [137] - -
                    Reset counter: 100
                    Mileage: 98359 km
                    Date: 2017.01.07
                    Time: 07:30:50
                    Internal Fault ID: 185
                    RWU: not active
                    DSD: not active
                    HTR: not active
                    ECD: not active
   Revision: AB001007    Serial number: 156H 0C7620348
   Coding: 020007010000000001
   VCID: A404AC0EA7CD19620D-80F0
   Part No SW: 8R1 035 746 G    HW: 8R1 035 746 B
   Component: H-BNT-NA      H43 0901
   Revision: --------    Serial number: 204HY0C7515446
   Coding: 140200020206A9EF75028B4E00000403140000000000000000
   VCID: BB3677723A73469A5C-80EE
   Subsystem 1 - Part No: 8R0 060 884 AM
   Component: NAR 2012  0605
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Serial number: A130GK0C2512461
   Subsystem 3 - Part No SW: 8T0 919 611 L    HW: 8T0 919 611 C
   Serial number: 00000001237192
   Subsystem 4 - Part No: 8R0 060 961 D
   Component: CD-Database  4353
   Revision: --H07---    Serial number: 525PA8-J2691PX
   Coding: 1001008
   Shop #: WSC 09012 002 1048576
   VCID: B83C687ECB456D82B1-80EC
   Part No SW: 8K0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0005
   Serial number: 120717200056
   ASAM Dataset: EV_SoundActuaGen2AU64X 002005
   ROD: EV_SoundActuaGen2AU64X_002.rod
   VCID: F2A89A5625B9C7D24F-80A6
End----------(Elapsed Time: 03:05, VBatt start/end: 11.4V/11.4V)-----------
hans j
Utah
C?ID=60436
Found out that the soft coding in ABS didn't have the auto hill hold function checked. Did that, all fault codes went away! Test drove and no issues. The AHH still doesn't work, but I have to find out if it ever did...
United States
After some digging I think 282D1A was the correct ABS coding. I don't see anything obviously wrong with the other PT modules (i.e. Engine, trans, ACC, etc) so I suspect the car has (or had) an ESP sensor problem that cause a lot of faults.
Some B8 models used 2 sensors and others only had one but I would locate and inspect G419 and/or G536. I think those are under the carpet, driver's side but double check your repair sources or bump this back up if that car gives you trouble.
hans j
Utah
C?ID=60436
It turns out there is much more to the story my service writer only found out after spending time on it. He still hasn't told me what, but apparently the vehicle owner unclicked the check box for AHH. I really don't know the whole story, but all the lights turned off when I checked that box! Thanks for checking against your scans, this appears to be the first one I have had in.
