VW Passat B8 - some teweks I would liek to enable
VW Passat B8 2016 (or 2017?), 2.0 TDI 150HP
VIN: WVWZZZ3CZHE078335
(Only enabled some features through : 01 - Refueling Gasoline Amount, 02 - Horn on closing and opening the car and 03 - Comfort Blink Cycle (changed from 3 to 5).)
COMPLETE Auto-Scan
Chassis Type: 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F
VIN: WVWZZZ3CZHE078335 Mileage: 176371km-109591miles
03- Brakes -- Status: OK 0000
05-/Start Auth. -- Status: Malfunction 0010
Address 01: Engine (J623-CRLB) Labels:. 04L-907-309-V1.clb
Part No SW: 04L 906 026 ET HW: 04L 907 309 R
Component: R4 2.0l TDI H23 1990
Revision: B5H23---
Coding: 011D003203641D083000
Shop #: 05311 115 00319
Dataset: EV_ECM20TDI01104L906026ET 002002
ROD: EV_ECM20TDI01104L906026ES_002_VW48.rod
VCID: 005986A2FA8174EB532-8054
Part No SW: 0D9 300 042 M HW: 02E 927 770 AS
Component: DQ250-6F H54 5013
Revision: 06454104 Serial number: TFK01609082199
Shop #: 05311 115 00084
Dataset: EV_TCMDQ250021 001001
ROD: EV_TCMDQ250021.rod
VCID: 2313E92E4B578FF36E0-8076
10657 - RPM Signal from
P0726 00 [002] - Implausible Signal
Address 03: Brakes (J104) Labels: 5Q0-907-379-IPB-V1.clb
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 62626000001467
Coding: 0EEC6A8F34270B74477A060341C84970562CD0E2608292713862F078C20202
Shop #: 00015 115 00001
Dataset: EV_Brake1UDSContiMK100IPB 035019
VCID: 7BA3F14E93671733060-802E
Address 05: /Start Auth. (J518) Labels:| 5Q0-959-435.clb
Part No SW: 3Q0 959 435 D HW: 3Q0 959 435 D
Component: VWKESSYMQB 026 0811
Revision: 00026000 Serial number: 0417407871
Coding: 002F0F070F
Dataset: EV_KessyHellaMQBAB 004039
ROD: EV_KessyHellaMQBAB.rod
VCID: 3B23314ED3E7D733460-806E
65794 - Function Restricted due to Insufficient Voltage
U1400 00 [008] - -
[Function restriction due to temp low voltage]
Fault Frequency: 16
Reset counter: 6
Mileage: 175671 km
Date: 2020.03.18
Time: 10:32:49
Terminal_15_Kessy_specified_value: On
Terminal_15_Kessy_actual_value: On
Terminal_15_central electric_actual_value: On
Terminal_15red_Kessy_specified_value: On
Terminal_15red_Kessy_actual_value: On
Terminal_S_Kessy_specified_value: On
Terminal_S_Kessy_actual_value: On
Terminal_S_central electric_actual_value: On
Terminal_50_Kessy_specified_value: OFF
Terminal_50_Kessy_actual_value: OFF
ZAT_pressed: OFF
Request active: Condition not met
Enabling Steering Column Lock: Condition not met
Enabling immobilizer: Condition met
Control Module Voltage: 8.443 V
Vehicle speed: 0.0 km/h
Engine speed: 157.5 /min
Status of vehicle locking: Vehicle unlocked
Coding information: Not coded
Driver door: closed
Front Passenger Door: closed
Left rear door: closed
Right rear door: closed
Active_LF_scans: Init
ID sensor 1 authentication: status: No response
ID sensor 2 authentication: status: No response
ID sensor 3 authentication: status: No response
ID sensor 4 authentication: status: No response
SPN_Byte 0: 00
SPN_Byte 1: 00
SPN_Byte 2: 00
Part No SW: 5G0 907 044 BP HW: 5G0 907 044 BP
Component: Climatronic H04 1601
Revision: 00001K10
Coding: 11020104202110011015500000101822
Dataset: EV_ACClimaBHBVW37X 006142
VCID: 76B5E07AA8454A5B79E-8022
Air quality sensor:
1048834 - Functional Limitation due to Energy Management
B10CD 00 [008] - -
[-Reduzierung durch ]
Fault Frequency: 8
Reset counter: 252
Mileage: 175817 km
Date: 2020.03.23
Time: 08:31:13
Voltage terminal 30: 14.6 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 1
Auxiliary heater: in stages-Act.val.: 1
Auxiliary heater: in stages-Specified value: 3
Auxiliary heater: in stages-Specified value for control: 3
1048835 - Functionality limited due to Engine Control Module
P1719 00 [008] - -
Reset counter: 232
Mileage: 175807 km
Date: 2020.03.22
Time: 18:02:35
Voltage terminal 30: 14.4 V
Auxiliary heater: in stages-Enabling for auxiliary heater operation: Enabling stage 3
Auxiliary heater: in stages-Act.val.: 0
Part No SW: 5Q0 937 086 BH HW: 5Q0 937 086 BH
Component: PQ37BOSCH 032 0222
Revision: -------- Serial number: 8658190916008P
Dataset: EV_BodyContrModul1UDSBosc 017002
ROD: EV_BCMBOSCH_017.rod
VCID: 015F83A6F18B7DE35CC-8054
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160901 042 0607
Serial number: 160908192821
Component: 042 0105
Serial number: S5Y16M09D22H21M03S30
Coding: 00A8DD
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - H01 0032
Serial number: 25 06 2016 10000768
U1400 00 [008] - -
[Funktionseinschränkung durch Unterspannung - unterer Grenzwert unterschritten >]
550677 - Databus
[TSG_HBFS_01 Datenbus fehlende Botschaft]
589592 - Databus
U1201 00 [008] - No Communications
[CAN Keine Kommunikation]
Reset counter: 3
Mileage: 172246 km
Date: 2019.09.15
Time: 11:22:41
787212 - Windshield Washer Pump
B1261 01 [008] - Electrical Failure
204290 - Remote key 1
B1479 18 [008] - Current Too Low
204546 - Remote key 2
B147A 18 [008] - Current Too Low
Mileage: 60059 km
Date: 2017.11.20
Time: 08:17:04
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616252
Coding: 0271061851
Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D47AF96BDD32983284-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: BOSCH H04 0194
Coding: 3200670359FFC428949C8045
Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 34311A72FEB9184B87A-8060
Part No SW: 3Q0 959 655 BB HW: 3Q0 959 655 BB
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003STPJZ9CSG
Coding: 98CCC000000000005C5400CC000800000065
Shop #: 05314 000 00001
Dataset: EV_AirbaVW20TS6VW48X 001116
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F5B055E877F0B132A8-802A
Subsystem 1 - Part No SW: ----------- HW: 454 000 609 16
Serial number: 3576U0000001C2A4ED1M
Subsystem 2 - Part No SW: ----------- HW: 454 000 109 16
Serial number: 3586U000000F2818AD1O
Subsystem 3 - Part No SW: ----------- HW: 454 800 909 16
Serial number: 3516RFB5C2E0C000000R
Subsystem 4 - Part No SW: ----------- HW: 454 800 809 16
Serial number: 3526RE00D980C000000D
Subsystem 5 - Part No SW: ----------- HW: 454 800 609 16
Serial number: 3556V5ED6D00C000000R
Part No SW: 3Q0 953 521 CS HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF033033 Serial number: 20160920100674
Coding: 0010
Dataset: EV_SMLSVALEOMQB 001016
ROD: EV_SMLSVALEOMQB.rod
VCID: 035389AEEB976FF34E0-8056
Part No SW: 3G0 920 791 B HW: 3G0 920 791 B
Component: KOMBI 404 2153
Coding: 07A401182F80000801886B011001000000000000
Dataset: EV_DashBoardVDDMQBAB 009052
VCID: 2809FE0232716CAB3B2-807C
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW High 212 2265
Revision: -------- Serial number: 12091610520017
Coding: 030300045F087300FB0002581C0F00010001070000000000000000000000
Dataset: EV_GatewConti 013020
ROD: EV_GatewConti_013.rod
VCID: 7CA1F2529669100B0FA-8028
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160001847210056373
Coding: 2CFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 J HW: 5Q0 915 181 J
Serial number: 75410803001609126496
Analog clock:
Subsystem 4 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000227917015
Coding: 0800000000000000
Dataset: EV_ELVMarquMQBB 001007
ROD: EV_ELVMarquMQBB.rod
VCID: 71BFD366C12B6D63ACC-8024
Component: FS 020 0041
Serial number: 080816EH709114
Coding: 00350B20D000020000001000
Dataset: EV_DCUDriveSideEWMAXKLO 006003
VCID: 43D349AEAB17AFF30E0-8016
Subsystem 1 - Part No SW: 5Q4 959 812 E HW: 5Q4 959 812 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000004585498
Address 44: Steering Assist (J500) Labels:| 5Q0-909-143.clb
Part No SW: 5Q0 909 143 M HW: 5Q0 909 143 E
Component: MQB_PP_APA 204 2041
Revision: 00000000 Serial number: 0001055654
Coding: 01010010005000
Shop #: 00015 115 00319
Dataset: EV_SteerAssisVWBSMQBA 008028
ROD: EV_SteerAssisVWBSMQBA_008.rod
VCID: 3D273F56CDF3D903784-8068
Component: BFS 020 0041
Serial number: 270716EGQ28591
Coding: 00350120DE00020000001000
Dataset: EV_DCUPasseSideEWMAXKLO 006003
VCID: 42DD4CAAB40DA6FB056-8016
Subsystem 1 - Part No SW: 5Q4 959 811 E HW: 5Q4 959 811 E Labels: 5QX-959-81X-V1.CLB
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000004589425
Coding: 090000
Address 55: Headlight Range (J431) Labels:| 5Q0-907-357.clb
Part No SW: 5Q0 907 357 HW: 6R0 907 357 A
Component: LWR- 005 0080
Coding: 03DA000009010000
Shop #: 05311 000 00001
Dataset: EV_HeadlRegulVWLWRMQB 001110
VCID: 75B7E776B5434143704-8020
Address 5F: Information Electr. (J794) Labels:| 5G0-035--HGH2.clb
Part No SW: 3G0 035 043 D HW: 3G0 035 043
Component: MU-H-N-EU H51 0814
Serial number: A683I0GB041511
Coding: 02840101FF00000051110001000808001F0100E401200000DF
Dataset: EV_MUHig4CGen2HBAS 001001
VCID: 1D67DFD66D33B903584-8048
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL03WVE
Subsystem 2 - Part No SW: V03 959 806 FN HW: -----------
Component: ECE 2020 --- 0184
Compact Disc Database:
Component: Gracenote2--- --- 1013
0513 - Rear Right Treble Speaker
B1068 13 [009] - Open Circuit
[Hochtonlautsprecher Kanal 1: Unterbrechung]
Reset counter: 78
Mileage: 51725 km
Date: 2017.10.10
Time: 14:34:09
Voltage terminal 30: 12.4 V
1561 - predictive route data
B1630 02 [009] - Signal Failure
Reset counter: 145
Mileage: 72418 km
Date: 2018.02.07
Time: 18:29:25
Voltage terminal 30: 13.5 V
End----------(Elapsed Time: 01:45, VBatt start/end: 14.7V/14.4V)-----------
No repairs were done to the car since I have it (Feb 2020) and I do not have the history of the car repairs
I would like to know if the following are possible:
1. All windows to be closed when I lock the car - not by long pressing the lock button.
2. Know how to check if my device has protection or not;
3. If Playing youtube is possible
4. If Video in Motion can be enabled, without involving a VW dealer
5. Is there a way to have somewhere in the DiscoverPro unit displayed the Voltage of battery? It would be very usefull, at least for me
6. Sport HMI - can this be activated it is not present for my unit under Supported/Installed codes - without involving a VW dealer?
7. When coming home, the "Coming Home / Leaving Home" does not work. When leaving home (and unlocking the car) the lights do power on.
