SO if not possible with VCDS and OBD11 what can you use? ODIS?No, OBD11 is not capable of uploading parameter data.
Friday,01,June,2018,16:29:19:56142
VCDS Version: 18.2.0.3 (x64)
VIN: WVWZZZ3CZGE234991 License Plate: XXX34
Mileage: 28974km-18003mi Repair Order:
Chassis Type 3C-VW48 (5Q0)
Scan: 01 02 03 05 08 09 10 13 14 15 16 17 18 19 22 2B 36 3C 42 44
47 52 55 5F 65 69 6C 6D A5 BB BC CA CF
VIN: WVWZZZ3CZGE234991 Mileage: 28974km-18003miles
CA-Sunroof -- Status: INTERFACE NOT COMPATIBLE
CF-Lane Chge Asst 2 -- Status: INTERFACE NOT COMPATIBLE
Address 01: Engine (J623-CUAA) Labels:. 03N-906-026-CUA.clb
Part No SW: 03N 906 026 E HW: 03N 907 309
Component: R4 2.0l BTD H23 2114
Revision: A1H23---
Coding: 0125003A047605083000
Shop #: WSC 05311 115 00303
ASAM Dataset: EV_ECM20BTD01103N906026E 001004
ROD: EV_ECM20BTD_VW48.rod
VCID: 2D5AE2107CCA702C83-8078
Readiness: 1110 1011
Part No SW: 0DL 300 011 H HW: 0BH 927 711 F
Component: GSG DQ500 H10 5206
Revision: 00H10V01
Address 03: ABS Brakes (J104) Labels:. 5Q0-907-379-IPB-V1.clb
Part No SW: 3Q0 907 379 AC HW: 3Q0 907 379 H
Component: ESC H34 0912
Revision: 00000000 Serial number: 40956000000373
Coding: 0EEC6B8F54230B700780070941C46970D62AD0E0E08296F5B86250884AA9
Shop #: WSC 00015 115 08193
VCID: 7BFE1C48F23E2E9C4D-802E
Part No SW: 3Q0 959 435 C HW: 3Q0 959 435 C
Component: VWKESSYMQB 036 0710
Revision: 00036000 Serial number: 0400713087
Coding: 0F00000F03
VCID: 3A70D94CBD84D79416-806E
Subsystem 1 - Part No SW: 3G0 962 243 HW: 3G0 962 243
Component: GEB.F.Heckoef H17 0812
Serial number: ;8049892
Part No SW: 5G1 907 044 J HW: 5G1 907 044 J
Component: Climatronic H04 1202
Revision: 00001K10
Coding: 11020114204401011115500E0010190A
ASAM Dataset: EV_ACClimaBHBVW37X 005137
VCID: 2F66F81876C6023CB1-807A
Air quality sensor:
Part No SW: 5Q0 937 086 AK HW: 5Q0 937 086 AK
Component: BCM PQ37BOSCH 028 0163
Revision: -------- Serial number: 8658210416012I
Coding: 00931E66C2C10AFF17844094B118172C1C80000000000000000000000000
ASAM Dataset: EV_BodyContrModul1UDSBosc 015001
ROD: EV_BCMBOSCH_015.rod
VCID: 030E64A88ACE565C05-8056
Subsystem 1 - Part No SW: 3G1 955 119 A HW: 3G1 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160330 042 0607
Serial number: 160409020506
Subsystem 2 - Part No SW: 8UD 955 559 B HW: 8UD 955 559 B Labels: 8U0-955-559.CLB
Component: G397_RLFS H06 0004
Serial number: 90060844
Coding: 00006E
Subsystem 3 - Part No SW: 3G0 941 633 H HW: 3G0 941 633 H
Component: E1 - LDS MQB H01 0032
Serial number: 30 01 2016 10000406
Subsystem 4 - Part No SW: 5Q0 951 172 HW: 5Q0 951 172
Serial number: 000000000ZY160321D57
Serial number: 00000000000034818077
Part No SW: 5QA 919 298 HW: 5Q0 919 298 C
Component: PLA 3.0 12KH08 0161
Serial number: 000305183616105
Coding: 0A71167951
Shop #: WSC 05311 115 00090
ASAM Dataset: EV_EPHVA2CAU3700000 009017
VCID: 0D1A4290DC8A102C63-8058
Address 13: Auto Dist. Reg (J428) Labels:| 3Q0-907-572.clb
Part No SW: 3Q0 907 572 B HW: 3Q0 907 572 B
Component: ACC BOSCH MQB H04 0194
Coding: 320467DB5DFFC728949C804D
ASAM Dataset: EV_ACCBOSCHVW48X 001009
ROD: EV_ACCBOSCHVW48X.rod
VCID: 346CF7749FE021E4CC-8060
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 A HW: 5Q0 907 376 A
Component: DAEMPFUNGS-SG H17 0120
Serial number: 10041641350170
ROD: EV_DRCONTITEMIC_VW27.rod
VCID: 3776C0788E96CAFCE9-8062
Part No SW: 3Q0 959 655 BA HW: 3Q0 959 655 BA
Component: Airbag VW20 013 0195
Revision: -------- Serial number: 003SSP7RLXMM
Coding: 98FCC0C0008000005C5400CC000800000065
Shop #: WSC 05314 000 00001
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7EF8155CE12C3BB46A-802A
Belt Pretensioner left:
Serial number: 3G1857705G0107Q01487
Coding: 80000D
Belt Pretensioner right:
Serial number: 3G1857706G0107Q01565
Coding: 80000D
Subsystem 3 - Part No SW: ----------- HW: 454 000 904 16
Serial number: 3576U000000C716C4A1I
Subsystem 4 - Part No SW: ----------- HW: 454 000 904 16
Serial number: 3586U0000008716C4A1F
Subsystem 5 - Part No SW: ----------- HW: 454 800 304 16
Serial number: 3516RD3CD640A000000H
Subsystem 6 - Part No SW: ----------- HW: 454 800 304 16
Serial number: 3526R42C5640A0000000
Subsystem 7 - Part No SW: ----------- HW: 454 802 703 16
Serial number: 3556V952E0F0A000000J
Part No SW: 3Q0 953 521 EH HW: 5Q0 953 569 B
Component: Lenks.Modul 100 0205
Revision: FF035035 Serial number: 20160212501046
Coding: 0810
Shop #: WSC 00015 115 00001
ASAM Dataset: EV_SMLSVALEOMQBLRH 001005
ROD: EV_SMLSVALEOMQBLRH.rod
VCID: 7AF0194CFD04179456-802E
Part No SW: 3G0 920 791 A HW: 3G0 920 791 A
Component: KOMBI 412 1440
Coding: 07A40098FE8C000801886B2F3001000000000000
ROD: EV_DashBoardVDDMQBAB_VW48.rod
VCID: 275610385E365A7C79-8072
Address 18: Aux. Heat (J364) Labels:| 5Q0-963-272.clb
Part No SW: 5Q0 963 272 E HW: 5Q0 963 272 E
Component: STH-MQB 007 0072
Coding: 9309
VCID: 3874C3448388C584E0-806C
Subsystem 1 - Part No SW: 5Q0 963 513 A HW: 5Q0 963 513 A
Component: R149 T91-LIN 003 0301
Serial number: 00000000000001368992
Part No SW: 5Q0 907 530 AJ HW: 5Q0 907 530 M
Component: GW MQB High 212 2246
Revision: -------- Serial number: 14041610800174
Coding: 0B0300345F017300FB00025E9C0F00010001070000000000000000000000
ROD: EV_GatewConti_013_VW37.rod
VCID: 79F20640F8021C8C5F-802C
Subsystem 2 - Part No SW: 5G0 959 442 K HW: 5G0 959 442 K Labels: 3C8-959-537.CLB
Component: E221__MFL-DC1 H17 0040
Serial number: 29160000733230116153
Coding: 2FFFFF
Subsystem 3 - Part No SW: 3Q0 915 181 A HW: 3Q0 915 181 A
Component: J367-BDMHella H04 8050
Serial number: 1646649703
Power Converter DC AC:
Subsystem 4 - Part No SW: 5Q0 907 155 C HW: 5Q0 907 155 C
Component: WECHSELRICHTE H55 0033
Serial number: 0222914
Analog clock:
Subsystem 5 - Part No SW: 3G0 919 204 C HW: 3G0 919 204 C
Component: Analoguhr 209 2002
Serial number: HA1-00004.03.16
Coding: 0301
VCID: 4A90898CED64471486-801E
Address 2B: Steer. Col. Lock (J764) Labels:| 5Q0-905-861.clb
Part No SW: 3Q0 905 861 HW: 3Q0 905 861
Component: ELV-MQBB H05 0032
Serial number: 16000085971009
Coding: 0800000000000000
ROD: EV_ELVMarquMQBB.rod
VCID: 71E23E60A07254CCE7-8024
Address 36: Seat Mem. Drvr (J810) Labels:* None
Part No SW: 3Q0 959 760 B HW: 3Q0 959 760 B
Component: Sitzmemory H04 0020
Serial number: Y0006PDG13411
Coding: 0010000200000500818280808080000000008181000000F400
ASAM Dataset: EV_SeatMemorDriveSide 002021
Address 3C: Lane Change (J769) Labels:| 3Q0-907-566.clb
Part No SW: 3Q0 907 566 B HW: 3Q0 907 566
Component: MRR1Rear H16 0230
Revision: --------
Coding: 14C002
ASAM Dataset: EV_RearRadarS1BoschVW48X 001002
Component: TSG FS 020 0041
Serial number: 200316ECI11525
Coding: 003F1A20D200028000001000
VCID: 438EA4A8CA4E965C45-8016
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 9303
Shop #: WSC 00015 115 00303
VCID: 3972C640B882DC8C1F-806C
Address 47: Sound System (J525) Labels:| 3Q0-035-466.clb
Part No SW: 3Q0 035 466 C HW: 3Q0 035 466 C
Component: MIB2_amp_P_VW H45 0210
Revision: 00000001 Serial number: VWZ8Z1GAT00K1TW
Coding: 1284010001AA0A2AAA0000000000
ASAM Dataset: EV_AMPMst16C3Gen2ALPI 001016
ROD: EV_AMPMst16C3Gen2ALPI_VW37.rod
0570 - Loudspeaker 1 in Double-Subwoofer
B130C 13 [009] - Open Circuit
Reset counter: 210
Mileage: 28974 km
Date: 2018.06.01
Time: 16:07:01
Voltage terminal 30: 11.9 V
0575 - Loudspeaker 2 in Double-Subwoofer
B130D 13 [009] - Open Circuit
Reset counter: 210
Mileage: 28974 km
Date: 2018.06.01
Time: 16:07:01
Component: TSG BFS 020 0041
Serial number: 120416EDC13285
Coding: 003F1020DE00028200001000
VCID: 4280A1ACD5549F544E-8016
Part No SW: 7P6 907 357 C HW: 7P6 907 357 B
Component: AFS-ECU H01 0120
Coding: 03A203004F210200
Shop #: WSC 05311 000 08193
ROD: EV_HeadlRegulAFSMQBMLB_VW48.rod
VCID: 3F86A858A6A6F2BC21-806A
Subsystem 1 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo li. H09 0003
Coding: E02400
Subsystem 2 - Part No SW: 7PP 941 572 AB HW: 7PP 941 572 A Labels: 3D0-941-329.CLB
Component: LED LeiMo re. H09 0003
Coding: E02400
Subsystem 3 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo links H02 0003
Coding: E02400
Subsystem 4 - Part No SW: 3G0 941 329 _ HW: 3G0 941 329 _ Labels: 3D0-941-329.CLB
Component: LeiMo rechts H02 0003
Coding: E02400
Address 5F: Information Electr. (J794) Labels:| 5G0-035-MIB-HGH2.clb
Part No SW: 3G0 035 021 C HW: 3G0 035 021
Component: MU-H-TND-EU H50 0343
Serial number: A680D0GB007944
Coding: 028401010000000051111102008808101F0100E4012000009F
VCID: 183423C4E348E584C0-804C
Subsystem 1 - Part No SW: 5G0 919 606 HW: 5G0 919 606
Component: ABT_High H63 0032
Serial number: VWZ8Z9SKL00SJN
Subsystem 2 - Part No SW: V03 959 800 QS HW: -----------
Component: ECE 2018 --- 0166
Compact Disc Database:
Component: Gracenote2 --- 1012
Part No SW: 5Q0 907 273 B HW: 5Q0 907 273
Component: RDKBERU30 H04 0009
Serial number: 30000000017886
ROD: EV_RDKBERU30_006_VW48.rod
Part No SW: 5Q0 907 383 G HW: 5Q0 907 383 D
Component: Anhaenger H21 0204
Revision: 8A001003 Serial number: 0401538670
Coding: 0100000202000000
VCID: 3B7EDC48B2BEEE9C0D-806E
Part No SW: 5Q0 980 568 HW: 5Q0 980 568
Component: RVC Compact+ H05 0100
Coding: 0184010163002017000048
ASAM Dataset: EV_CamSysRVRVCARPANAMQBAB 006008
ROD: EV_CamSysRVRVCARPANAMQBAB_006_VW37.rod
Part No SW: 5Q0 959 107 H HW: 5Q0 959 107 H
Component: HDSG-Modul H13 0253
Revision: -------- Serial number: 30526584800000
Coding: 0108
ASAM Dataset: EV_DeckLidCONTIAU736 001012
VCID: 3D7AD250ACAAE0AC33-8068
Part No SW: 3Q0 980 653 D HW: 3Q0 980 653
Component: MQB_B_MFK H08 0072
Serial number: 18041611K11584
Coding: 00040801000004010026234FC050A100980084300040
ROD: EV_MFKBoschMQBB_VW27.rod
Component: TSG HFS 020 0041
Serial number: 100316EC81986A
Coding: 000E10200100028000001000
VCID: 458ABAB0C47AA86C6B-8010
Component: TSG HBFS 020 0041
Serial number: 100316EC819867
Address CA: Sunroof
Interface not compatible.
Please upgrade to a current Ross-Tech interface.
Address CF: Lane Chge Asst 2
End-------------------------(Elapsed Time: 07:27)--------------------------
In the BCM at address 09, take a look at the following adaptation channels:hello, just change my B& to a Passat B8 2016 with a lot of gizmo on board but also with a very different electronic and I try for almost a day to do a simple thing, I want to activate horn beeps for lock unlock and cannot find where....
a litle help ?!!
IDE02269-ENG116666 -- Acknowledgement signals - Akustische Rueckmeldung entriegeln
IDE02269-ENG116667 -- Acknowledgement signals - Akustische Rueckmeldung verriegeln
;SW:5Q0-937-086-AK HW:5Q0-937-086-AK --- Cent. Elect.
;Component:BCM PQ37BOSCH 028 0163 Coding:00931E66C2C10AFF17844094B118172C1C80000000000000000000000000
;EV_BodyContrModul1UDSBosc 15001 EV_BCMBOSCH_015.rod
;Tuesday 5 June 2018 22:18:42:56142
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 030E64A88ACE565C3A-8056
IDE00001-ENG99061-Production mode-Access control not active 3
IDE00001-ENG115730-Production mode-Aussenbeleuchtung not active 3
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren not active 3
IDE00001-ENG112304-Production mode-Heckwischer not active 3
IDE00001-ENG98647-Production mode-Interior lighting not active 3
IDE00001-ENG115729-Production mode-Scheinwerferreinigung not active 3
IDE00001-ENG115731-Production mode-Virtuel_pedal not active 3
IDE00002-Transport mode active 1
IDE00820-Activating and deactivating all development messages not active 1
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA not active 12
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung 10 12
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm active 12
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf active 12
IDE01268-ENG133394-Windshield wiper-Frontwischer_Abtauposition not active 12
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung active 12
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer not active 12
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren Deactivating 12
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel not active 12
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit 2550 ms 12
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit 1200 ms 12
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit 0 ms 12
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit 0 ms 12
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit 1200 ms 12
IDE01268-ENG133393-Windshield wiper-Tippendes_Frontwaschen not active 12
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz active 12
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status not active 12
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung not active 12
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant 0 12
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube not active 12
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus not active 12
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube not active 12
IDE01550-Service position 153.30 ° 2
IDE02152-Characteristics in production mode 2000 ms 4
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking Decelerate 4
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln active 4
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global active 4
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn active 4
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln active 4
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn normal 4
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung active 4
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte active 4
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen active 4
IDE02269-ENG133344-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl not active 4
IDE02269-ENG133345-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl not active 4
IDE02332-Deactivate production mode 0 3
IDE02488-DWA Interior monitoring 100% 1
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen not active 8
IDE02711-ENG133397-Rear Window Wiper-Einzelansteuerung Heckintervallwischen not active 8
IDE02711-ENG133395-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1 0 s 8
IDE02711-ENG133396-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2 0.0 s 8
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf not active 8
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken not active 8
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck active 8
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1 5 s 8
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2 3 s 8
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik 7 s 8
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall 7 s 8
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW active 8
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck active 8
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum 80% 8
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer 80% 8
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn 10% 8
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung not enabled 8
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel not installed 8
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel not installed 8
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset 0.25 ° 14
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit 50.00 %/s 14
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt both sides 14
IDE03638-ENG116675-static AFS light-Lower speed threshold 0.00 km/h 14
IDE03638-ENG116682-static AFS light-Maximaltemperatur 100.00 °C 14
IDE03638-ENG116679-static AFS light-obere Grenztemperatur 95.00 °C 14
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel 120 ° 14
IDE03638-ENG116680-static AFS light-untere Grenztemperatur 80.00 °C 14
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel 80 ° 14
IDE03638-ENG116676-static AFS light-Upper speed threshold 40.00 km/h 14
IDE03638-ENG116674-static AFS light-Vorschrift ECE R119 14
IDE04923-ENG133379-Turn signal control-Abbruch Komfortblinken active 8
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger separte 8
IDE04923-ENG115774-Turn signal control-Komfortblinken active 8
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen 3 8
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker MFG 8
IDE04923-ENG116588-Turn signal control-Sonderfunktionen not enabled 8
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung not active 8
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung Always active 8
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor 0.1 8
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert 10.00% 8
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze 350 km/h 14
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze 350 km/h 14
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht integriert in Suchbeleuchtung 14
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich active 14
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten klemmenabhaengig 14
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO Menuesteuerung Zeit aktivieren 14
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit 0 km/h 14
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert One-sided 14
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion not active 14
IDE04924-ENG126816-Driving light and parking light-Standlicht aus active 14
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht active 14
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht not active 14
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren in Betrieb lassen 14
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht 15 min 14
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten Low beam 8
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus manual 8
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis Driver door 8
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung 46400 lx 8
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung 12 lx 8
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus Enabled 8
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome 10 seconds 8
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP 10 seconds 8
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung active 8
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP active 8
IDE04927-IDE01446-Window heater-Running time of heated front window 240 s 8
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung 35.00 °C 8
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung 35.00 °C 8
IDE04927-ENG126845-Window heater-FSH Automatik active 8
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert 320 s 8
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH active 8
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH active 8
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn active 4
IDE04928-ENG115864-Anti-theft device-Alarmsignal frequency modulated 4
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung driver door contact thatcham 4
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus not active 4
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl 10 Alarme 4
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel not active 4
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm 2 sekunden verzoegerung 4
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck active 8
IDE05142-ENG116621-Access control-automatisches Entriegeln active 8
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit not active 8
IDE05142-ENG116706-Access control-Autounlock NAR not active 8
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB not active 8
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung active 8
IDE05142-ENG133387-Access control-Deaktivierung_Laderaumschliessung_extern not active 8
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster active 8
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels active 8
IDE05142-ENG115722-Access control-Electrical rear lid not active 8
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang not active 8
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein not active 8
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster not active 8
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein not active 8
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung not active 8
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren active 8
IDE05142-ENG133386-Access control-Heckfreigabe_Ohne_Verzoegerung not active 8
IDE05142-ENG133388-Access control-LS_Taster_Togglefunktion not active 8
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung active 8
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock adjustable 8
IDE05142-ENG137162-Access control-Mindestbetaetigung_HDF_Innentaster 0.00 s 8
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt not active 8
IDE05142-ENG115755-Access control-Notschließfunktion active 8
IDE05142-ENG133389-Access control-Nutzfahrzeug_Schliessung not active 8
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung not active 8
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe not active 8
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung nur wenn mind. 1 Raste zu 8
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden Always 8
IDE05142-ENG115758-Access control-Valet Parking not active 8
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe not active 8
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT not active 8
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer not active 8
IDE05142-ENG133390-Access control-Wiederverriegelung_Laderaum Freigabe_Softtouch 8
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel active 8
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen not active 8
IDE05142-ENG116623-Access control-ZV Tuerentriegelung Einzeltuerentriegelung 8
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash not active 8
IDE05143-MAS02985-Writing parameter-Value 130 5
IDE05143-MAS04381-Writing parameter-Parameter address FE 00 00 5
IDE05144-Read parameter address FE 00 00 3
IDE05145-ENG115874-Light configuration-BAP Bitposition 0 34 560
IDE05145-ENG115893-Light configuration-BAP Bitposition 1 3E 560
IDE05145-ENG116063-Light configuration-BAP Bitposition 10 0 560
IDE05145-ENG116082-Light configuration-BAP Bitposition 11 0 560
IDE05145-ENG116101-Light configuration-BAP Bitposition 12 38 560
IDE05145-ENG116120-Light configuration-BAP Bitposition 13 42 560
IDE05145-ENG116139-Light configuration-BAP Bitposition 14 0 560
IDE05145-ENG116158-Light configuration-BAP Bitposition 15 0 560
IDE05145-ENG116177-Light configuration-BAP Bitposition 16 20 560
IDE05145-ENG116196-Light configuration-BAP Bitposition 17 10 560
IDE05145-ENG116215-Light configuration-BAP Bitposition 18 8 560
IDE05145-ENG116234-Light configuration-BAP Bitposition 19 18 560
IDE05145-ENG115911-Light configuration-BAP Bitposition 2 48 560
IDE05145-ENG116253-Light configuration-BAP Bitposition 20 9 560
IDE05145-ENG116272-Light configuration-BAP Bitposition 21 19 560
IDE05145-ENG116291-Light configuration-BAP Bitposition 22 29 560
IDE05145-ENG116310-Light configuration-BAP Bitposition 23 0A 560
IDE05145-ENG116329-Light configuration-BAP Bitposition 24 1A 560
IDE05145-ENG116348-Light configuration-BAP Bitposition 25 28 560
IDE05145-ENG116367-Light configuration-BAP Bitposition 26 0C 560
IDE05145-ENG116386-Light configuration-BAP Bitposition 27 1A 560
IDE05145-ENG116405-Light configuration-BAP Bitposition 28 9 560
IDE05145-ENG116424-Light configuration-BAP Bitposition 29 1B 560
IDE05145-ENG115930-Light configuration-BAP Bitposition 3 4C 560
IDE05145-ENG116443-Light configuration-BAP Bitposition 30 0 560
IDE05145-ENG116462-Light configuration-BAP Bitposition 31 0 560
IDE05145-ENG116481-Light configuration-BAP Bitposition 32 0 560
IDE05145-ENG116500-Light configuration-BAP Bitposition 33 0 560
IDE05145-ENG116519-Light configuration-BAP Bitposition 34 0 560
IDE05145-ENG115949-Light configuration-BAP Bitposition 4 3A 560
IDE05145-ENG115968-Light configuration-BAP Bitposition 5 44 560
IDE05145-ENG115987-Light configuration-BAP Bitposition 6 36 560
IDE05145-ENG116006-Light configuration-BAP Bitposition 7 40 560
IDE05145-ENG116025-Light configuration-BAP Bitposition 8 0 560
IDE05145-ENG116044-Light configuration-BAP Bitposition 9 0 560
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0 maximize 560
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1 maximize 560
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10 maximize 560
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11 maximize 560
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12 maximize 560
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13 maximize 560
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14 maximize 560
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15 maximize 560
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16 maximize 560
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17 maximize 560
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18 maximize 560
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19 maximize 560
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2 minimize 560
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20 maximize 560
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21 maximize 560
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22 maximize 560
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23 minimize 560
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24 minimize 560
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25 maximize 560
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26 maximize 560
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27 minimize 560
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28 minimize 560
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29 maximize 560
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3 minimize 560
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30 maximize 560
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31 maximize 560
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32 maximize 560
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33 maximize 560
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34 maximize 560
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4 maximize 560
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5 maximize 560
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6 maximize 560
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7 maximize 560
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8 maximize 560
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9 maximize 560
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0 maximize 560
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1 maximize 560
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10 maximize 560
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11 maximize 560
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12 maximize 560
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13 maximize 560
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14 maximize 560
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15 maximize 560
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16 maximize 560
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17 maximize 560
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18 maximize 560
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19 maximize 560
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2 maximize 560
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20 maximize 560
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21 maximize 560
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22 maximize 560
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23 maximize 560
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24 maximize 560
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25 maximize 560
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26 maximize 560
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27 maximize 560
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28 maximize 560
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29 maximize 560
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3 maximize 560
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30 maximize 560
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31 maximize 560
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32 maximize 560
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33 maximize 560
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34 maximize 560
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4 maximize 560
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5 maximize 560
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6 maximize 560
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7 maximize 560
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8 maximize 560
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9 maximize 560
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0 maximize 560
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1 maximize 560
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10 maximize 560
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11 maximize 560
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12 maximize 560
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13 maximize 560
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14 maximize 560
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15 maximize 560
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16 maximize 560
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17 maximize 560
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18 maximize 560
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19 maximize 560
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2 minimize 560
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20 maximize 560
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21 maximize 560
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22 maximize 560
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23 maximize 560
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24 maximize 560
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25 maximize 560
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26 maximize 560
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27 maximize 560
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28 maximize 560
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29 maximize 560
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3 minimize 560
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30 maximize 560
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31 maximize 560
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32 maximize 560
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33 maximize 560
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34 maximize 560
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4 maximize 560
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5 maximize 560
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6 maximize 560
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7 maximize 560
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8 maximize 560
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9 maximize 560
IDE05145-ENG115878-Light configuration-Dimmwert AB 0 127 560
IDE05145-ENG115897-Light configuration-Dimmwert AB 1 127 560
IDE05145-ENG116067-Light configuration-Dimmwert AB 10 0 560
IDE05145-ENG116086-Light configuration-Dimmwert AB 11 0 560
IDE05145-ENG116105-Light configuration-Dimmwert AB 12 100 560
IDE05145-ENG116124-Light configuration-Dimmwert AB 13 100 560
IDE05145-ENG116143-Light configuration-Dimmwert AB 14 0 560
IDE05145-ENG116162-Light configuration-Dimmwert AB 15 0 560
IDE05145-ENG116181-Light configuration-Dimmwert AB 16 100 560
IDE05145-ENG116200-Light configuration-Dimmwert AB 17 100 560
IDE05145-ENG116219-Light configuration-Dimmwert AB 18 100 560
IDE05145-ENG116238-Light configuration-Dimmwert AB 19 100 560
IDE05145-ENG115915-Light configuration-Dimmwert AB 2 100 560
IDE05145-ENG116257-Light configuration-Dimmwert AB 20 100 560
IDE05145-ENG116276-Light configuration-Dimmwert AB 21 100 560
IDE05145-ENG116295-Light configuration-Dimmwert AB 22 100 560
IDE05145-ENG116314-Light configuration-Dimmwert AB 23 100 560
IDE05145-ENG116333-Light configuration-Dimmwert AB 24 100 560
IDE05145-ENG116352-Light configuration-Dimmwert AB 25 127 560
IDE05145-ENG116371-Light configuration-Dimmwert AB 26 90 560
IDE05145-ENG116390-Light configuration-Dimmwert AB 27 100 560
IDE05145-ENG116409-Light configuration-Dimmwert AB 28 100 560
IDE05145-ENG116428-Light configuration-Dimmwert AB 29 100 560
IDE05145-ENG115934-Light configuration-Dimmwert AB 3 100 560
IDE05145-ENG116447-Light configuration-Dimmwert AB 30 100 560
IDE05145-ENG116466-Light configuration-Dimmwert AB 31 0 560
IDE05145-ENG116485-Light configuration-Dimmwert AB 32 0 560
IDE05145-ENG116504-Light configuration-Dimmwert AB 33 0 560
IDE05145-ENG116523-Light configuration-Dimmwert AB 34 0 560
IDE05145-ENG115953-Light configuration-Dimmwert AB 4 127 560
IDE05145-ENG115972-Light configuration-Dimmwert AB 5 127 560
IDE05145-ENG115991-Light configuration-Dimmwert AB 6 127 560
IDE05145-ENG116010-Light configuration-Dimmwert AB 7 127 560
IDE05145-ENG116029-Light configuration-Dimmwert AB 8 0 560
IDE05145-ENG116048-Light configuration-Dimmwert AB 9 0 560
IDE05145-ENG115882-Light configuration-Dimmwert CD 0 0 560
IDE05145-ENG115901-Light configuration-Dimmwert CD 1 0 560
IDE05145-ENG116071-Light configuration-Dimmwert CD 10 0 560
IDE05145-ENG116090-Light configuration-Dimmwert CD 11 0 560
IDE05145-ENG116109-Light configuration-Dimmwert CD 12 0 560
IDE05145-ENG116128-Light configuration-Dimmwert CD 13 0 560
IDE05145-ENG116147-Light configuration-Dimmwert CD 14 0 560
IDE05145-ENG116166-Light configuration-Dimmwert CD 15 0 560
IDE05145-ENG116185-Light configuration-Dimmwert CD 16 100 560
IDE05145-ENG116204-Light configuration-Dimmwert CD 17 100 560
IDE05145-ENG116223-Light configuration-Dimmwert CD 18 0 560
IDE05145-ENG116242-Light configuration-Dimmwert CD 19 0 560
IDE05145-ENG115919-Light configuration-Dimmwert CD 2 28 560
IDE05145-ENG116261-Light configuration-Dimmwert CD 20 0 560
IDE05145-ENG116280-Light configuration-Dimmwert CD 21 0 560
IDE05145-ENG116299-Light configuration-Dimmwert CD 22 0 560
IDE05145-ENG116318-Light configuration-Dimmwert CD 23 0 560
IDE05145-ENG116337-Light configuration-Dimmwert CD 24 0 560
IDE05145-ENG116356-Light configuration-Dimmwert CD 25 0 560
IDE05145-ENG116375-Light configuration-Dimmwert CD 26 0 560
IDE05145-ENG116394-Light configuration-Dimmwert CD 27 0 560
IDE05145-ENG116413-Light configuration-Dimmwert CD 28 0 560
IDE05145-ENG116432-Light configuration-Dimmwert CD 29 0 560
IDE05145-ENG115938-Light configuration-Dimmwert CD 3 28 560
IDE05145-ENG116451-Light configuration-Dimmwert CD 30 0 560
IDE05145-ENG116470-Light configuration-Dimmwert CD 31 0 560
IDE05145-ENG116489-Light configuration-Dimmwert CD 32 0 560
IDE05145-ENG116508-Light configuration-Dimmwert CD 33 0 560
IDE05145-ENG116527-Light configuration-Dimmwert CD 34 0 560
IDE05145-ENG115957-Light configuration-Dimmwert CD 4 0 560
IDE05145-ENG115976-Light configuration-Dimmwert CD 5 0 560
IDE05145-ENG115995-Light configuration-Dimmwert CD 6 0 560
IDE05145-ENG116014-Light configuration-Dimmwert CD 7 0 560
IDE05145-ENG116033-Light configuration-Dimmwert CD 8 0 560
IDE05145-ENG116052-Light configuration-Dimmwert CD 9 0 560
IDE05145-ENG115886-Light configuration-Dimmwert EF 0 0 560
IDE05145-ENG115905-Light configuration-Dimmwert EF 1 0 560
IDE05145-ENG116075-Light configuration-Dimmwert EF 10 0 560
IDE05145-ENG116094-Light configuration-Dimmwert EF 11 0 560
IDE05145-ENG116113-Light configuration-Dimmwert EF 12 0 560
IDE05145-ENG116132-Light configuration-Dimmwert EF 13 0 560
IDE05145-ENG116151-Light configuration-Dimmwert EF 14 0 560
IDE05145-ENG116170-Light configuration-Dimmwert EF 15 0 560
IDE05145-ENG116189-Light configuration-Dimmwert EF 16 0 560
IDE05145-ENG116208-Light configuration-Dimmwert EF 17 0 560
IDE05145-ENG116227-Light configuration-Dimmwert EF 18 0 560
IDE05145-ENG116246-Light configuration-Dimmwert EF 19 0 560
IDE05145-ENG115923-Light configuration-Dimmwert EF 2 28 560
IDE05145-ENG116265-Light configuration-Dimmwert EF 20 0 560
IDE05145-ENG116284-Light configuration-Dimmwert EF 21 0 560
IDE05145-ENG116303-Light configuration-Dimmwert EF 22 0 560
IDE05145-ENG116322-Light configuration-Dimmwert EF 23 0 560
IDE05145-ENG116341-Light configuration-Dimmwert EF 24 0 560
IDE05145-ENG116360-Light configuration-Dimmwert EF 25 0 560
IDE05145-ENG116379-Light configuration-Dimmwert EF 26 0 560
IDE05145-ENG116398-Light configuration-Dimmwert EF 27 100 560
IDE05145-ENG116417-Light configuration-Dimmwert EF 28 0 560
IDE05145-ENG116436-Light configuration-Dimmwert EF 29 0 560
IDE05145-ENG115942-Light configuration-Dimmwert EF 3 28 560
IDE05145-ENG116455-Light configuration-Dimmwert EF 30 0 560
IDE05145-ENG116474-Light configuration-Dimmwert EF 31 0 560
IDE05145-ENG116493-Light configuration-Dimmwert EF 32 0 560
IDE05145-ENG116512-Light configuration-Dimmwert EF 33 0 560
IDE05145-ENG116531-Light configuration-Dimmwert EF 34 0 560
IDE05145-ENG115961-Light configuration-Dimmwert EF 4 127 560
IDE05145-ENG115980-Light configuration-Dimmwert EF 5 127 560
IDE05145-ENG115999-Light configuration-Dimmwert EF 6 0 560
IDE05145-ENG116018-Light configuration-Dimmwert EF 7 0 560
IDE05145-ENG116037-Light configuration-Dimmwert EF 8 0 560
IDE05145-ENG116056-Light configuration-Dimmwert EF 9 0 560
IDE05145-ENG115890-Light configuration-Dimmwert GH 0 0 560
IDE05145-ENG115908-Light configuration-Dimmwert GH 1 0 560
IDE05145-ENG116079-Light configuration-Dimmwert GH 10 0 560
IDE05145-ENG116098-Light configuration-Dimmwert GH 11 0 560
IDE05145-ENG116117-Light configuration-Dimmwert GH 12 0 560
IDE05145-ENG116136-Light configuration-Dimmwert GH 13 0 560
IDE05145-ENG116155-Light configuration-Dimmwert GH 14 0 560
IDE05145-ENG116174-Light configuration-Dimmwert GH 15 0 560
IDE05145-ENG116193-Light configuration-Dimmwert GH 16 0 560
IDE05145-ENG116212-Light configuration-Dimmwert GH 17 0 560
IDE05145-ENG116231-Light configuration-Dimmwert GH 18 0 560
IDE05145-ENG116250-Light configuration-Dimmwert GH 19 0 560
IDE05145-ENG115927-Light configuration-Dimmwert GH 2 28 560
IDE05145-ENG116269-Light configuration-Dimmwert GH 20 0 560
IDE05145-ENG116288-Light configuration-Dimmwert GH 21 0 560
IDE05145-ENG116307-Light configuration-Dimmwert GH 22 0 560
IDE05145-ENG116326-Light configuration-Dimmwert GH 23 0 560
IDE05145-ENG116345-Light configuration-Dimmwert GH 24 0 560
IDE05145-ENG116364-Light configuration-Dimmwert GH 25 0 560
IDE05145-ENG116383-Light configuration-Dimmwert GH 26 0 560
IDE05145-ENG116402-Light configuration-Dimmwert GH 27 0 560
IDE05145-ENG116421-Light configuration-Dimmwert GH 28 0 560
IDE05145-ENG116440-Light configuration-Dimmwert GH 29 0 560
IDE05145-ENG115946-Light configuration-Dimmwert GH 3 28 560
IDE05145-ENG116459-Light configuration-Dimmwert GH 30 0 560
IDE05145-ENG116478-Light configuration-Dimmwert GH 31 0 560
IDE05145-ENG116497-Light configuration-Dimmwert GH 32 0 560
IDE05145-ENG116516-Light configuration-Dimmwert GH 33 0 560
IDE05145-ENG116535-Light configuration-Dimmwert GH 34 0 560
IDE05145-ENG115965-Light configuration-Dimmwert GH 4 0 560
IDE05145-ENG115984-Light configuration-Dimmwert GH 5 0 560
IDE05145-ENG116003-Light configuration-Dimmwert GH 6 0 560
IDE05145-ENG116022-Light configuration-Dimmwert GH 7 0 560
IDE05145-ENG116041-Light configuration-Dimmwert GH 8 0 560
IDE05145-ENG116060-Light configuration-Dimmwert GH 9 0 560
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0 14 560
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1 15 560
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10 0 560
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11 0 560
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12 22 560
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13 23 560
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14 0 560
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15 0 560
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16 3A 560
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17 39 560
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18 16 560
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19 18 560
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2 4A 560
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20 2B 560
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21 2D 560
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22 2C 560
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23 29 560
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24 2A 560
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25 30 560
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26 2E 560
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27 36 560
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28 37 560
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29 32 560
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3 4C 560
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30 2 560
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31 0 560
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32 0 560
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33 0 560
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34 0 560
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4 49 560
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5 4B 560
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6 1A 560
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7 1B 560
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8 0 560
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9 0 560
IDE05145-ENG115873-Light configuration-Lasttyp 0 33 - LED-Modul Blinkleuchten 560
IDE05145-ENG115892-Light configuration-Lasttyp 1 33 - LED-Modul Blinkleuchten 560
IDE05145-ENG116062-Light configuration-Lasttyp 10 not active 560
IDE05145-ENG116081-Light configuration-Lasttyp 11 not active 560
IDE05145-ENG116100-Light configuration-Lasttyp 12 10 - allgemeine Scheinwerfer 560
IDE05145-ENG116119-Light configuration-Lasttyp 13 10 - allgemeine Scheinwerfer 560
IDE05145-ENG116138-Light configuration-Lasttyp 14 not active 560
IDE05145-ENG116157-Light configuration-Lasttyp 15 not active 560
IDE05145-ENG116176-Light configuration-Lasttyp 16 37 - allgemeine LED bis 12W 560
IDE05145-ENG116195-Light configuration-Lasttyp 17 37 - allgemeine LED bis 12W 560
IDE05145-ENG116214-Light configuration-Lasttyp 18 38 - LED Blinkleuchten 560
IDE05145-ENG116233-Light configuration-Lasttyp 19 38 - LED Blinkleuchten 560
IDE05145-ENG115910-Light configuration-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116252-Light configuration-Lasttyp 20 34 - LED Bremsleuchten 560
IDE05145-ENG116271-Light configuration-Lasttyp 21 34 - LED Bremsleuchten 560
IDE05145-ENG116290-Light configuration-Lasttyp 22 42 - LED dritte Bremsleuchte 560
IDE05145-ENG116309-Light configuration-Lasttyp 23 32 - allgemeine LED bis 12W 560
IDE05145-ENG116328-Light configuration-Lasttyp 24 32 - allgemeine LED bis 12W 560
IDE05145-ENG116347-Light configuration-Lasttyp 25 43 - allgemeine LED 560
IDE05145-ENG116366-Light configuration-Lasttyp 26 43 - allgemeine LED 560
IDE05145-ENG116385-Light configuration-Lasttyp 27 32 - allgemeine LED bis 12W 560
IDE05145-ENG116404-Light configuration-Lasttyp 28 34 - LED Bremsleuchten 560
IDE05145-ENG116423-Light configuration-Lasttyp 29 37 - allgemeine LED bis 12W 560
IDE05145-ENG115929-Light configuration-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 560
IDE05145-ENG116442-Light configuration-Lasttyp 30 36 - LED Kleinleistung 560
IDE05145-ENG116461-Light configuration-Lasttyp 31 not active 560
IDE05145-ENG116480-Light configuration-Lasttyp 32 not active 560
IDE05145-ENG116499-Light configuration-Lasttyp 33 not active 560
IDE05145-ENG116518-Light configuration-Lasttyp 34 not active 560
IDE05145-ENG115948-Light configuration-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115967-Light configuration-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 560
IDE05145-ENG115986-Light configuration-Lasttyp 6 5 - LED Abblendlicht 560
IDE05145-ENG116005-Light configuration-Lasttyp 7 5 - LED Abblendlicht 560
IDE05145-ENG116024-Light configuration-Lasttyp 8 not active 560
IDE05145-ENG116043-Light configuration-Lasttyp 9 not active 560
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0 Always 560
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1 Always 560
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10 Always 560
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11 Always 560
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12 Always 560
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13 Always 560
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14 Always 560
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15 Always 560
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16 Always 560
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17 Always 560
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18 Always 560
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19 Always 560
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2 Always 560
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20 Always 560
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21 Always 560
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22 Always 560
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23 Always 560
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24 Always 560
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25 Always 560
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26 only_if_closed 560
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27 Always 560
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28 Always 560
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29 Always 560
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3 Always 560
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30 Always 560
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31 Always 560
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32 Always 560
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33 Always 560
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34 Always 560
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4 Always 560
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5 Always 560
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6 Always 560
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7 Always 560
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8 Always 560
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9 Always 560
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17 9 560
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13 0 560
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0 2 560
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1 4 560
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10 0 560
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11 0 560
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12 18 560
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13 19 560
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14 0 560
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15 0 560
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16 8 560
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17 8 560
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18 2 560
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19 4 560
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2 20 560
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20 24 560
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21 24 560
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22 24 560
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23 8 560
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24 8 560
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25 8 560
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26 27 560
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27 8 560
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28 24 560
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29 25 560
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3 20 560
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30 43 560
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31 0 560
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32 0 560
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33 0 560
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34 0 560
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4 20 560
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5 20 560
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6 11 560
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7 12 560
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8 0 560
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9 0 560
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0 0 560
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1 0 560
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10 0 560
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11 0 560
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12 0 560
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13 0 560
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14 0 560
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15 0 560
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16 10 560
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18 0 560
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19 0 560
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2 0 560
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20 0 560
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21 0 560
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22 36 560
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23 9 560
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24 10 560
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25 0 560
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26 0 560
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27 0 560
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28 0 560
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29 0 560
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3 0 560
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30 0 560
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31 0 560
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32 0 560
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33 0 560
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34 0 560
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4 0 560
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5 0 560
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6 15 560
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7 15 560
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8 0 560
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9 0 560
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0 0 560
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1 0 560
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10 0 560
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11 0 560
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12 0 560
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14 0 560
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15 0 560
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16 24 560
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17 24 560
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18 0 560
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19 0 560
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2 6 560
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20 0 560
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21 0 560
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22 0 560
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23 6 560
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24 7 560
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25 0 560
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26 0 560
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27 24 560
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28 27 560
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29 0 560
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3 7 560
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30 0 560
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31 0 560
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32 0 560
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33 0 560
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34 0 560
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4 0 560
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5 0 560
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6 0 560
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7 0 560
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8 0 560
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9 0 560
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0 0 560
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1 0 560
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10 0 560
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11 0 560
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12 0 560
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13 0 560
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14 0 560
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15 0 560
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16 0 560
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17 0 560
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18 0 560
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19 0 560
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2 0 560
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20 0 560
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21 0 560
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22 0 560
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23 24 560
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24 24 560
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25 0 560
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26 0 560
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27 0 560
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28 0 560
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29 0 560
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3 0 560
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30 0 560
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31 0 560
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32 0 560
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33 0 560
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34 0 560
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4 0 560
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5 0 560
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6 0 560
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7 0 560
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8 0 560
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9 0 560
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0 0 560
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1 0 560
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10 0 560
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11 0 560
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12 0 560
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13 0 560
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14 0 560
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15 0 560
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16 0 560
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17 0 560
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18 0 560
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19 0 560
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2 8 560
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20 0 560
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21 0 560
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22 0 560
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23 0 560
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24 0 560
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25 0 560
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26 0 560
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27 27 560
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28 0 560
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29 0 560
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3 8 560
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30 0 560
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31 0 560
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32 0 560
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33 0 560
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34 0 560
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4 8 560
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5 8 560
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6 0 560
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7 0 560
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8 0 560
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9 0 560
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0 0 560
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1 0 560
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10 0 560
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11 0 560
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12 0 560
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13 0 560
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14 0 560
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15 0 560
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16 0 560
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17 0 560
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18 0 560
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19 0 560
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2 9 560
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20 0 560
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21 0 560
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22 0 560
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23 0 560
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24 0 560
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25 0 560
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26 0 560
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27 0 560
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28 0 560
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29 0 560
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30 0 560
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31 0 560
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32 0 560
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33 0 560
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34 0 560
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4 9 560
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6 0 560
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7 0 560
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8 0 560
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9 0 560
IDE05145-ENG115941-Light configuration-Lichtfunktion F3 10 560
IDE05145-ENG115979-Light configuration-Lichtfunktion F5 10 560
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0 0 560
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1 0 560
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10 0 560
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11 0 560
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12 0 560
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13 0 560
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14 0 560
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15 0 560
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16 0 560
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17 0 560
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18 0 560
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19 0 560
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2 18 560
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20 0 560
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21 0 560
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22 0 560
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23 0 560
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24 0 560
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25 0 560
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26 0 560
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27 0 560
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28 0 560
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29 0 560
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3 19 560
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30 0 560
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31 0 560
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32 0 560
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33 0 560
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34 0 560
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4 0 560
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5 0 560
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6 0 560
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7 0 560
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8 0 560
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9 0 560
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0 0 560
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1 0 560
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10 0 560
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11 0 560
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12 0 560
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13 0 560
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14 0 560
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15 0 560
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16 0 560
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17 0 560
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18 0 560
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19 0 560
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2 0 560
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20 0 560
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21 0 560
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22 0 560
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23 0 560
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24 0 560
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25 0 560
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26 0 560
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27 0 560
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28 0 560
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29 0 560
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3 0 560
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30 0 560
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31 0 560
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32 0 560
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33 0 560
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34 0 560
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4 0 560
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5 0 560
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6 0 560
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7 0 560
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8 0 560
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9 0 560
IDE05145-ENG154438-Light configuration-Reserved 0 0 560
IDE05145-ENG99841-Light configuration-Reserved 1 0 560
IDE05145-ENG154357-Light configuration-Reserved 10 0 560
IDE05145-ENG154352-Light configuration-Reserved 11 0 560
IDE05145-ENG154182-Light configuration-Reserved 12 0 560
IDE05145-ENG154265-Light configuration-Reserved 13 0 560
IDE05145-ENG154334-Light configuration-Reserved 14 0 560
IDE05145-ENG154340-Light configuration-Reserved 15 0 560
IDE05145-ENG154204-Light configuration-Reserved 16 0 560
IDE05145-ENG154344-Light configuration-Reserved 17 0 560
IDE05145-ENG154195-Light configuration-Reserved 18 0 560
IDE05145-ENG154190-Light configuration-Reserved 19 0 560
IDE05145-ENG99862-Light configuration-Reserved 2 0 560
IDE05145-ENG154300-Light configuration-Reserved 20 0 560
IDE05145-ENG154439-Light configuration-Reserved 21 0 560
IDE05145-ENG154440-Light configuration-Reserved 22 0 560
IDE05145-ENG154441-Light configuration-Reserved 23 0 560
IDE05145-ENG154442-Light configuration-Reserved 24 0 560
IDE05145-ENG154443-Light configuration-Reserved 25 0 560
IDE05145-ENG154444-Light configuration-Reserved 26 0 560
IDE05145-ENG154445-Light configuration-Reserved 27 0 560
IDE05145-ENG154446-Light configuration-Reserved 28 0 560
IDE05145-ENG154447-Light configuration-Reserved 29 0 560
IDE05145-ENG101107-Light configuration-Reserved 3 0 560
IDE05145-ENG154448-Light configuration-Reserved 30 0 560
IDE05145-ENG154449-Light configuration-Reserved 31 0 560
IDE05145-ENG154450-Light configuration-Reserved 32 0 560
IDE05145-ENG154451-Light configuration-Reserved 33 0 560
IDE05145-ENG154452-Light configuration-Reserved 34 0 560
IDE05145-ENG154267-Light configuration-Reserved 4 0 560
IDE05145-ENG154291-Light configuration-Reserved 5 0 560
IDE05145-ENG154239-Light configuration-Reserved 6 0 560
IDE05145-ENG154308-Light configuration-Reserved 7 0 560
IDE05145-ENG154184-Light configuration-Reserved 8 0 560
IDE05145-ENG154255-Light configuration-Reserved 9 0 560
IDE05822-DWA Vehicle inclination sensor 100% 1
IDE05823-DWA Interior monitoring parameter set 01 0A 08 00 43 53 0A C8 01 14 0A 03 81 33 0C 00 00 00 01 CD D6 06 00 0F 1E 00 85 0F 39 F7 64 23 45 42 57 9B 25 44 3F 3A 69 58 95 2D 09 A3 02 7A 06 56 00 0F 17 00 89 10 2F F7 69 0F E3 42 87 1B 05 34 3F 3A 69 58 03 08 09 A3 03 44 46 2A 00 0F 1C 00 88 0E 2F E7 69 1E 65 42 77 1B 05 24 3F 3A 69 47 03 08 09 A3 04 FF F6 46 00 0F 1E 00 85 1E 32 F7 44 0C 42 20 57 1B 05 24 3F 3A 69 58 02 05 09 A3 05 29 04 19 15 0C 12 18 84 09 26 33 6A 23 45 42 57 9B 25 24 0C FA 0A 34 95 2D 09 A3 21 03 00 02 02 02 02 02 02 B1 10 C2 28 29 172
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss 1 s 24
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss 0.00 °C 24
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle 23.00 °C 24
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle 22.00 °C 24
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle 23.00 °C 24
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle 22.00 °C 24
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle 35.50 °C 24
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle 36.00 °C 24
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle 35.50 °C 24
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle 54.00 °C 24
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle 53.00 °C 24
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle 54.00 °C 24
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle 53.00 °C 24
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten not active 8
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM not active 8
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe not active 8
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten not active 8
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung active 8
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert 50% 8
IDE06425-Roller test bench mode: functional not active 1
IDE06507-MAS13125-Button in center console-Function of button 1 Start-stop 8
IDE06507-MAS13129-Button in center console-Function of button 2 GTE 8
IDE06507-MAS13132-Button in center console-Function of button 3 Driving program 8
IDE06507-MAS13135-Button in center console-Function of button 4 Steering wheel heater 8
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag Daytime running lights 4
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht not active 4
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht active 4
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich not active 4
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten not active 4
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO not active 4
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht not active 4
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte not active 4
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge active 4
IDE07356-Position during interval mode 24.89 ° 2
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs abschalten nach der Nachlaufzeit 12
IDE07470-ENG133381-After-run for park light-Bedingungen zur Parklichtbegrenzung abschaltbar über Energiemanagement 12
IDE07470-ENG133380-After-run for park light-Bedingungen zur Standlichtbegrenzung abschaltbar über Energiemanagement 12
IDE07470-ENG133382-After-run for park light-Faktor fuer Verfügbarkeitstimer Faktor fuer x5 Minuten 12
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit 30 min 12
IDE07470-ENG133383-After-run for park light-Standlicht-Verfügbarkeit 24 s 12
IDE08542-IDE02021-Access control 2-Comfort closing active 8
IDE08542-IDE02022-Access control 2-Comfort opening not active 8
IDE08542-ENG128459-Access control 2-easycloselight_aktiv not active 8
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen active 8
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen active 8
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit 600 s 8
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus active 8
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen active 8
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen active 8
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen active 8
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen active 8
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus by look command via remote control key 8
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen not active 8
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen active 8
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung not active 8
IDE08542-ENG115670-Access control 2-Komfortbedienung global active 8
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer not active 8
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen active 8
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar adjustable 8
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen not active 8
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung active 8
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung active 8
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf not active 8
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel active 8
IDE08542-ENG125656-Access control 2-Regenschliessen_art once 8
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus not active 8
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock not_active 8
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen active 8
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen active 8
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen active 8
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen tilting 8
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen not active 8
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen not active 8
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung active 8
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt active 8
IDE08542-ENG133411-Access control 2-Spiegelanklappen_bei_Wiederverriegelung not active 8
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron active 8
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal active 8
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar active 8
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung 2000 ms 8
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen active 8
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach active 8
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig Hinweis_in_LDS-Stellung_Null_und_SL 8
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset active 8
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert 0 ms 8
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit normal 8
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe active 8
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent present 8
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung present 8
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA active 8
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte not active 8
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben active 2
IDE08787-ENG101416-Auxiliary functions-Reserved_1 not active 2
IDE08787-ENG99458-Auxiliary functions-Reserved_2 not active 2
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15 active 2
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren not active 2
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT not active 2
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken not active 4
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing not active 4
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken not active 4
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung not active 4
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken not active 4
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken not active 4
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2 not active 4
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing not active 4
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links not active 4
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts not active 4
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken not active 4
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing not active 4
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken not active 4
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken not active 4
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS not active 4
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN not active 4
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf not active 4
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu not active 4
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit 0.25 s 20
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1 0 20
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2 0 20
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3 0 20
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1 225 20
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2 225 20
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3 225 20
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig not active 20
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig not active 20
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach 80% 20
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe 0 20
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole 80% 20
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen active 20
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1 225 20
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2 225 20
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3 225 20
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen active 20
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen active 20
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen active 20
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen active 20
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen active 20
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen active 20
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen not active 20
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig not active 20
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig not active 20
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren not active 20
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig not active 20
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1 225 20
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2 225 20
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3 225 20
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig not active 20
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel not active 20
IDE09732-ENG133384-Interior light: light configuration-Ambient_Farbliste_HMI not active 2
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel not installed 2
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel installed 2
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher not installed 2
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen active 2
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus not active 2
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung not installed 2
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung not installed 2
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil not installed 2
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI not installed 2
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting installed 2
IDE09732-ENG133385-Interior light: light configuration-Frei_Farbwahl_ueber_HMI not active 2
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar not active 2
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung not installed 2
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung not installed 2
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne 30% 12
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz 30% 12
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne 30% 12
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz 30% 12
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne 50% 12
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz 50% 12
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne 50% 12
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz 50% 12
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne 75% 12
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz 75% 12
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne 80% 12
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz 80% 12
IDE10298-Alternating park position 1 8.30 ° 2
IDE10299-Alternating park position 2 24.89 ° 2
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit 64 256
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach 28 256
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum 28 256
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel 3C 256
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher 64 256
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko 64 256
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd 64 256
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer 3C 256
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI 1 256
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2 3C 256
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3 0 256
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4 0 256
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI 0 256
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2 0 256
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3 0 256
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4 0 256
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab 1 256
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf 1 256
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI 0 256
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay 0 256
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach 60% 256
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach 60% 256
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum 70% 256
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel 96% 256
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren 96% 256
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach 60% 256
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach 60% 256
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum 70% 256
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel 96% 256
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren 96% 256
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit 100% 256
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach 60% 256
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum 70% 256
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht 100% 256
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel 96% 256
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher 100% 256
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko 100% 256
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd 100% 256
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren 96% 256
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit 100% 256
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach 60% 256
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum 0% 256
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht 100% 256
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel 0% 256
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher 100% 256
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko 100% 256
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd 100% 256
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren 0% 256
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach 60% 256
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum 70% 256
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel 96% 256
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren 96% 256
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit 100% 256
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach 127% 256
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum 127% 256
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel 127% 256
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko 100% 256
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd 100% 256
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren 127% 256
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit 126% 256
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach 126% 256
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum 126% 256
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht 0% 256
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel 126% 256
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher 126% 256
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko 126% 256
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd 126% 256
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren 126% 256
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach 127% 256
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum 127% 256
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel 127% 256
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren 127% 256
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit 100% 256
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach 126% 256
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum 126% 256
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht 100% 256
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel 126% 256
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher 100% 256
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko 100% 256
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd 100% 256
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren 126% 256
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit 100% 256
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach 60% 256
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum 70% 256
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht 100% 256
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel 96% 256
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher 100% 256
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko 100% 256
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd 100% 256
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren 96% 256
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit 100% 256
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach 60% 256
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum 70% 256
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel 96% 256
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko 100% 256
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd 100% 256
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren 96% 256
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit 100% 256
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach 60% 256
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum 70% 256
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht 100% 256
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel 96% 256
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher 100% 256
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko 100% 256
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd 100% 256
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren 96% 256
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit 100% 256
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach 60% 256
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum 70% 256
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht 100% 256
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel 96% 256
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher 100% 256
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko 100% 256
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd 100% 256
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren 96% 256
IDE11477-ENG137165-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte 0 ms 256
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit 0 s 256
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach 0 s 256
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum 0 s 256
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht 0 s 256
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko 0 s 256
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren 0 s 256
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit 20 s 256
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach 0 s 256
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum 20 s 256
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht 0 s 256
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko 0 s 256
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren 5 s 256
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit 0 s 256
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach 0 s 256
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum 0 s 256
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht 0 s 256
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko 0 s 256
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren 0 s 256
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit 0 s 256
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach 0 s 256
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum 0 s 256
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht 0 s 256
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko 0 s 256
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren 0 s 256
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit 0 s 256
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach 0 s 256
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum 0 s 256
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht 0 s 256
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko 0 s 256
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren 0 s 256
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit 0 s 256
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach 0 s 256
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum 0 s 256
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht 0 s 256
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko 0 s 256
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren 0 s 256
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit 0 s 256
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach 0 s 256
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum 0 s 256
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht 0 s 256
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko 0 s 256
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren 0 s 256
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen 0 256
IDE11714-ENG133432-Ambient light color list-Blauwert Farbe 10 E1 30
IDE11714-ENG133414-Ambient light color list-Blauwert Farbe 4 E1 30
IDE11714-ENG133417-Ambient light color list-Blauwert Farbe 5 E1 30
IDE11714-ENG133420-Ambient light color list-Blauwert Farbe 6 E1 30
IDE11714-ENG133423-Ambient light color list-Blauwert Farbe 7 E1 30
IDE11714-ENG133426-Ambient light color list-Blauwert Farbe 8 E1 30
IDE11714-ENG133429-Ambient light color list-Blauwert Farbe 9 E1 30
IDE11714-ENG133431-Ambient light color list-Gruenwert Farbe 10 E1 30
IDE11714-ENG133413-Ambient light color list-Gruenwert Farbe 4 E1 30
IDE11714-ENG133416-Ambient light color list-Gruenwert Farbe 5 E1 30
IDE11714-ENG133419-Ambient light color list-Gruenwert Farbe 6 E1 30
IDE11714-ENG133422-Ambient light color list-Gruenwert Farbe 7 E1 30
IDE11714-ENG133425-Ambient light color list-Gruenwert Farbe 8 E1 30
IDE11714-ENG133428-Ambient light color list-Gruenwert Farbe 9 E1 30
IDE11714-ENG133430-Ambient light color list-Rotwert Farbe 10 E1 30
IDE11714-ENG133412-Ambient light color list-Rotwert Farbe 4 E1 30
IDE11714-ENG133415-Ambient light color list-Rotwert Farbe 5 E1 30
IDE11714-ENG133418-Ambient light color list-Rotwert Farbe 6 E1 30
IDE11714-ENG133421-Ambient light color list-Rotwert Farbe 7 E1 30
IDE11714-ENG133424-Ambient light color list-Rotwert Farbe 8 E1 30
IDE11714-ENG133427-Ambient light color list-Rotwert Farbe 9 E1 30
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation Energy management active 1
MAS01490-ENG133400-Energy management-Praediktives_Energiemanagement not active 1
MAS05055-lower turn position 26.30 ° 2
MAS05056-upper turn position 171.30 ° 2
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck active 8
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb not active 8
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG not active 8
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global active 8
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen active 8
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen active 8
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen active 8
MAS05934-ENG133391-Convert. top oper.-Remote Lock Unlock Timer s1 80 s 8
MAS05934-ENG133392-Convert. top oper.-Remote Lock Unlock Timer s3 20.000 ms 8
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach not active 8
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung active 8
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy active 8
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder active 8
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung active 8
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy active 8
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder active 8
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein active 8
MAS08228-ENG133434-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze 60 lx 24
MAS08228-ENG133435-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze 110 lx 24
MAS08228-ENG133444-Light sensor-ECE_Lichteinschaltschwelle 1000 lx 24
MAS08228-ENG133433-Light sensor-Einschaltgrenze_CHO_LHO 30 lx 24
MAS08228-ENG133437-Light sensor-Helligkeitsgrenze_Licht__einschalten 60 lx 24
MAS08228-ENG133438-Light sensor-Helligkeitsgrenze_Licht_ausschalten 110 lx 24
MAS08228-ENG133445-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red 80 24
MAS08228-ENG133436-Light sensor-Helligkeitsgrenze_sehr_hell 100 lx 24
MAS08228-ENG133442-Light sensor-Maximale_Ausgangsspannung 4500 mV 24
MAS08228-ENG133440-Light sensor-Maximale_Beleuchtungsstaerke 300 lx 24
MAS08228-ENG133441-Light sensor-Minimale_Ausgangsspannung 2000 mV 24
MAS08228-ENG133439-Light sensor-Minimale_Beleuchtungsstaerke 0 lx 24
MAS08228-ENG133443-Light sensor-Tunnel_einschalt_verzoegerung 2 24
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1 1 30
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10 1 30
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11 1 30
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12 1 30
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13 1 30
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14 1 30
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15 1 30
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2 1 30
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3 1 30
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4 1 30
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5 1 30
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6 1 30
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7 1 30
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8 1 30
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9 1 30
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1 door 30
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10 door 30
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11 door 30
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12 door 30
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13 door 30
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14 door 30
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15 door 30
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2 door 30
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3 door 30
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4 door 30
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5 door 30
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6 door 30
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7 door 30
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8 door 30
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9 door 30
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1 not installed 30
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10 not installed 30
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11 not installed 30
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12 not installed 30
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13 not installed 30
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14 not installed 30
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15 not installed 30
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2 not installed 30
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3 not installed 30
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4 not installed 30
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5 not installed 30
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6 not installed 30
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7 not installed 30
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8 not installed 30
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9 not installed 30
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12 0 60
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1 0 60
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10 0 60
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11 0 60
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13 0 60
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14 0 60
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15 0 60
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16 0 60
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17 0 60
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18 0 60
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19 0 60
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2 0 60
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20 0 60
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3 0 60
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4 0 60
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5 0 60
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6 0 60
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7 0 60
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8 0 60
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9 0 60
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1 0 60
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10 0 60
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11 0 60
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12 0 60
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13 0 60
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14 0 60
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15 0 60
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16 0 60
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17 0 60
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18 0 60
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19 0 60
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2 0 60
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20 0 60
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3 0 60
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4 0 60
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5 0 60
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6 0 60
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7 0 60
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9 0 60
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8 0 60
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1 not installed 60
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10 not installed 60
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11 not installed 60
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12 not installed 60
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13 not installed 60
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14 not installed 60
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15 not installed 60
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16 not installed 60
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17 not installed 60
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18 not installed 60
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19 not installed 60
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2 not installed 60
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20 not installed 60
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3 not installed 60
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4 not installed 60
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5 not installed 60
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6 not installed 60
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7 not installed 60
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9 not installed 60
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8 not installed 60
ENG126647-ENG98399-debug_light_function-Activation 0 11
ENG126647-ENG101417-debug_light_function-Adresse 0 11
ENG126647-ENG126820-debug_light_function-Bitmask 0 11
ENG126647-ENG126821-debug_light_function-Divisor 0 11
ENG126647-ENG98827-debug_light_function-Offset 0 11
ENG126647-ENG126822-debug_light_function-Polaritaet 0 11
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe 0 11
ENG99457-ENG117394-Head area heater-blower_speed 1 2
ENG99457-ENG98971-Head area heater-Temperature -2 2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0 0 ms 22
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1 200 ms 22
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10 2000 ms 22
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2 400 ms 22
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3 600 ms 22
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4 800 ms 22
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5 1000 ms 22
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6 1200 ms 22
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7 1400 ms 22
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8 1600 ms 22
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9 1800 ms 22
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0 100.00% 22
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1 72.00% 22
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10 0.00% 22
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2 48.00% 22
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3 33.00% 22
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4 18.00% 22
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5 12.00% 22
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6 8.00% 22
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7 6.00% 22
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8 4.00% 22
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9 2.00% 22
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0 0 22
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1 50 22
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10 0 22
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2 100 22
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3 200 22
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4 253 22
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5 0 22
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6 0 22
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7 0 22
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8 0 22
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9 0 22
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0 0 lx 22
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1 50 lx 22
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10 0 lx 22
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2 100 lx 22
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3 200 22
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4 500 22
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5 0 22
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6 0 lx 22
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7 0 lx 22
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8 0 lx 22
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9 0 lx 22
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0 0 ms 22
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1 200 ms 22
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10 2000 ms 22
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2 400 ms 22
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3 600 ms 22
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4 800 ms 22
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5 1000 ms 22
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6 1200 ms 22
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7 1400 ms 22
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8 1600 ms 22
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9 1800 ms 22
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0 0.00% 22
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1 1.00% 22
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10 100.00% 22
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2 3.00% 22
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3 5.00% 22
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4 11.00% 22
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5 22.00% 22
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6 40.00% 22
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7 80.00% 22
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8 95.00% 22
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9 100.00% 22
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0 0.00% 12
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1 6.00% 12
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2 16.00% 12
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3 30.00% 12
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4 60.00% 12
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5 100.00% 12
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0 10 12
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1 10 12
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2 100 12
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3 150 12
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4 220 12
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5 253 12
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0 0 lx 10
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1 8 lx 10
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2 200 lx 10
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3 300 lx 10
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4 500 lx 10
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0 16 10
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1 16 10
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2 100 10
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3 100 10
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4 100 10
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0 0 lx 10
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1 50 lx 10
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2 220 lx 10
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3 300 lx 10
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4 500 lx 10
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0 6 10
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1 16 10
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2 25 10
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3 30 10
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4 50 10
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0 0 12
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1 10 12
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2 50 12
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3 100 12
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4 220 12
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5 253 12
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0 2.00% 12
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1 2.00% 12
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2 6.00% 12
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3 10.00% 12
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4 80.00% 12
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5 100.00% 12
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0 0 lx 8
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1 8 lx 8
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2 50 lx 8
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3 500 lx 8
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0 100 8
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1 100 8
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2 100 8
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3 100 8
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0 0 lx 8
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1 8 lx 8
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2 50 lx 8
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3 500 lx 8
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0 6 8
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1 6 8
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2 100 8
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3 100 8
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0 0.00% 6
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1 50.00% 6
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2 100.00% 6
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0 0.00% 6
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1 50.00% 6
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2 100.00% 6
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0 0 lx 8
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1 8 lx 8
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2 50 lx 8
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3 500 lx 8
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0 100 8
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1 100 8
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2 100 8
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3 100 8
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0 0 lx 8
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1 8 lx 8
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2 50 lx 8
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3 500 lx 8
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0 6 8
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1 6 8
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2 100 8
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3 100 8
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0 0.00% 6
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1 50.00% 6
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2 100.00% 6
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0 0.00% 6
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1 50.00% 6
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2 100.00% 6
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0 0 ms 10
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1 100 ms 10
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2 160 ms 10
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3 200 ms 10
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4 260 ms 10
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0 1.00% 10
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1 5 10
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2 15 10
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3 10 10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4 100 10
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0 maximize 16
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0 maximize 16
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0 maximize 16
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0 127 16
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0 0 16
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0 0 16
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0 0 16
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0 14 16
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0 34 16
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0 33 - LED-Modul Blinkleuchten 16
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0 Always 16
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0 Blinken links Hellphase 16
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0 not active 16
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0 not active 16
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0 not active 16
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0 not active 16
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0 not active 16
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0 not active 16
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0 not active 16
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10 maximize 16
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10 maximize 16
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10 maximize 16
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10 0 16
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10 0 16
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10 0 16
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10 0 16
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10 0 16
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10 0 16
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10 not active 16
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10 Always 16
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10 not active 16
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10 not active 16
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10 not active 16
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10 not active 16
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10 not active 16
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10 not active 16
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10 not active 16
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10 not active 16
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11 maximize 16
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11 maximize 16
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11 maximize 16
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11 0 16
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11 0 16
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11 0 16
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11 0 16
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11 0 16
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11 0 16
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11 not active 16
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11 Always 16
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11 not active 16
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11 not active 16
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11 not active 16
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11 not active 16
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11 not active 16
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11 not active 16
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11 not active 16
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11 not active 16
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12 maximize 16
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12 maximize 16
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12 maximize 16
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12 100 16
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12 0 16
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12 0 16
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12 0 16
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12 22 16
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12 38 16
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12 10 - allgemeine Scheinwerfer 16
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12 Always 16
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12 Nebellicht links 16
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12 not active 16
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12 not active 16
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12 not active 16
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12 not active 16
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12 not active 16
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12 not active 16
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12 not active 16
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13 maximize 16
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13 maximize 16
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13 maximize 16
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13 100 16
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13 0 16
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13 0 16
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13 0 16
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13 23 16
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13 42 16
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13 10 - allgemeine Scheinwerfer 16
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13 Always 16
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13 Nebellicht rechts 16
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13 not active 16
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13 not active 16
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13 not active 16
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13 not active 16
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13 not active 16
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13 not active 16
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13 not active 16
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15 maximize 16
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15 maximize 16
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15 maximize 16
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15 0 16
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15 0 16
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15 0 16
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15 0 16
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15 0 16
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15 0 16
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15 not active 16
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15 Always 16
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15 not active 16
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15 not active 16
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15 not active 16
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15 not active 16
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15 not active 16
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15 not active 16
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15 not active 16
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15 not active 16
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16 maximize 16
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16 maximize 16
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16 maximize 16
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16 100 16
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16 100 16
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16 0 16
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16 0 16
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16 3A 16
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16 20 16
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16 37 - allgemeine LED bis 12W 16
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16 Always 16
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16 Parking light right 16
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16 Brake light 16
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16 not active 16
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16 not active 16
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16 not active 16
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16 not active 16
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16 not active 16
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17 maximize 16
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17 maximize 16
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17 maximize 16
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17 100 16
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17 100 16
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17 0 16
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17 0 16
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17 39 16
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17 10 16
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17 37 - allgemeine LED bis 12W 16
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17 Always 16
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17 Brake light 16
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17 not active 16
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17 not active 16
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17 not active 16
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17 not active 16
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17 not active 16
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18 maximize 16
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18 maximize 16
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18 maximize 16
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18 100 16
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18 0 16
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18 0 16
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18 0 16
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18 16 16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18 8 16
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18 38 - LED Blinkleuchten 16
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18 Always 16
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18 Blinken links Hellphase 16
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18 not active 16
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18 not active 16
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18 not active 16
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18 not active 16
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18 not active 16
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18 not active 16
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18 not active 16
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19 maximize 16
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19 maximize 16
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19 maximize 16
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19 100 16
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19 0 16
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19 0 16
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19 0 16
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19 18 16
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19 18 16
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19 38 - LED Blinkleuchten 16
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19 Always 16
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19 Blinken rechts Hellphase 16
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19 not active 16
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19 not active 16
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19 not active 16
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19 not active 16
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19 not active 16
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19 not active 16
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19 not active 16
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1 maximize 16
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1 maximize 16
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1 maximize 16
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1 127 16
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1 0 16
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1 0 16
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1 0 16
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1 15 16
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1 3E 16
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1 33 - LED-Modul Blinkleuchten 16
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1 Always 16
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1 Blinken rechts Hellphase 16
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1 not active 16
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1 not active 16
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1 not active 16
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1 not active 16
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1 not active 16
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1 not active 16
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1 not active 16
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20 maximize 16
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20 maximize 16
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20 maximize 16
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20 100 16
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20 0 16
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20 0 16
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20 0 16
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20 2B 16
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20 9 16
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20 34 - LED Bremsleuchten 16
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20 Always 16
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20 Brake light 16
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20 not active 16
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20 not active 16
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20 not active 16
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20 not active 16
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20 not active 16
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20 not active 16
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20 not active 16
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21 maximize 16
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21 maximize 16
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21 maximize 16
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21 100 16
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21 0 16
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21 0 16
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21 0 16
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21 2D 16
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21 19 16
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21 34 - LED Bremsleuchten 16
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21 Always 16
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21 Brake light 16
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21 not active 16
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21 not active 16
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21 not active 16
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21 not active 16
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21 not active 16
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21 not active 16
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21 not active 16
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22 maximize 16
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22 maximize 16
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22 maximize 16
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22 100 16
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22 0 16
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22 0 16
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22 0 16
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22 2C 16
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22 29 16
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22 42 - LED dritte Bremsleuchte 16
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22 Always 16
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22 Brake light 16
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22 Quittierungsfunktion 1 16
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22 not active 16
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22 not active 16
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22 not active 16
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22 not active 16
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22 not active 16
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22 not active 16
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23 minimize 16
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23 maximize 16
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23 maximize 16
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23 100 16
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23 0 16
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23 0 16
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23 0 16
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23 29 16
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23 0A 16
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23 32 - allgemeine LED bis 12W 16
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23 Always 16
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23 Blinken links aktiv (beide Phasen) 16
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23 Brake light 16
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23 not active 16
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23 not active 16
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23 not active 16
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23 not active 16
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24 minimize 16
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24 maximize 16
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24 maximize 16
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24 100 16
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24 0 16
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24 0 16
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24 0 16
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24 2A 16
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24 1A 16
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24 32 - allgemeine LED bis 12W 16
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24 Always 16
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24 Parking light right 16
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24 Blinken rechts aktiv (beide Phasen) 16
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24 Brake light 16
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24 not active 16
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24 not active 16
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24 not active 16
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24 not active 16
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25 maximize 16
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25 maximize 16
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25 maximize 16
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25 127 16
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25 0 16
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25 0 16
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25 0 16
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25 30 16
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25 28 16
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25 43 - allgemeine LED 16
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25 Always 16
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25 not active 16
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25 not active 16
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25 not active 16
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25 not active 16
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25 not active 16
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25 not active 16
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25 not active 16
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26 maximize 16
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26 maximize 16
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26 maximize 16
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26 90 16
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26 0 16
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26 0 16
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26 0 16
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26 2E 16
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26 0C 16
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26 43 - allgemeine LED 16
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26 only_if_closed 16
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26 Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr 16
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26 not active 16
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26 not active 16
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26 not active 16
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26 not active 16
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26 not active 16
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26 not active 16
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26 not active 16
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27 minimize 16
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27 maximize 16
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27 maximize 16
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27 100 16
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27 0 16
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27 100 16
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27 0 16
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27 36 16
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27 1A 16
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27 32 - allgemeine LED bis 12W 16
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27 Always 16
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27 not active 16
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27 Brake light 16
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27 not active 16
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27 Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr 16
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27 not active 16
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27 not active 16
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27 not active 16
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28 minimize 16
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28 maximize 16
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28 maximize 16
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28 100 16
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28 0 16
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28 0 16
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28 0 16
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28 37 16
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28 9 16
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28 34 - LED Bremsleuchten 16
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28 Always 16
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28 Brake light 16
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28 not active 16
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28 Nebelschlusslicht wenn kein Anhaenger gesteckt und Rechtsverkehr 16
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28 not active 16
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28 not active 16
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28 not active 16
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28 not active 16
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28 not active 16
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29 maximize 16
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29 maximize 16
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29 maximize 16
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29 100 16
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29 0 16
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29 0 16
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29 0 16
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29 32 16
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29 1B 16
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29 37 - allgemeine LED bis 12W 16
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29 Always 16
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29 Rueckfahrlicht 16
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29 not active 16
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29 not active 16
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29 not active 16
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29 not active 16
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29 not active 16
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29 not active 16
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29 not active 16
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2 minimize 16
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2 maximize 16
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2 minimize 16
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2 100 16
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2 28 16
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2 28 16
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2 28 16
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2 4A 16
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2 48 16
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2 4 - LED Tagfahrlichtmodul Signal 16
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2 Always 16
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2 Daytime running lights 16
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2 not active 16
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2 Blinken links aktiv (beide Phasen) 16
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2 not active 16
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2 Nebellicht links 16
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2 not active 16
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30 maximize 16
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30 maximize 16
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30 maximize 16
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30 100 16
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30 0 16
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30 0 16
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30 0 16
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30 2 16
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30 0 16
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30 36 - LED Kleinleistung 16
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30 Always 16
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30 Footwell light 16
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30 not active 16
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30 not active 16
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30 not active 16
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30 not active 16
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30 not active 16
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30 not active 16
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30 not active 16
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31 maximize 16
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31 maximize 16
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31 maximize 16
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31 0 16
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31 0 16
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31 0 16
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31 0 16
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31 0 16
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31 0 16
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31 not active 16
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31 Always 16
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31 not active 16
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31 not active 16
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31 not active 16
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31 not active 16
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31 not active 16
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31 not active 16
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31 not active 16
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31 not active 16
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32 maximize 16
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32 maximize 16
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32 maximize 16
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32 0 16
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32 0 16
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32 0 16
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32 0 16
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32 0 16
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32 0 16
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32 not active 16
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32 Always 16
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32 not active 16
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32 not active 16
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32 not active 16
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32 not active 16
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32 not active 16
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32 not active 16
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32 not active 16
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32 not active 16
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33 maximize 16
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33 maximize 16
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33 maximize 16
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33 0 16
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33 0 16
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33 0 16
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33 0 16
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33 0 16
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33 0 16
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33 not active 16
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33 Always 16
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33 not active 16
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33 not active 16
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33 not active 16
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33 not active 16
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33 not active 16
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33 not active 16
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33 not active 16
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33 not active 16
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34 maximize 16
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34 maximize 16
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34 maximize 16
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34 0 16
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34 0 16
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34 0 16
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34 0 16
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34 0 16
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34 0 16
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34 not active 16
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34 Always 16
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34 not active 16
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34 not active 16
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34 not active 16
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34 not active 16
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34 not active 16
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34 not active 16
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34 not active 16
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34 not active 16
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3 minimize 16
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3 maximize 16
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3 minimize 16
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3 100 16
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3 28 16
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3 28 16
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3 28 16
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3 4C 16
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3 4C 16
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3 4 - LED Tagfahrlichtmodul Signal 16
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3 Always 16
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3 Daytime running lights 16
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3 not active 16
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3 Blinken rechts aktiv (beide Phasen) 16
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3 not active 16
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3 Parking light right 16
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3 Nebellicht rechts 16
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3 not active 16
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4 maximize 16
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4 maximize 16
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4 maximize 16
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4 127 16
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4 0 16
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4 127 16
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4 0 16
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4 49 16
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4 3A 16
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4 Always 16
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4 Daytime running lights 16
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4 not active 16
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4 not active 16
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4 not active 16
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4 Parklicht links (beidseitiges Parklicht aktiviert li & re) 16
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4 not active 16
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4 not active 16
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5 maximize 16
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5 maximize 16
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5 maximize 16
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5 127 16
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5 0 16
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5 127 16
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5 0 16
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5 4B 16
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5 44 16
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5 1 - LED Tagfahrlichtmodul Versorgung 16
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5 Always 16
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5 Daytime running lights 16
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5 not active 16
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5 not active 16
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5 not active 16
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5 Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht) 16
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5 Parking light right 16
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5 not active 16
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5 not active 16
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6 maximize 16
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6 maximize 16
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6 maximize 16
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6 127 16
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6 0 16
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6 0 16
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6 0 16
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6 1A 16
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6 36 16
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6 5 - LED Abblendlicht 16
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6 Always 16
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6 Abblendlicht links 16
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6 Lichthupe generell 16
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6 not active 16
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6 not active 16
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6 not active 16
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6 not active 16
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6 not active 16
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6 not active 16
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7 maximize 16
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7 maximize 16
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7 maximize 16
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7 127 16
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7 0 16
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7 0 16
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7 0 16
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7 1B 16
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7 40 16
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7 5 - LED Abblendlicht 16
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7 Always 16
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7 Abblendlicht rechts 16
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7 Lichthupe generell 16
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7 not active 16
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7 not active 16
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7 not active 16
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7 not active 16
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7 not active 16
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7 not active 16
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8 maximize 16
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8 maximize 16
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8 maximize 16
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8 0 16
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8 0 16
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8 0 16
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8 0 16
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8 0 16
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8 0 16
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8 not active 16
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8 Always 16
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8 not active 16
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8 not active 16
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8 not active 16
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8 not active 16
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8 not active 16
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8 not active 16
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8 not active 16
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8 not active 16
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9 maximize 16
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9 maximize 16
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9 maximize 16
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9 0 16
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9 0 16
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9 0 16
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9 0 16
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9 0 16
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9 0 16
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9 not active 16
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9 Always 16
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9 not active 16
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9 not active 16
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9 not active 16
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9 not active 16
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9 not active 16
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9 not active 16
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9 not active 16
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9 not active 16
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14 maximize 16
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14 maximize 16
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14 maximize 16
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14 0 16
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14 0 16
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14 0 16
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14 0 16
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14 0 16
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14 0 16
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14 not active 16
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14 Always 16
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14 not active 16
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14 not active 16
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14 not active 16
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14 not active 16
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14 not active 16
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14 not active 16
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14 not active 16
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14 not active 16
ENG126648-MAS10452-LIN-Mirrormode-Data bus LIN 1 active 1
ENG126648-MAS10453-LIN-Mirrormode-Data bus LIN 2 active 1
ENG126648-MAS10454-LIN-Mirrormode-Data bus LIN 3 active 1
ENG126648-MAS12782-LIN-Mirrormode-Data bus LIN 4 active 1
ENG126648-MAS12783-LIN-Mirrormode-Data bus LIN 5 active 1
ENG126648-MAS12784-LIN-Mirrormode-Data bus LIN 6 active 1
ENG126648-ENG118465-LIN-Mirrormode-mirror_mode_typ not active 1
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0 0.00% 12
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1 5.00% 12
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2 50.00% 12
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3 75.00% 12
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4 110 12
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5 126.5 12
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0 0.00% 12
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1 6.00% 12
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2 16.00% 12
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3 30.00% 12
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4 60.00% 12
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5 100.00% 12
ENG98831-ENG126849-Personalization-Aktivierungsoption_im_HMI-Menue_sichtbar active 16
ENG98831-ENG133401-Personalization-Anzahl_Benutzerkonten 4 16
ENG98831-ENG133402-Personalization-Automatische_ Schluesselzuordnung not active 16
ENG98831-ENG126850-Personalization-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar active 16
ENG98831-ENG126848-Personalization-Personalisierung_aktiv active 16
ENG98831-ENG126851-Personalization-Personalisierungsfunktionen_in_HMI-Menue_sichtbar active 16
ENG98831-ENG133403-Personalization-PSO_FSG_Setup2_Bit_0 not active 16
ENG98831-ENG133404-Personalization-PSO_FSG_Setup2_Bit_1 active 16
ENG98831-ENG133405-Personalization-PSO_FSG_Setup2_Bit_2 active 16
ENG98831-ENG133406-Personalization-PSO_FSG_Setup2_Bit_3 active 16
ENG98831-ENG133407-Personalization-PSO_FSG_Setup2_Bit_4 not active 16
ENG98831-ENG133408-Personalization-PSO_FSG_Setup2_Bit_5 not active 16
ENG98831-ENG133409-Personalization-PSO_FSG_Setup2_Bit_6 not active 16
ENG98831-ENG133410-Personalization-PSO_FSG_Setup2_Bit_7 not active 16
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt active 8
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung active 8
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1 00 00 20
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2 00 00 20
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3 00 00 20
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4 00 00 20
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1 00 00 20
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2 00 00 20
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3 00 00 20
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4 00 00 20
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5 00 00 20
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6 00 00 20
Elapsed Time: 02:07
Not both together.IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn
;SW:3G0-035-021-C HW:3G0-035-021 --- Information Electr.
;Component:MU-H-TND-EU H50 0343 Coding:028401010000000051111102008808101F0100E4012000009F
;EV_MUHig4CGen2HBAS 1001 EV_MUHig4CGen2HBAS_VW37.rod
;Wednesday 22 August 2018 00:32:50:56142
;VCDS Version: Release 18.2.1 (x64) Data version: 20180518 DS287.1
;VCID: 183423C4E348E584FF-804C
IDE00001-Production mode 00 00 00 3
IDE00346-Summertime-automatic Europe 1
IDE00759-Base volume of speech output 50% 1
IDE00760-Microphone sensitivity 0 dB 1
IDE00768-Country identification: country of sale -- 2
IDE00769-Number 1 for Info call 5E 07 A1 80 00 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE00770-Number 1 for roadside assistance 5E 07 A1 80 00 98 37 87 24 F3 FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages OFF 1
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages OFF 1
IDE00845-Wheel circ. 0 mm 2
IDE01996-MAS00076-Installation list: specified installations-Instrument cluster control module Yes 3
IDE01996-MAS00839-Installation list: specified installations-TV Tuner No 3
IDE01996-MAS00844-Installation list: specified installations-Radio No 3
IDE01996-MAS00847-Installation list: specified installations-Digital Sound System Control Module Yes 3
IDE01996-MAS00849-Installation list: specified installations-Information electronics control module 1 Yes 3
IDE01996-MAS00850-Installation list: specified installations-Information electronics control module 2 No 3
IDE01996-MAS04300-Installation list: specified installations-DVD changer No 3
IDE01996-MAS14306-Installation list: specified installations-Windshield projection head up display control module No 3
IDE01996-SFT271943-Installation list: specified installations-Multimedia Operating Unit No 3
IDE01996-ENG154341-Installation list: specified installations-Reserved_8 No 3
IDE01996-ENG152491-Installation list: specified installations-Smart Control Carrier 1 No 3
IDE01996-ENG152490-Installation list: specified installations-Smart Control Carrier 2 No 3
IDE01996-ENG152488-Installation list: specified installations-Smart Display Carrier 1 No 3
IDE01996-ENG152492-Installation list: specified installations-Smart Display Carrier 2 No 3
IDE01996-ENG152493-Installation list: specified installations-Wireless Charger 1 No 3
IDE01996-ENG152489-Installation list: specified installations-Wireless Charger 2 No 3
IDE02121-CD eject button Enabled 1
IDE02122-Developer mode not activated 1
IDE02330-Number 2 for Info call 5E 08 91 94 81 20 68 55 97 42 63 FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02331-Number 2 for roadside assistance 5E 06 91 94 81 60 11 21 31 FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02332-Deactivate production mode 0 3
IDE02476-MAS03001-Electrical test of loudspeakers-Mode automatic 49
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency 19000 Hz 49
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume 22 49
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency 19000 Hz 49
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume 22 49
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency 19000 Hz 49
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume 22 49
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency 19000 Hz 49
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume 22 49
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency 19000 Hz 49
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume 22 49
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency 19000 Hz 49
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume 22 49
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency 19000 Hz 49
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume 22 49
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency 19000 Hz 49
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume 22 49
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency 19000 Hz 49
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume 22 49
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency 19000 Hz 49
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume 22 49
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency 19000 Hz 49
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume 22 49
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency 19000 Hz 49
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume 22 49
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency 19000 Hz 49
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume 22 49
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency 19000 Hz 49
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume 22 49
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency 19000 Hz 49
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume 22 49
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency 19000 Hz 49
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume 22 49
IDE02502-Confirmation of installation change 2E 81 2
IDE02506-MAS03229-Copy multimedia data-Data medium On 1
IDE02506-MAS03230-Copy multimedia data-Optical drive On 1
IDE02607-Wheel pulse 0 2
IDE02699-Number 1 for roadside assistance 5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE02701-Number 1 (roaming) for roadside assistance 5E 02 A1 11 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 23
IDE03238-ENG117830-Parameter for connection transfer (UMTS)-1E_EcLo 0 8
IDE03238-ENG117831-Parameter for connection transfer (UMTS)-1E_RSCP 15 8
IDE03238-ENG117832-Parameter for connection transfer (UMTS)-1F_EcLo 0 8
IDE03238-ENG117833-Parameter for connection transfer (UMTS)-1F_RSCP 15 8
IDE03238-ENG122277-Parameter for connection transfer (UMTS)-2D_EcLo 0 8
IDE03238-ENG122278-Parameter for connection transfer (UMTS)-2D_RSCP 11 8
IDE03238-ENG122275-Parameter for connection transfer (UMTS)-3A_EcLo 0 8
IDE03238-ENG122276-Parameter for connection transfer (UMTS)-3A_RSCP 8 8
IDE03471-ENG117847-Vehicle configuration-advanced_range_display OFF 30
IDE03471-ENG142146-Vehicle configuration-allow_message_editing OFF 30
IDE03471-ENG130249-Vehicle configuration-Apple_DIO On 30
IDE03471-ENG185764-Vehicle configuration-Apple_DIO_Wireless OFF 30
IDE03471-ENG152525-Vehicle configuration-Baidu_Car_Life OFF 30
IDE03471-ENG152559-Vehicle configuration-Baidu_Car_Life_ios OFF 30
IDE03471-ENG185765-Vehicle configuration-Baidu_Car_Life_ios_Wireless OFF 30
IDE03471-ENG185766-Vehicle configuration-Baidu_Car_Life_Wireless OFF 30
IDE03471-ENG152560-Vehicle configuration-block_hmi_function_p_epb blocked 30
IDE03471-ENG142151-Vehicle configuration-conditioning_variant 0 30
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call On 30
IDE03471-ENG142145-Vehicle configuration-esim_data_only_sms_support OFF 30
IDE03471-ENG185778-Vehicle configuration-FoD SWaP 30
IDE03471-ENG130248-Vehicle configuration-Google_GAL On 30
IDE03471-ENG185779-Vehicle configuration-Google_GAL_Wireless OFF 30
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts On 30
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other On 30
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts OFF 30
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other OFF 30
IDE03471-ENG152533-Vehicle configuration-Hybrid_Radio_additional_online_data not activated 30
IDE03471-ENG152534-Vehicle configuration-Hybrid_Radio_Range_Extender Deactivated 30
IDE03471-ENG125049-Vehicle configuration-Joker_button_1 Not Present 30
IDE03471-ENG125050-Vehicle configuration-Joker_button_2 Not Present 30
IDE03471-ENG127492-Vehicle configuration-LGI OFF 30
IDE03471-ENG130246-Vehicle configuration-LTE_modul Deactivated 30
IDE03471-ENG142142-Vehicle configuration-map_email_support OFF 30
IDE03471-ENG142143-Vehicle configuration-map_instant_messaging_support OFF 30
IDE03471-ENG142141-Vehicle configuration-map_sms_support OFF 30
IDE03471-ENG142152-Vehicle configuration-Map_Style 0 30
IDE03471-ENG152537-Vehicle configuration-media_control not activated 30
IDE03471-ENG138662-Vehicle configuration-Mirror_link OFF 30
IDE03471-ENG142148-Vehicle configuration-MirrorLink_Country_Code MIB_EU 30
IDE03471-ENG142150-Vehicle configuration-MirrorLink_RGB_Preference RGB565 30
IDE03471-ENG117843-Vehicle configuration-my_audi OFF 30
IDE03471-ENG117845-Vehicle configuration-online_dictation OFF 30
IDE03471-ENG127495-Vehicle configuration-online_media OFF 30
IDE03471-ENG117840-Vehicle configuration-online_navigation OFF 30
IDE03471-ENG117837-Vehicle configuration-online_POI OFF 30
IDE03471-ENG117838-Vehicle configuration-online_POI_voice OFF 30
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services OFF 30
IDE03471-ENG152553-Vehicle configuration-online_radio Deactivated 30
IDE03471-ENG117841-Vehicle configuration-online_street_view OFF 30
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit OFF 30
IDE03471-ENG167521-Vehicle configuration-perso_v_threshold 0 30
IDE03471-ENG167522-Vehicle configuration-perso_v_threshold_hysteresis 0 30
IDE03471-ENG152554-Vehicle configuration-Phone_HMI_Privacy 0 30
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode only data service act. 30
IDE03471-ENG117844-Vehicle configuration-picture_navi On 30
IDE03471-ENG167523-Vehicle configuration-Pilot_Parking not activated 30
IDE03471-ENG167525-Vehicle configuration-Popup_if_GPS_services_in_use not activated 30
IDE03471-ENG152555-Vehicle configuration-Privacy_WithPINRequest 0 30
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi OFF 30
IDE03471-ENG137646-Vehicle configuration-ProbeCar_vzo OFF 30
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version PSD_1.5 30
IDE03471-ENG117846-Vehicle configuration-remote_HMI OFF 30
IDE03471-ENG138661-Vehicle configuration-RSE_software_component activated 30
IDE03471-ENG245031-Vehicle configuration-rvc_low_black_screen_trunk_open not activated 30
IDE03471-ENG244966-Vehicle configuration-rvc_low_black_screen_velocity_threshold not activated 30
IDE03471-ENG245015-Vehicle configuration-rvc_low_failsafe not activated 30
IDE03471-ENG126143-Vehicle configuration-RVC_video_input FBAS 30
IDE03471-ENG152556-Vehicle configuration-scon_telephony not activated 30
IDE03471-ENG142081-Vehicle configuration-sd_slot_deactivation no restriction 30
IDE03471-ENG138660-Vehicle configuration-SDS_Region_Flag no_region 30
IDE03471-ENG152557-Vehicle configuration-show_volte_hmi_switch not activated 30
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch present 30
IDE03471-ENG142144-Vehicle configuration-sim_data_only_sms_support OFF 30
IDE03471-ENG138663-Vehicle configuration-Smartphone_interface_for_rhmi activated 30
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode 1 30
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold OFF 30
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling OFF 30
IDE03471-ENG130247-Vehicle configuration-Support_second_phone On 30
IDE03471-ENG167531-Vehicle configuration-Tencent_myCar_canceling_share_location OFF 30
IDE03471-ENG126994-Vehicle configuration-TPEG_availability OFF 30
IDE03471-ENG152571-Vehicle configuration-unblock_functions_while_piloted_driving blocked 30
IDE03471-ENG137647-Vehicle configuration-UOTA OFF 30
IDE03471-ENG167532-Vehicle configuration-UOTA_2 OFF 30
IDE03471-ENG117852-Vehicle configuration-UPnP On 30
IDE03471-ENG142149-Vehicle configuration-vehicle_leaving_sound not activated 30
IDE03471-ENG142147-Vehicle configuration-vehicle_readiness_sound not activated 30
IDE03471-ENG152558-Vehicle configuration-voice_over_lte not activated 30
IDE03471-ENG117836-Vehicle configuration-VZAPro OFF 30
IDE03471-ENG127494-Vehicle configuration-VZO OFF 30
IDE03471-ENG137648-Vehicle configuration-WiFi_Client_HMI OFF 30
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot On 30
IDE03471-ENG152572-Vehicle configuration-wlan_5ghz_switch not activated 30
IDE03580-Country code for mobile network 0 2
IDE03902-Automatic ring break diagnostic No automatic start 1
IDE04295-Bluetooth: Preferred connection profile for phone book data PBAP 1
IDE04298-MAS01779-Vehicle dimensions-Length 0 mm 6
IDE04298-MAS01780-Vehicle dimensions-Width 0 mm 6
IDE04298-MAS02230-Vehicle dimensions-Height 0 mm 6
IDE04331-Selection of release codes for a SWaP function FF FF FF FF 4
IDE04484-ENG117426-Regional codes-Parameter_Set_BlueRay_System_Region_Code 2 2
IDE04484-ENG117425-Regional codes-Parameter_Set_DVD_Region_Code 2 2
IDE04521-Sporadic ring break detection Visual 1
IDE04522-Awakening ability on optical databus OFF 1
IDE04549-Telephone data services On 1
IDE04550-Bluetooth: Sniff mode OFF 1
IDE05111-Fee-based traffic information (TMC) 32768 2
IDE05113-Infotainment Recorder activated 1
IDE06425-Roller test bench mode: functional not activated 1
IDE06697-Audio management mute function Muting of audio sources 1
IDE09382-ENG125051-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 2G 0 16
IDE09382-ENG125052-Parameter 2 for connection transfer (UMTS)-Scan Tune Level 3G 0 16
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner -128 40
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio 5 40
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM) -128 40
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM) -128 40
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB) -128 40
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB -128 40
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP -128 40
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay -128 40
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter -128 40
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN -128 40
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray -128 40
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice -128 40
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA -128 40
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud -128 40
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD -128 40
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI -128 40
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP -128 40
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP -128 40
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink -128 40
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP -128 40
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB -3 40
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice -128 40
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM -128 40
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep -128 40
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging -128 40
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen -128 40
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning -128 40
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav -128 40
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS -128 40
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online -128 40
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal -128 40
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI -128 40
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN -128 40
IDE10480-MAS10741-Interface for external media: activation-Connection 1 activated 4
IDE10480-MAS10742-Interface for external media: activation-Connection 2 not activated 4
IDE10480-MAS10743-Interface for external media: activation-Connection 3 not activated 4
IDE10480-MAS10744-Interface for external media: activation-Connection 4 not activated 4
IDE10604-Menu entries for mobile online services activated 1
IDE10668-Internal SIM card: use automatic 1
IDE11104-ENG127502-FM tuner: mono/stereo setting-l_hf_stereo_lower_threshold 37 dBµV 3
IDE11104-ENG127503-FM tuner: mono/stereo setting-l_nf_max_stereo_channel_separation 32 dB 3
IDE11104-ENG127504-FM tuner: mono/stereo setting-t_hysteresis_mono_to_stereo 15.0 s 3
IDE11105-Brand-specific display of connect application 256
IDE11122-Country identification: country of sale HMI DE 2
IDE11153-ENG152487-Surroundings display: virtual camera positions-focallength 4294967295 330
IDE11153-ENG152457-Surroundings display: virtual camera positions-Pitchangle 65535 330
IDE11153-ENG152445-Surroundings display: virtual camera positions-Rollangle 65535 330
IDE11153-ENG147432-Surroundings display: virtual camera positions-xpos 32767 330
IDE11153-ENG152451-Surroundings display: virtual camera positions-Yawangle 65535 330
IDE11153-ENG147433-Surroundings display: virtual camera positions-ypos 32767 330
IDE11153-ENG147434-Surroundings display: virtual camera positions-zpos 32767 330
IDE11502-ENG127601-Locked menu contents-FB_CAR_0 non_blocked 21
IDE11502-ENG127602-Locked menu contents-FB_CAR_1 non_blocked 21
IDE11502-ENG127611-Locked menu contents-FB_CAR_10 non_blocked 21
IDE11502-ENG127612-Locked menu contents-FB_CAR_11 non_blocked 21
IDE11502-ENG127613-Locked menu contents-FB_CAR_12 non_blocked 21
IDE11502-ENG127614-Locked menu contents-FB_CAR_13 non_blocked 21
IDE11502-ENG127615-Locked menu contents-FB_CAR_14 non_blocked 21
IDE11502-ENG127616-Locked menu contents-FB_CAR_15 non_blocked 21
IDE11502-ENG127617-Locked menu contents-FB_CAR_16 non_blocked 21
IDE11502-ENG127618-Locked menu contents-FB_CAR_17 non_blocked 21
IDE11502-ENG127619-Locked menu contents-FB_CAR_18 non_blocked 21
IDE11502-ENG127620-Locked menu contents-FB_CAR_19 non_blocked 21
IDE11502-ENG127603-Locked menu contents-FB_CAR_2 non_blocked 21
IDE11502-ENG127621-Locked menu contents-FB_CAR_20 non_blocked 21
IDE11502-ENG127622-Locked menu contents-FB_CAR_21 non_blocked 21
IDE11502-ENG127623-Locked menu contents-FB_CAR_22 non_blocked 21
IDE11502-ENG127624-Locked menu contents-FB_CAR_23 non_blocked 21
IDE11502-ENG127604-Locked menu contents-FB_CAR_3 non_blocked 21
IDE11502-ENG127605-Locked menu contents-FB_CAR_4 non_blocked 21
IDE11502-ENG127606-Locked menu contents-FB_CAR_5 non_blocked 21
IDE11502-ENG127607-Locked menu contents-FB_CAR_6 non_blocked 21
IDE11502-ENG127608-Locked menu contents-FB_CAR_7 non_blocked 21
IDE11502-ENG127609-Locked menu contents-FB_CAR_8 non_blocked 21
IDE11502-ENG127610-Locked menu contents-FB_CAR_9 non_blocked 21
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0 non_blocked 21
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1 non_blocked 21
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10 non_blocked 21
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11 non_blocked 21
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12 non_blocked 21
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13 non_blocked 21
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14 non_blocked 21
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15 non_blocked 21
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16 non_blocked 21
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17 non_blocked 21
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18 non_blocked 21
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19 non_blocked 21
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2 non_blocked 21
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20 non_blocked 21
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21 non_blocked 21
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22 non_blocked 21
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23 non_blocked 21
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3 non_blocked 21
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4 non_blocked 21
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5 non_blocked 21
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6 non_blocked 21
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7 non_blocked 21
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8 non_blocked 21
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9 non_blocked 21
IDE11502-ENG127625-Locked menu contents-FB_MISC_0 non_blocked 21
IDE11502-ENG127626-Locked menu contents-FB_MISC_1 non_blocked 21
IDE11502-ENG127635-Locked menu contents-FB_MISC_10 non_blocked 21
IDE11502-ENG127636-Locked menu contents-FB_MISC_11 non_blocked 21
IDE11502-ENG127637-Locked menu contents-FB_MISC_12 non_blocked 21
IDE11502-ENG127638-Locked menu contents-FB_MISC_13 non_blocked 21
IDE11502-ENG127639-Locked menu contents-FB_MISC_14 non_blocked 21
IDE11502-ENG127640-Locked menu contents-FB_MISC_15 non_blocked 21
IDE11502-ENG127641-Locked menu contents-FB_MISC_16 non_blocked 21
IDE11502-ENG127642-Locked menu contents-FB_MISC_17 non_blocked 21
IDE11502-ENG127643-Locked menu contents-FB_MISC_18 non_blocked 21
IDE11502-ENG127644-Locked menu contents-FB_MISC_19 non_blocked 21
IDE11502-ENG127627-Locked menu contents-FB_MISC_2 non_blocked 21
IDE11502-ENG127645-Locked menu contents-FB_MISC_20 non_blocked 21
IDE11502-ENG127646-Locked menu contents-FB_MISC_21 non_blocked 21
IDE11502-ENG127647-Locked menu contents-FB_MISC_22 non_blocked 21
IDE11502-ENG127648-Locked menu contents-FB_MISC_23 non_blocked 21
IDE11502-ENG127649-Locked menu contents-FB_MISC_24 non_blocked 21
IDE11502-ENG127650-Locked menu contents-FB_MISC_25 non_blocked 21
IDE11502-ENG127651-Locked menu contents-FB_MISC_26 non_blocked 21
IDE11502-ENG127652-Locked menu contents-FB_MISC_27 non_blocked 21
IDE11502-ENG127653-Locked menu contents-FB_MISC_28 non_blocked 21
IDE11502-ENG127654-Locked menu contents-FB_MISC_29 non_blocked 21
IDE11502-ENG127628-Locked menu contents-FB_MISC_3 non_blocked 21
IDE11502-ENG127655-Locked menu contents-FB_MISC_30 non_blocked 21
IDE11502-ENG127656-Locked menu contents-FB_MISC_31 non_blocked 21
IDE11502-ENG127657-Locked menu contents-FB_MISC_32 non_blocked 21
IDE11502-ENG127658-Locked menu contents-FB_MISC_33 non_blocked 21
IDE11502-ENG127659-Locked menu contents-FB_MISC_34 non_blocked 21
IDE11502-ENG127660-Locked menu contents-FB_MISC_35 non_blocked 21
IDE11502-ENG127661-Locked menu contents-FB_MISC_36 non_blocked 21
IDE11502-ENG127662-Locked menu contents-FB_MISC_37 non_blocked 21
IDE11502-ENG127663-Locked menu contents-FB_MISC_38 non_blocked 21
IDE11502-ENG127664-Locked menu contents-FB_MISC_39 non_blocked 21
IDE11502-ENG127629-Locked menu contents-FB_MISC_4 non_blocked 21
IDE11502-ENG127665-Locked menu contents-FB_MISC_40 non_blocked 21
IDE11502-ENG127666-Locked menu contents-FB_MISC_41 non_blocked 21
IDE11502-ENG127667-Locked menu contents-FB_MISC_42 non_blocked 21
IDE11502-ENG127668-Locked menu contents-FB_MISC_43 non_blocked 21
IDE11502-ENG127669-Locked menu contents-FB_MISC_44 non_blocked 21
IDE11502-ENG127670-Locked menu contents-FB_MISC_45 non_blocked 21
IDE11502-ENG127671-Locked menu contents-FB_MISC_46 non_blocked 21
IDE11502-ENG127672-Locked menu contents-FB_MISC_47 non_blocked 21
IDE11502-ENG127630-Locked menu contents-FB_MISC_5 non_blocked 21
IDE11502-ENG127631-Locked menu contents-FB_MISC_6 non_blocked 21
IDE11502-ENG127632-Locked menu contents-FB_MISC_7 non_blocked 21
IDE11502-ENG127633-Locked menu contents-FB_MISC_8 non_blocked 21
IDE11502-ENG127634-Locked menu contents-FB_MISC_9 non_blocked 21
IDE11502-ENG127561-Locked menu contents-FB_NAV_0 non_blocked 21
IDE11502-ENG127562-Locked menu contents-FB_NAV_1 non_blocked 21
IDE11502-ENG127571-Locked menu contents-FB_NAV_10 non_blocked 21
IDE11502-ENG127572-Locked menu contents-FB_NAV_11 non_blocked 21
IDE11502-ENG127573-Locked menu contents-FB_NAV_12 non_blocked 21
IDE11502-ENG127574-Locked menu contents-FB_NAV_13 non_blocked 21
IDE11502-ENG127575-Locked menu contents-FB_NAV_14 non_blocked 21
IDE11502-ENG127576-Locked menu contents-FB_NAV_15 non_blocked 21
IDE11502-ENG127577-Locked menu contents-FB_NAV_16 non_blocked 21
IDE11502-ENG127578-Locked menu contents-FB_NAV_17 non_blocked 21
IDE11502-ENG127579-Locked menu contents-FB_NAV_18 non_blocked 21
IDE11502-ENG127580-Locked menu contents-FB_NAV_19 non_blocked 21
IDE11502-ENG127563-Locked menu contents-FB_NAV_2 non_blocked 21
IDE11502-ENG127581-Locked menu contents-FB_NAV_20 non_blocked 21
IDE11502-ENG127582-Locked menu contents-FB_NAV_21 non_blocked 21
IDE11502-ENG127583-Locked menu contents-FB_NAV_22 non_blocked 21
IDE11502-ENG127584-Locked menu contents-FB_NAV_23 non_blocked 21
IDE11502-ENG127585-Locked menu contents-FB_NAV_24 non_blocked 21
IDE11502-ENG127586-Locked menu contents-FB_NAV_25 non_blocked 21
IDE11502-ENG127587-Locked menu contents-FB_NAV_26 non_blocked 21
IDE11502-ENG127588-Locked menu contents-FB_NAV_27 non_blocked 21
IDE11502-ENG127589-Locked menu contents-FB_NAV_28 non_blocked 21
IDE11502-ENG127590-Locked menu contents-FB_NAV_29 non_blocked 21
IDE11502-ENG127564-Locked menu contents-FB_NAV_3 non_blocked 21
IDE11502-ENG127591-Locked menu contents-FB_NAV_30 non_blocked 21
IDE11502-ENG127592-Locked menu contents-FB_NAV_31 non_blocked 21
IDE11502-ENG127593-Locked menu contents-FB_NAV_32 non_blocked 21
IDE11502-ENG127594-Locked menu contents-FB_NAV_33 non_blocked 21
IDE11502-ENG127595-Locked menu contents-FB_NAV_34 non_blocked 21
IDE11502-ENG127596-Locked menu contents-FB_NAV_35 non_blocked 21
IDE11502-ENG127597-Locked menu contents-FB_NAV_36 non_blocked 21
IDE11502-ENG127598-Locked menu contents-FB_NAV_37 non_blocked 21
IDE11502-ENG127599-Locked menu contents-FB_NAV_38 non_blocked 21
IDE11502-ENG127600-Locked menu contents-FB_NAV_39 non_blocked 21
IDE11502-ENG127565-Locked menu contents-FB_NAV_4 non_blocked 21
IDE11502-ENG127566-Locked menu contents-FB_NAV_5 non_blocked 21
IDE11502-ENG127567-Locked menu contents-FB_NAV_6 non_blocked 21
IDE11502-ENG127568-Locked menu contents-FB_NAV_7 non_blocked 21
IDE11502-ENG127569-Locked menu contents-FB_NAV_8 non_blocked 21
IDE11502-ENG127570-Locked menu contents-FB_NAV_9 non_blocked 21
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0 non_blocked 21
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1 non_blocked 21
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10 non_blocked 21
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11 non_blocked 21
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12 non_blocked 21
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13 non_blocked 21
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14 non_blocked 21
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15 non_blocked 21
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2 non_blocked 21
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3 non_blocked 21
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4 non_blocked 21
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5 non_blocked 21
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6 non_blocked 21
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7 non_blocked 21
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8 non_blocked 21
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9 non_blocked 21
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0 non_blocked 21
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1 non_blocked 21
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10 non_blocked 21
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11 non_blocked 21
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12 non_blocked 21
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13 non_blocked 21
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14 non_blocked 21
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15 non_blocked 21
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2 non_blocked 21
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3 non_blocked 21
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4 non_blocked 21
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5 non_blocked 21
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6 non_blocked 21
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7 non_blocked 21
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8 non_blocked 21
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9 non_blocked 21
IDE11638-Bluetooth Audio Codec FF 1
MAS00951-Bluetooth On 1
MAS02809-MAS02870-Check tone frequency-High note frequency range 4000 Hz 6
MAS02809-MAS02871-Check tone frequency-Medium note frequency range 1000 Hz 6
MAS02809-MAS02872-Check tone frequency-Low note frequency range 100 Hz 6
MAS03690-Telephone Data & language service active 1
MAS03782-WLAN On 1
ENG126140-ENG117811-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_On_Off OFF 12
ENG126140-ENG117813-Audio_Management_Audio_Delay_Lines_Gen2-Amplifier_Delay_Time 0.00 ms 12
ENG126140-ENG126188-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_On_Off OFF 12
ENG126140-ENG126189-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_Delay_Time 0.00 ms 12
ENG126140-ENG126190-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_On_Off OFF 12
ENG126140-ENG126191-Audio_Management_Audio_Delay_Lines_Gen2-Headphone_wireless_Delay_Time 0.00 ms 12
ENG126140-ENG117810-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_On_Off OFF 12
ENG126140-ENG117812-Audio_Management_Audio_Delay_Lines_Gen2-Main_Unit_Delay_Time 0.00 ms 12
ENG117920-Audio_Managment_Soundset_Menu OFF 1
ENG117917-BAP_Debug_Mode_Release not_released 1
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization not activated 60
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer not activated 60
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off not activated 60
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high not activated 60
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill not activated 60
ENG122227-ENG152538-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation not activated 60
ENG122227-ENG152539-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_after_disclaimer not activated 60
ENG122227-ENG152540-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_clamp_15_off not activated 60
ENG122227-ENG152541-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_over_threshold_high not activated 60
ENG122227-ENG152542-Car_Function_Adaptations_Gen2-menu_auxiliary_ventilation_standstill not activated 60
ENG122227-ENG152543-Car_Function_Adaptations_Gen2-menu_crossroad_assistent not activated 60
ENG122227-ENG152544-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_after_disclaimer not activated 60
ENG122227-ENG152545-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_clamp_15_off not activated 60
ENG122227-ENG152546-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_over_threshold_high not activated 60
ENG122227-ENG152547-Car_Function_Adaptations_Gen2-menu_crossroad_assistent_standstill not activated 60
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC activated 60
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer not activated 60
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off not activated 60
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high activated 60
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill not activated 60
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key not activated 60
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer not activated 60
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off not activated 60
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high not activated 60
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill not activated 60
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue not activated 60
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer not activated 60
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off not activated 60
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high not activated 60
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill not activated 60
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper not activated 60
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer not activated 60
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off not activated 60
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high not activated 60
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill not activated 60
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination activated 60
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer not activated 60
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off not activated 60
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high activated 60
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill not activated 60
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope not activated 60
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer not activated 60
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off not activated 60
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high not activated 60
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill not activated 60
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification not activated 60
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer not activated 60
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off not activated 60
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high not activated 60
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill not activated 60
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating activated 60
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer not activated 60
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off not activated 60
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high activated 60
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill not activated 60
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv activated 60
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer not activated 60
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off not activated 60
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high activated 60
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill not activated 60
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management not activated 60
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer not activated 60
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off not activated 60
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high not activated 60
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill not activated 60
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE activated 60
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer not activated 60
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off not activated 60
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high activated 60
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill not activated 60
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer activated 60
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer not activated 60
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off not activated 60
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high activated 60
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill not activated 60
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function activated 60
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer not activated 60
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off not activated 60
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high activated 60
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill not activated 60
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror activated 60
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer not activated 60
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off not activated 60
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high activated 60
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill not activated 60
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking activated 60
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer not activated 60
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off not activated 60
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high activated 60
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill not activated 60
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master activated 60
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer not activated 60
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off not activated 60
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high activated 60
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill not activated 60
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma activated 60
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer not activated 60
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off not activated 60
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high activated 60
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill not activated 60
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration activated 60
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer not activated 60
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off not activated 60
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high activated 60
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill not activated 60
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock activated 60
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer not activated 60
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off not activated 60
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high activated 60
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill not activated 60
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass not activated 60
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer not activated 60
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off not activated 60
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high not activated 60
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill not activated 60
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist not activated 60
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer not activated 60
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off not activated 60
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high not activated 60
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill not activated 60
ENG122227-ENG142087-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration not activated 60
ENG122227-ENG142091-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer not activated 60
ENG122227-ENG142088-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off not activated 60
ENG122227-ENG142089-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high not activated 60
ENG122227-ENG142090-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill not activated 60
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school not activated 60
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer not activated 60
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off not activated 60
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high not activated 60
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill not activated 60
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall not activated 60
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer not activated 60
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off not activated 60
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high not activated 60
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill not activated 60
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist not activated 60
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer not activated 60
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off not activated 60
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high not activated 60
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill not activated 60
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI not activated 60
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer not activated 60
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off not activated 60
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high not activated 60
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill not activated 60
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination activated 60
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer not activated 60
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off not activated 60
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high activated 60
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill not activated 60
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display not activated 60
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer not activated 60
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off not activated 60
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high not activated 60
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill not activated 60
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid not activated 60
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer not activated 60
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off not activated 60
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high not activated 60
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill not activated 60
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant activated 60
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer not activated 60
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off not activated 60
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high activated 60
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill not activated 60
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning activated 60
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer not activated 60
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off not activated 60
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high activated 60
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill not activated 60
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker not activated 60
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer not activated 60
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off not activated 60
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high not activated 60
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill not activated 60
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision not activated 60
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer not activated 60
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off not activated 60
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high not activated 60
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill not activated 60
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level not activated 60
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer not activated 60
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off not activated 60
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high not activated 60
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill not activated 60
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc activated 60
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer not activated 60
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off not activated 60
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high activated 60
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill not activated 60
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist activated 60
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer not activated 60
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off not activated 60
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high activated 60
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill not activated 60
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk activated 60
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer not activated 60
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off not activated 60
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high activated 60
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill not activated 60
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment not activated 60
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer not activated 60
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off not activated 60
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high not activated 60
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill not activated 60
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load activated 60
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer not activated 60
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off not activated 60
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high activated 60
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill not activated 60
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification activated 60
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer not activated 60
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off not activated 60
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high activated 60
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill not activated 60
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration not activated 60
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer not activated 60
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off not activated 60
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high not activated 60
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill not activated 60
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic not activated 60
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer not activated 60
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off not activated 60
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high not activated 60
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill not activated 60
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia activated 60
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer not activated 60
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off not activated 60
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high activated 60
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill not activated 60
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view not activated 60
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer not activated 60
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off not activated 60
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high not activated 60
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill not activated 60
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions not activated 60
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer not activated 60
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off not activated 60
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high not activated 60
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill not activated 60
ENG122227-ENG142082-Car_Function_Adaptations_Gen2-menu_display_Spoiler not activated 60
ENG122227-ENG142086-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer not activated 60
ENG122227-ENG142083-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off not activated 60
ENG122227-ENG142084-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high not activated 60
ENG122227-ENG142085-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill not activated 60
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI not activated 60
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer not activated 60
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off not activated 60
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high not activated 60
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill not activated 60
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons activated 60
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer not activated 60
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off not activated 60
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high activated 60
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill not activated 60
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant not activated 60
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer not activated 60
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off not activated 60
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high not activated 60
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill not activated 60
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner not activated 60
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer not activated 60
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off not activated 60
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high not activated 60
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill not activated 60
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo not activated 60
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer not activated 60
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off not activated 60
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high not activated 60
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill not activated 60
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating activated 60
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer not activated 60
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off not activated 60
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high activated 60
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill not activated 60
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin activated 60
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer not activated 60
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off not activated 60
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high activated 60
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill not activated 60
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition activated 60
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer not activated 60
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off not activated 60
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high activated 60
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill not activated 60
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows activated 60
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer not activated 60
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off not activated 60
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high activated 60
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill not activated 60
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper activated 60
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer not activated 60
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off not activated 60
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high activated 60
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill not activated 60
ENG122227-ENG142092-Car_Function_Adaptations_Gen2-menu_soundcontrol not activated 60
ENG122227-ENG142096-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer not activated 60
ENG122227-ENG142093-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off not activated 60
ENG122227-ENG142094-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high not activated 60
ENG122227-ENG142095-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill not activated 60
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05 activated 64
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus Databus extended 64
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06 not activated 64
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus Suspension data bus 64
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D not activated 64
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus not activated 64
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24 not activated 64
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus not activated 64
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03 activated 64
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus Comfort data bus 64
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B activated 64
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus Terminal 15 64
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25 not activated 64
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus Databus drivetrain 64
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23 activated 64
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus Databus Infotainment 64
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26 activated 64
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus Suspension data bus 64
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D activated 64
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus Comfort data bus 64
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17 activated 64
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus Databus Infotainment 64
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16 not activated 64
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus Comfort data bus 64
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01 activated 64
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus Comfort data bus 64
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02 activated 64
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus Comfort data bus 64
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11 activated 64
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus Comfort data bus 64
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15 not activated 64
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus not activated 64
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10 not activated 64
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus Comfort data bus 64
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33 not activated 64
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus Comfort data bus 64
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C Comfort data bus 64
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C not activated 64
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37 not activated 64
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus Comfort data bus 64
ENG122229-ENG152531-Car_Function_List_BAP_Gen2-ExBoxM2_0x38 not activated 64
ENG122229-ENG152532-Car_Function_List_BAP_Gen2-ExBoxM2_0x38_msg_bus Comfort data bus 64
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09 activated 64
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus Comfort data bus 64
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04 not activated 64
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus Comfort data bus 64
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D not activated 64
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus Databus drivetrain 64
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08 activated 64
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus Comfort data bus 64
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19 activated 64
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus Databus extended 64
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F activated 64
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus Comfort data bus 64
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34 not activated 64
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34 Databus Infotainment 64
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E activated 64
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus Comfort data bus 64
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18 not activated 64
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus not activated 64
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A activated 64
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus Terminal 15 64
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20 not activated 64
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus Comfort data bus 64
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A activated 64
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A Databus extended 64
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39 not activated 64
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39 Databus Infotainment 64
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E not activated 64
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus Comfort data bus 64
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F activated 64
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus Databus drivetrain 64
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B not activated 64
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B Comfort data bus 64
ENG122229-ENG139200-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F not activated 64
ENG122229-ENG139201-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F Comfort data bus 64
ENG122229-ENG139198-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E not activated 64
ENG122229-ENG139199-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E Comfort data bus 64
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12 activated 64
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus Comfort data bus 64
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E not activated 64
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus not activated 64
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35 not activated 64
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35 Comfort data bus 64
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27 activated 64
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus Databus Infotainment 64
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A activated 64
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus Databus extended 64
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07 activated 64
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus Databus extended 64
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21 activated 64
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus Databus extended 64
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36 not activated 64
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36 Comfort data bus 64
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C not activated 64
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus Comfort data bus 64
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14 not activated 64
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus Terminal 15 64
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13 activated 64
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus Comfort data bus 64
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B activated 64
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus Databus Infotainment 64
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22 activated 64
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus Databus Infotainment 64
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C activated 64
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus Comfort data bus 64
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key Not available 8
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus Comfort data bus 8
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school Not available 8
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus Databus Infotainment 8
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL Available 8
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus Databus Infotainment 8
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level Not available 8
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus Databus drivetrain 8
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering Available 8
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus Suspension data bus 8
ENG122228-ENG98891-Car_Function_List_CAN_Gen2-Reserved Not available 8
ENG122228-ENG101416-Car_Function_List_CAN_Gen2-Reserved_1 Comfort data bus 8
ENG122228-ENG99458-Car_Function_List_CAN_Gen2-Reserved_2 Comfort data bus 8
ENG122228-ENG99668-Car_Function_List_CAN_Gen2-Reserved_3 Not available 8
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN Available 8
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus Comfort data bus 8
ENG122230-ENG142097-Dashboard_Display_Configuration-ability_switch_nav_maps OFF 10
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture On 10
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart On 10
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode RLE 10
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution resolution_1 10
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode OFF 10
ENG122230-ENG142153-Dashboard_Display_Configuration-dynamic_icon 0 10
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most OFF 10
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode H264 10
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution resolution_1 10
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode MOST_streaming 10
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart OFF 10
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1 0 6
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2 50 6
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3 100 6
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1 0 6
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2 50 6
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3 100 6
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1 0 6
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2 50 6
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3 100 6
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1 0 6
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2 50 6
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3 100 6
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1 0 12
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2 10 12
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3 100 12
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4 150 12
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5 220 12
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6 253 12
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1 1% 12
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2 1% 12
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3 8% 12
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4 20% 12
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5 60% 12
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6 100% 12
ENG117911-ENG117768-FM_Delay_Adaption-Parameter_Adaption_FM_Delay 0 ms 3
ENG117911-ENG117769-FM_Delay_Adaption-Seamless_linking_automatic On 3
ENG107658-ENG126192-mobile phone voice control availability-apple_device not installed 1
ENG107658-ENG126193-mobile phone voice control availability-other_devices not installed 1
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation 04 01 52 04 52 10 52 40 52 32 00 64 00 5E 01 5E 01 96 00 FA 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 CE 40
ENG117809-p_damping_Display 5 ms 1
ENG117808-p_HMI_Display 13% 1
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset 0 2
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset 0 2
ENG117919-Startup_Screen_Sticker_HMI 00 02 2
ENG117905-ENG99753-Testmode_Video_speed_cutoff-PIN 0 3
ENG117905-ENG109008-Testmode_Video_speed_cutoff-speed_limit 0 km/h 3
Elapsed Time: 00:53
I haven't tried this on the Passat B8 but I disabled this option on the finance's Polo 6R. I was able to achieve it by changing the long coding on the central electrics unit which was named something along the lines of "Parking Lights ON Terminal 15" in VCDS. Perhaps worth investigating in VCDS?Hi, Passat B8 and i want my rear lights on all the time.
But don't know where to do that, no coding setting for that and adaption i found D16 and D17 which are. i guess, for rear lights but changing those values isn't the right place to do that?
Thanks for the hint, i will check that out. First i checked all the long coding options but can't remember was that there.I haven't tried this on the Passat B8 but I disabled this option on the finance's Polo 6R. I was able to achieve it by changing the long coding on the central electrics unit which was named something along the lines of "Parking Lights ON Terminal 15" in VCDS. Perhaps worth investigating in VCDS?
Your link doesn’t work. Can you please post how you got this working?Hey guys
In the meantime I managed to activate the Dynamic Light Assist! :-)
I published a free instruction on the internet:
https://www.vcdsschweiz.ch/en/activating-dynamic-light-assist-dla/
(this is for MY 2017 and higher, but there is also one for the older MY).
Thanks everybody who helped me by finding the solution... :-)
Regards
No such thing found, anybody knows where to apply that function?Thanks for the hint, i will check that out. First i checked all the long coding options but can't remember was that there.
Thanks a lot, i will try that!Activate this channel in Unit 09:
IDE06864-ENG116593-Tagfahrlicht-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht
It is the easiest way. DRL activates rear lights, plate lights and instrument lights...
If you do not want this but only the rear lights, report back.
I'd look at the IDE08786 channels. This one in particular may be what you are looking for:Hy guys,
I want to ask you if anybody of you know how to set LIGHT SENSOR SENSITIVITY with VCDS to stop starting the DIPPER HEADLIGHT BEAM in the middle of the day .
Thanks .
