2017 NAR Golf Alltrack SEL with Driver assist maps
   #21
5F-Information Electr.
blockmap-5F-3Q0-035-876-A.CSV
;SW:3Q0-035-876-A   HW:3Q0-035-876-A ---  Information Electr.
;Component:MU-S-NS-US    840 0751	 Coding:027302020000000051220002001808009F0108F401200105C6
;EV_MUStd4CDELP	1001	EV_MUStd4CDELP_VW26.rod
;Wednesday	11	January	2017	20:17:18:08929
;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
;VCID: B227196DE50D00D193-80E6
Group	Description	Actual
IDE00019	Voltage terminal 30	12.9	 V
IDE00020	Terminal 15 status	On
IDE00021	Engine speed	0	 /min
IDE00075	Vehicle speed	0	 km/h
IDE00323	Security Access: Number of invalid keys	0
IDE00668-MAS03231	Microphone current consumption-Microphone 1	5.9	 mA
IDE00668-MAS03232	Microphone current consumption-Microphone 2	25.5	 mA
IDE00767	No. of unscheduled ECU resets	0	 counts
IDE00916-IDE02127	Speaker status-Left front speaker	Measured value not available
IDE00916-IDE02128	Speaker status-Right front speaker	Measured value not available
IDE00916-IDE02129	Speaker status-Left rear speaker	Measured value not available
IDE00916-IDE02130	Speaker status-Right rear speaker	Measured value not available
IDE00916-ENG117413	Speaker status-loudspeaker_channel_10	Measured value not available
IDE00916-ENG117414	Speaker status-loudspeaker_channel_11	Measured value not available
IDE00916-ENG117415	Speaker status-loudspeaker_channel_12	Measured value not available
IDE00916-ENG117416	Speaker status-loudspeaker_channel_13	Measured value not available
IDE00916-ENG117417	Speaker status-loudspeaker_channel_14	Measured value not available
IDE00916-ENG117418	Speaker status-loudspeaker_channel_15	Measured value not available
IDE00916-ENG117419	Speaker status-loudspeaker_channel_16	Measured value not available
IDE00916-ENG117408	Speaker status-loudspeaker_channel_5	Measured value not available
IDE00916-ENG117409	Speaker status-loudspeaker_channel_6	Measured value not available
IDE00916-ENG117410	Speaker status-loudspeaker_channel_7	Measured value not available
IDE00916-ENG117411	Speaker status-loudspeaker_channel_8	Measured value not available
IDE00916-ENG117412	Speaker status-loudspeaker_channel_9	Measured value not available
IDE01285-ENG101364	Counter of component protection malfunctions-Theft Protection Error Counter	00 00
IDE01351	Terminal 75 status	OFF
IDE01442-MAS06123	Pressing a button-Eject button	not activated
IDE01698-MAS07206	Status audio signal outputs-Audio signal output channel 1	Measured value not available
IDE01698-MAS07207	Status audio signal outputs-Audio signal output channel 2	Measured value not available
IDE01698-MAS07208	Status audio signal outputs-Audio signal output channel 3	Measured value not available
IDE01698-MAS07209	Status audio signal outputs-Audio signal output channel 4	Measured value not available
IDE01712-MAS01779	GPS Position-Length	079°37'22.91"W
IDE01712-MAS01780	GPS Position-Width	040°31'58.95"N
IDE01713-MAS01632	Status GPS reception-Status	GPS data is being received: position completely determined
IDE01713-MAS01785	Status GPS reception-Number of visible satellites	14
IDE01713-MAS01786	Status GPS reception-Number of tracked satellites	10
IDE01715	Status terminal S	On
IDE01716	Terminal 50 status	OFF
IDE01767-MAS00940	Status of telephone-Antenna diagnostic	Not available
IDE01767-MAS00941	Status of telephone-Telephone baseplate diagnostic	not connected
IDE01767-MAS00955	Status of telephone-Handset in handset holder (cradle)	not selected
IDE01767-MAS01806	Status of telephone-Handset holder (cradle)	not connected
IDE01768-MAS01808	Status of antenna 1 for radio-Antenna current	61	 mA
IDE01768-MAS03938	Status of antenna 1 for radio-Connection between radio and antenna amplifier	Electrical OK
IDE01768-MAS03939	Status of antenna 1 for radio-Connection between antenna amplifier and antenna	Electrical OK
IDE01768-MAS03991	Status of antenna 1 for radio-Reception level antenna 1	9	 dBµV
IDE01769-MAS01808	Status of antenna 2 for radio-Antenna current	51	 mA
IDE01769-MAS03938	Status of antenna 2 for radio-Connection between radio and antenna amplifier	Electrical OK
IDE01769-MAS03939	Status of antenna 2 for radio-Connection between antenna amplifier and antenna	Electrical OK
IDE01769-MAS04344	Status of antenna 2 for radio-Reception level antenna 2	14	 dBµV
IDE01770-MAS01632	Status of GPS antenna-Status	Electrical OK
IDE01770-MAS01808	Status of GPS antenna-Antenna current	24	 mA
IDE01868-MAS00839	Ring break diagnostic result-TV Tuner	Not available
IDE01868-MAS00840	Ring break diagnostic result-Media Player: Position 1	Not available
IDE01868-MAS00844	Ring break diagnostic result-Radio	Not available
IDE01868-MAS00847	Ring break diagnostic result-Digital Sound System Control Module	Not available
IDE01868-MAS00849	Ring break diagnostic result-Information electronics control module 1	System OK
IDE01868-MAS00850	Ring break diagnostic result-Information electronics control module 2	Not available
IDE01868-MAS02840	Ring break diagnostic result-Instrument cluster display	Not available
IDE01868-ENG117473	Ring break diagnostic result-MOST_Component_10	Not available
IDE01868-ENG117474	Ring break diagnostic result-MOST_Component_11	Not available
IDE01868-ENG117475	Ring break diagnostic result-MOST_Component_12	Not available
IDE01868-ENG117476	Ring break diagnostic result-MOST_Component_13	Not available
IDE01868-ENG117477	Ring break diagnostic result-MOST_Component_14	Not available
IDE01868-ENG117478	Ring break diagnostic result-MOST_Component_15	Not available
IDE01868-ENG117479	Ring break diagnostic result-MOST_Component_16	Not available
IDE01868-ENG117480	Ring break diagnostic result-MOST_Component_17	Not available
IDE01868-ENG117481	Ring break diagnostic result-MOST_Component_18	Not available
IDE01868-ENG117482	Ring break diagnostic result-MOST_Component_19	Not available
IDE01868-ENG117483	Ring break diagnostic result-MOST_Component_20	Not available
IDE01868-ENG117471	Ring break diagnostic result-MOST_Component_8	Not available
IDE01868-ENG117472	Ring break diagnostic result-MOST_Component_9	Not available
IDE01992-ENG117819	Installation list: current installations-ECUs present_1	installed
IDE01992-ENG117820	Installation list: current installations-ECUs present_2	not installed
IDE01992-ENG117821	Installation list: current installations-ECUs present_3	not installed
IDE01995-ENG103538	Control module protocol information-ECUs DiagProt	Yes
IDE02070-IDE02060	Wake-up cause-Eject optical medium\ (CD/DVD Eject)	No
IDE02070-IDE04544	Wake-up cause-Media type in optical drive	No
IDE02070-MAS03177	Wake-up cause-Databus Infotainment	Yes
IDE02070-MAS03180	Wake-up cause-Local data bus	No
IDE02070-MAS03690	Wake-up cause-Telephone	No
IDE02070-MAS03782	Wake-up cause-WLAN	No
IDE02070-MAS03833	Wake-up cause-Optical data bus	No
IDE02326-ENG117459	GPS signal strength-ID_GPS_satellite_no_1	9
IDE02326-ENG117461	GPS signal strength-ID_GPS_satellite_no_2	23
IDE02326-ENG117463	GPS signal strength-ID_GPS_satellite_no_3	27
IDE02326-ENG117465	GPS signal strength-ID_GPS_satellite_no_4	16
IDE02326-ENG117460	GPS signal strength-S/N_GPS_satellite_no_1	50	 dBµV
IDE02326-ENG117462	GPS signal strength-S/N_GPS_satellite_no_2	50	 dBµV
IDE02326-ENG117464	GPS signal strength-S/N_GPS_satellite_no_3	49	 dBµV
IDE02326-ENG117466	GPS signal strength-S/N_GPS_satellite_no_4	48	 dBµV
IDE02384-ENG117816	Status of event memory-ECU Dtcs_1	OK
IDE02384-ENG117817	Status of event memory-ECU Dtcs_2	OK
IDE02384-ENG117818	Status of event memory-ECU Dtcs_3	OK
IDE02486	Data logger triggering	not active
IDE02508-MAS00951	Bluetooth: Visibility-Bluetooth	On
IDE02508-MAS03001	Bluetooth: Visibility-Mode	Bluetooth available
IDE02766	Malfunction status	FF FB
IDE03150-ENG117823	Readiness for bus sleep mode-Sleep_1	End busstat
IDE03150-ENG117824	Readiness for bus sleep mode-Sleep_2	Unknown
IDE03150-ENG117825	Readiness for bus sleep mode-Sleep_3	Unknown
IDE03151-ENG117815	TP CAN identifier-ECUs TP-CAN-Identifier	1907
IDE03477-MAS01632	GPS time-Status	valid
IDE03477-ENG117467	GPS time-gps_date_time	2017
IDE03610-MAS02573	Voice operation: last detected command-Reception quality	255	 %
IDE03610-MAS03874	Voice operation: last detected command-last detected command	16776960
IDE03610-MAS03875	Voice operation: last detected command-Reliability	255	 %
IDE03880-MAS03119	MOST address-Functional block: diagnostic instance	5F
IDE03880-MAS03425	MOST address-Physical address	04 00
IDE04312-MAS00109	System run time-Hours	0	 H
IDE04312-MAS00110	System run time-Minutes	36	 min
IDE04317-MAS00108	Total system run time-Day	0	 d
IDE04317-MAS00109	Total system run time-Hours	15	 H
IDE04317-MAS00110	Total system run time-Minutes	53	 min
IDE04329	Status of all SWaP functions	00 03 00 00
IDE04329	Status of all SWaP functions	Available
IDE04329	Status of all SWaP functions	No
IDE04329	Status of all SWaP functions	valid
IDE04329	Status of all SWaP functions	Condition met
IDE04329	Status of all SWaP functions	OK
IDE04332	Release code for a SWaP function	Not available
IDE04334-MAS02643	Public key for SWaP function-Key	C2 93 92 9A 21 E4 DC EB 18 D7 5C 0E 67 EF 75 08 4A CA 81 A8 8A A1 CD 26 08 6F 9F 96 D8 F8 FA 57 23 75 F8 CC AC 03 B4 32 29 83 5E E1 8C CD 2B D4 35 44 5F C3 B1 B5 E4 E7 66 80 2B 94 D4 EA 91 A0 D0 58 AD 49 5A 16 DA 8D 0F 9C 65 A1 83 35 8B 85 CC 77 97 7A DE 07 49 4C A7 F9 AB 60 20 54 F1 F2 8B 52 39 6F 6C 41 24 BF 24 89 4D E5 3F AA 8B 5B 5C 19 D2 F4 80 50 F8 3C 6B 82 87 B2 35 B9 4D 43 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03
IDE04343-ENG117822	Bus identification-BusIdentifier	Busmaster
IDE04344-ENG103664	Control module assignment-ECU IDs	Information Control Unit 1
IDE04541-MAS03621	Status of active media source at output 1-Video codec	--------------------
IDE04541-MAS03622	Status of active media source at output 1-Horizontal video resolution	65535
IDE04541-MAS03623	Status of active media source at output 1-Vertical video resolution	65535
IDE04541-MAS03778	Status of active media source at output 1-Active media source	Not available
IDE04541-MAS03783	Status of active media source at output 1-Video Bitrate	65535	 kbps
IDE04541-MAS03784	Status of active media source at output 1-Audio Bitrate	Not available
IDE04541-MAS03785	Status of active media source at output 1-Digital rights management (DRM)	Not available
IDE04541-MAS03786	Status of active media source at output 1-Audio Codec	--------------------
IDE04541-MAS03787	Status of active media source at output 1-Image format	--------------------
IDE04541-MAS03788	Status of active media source at output 1-Horizontal image resolution	65535
IDE04541-MAS03789	Status of active media source at output 1-Vertical image resolution	65535
IDE04541-MAS03793	Status of active media source at output 1-Color depth	65535	 bit
IDE04544	Media type in optical drive	Not available
IDE04545-IDE01588	Vehicle state-Driving direction	Measured value not available
IDE04545-IDE01714	Vehicle state-Status reverse gear	not selected
IDE04545-IDE01766	Vehicle state-Distance impulses	0
IDE04545-IDE03684	Vehicle state-Vehicle stopped	Yes
IDE04546-IDE00301	Navigation calibration-Distance	0.46	 mm
IDE04546-MAS03647	Navigation calibration-Calibration condition	Position finding possible even without GPS
IDE04547	Traffic information	OFF
IDE04605-MAS01779	Navigation: Corrected position-Length	079°37'22.42"W
IDE04605-MAS01780	Navigation: Corrected position-Width	040°31'58.15"N
IDE04607-IDE03661	Angle of turn sensor for navigation-Rotation rate	3.6	 °/s
IDE04607-ENG117452	Angle of turn sensor for navigation-gyro_sensor_x_acceleration	20.08	 m/s²
IDE04607-ENG117453	Angle of turn sensor for navigation-gyro_sensor_y_acceleration	20.08	 m/s²
IDE04607-ENG117454	Angle of turn sensor for navigation-gyro_sensor_z_acceleration	20.08	 m/s²
IDE04639-IDE02060	Last wake-up cause-Eject optical medium\ (CD/DVD Eject)	No
IDE04639-IDE04544	Last wake-up cause-Media type in optical drive	No
IDE04639-MAS03177	Last wake-up cause-Databus Infotainment	Yes
IDE04639-MAS03180	Last wake-up cause-Local data bus	No
IDE04639-MAS03690	Last wake-up cause-Telephone	No
IDE04639-MAS03782	Last wake-up cause-WLAN	No
IDE04639-MAS03833	Last wake-up cause-Optical data bus	No
IDE04640	Over-temperature protection for amplifier	no restriction
IDE04641	Speed-dependent volume adjustment	0	 dB
IDE04649-MAS01968	Activation for housing fan-Fan	Stage 3
IDE04649-MAS06857	Activation for housing fan-Speed	6000	 /min
IDE04748	Microphone override meter	0
IDE04749-ENG117444	Mute-am_fm_tuner	No
IDE04749-ENG117443	Mute-audiomanager	No
IDE04749-ENG117447	Mute-component_protection	No
IDE04749-ENG117445	Mute-dab_sdars_tuner	No
IDE04749-ENG117446	Mute-drm_hd_tuner	No
IDE04749-ENG113342	Mute-Hardware	No
IDE04767-MAS01240	Update software via medium-Programming status	not active
IDE04767-MAS02111	Update software via medium-Data consistency	valid
IDE04767-MAS02112	Update software via medium-Programmability	no request
IDE04768	Bluetooth device address	28 A1 83 DD 3E B9
IDE05040-MAS01632	Video input status-Status	Not available
IDE05040-MAS04390	Video input status-Active source	Not available
IDE05536-MAS01632	GPS almanac-Status	valid
IDE05595-MAS00106	Last time GPS without satellite reception-Year	2017
IDE05595-MAS00107	Last time GPS without satellite reception-Month	1
IDE05595-MAS00108	Last time GPS without satellite reception-Day	11
IDE05595-MAS00109	Last time GPS without satellite reception-Hours	23
IDE05595-MAS00110	Last time GPS without satellite reception-Minutes	53
IDE05595-MAS00111	Last time GPS without satellite reception-Seconds	44
IDE05596-MAS00106	Last time GPS position outside map-Year	2000
IDE05596-MAS00107	Last time GPS position outside map-Month	0
IDE05596-MAS00108	Last time GPS position outside map-Day	0
IDE05596-MAS00109	Last time GPS position outside map-Hours	0
IDE05596-MAS00110	Last time GPS position outside map-Minutes	0
IDE05596-MAS00111	Last time GPS position outside map-Seconds	0
IDE05597-IDE03615	Bluetooth: Paired device 1-Version	a
IDE05597-IDE04768	Bluetooth: Paired device 1-Bluetooth device address	90 E7 C4 46 C4 6A
IDE05597-MAS01483	Bluetooth: Paired device 1-Software version	z
IDE05597-MAS02159	Bluetooth: Paired device 1-Remote SIM Access Profile (rSAP)	48 54
IDE05597-MAS02160	Bluetooth: Paired device 1-Hands free profile (HFP)	65 03
IDE05597-MAS03159	Bluetooth: Paired device 1-Manufacturer	R
IDE05597-MAS04326	Bluetooth: Paired device 1-Device name
IDE05597-ENG117431	Bluetooth: Paired device 1-A2DP	43 0A
IDE05597-ENG117440	Bluetooth: Paired device 1-ACTIVESYNCML	FF 01
IDE05597-ENG105233	Bluetooth: Paired device 1-AT	02 01
IDE05597-ENG117432	Bluetooth: Paired device 1-AVRCP	48 54
IDE05597-ENG117434	Bluetooth: Paired device 1-DUN	4F 6E
IDE05597-ENG106692	Bluetooth: Paired device 1-FTP	FF 01
IDE05597-ENG117435	Bluetooth: Paired device 1-HIDP	65 20
IDE05597-ENG117429	Bluetooth: Paired device 1-HSP	61 64
IDE05597-ENG117437	Bluetooth: Paired device 1-IRMC	2D FF
IDE05597-ENG101499	Bluetooth: Paired device 1-map	4D 39
IDE05597-ENG117436	Bluetooth: Paired device 1-OBEX	02 2D
IDE05597-ENG117439	Bluetooth: Paired device 1-OPP	FF FF
IDE05597-ENG117433	Bluetooth: Paired device 1-PAN	43 20
IDE05597-ENG108174	Bluetooth: Paired device 1-PBAP	06 FF
IDE05597-ENG117427	Bluetooth: Paired device 1-SDAP	6F 72
IDE05597-ENG117428	Bluetooth: Paired device 1-SPP	62 6C
IDE05597-ENG117438	Bluetooth: Paired device 1-SYNCML	FF FF
IDE05598-IDE03615	Bluetooth: Paired device 2-Version	-
IDE05598-IDE04768	Bluetooth: Paired device 2-Bluetooth device address	00 00 00 00 00 00
IDE05598-MAS01483	Bluetooth: Paired device 2-Software version
IDE05598-MAS02159	Bluetooth: Paired device 2-Remote SIM Access Profile (rSAP)	FF FF
IDE05598-MAS02160	Bluetooth: Paired device 2-Hands free profile (HFP)	2D 2D
IDE05598-MAS03159	Bluetooth: Paired device 2-Manufacturer	-
IDE05598-MAS04326	Bluetooth: Paired device 2-Device name
IDE05598-ENG117431	Bluetooth: Paired device 2-A2DP	FF FF
IDE05598-ENG117440	Bluetooth: Paired device 2-ACTIVESYNCML	FF FF
IDE05598-ENG105233	Bluetooth: Paired device 2-AT	FF FF
IDE05598-ENG117432	Bluetooth: Paired device 2-AVRCP	FF FF
IDE05598-ENG117434	Bluetooth: Paired device 2-DUN	FF FF
IDE05598-ENG106692	Bluetooth: Paired device 2-FTP	FF FF
IDE05598-ENG117435	Bluetooth: Paired device 2-HIDP	FF FF
IDE05598-ENG117429	Bluetooth: Paired device 2-HSP	2D 02
IDE05598-ENG117437	Bluetooth: Paired device 2-IRMC	FF FF
IDE05598-ENG101499	Bluetooth: Paired device 2-map	FF FF
IDE05598-ENG117436	Bluetooth: Paired device 2-OBEX	FF FF
IDE05598-ENG117439	Bluetooth: Paired device 2-OPP	FF FF
IDE05598-ENG117433	Bluetooth: Paired device 2-PAN	FF FF
IDE05598-ENG108174	Bluetooth: Paired device 2-PBAP	FF FF
IDE05598-ENG117427	Bluetooth: Paired device 2-SDAP	2D 2D
IDE05598-ENG117428	Bluetooth: Paired device 2-SPP	02 2D
IDE05598-ENG117438	Bluetooth: Paired device 2-SYNCML	FF FF
IDE05599-IDE03615	Bluetooth: Paired device 3-Version	-
IDE05599-IDE04768	Bluetooth: Paired device 3-Bluetooth device address	00 00 00 00 00 00
IDE05599-MAS01483	Bluetooth: Paired device 3-Software version
IDE05599-MAS02159	Bluetooth: Paired device 3-Remote SIM Access Profile (rSAP)	FF FF
IDE05599-MAS02160	Bluetooth: Paired device 3-Hands free profile (HFP)	2D 2D
IDE05599-MAS03159	Bluetooth: Paired device 3-Manufacturer	-
IDE05599-MAS04326	Bluetooth: Paired device 3-Device name
IDE05599-ENG117431	Bluetooth: Paired device 3-A2DP	FF FF
IDE05599-ENG117440	Bluetooth: Paired device 3-ACTIVESYNCML	FF FF
IDE05599-ENG105233	Bluetooth: Paired device 3-AT	FF FF
IDE05599-ENG117432	Bluetooth: Paired device 3-AVRCP	FF FF
IDE05599-ENG117434	Bluetooth: Paired device 3-DUN	FF FF
IDE05599-ENG106692	Bluetooth: Paired device 3-FTP	FF FF
IDE05599-ENG117435	Bluetooth: Paired device 3-HIDP	FF FF
IDE05599-ENG117429	Bluetooth: Paired device 3-HSP	2D 02
IDE05599-ENG117437	Bluetooth: Paired device 3-IRMC	FF FF
IDE05599-ENG101499	Bluetooth: Paired device 3-map	FF FF
IDE05599-ENG117436	Bluetooth: Paired device 3-OBEX	FF FF
IDE05599-ENG117439	Bluetooth: Paired device 3-OPP	FF FF
IDE05599-ENG117433	Bluetooth: Paired device 3-PAN	FF FF
IDE05599-ENG108174	Bluetooth: Paired device 3-PBAP	FF FF
IDE05599-ENG117427	Bluetooth: Paired device 3-SDAP	2D 2D
IDE05599-ENG117428	Bluetooth: Paired device 3-SPP	02 2D
IDE05599-ENG117438	Bluetooth: Paired device 3-SYNCML	FF FF
IDE05600-IDE03615	Bluetooth: Paired device 4-Version	-
IDE05600-IDE04768	Bluetooth: Paired device 4-Bluetooth device address	00 00 00 00 00 00
IDE05600-MAS01483	Bluetooth: Paired device 4-Software version
IDE05600-MAS02159	Bluetooth: Paired device 4-Remote SIM Access Profile (rSAP)	FF FF
IDE05600-MAS02160	Bluetooth: Paired device 4-Hands free profile (HFP)	2D 2D
IDE05600-MAS03159	Bluetooth: Paired device 4-Manufacturer	-
IDE05600-MAS04326	Bluetooth: Paired device 4-Device name
IDE05600-ENG117431	Bluetooth: Paired device 4-A2DP	FF FF
IDE05600-ENG117440	Bluetooth: Paired device 4-ACTIVESYNCML	FF FF
IDE05600-ENG105233	Bluetooth: Paired device 4-AT	FF FF
IDE05600-ENG117432	Bluetooth: Paired device 4-AVRCP	FF FF
IDE05600-ENG117434	Bluetooth: Paired device 4-DUN	FF FF
IDE05600-ENG106692	Bluetooth: Paired device 4-FTP	FF FF
IDE05600-ENG117435	Bluetooth: Paired device 4-HIDP	FF FF
IDE05600-ENG117429	Bluetooth: Paired device 4-HSP	2D 02
IDE05600-ENG117437	Bluetooth: Paired device 4-IRMC	FF FF
IDE05600-ENG101499	Bluetooth: Paired device 4-map	FF FF
IDE05600-ENG117436	Bluetooth: Paired device 4-OBEX	FF FF
IDE05600-ENG117439	Bluetooth: Paired device 4-OPP	FF FF
IDE05600-ENG117433	Bluetooth: Paired device 4-PAN	FF FF
IDE05600-ENG108174	Bluetooth: Paired device 4-PBAP	FF FF
IDE05600-ENG117427	Bluetooth: Paired device 4-SDAP	2D 2D
IDE05600-ENG117428	Bluetooth: Paired device 4-SPP	02 2D
IDE05600-ENG117438	Bluetooth: Paired device 4-SYNCML	FF FF
IDE05601-IDE03615	Bluetooth: Paired device 5-Version	-
IDE05601-IDE04768	Bluetooth: Paired device 5-Bluetooth device address	00 00 00 00 00 00
IDE05601-MAS01483	Bluetooth: Paired device 5-Software version
IDE05601-MAS02159	Bluetooth: Paired device 5-Remote SIM Access Profile (rSAP)	FF FF
IDE05601-MAS02160	Bluetooth: Paired device 5-Hands free profile (HFP)	2D 2D
IDE05601-MAS03159	Bluetooth: Paired device 5-Manufacturer	-
IDE05601-MAS04326	Bluetooth: Paired device 5-Device name
IDE05601-ENG117431	Bluetooth: Paired device 5-A2DP	FF FF
IDE05601-ENG117440	Bluetooth: Paired device 5-ACTIVESYNCML	FF FF
IDE05601-ENG105233	Bluetooth: Paired device 5-AT	FF FF
IDE05601-ENG117432	Bluetooth: Paired device 5-AVRCP	FF FF
IDE05601-ENG117434	Bluetooth: Paired device 5-DUN	FF FF
IDE05601-ENG106692	Bluetooth: Paired device 5-FTP	FF FF
IDE05601-ENG117435	Bluetooth: Paired device 5-HIDP	FF FF
IDE05601-ENG117429	Bluetooth: Paired device 5-HSP	2D 02
IDE05601-ENG117437	Bluetooth: Paired device 5-IRMC	FF FF
IDE05601-ENG101499	Bluetooth: Paired device 5-map	FF FF
IDE05601-ENG117436	Bluetooth: Paired device 5-OBEX	FF FF
IDE05601-ENG117439	Bluetooth: Paired device 5-OPP	FF FF
IDE05601-ENG117433	Bluetooth: Paired device 5-PAN	FF FF
IDE05601-ENG108174	Bluetooth: Paired device 5-PBAP	FF FF
IDE05601-ENG117427	Bluetooth: Paired device 5-SDAP	2D 2D
IDE05601-ENG117428	Bluetooth: Paired device 5-SPP	02 2D
IDE05601-ENG117438	Bluetooth: Paired device 5-SYNCML	FF FF
IDE05602-MAS01763	Bluetooth: connected device 1-Signal Strength	Not available
IDE05602-MAS04326	Bluetooth: connected device 1-Device name	65280
IDE05603-MAS01763	Bluetooth: connected device 2-Signal Strength	Not available
IDE05603-MAS04326	Bluetooth: connected device 2-Device name	65280
IDE05604-MAS01763	Bluetooth: connected device 3-Signal Strength	Not available
IDE05604-MAS04326	Bluetooth: connected device 3-Device name	65280
IDE05605-MAS01763	Bluetooth: connected device 4-Signal Strength	Not available
IDE05605-MAS04326	Bluetooth: connected device 4-Device name	65280
IDE05606-MAS01763	Bluetooth: connected device 5-Signal Strength	Not available
IDE05606-MAS04326	Bluetooth: connected device 5-Device name	65280
IDE05700-MAS01456	USB connection-Speed	Not available
IDE05700-MAS01632	USB connection-Status	OK
IDE05700-MAS03159	USB connection-Manufacturer	FF FF
IDE05700-MAS04393	USB connection-USB device class	FF
IDE05700-MAS04394	USB connection-Connection status	not connected
IDE05700-MAS04436	USB connection-USB device sub-class	FF
IDE05700-ENG111957	USB connection-usb_product_id	FF FF
IDE05700-ENG111955	USB connection-usb_protocol	FF
IDE05713-MAS01632	Network diagnosis-Status	Enabled
IDE05725	Terminal 58xs dimmer	0	 %
IDE05726	Terminal 58xd dimmer	39.5	 %
IDE05814	Individualization characteristic	CA 33 28 6A 07
IDE06028-MAS02317	Control head button operation-Button code 1	FF
IDE06028-MAS02318	Control head button operation-Button code 2	FF
IDE06028-MAS04151	Control head button operation-Joystick	0
IDE06028-MAS04413	Control head button operation-Push-and rotary knob for selection	0
IDE06028-MAS04414	Control head button operation-Volume control	0
IDE06425	Roller test bench mode: functional	not activated
IDE07589-IDE07590	Update programming: status-Currently processed module	0
IDE07589-IDE07591	Update programming: status-Number of modules to be programmed	0
IDE07589-MAS01632	Update programming: status-Status	not active
IDE07589-MAS10948	Update programming: status-control	Diagnosis
IDE07938	Cause of system start	Data bus
IDE07939	Last cause of system start	Data bus
IDE09563-MAS09154	Proximity detection for touchscreen 1-Proximity sensor 1	No object in sector
IDE10478-MAS01632	Interface for external media: status-Status	OK
IDE10479-MAS01482	Interface for external media: identification-Hardware version	---
IDE10479-MAS01483	Interface for external media: identification-Software version	----
IDE10479-MAS04970	Interface for external media: identification-Part Number	-----------
MAS00464	Standard - ambient data 1	5
MAS00464	Standard - ambient data 1	2
MAS00464	Standard - ambient data 1	9
MAS00481-ENG117777	BAP-BAP_Function_ID	FF
MAS00778-IDE03619	Multimedia display unit 1-System status	On
MAS00778-IDE05228	Multimedia display unit 1-Operating hour counter	10	 H
MAS00778-MAS00362	Multimedia display unit 1-Battery voltage	12.9	 V
MAS00778-MAS02200	Multimedia display unit 1-Highest measured temperature	47	 °C
MAS00778-MAS02201	Multimedia display unit 1-Temperature	29	 °C
MAS00778-MAS03691	Multimedia display unit 1-Dimming	8	 %
MAS00951-IDE04058	Bluetooth-Bluetooth: devices found	0
MAS00951-MAS04324	Bluetooth-Bluetooth: connected devices	0
MAS00951-MAS04325	Bluetooth-Bluetooth: Paired devices	1
MAS01760-MAS01765	Radio Tuner 1-Audio Signal	Mute
MAS01760-MAS02949	Radio Tuner 1-Frequency	88.7	 MHz
MAS01760-MAS03991	Radio Tuner 1-Reception level antenna 1	10	 dBµV
MAS01760-MAS04344	Radio Tuner 1-Reception level antenna 2	15	 dBµV
MAS01760-MAS04345	Radio Tuner 1-Frequency (AM)	65535	 kHz
MAS01760-ENG117356	Radio Tuner 1-iboc_audio_signal	Not available
MAS01760-ENG117358	Radio Tuner 1-iboc_count	0
MAS01760-ENG117355	Radio Tuner 1-iboc_error_rate	255
MAS01760-ENG117357	Radio Tuner 1-iboc_service	1
MAS01761-MAS01763	Radio Tuner 2-Signal Strength	14	 dBµV
MAS01991-IDE00010	Card reader-Serial number	10 7C 3B BB
MAS01991-IDE01001	Card reader-Application	AP
MAS01991-MAS01632	Card reader-Status	connected
MAS01991-MAS03159	Card reader-Manufacturer	9
MAS01991-MAS03375	Card reader-Major version	2
MAS01991-MAS03376	Card reader-Minor version	0
MAS01991-MAS03959	Card reader-Write-protection	activated
MAS01991-MAS04388	Card reader-Card type	MIBST
MAS01991-MAS13476	Card reader-Herstellungsdatum: Monat	6	 mon
MAS01991-MAS13477	Card reader-Herstellungsdatum: Jahr	2016	 yr
MAS03121	Ring break diagnostic line status	Supply voltage
MAS03780-IDE00010	Card reader 2-Serial number	FF FF FF FF
MAS03780-IDE01001	Card reader 2-Application	--
MAS03780-MAS01632	Card reader 2-Status	not connected
MAS03780-MAS03159	Card reader 2-Manufacturer	FF
MAS03780-MAS03375	Card reader 2-Major version	15
MAS03780-MAS03376	Card reader 2-Minor version	15
MAS03780-MAS03959	Card reader 2-Write-protection	Not available
MAS03780-MAS04388	Card reader 2-Card type	-----
MAS03780-MAS13476	Card reader 2-Herstellungsdatum: Monat	15	 mon
MAS03780-MAS13477	Card reader 2-Herstellungsdatum: Jahr	2255	 yr
MAS04324	Bluetooth: connected devices	SDAP
MAS04324	Bluetooth: connected devices	0
MAS04325	Bluetooth: Paired devices	Remote SIM Access Profile (rSAP)
MAS04325	Bluetooth: Paired devices	1.12955E+15
ENG117872-ENG117778	Byte_Coding_Condition-byte_0_condition	OK
ENG117872-ENG117779	Byte_Coding_Condition-byte_1_condition	OK
ENG117872-ENG117788	Byte_Coding_Condition-byte_10_condition	OK
ENG117872-ENG117789	Byte_Coding_Condition-byte_11_condition	OK
ENG117872-ENG117790	Byte_Coding_Condition-byte_12_condition	OK
ENG117872-ENG117791	Byte_Coding_Condition-byte_13_condition	OK
ENG117872-ENG117792	Byte_Coding_Condition-byte_14_condition	OK
ENG117872-ENG117793	Byte_Coding_Condition-byte_15_condition	OK
ENG117872-ENG117794	Byte_Coding_Condition-byte_16_condition	OK
ENG117872-ENG117795	Byte_Coding_Condition-byte_17_condition	OK
ENG117872-ENG117796	Byte_Coding_Condition-byte_18_condition	OK
ENG117872-ENG117797	Byte_Coding_Condition-byte_19_condition	OK
ENG117872-ENG117780	Byte_Coding_Condition-byte_2_condition	OK
ENG117872-ENG117798	Byte_Coding_Condition-byte_20_condition	OK
ENG117872-ENG117799	Byte_Coding_Condition-byte_21_condition	OK
ENG117872-ENG117800	Byte_Coding_Condition-byte_22_condition	OK
ENG117872-ENG117801	Byte_Coding_Condition-byte_23_condition	OK
ENG117872-ENG117802	Byte_Coding_Condition-byte_24_condition	OK
ENG117872-ENG117803	Byte_Coding_Condition-byte_25_condition	dont care
ENG117872-ENG117804	Byte_Coding_Condition-byte_26_condition	dont care
ENG117872-ENG117805	Byte_Coding_Condition-byte_27_condition	dont care
ENG117872-ENG117781	Byte_Coding_Condition-byte_3_condition	OK
ENG117872-ENG117782	Byte_Coding_Condition-byte_4_condition	OK
ENG117872-ENG117783	Byte_Coding_Condition-byte_5_condition	OK
ENG117872-ENG117784	Byte_Coding_Condition-byte_6_condition	OK
ENG117872-ENG117785	Byte_Coding_Condition-byte_7_condition	OK
ENG117872-ENG117786	Byte_Coding_Condition-byte_8_condition	OK
ENG117872-ENG117787	Byte_Coding_Condition-byte_9_condition	OK
ENG117867-ENG117773	GPS_Count_Satellite_Phase_Lock_Counter-satellites	10
ENG117868-ENG117773	GPS_Satellite_Code_Lock_Counter-satellites	10
ENG117857-MAS00109	Last_System_Operating_Time-Hours	0	 H
ENG117857-MAS00110	Last_System_Operating_Time-Minutes	14	 min
ENG117856-MAS00106	Last_System_Operating_Time/Mins.-Year	0	 yr
ENG117856-MAS00107	Last_System_Operating_Time/Mins.-Month	0	 mon
ENG117856-MAS00108	Last_System_Operating_Time/Mins.-Day	0	 d
ENG117856-MAS00109	Last_System_Operating_Time/Mins.-Hours	0	 H
ENG117856-MAS00110	Last_System_Operating_Time/Mins.-Minutes	0	 min
ENG117856-MAS00111	Last_System_Operating_Time/Mins.-Seconds	0	 s
ENG117869-ENG117441	Nav._Calculated_Direction-driving direction corrected	248	 °
ENG117869-ENG98933	Nav._Calculated_Direction-Status	OK
ENG122217-ENG122284	SDARS_service-audio_service	subscribed
ENG122217-ENG122285	SDARS_service-traffic_service	subscribed
ENG122217-ENG122286	SDARS_service-travel_link_service	subscribed
ENG122216-ENG122281	SDARS_subscription_status-SDARS_expiration_date	2000
ENG122216-ENG122279	SDARS_subscription_status-SDARS_subscription	subscribed
ENG122216-ENG125804	SDARS_subscription_status-SDARS_suspend_alert	0
ENG122216-ENG122280	SDARS_subscription_status-SDARS_suspension	not_suspended
ENG127487-IDE02451	SDARS_tuner_status_2-Satellite radio antenna status	Electrical OK
ENG127487-IDE02453	SDARS_tuner_status_2-Channel selection for satellite radio	34
ENG127487-MAS01765	SDARS_tuner_status_2-Audio Signal	Available
ENG127487-MAS01808	SDARS_tuner_status_2-Antenna current	146	 mA
ENG127487-MAS02573	SDARS_tuner_status_2-Reception quality	optimum_signal
ENG127487-MAS13343	SDARS_tuner_status_2-Tuner für Satellitenradio: Status der Voraktivierung	7
ENG127487-MAS13344	SDARS_tuner_status_2-Tuner für Satellitenradio: Wert der Voraktivierung	7
ENG117864-MAS01632	Status_Position_Touchscreen_1-Status	Not available
ENG117864-ENG117402	Status_Position_Touchscreen_1-calibrate_delta_x	65535
ENG117864-ENG117403	Status_Position_Touchscreen_1-calibrate_delta_y	65535
ENG117864-ENG117396	Status_Position_Touchscreen_1-position_x1	65535
ENG117864-ENG117397	Status_Position_Touchscreen_1-position_x2	65535
ENG117864-ENG117398	Status_Position_Touchscreen_1-position_x3	65535
ENG117864-ENG117399	Status_Position_Touchscreen_1-position_y1	65535
ENG117864-ENG117400	Status_Position_Touchscreen_1-position_y2	65535
ENG117864-ENG117401	Status_Position_Touchscreen_1-position_y3	65535
ENG117858-MAS01424	System_Temperature_Sensor_2-Maximum value	55	 °C
ENG117858-MAS01425	System_Temperature_Sensor_2-Minimum value	-7	 °C
ENG117858-MAS02238	System_Temperature_Sensor_2-Current	48	 °C
ENG117860-MAS01424	System_Temperature_Sensor_4-Maximum value	47	 °C
ENG117860-MAS01425	System_Temperature_Sensor_4-Minimum value	-11	 °C
ENG117860-MAS02238	System_Temperature_Sensor_4-Current	40	 °C
ENG117862-MAS01424	System_Temperature_Sensor_6-Maximum value	52	 °C
ENG117862-MAS01425	System_Temperature_Sensor_6-Minimum value	-7	 °C
ENG117862-MAS02238	System_Temperature_Sensor_6-Current	46	 °C
Elapsed Time: 00:40
adpmap-5F-3Q0-035-876-A.CSV
;Wednesday	11	January	2017	20:17:59:08929
IDE00001-Production mode	00 00 00
IDE00346-Summertime-automatic	manual
IDE00758-Base volume of telephone	50%
IDE00759-Base volume of speech output	50%
IDE00760-Microphone sensitivity	0 dB
IDE00769-Number 1 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00770-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages	OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages	OFF
IDE00845-Wheel circ.	0 mm
IDE01996-ENG99724-Installation list: specified installations-ECU coded	Yes
IDE01996-ENG99724-Installation list: specified installations-ECU coded	No
IDE01996-ENG06573-Installation list: specified installations-ECU coded 2	No
IDE02121-CD eject button	Enabled
IDE02122-Developer mode	not activated
IDE02330-Number 2 for Info call	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02331-Number 2 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02332-Deactivate production mode	0
IDE02476-MAS03001-Electrical test of loudspeakers-Mode	automatic
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency	19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume	27
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency	19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume	27
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency	19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume	27
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency	19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume	27
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency	19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume	27
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency	19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume	27
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency	19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume	27
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency	19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume	27
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency	19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume	27
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency	19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume	27
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency	19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume	27
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency	19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume	27
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency	19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume	27
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency	19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume	27
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency	19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume	27
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency	19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume	27
IDE02502-Confirmation of installation change	A4 5A
IDE02607-Wheel pulse	0
IDE02699-Number 1 for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02701-Number 1 (roaming) for roadside assistance	FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE03471-ENG117847-Vehicle configuration-advanced_range_display	OFF
IDE03471-ENG130249-Vehicle configuration-Apple_DIO	On
IDE03471-ENG125043-Vehicle configuration-Dtmf_without_active_call	On
IDE03471-ENG130248-Vehicle configuration-Google_GAL	On
IDE03471-ENG117850-Vehicle configuration-gracenote_local_coverarts	OFF
IDE03471-ENG117851-Vehicle configuration-gracenote_local_other	OFF
IDE03471-ENG117848-Vehicle configuration-gracenote_online_coverarts	OFF
IDE03471-ENG117849-Vehicle configuration-gracenote_online_other	OFF
IDE03471-ENG125049-Vehicle configuration-Joker_button_1	Not Present
IDE03471-ENG125050-Vehicle configuration-Joker_button_2	Not Present
IDE03471-ENG127492-Vehicle configuration-LGI	OFF
IDE03471-ENG130246-Vehicle configuration-LTE_modul	activated
IDE03471-ENG07590-Vehicle configuration-Mirror_link	function_on_hmi_on
IDE03471-ENG117843-Vehicle configuration-my_audi	OFF
IDE03471-ENG117845-Vehicle configuration-online_dictation	OFF
IDE03471-ENG127495-Vehicle configuration-online_media	OFF
IDE03471-ENG117840-Vehicle configuration-online_navigation	OFF
IDE03471-ENG117837-Vehicle configuration-online_POI	OFF
IDE03471-ENG117838-Vehicle configuration-online_POI_voice	OFF
IDE03471-ENG117839-Vehicle configuration-online_portal_browser_services	OFF
IDE03471-ENG117841-Vehicle configuration-online_street_view	OFF
IDE03471-ENG125048-Vehicle configuration-OPS_display_in_dash_board_display_unit	OFF
IDE03471-ENG125046-Vehicle configuration-Phone_module_operation_mode	Data & language service active
IDE03471-ENG117844-Vehicle configuration-picture_navi	On
IDE03471-ENG127496-Vehicle configuration-ProbeCar_lgi	OFF
IDE03471-ENG06574-Vehicle configuration-ProbeCar_vzo	OFF
IDE03471-ENG125047-Vehicle configuration-PSD_Protocol_Version	PSD_1.5
IDE03471-ENG117846-Vehicle configuration-remote_HMI	OFF
IDE03471-ENG07589-Vehicle configuration-RSE_software_component	activated
IDE03471-ENG126143-Vehicle configuration-RVC_video_input	FBAS
IDE03471-ENG11009-Vehicle configuration-sd_slot_deactivation	no restriction
IDE03471-ENG07588-Vehicle configuration-SDS_Region_Flag	no_region
IDE03471-ENG125045-Vehicle configuration-Sim_card_mode_switch	Not Present
IDE03471-ENG07591-Vehicle configuration-Smartphone_interface_for_rhmi	activated
IDE03471-ENG126993-Vehicle configuration-Station_Logo_DB_Mode	0
IDE03471-ENG125044-Vehicle configuration-Support_for_response_and_hold	OFF
IDE03471-ENG125042-Vehicle configuration-Support_of_threeway_calling	On
IDE03471-ENG130247-Vehicle configuration-Support_second_phone	On
IDE03471-ENG126994-Vehicle configuration-TPEG_availability	OFF
IDE03471-ENG06575-Vehicle configuration-UOTA	OFF
IDE03471-ENG117852-Vehicle configuration-UPnP	OFF
IDE03471-ENG117836-Vehicle configuration-VZAPro	OFF
IDE03471-ENG127494-Vehicle configuration-VZO	OFF
IDE03471-ENG06576-Vehicle configuration-WiFi_Client_HMI	OFF
IDE03471-ENG117842-Vehicle configuration-WIFI_Hotspot	OFF
IDE03902-Automatic ring break diagnostic	No automatic start
IDE04295-Bluetooth: Preferred connection profile for phone book data	PBAP
IDE04331-Selection of release codes for a SWaP function	FF FF FF FF
IDE04521-Sporadic ring break detection	Visual
IDE04522-Awakening ability on optical databus	OFF
IDE04550-Bluetooth: Sniff mode	OFF
IDE05111-Fee-based traffic information (TMC)	1537
IDE05113-Infotainment Recorder	activated
IDE08814-IDE04033-Navigation receiver GNSS configuration-Compass	OFF
IDE08814-MAS01570-Navigation receiver GNSS configuration-Default	On
IDE08814-MAS02614-Navigation receiver GNSS configuration-GPS	OFF
IDE08814-MAS07828-Navigation receiver GNSS configuration-Galileo	OFF
IDE08814-MAS07829-Navigation receiver GNSS configuration-Glonass	OFF
IDE08814-ENG10975-Navigation receiver GNSS configuration-external_gps_1	OFF
IDE08814-ENG10976-Navigation receiver GNSS configuration-external_gps_2	OFF
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner	-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio	5
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM)	-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM)	-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB)	-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB	-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP	-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay	-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter	-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN	-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray	-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice	-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA	-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud	-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD	-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI	-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP	-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP	-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink	-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP	-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB	-3
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice	-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM	-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep	-128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging	-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen	6
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning	-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav	-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS	-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online	-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal	-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI	-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN	-128
IDE10480-MAS10741-Interface for external media: activation-Connection 1	activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2	not activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3	not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4	not activated
IDE10604-Menu entries for mobile online services	not activated
IDE11122-Country identification: country of sale HMI	US
IDE11502-ENG127601-Locked menu contents-FB_CAR_0	blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1	non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10	non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11	blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12	blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13	non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14	non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15	non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16	non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17	non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18	non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19	non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2	blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20	non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21	non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22	non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23	non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3	blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4	non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5	non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6	non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7	blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8	non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9	non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0	non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1	blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10	blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11	blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12	blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13	blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14	non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15	blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16	non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17	non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18	non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19	non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2	non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20	non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21	non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22	non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23	non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3	blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4	blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5	blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6	non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7	non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8	blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9	blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0	blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1	non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10	blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11	blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12	blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13	blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14	blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15	non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16	non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17	non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18	blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19	blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2	blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20	blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21	non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22	non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23	non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24	non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25	non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26	non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27	non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28	non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29	non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3	non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30	non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31	non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32	non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33	non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34	non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35	non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36	non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37	non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38	non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39	non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4	non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40	non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41	non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42	non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43	non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44	blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45	blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46	blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47	blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5	blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6	non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7	non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8	non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9	blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0	blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1	non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10	non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11	non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12	non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13	non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14	non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15	non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16	non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17	non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18	non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19	non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2	non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20	non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21	blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22	non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23	non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24	non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25	non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26	non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27	non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28	non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29	non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3	non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30	non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31	non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32	non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33	non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34	non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35	non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36	non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37	non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38	non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39	non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4	blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5	non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6	blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7	non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8	non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9	blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0	blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1	non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10	non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11	non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12	non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13	non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14	non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15	non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2	non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3	non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4	blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5	blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6	blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7	blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8	non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9	non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0	non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1	non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10	non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11	non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12	non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13	non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14	non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15	non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2	non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3	blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4	blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5	blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6	blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7	blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8	non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9	non_blocked
IDE11503-Tuner for satellite radio: preparation	7
MAS00951-Bluetooth	On
MAS01968-Fan	normal
MAS02809-MAS02870-Check tone frequency-High note frequency range	4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range	1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range	100 Hz
MAS03782-WLAN	On
ENG117917-BAP_Debug_Mode_Release	not_released
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization	not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer	not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off	not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high	not activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill	not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC	activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer	not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off	not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high	activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill	not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key	not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer	not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off	not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high	not activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill	not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue	not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer	not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off	not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high	not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill	not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper	not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer	not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off	not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high	not activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill	not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination	activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer	not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off	not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high	activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill	not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope	not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer	not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off	not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high	not activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill	not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification	not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer	not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off	not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high	not activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill	not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating	not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer	not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off	not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high	not activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill	not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv	activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer	not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off	not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high	activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill	not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management	not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer	not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off	not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high	not activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill	not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE	activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer	not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off	not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high	activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill	not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer	activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer	not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off	not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high	activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill	not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function	activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer	not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off	not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high	activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill	not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror	activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer	not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off	not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high	activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill	not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking	activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer	not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off	not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high	activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill	not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master	activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer	not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off	not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high	activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill	not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma	activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer	not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off	not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high	activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill	not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration	activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer	not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off	not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high	activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill	not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock	activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer	not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off	not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high	activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill	not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass	activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer	not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off	not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high	activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill	not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist	not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer	not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off	not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high	not activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill	not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration	not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer	not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off	not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high	not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill	not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school	not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer	not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off	not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high	not activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill	not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall	activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer	not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off	not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high	activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill	not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist	not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer	not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off	not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high	not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill	not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI	activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer	not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off	not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high	activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill	not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination	activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer	not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off	not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high	activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill	not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display	not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer	not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off	not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high	not activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill	not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid	not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer	not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off	not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high	not activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill	not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant	not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer	not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off	not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high	not activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill	not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning	activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer	not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off	not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high	activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill	not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker	not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer	not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off	not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high	not activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill	not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision	not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer	not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off	not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high	not activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill	not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level	not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer	not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off	not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high	not activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill	not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc	activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer	not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off	not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high	activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill	not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist	not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer	not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off	not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high	not activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill	not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk	activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer	not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off	not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high	activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill	not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment	not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer	not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off	not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high	not activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill	not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load	not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer	not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off	not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high	not activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill	not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification	not activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer	not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off	not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high	not activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill	not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration	not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer	not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off	not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high	not activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill	not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic	not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer	not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off	not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high	not activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill	not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia	activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer	not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off	not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high	activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill	not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view	not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer	not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off	not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high	not activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill	not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions	not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer	not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off	not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high	not activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill	not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler	not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer	not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off	not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high	not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill	not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI	not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer	not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off	not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high	not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill	not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons	not activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer	not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off	not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high	not activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill	not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant	not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer	not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off	not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high	not activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill	not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner	not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer	not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off	not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high	not activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill	not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo	not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer	not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off	not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high	not activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill	not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating	activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer	not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off	not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high	activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill	not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin	activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer	not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off	not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high	activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill	not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition	not activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer	not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off	not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high	not activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill	not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows	activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer	not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off	not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high	activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill	not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper	activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer	not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off	not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high	activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill	not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol	not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer	not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off	not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high	not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill	not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05	activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus	Databus extended
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06	not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus	Suspension data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D	not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus	Databus Infotainment
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24	not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus	not activated
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03	not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus	Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B	activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus	Terminal 15
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25	not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus	Databus drivetrain
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23	activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus	Databus Infotainment
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26	activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus	Suspension data bus
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D	activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus	Comfort data bus
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17	activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus	Databus Infotainment
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16	not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus	Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01	activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus	Comfort data bus
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02	not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus	Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11	activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus	Comfort data bus
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15	not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus	not activated
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10	not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus	Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33	activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus	Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C	Comfort data bus
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C	not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37	activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus	Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09	activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus	Comfort data bus
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04	not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus	Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D	not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus	Databus drivetrain
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08	activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus	Comfort data bus
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19	activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus	Databus extended
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F	activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus	Comfort data bus
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34	not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34	Databus Infotainment
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E	activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus	Comfort data bus
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18	not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus	not activated
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A	activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus	Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20	not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus	Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A	not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A	Databus extended
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39	not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39	Databus Infotainment
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E	not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus	Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F	not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus	Databus drivetrain
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B	not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B	Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F	not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F	Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E	not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E	Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12	activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus	Comfort data bus
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E	not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus	not activated
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35	not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35	Comfort data bus
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27	not activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus	Databus Infotainment
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A	not activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus	Databus extended
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07	activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus	Suspension data bus
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21	not activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus	Databus extended
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36	not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36	Comfort data bus
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C	not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus	Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14	not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus	Terminal 15
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13	activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus	Comfort data bus
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B	not activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus	Databus Infotainment
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22	not activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus	Databus Infotainment
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C	activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus	Comfort data bus
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key	Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus	Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school	Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus	Databus Infotainment
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL	Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus	Databus Infotainment
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level	Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus	Databus drivetrain
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering	Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus	Suspension data bus
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN	Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus	Comfort data bus
ENG122230-ENG11025-Dashboard_Display_Configuration-ability_switch_nav_maps	OFF
ENG122230-ENG122343-Dashboard_Display_Configuration-call_picture	OFF
ENG122230-ENG122341-Dashboard_Display_Configuration-coverart	OFF
ENG122230-ENG122340-Dashboard_Display_Configuration-crossroad_detail_map_compression_mode	RLE
ENG122230-ENG122344-Dashboard_Display_Configuration-crossroad_detail_map_resolution	resolution_1
ENG122230-ENG127006-Dashboard_Display_Configuration-crossroad_detail_map_transmission_mode	OFF
ENG122230-ENG127501-Dashboard_Display_Configuration-fastlist_most	OFF
ENG122230-ENG122338-Dashboard_Display_Configuration-navigation_map_compression_mode	RLE
ENG122230-ENG122339-Dashboard_Display_Configuration-navigation_map_resolution	resolution_1
ENG122230-ENG127005-Dashboard_Display_Configuration-navigation_map_transmission_mode	OFF
ENG122230-ENG122342-Dashboard_Display_Configuration-stationart	OFF
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1	0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2	50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3	100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1	0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2	50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3	100
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1	0
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2	50
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3	100
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1	0
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2	50
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3	100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1	0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2	10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3	100
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4	150
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5	220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6	253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1	1%
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2	1%
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3	8%
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4	20%
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5	60%
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6	100%
ENG10564-ENG10977-Key_code_monitoring-monitoring_keycode_0x00_0x07	0
ENG10564-ENG10978-Key_code_monitoring-monitoring_keycode_0x08_0x0F	0
ENG10564-ENG10979-Key_code_monitoring-monitoring_keycode_0x10_0x17	0
ENG10564-ENG10980-Key_code_monitoring-monitoring_keycode_0x18_0x1F	0
ENG10564-ENG10981-Key_code_monitoring-monitoring_keycode_0x20_0x27	0
ENG10564-ENG10982-Key_code_monitoring-monitoring_keycode_0x28_0x2F	0
ENG10564-ENG10983-Key_code_monitoring-monitoring_keycode_0x30_0x37	0
ENG10564-ENG10984-Key_code_monitoring-monitoring_keycode_0x38_0x3F	0
ENG10564-ENG10985-Key_code_monitoring-monitoring_keycode_0x40_0x47	0
ENG10564-ENG10986-Key_code_monitoring-monitoring_keycode_0x48_0x4F	0
ENG10564-ENG10987-Key_code_monitoring-monitoring_keycode_0x50_0x57	0
ENG10564-ENG10988-Key_code_monitoring-monitoring_keycode_0x58_0x5F	0
ENG10564-ENG10989-Key_code_monitoring-monitoring_keycode_0x60_0x67	0
ENG10564-ENG10990-Key_code_monitoring-monitoring_keycode_0x68_0x6F	0
ENG10564-ENG10991-Key_code_monitoring-monitoring_keycode_0x70_0x77	0
ENG10564-ENG10992-Key_code_monitoring-monitoring_keycode_0x78_0x7F	0
ENG10564-ENG10993-Key_code_monitoring-monitoring_keycode_0x80_0x87	0
ENG10564-ENG10994-Key_code_monitoring-monitoring_keycode_0x88_0x8F	0
ENG10564-ENG10995-Key_code_monitoring-monitoring_keycode_0x90_0x97	0
ENG10564-ENG10996-Key_code_monitoring-monitoring_keycode_0x98_0x9F	0
ENG10564-ENG10997-Key_code_monitoring-monitoring_keycode_0xA0_0xA7	0
ENG10564-ENG10998-Key_code_monitoring-monitoring_keycode_0xA8_0xAF	0
ENG10564-ENG10999-Key_code_monitoring-monitoring_keycode_0xB0_0xB7	0
ENG10564-ENG11000-Key_code_monitoring-monitoring_keycode_0xB8_0xBF	0
ENG10564-ENG11001-Key_code_monitoring-monitoring_keycode_0xC0_0xC7	0
ENG10564-ENG11002-Key_code_monitoring-monitoring_keycode_0xC8_0xCF	0
ENG10564-ENG11003-Key_code_monitoring-monitoring_keycode_0xD0_0xD7	0
ENG10564-ENG11004-Key_code_monitoring-monitoring_keycode_0xD8_0xDF	0
ENG10564-ENG11005-Key_code_monitoring-monitoring_keycode_0xE0_0xE7	0
ENG10564-ENG11006-Key_code_monitoring-monitoring_keycode_0xE8_0xEF	0
ENG10564-ENG11007-Key_code_monitoring-monitoring_keycode_0xF0_0xF7	0
ENG10564-ENG11008-Key_code_monitoring-monitoring_keycode_0xF8_0xFF	0
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation	04 01 52 04 52 10 52 40 52 32 00 64 00 3C 00 7C 01 1D 01 50 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 02 00 A8
ENG117809-p_damping_Display	5 ms
ENG117808-p_HMI_Display	13%
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset	0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset	0
ENG117919-Startup_Screen_Sticker_HMI	00 01
Elapsed Time: 00:29
75-Telematics
blockmap-75-5QE-035-285-A.CSV
;SW:5QE-035-285-A   HW:5QE-035-285-A ---  Telematics
;Component:OCULowMQBUS   007 0568	 Coding:02730202C2823A017F1E06020000
;EV_OCULowMQB	1006	EV_OCULowMQB.rod
;Wednesday	11	January	2017	20:18:50:08929
;VCDS Version: Release 17.1.1 (x64)  Data version: 20170106 DS267.0
;VCID: C3C94CA94AB7B95908-8096
Group	Description	Actual
IDE00019	Voltage terminal 30	12.7	 V
IDE00020	Terminal 15 status	On
IDE00102	Control Module temperature	48	 °C
IDE00323	Security Access: Number of invalid keys	0
IDE00608	Type of fuel	Petrol
IDE00667	Microphone status	Electrical OK
IDE00668	Microphone current consumption	5	 mA
IDE00672	Roadside Assistance Button	not activated
IDE00673	Information Service Button	not activated
IDE00767	No. of unscheduled ECU resets	0
IDE01215	Terminal 58d dimmer	3.97	 %
IDE01625	Muting of radio/radio navigation system via control wire	Measured value not available
IDE01712-IDE06673	GPS Position-Initialization status	initialized
IDE01712-MAS01779	GPS Position-Length	W79°37'22.894"
IDE01712-MAS01780	GPS Position-Width	N40°31'58.922"
IDE01712-MAS02230	GPS Position-Height	134	 m
IDE01713-MAS01632	Status GPS reception-Status	No GPS reception
IDE01713-MAS01785	Status GPS reception-Number of visible satellites	14
IDE01713-MAS01786	Status GPS reception-Number of tracked satellites	8
IDE01715	Status terminal S	On
IDE01770-MAS01632	Status of GPS antenna-Status	OK
IDE01770-MAS01808	Status of GPS antenna-Antenna current	0	 mA
IDE01971	Lowest recorded control module temperature	-8	 °C
IDE01972	Highest recorded control module temperature	57	 °C
IDE02067-IDE00690	Antenna for telephone status-Connection to antenna	Electrical OK
IDE02067-MAS01808	Antenna for telephone status-Antenna current	1	 mA
IDE02067-MAS03991	Antenna for telephone status-Reception level antenna 1	100	 %
IDE02326-ENG117459	GPS signal strength-ID_GPS_satellite_no_1	0
IDE02326-ENG117461	GPS signal strength-ID_GPS_satellite_no_2	0
IDE02326-ENG117463	GPS signal strength-ID_GPS_satellite_no_3	0
IDE02326-ENG117465	GPS signal strength-ID_GPS_satellite_no_4	0
IDE02326-ENG117460	GPS signal strength-S/N_GPS_satellite_no_1	0	 dBµV
IDE02326-ENG117462	GPS signal strength-S/N_GPS_satellite_no_2	0	 dBµV
IDE02326-ENG117464	GPS signal strength-S/N_GPS_satellite_no_3	0	 dBµV
IDE02326-ENG117466	GPS signal strength-S/N_GPS_satellite_no_4	0	 dBµV
IDE02486	Data logger triggering	Measured value not available
IDE03348-MAS01586	Speed warning-Alarm	0
IDE03348	Speed warning	655.33	 km/h
IDE03348-MAS08775	Speed warning-Calculation frequency	5	 s
IDE03348-MAS08776	Speed warning-tolerance	5	 m
IDE03348-MAS08777	Speed warning-Contact bounce suppression	5	 s
IDE03477-MAS01632	GPS time-Status	valid
IDE03477-ENG117467	GPS time-gps_date_time	2000
IDE04605-IDE01712	Navigation: Corrected position-GPS Position	Not available
IDE04605-MAS01779	Navigation: Corrected position-Length	79623027
IDE04605-MAS01780	Navigation: Corrected position-Width	40533032
IDE04605-ENG123297	Navigation: Corrected position-error_value	0	 m
IDE04750-MAS03876	SIM cards-active SIM card	internal
IDE04750-MAS03877	SIM cards-SIM ID	8.90117E+19
IDE04750-MAS03878	SIM cards-SIM IMSI	3.10171E+14
IDE04750-MAS04226	SIM cards-Telephone number
IDE04750-MAS08401	SIM cards-SIM intern	Available
IDE04750-MAS08402	SIM cards-SIM extern	Not available
IDE04790	Call for help button	not activated
IDE05430	Telephone serial number	3.58895E+14
IDE06644	Vehicle positioning system	Measured value not available
IDE07007-IDE00983	A/C heater function via remote control-Interior temperature	128	 °C
IDE07007-IDE04927	A/C heater function via remote control-Window heater	On
IDE07007-MAS01118	A/C heater function via remote control-Climate control	Measured value not available
IDE07007-MAS02289	A/C heater function via remote control-Outside air temperature	128	 °C
IDE07007-MAS05945	A/C heater function via remote control-Specified temperature	128	 °C
IDE07007-MAS08947	A/C heater function via remote control-After-run time for power supply	255	 min
IDE07007-MAS08948	A/C heater function via remote control-After-run time for battery	255	 min
IDE07007-MAS08949	A/C heater function via remote control-Climate control without power supply	On
IDE07007-MAS08957	A/C heater function via remote control-A/C window heater	On
IDE07007-MAS08958	A/C heater function via remote control-reason for last climate control	Measured value not available
IDE07543	Vehicle speed	0	 km/h
IDE07940-IDE07007	Status of enabling for online services-A/C heater function via remote control	not activated
IDE07940-IDE07909	Status of enabling for online services-Remote control for vehicle locking	activated
IDE07940	Status of enabling for online services	activated
IDE07940-IDE07974	Status of enabling for online services-Transmission of navigation targets	activated
IDE07940-IDE07975	Status of enabling for online services-Remote control for charge function of high-voltage battery	not activated
IDE07940-IDE07976	Status of enabling for online services-Info call	activated
IDE07940-IDE08155	Status of enabling for online services-Vehicle state report	activated
IDE07940-IDE08158	Status of enabling for online services-Roadside assistance / schedule agreement for service	activated
IDE07940-MAS08370	Status of enabling for online services-Position monitoring (Geofencing)	activated
IDE07940-MAS08371	Status of enabling for online services-Remote control for speed warning	activated
IDE07940-MAS08372	Status of enabling for online services-Remote control for vehicle shutdown	not activated
IDE07940-MAS08373	Status of enabling for online services-Remote control for vehicle location	activated
IDE07940-MAS08374	Status of enabling for online services-Remote control for lights and horn	activated
IDE07940-MAS08375	Status of enabling for online services-Distance statistics display	not activated
IDE07940-MAS08376	Status of enabling for online services-Display vehicle state	activated
IDE07940-MAS08377	Status of enabling for online services-Remote control for departure time programming	not activated
IDE07940-MAS08448	Status of enabling for online services-Manual roadside assistance	activated
IDE07940-MAS08449	Status of enabling for online services-Automatic roadside assistance	activated
IDE07975-IDE00704	Remote control for charge function of high-voltage battery-Charge level	Measured value not available
IDE07975-IDE01839	Remote control for charge function of high-voltage battery-Battery charge condition	255	 %
IDE07975-IDE05431	Remote control for charge function of high-voltage battery-Locking for high-voltage charge plug	Measured value not available
IDE07975-IDE06986	Remote control for charge function of high-voltage battery-High-voltage battery charge current: maximum value	63	 A
IDE07975-MAS01002	Remote control for charge function of high-voltage battery-Remaining operating range	65535	 km
IDE07975-MAS01118	Remote control for charge function of high-voltage battery-Climate control	Measured value not available
IDE07975-MAS05682	Remote control for charge function of high-voltage battery-External Charging	Not available
IDE07975-MAS08781	Remote control for charge function of high-voltage battery-Connection state of charging plug	Measured value not available
IDE07975-MAS08782	Remote control for charge function of high-voltage battery-Remaining charge time	771	 min
IDE07975-MAS08783	Remote control for charge function of high-voltage battery-Reason for last battery charge	Measured value not available
IDE07975-MAS08784	Remote control for charge function of high-voltage battery-Charging current type	Measured value not available
IDE08077-IDE02068	Timer 1 for programming of departure time-Time stamp	2000
IDE08077-MAS01240	Timer 1 for programming of departure time-Programming status	Measured value not available
IDE08077-MAS01635	Timer 1 for programming of departure time-Monday	not programmed
IDE08077-MAS01636	Timer 1 for programming of departure time-Tuesday	not programmed
IDE08077-MAS01637	Timer 1 for programming of departure time-Wednesday	not programmed
IDE08077-MAS01638	Timer 1 for programming of departure time-Thursday	not programmed
IDE08077-MAS01639	Timer 1 for programming of departure time-Friday	not programmed
IDE08077-MAS01640	Timer 1 for programming of departure time-Saturday	not programmed
IDE08077-MAS01641	Timer 1 for programming of departure time-Sunday	not programmed
IDE08077-MAS08963	Timer 1 for programming of departure time-Condition of timer	Measured value not available
IDE08077-ENG123310	Timer 1 for programming of departure time-Timer_Mode	Measured value not available
IDE08077-ENG123309	Timer 1 for programming of departure time-Timer_Type	Measured value not available
IDE08078-IDE02068	Timer 2 for programming of departure time-Time stamp	2000
IDE08078-MAS01240	Timer 2 for programming of departure time-Programming status	Measured value not available
IDE08078-MAS01635	Timer 2 for programming of departure time-Monday	not programmed
IDE08078-MAS01636	Timer 2 for programming of departure time-Tuesday	not programmed
IDE08078-MAS01637	Timer 2 for programming of departure time-Wednesday	not programmed
IDE08078-MAS01638	Timer 2 for programming of departure time-Thursday	not programmed
IDE08078-MAS01639	Timer 2 for programming of departure time-Friday	not programmed
IDE08078-MAS01640	Timer 2 for programming of departure time-Saturday	not programmed
IDE08078-MAS01641	Timer 2 for programming of departure time-Sunday	not programmed
IDE08078-MAS08963	Timer 2 for programming of departure time-Condition of timer	Measured value not available
IDE08078-ENG123310	Timer 2 for programming of departure time-Timer_Mode	Measured value not available
IDE08078-ENG123309	Timer 2 for programming of departure time-Timer_Type	Measured value not available
IDE08079-IDE02068	Timer 3 for programming of departure time-Time stamp	2000
IDE08079-MAS01240	Timer 3 for programming of departure time-Programming status	Measured value not available
IDE08079-MAS01635	Timer 3 for programming of departure time-Monday	not programmed
IDE08079-MAS01636	Timer 3 for programming of departure time-Tuesday	not programmed
IDE08079-MAS01637	Timer 3 for programming of departure time-Wednesday	not programmed
IDE08079-MAS01638	Timer 3 for programming of departure time-Thursday	not programmed
IDE08079-MAS01639	Timer 3 for programming of departure time-Friday	not programmed
IDE08079-MAS01640	Timer 3 for programming of departure time-Saturday	not programmed
IDE08079-MAS01641	Timer 3 for programming of departure time-Sunday	not programmed
IDE08079-MAS08963	Timer 3 for programming of departure time-Condition of timer	Measured value not available
IDE08079-ENG123310	Timer 3 for programming of departure time-Timer_Mode	Measured value not available
IDE08079-ENG123309	Timer 3 for programming of departure time-Timer_Type	Measured value not available
IDE08159-IDE07007	Status of online services-A/C heater function via remote control	not active
IDE08159-IDE07975	Status of online services-Remote control for charge function of high-voltage battery	not active
IDE08159-IDE08158	Status of online services-Roadside assistance / schedule agreement for service	not active
IDE08159-MAS08370	Status of online services-Position monitoring (Geofencing)	not active
IDE08159-MAS08371	Status of online services-Remote control for speed warning	not active
IDE08159-MAS08372	Status of online services-Remote control for vehicle shutdown	not active
IDE08159-MAS08373	Status of online services-Remote control for vehicle location	not active
IDE08159-MAS08374	Status of online services-Remote control for lights and horn	not active
IDE08159-MAS08377	Status of online services-Remote control for departure time programming	not active
IDE08159-MAS08448	Status of online services-Manual roadside assistance	not active
MAS00464	Standard - ambient data 1	2000
MAS00464-MAS00468	Standard - ambient data 1-Unlearning counter	13
MAS00464-MAS00711	Standard - ambient data 1-Odometer reading	490	 km
MAS00464	Standard - ambient data 1	1
MAS00464	Standard - ambient data 1	11
MAS00464	Standard - ambient data 1	5
MAS00464	Standard - ambient data 1	27
MAS01490-MAS08403	Energy management-Remaining short term energy budget	962	 mAh
MAS01490-MAS08404	Energy management-Remaining long term energy budget	3600	 mAh
MAS01490-MAS08405	Energy management-Wake up cycles counter	5
MAS04394-IDE03580	Connection status-Country code for mobile network	310
MAS04394-IDE07699	Connection status-Mobile network operator	410
MAS04394-MAS03991	Connection status-Reception level antenna 1	100	 %
MAS04394-MAS04460	Connection status-Validity	valid
MAS04394-MAS08406	Connection status-Network type	HSPA
MAS04394-MAS08407	Connection status-Data connection	not active
MAS04394-MAS08408	Connection status-Number of hours to next event	0
MAS04394-MAS08409	Connection status-Number of minutes to next event	29
MAS04394-MAS08410	Connection status-Number of seconds to next event	58
MAS04394-ENG123307	Connection status-Radio_Cell_Number	79233426
MAS04394-ENG123308	Connection status-TCP_Connection_State	not active
MAS06193-IDE06986	Profile 1-High-voltage battery charge current: maximum value	0	 A
MAS06193-MAS04721	Profile 1-Minimum charge level	0	 %
MAS06193-MAS04722	Profile 1-Maximum charge level	0	 %
MAS06193-MAS08967	Profile 1-Start high voltage charging:Hour	0
MAS06193-MAS08968	Profile 1-Start high voltage charging:Minute	0
MAS06193-MAS08969	Profile 1-End of high voltage charging:Hour	0
MAS06193-MAS08970	Profile 1-End of high voltage charging:Minute	0
MAS06194-IDE06986	Profile 2-High-voltage battery charge current: maximum value	0	 A
MAS06194-MAS04721	Profile 2-Minimum charge level	0	 %
MAS06194-MAS04722	Profile 2-Maximum charge level	0	 %
MAS06194-MAS08967	Profile 2-Start high voltage charging:Hour	0
MAS06194-MAS08968	Profile 2-Start high voltage charging:Minute	0
MAS06194-MAS08969	Profile 2-End of high voltage charging:Hour	0
MAS06194-MAS08970	Profile 2-End of high voltage charging:Minute	0
MAS06195-IDE06986	Profile 3-High-voltage battery charge current: maximum value	0	 A
MAS06195-MAS04721	Profile 3-Minimum charge level	0	 %
MAS06195-MAS04722	Profile 3-Maximum charge level	0	 %
MAS06195-MAS08967	Profile 3-Start high voltage charging:Hour	0
MAS06195-MAS08968	Profile 3-Start high voltage charging:Minute	0
MAS06195-MAS08969	Profile 3-End of high voltage charging:Hour	0
MAS06195-MAS08970	Profile 3-End of high voltage charging:Minute	0
MAS06413	Audio signal output	Electrical OK
MAS08178-IDE02493	Crash information-Automatic door unlocking	No
MAS08178-IDE05253	Crash information-Front crash	No
MAS08178-IDE05254	Crash information-Side crash on driver side	No
MAS08178-IDE05255	Crash information-Side crash on frt.pass.side	No
MAS08178-IDE05256	Crash information-Rear crash	No
MAS08178-IDE05257	Crash information-Rollover crash	No
MAS08178-MAS08636	Crash information-Automatic emergency call activated:Accident sensor	No
MAS08178-MAS08956	Crash information-Automatic emergency call activated:Fuel shut-off	No
MAS08179	List of last telephone numbers
MAS08180	Remote-controlled horn and lights	0	 s
MAS08181-MAS01779	Area restriction configuration-Length	0	 m
MAS08181-MAS01780	Area restriction configuration-Width	0	 m
MAS08181-MAS08775	Area restriction configuration-Calculation frequency	65535	 s
MAS08181-MAS08776	Area restriction configuration-tolerance	65535	 m
MAS08181-MAS08777	Area restriction configuration-Contact bounce suppression	65535	 s
MAS08181-MAS08778	Area restriction configuration-Rotation angle	65535	 °
MAS08181-MAS08779	Area restriction configuration-Zone type	Not available
MAS08181-MAS08780	Area restriction configuration-Area type	rectangle
MAS08183-ENG123274	Event list: horn and lights (ring memory)-Remote Honking Flashing Cycle Data	Unknown
MAS08184-ENG123277	Event list: emergency call(ring memory)-Emergency Call Cycle Data	Unknown
MAS08185-ENG123279	Event list: vehicle shut-down (ring memory)-Remote Vehicle Immobilisation Cycle Data	Unknown
MAS08186-ENG123280	Event list: vehicle location (ring memory)-Vehicle Tracking Cycle Data	Unknown
MAS08187-ENG123281	Event list area restriction (ring memory)-Geofencing Cycle Data	Unknown
MAS08188-ENG123282	Event list: Mobile Online services (ring memory)-Online Service Cycle Data	Unknown
MAS08189-ENG123278	Event list: speed warning (ring memory)-Speed Alert Cycle Data	Unknown
MAS08190-ENG123283	Event list: distance statistics (ring memory)-Remote Trip Statistics Cycle Data	Unknown
MAS08191-ENG123284	Event list: vehicle state (ring memory)-Remote Vehicle Status Cycle Data	Unknown
MAS08192-ENG123298	Event list: info call (ring memory)-Information Call Cycle Data	Unknown
MAS08193-ENG123299	Event list: battery charge management (ring memory)-Remote Battery Charging Management Cycle Data	Unknown
MAS08194-ENG123285	Event list: A/C (ring memory)-Pre Trip Climatisation Cycle Data	Unknown
MAS08195-ENG123300	Event list: departure time (ring memory)-Remote Departure Time Programming Cycle Data	Unknown
MAS08196-ENG123272	Event list: vehicle status report (ring memory)-Vehicle Health Report Cycle Data	Unknown
MAS08197-ENG123273	Event list:roadside assist and maint. schedule(ring memory)-Roadside Assistance Maintenance Scheduling Cycle Data	Unknown
MAS08198-ENG123275	Event lists: imported navigation destinations (bring memory)-POI Address Import Cycle Data	Unknown
MAS08199-ENG123276	Event list: vehicle locking (ring memory)-Remote Door Unlock Cycle Data	Unknown
ENG123206-ENG123337	Antenna_Switch-GPS_Antenna_Switch	external
ENG123206-ENG123336	Antenna_Switch-GSM_Antenna_Switch	external
ENG123207-IDE01588	Calculated_Position_And_Direction_Areal_Update-Driving direction	0	 °
ENG123207-MAS01632	Calculated_Position_And_Direction_Areal_Update-Status	Not available
ENG123207-MAS01779	Calculated_Position_And_Direction_Areal_Update-Length
ENG123207-MAS01780	Calculated_Position_And_Direction_Areal_Update-Width
ENG123207-ENG123297	Calculated_Position_And_Direction_Areal_Update-error_value	0	 m
ENG123208-MAS00106	Geofencing_schedule_start_time-Year	2000
ENG123208-MAS00107	Geofencing_schedule_start_time-Month	0
ENG123208-MAS00108	Geofencing_schedule_start_time-Day	0
ENG123208-MAS00109	Geofencing_schedule_start_time-Hours	0
ENG123208-MAS00110	Geofencing_schedule_start_time-Minutes	0
ENG123208-MAS00111	Geofencing_schedule_start_time-Seconds	0
ENG123209-MAS00106	Geofencing_schedule_stop_time-Year	2000
ENG123209-MAS00107	Geofencing_schedule_stop_time-Month	0
ENG123209-MAS00108	Geofencing_schedule_stop_time-Day	0
ENG123209-MAS00109	Geofencing_schedule_stop_time-Hours	0
ENG123209-MAS00110	Geofencing_schedule_stop_time-Minutes	0
ENG123209-MAS00111	Geofencing_schedule_stop_time-Seconds	0
ENG117867-ENG117773	GPS_Count_Satellite_Phase_Lock_Counter-satellites	255
ENG123212-ENG123347	GPS_Dilution_of_precision-geometric_dilution_of_precision	3292
ENG123212-ENG123346	GPS_Dilution_of_precision-horizontal_dilution_of_precision	4108
ENG123212-ENG123296	GPS_Dilution_of_precision-Initiation	initialized
ENG123212-ENG123348	GPS_Dilution_of_precision-positional_dilution_of_precision	901
ENG123212-ENG123345	GPS_Dilution_of_precision-time_dilution_of_precision	2881
ENG123212-ENG123344	GPS_Dilution_of_precision-vertical_dilution_of_precision	440
ENG117868-ENG117773	GPS_Satellite_Code_Lock_Counter-satellites	255
ENG125913	Hybrid_Type	no_Hybrid_Car
ENG117422	IP_Address	10.97.33.48
ENG117869-IDE01588	Nav._Calculated_Direction-Driving direction	208	 °
ENG117869-MAS01632	Nav._Calculated_Direction-Status	Available
ENG123203-ENG123321	Network_Statistics-CRC_Errors	0
ENG123203-ENG123320	Network_Statistics-DNS_Resolution	46
ENG123203-ENG123324	Network_Statistics-DNS_Resolution_Error	no error
ENG123203-ENG124655	Network_Statistics-Duration_Of_Voice_Calls	0	 min
ENG123203-ENG123319	Network_Statistics-Established_TCP_Connections	17
ENG123203-ENG123326	Network_Statistics-HTTP_Transmission_Error	no error
ENG123203-ENG123317	Network_Statistics-Interrupted_TCP_Connections	0
ENG123203-ENG123323	Network_Statistics-Network_Timeout_Error	no error
ENG123203-ENG123315	Network_Statistics-Number_Of_Events	23
ENG123203-ENG123330	Network_Statistics-Number_Of_Failed_DNS_Requests	0
ENG123203-ENG123332	Network_Statistics-Number_Of_Failed_HTTP_Requests	0
ENG123203-ENG123331	Network_Statistics-Number_Of_Failed_PDP_Connections	12
ENG123203-ENG123333	Network_Statistics-Number_Of_Failed_Secure_Connections	0
ENG123203-ENG123328	Network_Statistics-Number_Of_Failed_Transport_Protocol_Connections	0
ENG123203-ENG123314	Network_Statistics-Number_Of_Jobs	6
ENG123203-ENG123329	Network_Statistics-Number_Of_Network_Timeouts	0
ENG123203-ENG123316	Network_Statistics-Number_Of_Packet_Data_Connection_Failures	24
ENG123203-ENG123311	Network_Statistics-Number_Of_Voice_Calls	0
ENG123203-ENG123325	Network_Statistics-PDP_Connection_Error	no error
ENG123203-ENG123318	Network_Statistics-Rejected_TCP_Connections	0
ENG123203-ENG123334	Network_Statistics-Round_Trip_Time	1	 ms
ENG123203-ENG123327	Network_Statistics-Secure_Connection_Error	no error
ENG123203-ENG123313	Network_Statistics-Service_Data_Volume	6226	 B
ENG123203-ENG123335	Network_Statistics-SMS_Counter	0
ENG123203-ENG123312	Network_Statistics-Total_Data_Volume	147542	 B
ENG123203-ENG123322	Network_Statistics-Transport_Protocol_Connection_Error	no error
ENG123204	Outgoing_call_line_state	Idle
ENG123202	Phone_Register_State	registerstate_registered
ENG129162-ENG98933	Serial_Tracing-Status	not activated
ENG123210-MAS00106	Speed_alert_schedule_start_time-Year	2000
ENG123210-MAS00107	Speed_alert_schedule_start_time-Month	0
ENG123210-MAS00108	Speed_alert_schedule_start_time-Day	0
ENG123210-MAS00109	Speed_alert_schedule_start_time-Hours	0
ENG123210-MAS00110	Speed_alert_schedule_start_time-Minutes	0
ENG123210-MAS00111	Speed_alert_schedule_start_time-Seconds	0
ENG123211-MAS00106	Speed_alert_schedule_stop_time-Year	2000
ENG123211-MAS00107	Speed_alert_schedule_stop_time-Month	0
ENG123211-MAS00108	Speed_alert_schedule_stop_time-Day	0
ENG123211-MAS00109	Speed_alert_schedule_stop_time-Hours	0
ENG123211-MAS00110	Speed_alert_schedule_stop_time-Minutes	0
ENG123211-MAS00111	Speed_alert_schedule_stop_time-Seconds	0
ENG123193-ENG123341	Vehicle_Health_Report-Collection_Period	weekly
ENG123193-ENG123342	Vehicle_Health_Report-Day_at_month_for_report	11
ENG123193-ENG123343	Vehicle_Health_Report-Day_at_week_for_report	Not available
ENG123193-ENG123339	Vehicle_Health_Report-Distance_Based_Distance	0	 km
ENG123193-ENG123338	Vehicle_Health_Report-Distance_Based_Start_Mileage	0	 km
ENG123193-ENG123340	Vehicle_Health_Report-Maintenance_Based_Distance	0	 km
Elapsed Time: 00:23
adpmap-75-5QE-035-285-A.CSV
;Wednesday	11	January	2017	20:19:14:08929
IDE00001-Production mode	00 00 00
IDE00759-Base volume of speech output	0 dB
IDE00760-Microphone sensitivity	0 dB
IDE00761-MAS08397-After-run time-Long term energy budget	3600 mAh
IDE00761-MAS08398-After-run time-Short term energy budget	1000 mAh
IDE00761-MAS08399-After-run time-Waiting period from sleep to standby mode	0 min
IDE00761-MAS08400-After-run time-Waiting period from standby to stop mode	336 H
IDE00761-MAS08950-After-run time-Time period for cyclic stop mode in operating mode	0 min
IDE00761-MAS08951-After-run time-Time period for cyclic standby mode in operating mode	0 min
IDE00761-MAS08952-After-run time-Time period for operating mode	0 d
IDE00761-MAS08953-After-run time-Cyclic time after the operating mode	0 H
IDE00761-MAS08954-After-run time-Connection after T. 15 on	No
IDE00761-MAS08955-After-run time-Time period for connection after T. 15 on	15 min
IDE00766-Reference channel delay	40 ms
IDE00769-Number 1 for Info call	8774193655
IDE00770-Number 1 for roadside assistance	8774193654
IDE02067-Antenna for telephone status	automatic
IDE02330-Number 2 for Info call	8882915686
IDE02699-Number 1 for roadside assistance	8774193653
IDE02700-Number 2 for roadside assistance	8882449108
IDE03481-Emergency telephone number	112
IDE04307-MAS00688-Vehicle function list BAP-Multifunction indicator	activated
IDE04307-MAS02957-Vehicle function list BAP-Time	activated
IDE04307-MAS06654-Vehicle function list BAP-Charge manager	not activated
IDE04478-SMS number 1 for call for help	60000004
IDE07699-Mobile network operator	aprd3.hughestelematics.com.attz
IDE07899-Status of GPS antenna	external
IDE09244-Fuel tank volume	55 l
MAS07461-Vehicle shut-down: maximum speed	5 km/h
MAS07464-Waiting period for activation vehicle shutdown	30 s
MAS07465-Safety mode for activation vehicle shutdown	activated
MAS07466-Safety mode for deactivation vehicle shutdown	not activated
MAS07467-Speed warning maximum speed	0 km/h
MAS08170-User profile name	none
MAS08171-User profile password	none
MAS08172-Mobile Online services: first host name	vw.us.p.tos.hughestelematics.net
MAS08173-Mobile Online services: second host name	vw.us.p.tos.hughestelematics.net
MAS08174-Fallback DNS Server	0.0.0.0
MAS08175-IDE02634-Mobile Online services: activation threshold-Lock time during deactivation	0 min
MAS08175-MAS07123-Mobile Online services: activation threshold-Distance for activation	5 km
MAS08176-Test tel. number for roadside assistance	0
MAS08177-Acoustic warning for vehicle shut-down	activated
MAS08981-ENG101574-Dimming charac. curve of red function illumination-X1	0
MAS08981-ENG99557-Dimming charac. curve of red function illumination-X2	10
MAS08981-ENG102140-Dimming charac. curve of red function illumination-X3	50
MAS08981-ENG102936-Dimming charac. curve of red function illumination-X4	100
MAS08981-ENG103548-Dimming charac. curve of red function illumination-X5	150
MAS08981-ENG113992-Dimming charac. curve of red function illumination-X6	253
MAS08981-ENG99777-Dimming charac. curve of red function illumination-Y1	1%
MAS08981-ENG100480-Dimming charac. curve of red function illumination-Y2	1%
MAS08981-ENG100773-Dimming charac. curve of red function illumination-Y3	2%
MAS08981-ENG100631-Dimming charac. curve of red function illumination-Y4	4%
MAS08981-ENG102174-Dimming charac. curve of red function illumination-Y5	80%
MAS08981-ENG113993-Dimming charac. curve of red function illumination-Y6	100%
MAS08982-ENG101574-Dimming charac. curve of green function illumination-X1	0
MAS08982-ENG99557-Dimming charac. curve of green function illumination-X2	10
MAS08982-ENG102140-Dimming charac. curve of green function illumination-X3	50
MAS08982-ENG102936-Dimming charac. curve of green function illumination-X4	100
MAS08982-ENG103548-Dimming charac. curve of green function illumination-X5	150
MAS08982-ENG113992-Dimming charac. curve of green function illumination-X6	253
MAS08982-ENG99777-Dimming charac. curve of green function illumination-Y1	1%
MAS08982-ENG100480-Dimming charac. curve of green function illumination-Y2	1%
MAS08982-ENG100773-Dimming charac. curve of green function illumination-Y3	2%
MAS08982-ENG100631-Dimming charac. curve of green function illumination-Y4	4%
MAS08982-ENG102174-Dimming charac. curve of green function illumination-Y5	80%
MAS08982-ENG113993-Dimming charac. curve of green function illumination-Y6	100%
MAS08983-Dimming coefficient of red function illumination	50%
MAS08984-Dimming coefficient of green function illumination	50%
MAS09650-Threshold for vehicle movement recognition	5 km/h
ENG123201-ENG123295-Cycle_Data_Log_Level-Automatic_Crash_Notification	ERROR
ENG123201-ENG123362-Cycle_Data_Log_Level-Core_Service_Management	ERROR
ENG123201-ENG123286-Cycle_Data_Log_Level-Geofencing	ERROR
ENG123201-ENG123294-Cycle_Data_Log_Level-Information_Call	ERROR
ENG123201-ENG123186-Cycle_Data_Log_Level-Manual_Emergency_Call	ERROR
ENG123201-ENG123288-Cycle_Data_Log_Level-POI_Address_Import	ERROR
ENG123201-ENG123215-Cycle_Data_Log_Level-Remote_Battery_Charging_Management	ERROR
ENG123201-ENG123293-Cycle_Data_Log_Level-Remote_Departure_Time_Programming	ERROR
ENG123201-ENG123287-Cycle_Data_Log_Level-Remote_Door_Unlock	ERROR
ENG123201-ENG123216-Cycle_Data_Log_Level-Remote_Honking_and_Flashing	ERROR
ENG123201-ENG123214-Cycle_Data_Log_Level-Remote_Pre_Trip_Climatisation	ERROR
ENG123201-ENG123289-Cycle_Data_Log_Level-Remote_Speed_Alert	ERROR
ENG123201-ENG123292-Cycle_Data_Log_Level-Remote_Trip_Statistics	ERROR
ENG123201-ENG123290-Cycle_Data_Log_Level-Remote_Vehicle_Disabling	ERROR
ENG123201-ENG123183-Cycle_Data_Log_Level-Remote_Vehicle_Status	ERROR
ENG123201-ENG123291-Cycle_Data_Log_Level-Remote_Vehicle_Tracking	ERROR
ENG123201-ENG123371-Cycle_Data_Log_Level-Roadside_Assistance_Dealer_Maintenance_Scheduling	ERROR
ENG123201-ENG123193-Cycle_Data_Log_Level-Vehicle_Health_Report	ERROR
ENG123200-Driving_Follow_Up_Time	5 min
ENG123199-Emergency_Call_Trigger_Condition	crash_intensity_2
ENG123187-MAS01424-Geofencing_Area_First_Radius-Maximum value	4294967294 m
ENG123187-MAS01425-Geofencing_Area_First_Radius-Minimum value	1 m
ENG123190-MAS01424-Geofencing_Area_Highth-Maximum value	4294967294 m
ENG123190-MAS01425-Geofencing_Area_Highth-Minimum value	1 m
ENG123192-MAS01424-Geofencing_Area_Latitude-Maximum value	+2.147.483.647
ENG123192-MAS01425-Geofencing_Area_Latitude-Minimum value	-2.147.483.648
ENG123191-MAS01424-Geofencing_Area_Longitude-Maximum value	+2.147.483.647
ENG123191-MAS01425-Geofencing_Area_Longitude-Minimum value	-2.147.483.648
ENG123188-MAS01424-Geofencing_Area_Second_Radius-Maximum value	4294967294 m
ENG123188-MAS01425-Geofencing_Area_Second_Radius-Minimum value	1 m
ENG123189-MAS01424-Geofencing_Area_Width-Maximum value	4294967294 m
ENG123189-MAS01425-Geofencing_Area_Width-Minimum value	1 m
ENG123186-ENG123304-Manual_Emergency_Call-Radio_On_Trigger	On
ENG123186-ENG123305-Manual_Emergency_Call-Vehicle_Termination	On
ENG125481-Number_Of_Navigation_Destinations	20
ENG123194-ENG123349-Online_Services_Communication_Protocol-APN_Auth_Type	PAP_CHAP
ENG123194-ENG123350-Online_Services_Communication_Protocol-GSM_Automatic_Operator	manual
ENG123194-ENG123354-Online_Services_Communication_Protocol-Keep_Connection_Alive_If_Event_Expected_Within	10 min
ENG123194-ENG123356-Online_Services_Communication_Protocol-PDP_Grace_Time	120 s
ENG123194-ENG123351-Online_Services_Communication_Protocol-PDP_Type	IPv4
ENG123194-ENG123352-Online_Services_Communication_Protocol-TCP_Max_Receive_Window	65535 B
ENG123194-ENG123353-Online_Services_Communication_Protocol-TCP_Max_Transmit_Window	65535 B
ENG123194-ENG123355-Online_Services_Communication_Protocol-TCPMS	532 B
ENG123196-ENG123362-Online_Services_Data_Roaming-Core_Service_Management	activated
ENG123196-ENG125484-Online_Services_Data_Roaming-Core_Service_Telephony	activated
ENG123196-ENG123286-Online_Services_Data_Roaming-Geofencing	activated
ENG123196-ENG125485-Online_Services_Data_Roaming-JobMechanism	activated
ENG123196-ENG123288-Online_Services_Data_Roaming-POI_Address_Import	activated
ENG123196-ENG123215-Online_Services_Data_Roaming-Remote_Battery_Charging_Management	activated
ENG123196-ENG123293-Online_Services_Data_Roaming-Remote_Departure_Time_Programming	activated
ENG123196-ENG123287-Online_Services_Data_Roaming-Remote_Door_Unlock	activated
ENG123196-ENG123216-Online_Services_Data_Roaming-Remote_Honking_and_Flashing	activated
ENG123196-ENG123214-Online_Services_Data_Roaming-Remote_Pre_Trip_Climatisation	activated
ENG123196-ENG123289-Online_Services_Data_Roaming-Remote_Speed_Alert	activated
ENG123196-ENG123292-Online_Services_Data_Roaming-Remote_Trip_Statistics	activated
ENG123196-ENG123290-Online_Services_Data_Roaming-Remote_Vehicle_Disabling	activated
ENG123196-ENG123183-Online_Services_Data_Roaming-Remote_Vehicle_Status	activated
ENG123196-ENG123291-Online_Services_Data_Roaming-Remote_Vehicle_Tracking	activated
ENG123196-ENG123363-Online_Services_Data_Roaming-Roadside_Assistance	activated
ENG123196-ENG123193-Online_Services_Data_Roaming-Vehicle_Health_Report	activated
ENG123195-ENG123358-Online_Services_Timeouts-HTTP_Timeout	125 s
ENG123195-ENG123361-Online_Services_Timeouts-Network_Timeout	120 s
ENG123195-ENG123360-Online_Services_Timeouts-PDP_Timeout	120 s
ENG123195-ENG123359-Online_Services_Timeouts-Secure_Connection_Timeout	120 s
ENG123195-ENG123357-Online_Services_Timeouts-Transport_Protocol_Timeout	120 s
ENG123197-Online_Services_Voice_Roaming	activated
ENG123185-IDE00301-Pearl_Chain_Generation_Criteria-Distance	500 m
ENG123185-MAS00156-Pearl_Chain_Generation_Criteria-Driving direction	30 °
ENG123185-MAS01456-Pearl_Chain_Generation_Criteria-Speed	30 km/h
ENG123185-MAS02230-Pearl_Chain_Generation_Criteria-Height	50 m
ENG123185-MAS05076-Pearl_Chain_Generation_Criteria-Time	60 s
ENG123185-ENG123306-Pearl_Chain_Generation_Criteria-Debounce	10 m
ENG123183-ENG123302-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_Off_Delay	60 s
ENG123183-ENG123301-Remote_Vehicle_Status-Remote_Vehicle_Status_Clamp_15_On_Delay	1275 s
ENG125482-MAS01424-Remote_Vehicle_Tracking_Mileage_Trigger-Maximum value	65535 m
ENG125482-MAS01425-Remote_Vehicle_Tracking_Mileage_Trigger-Minimum value	0 m
ENG125483-MAS01424-Remote_Vehicle_Tracking_Time_Trigger-Maximum value	65535 s
ENG125483-MAS01425-Remote_Vehicle_Tracking_Time_Trigger-Minimum value	0 s
ENG123184-Roof_Crash_Detection_Speed_Limit	30 km/h
ENG129162-Serial_Tracing
ENG123193-Vehicle_Health_Report	15000 km
ENG123198-ENG123365-Voice_Connection_Timeouts-Call_Failed_Timer	10 s
ENG123198-ENG123368-Voice_Connection_Timeouts-Redial_ACN_MEC_If_Failed	Yes
ENG123198-ENG123367-Voice_Connection_Timeouts-Redial_Attempts	6
ENG123198-ENG123369-Voice_Connection_Timeouts-Redial_Timer	2 s
ENG123198-ENG123370-Voice_Connection_Timeouts-Voice_Data_Transfer_Failed_Timer	15 s
ENG123198-ENG123366-Voice_Connection_Timeouts-Wait_Tone_Timer	30 s
Elapsed Time: 00:54
A5-Frt Sens. Drv. Assist
blockmap-A5-3Q0-980-654-G.CSV
;SW:3Q0-980-654-G   HW:3Q0-980-654 ---  Frt Sens. Drv. Assist
;Component:MQB_B_MFK     H06 0231	 Coding:000307020002020100221344C040490084000E100020
;EV_MFKBoschMQBB	1001	EV_MFKBoschMQBB.rod
;Wednesday	11	January	2017	20:20:31:08929
;VCID: BB3934493247C19940-80EE
IDE00018	Voltage terminal 15	12.7	 V
IDE00030	Status of actuator test	not active
IDE00102	Control Module temperature	34	 °C
IDE00322	Status of basic setting	not active
IDE00326-MAS02471	Steering wheel angle-Sign	Negative
IDE00326	Steering wheel angle	0	 °
IDE00767	No. of unscheduled ECU resets	3
IDE00925-MAS02471	Yaw rate-Sign	Positive
IDE00925	Yaw rate	0	 °/s
IDE00973	Outside air temperature	7.5	 °C
IDE01968	Dynamic calibration: yaw angle offset	0.464	 °
IDE01969	Dynamic calibration: pitch angle offset	0.751	 °
IDE01970	Dynamic calibration: roll angle offset	-0.429	 °
IDE01971	Lowest recorded control module temperature	-10	 °C
IDE01972	Highest recorded control module temperature	56	 °C
IDE02057	Dynamic calibration: status	Passive values stored
IDE02486	Data logger triggering	not active
IDE03222-MAS02534	Blindness detection-Clear view	No
IDE03222-MAS03365	Blindness detection-Blind vehicle detection during darkness	No
IDE03222-MAS03366	Blindness detection-Blind traffic sign detection	No
IDE03222-MAS03399	Blindness detection-Blindness automatic distance control	No
IDE03222-MAS09886	Blindness detection-Blind during pedestrian recognition	No
IDE03222-MAS09887	Blindness detection-Blind during object recognition	No
IDE03222-MAS09888	Blindness detection-Blind during lane recognition	No
IDE03222-MAS10690	Blindness detection-Activation condition	activated
IDE03222-MAS11902	Blindness detection-Blind DTC memory entry	No
IDE03222-MAS11936	Blindness detection-Causes of blindness	Fuzziness/Diffusion
IDE03222-MAS11937	Blindness detection-Pixel failure	0	 %
IDE03222-MAS11949	Blindness detection-Windshield heater blindness	Yes
IDE03354-MAS01632	Dynamic calibration: details-Status	No calibration relevant malfunction
IDE03354-MAS02552	Dynamic calibration: details-Distance traveled with active dynamic calibration	25	 km
IDE04036	High beam assistant: status	not active
IDE04037	High beam recommendation	OFF
IDE04123	High beam: reason for shut-off	4
IDE04125	Visibility	Not Used
IDE06425-IDE02766	Roller test bench mode: functional-Malfunction status	no error
IDE06425-MAS06026	Roller test bench mode: functional-Activation stages	not activated
IDE07214	Dynamic calibration: camera height offset	0	 mm
IDE09424	Number of recognized lane markings	0
IDE09433-MAS01632	Perception module for light assistant-Status	passive
IDE09433-MAS08885	Perception module for light assistant-Object 1 removal	1	 m
IDE09433-MAS08886	Perception module for light assistant-Object 2 removal	1	 m
IDE09433-MAS08887	Perception module for light assistant-Object 1 horizontal position	-25.4	 °
IDE09433-MAS08888	Perception module for light assistant-Object 2 horizontal position	-25.4	 °
IDE09433-MAS08889	Perception module for light assistant-Object 1 vertical position	-16	 °
IDE09433-MAS08890	Perception module for light assistant-Object 2 vertical position	-16	 °
IDE09433-MAS08891	Perception module for light assistant-Object 1 horizontal expansion	0	 °
IDE09433-MAS08892	Perception module for light assistant-Object 2 horizontal expansion	0	 °
IDE09433-MAS08893	Perception module for light assistant-Object 1 ID	0
IDE09433-MAS08894	Perception module for light assistant-Object 2 ID	0
IDE09433-MAS08895	Perception module for light assistant-Object 1 replacement value	No
IDE09433-MAS08896	Perception module for light assistant-Object 2 replacement value	No
IDE09433-MAS08897	Perception module for light assistant-Object 1 horizontal quality left	0	 °
IDE09433-MAS08898	Perception module for light assistant-Object 2 horizontal quality left	0	 °
IDE09433-MAS08899	Perception module for light assistant-Object 1 horizontal quality right	0	 °
IDE09433-MAS08900	Perception module for light assistant-Object 2 horizontal quality right	0	 °
IDE09433-MAS08901	Perception module for light assistant-Object 1 vertical quality	0	 °
IDE09433-MAS08902	Perception module for light assistant-Object 2 vertical quality	0	 °
IDE09433-MAS08903	Perception module for light assistant-Object 1 Object type	No object
IDE09433-MAS08904	Perception module for light assistant-Object 2 Object type	No object
IDE09433-MAS08905	Perception module for light assistant-Object 1 Object quality	<= 50%
IDE09433-MAS08906	Perception module for light assistant-Object 2 Object quality	<= 50%
IDE09433-MAS08907	Perception module for light assistant-Cause for passive switching	Ambient brightness too high
IDE09436	Recognized street illumination	Not available
IDE09438	Drive sequence	Left hand driv.
IDE10220	Initial online calibration active	not active
IDE10398-MAS10691	Self-glare-Self-glare quality	0	 %
IDE10398-MAS11502	Self-glare-Self-glare recognition	No
IDE10398-MAS11503	Self-glare-Self-glare status	not active
IDE10403	Current initial calibration: status	Initial static calibration KD OK.
IDE10404-MAS10704	Dynamic calibration: quality-Dynamic calibration: yaw angle offset quality	1
IDE10404-MAS10705	Dynamic calibration: quality-Dynamic calibration: pitch angle offset quality	1
IDE10404-MAS10706	Dynamic calibration: quality-Dynamic calibration: roll angle offset quality	1
IDE10404-MAS10707	Dynamic calibration: quality-Dynamic calibration: camera height offset quality	1
IDE10405-MAS10708	Initial dynamic calibration: details-Initial dynamic calibration: roll angle	-0.075	 °
IDE10405-MAS10709	Initial dynamic calibration: details-Initial dynamic calibration: roll angle quality	1
IDE10405-MAS10710	Initial dynamic calibration: details-Initial dynamic calibration: pitch angle	-1.193	 °
IDE10405-MAS10711	Initial dynamic calibration: details-Initial dynamic calibration: pitch angle quality	1
IDE10405-MAS10712	Initial dynamic calibration: details-Initial dynamic calibration: yaw angle	-0.697	 °
IDE10405-MAS10713	Initial dynamic calibration: details-Initial dynamic calibration: yaw angle quality	1
IDE10405-MAS10714	Initial dynamic calibration: details-Initial dynamic calibration: Camera height	1374	 mm
IDE10405-MAS10715	Initial dynamic calibration: details-Initial dynamic calibration: Camera height quality	1
IDE10405-MAS10716	Initial dynamic calibration: details-Distance traveled with active initial calibration	0	 m
IDE10406-MAS10994	Last initial calibrations: details-Last initial calibration: error code	No calibration relevant malfunction
IDE10406-MAS10995	Last initial calibrations: details-Penultimate initial calibration: error code	No calibration relevant malfunction
IDE10406-MAS10996	Last initial calibrations: details-Third-to-last initial calibration: error code	Calibration not yet performed
IDE10406-MAS10997	Last initial calibrations: details-Fourth-to-last initial calibration: error code	Calibration not yet performed
IDE10547	Status of camera	Camera operating
IDE10664-MAS00106	Current initial calibration: details-Year	2011
IDE10664-MAS00107	Current initial calibration: details-Month	1
IDE10664-MAS00108	Current initial calibration: details-Day	1
IDE10664-MAS00109	Current initial calibration: details-Hours	1
IDE10664-MAS00110	Current initial calibration: details-Minutes	58
IDE10664-MAS00111	Current initial calibration: details-Seconds	18
IDE10664-MAS00711	Current initial calibration: details-Odometer reading	0
IDE10664-MAS01632	Current initial calibration: details-Status	No calibration relevant malfunction
IDE10664-MAS02541	Current initial calibration: details-Rear projection fault	0
IDE10664-MAS02542	Current initial calibration: details-Calibration marks	100001
IDE10664-MAS02543	Current initial calibration: details-VIN determined during calibration	3VWH17AU6HM508859
IDE10664-MAS03010	Current initial calibration: details-Focal length	1384
IDE10664-MAS03075	Current initial calibration: details-Calibration point X coordinates on imaging sensor	645
IDE10664-MAS03076	Current initial calibration: details-Calibration point Y coordinates on imaging sensor	362
IDE10664	Current initial calibration: details	111111
IDE10664	Current initial calibration: details	110011
IDE11956	Version des Bootmanagers	10
MAS00464	Standard - ambient data 1	2017
MAS00464	Standard - ambient data 1	8
ENG130818-MAS01505	Windscreen_heater_camera-Engine off	Yes
ENG130818-MAS02374	Windscreen_heater_camera-System malfunction	no error
ENG130818-MAS03849	Windscreen_heater_camera-Crash signal	not active
ENG130818-ENG120256	Windscreen_heater_camera-par_Actuator_test	not active
ENG130818-ENG120266	Windscreen_heater_camera-par_Ambient_temperature_too_low	No
ENG130818-ENG120257	Windscreen_heater_camera-par_Blindness_activation	active
ENG130818-ENG120260	Windscreen_heater_camera-par_camera_temperature_too_high	No
ENG130818-ENG120258	Windscreen_heater_camera-par_condensation_danger_activation	active
ENG130818-ENG120268	Windscreen_heater_camera-par_current_windscreen_heater	0	 A
ENG130818-ENG120265	Windscreen_heater_camera-par_Heating_time_exceeded	No
ENG130818-ENG120259	Windscreen_heater_camera-par_initial_heating	not active
ENG130818-ENG130881	Windscreen_heater_camera-par_preventive_heating	not active
ENG130818-ENG120264	Windscreen_heater_camera-par_Windscreenheater_error	not active
ENG130818-ENG101577	Windscreen_heater_camera-Windscreen_heater_state_of_activation	not active
Elapsed Time: 00:46
adpmap-A5-3Q0-980-654-G.CSV
;Wednesday	11	January	2017	20:21:18:08929
IDE00001-Production mode	Deactivating
IDE00820-ENG130919-Activating and deactivating all development messages-Activation_of_development_messages_EHR	not activated
IDE00820-ENG130920-Activating and deactivating all development messages-Activation_of_development_messages_HCA_lane	not activated
IDE00820-ENG130921-Activating and deactivating all development messages-Activation_of_development_messages_HCA_state	not activated
IDE00820-ENG130922-Activating and deactivating all development messages-Activation_of_development_messages_internal	not activated
IDE00820-ENG130916-Activating and deactivating all development messages-Activation_of_development_messages_lane	not activated
IDE00820-ENG130915-Activating and deactivating all development messages-Activation_of_development_messages_reserved	not activated
IDE00820-ENG130918-Activating and deactivating all development messages-Activation_of_development_messages_VZF/TSR	not activated
IDE00820-ENG130917-Activating and deactivating all development messages-Activation_of_development_messages_WLA	not activated
IDE02332-Deactivate production mode	0
IDE04160-Direct. stab. assist speed threshold during towing mode	300 km/h
IDE04733-Road sign detection fusion mode	Road sign fusion
IDE06425-Roller test bench mode: functional	not activated
IDE07358-Distance to calibration field	2400 mm
IDE09375-IDE05717-Axle offset-Front axle transverse position	0.300006 mm
IDE09375-IDE05718-Axle offset-Rear axle transverse position	-1.59999 mm
IDE09376-IDE02001-Body height wheel house edge-Body height left front wheel house edge	713 mm
IDE09376-IDE02002-Body height wheel house edge-Body height right front wheel house edge	717.5 mm
IDE09376-IDE02003-Body height wheel house edge-Body height left rear wheel house edge	728.5 mm
IDE09376-IDE02004-Body height wheel house edge-Body height right rear wheel house edge	729.5 mm
IDE09391-MAS08824-Calibration target position-Target 1: calibration mark 1: x-coordinate	2400 mm
IDE09391-MAS08825-Calibration target position-Target 1: calibration mark 1: y-coordinate	733 mm
IDE09391-MAS08826-Calibration target position-Target 1: calibration mark 1: z-coordinate	1493 mm
IDE09391-MAS08827-Calibration target position-Target 1: calibration mark 2: x-coordinate	2336 mm
IDE09391-MAS08828-Calibration target position-Target 1: calibration mark 2: y-coordinate	-733 mm
IDE09391-MAS08829-Calibration target position-Target 1: calibration mark 2: z-coordinate	1493 mm
IDE09391-MAS08830-Calibration target position-Target 1: calibration mark 3: x-coordinate	2400 mm
IDE09391-MAS08831-Calibration target position-Target 1: calibration mark 3: y-coordinate	-733 mm
IDE09391-MAS08832-Calibration target position-Target 1: calibration mark 3: z-coordinate	907 mm
IDE09391-MAS08833-Calibration target position-Target 1: calibration mark 4: x-coordinate	2400 mm
IDE09391-MAS08834-Calibration target position-Target 1: calibration mark 4: y-coordinate	733 mm
IDE09391-MAS08835-Calibration target position-Target 1: calibration mark 4: z-coordinate	907 mm
IDE10407-Personalization of intervention moment at T. 15 on	Last setting
IDE10870-Switch-on condition: lane depart. warn.	on (setting via menu)
IDE10871-System mode: lane depart. warn:	Steering wheel vibration not active
IDE10872-Warning intensity: lane depart. warning	Medium
IDE10873-BAP personalization	activated
IDE10924-MAS02479-Initial calibration: result-Yaw angle	-0.697 °
IDE10924-MAS05286-Initial calibration: result-Roll angle	-0.075 °
IDE10924-MAS05287-Initial calibration: result-Pitch angle	-1.193 °
IDE10924-MAS10678-Initial calibration: result-Camera height	1374 mm
ENG130776-ENG130840-Adaptation_tsr-Par_country_code_RSR	0
ENG130776-ENG130841-Adaptation_tsr-Par_country_code_VZF	0
ENG130776-ENG130838-Adaptation_tsr-Par_country_mode	automatic
ENG130776-ENG130839-Adaptation_tsr-Par_relevance_mode	Enabled
ENG120319-Mask_error_reactions_for_development	not activated
ENG107577-ENG107577-Masked_fault_classes-	255
ENG130777-standstill_mode	not activated
ENG130781-ENG130836-WLA_adjustment-BrightnessThreshold_active	12.8
ENG130781-ENG130837-WLA_adjustment-BrightnessThreshold_passive	0
ENG130779-Xcp_interface	not activated
Elapsed Time: 00:08
