Unable to pair existing remotes to cars
Mac
C?ID=208817
Car lost battery voltage and now remotes don't work. I am using Wiki video procedure to Pair/Synchronize the Remote key on 2 different cars. Unable to save adaptation values for channel 21 Comfort Module (46). Tried both VCDS mobile and VCDS via browser on laptop. All the steps work until you are supposed to press the remote button after putting in a new remote location value. At this point you are supposed to click the remote button and Field 3 should change from Adjustment to Recognized. Nothing happens. If I click save and re-read Channel 21, I get the original un-synched values of "0" and "Adjustment".
It might be useful if you told us exactly what kind of car you're working on there. ;)
Mac
C?ID=208817
Mea Culpa. 2005 Audi A4, 2005 Audi S4. No fault codes stored after clearing.
Original Scan for 1 car when it arrived
VCDS Mobile 0.4012.0.4
Chassis Type:8E
Scan:
	 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
	 69 75 76 77
VIN: WAULC68EX5A081353
Address 01: Engine	Labels:06B-909-518-AMB.lbl
	Part Number SW: 8E0-909-518-BC	HW: 8E0909018A
	Component: 1.8L R4/5VT     G    0010
	Revision: 00000000	Serial Number: AUZ6Z0D0330788
	Coding: 0016751
	Shop #: WSC 06335 000 00000
	VCID: 72A749CB3DBB30FA038D5
16684 - Random/Multiple Cylinder Misfire Detected
	P0300 - 001 - Upper Limit Exceeded - MIL ON
16685 - Cylinder 1
	P0301 - 001 - Misfire Detected - MIL ON
Address 02: Auto Trans	Labels:01V-927-156.lbl
	Part Number SW: 8E0-927-156-AA
	Component: AG5 01V 1.8l5VT USA  0404
	Coding: 0001002
	VCID: 6D9D5AB72485EF02DEBFE
No fault codes found.
Address 03: ABS Brakes	Labels:8E0-614-517.lbl
	Part Number SW: 8E0-614-517-A
	Component: ABS/ESP allrad      45290
	Coding: 04277
	Shop #: WSC 06435 000
	VCID: 260F659BC1F30C5A5F859
	35-10 -  -  - Intermittent
Address 08: Auto HVAC	Labels:8E0-820-043.lbl
	Part Number SW: 8E0-820-043-AD
	Component:   A4 Klimaautomat   1424
	Coding: 00000
	VCID: 63893C8FF241B972781B8
Address 09: Cent. Elect.	Labels:8E0-907-279-8E2.lbl
	Part Number SW: 8E0-907-279-F
	Component: int. Lastmodul  RDW 0517
	Coding: 00011
	Shop #: WSC 00000 000
	VCID: 352DB2D70C5577C2E6EF6
01800 - Light Switch (E1)
	27-00 - Implausible Signal
01794 - Control Module - Incorrect Chassis (VIN) Number
	35-00 -  -
01326 - Control Module for Multi-Function Steering Wheel (J453)
	79-10 - Please Check Fault Codes - Intermittent
Address 15: Airbags	Labels:8E0-959-655-84.lbl
	Part Number SW: 8E0-959-655-K
	Component: Airbag 8.4EP         1001
	Coding: 0010607
	VCID: 3FC1D0FF3E69AD923C834
Address 16: Steering wheel	Labels:8E0-953-549.lbl
	Part Number SW: 8E0-953-549-N
	Component: Lenksäulenmodul     0611
	Coding: 01041
	VCID: 3E3FADFB3963B49A37951
Address 17: Instruments	Labels:8E0-920-9xx-8E2.lbl
	Part Number SW: 8E0-920-950-P
	Component: KOMBI+WEGFAHRS. RB4 D42
	Coding: 01231
	Shop #: WSC 05136 000
	VCID: 362FB5DB11537CDAEFE59
	Subsystem 1 - 	Part Number: WAU-LC6-8EX-5A0
	Component: 81353     AUZ6Z0D0330788
01304 - Radio
	49-00 - No Communications
Address 46: Central Conv.	Labels:8E0-959-433-MAX.lbl
	Part Number SW: 8E0-959-433-BB
	Component: Komfortgerät T7B    1311
	Coding: 11788
	Shop #: WSC 63351 000
	VCID: 72A749CB3DBB20FA038D5
	Subsystem 1 - 	Part Number: 8E1-959-801
	Component:    Türsteuer.FS BRM 0205
9 Faults Found:
00962 - Alarm via. Tilt Sensor
	35-00 -  -
01369 - Alarm triggered by Hood Switch
	35-00 -  -
01374 - Alarm triggered by Terminal 15
	35-00 -  -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
	35-00 -  -
Address 55: Xenon Range	Labels:4Z7-907-357.lbl
	Part Number SW: 4Z7-907-357
	Component: dynamische LWR       D09
	Coding: 00060
	VCID: 044B1F13170F1D4A21D13
While looking at measuring values group 007 in your comfort module, press various buttons on the remote. Does anything change?
Mac
C?ID=208817
Yes. For each button on the remote it displays 1,2 or 3 depending on lock, unlock and trunk.
Mac
C?ID=208817
Yes I tried the special procedure. No response from the locks or lights.
What exactly happened originally when you said, "Car lost battery voltage" ?
I'm thinking the next thing I would try is to cold-boot the comfort module. That means removing all power from it for a while, either by disconnecting it from the car's harness, pulling the appropriate fuses, or disconnecting the car's battery for a while.
Mac
C?ID=208817
Cold reboot done. No change. I am thinking this has to be something in the scan tool software. I will try a different scan tool on one of the cars. I will post the results.
Mac, did Andy talk you through doing a "Feature Update" today and is your HEX-NET working correctly with VCDS yet?
Mac
C?ID=208817
Hex Net is working via Mobile VCDS and VCDS beta application on the laptop is not working, I am only able to access the Hex Net via a browser. I will try the feature update tomorrow. I used another scan tool and the key remote synced right away. There is definitely something with the software coding that needs to be looked at. Let me know what additional information I can provide to help resolve this glitch, I have another vehicle I can test and program.
OK, thanks for the (apparent) bug report.
Andy
Sector 7G
HC424490
Just to close the loop on one portion of this, Mac reported that the problem of not being able to use VCDS Beta with his HEX-NET has been fixed. We will try to reproduce the remote matching behavior soon.
