VW Touran MY2005 G85 and limit stops adaption problem
MartinsX
Riga, Latvia
C?ID=268515
This Touran went to me with no start condition. A lot of several faults codes were stored and mainly all engine related faults were because of damaged wiring loom in front part of engine compartment. Wires were repaired and faults are gone, engine starts and runs normally. Now one problem left - G85 and steering limit stops don't want to adapt. I have tried both procedures, described in Wiki (through address 03 and through 44), no results. Steering angle in MVB is not changing when turning steering wheel.
I have out of ideas at the moment.
First autoscan before any repairs:
Friday,06,January,2017,10:52:45:32442
VCDS Version: 16.8.4.2
VIN: WVGZZZ1TZ5W120530   License Plate:
Chassis Type: 1T (1K0)
Scan: 01 03 08 09 15 16 17 18 19 25 42 44 46 52 56
VIN: WVGZZZ1TZ5W120530   Mileage: 333530km-207245miles
44-Steering Assist -- Status: Malfunction 1010
46-Central Conv. -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 HP    HW: 028 101 236 1
   Component: R4 1,9L EDC G000SG  7000
   Revision: 12345678    Serial number: VWZ7Z0D1240850
   Coding: 0000072
   Shop #: WSC 01324 785 00200
   VCID: 78FF82DF0BADF182F1-802C
18080 - Coolant Fan Control 1
            P1672 - 000 - Open or Short to Ground - Intermittent
                    RPM: 798 /min
                    Torque: 44.0 Nm
                    Voltage: 14.29 V
                    Bin. Bits: 00001000
                    Temperature: 38.7°C
                    Duty Cycle: 9.6 %
18359 - Radiator Fan 2 (V177)
            P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    RPM: 1449 /min
                    Torque: 128.0 Nm
                    Load: 69.0 %
                    Voltage: 14.44 V
                    Bin. Bits: 00001000
                    Temperature: 39.6°C
                    Duty Cycle: 9.6 %
16785 - EGR System
            P0401 - 000 - Insufficient Flow
                    RPM: 1680 /min
                    Torque: 66.0 Nm
                    Speed: 13.0 km/h
                    Load: 22.0 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 00001000
                    Mass Air / Rev.: 290.0 mg/str
                    Mass Air / Rev.: 605.0 mg/str
16705 - Engine Speed Sensor (G28)
            P0321 - 000 - Implausible Signal - Intermittent
                    RPM: 1890 /min
                    Torque: 28.0 Nm
                    Speed: 41.0 km/h
                    Load: 12.2 %
                    Voltage: 14.52 V
                    Bin. Bits: 00001000
                    Idle Stabilization: 0.0°KW
                    RPM: 924 /min
16725 - Camshaft Position Sensor (G40)
            P0341 - 000 - Implausible Signal
                    RPM: 1260 /min
                    Torque: 154.0 Nm
                    Load: 94.5 %
                    Voltage: 11.48 V
                    Bin. Bits: 00001100
                    (no units): 38.0
Readiness: 1 2 0 0 0
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0021190
   VCID: 3A7B58D775212392C7-806E
   Part No: 1K0 820 047 EF
   Component: Climatic PQ35   084 0404
   VCID: 6CD7AE8F4FF54D2205-8038
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 1K0 937 049 M    HW: 1K0 937 049 M*
   Component: Bordnetz-SG     H34 0803
   Revision: 00H34000    Serial number: 00000001330612
   Coding: 00890F020004100000120C000000000000087B075C
   VCID: 397947DB7027288ACE-806C
   Subsystem 1 - Part No: 2K1 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
Address 15: Airbags        Labels: 1T0-909-605.lbl
   Part No SW: 1T0 909 605 C    HW: 1T0 909 605 C
   Component: 02 AIRBAG VW62 0506 1500
   Revision: 09025000    Serial number: 0038BD0B31LS
   Coding: 0012338
   VCID: 35614BEB5C3FCCEA2A-8060
   Part No SW: 1K0 953 549 F    HW: 1K0 953 549 F
   Component: Lenksaulenmodul 021 0050
   Coding: 0000042
   Part No: 1T0 920 861 A
   Component: KOMBIINSTRUMENT VDD 0814
   Coding: 0003103
   Shop #: WSC 00867 461 89045
   VCID: 306F7AFFA35DE9C279-8064
   Part No: 1K0 815 071 P
   Component: Zuheizer        031 1312
   Revision:        A    Serial number: 09010046
   Coding: 0000011
   VCID: 326B70F7AD51DBD20F-8066
                    Reset counter: 30
                    Mileage: 508945 km
                    Time: 16:14:23
                    Reset counter: 69
                    Mileage: 463729 km
                    Time: 16:04:38
                    Reset counter: 30
                    Mileage: 508945 km
                    Time: 16:14:23
00664 - Fuel gauge
                    Reset counter: 0
                    Mileage: 462756 km
                    Time: 17:06:13
                    Reset counter: 30
                    Mileage: 509011 km
                    Time: 16:58:39
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H09 0110
   Revision: 09          Serial number: 2700104C190085
   Coding: 3D0F1340078002
   VCID: 2959979B8087980ABE-807C
00469 - Infotainment Databus in Single Wire Operation
                    Reset counter: 58
                    Mileage: 314286 km
                    Time: 08:54:20
                    Reset counter: 69
                    Mileage: 332657 km
                    Time: 12:54:41
                    Reset counter: 69
                    Mileage: 332657 km
                    Time: 00:02:55
                    Reset counter: 69
                    Mileage: 332657 km
                    Time: 00:02:56
                    Reset counter: 98
                    Mileage: 333529 km
                    Time: 07:08:45
   Component: IMMO            VDD 0814
Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN1.lbl
   Part No: 1T0 959 701
   Component: Tuersteuergeraet 09 0157
   Coding: 0000052
   VCID: 74E7B6EF17C595E2DD-8020
   Part No: 1K1 909 144 E
   Component: EPS_ZFLS Kl.0       1302
   VCID: 2D51638BB46F842A52-8078
00573 - Steering Torque Sensor (G269)
                    Mileage: 3520 km
                    Temperature: 1.0°C
                    Voltage: 10.10 V
                    Voltage: 9.90 V
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 BL
   Component: 01 KSG              0301
   Coding: 80E802087F2D8404084B016010
   VCID: 7BF59DD33A9BDA9A9C-802E
Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN1.lbl
   Part No: 1T0 959 702
   Coding: 0000052
   VCID: 75E18BEB1CBF8CEAEA-8020
   Part No: 1K0 035 186 L
   Component: Radio GR0       012 0018
   Revision: 0001201S    Serial number: VWZ2Z2D1929377
   Coding: 0020200
   VCID: 2F6D7983BE63F63A60-807A
End-------------------------(Elapsed Time: 01:50)--------------------------
Autoscan after engine wiring repaired, short test drive and several attempts of G85 addaption.
P.S. Please ignore EGR fault, it is done by customer and I'm asked not to touch it :D
As well at the moment customer don't want to repair aux heater.
Monday,09,January,2017,14:32:37:32442
   Coding: 0000072
16785 - EGR System
                    RPM: 1827 /min
                    Torque: 60.0 Nm
                    Speed: 14.0 km/h
                    Load: 18.4 %
                    Duty Cycle: 14.7 %
                    Bin. Bits: 00001000
                    Mass Air / Rev.: 230.0 mg/str
                    Mass Air / Rev.: 615.0 mg/str
Readiness: 1 1 0 0 0
   Coding: 0021190
   Coding: 00065493
   Coding: 0012338
   Component: Lenksäulenmodul 021 0050
   Coding: 0000042
   Coding: 0003103
   Coding: 0000011
                    Reset counter: 30
                    Mileage: 508945 km
                    Time: 16:14:23
                    Reset counter: 69
                    Mileage: 463729 km
                    Time: 16:04:38
02085 - Incorrect Control Module Installed
            000 -  -  - Intermittent
                    Reset counter: 69
                    Mileage: 463729 km
                    Time: 16:04:38
00664 - Fuel gauge
                    Reset counter: 0
                    Mileage: 462756 km
                    Time: 17:06:13
                    Reset counter: 30
                    Mileage: 509011 km
                    Time: 16:58:39
                    Reset counter: 59
                    Mileage: 333532 km
                    Time: 01:36:08
   Coding: 0000052
02546 - Steering Limit Stop
                    Mileage: 3520 km
                    Temperature: 27.0°C
                    Voltage: 14.30 V
                    Voltage: 14.00 V
            000 -  -
   Coding: 0000052
   Coding: 0020200
End-------------------------(Elapsed Time: 01:41)--------------------------
NEtech
Denmark
C?ID=56995
Please check wheel speed sensor, in [03-ABS] with VCDS Scope and/or a scope, start moving the car and driving slowly.
Or G85 problem.
Or maybe reset channel 00 in [44-Power steering].
MartinsX
Riga, Latvia
C?ID=268515
Thnanks, NEtech!
I know, that G85 can't be adapted if there are active faults stored in ABS/ESP, but I didn't know that implausible/corrupted signal without stored code will lead to the same. In VC-Scope it's clearly seen, that rear left wheel sensor is making some spikes. Will check sensor, wiring and rotor tomorrow.
http://fotki.lv/lv/Martins_X/comments45307999/
MartinsX
Riga, Latvia
C?ID=268515
New wheel bearing with rotor solved this issue ;)
raziel90
Sweden
C?ID=172805
Hi
I have a passat cc and my left cv boot started leaking and i had to remove my left drive axel and when i finished everything and i also had to remove the steering wheel and when i finished everything and tried to adapt the g85 sensor nothing happend. The angel showed 0° the whole time and when i followed you v-scope instruction the red graph differd from the other colors. Any idea what the problem could be? I have no code that say faulty.
South Molton, UK
Hi
Got a VCDS Auto-Scan?
