Sticky VIN-Limited Interface FAQ
Sticky
   #101
fin reaper
C?ID=399146
Question on Hex-V2 - 3 vin to 10 vin upgrade. When I upgrade, will the new vins be added to my current cable, or will a new cable be sent? Will the upgrade give me 10 new vin slots, or 7 + 3 from my existing cable? Thx
   #103
81llyh
C?ID=155229
Hi guys, I’ve upgraded the vin to unlimited, anyone know how long it takes to process the order?
   #104
The page you presumably order from states:
Orders for Vin-Upgrade are processed during normal business hours only.
All orders are processed on a first-in, first-out basis. A Feature Code cannot be issued until after your order has been reviewed by a human being during normal business hours. Assuming the information and the serial number you provide in this order is correct and verifiable, your Feature Code should be sent to you via e-mail no later than the end of the next business day. Please Note: “end of day” can be late in the evening.
Note that today is Labor Day, one of the few major Holidays in the USA that the Ross-Tech office is closed for.
why is it called Labor Day if no one works ? :)
For the same reason that we park on a driveway and drive on a parkway. ;)
PS: What do you mean "no one works"? What do you call what I'm doing here right now? :p
81llyh
C?ID=155229
Oh that explains why my order hasn’t processed yet. Thanks!
   #109
BigShoots
Arizona, USA
I see this comparison page it shows the HEX-V2 limited 10 Vin can no longer be upgraded to Unlimited Vins? Is that correct now?
Am I reading this correctly even though a while back in this thread it states V2 can be upgraded to UNLIMITED VINs?
Just trying to determine if the HEX-NET is worth the extra ~$150 or not for the 10 VINs. Thank you.
Ross-Tech: Interfaces
What? Where do you see that? A 10-VIN HEX-V2 definitely can be upgraded to Unlimited, you just can't get an Unlimited VIN license at the time of purchase directly from Ross-Tech.
BigShoots
Arizona, USA
Ah, got it, Thank you Uwe.
I saw The "NO" in RED on the Ross-Tech: Interfaces page which confused me thinking the 10 Vin HEX-V2 wasn't UPGRADEABLE to unlimited in looking at the table. The "NO" just means You can't purchase it directly that way.
Suggestion, It might make it more clear to either add a row at the bottom of that table to say "Unlimited VIN Upgradeable?" with a YES, OR change the "No" in the existing row to "No, but upgradeable".
-Bigshoots-
   #112
Hmm, the page does say,
All VIN-Limited (enthusiast) interfaces are upgradable. 3-VIN to 10-VIN or 10-VIN to Unlimited at a cost of $169.
shakir
Sweden
hi
i try to buy hex-v2 is not show me vin unlimited only 3 vin or 10 vin how i can buy unlimited vin
i cannt add product to cart if i dont choose 3 vin or 10 vin ?
mvh
shakir
   #114
Ross-Tech only sells HEX-V2s with 3-VIN or 10-VIN licenses. Some of our distributors overseas sell them with Unlimited VIN licenses.
Since you are in Sweden, look here:
New2Tregs
C?ID=374137
Quick question.
Can one do an auto-scan and save that auto-scan as a file if you decline on registering the VIN of the vehicle you are scanning> Thanks.
   #117
Yes.
70chips
C?ID=341258
I'm having a bit of a problem...
I performed a g85 reset using my 3 VIN license on my father's A4. Never once was asked for a vin to be entered during the process including the log in for the module. 3 days later after sorting the power issue causing the fault VDCS is now demanding a VIN imput.. I'm fairly sure this vin has been entered before.. I've researched a fair bit today, but can't seem to find any place to see which VINS are registered!
Why am I able to one thing one day but not 3 days later?
I seem to think I've had this before on a previous car.. done a dynamic diesel pump adjustment requiring a VIN then being told it wasn't registered..
Any thoughts? Even to just see which VINs are registered to the dongle..
Regards
Alan.
   #119
What generation A4? There are some conditions under which the interface and VCDS won't be able to get a VIN from the car (and power problems might be a contributing factor), in which case it won't ask you to register a VIN. If it doesn't, then: "Don't look a gift horse in the mouth." ;)
Yes, that's intentional. If at some point down the road, you sell your interface, would you want the next person, or the person after that, to be able to see all the VINs you charged against the license?
VCDS keeps a log of VINs you've registered on your computer. I've forgotten the exact name of the file, but look in the Debug sub-folder. Whether that log is complete or not will depend on whether you've used that computer and that installation of VCDS to register all the VINs in question. I.e. if you've used different PCs or even different installations (for example Release and Beta, which are in different folders) then the logs can be spread out among them.
If you e-mail us, we can also generate a Feature Code for you that will cause your interface to report the VINs it has stored to our server, and then we can give you a definitive list of exactly what VINs you've charged against the license.
NT7000
Georgia, USA
C?ID=437159
I already own/use my HEX-V2 interface for my car, if expunging a VIN isn't possible, do you offer credit for a VIN used to adapt a module? For instance, I just did a cluster swap on my car, in doing so I had to register the vin of the donor cluster in order to adapt it. If I can reasonably prove I do not own the car in question (donor car), can I get a credit/voucher toward a VIN upgrade at a later date?
