Friday,06,January,2017,15:50:27:29062
VCDS Version: 16.8.3.1
VIN: TMBBG7NE7E0154732 License Plate: OCT AJMAL DES AUTO 14
Mileage: 110436km-68621mi Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 08 09 15 16 17 19 42 44 52 5F
VIN: TMBBG7NE7E0154732 Mileage: 110436km-68621miles
Address 01: Engine (J623-CLHA) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 021 N HW: 04L 907 309 B
Component: R4 1,6L EDC H22 6547
Revision: 84H22---
Coding: 01250012030501090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI01104L906021N 002011
ROD: EV_ECM16TDI01104L906021N_002.rod
VCID: 306A9C636B52D5C20C-8064
Address 02: Auto Trans (J743) Labels: 0CW-927-769.clb
Part No SW: 0CW 300 046 HW: 0AM 927 769 K
Component: GSG DQ200-MQB H43 5110
Revision: 00043014 Serial number: CU501401116892
ROD: EV_TCMDQ200021.rod
VCID: 77F8677FCEBCC2FA8D-8022
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 907 379 R HW: 5Q0 907 379 F
Component: EMB8 EHCB H31 0356
Revision: 00000000 Serial number: 60184000000435
Coding: 1A078A9114250970007E060341C5245851289000608224F0004100004002
Shop #: WSC 73430 031 00063
ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
ROD: EV_Brake1UDSContiMK100ESP_033.rod
VCID: 4B90EB8FE2B4961A19-801E
Address 08: Auto HVAC (J301) Labels: 5G0-907-426.clb
Part No SW: 5E0 820 047 H HW: 5E0 820 047 H
Component: AC Manuell H03 0705
Revision: 00001K06
Coding: 01110104000100001000000000400000
ASAM Dataset: EV_ACManueBHBVW37X 003017
ROD: EV_ACManueBHBVW37X_SK48.rod
VCID: 2758773F5E9C927ADD-8072
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 084 AC HW: 5Q0 937 084 AC
Component: BCM MQBAB M H16 0124
Serial number: 00011401200202
Coding: 0F0018424207005307A04082B10407080000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_012.rod
VCID: 79FC6147F8A8D48AFB-802C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 140113 041 0570
Serial number: 140115102357
Coding: 065DDD
Subsystem 2 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Component: Sensor, DWA 005 0315
Serial number: 000000000ZY132982N22
Subsystem 3 - Part No SW: 5Q0 951 605 HW: 5Q0 951 605
Serial number: 00000000000028650274
Part No SW: 3Q0 959 655 AC HW: 3Q0 959 655 AC
Component: Airbag VW20 012 0189
Revision: -------- Serial number: 003P4P104NLK
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 7F088F5FE68CFABAC5-802A
Subsystem 1 - Part No SW: ----------- HW: 454 001 001 14
Serial number: 3576U0000009D3F4BE0Y
Subsystem 2 - Part No SW: ----------- HW: 454 001 001 14
Serial number: 3586U000000B26F4BE0T
Subsystem 3 - Part No SW: ----------- HW: 454 800 301 14
Component: SideSensor_Dr 111 0148
Serial number: 3516R5410A802000000T
Subsystem 4 - Part No SW: ----------- HW: 454 800 401 14
Component: SideSensor_Pr 111 0148
Serial number: 3526RA011A802000000W
Subsystem 5 - Part No SW: ----------- HW: 454 801 911 13
Component: FrontSensor_D 114 0149
Serial number: 3556VFE5B3902000000N
Address 16: Steering wheel (J527) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 507 DC HW: 5Q0 953 549 C
Component: Lenks. Modul 002 0110
Revision: -------- Serial number: 10011404220445
Coding: 0610
ROD: EV_SMLSKLOMQB_AU37.rod
VCID: 7AFE7E4BFDAEDF92F2-802E
Part No SW: 5E0 920 951 E HW: 5E0 920 951 E
Component: KOMBI 103 3390
Coding: 272402082000A60001080800040000
ASAM Dataset: EV_DashBoardJCIMQBAB 008011
ROD: EV_DashBoardJCIMQBAB_008.rod
VCID: 295C71074888A40ACB-807C
Part No SW: 5Q0 907 530 N HW: 5Q0 907 530 D
Component: GW MQB Low 123 1164
Revision: -------- Serial number: 0001465097
Coding: 030000040F087300EF0000481C0F00010001050000000000000000000000
ASAM Dataset: EV_GatewLear 010015
ROD: EV_GatewLear_010.rod
VCID: 3C72B853B71A21A2A0-8068
Subsystem 2 - Part No SW: 5Q0 915 181 E HW: 5Q0 915 181 E
Component: J367-BDMHella H03 8043
Serial number: 3036282303
Part No SW: 5Q4 959 393 B HW: 5Q4 959 393 B
Component: TSG FS 009 0014
Serial number: 0000089091958
Coding: 001000208001040100001100
VCID: 428EC6ABD5FE5752EA-8016
Part No SW: 5Q0 909 144 P HW: 5Q0 909 144 P
Component: EPS_MQB_ZFLS 122 1043
Coding: 0103
ROD: EV_SteerAssisMQB_010.rod
VCID: 418CC9A7D0F84C4AF3-8014
Part No SW: 5Q4 959 392 B HW: 5Q4 959 392 B
Component: TSG BFS 009 0014
Serial number: 0000088772701
Address 5F: Information Electr. (J794) Labels: 5E0-035-MIB-STD1.clb
Part No SW: 5E0 035 820 A HW: 5E0 035 820 A
Component: MU-S-D-ER 040 0421
Serial number: S5C01301142964
Coding: 03730100FF0000001111120100A800002F0000860100010000
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CPASE_AU37.rod
VCID: 1D3455D70CC048AAB7-8048
Subsystem 1 - Part No SW: 5E0 919 605 HW: 5E0 919 605
Component: ABT_Std_Radio H50 0022
Serial number: SKZ8Z9NL200GCY
0528 - Rear Left Treble Speaker
B1066 13 [009] - Open Circuit
Reset counter: 96
Mileage: 110436 km
Date: 2017.01.06
Time: 15:46:19
Voltage terminal 30: 12.3 V
End-------------------------(Elapsed Time: 03:06)--------------------------
