MIB2 Discover Media PQ /picture heavyyy :D
m87a
Bosnia and Herzegovina
C?ID=156900
I'm trying to retrofit discover media pq from tiguan 2016/sirocco/caddy/beetle/passat cc 5C0 035 680 to golf 6 2010. So far I have replaced gateway and made an adapter from old to new quadlock connector. I'm waiting for stealership appointment next week to remove cp and I have a friend who activate navi/maps and mirrolink, so we shall see. With software 0359 in standy there are 4 clock's to choose from
I have documented byte 18 which should be simllar to MIB 1/2 devices, and this can be documented, maybe it can help someone too ;)
byte 18:
00 standard
01 hybrid (twin drive)
02 GTD
03 GTI
04 BlueMotion
05 E Golf
06 R Line
07 Golf R
08 AllTrack
09 GTE
0C FAMILY
0F Welcome to SKODA
10 beats audio
11...FF - last used or coded logo is displayed
m87a
C?ID=156900
adaptation -> ENG117919-Startup_Screen_Sticker_HMI
00 01 - Fender
00 02 - Dynaudio
best of all is that you can combine byte18 logo which will be followed by either fender or dynaudio ex. byte18 07, adapt 00 02
it will show Golf R and second later sound by Dynaudio
for mib devices
adaptation -> (8)-Startup_Screen_Sticker_HMI-Fender
set actived
or
adaptation -> (9)-Startup_Screen_Sticker_HMI-Dynaudio
set activated
as always after coding reset device, hold power button 10 seconds
supremo
Italy
C?ID=245837
you can see in your navigator all the information of your air conditioning.
m87a
C?ID=156900
no it doesn't show any info for air conditioning but it could be since i'm using old mk6 climatronic, will check that later
Viking
C?ID=151455
What part number can gateway did you fit?
Dhafer
Tunisia
C?ID=36240
I tryed the same on 2013 car with last gateway, the dealer was not able to disable CP on the radio for the car !
golfi_vend
Tartu, Estonia
C?ID=195131
Impossible to match Discovery to car even with latest SW cluster which supports CP.
supremo
Italy
C?ID=245837
To turn off the cp must perform a cluster retrofit with part number 5n0920883g sw 1008 gateway 7n0907530 then bg or bc. . . . then he goes off cp in service volkswagen
Thanks for that coding chart with pics! I added this to an internal task so we can use that feedback to enhance the label file(s).
Ref to: FS#1001
golfi_vend
Tartu, Estonia
C?ID=195131
Have you done this and can confirm it is possible?
m87a
C?ID=156900
gone to the dealership, checked the unit, everything is ok, not stolen or blacklisted in GeKo, got the 4 digit code for what i don't know, they are quite busy so had to re schedule for cp removal. Since they are only friendly dealership in region quite far away from me, and low temperatures on highway, while keeping temp in side a car quite high i noticed that display started to "lose contact" since lack of better term after couple of minutes it turned off, black, nothing.... it seems that board is f#$ked.... just my luck
supremo
Italy
C?ID=245837
confirm that it is possible? that model of car do you have?
Dhafer
Tunisia
C?ID=36240
I have Tiguan 2013, changed Gateway to last version and Instrument with 1008 3D color all adapted at the dealer,
After fitting the Radio with CP protection, we are not able to remove CP for the Radio,
In ODIS, show that the Master dont ask for CP so, the Radio stay locked with CP,
Batter Off/ON, etc.. dont change this,
Any update to this ?
golfi_vend
Tartu, Estonia
C?ID=195131
This has been confirmed many times. Impossible to match CP on car with no CP from factoy. Only maybe if you change identity of car.
Right now only possible way to use discovery is match it to car where CP was available with all option(Carplay, Voice command, navigation etc...) and use EEPROM patch. This way you use the runtime limit of 8hours of CP, it won't let write anything to EEPROM and it re-reads the content every time you start the Discovery.
m87a
C?ID=156900
talked to a guy and he confirms this story, also he says in my case it could be that software crashed because of playing with coding, so i'm in hunt for firmware to try to update to restore functionality, any info will it allow firmware update with cp active?
supremo
Italy
C?ID=245837
I installed the media discover PQ of vw tiguan. to disable cp I went to a company that disabled me this type of protection. . Now it all works from the navigator ,. voice commands, ops.
