- May 1, 2014
- 58
- 52
- Northern Ireland
- C?ID=109519
Having issues getting VCDS to complete the Controller Map scan on this car and the other I've just posted.
Debug level was correct but it just carried out a normal scan and didn't save any additional files
Friday,06,January,2017,19:30:05:49196
VCDS Version: 16.8.4.2 (x64)
VIN: WVWZZZAUZxxxxxxxx License Plate: Golf R
Mileage: 381km-236mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 22 42 44 47 52 55 5F A9
VIN: WVWZZZAUZxxxxxxxx Mileage: 381km-236miles
Address 01: Engine (J623-CJXC) Labels: 06K-907-425-V1.clb
Part No SW: 5G0 906 259 F HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0002
Revision: --H13---
Coding: 091D00122466050B2004
ASAM Dataset: EV_ECM20TFS0205G0906259F 001004
ROD: EV_ECM20TFS0205G0906259F_VW37.rod
VCID: 316D6D0A60E976CA76-8064
Part No SW: 0D9 300 014 Q HW: 02E 927 770 AS
Component: DQ250-6A MQB H54 5005
Revision: 06454104 Serial number: TFK01610201455
ROD: EV_TCMDQ250021.rod
VCID: 26478E565927217293-8072
Address 03: ABS Brakes (J104) Labels: None
Part No SW: 5Q0 614 517 CH HW: 5Q0 614 517 AH
Component: ESC H62 0743
Revision: 00000000 Serial number: 63076000001855
Coding: 01FA93A154232170477B070040C36980C92A84E2E002967718425078C208430000000012121212B835351919323200
VCID: 79FD952AF8197E8A8E-802C
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5G0 907 044 CF HW: 5G0 907 044 CF
Component: Climatronic H04 1801
Revision: 00001K08
Coding: 0012000420011001100500000010102A
VCID: 6DD5B17ABC51D22A12-8038
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 CL HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061631003061
Coding: 03001A46C24122F30BA44080B11C07281000000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 0403F4DE8FDB3362ED-8050
Subsystem 1 - Part No SW: 5G2 955 119 A HW: 5G2 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 161020 042 0551
Serial number: 161031132250
Component: RLHS 042 0105
Serial number: S5Y16M11D11H17M48S39
Coding: 00A8DD
Serial number: 000000000ZY1627801NS
Serial number: 00000000000067551898
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-294.clb
Part No SW: 5Q0 919 294 K HW: 5Q0 919 294 A
Component: PARKHILFE 8K H03 0054
Revision: -------- Serial number: 39331631408390
Coding: 0071051011
ROD: EV_EPHVA18AU3700000_VW37.rod
VCID: 438137C2CA55F45A94-8016
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 H HW: 5Q0 907 572 H
Coding: 3500478151FFC428949C810530300600000000000000000000
ROD: N/A
VCID: 3C734C3EB7AB8BA2D5-8068
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
0836 - ROD - Unknown Error Code
- 00 [008]
Reset counter: 53
Mileage: 256 km
Date: 2017.01.05
Time: 21:07:20
Part No SW: 5Q0 959 655 AR HW: 5Q0 959 655 AR
Component: AirbagVW21 003 0317
Serial number: 003TDR29L1R3
Coding: 98CCC000000000005C0000CF008800000065
VCID: 102BC88ECBA35FC259-8044
Belt Pretensioner left:
Component: BeltPretRevFL H37 0350
Serial number: 34169677D08111650973
Coding: 333135
Belt Pretensioner right:
Component: BeltPretRevFR H37 0350
Serial number: 34169676D09111651283
Coding: 333135
Subsystem 3 - Part No SW: ----------- HW: 480 000 511 16
Serial number: 35700000000C2A787F1Y
Subsystem 4 - Part No SW: ----------- HW: 480 000 511 16
Serial number: 35800000000099AC2E1U
Subsystem 5 - Part No SW: ----------- HW: 480 400 811 16
Serial number: 3510001BF23204B4E5D8
Subsystem 6 - Part No SW: ----------- HW: 480 400 811 16
Serial number: 3520001AB23204B375E/
Subsystem 7 - Part No SW: ----------- HW: 480 400 511 16
Serial number: 3550001BD232EA20F3EH
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 P HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20161109500400
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 3F893B32A6BD90BAF0-806A
Part No SW: 5G1 920 958 B HW: 5G1 920 958 B
Component: KOMBI 304 8311
Coding: 27AD08082F80260001886B011400000000000000
VCID: 306B680E6BE37FC279-8064
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 F
Component: GW MQB High 128 1265
Revision: -------- Serial number: 0005539140
Coding: 030100043F085900FB00027E1C0F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 7CF38C3EF72B4BA295-8028
Subsystem 2 - Part No SW: 5G0 959 442 N HW: 5G0 959 442 N
Component: E221__MFL-DC1 H11 0040
Serial number: 29160002348970066452
Coding: 2DFFFF
Subsystem 3 - Part No SW: 5Q0 915 181 K HW: 5Q0 915 181 K
Serial number: 7974841904
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00027.09.16
Coding: 0001
VCID: 4A9F1AE6ED7F251257-801E
Component: TSG FS 020 0041
Serial number: 210816EHL19343
Coding: 003F0220D001048000001000
Subsystem 1 - Part No SW: 5Q0 959 812 HW: 5Q0 959 812
Serial number: 00000000000012213072
Coding: 0D0000
Part No SW: 3Q0 909 144 K HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 506 5072
Coding: 8107
ROD: EV_SteerAssisMQB_013.rod
VCID: 3A7F4A26BD9FB592C7-806E
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Revision: 00000001 Serial number: VWZ8Z1GBA02PN6K
Coding: 12000000008AAA8A000000000000
ASAM Dataset: EV_AMPMst11CGen2ALPI 001003
ROD: EV_AMPMst11CGen2ALPI.rod
Component: TSG BFS 020 0041
Serial number: 120816EHB22826
Coding: 003F0020DE01048000801000
VCID: 428F32C6D54FFD529F-8016
Subsystem 1 - Part No SW: 5Q0 959 811 HW: 5Q0 959 811
Serial number: 00000000000012216284
Coding: 150000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 02AE01000B000200
VCID: 408B38CEDB43EF4289-8014
Subsystem 1 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0002
Coding: 2E0000
Subsystem 2 - Part No SW: 3D0 941 329 E HW: 3D0 941 329 E Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0002
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 874 B HW: 3Q0 035 874 B
Component: MU-S-ND-ER 840 0751
Coding: 027300010000000051110102008808001F0207E601200100CF
ROD: EV_MUStd4CDELP_VW26.rod
Subsystem 1 - Part No SW: 3G0 919 605 D HW: 3G0 919 605 D
Component: ABT_Std-2_Nav H70 6121
Serial number: VWZ6Z9S3151058
Subsystem 2 - Part No SW: 3G0 919 866 AQ HW: -----------
Component: ECE1 2017 --- 0730
Part No SW: 5G0 907 159 D HW: 4H0 907 159 A
Component: SAS-GEN 2 H07 0001
Serial number: 161004200930
VCID: 2F696B7276DD603A60-807A
End---------------------(Elapsed Time: 04:27, Deb=2)-----------------------
