Sticky Wanted: Control Module Maps from AFP 2.8L Vr6
Sticky
Due to a discrepancy in MVB/BS 077.2 (Coolant versus MAF) we would like to review Auto-Scans (with the VIN please) and PLB function control module maps from the Mk4 chassis AFP 2.8L Vr6 Golf and Jetta.
They use the 021-906-018-AFP.lbl label file and this engine was found in the NAR market from 1999.5 - 2002.5:
Address 01: Engine Labels: 021-906-018-AFP.lbl
Part No: 021 906 018 T
Component: MOTRONIC ME7.1 G 6764
Coding: 00031
Internal ref: FS#1254
hans j
Utah
C?ID=60436
Still in need?
Wednesday,21,May,2014,12:13:57:05734
VCDS Version: 14.5.1.0 (x64)
Data version: 20140515
Dealer/Shop Name: Utah Imports hj
VIN: 9BWPG61J424006566   License Plate:
Mileage: 170840km-106155mi   Repair Order:
          76
VIN: 9BWPG61J424006566   Mileage: 170840km-106155miles
   Coding: 00031
   Shop #: WSC 19400
   VCID: 9F0EA3E21FAB3AC334-5184
   9BWPG61J424006566     VWZ7Z0A3892027
16712 - Knock Sensor 1 (G61)
            P0328 - 35-10 - Signal too High - Intermittent
16717 - Knock Sensor 2 (G66)
            P0333 - 35-10 - Signal too High - Intermittent
Address 03: ABS Brakes        Labels: 1C0-907-37x-ASR.lbl
   Part No: 1C0 907 379 D
   Component: ASR FRON
   Coding: 0021505
   Shop #: WSC 00034 785 00200
   VCID: AB1647320B13D663A8-5184
   Part No: 6Q0 909 605 F
   Component: 08 AIRBAG VW6  0202 0004
   Coding: 12344
   Shop #: WSC 00034
   VCID: BA387276A4497FEB23-5160
00591 - Seat Belt Switch; Driver (E24)
            32-10 - Resistance Too High - Intermittent
00592 - Seat Belt Switch; Passenger (E25)
01217 - Side Airbag Igniter; Driver Side (N199)
01218 - Side Airbag Igniter; Passenger Side (N200)
   Part No: 1J0 920 926 D
   Coding: 07232
   Shop #: WSC 20691
   VCID: AB1647325B13D663A8-5160
   Part No: 6N0 909 901
   Coding: 00006
   VCID: F0AC905EB2B5F5BBDD-5160
   Part No: 1C0 959 799 C
   Component: 1J Komfortgerát HLO 0003
   Coding: 00064
   VCID: B73E6B42975B6283DC-4B3C
   Component: 1J Tõrsteuer.FS KLO 0002
   Component: 1J Tõrsteuer.BF KLO 0002
            37-00 - Faulty
End-------------------------(Elapsed Time: 08:05)--------------------------
and
Friday,04,April,2014,11:21:13:05734
VCDS Version: 14.2.3.0 (x64)
Data version: 20140320
VIN: 9BWPG61J824003766   License Plate:
Mileage: 219240km-136229mi   Repair Order:
          76
VIN: 9BWPG61J824003766   Mileage: 219240km-136229miles
   Component: MOTRONIC ME7.1  G   0003
   Coding: 00031
   Shop #: WSC 01120
   VCID: 9F0EA3E21DAB3ACC0C-5184
   9BWPG61J824003766     VWZ7Z0A3885092
16885 - Vehicle Speed Sensor
            P0501 - 35-00 - Implausible Signal
16486 - Mass Air Flow Sensor (G70)
            P0102 - 35-10 - Signal too Low - Intermittent
17550 - Load Calculation Cross Check
            P1142 - 35-10 - Lower Limit Exceeded - Intermittent
17573 - Long Term Fuel Trim Additive Air; Bank 1; Range 1
            P1165 - 35-10 - System too Rich - Intermittent
Readiness: 0000 1100
   Component: ASR FRON
   Coding: 0021505
   Shop #: WSC 00000 785 00200
   VCID: AB1647320913D66C90-5184
   Coding: 12344
   VCID: BA387276A6497FE41B-5160
   Coding: 07232
   Shop #: WSC 19506
   VCID: AB1647325913D66C90-5160
   Coding: 00006
   VCID: F0AC905EB0B5F5B4E5-5160
   Coding: 00064
   VCID: B73E6B42955B628CE4-4B3C
   Component: 1J Tõrsteuer.FS KLO 0003
                Address 01: Engine  (021 906 018 T)
11:22:04 Group 032: Lambda Control (Mixture Adaptation)
  -2.1 %  Adaptation (Idle) Bank 1 Sensor 1
  16.4 %  Adaptation (Partial) Bank 1 Sensor 1
            Bin. Bits
            Bin. Bits
Monday,14,April,2014,13:11:47:05734
VCDS Version: 14.4.0.3 (x64)
Data version: 20140411
          76
   Coding: 00031
   Shop #: WSC 01120
   VCID: 9F0EA3E21DAB3AC3D9-5184
Readiness: 0000 0101
   Component: ASR FRON
   Coding: 0021505
   VCID: AB1647320913D66345-5184
   Coding: 12344
   VCID: BA387276A6497FEBCE-5160
   Coding: 07232
   Shop #: WSC 19506
   VCID: AB1647325913D66345-5160
   Coding: 00006
   VCID: F0AC905EB0B5F5BB30-5160
   Coding: 00064
   VCID: B73E6B42955B628331-4B3C
00912 - Window Regulator Switch; Front Left (E40)
13:12:14 Group 032: Lambda Control (Mixture Adaptation)
  -1.7 %  Adaptation (Idle) Bank 1 Sensor 1
  18.8 %  Adaptation (Partial) Bank 1 Sensor 1
            Bin. Bits
            Bin. Bits
It's funny the only two I have out of 5400+ scans were scanned a few weeks apart.
I don't see these cars as much as I used to, but if I remember when I see another one, I'll get a control module map.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Yes, please! :)
hans j sent a map and scan set from: Part No: 021 906 018 M
Thanks!
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Thanks, we may still need a few more from other P/Ns.
Excellent, hans j sent a map and scan from:
Part No: 021 906 018 R
Component: MOTRONIC ME7.1 G 6762
Coding: 00031
(Seb I have the originals in our Support>Dataversion folder)
budvidua
Indiana
C?ID=356887
Still looking? I have several friends with this type of car wanting scans in the near future. My daily.
Sunday,13,January,2019,15:25:37:45417
VCDS Version: 18.9.0.4 (x64)  HEX-NET CB: 0.4437.4
Data version: 20181017 DS296.0
VIN: 9BWPG61J214061127   License Plate:
Mileage: 264640km-164439mi   Repair Order:
Chassis Type: 1J - VW Golf/Bora IV (1998 > 2006)
          76
   Mileage: 264640km-164439miles
   Coding: 00031
   Shop #: WSC 03311
   VCID: 1D72DE129500A7A2D0-5184
Readiness: 0010 1101
   Component: ASR FRONT MK60      0103
   Coding: 0021505
   Shop #: WSC 00001 785 00200
   VCID: 2B1600CA8BB459125E-5184
   Part No: 3B1 907 044 C
   Component: CLIMATRONIC     C 1.0.0
   Coding: 01000
   Shop #: WSC 00001
   VCID: 210AE2E2A9788342F4-51A8
   Component: 07 AIRBAG VW6  0202 0004
   Coding: 12343
   Shop #: WSC 00001
   VCID: 3A38358E24EEF09AD5-4B3C
   Part No: 1J0 907 487 B
   Component: Lenkradelektronik   0001
   Coding: 00008
   Shop #: WSC 00001
   VCID: 302C17A6F2923ACA6B-51CE
   Part No: 1J0 920 925 D
   Component: A4-KOMBIINSTR. VDO V01
   Coding: 07232
   Shop #: WSC 03311
   VCID: 2A1805CED44E401AA5-5160
   Subsystem 1 - Part No: IMMO
   Component: IDENTNR: VWZ7Z0Y2737527
   IMMO-IDENTNR: VWZ7Z0Y2737527
   Coding: 00006
   Shop #: WSC 00001
   VCID: 70ACD7A632127ACA2B-5160
   Part No: 1J0 959 799 AJ
   Component: 62 Zentral-SG Komf. 0001
   Coding: 00256
   Shop #: WSC 00001
   VCID: 0640917E2096447AE1-4B1E
   Subsystem 1 - Part No: 1J1959801C
   Component: 62 Tõrsteuerger. FS0002r
   Subsystem 2 - Part No: 1J1959802D
   Component: 62 Tõrsteuerger. BF0002r
   Part No: 1J0 035 180 B
   Component:  Radio DE2         0005
   Coding: 01033
   Shop #: WSC 16403
   VCID: 1E70D91E9806BCBAC9-51F2
End----------(Elapsed Time: 04:31, VBatt start/end: 13.9V/13.8V)-----------
