- Apr 18, 2014
- 679
- 216
- Stoke on Trent, England
- C?ID=122432
It isn't only a Mk6 Golf problem as the same type of light is fitted to other models.
I've had an error code for a few months. The indictor strip light works on both mirrors so I haven't really bothered about it. Last week I noticed the light in the drivers door the one with the fault code isn't as bright. VW in there stupid wisdom don't show these LED bulbs as a replacement item you have to buy a new light unit. I was going to count the number of LED lights when I went out today but I forgot. I think there are 5 or 6.
Turn signal indicator left - 5K0 949 101 - £32.53
Turn signal indicator right - 5K0 949 102 - £32.53
This is stupid you have to buy a new light if the bulb goes, I believe its the same for the rear fog light LED which you don't use in USA.
I've Googled LED amber bulb strip 12v. There are sellers on fleabay
http://www.ebay.co.uk/itm/4x12LED-1...957639?hash=item33bde0c9c7:g:-SUAAOSwawpXvkH8
http://www.ebay.co.uk/itm/12-YELLOW...hash=item5688830b2f:m:mjMzmjSqa7cYFOjeOjh6iWA
I was wondering if anyone else has had the error code or replace the LED bulbs in the mirror?
VAG Error Code: 00109
Fault Location:
Turn Signal Lamp: Driver, Left Mirror (L131) - Electrical Fault in Circuit
Possible Cause:
Wiring/Connector(s).
Voltage Supply for Left Mirror Turn Signal Lamp (L131) faulty.
Possible Solutions:
Check/Replace all faulty Wiring/Connector(s).
Check Voltage Supply for Left Mirror Turn Signal Lamp (L131).
Check Left Mirror Turn Signal Lamp (L131) Operation.
Fault Location:
Possible Cause:
Possible Solutions:
