manual conversion help needed
starkie
C?ID=279996
hi looking for advice as really struggling with this car. Car is 2004 a4 tdi multitronic converted to manual and getting brake symbol etc still coming on when car ignition switched on as i believe parts of the car still believe its a multitronic
here is a list that my faults etc being displayed any help and advice would be greatly appreciated
Wednesday,04,January,2017,13:26:42:44553
VCDS Version: 16.8.4.2 (x64)
VIN: WAUZZZ8E84A046688   License Plate:
          67 69 75 76 77
VIN: WAUZZZ8E84A046688   Mileage: 187230km-116339miles
Address 01: Engine        Labels: 038-906-019-AVF.lbl
   Part No: 038 906 019 LJ
   Component: 1,9l R4 EDC 0000SG  4910
   Coding: 00002
   Shop #: WSC 63351
   VCID: 6ADBBA4F16D1E01277-4B00
   WAUZZZ8E84A046688     AUZ6Z0C0205287
17994 - Engine Mount Solenoid Valves (N144/N145)
            P1586 - 35-10 - Short to Plus - Intermittent
17910 - Fuel Pump Relay (J17)
            P1502 - 35-00 - Short to Plus
Readiness: 1 1 1 0 1
Address 03: ABS Brakes        Labels: 8E0-614-517.lbl
   Part No: 8E0 614 517
   Component: ABS/ESP front       3429
   Coding: 04255
   Shop #: WSC 06435
   VCID: 65C1C973FFCFCF6A5A-5124
01486 - System Function Test Activated
            35-00 -  -
   Part No: 8E0 820 043 AA
   Component:   A4 Klimaautomat   1219
   Coding: 00000
   Shop #: WSC 63351
   VCID: 60CFD867E0EDAA42A9-5140
            30-00 - Open or Short to Plus
            27-00 - Implausible Signal
Address 09: Cent. Elect.        Labels: 8E0-907-279-8E2.lbl
   Part No: 8E0 907 279 E
   Component: int. Lastmodul  RDW 0305
   Coding: 00001
   VCID: 34676437049566E21D-4B00
Address 15: Airbags        Labels: 8E0-959-655-84.lbl
   Part No: 8E0 959 655 B
   Component: Airbag 8.4EP        3002
   Coding: 0010602
   Shop #: WSC 63351 000 00000
   VCID: 36635E3F42E974F223-5140
   Part No: 8E0 953 549 F
   Component: Lenksáulenmodul     0308
   Coding: 01011
   Shop #: WSC 63351
   VCID: 36635E3F12E974F223-4B00
Address 17: Instruments        Labels: 8E0-920-9xx-8E2.lbl
   Part No: 8E0 920 950 J
   Component: KOMBI+WEGFAHRS. RB4 D36
   Coding: 00401
   Shop #: WSC 00048
   VCID: 306F6827F08D5AC279-5140
            49-00 - No Communications
Address 45: Inter. Monitor        Labels: 8E0-951-177.lbl
   Part No: 8E0 951 177
   Component: Innenraumueberw.   0604
   Coding: 00001
   VCID: 6BD5BF4B192BF91A0C-5140
Address 46: Central Conv.        Labels: 8E0-959-433-MAX.lbl
   Part No: 8E0 959 433 BC
   Component: Komfortgerát T3B    1311
   Coding: 06859
   Shop #: WSC 63351
   VCID: 73E5A72B411B21DAC4-4B00
   Subsystem 1 - Part No: 8E2959802B
   Component: Tõrsteuer.FS BRM 0003
   Subsystem 2 - Part No: 8E2959801B
   Component: Tõrsteuer.BF BRM 0003
   Subsystem 3 - Part No: 8E0959801A
   Component: Tõrsteuer.HL BRM 0003
   Subsystem 4 - Part No: 8E0959802A
   Component: Tõrsteuer.HR BRM 0003
            80-00 - Single-Wire Operation
   Part No: 8E0 035 186 J
   Component: concert II  GRO    0008
   Coding: 01001
   Shop #: WSC 63351
   VCID: 2E53765FEAB94C326B-4B00
00852 - Loudspeaker(s); Front
            36-00 - Open Circuit
End-------------------------(Elapsed Time: 05:37)--------------------------
Engine coding looks OK.
ABS looks OK too, but see here.
Instrument Cluster thinks you still have an Auto trans. But the "Coding" for that is done in Adaptation Channel 060. What do you have in there?
starkie
C?ID=279996
will go have a look the now
starkie
C?ID=279996
starkie
C?ID=279996
i have now changed the coding of this to 1029 and no fault showing from instruments now so just the brake issue which i will continue to look into
NZDubNurd
New Zealand
C?ID=230482
Is the brake fluid low? After fitting the clutch hose to the reservoir?
starkie
C?ID=279996
cant get car to turn over but if i run a wire from the battery down the the solenoid i can get the starter to turn over
does the a4 tdi need to have the clutch switch wired in to start as not done this as of yet but will be doing it just now trying to get car restarted
thanks in advance
thanks in advance
I'm not sure whether it's true in all markets, but NAR models with manual trannies did all need to have the clutch pressed in order to start. Moreover I would expect the instrument cluster provide a "press clutch" message once it believes the car is a manual...
starkie
C?ID=279996
got it turning over the guide i was looking at for the conversion was for a b5 and the relays are slightly different
