RCD-510-AE + Kufatec Fiscon Bluetooth basic retrofit not working for MK5 Golf GTI
NitrousOxide
Jamaica
C?ID=269481
I have a 2008 MK5 Golf GTI with DSG, multifunction steering wheel, Red MFA+ that came with a Premium7 haedunit that I am retrofitting a Premium8 RCD-510-AE and Kufatec Fiscon Bluetooth harness. The RCD installs and works OK, bu the Fiscon bluetooth harness isn't providing any bluetooth functionality. This device is just a harness that sits between the factory radio harness and the headunit (so there is no cutting or splicing of the wires). Completely plug&play. The installation insructions call for the usual enabling of the 77-Telephone in the Gateway, which I did. The other instructions were for the multifunction streering wheel to be coded, but this isn't accepted. Also the option to enable the bluetooth in the headunit coding fails with a 31-out of range error message.
The fiscon Bluetooth unit should be able to work independently of the headunit (using only the MFA+ and the multifunction steering wheel, but the car isn't seeing it (with Telephone-77 enabled in the gateway). I originally thought it was a missing fuse issue, but the fuse socket doesn't have the wiring to accept a fuse in that empty fuse-socket.
I noticed from day1 of getting my VCDS cable that my central electronics coding for Transmission Type is set to "manual" (as opposed to automatic since I have a DSG). Is this correct, or am I confusing this term with something else?
Please see my autoscan below. The antenna isn't properly attached to the radio, and I got T-boned 2 weeks ago that damaged the rear left speaker.
Tuesday,03,January,2017,18:29:29:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.4.2 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 0F 15 16 17 19 25 42 44 46 4F 52 55 56 77
VIN: WVWZZZ1KZ8W111078   Mileage: 157120km-97629miles
09-Cent. Elect. -- Status: Not registered 0011
0F-Digital Radio -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070060
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EEA2A-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
                    Mileage: 157009 km
                    Time: 21:38:24
                    Temperature: 69.0°C
                    Temperature: 39.0°C
                    Absolute Pres.: 990.0 mbar
                    Voltage: 12.065 V
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
                    Mileage: 157010 km
                    Time: 21:58:55
                    RPM: 1342 /min
                    Load: 18.0 %
                    Speed: 26.0 km/h
                    Temperature: 81.0°C
                    Temperature: 33.0°C
                    Absolute Pres.: 1000.0 mbar
                    Voltage: 13.843 V
Readiness: 0110 0101
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFA235-8048
   Revision: 00H11001
   Coding: 0004738
   VCID: 73CB2640122900DAC4-8026
            013 - Check DTC Memory
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457A8A8E-802C
00797 - Sunlight Photo Sensor (G107)
            010 - Open or Short to Plus
00709 - Sunlight Photosensor 2 (G134)
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Coding: E70E9E0F000414004F14000414000080800900005C100100000000000000
   VCID: 71C72C48683532CA36-8024
   Component: Wischer 300807 021  0501
   Coding: 00038837
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00221517
   Shop #: WSC 12345
00924 - Relay for Headlamp Cleaning System (J39)
                    Fault Status: 00101001
                    Reset counter: 226
                    Mileage: 157009 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
                    Fault Status: 01100101
                    Reset counter: 186
                    Mileage: 157124 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.15 V
00380 - Special Vehicle Control Module (J608)
                    Reset counter: 186
                    Mileage: 157116 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 12.20 V
02390 - Control / Regulation for Ambience Lighting (E400)
                    Fault Status: 01101001
                    Reset counter: 186
                    Mileage: 157009 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 11.80 V
                    Fault Status: 01101100
                    Reset counter: 186
                    Mileage: 157009 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.55 V
Address 0F: Digital Radio
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86AAE2-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
8 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            007 - Short to Ground - Intermittent - MIL ON
00589 - Airbag Igniter 1; Passenger Side (N131)
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
01578 - Airbag Deactivation Warning Lamp; Passenger Side (K145)
            009 - Open or Short to Ground - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012102
   VCID: 01277C885895224AC6-8054
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0004103
   Revision:   H07 01    Serial number: 040907F1000254
   Coding: ED811D060007030001
   VCID: 3041E94CA3BF7BC279-8064
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:07:16
02649 - Digital Radio Tuner
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:08:21
            000 -  -
                    Mileage: 157124 km
                    Time: 18:08:16
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 00000 785 00200
   VCID: 3851D16C4BCFA38231-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE81643A60-807A
01312 - Powertrain Data Bus
                    Fault Status: 00101110
                    Fault Frequency: 127
                    Reset counter: 214
                    Mileage: 156897 km
                    Time: 11:38:26
                    Voltage: 13.63 V
                        DU
                    Temperature: 51.0°C
                    RPM: 1498 /min
                    Speed: 31.0 km/h
                    Speed: 31.0 km/h
                    Count: 3
            008 - Implausible Signal - MIL ON
                    Fault Status: 11101000
                    Reset counter: 183
                    Mileage: 157009 km
                    Time: 21:38:39
                    Battery Volts: 12.3 V
                        DD
                    Temperature: 38.0°C
                    Count: 5
                    Steering Angle: -0.48°
                    Count: 1
                        SteerAng Init
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F42CE0F0FF0085A26509C40
   VCID: 032B76804289305AD4-8056
                    Reset counter: 183
                    Mileage: 157009 km
                    Time: 21:38:39
Address 4F: Centr. Electr. II (J533)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 00000000
   VCID: 66ED4F1491FBE57253-8032
   Coding: 0000564
   VCID: 3957D46870C5BA8ACE-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C9255C172707E2DD-8020
   Part No SW: 1K0 035 180 AE    HW: 1K0 035 180 AE
   Component: Radio Prem-8  H02 0016
   Revision: -----16S    Serial number: VWZ4Z7L3180243
   Coding: 01000401000000
   VCID: 63EB560062C9905AB4-8036
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:11:43
03138 - Input AUX IN
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:11:48
00856 - Radio Antenna
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:11:43
02633 - Antenna for Satellite Tuner
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:11:43
            000 -  -
                    Reset counter: 186
                    Mileage: 157124 km
                    Time: 18:11:43
Address 77: Telephone
End-------------------------(Elapsed Time: 01:17)--------------------------
Kinda strange that the Gateway sees 77-Telephone as Status: OK but VCDS doesn't find it when it tries to access it in the Auto-Scan.
What happens if you try to access it directly?
NitrousOxide
Jamaica
C?ID=269481
When I try to access it directly, it just takes me back to the previous window listing all the modules.
Currently, it says that intermittent communication (so it is no longer OK).
However, for the first time, I was able to successfully pair my phone directly with the bluetooth and make an outgoing call (although I don't have the microphone connected). The RCD-510 still has Bluetooth option grayed out on the screen, but it paused the audio that I was playing and presented an icon showing that I was on a call.
The Kufatec unit works independently of the headunit, but the headunit doesn't seen to interact with it otherwise. I'm wondering it has anything to do with the coding in my steering wheel. My car is DSG, yet the steering wheel came coded for a "manual" transmission (as opposed to automatic). The DSG paddles work fine.
I suspect that there is a coding clash that prevents me from enabling the bluetooth coding for the radio. The one interesting thing though is if I play A2DP directly to the Bluetooth from my phone, the audio coming from the radio is paused (as though instructed by CAN).
Is there a chart online that states what the dependency for enabling some coding options are (or there a combination of options that shouldn't be enabled simultaneously)?
sers77
Norway
C?ID=26140
Bluetooth option grayed out on the screen = correct.
New menu in FIS/DIS will get A2DP activated.
Does the oil, coolant, voltage, rpm, boost menu show up in FIS/DIS?
Trowbridge, UK
I seem to remember that the Fiscon Bluetooth module "pretends" to be a 77 Bluetooth module only as far as communicating with e.g. instruments and infotainment - but NOT for coding and diagnostics.
IIRC setting the Fiscon Bluetooth module isn't done via diagnostics, but using other controls in the car.
I think it's worth checking what information Kufatec or Fiscon have available regarding coding and setup.
Maybe this will help http://www.fiscon-mobile.eu/support/img/fiscon_vw_en.pdf
NitrousOxide
Jamaica
C?ID=269481
The menu for the E-MFA does appear and show the vehicle speed and the volume of fuel remaining. The other options are blank for the MK5 (as it is not compatible).
The harness I have is the "Basic" VW model
Viking
C?ID=151455
If it's any use, here's a scan log of my old 2008 Jetta which also had a Fiscon kit fitted. Ignore the faults on the navigation and radio, they were there due to having replaced the RNS510 and they cleared with no errors.
Thursday,15,September,2016,14:40:04:19273
VCDS Version: 16.8.1.3 (x64)
Data version: 20160902 DS256
VIN:    License Plate:
Mileage: 231190km-143654mi   Repair Order:
Scan: 01 03 08 09 15 16 17 19 25 37 42 44 46 52 55 56 62 72 76 77
VIN:    Mileage: 231190km-143654miles
Address 01: Engine        Labels: 03G-906-016-BKD.lbl
   Part No SW: 03G 906 021 PP    HW: 03G 906 021 AN
   Component: R4 2,0L EDC G000SG  4661
   Revision: --H07---    Serial number: VWX7Z0H12430NR
   Coding: 0000072
   Shop #: WSC 00532 210 88420
   VCID: 7CFC8F883FA02EA2F2-8028
000564 - Boost Pressure Regulation
               P0234 - 000 - Limit Exceeded (Overboost Condition) - Intermittent
                    Fault Status: 00110000
                    Fault Frequency: 16
                    Mileage: 227380 km
                    Time: 18:57:58
                    RPM: 2163 /min
                    Speed: 113.0 km/h
                    Load: 34.9 %
                    Voltage: 14.44 V
                    Bin. Bits: 10101000
                    Absolute Pres.: 1499.4 mbar
                    Absolute Pres.: 1836.0 mbar
006481 - Radiator Fan 2 (V177)
               P1951 - 000 - Movement Restricted / Jammed - Intermittent
                    Fault Frequency: 113
                    Mileage: 227900 km
                    Time: 13:33:15
                    RPM: 1974 /min
                    Speed: 86.0 km/h
                    Load: 36.1 %
                    Voltage: 14.29 V
                    Bin. Bits: 00001000
                    Temperature: 90.9°C
                    Duty Cycle: 36.6 %
   Revision: 00H11001
   Coding: 0006786
   Shop #: WSC 00066 000 00000
   VCID: 73EEA4B412FE61DAA3-8026
   Part No SW: 1K0 820 047 HC    HW: 1K0 820 047 HC
   Component: Climatic PQ35   141 1010
   Revision: 00141028    Serial number: 00000000000000
   VCID: 6CDCBFC84FC0BE2262-8038
   Revision: 00H54000    Serial number: 00000000894651
   Coding: E7038E0700041500470A00000F00000000185D035C000108000000000000
   Shop #: WSC 00066 123 12345
   VCID: 71E2AEBC68E253CA51-8024
   Component: Wischer 210208 021  0501
   Coding: 00038805
   Shop #: WSC 00066
   Component: RLS     100108 046  0204
   Coding: 00208933
   Shop #: WSC 00066
   Component: 2K AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1PP03H
   Coding: 0012875
   VCID: 3D7A428C643AE7AA85-8068
   Subsystem 1 - Serial number: 6332MSME377533469
   Subsystem 2 - Serial number: 6342MSME2D64723DM
   Subsystem 3 - Serial number: 6351HSME13162702W
   Subsystem 4 - Serial number: 6361HSME1316320B
   Part No SW: 1K0 953 549 BG    HW: 1K0 953 549 BG
   Component: J0527           051 0100
   Coding: 0002021
   VCID: 78F493980B98028296-802C
   Part No SW: 1K0 920 974 B    HW: 1K0 920 974 B
   Component: KOMBIINSTRUMENT 3HL 2216
   Revision: V0002000    Serial number: VWX7Z0H12430NR
   Coding: 0023403
   Shop #: WSC 35047 001 1048576
   VCID: 2D5A72CCB45A772A35-8078
   Revision:   H07 01    Serial number: 060108F1001550
   Coding: E9817F0E4006021003
   Shop #: WSC 00152 210 91233
   VCID: 30646BB8A3681AC21E-8064
   Component: IMMO            3HL 2216
   Shop #: WSC 00532 210 91380
   Part No SW: 7F0 035 686 A    HW: 7F0 035 686 A
   Component: RNS-MID       H30 6270
   Revision: AB001001    Serial number: VWZ6Z7R6735802
   Coding: 04000400040000010005
   VCID: 2A5079D045B46012D0-807E
   Component: EU West V13  8348
            000 -  -
                    Reset counter: 222
                    Mileage: 220744 km
                    Time: 08:01:33
02877 - Digital Radio Antenna (R183)
                    Reset counter: 222
                    Mileage: 231192 km
                    Time: 17:01:36
                    Fault Status: 00101011
                    Reset counter: 6
01523 - Microphone for Telephone (R38)
                    Reset counter: 222
                    Fault Frequency: 21
                    Reset counter: 6
   Part No SW: 1K0 959 701 Q    HW: 1K0 959 793 M
   Component: J386  TUER-SG FT    1134
   Revision: 31008001    Serial number: 00000515288125
   Coding: 0000692
   VCID: 3C7C4F887F20EEA2B2-8068
   Part No: 1K2 909 144 M
   Component: EPS_ZFLS Kl.070 H08 1901
   VCID: 36685DA0410C34F244-8062
   Coding: 81900A0001060C7F2D04840F7008DFC690FC00
   VCID: 030EF474425E515AB3-8056
   Subsystem 2 - Part No: 1K0 951 178 A
   Component: Neigungssensor  003 0203
   Subsystem 3 - Part No: 1K0 951 178 A
   Component: Innenraumueberw.003 0203
   Part No SW: 1K0 959 702 Q    HW: 1K0 959 792 M
   Component: J387  TUER-SG BT    1134
   Revision: 31008001    Serial number: 00000652888126
   Coding: 0000948
   Coding: 0000003
   VCID: 74ECA7A817F066E2BA-8020
            000 -  -
                    Reset counter: 222
                    Mileage: 220744 km
                    Time: 08:01:33
                    Reset counter: 222
                    Mileage: 231192 km
                    Time: 17:01:36
                    Reset counter: 6
                    Reset counter: 222
                    Fault Frequency: 21
                    Reset counter: 6
   Part No SW: 1K0 959 703 P    HW: 1K0 959 795 G
   Component: J388   TUER-SG HL   1120
   Revision: 11006001    Serial number: 00000002766111
   Coding: 0000144
00098 - Rear Left Central Locking (Safe) Motor (V163)
                    Fault Frequency: 12
                    Reset counter: 222
                    Mileage: 220052 km
                    Reset counter: 7
                    Mileage: 220052 km
   Part No SW: 1K0 959 704 P    HW: 1K0 959 794 G
   Component: J389   TUER-SG HR   1120
   Revision: 11006001    Serial number: 00000002735340
   Coding: 0000144
   VCID: 3E784580693CFCB29C-806A
Address 76: Park Assist        Labels: 1K0-919-283.lbl
   Part No: 1K0 919 283 A
   Component: 12 Einparkhilfe     0101
Address 77: Telephone        Labels: RETROFIT77.lbl
   Part No SW: KTC 364 96P     HW: KTC 364 96P
   Component: SWP:3.24.7      H24 0204
   Shop #: WSC 21977 142 74100
End-------------------------(Elapsed Time: 02:10)--------------------------
NitrousOxide
Jamaica
C?ID=269481
Thanks Viking, I'm going to try this first thing tomorrow.
I've noticed that LCODE.exe no longer opens label files in the newer versions of VCDS so that I can see what your coded options look like (compared to mine).
Would it be fair to say that VCDS can't identify the part number for this "basic" Kufatec unit as opposed to your more sophisticated model and as such it doesn't use the RETROFIT77.lbl file or allow the Radio-56 to be coded to enable the telephone/Bluetooth? As it is now, I can make and receive calls directly using the Red MFD+ and the multi-function steering wheel buttons. However, Bluetooth can't be enabled in the headunit, but it will pause the audio and show me that I'm on a call.
Viking
C?ID=151455
Ah, I see. You've fitted the "Fiscon Basic" which isn't compatible with the RCD510 touchscreen. The "Fiscon Basic Plus" is the one you need to work with your head unit. You can (as you say) make and receive calls using MFD and steering wheel buttons etc. but it'll never integrate with the touchscreen because it's not compatible. As to whether that accounts for the other errors I couldn't say, but that particular hurdle is insurmountable.
NitrousOxide
Jamaica
C?ID=269481
I did a firmware update the other day, hoping that it would improve compatibility.
Since you answered my issue, is there a way to improve the A2DP audio quality? It sounds horrible, but phone calls sound acceptable.
Is there a way to get the undocumented channels for the RCD510? I want to keep the radio on when I switch off the ignition
NitrousOxide
Jamaica
C?ID=269481
One annoying thing about the RCD-510 is that it does this cross-fade between songs (so the volume at the beginning and end of each song is too low to hear.
Can this be adjusted by an adaptation channel? I only see 13 adaptation channels, but most of them have the value "0" and aren't labeled. I tried placing values in each of these channels one by one, but it seems to have no effect on changing the volume or keeping the radio on when the engine is switched off.
Viking
C?ID=151455
I never found the a2dp very good at all
Mind you, I had the RNS510 with 20gb hard drive, 32gb sd card, and used all that for music.
NitrousOxide
Jamaica
C?ID=269481
I have a 4GB SD card in the RCD-510 that I use for playing music. What I wanted A2DP for was to play audio from the movies that I watch on my phone. The thought of having to keep my ignition on to keep the bluetooth running only serves to drain the car battery.
I find it hard to believe that there is no firmware update available for the RCD-510 and it doesn't provide any options to change settings like the RNS-510
