- Sep 5, 2016
- 1,165
- 1,244
- Riga, Latvia
- C?ID=268515
Today I got a really rare car for our region - Audi A4 B5 2,8l MY2001, the NAR version. Problem is with combined oil level/temperature sensor. Sensor fault is displayed and VCDS confirms it. There was some probably cheap noname sensor fitted by another workshop. I have checked wiring to sensor, repaired some suspicious connections but without any results. I tried one new Hella made sensor and two used original ones - all the same. Unfortunately new OEM sensor is not in stock at local dealer.
But I can't believe that all 4 sensors are bad. Wiring is re-checked several times, I have even disconnected original signal wire from IPC T32a, pin 15 and fitted another connector for sensor, in short wires directly to input of IPC. All the same. I have seen in some VW models, that sensor fault for low oil level could not be reset, before IPC "see" than bonnet was opened and closed. At this car switch for opened bonnet was damaged by corrosion, but I fitted another wire directly to IPC input for bonnet switch (T32a, pin 25) to imitate bonnet opening/closing. But LCD in IPC did not show warning for opened bonnet.
We do not have NAR version cars in junkyards here, no way to get another used IPC for testing/replacement.
Do anyone here has similar experience with not working signal inputs for NAR Audi A4 IPC 8D0920980Q? Is it some common know fault four those clusters?
Tuesday,03,January,2017,09:36:24:32442
VCDS Version: 16.8.3.1
Chassis Type: 8D - Audi A4/S4/RS4 B5 (1995 > 2002)
Scan: 01 02 03 08 15 16 17 25 35 37 45 55 56 57 67 75 76 77
Mileage: 229170km-142399miles
Address 01: Engine Labels: 078-907-551-ATQ.lbl
Part No: 3B0 907 551 BP
Component: 2.8L V6/5V G 0001
Coding: 07201
VCID: 72EBB0F73ED19BD2BA-5140
16804 - Catalyst System; Bank 1
P0420 - 35-10 - Efficiency Below Threshold - Intermittent
Address 03: ABS Brakes Labels: 8E0-614-111-EDS.lbl
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Shop #: BB 24334
VCID: 1C37BE4F8CD57DA240-5122
Address 08: Auto HVAC Labels: 8D0-820-043-1D.lbl
Part No: 8D0 820 043 Q
Component: A4 KLIMAAUTOMAT D57
Coding: 00160
Shop #: WSC 06435
VCID: 2E536487EA69FF321E-25A6
Address 15: Airbags Labels: 8D0-959-655-AI8.lbl
Part No: 8D0 959 655 G
Component: Airbag Front+Kopf 1002
Coding: 00304
Shop #: WSC 06435
VCID: 3A7B58D726212392B2-5198
Address 17: Instruments Labels: 8D0-920-xxx-17.lbl
Part No: 8D0 920 980 Q
Component: B5-KOMBIINSTR. VDO D09
Coding: 02062
Shop #: WSC 00006
VCID: 397947DB2327288ABB-5140
30-00 - Open or Short to Plus
Address 35: Centr. Locks Labels: 8D0-862-257.lbl
Part No: 8L0 862 257 N
Component: CV-Pump D11
Coding: 16140
Shop #: WSC 06435
VCID: 408F2A3F40FD7942FC-4F04
01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
35-00 - -
01371 - Alarm triggered by Door Contact Switch; Driver's Side
35-00 - -
01374 - Alarm triggered by Terminal 15
35-00 - -
01365 - Lock/Unlock Switch; Interior
29-00 - Short to Ground
00991 - Interior Lights
28-00 - Short to Plus
00955 - Key 1
09-00 - Adaptation Limit Surpassed
Address 45: Inter. Monitor Labels: 4B0-951-173.lbl
Part No: 4B0 951 173
Component: Innenraumueberw. D03
Coding: 00101
Shop #: WSC 06435
VCID: 60CFCABFE03D1942DC-4B4C
Address 56: Radio Labels: 8D0-035-1xx-56.lbl
Part No: 8D0 035 195 A
Component: Radio D00
Coding: 00204
Shop #: WSC 06435
VCID: 244786AFB4A54562F8-4B00
End-------------------------(Elapsed Time: 04:25)--------------------------
