really lost with voice command on 2010 a5 cabriolet
stang32
C?ID=142010
default module test says voice module not available?
i just got my vag com cable & want to change my voice settings so I can use voice commands in my 2010 cab. the module for voice is said to be not available. does anyone know what thats all about
I also do not have the telephone module available. '
are these only accessed through the can?
I am new to this whole tech system audi uses. I am a professional Automotive tech for 25 years but have been out of practice since 2008
new career.
a little background on my car:
01/15
Default voice button not operative
when I got this car last month, I believe it was working but I did not know to use the mmi system but was fiddling with it & may have hit something I shouldn't have.
when I push the voice command button, nothing happens but on the drivers information system display (between the tach & speedo) it reads "button n used"
anyone have any ideas, I tried resetting the MMI system & no change
01/28
spoke to the previous owner & he confirmed the voice button used to work when he had the car, i am know convinced I did something in playing with the settings to make this now not work. does anyone know what I could have done to make this button not work, other than plugging in a vag com cable & changing default settings?
any help is appreciated!!
here is the autoscan test results
VIN: WAULFAFH0AN013041   Mileage: 51360km/31913miles
Address 01: Engine (DL0MA-CAEB)       Labels: 06H-907-115-CAB.clb
   Part No SW: 8K2 907 115 AA    HW: 8K2 907 115 D
   Component: 2.0l R4/4V TF H15 0003
   Revision: E1H15---
   Coding: 011C010A190F0160
   Shop #: WSC 00000 785 00200
   ASAM Dataset: EV_ECM20TFS8K2907115AA A01004
   ROD: EV_ECM20TFS0118K2907115AL.rod
   VCID: 6ED9EB9AB1CC8D6E79B-803B
Readiness: 1110 0101
Address 02: Auto Trans (J217)       Labels: 0B6-927-156.clb
   Part No SW: 8K0 927 158 J    HW: 0B6 927 156
   Component: 0B6 20TFSIUSA H05 0008
   Revision: --H05---
   Coding: 001012
   ASAM Dataset: EV_TCMAL651 A01006
   ROD: EV_TCMAL651.rod
   VCID: 3D7B1CD6AC2A26F6B01-8068
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379.clb
   Part No SW: 8K0 907 379 CA    HW: 8K0 907 379 CA
   Component: ESP8 quattro  H04 0010
   Coding: 150D18
   Shop #: WSC 08224 016 263172
   VCID: 7AF1D7CAF584D1CED53-802F
   Part No SW: 8K0 907 064 DF    HW: 8K0 907 064 DF
   Component: BCM2 1.1      H02 0326
   Coding: 090300
   Shop #: WSC 02399 823 56573
   VCID: 77F7CEFEC696CCA6AAD-8022
   Subsystem 1 - Part No SW: 8T0 959 754 A    HW: 8T0 959 754 A
Address 06: Seat Mem. Pass (J521)       Labels: 8T0-959-760.clb
   Part No SW: 8T0 959 760 C    HW: 8T0 959 760 C
   Component: MEM-BFS       H10 0074
   Revision: AA000000    Serial number: 00001001353492
   Coding: 08017025002400001000
   Shop #: WSC 02391 823 56573
   VCID: 438F6A2EC2CE5006C65-8016
   Component: KLIMA 3 ZONEN H08 0171
   Revision: C1000000    Serial number: 01061020091077
   Coding: 64132000
   VCID: 8005252213580B1E1B7-80D5
   Component: BCM1 1.0      H25 0380
   Revision: 10025001    Serial number: 00000000474750
   Coding: 26001091063CAF010000080300003D3D0F1C528800010161000000
   VCID: 3C7D11D2BF302FFE87F-8069
   Subsystem 1 - Part No SW: 8F1 955 119     HW: 8K1 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 290909  H06 0021
   Coding: 00FD11
   Component: RLS  H04 0003
   Coding: 02562A
   Subsystem 3 - Part No SW: 8K0 941 531 AN    HW: 8K0 941 531 AN
   Component: E1 - LDS  H08 0090
   Subsystem 4 - Part No SW: 8K0 907 410 B    HW: 8K0 907 410 B
   Component: HOMELINK  H01 0010
Address 10: Park/Steer Assist (J446)       Labels: 8K0-919-475.clb
   Part No SW: 8K0 919 475 H    HW: 8K0 919 475
   Component: PARKHILFE 4K  H06 0050
   Revision: 11001001    Serial number: 39940928100831
   Coding: 200101
   VCID: 3E791BDAA92C3DEEA9B-806B
Address 15: Airbags (J234)       Labels: 8F0-959-655.clb
   Part No SW: 8F0 959 655 A    HW: 8F0 959 655 A
   Component: AirbagVW-AU10 H10 0430
   Serial number: 003A5D0605WV
   Coding: 303737353631303030304A55304C38463053
   Shop #: WSC 02145 785 00200
   ASAM Dataset: EV_AirbaAU10SMEAU485 001004
   ROD: EV_AirbaAU10SMEAU485.rod
   VCID: 366903FA891CF5AE71B-8063
   Subsystem 1 - Part No SW: 8K0 959 339     HW: 8K0 959 339
   Component: BF-Gewichtss.  H01 0050
   Serial number: 5810000R0900004599
   Serial number: 6334MSME4B623770D
   Serial number: 6344MSME4B6332249
   Serial number: 6352QSME063D04025
   Serial number: 6362QSME2C3B3B30N
   Serial number: 63732SME273B3B02
   Crash sensor for front airbag; passenger side:
   Serial number: 63832SME443C3C1C8
   Revision: --------    Serial number: 90319IJ50007T
   Coding: 000016
   VCID: 3D7B1CD6A42A26F6B01-8068
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8T0 920 981 J    HW: 8T0 920 981 J
   Component: KOMBIINSTR.   H34 0255
   Revision: 00000000    Serial number: CI074NX99
   Coding: 8B1619000300D705020000
   Part No SW: 8T0 907 468 T    HW: 8T0 907 468 K
   Component: GW-BEM 4CAN-M H09 0105
   Revision: EB800053    Serial number: 5300E09928820D
   Coding: 00C303
   VCID: 52A15F6A0DB4C98E7D3-8007
   Component: J367-BDM  H06 0170
Address 26: Auto Roof (J256)       Labels: 8F0-959-255.clb
   Part No SW: 8F0 959 255     HW: 8F0 959 255
   Component: VSG-AUDI-B8   H09 0170
   Coding: 030000
   ASAM Dataset: EV_ElectRoofContr 001007
   ROD: EV_ElectRoofContr.rod
   VCID: F1E370E620F21296E49-80A4
Address 36: Seat Mem. Drvr (J136)       Labels: 8T0-959-760.clb
   Component: MEM-FS        H10 0074
   Revision: AA000000    Serial number: 00001010019378
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 H    HW: 8K0 959 793 D
   Component: TSG FA        H11 0306
   Revision:             Serial number: 0000009436212
   Coding: 011C43724008332C03
   VCID: 458B7436CCFA6E36E81-8010
   Revision: 00002001    Serial number: 0121941364
   Coding: 010602BA007A442000B0030000000000
   Subsystem 1 - Part No SW: 8F0 959 719     HW: 8F0 959 719
   Component: GTO BF  H06 0050
   Part No SW: 8F0 035 223 C    HW: 8F0 035 223 C
   Component: DSP Prem      H08 0170
   Revision: 00008001    Serial number: 34862000452402
   VCID: 2045C5A233986B1EBB7-8075
                    Reset counter: 120
                    Voltage: 11.60 V
                    Temperature: 30.0°C
                    Temperature: 37.0°C
                    Bin. Bits: 00000100
                    Bin. Bits: 00001000
                    Bin. Bits: 00000000
   Part No SW: 8K0 959 792 H    HW: 8K0 959 792 D
   Revision:             Serial number: 0000009449626
   Coding: 011C43324008332C03
   VCID: 448D6932C7C0573EFFF-8011
   Revision: 00000003    Serial number: 10000000331362
   VCID: 346D39F29760E7BE4FF-8061
Address 55: Xenon Range        Labels: 8K0-907-357.clb
   Part No: 8K5 907 357
   Coding: 0000002
   VCID: F7F74EFE86964CA62AD-80A2
   Part No SW: 4F0 035 082 A    HW: 4F0 035 082
   Component: Radio U SIRIU H45 0021
   Revision: AB001007    Serial number: 335IR097531304
   Coding: 020000010000000101
   VCID: 1D3BFC5604EA46F6901-8048
00003 - Control Module
                    Fault Status: 00101110
                    Mileage: 50471 km
                    Date: 2014.02.22
                    Time: 11:43:55
                    Bin. Bits: 00000000 00001000
                    Fault Frequency: 13
                    Reset counter: 120
                    Mileage: 51365 km
                    Date: 2014.03.04
                    Time: 13:14:16
                    Bin. Bits: 00000001 11111100
   Part No SW: 8T1 035 664 A    HW: 8T1 035 664 A
   Component: H-BN-NA       H41 0042
   Revision: --------    Serial number: 490J$097519532
   Coding: 010200030006A1EF01000B0E004001010100
   VCID: 366903FA811CF5AE71B-8063
   Subsystem 1 - Part No: 8R0 060 884 F
   Component: NAR 2009/2010  5304
   Component: DU7 High  H43 0306
   Subsystem 3 - Part No SW: 8T0 919 609 F    HW: 8T0 919 609 F
   Component: CD-Database  1293
                    Fault Frequency: 12
                    Reset counter: 120
                    Mileage: 51365 km
                    Date: 2014.03.04
                    Time: 13:14:16
                    Bin. Bits: 10111110 10000010
                    Bin. Bits: 00000000 00001110
                    Bin. Bits: 00000000 00000000
02452 - Multimedia Display Unit Rear Left (Y22)
                    Reset counter: 80
                    Mileage: 51365 km
                    Date: 2014.03.04
                    Time: 12:38:03
                    Voltage: 12.00 V
                    Reset counter: 120
                    Mileage: 51365 km
                    Date: 2014.03.04
                    Time: 13:14:16
                    Bin. Bits: 00100001 00010000
                    Bin. Bits: 00000000 00001010
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 E    HW: 4F0 959 795 L
   Revision:             Serial number: 0000102005812
   Coding: 010C03324008372C03
   Part No SW: 8F0 907 441     HW: 4L0 907 441 B
   Revision: --H03---    Serial number: 525PA8-J99B04F
   Coding: 1000009
   VCID: E7D71EBED636DC26BAD-80B2
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-795.clb
   Revision:             Serial number: 0000102005037
I'm not that familiar with the 3rd-generation MMI system myself. Audi took a lot of the stuff that used to be in separate modules and stuffed it all into 5F: Information Electronics (J794). Whether that includes voice command, I'm not sure. Someone who knows this better than me will have to chime in here.
stang32
C?ID=142010
Thank you for the guidance, all it took was putting me on the right route to a correct link
i appreciate you guys a lot!!!
