2012 Audi Q7 modification help sought
Honeyridges
C?ID=210401
Hi
I'm new to the forum (this is my first post) and I'd appreciate any assistance that can be given with using VCDS to achieve a few mods to my 2012 Audi Q7 (4L). I've used VCDS to modify previous vehicles (two VW Golfs, and Audi A3 & and Audi A5) so know my way around the software, but am struggling to find the necessary Codings and Adaptations to achieve those same mods on the Q7.
In short, this is what I'm looking to achieve:
  • Alarm double-chirp on remote unlock
    I've got the single chirp on remote locking working, but would like to also have the vehicle double-chirp when unlocked by remote.
  • Passenger mirror down when reverse selected
    I've tried a Coding I found online (52 - Door Elec, Pass-> Change Byte 4, set Bit 2: Reverse Gear Mirror Dipping Active) and that causes the mirror to drop - but by the tiniest amount (making it pointless). I was wondering if an adaptation exists that defines how far the mirror drops, or whether a different Coding exists to fully achieve the result I'm after?
  • Disable comfort turn signals
    Currently nudging the indicator stalk briefly results in 3 blinks of the indicators. I'd like to be able to disable this feature - or set the number of blinks to 1 (same thing I suppose).
  • Auto folding mirrors
    The mirrors fold when the mirror control knob is turned to the 6 O'clock position, but I'd like them to do this automatically when I turn the ignition off, and unfold automatically when the ignition is switched back on.
The Autoscan output for this vehicle is below - if anyone does know of settings I can change to achieve any of the above I'd be very grateful to hear from you.
Brian
Wednesday,09,July,2014,10:20:27:35786
VCDS Version: 12.12.2.0 (x64)
Data version: 20140212
VIN: WAUZZZ4L2XXnnnnnn   License Plate: XXnnXXX
Mileage: 37120km-23065mi   Repair Order:
Chassis Type: 4L (4F0)
Scan: 01 02 03 05 08 09 15 16 17 18 19 34 3D 42 46 4F 52 55 56 5F
          62 6C 6D 6F 72 76
VIN: WAUZZZ4L2CD027233   Mileage: 37120km/23065miles
3D-Special Function -- Status: OK 0000
55-Xenon Range -- Status: Malfunction 0010
Address 01: Engine (J623-CRCA)       Labels: None
   Part No SW: 4L2 910 401 B    HW: 4L0 907 401 C
   Component: 3.0TDI EDC17  H37 0001
   Revision: 53H37---    Serial number:
   Coding: 2A2A4012A52701020000
   Shop #: WSC 31414 790 00001
   ASAM Dataset: EV_ECM30TDI0114L2910401B 001001
   ROD: EV_ECM30TDI0114L1910401H.rod
   VCID: 2345E0A62A5E3206A65-8076
Address 02: Auto Trans (J217)       Labels: 0C8-927-750.clb
   Part No SW: 0C8 927 750 AL    HW: 0C8 927 750 AL
   Component: AL1000 AISIN  001 1977
   Coding: 001578
   Shop #: WSC 30222 000 1048576
   ASAM Dataset: EV_TCMAL991031 001001
   ROD: EV_TCMAL991031.rod
   VCID: 76E3E9F2C94CF7AEB1B-8023
Address 03: ABS Brakes        Labels: 4L0-910-517.clb
   Part No SW: 4L0 910 517 M    HW: 4L0 614 517 L
   Revision: 00H02001
   Coding: 2200689
   VCID: 346713FA57B0A5BE4FF-8061
Address 05: Acc/Start Auth.        Labels: 4F0-910-852.clb
   Part No SW: 4F0 910 852 B    HW: 4F0 905 852 H
   Component: FBSAUDIC6 ELV   H07 0200
   Revision: 00H07000    Serial number: 10603501944062
   Coding: 0000211
   VCID: 2541FEBEEC6ACC36C81-8070
   Subsystem 1 - Part No: 4F0 910 132 E
   Component: FBSAUDIC6 EZS   H03 0020
   Subsystem 2 - Part No: 4F0 910 220 D
   Component: FBSAUDIC6 IDG   H01 0054
   Part No SW: 4L0 910 043 D    HW: 4L0 820 043 AH
   Revision: 00---026    Serial number: 00000030224956
   Coding: 01009416
   VCID: 2541FEBE2C6ACC36C81-8070
   Part No SW: 4F0 910 279 AH    HW: 4F0 907 279 D
   Component: ILM Fahrer      H31 0400
   Coding: 0033121
   VCID: 6FEDDC967E16C66672D-803A
   Subsystem 1 - Part No: 4L2 910 113   Labels: 1KX-955-119.CLB
   Component: Wischer AU716   H13 0110
   Coding: 00064792
   Shop #: WSC 31414
   Coding: 00150059
   Shop #: WSC 31414
   Part No SW: 4L0 910 655 D    HW: 4L0 959 655 C
   Component: 71 AIRBAG AUDI8RH43 0230
   Revision: 04H43000    Serial number: 00399D08PEGB
   Coding: 0014129
   VCID: 2E530192B99C8F6E39B-807B
   Subsystem 1 - Serial number: 6332QSME126A4E44K
   Subsystem 2 - Serial number: 6342QSME7367384CQ
   Subsystem 3 - Serial number: 6352QSME126A2F52K
   Subsystem 4 - Serial number: 6362QSME106A3A64I
   Subsystem 5 - Serial number: 63734SME03674748/
   Subsystem 6 - Serial number: 63834SME0C64265A4
   Part No SW: 4F0 910 549 B    HW: 4F0 953 549 E
   Component: J0527               0830
   Revision: 00H08000    Serial number: 90055113400203
   Coding: 0102142
   VCID: 285FF78A9B78D15EF37-807D
   Component: E0221           H03 0030
Address 17: Instruments (J285)       Labels: 4L0-920-xxx-17.clb
   Part No SW: 4L0 920 984 P    HW: 4L0 920 984 P
   Component: KOMBIINSTR.   H22 0411
   Revision: 00200000    Serial number: LMX009P1D
   Coding: 3357630408012600010404
   VCID: 408F4F2AD308091EDB7-8015
Address 18: Aux. Heat        Labels: None
   Part No SW: 4L0 910 105     HW: 4L0 815 071 G
   Component: Heizgeraet      H09 0140
   Revision: 0000000C    Serial number: 00000009021078
   Coding: 0000101
   VCID: E0CF2FAA33C8E91E7B7-80B5
Address 19: CAN Gateway (J533)       Labels: 4F0-907-468.clb
   Part No SW: 4F0 907 468 R    HW: 4F0 907 468 F
   Component: GW-BEM 4CAN-M H06 0057
   Revision: LB500035    Serial number: 3500L12105019D
   Coding: 00CF07
   VCID: 3E7331D2A9FC7FEEA9B-806B
   Component: J367-BDM  H07 0125
Address 34: Level Control        Labels: None
   Part No SW: 4L0 910 553 H    HW: 4L0 907 553 E
   Component: LUFTFDR.-CDC    H04 7870
   Revision: --H04001    Serial number: 15.1528-0150.2
   Coding: 0015510
   VCID: 2F6D1C96BE96866632D-807A
01577 - Turn-Off due to Over-Temp
                    Fault Status: 00100001
                    Fault Frequency: 9
                    Reset counter: 243
                    Mileage: 34193 km
                    Date: 2014.05.18
                    Time: 15:28:32
                    Error Code: 68
Address 3D: Special Function        Labels: 8K0-907-440.clb
   Part No SW: 8K0 907 440     HW: 8K0 907 440
   Component: STS             H04 0040
   Revision: S0H04000    Serial number: 00000000052699
   Coding: 01010101000000000001000202
   VCID: EBD54886CA0EBA46DE5-80BE
Address 42: Door Elect, Driver (J386)       Labels: 4F0-959-793.clb
   Part No SW: 4F0 959 793 T    HW: 8K0 959 793 M
   Component: TSG FA        H12 0362
   Revision:             Serial number: 0000020155664
   Coding: 011F06205061440004
   VCID: 489F570AFB38315E137-801D
Address 46: Central Conv.        Labels: 4L0-910-289.lbl
   Part No SW: 4L0 910 289 H    HW: 4L0 907 289 H
   Component: Komfortgeraet   H10 0110
   Revision: 0110 ---    Serial number: 01637562410000
   Coding: 4073723
   VCID: 35612EFE5CCABCB6781-8060
   Subsystem 2 - Part No: 4F0 910 177
   Component: Innenraumueberw.H01 0020
   Part No SW: 4F0 910 280     HW: 4F0 907 280 E
   Component: ILM Beifahrer   H16 0100
   Revision:             Serial number: 00000000265553
   Coding: 0011101
   VCID: DEB3115209BCDFEE49B-808B
Address 52: Door Elect, Pass. (J387)       Labels: 4F0-959-792.clb
   Part No SW: 4F0 959 792 T    HW: 8K0 959 792 M
   Component: TSG BF        H12 0362
   Revision:             Serial number: 0000020164785
   Shop #: WSC 30222 123 104857
   VCID: 479D5436F6263E261AD-8012
01964 - Control Module for Seat & Steering Column Memory (J136)
                    Reset counter: 243
                    Mileage: 36921 km
                    Date: 2014.07.06
                    Time: 16:07:04
Address 55: Xenon Range        Labels: 4F0-910-357.lbl
   Part No SW: 4L0 910 357 B    HW: 4L0 907 357 B
   Coding: 0000032
   VCID: 2B5508868A8EFA461E5-807E
02988 - Left-Hand/Right-Hand Traffic Switchover Active
            000 - - - MIL ON
                    Fault Status: 11100000
                    Reset counter: 154
                    Mileage: 33036 km
                    Date: 2014.04.29
                    Time: 12:25:46
   Part No SW: 4G0 035 056 E    HW: 4G0 035 056
   Component: Radio U STD   H60 0093
   Revision: AB001007    Serial number: 230AN0C7527413
   Coding: 010003020100000000
   VCID: 2345E0A6225E3206A65-8076
   Part No SW: 4L2 035 670 A    HW: 4L2 035 670
   Component: H-BNT-EU      H43 0467
   Revision: --------    Serial number: 075AY0C7506069
   Coding: 180101060004D3FF01000355EF632003040000000100000000
   VCID: 285FF78A5B78D15EF37-807D
   Subsystem 1 - Part No: 8R0 060 884 BK
   Component: EUR 2014  1703
   Subsystem 2 - Part No SW: 8R0 919 604     HW: 8R0 919 604
   Component: DU7 High  H41 0104
   Subsystem 3 - Part No SW: 4L0 919 614 B    HW: 4L0 919 614 B
   Component: E0380 Bedient  H01 0060
   Subsystem 4 - Part No: 8R0 060 961 C
   Component: CD-Database  3638
                    Reset counter: 197
                    Mileage: 36265 km
                    Date: 2014.06.21
                    Time: 12:42:34
                    Text: DUA130,Front,M,0,0,6
Address 62: Door, Rear Left (J388)       Labels: 4F0-959-795.clb
   Part No SW: 4F0 959 795 P    HW: 4F0 959 795 P
   Component: TSG HL        H11 0362
   Revision:             Serial number: 0000020674308
   Coding: 010E06204061230004
   VCID: 46835932F12C272EE1B-8013
                    Reset counter: 225
                    Mileage: 35173 km
                    Date: 2014.06.03
                    Time: 18:08:46
   Part No SW: 4L0 910 441 C    HW: 8T0 907 441 D
   Component: J772__Rearview      0130
   Revision: --H06---    Serial number: 525PA8-J21402G
   Coding: 1021001
   VCID: 2643F9B2916CC72EC1B-8073
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 4L0 910 945     HW: 4L0 827 851 E
   Revision: --H57001    Serial number: E5030000B
   Shop #: WSC 98765 666 38354
   VCID: ECD74B9ACF00BD7ED7F-80B9
   Subsystem 3 - Serial number: RD18.01.12--H57001001A0046ÿ
   Subsystem 4 - Serial number: 1A0046ÿ
Address 6F: Centr. Conv. II        Labels: 4L0-910-290.lbl
   Component: ILM HINTEN 2    H08 0080
   Revision: AAH08080    Serial number: 122518954-----
   Coding: 0003587
   Component: J_245_EE16_SKB10H12 0220
   Component: J_394_EE16_SKB10H12 0220
   Component: J_392_EE16_SKB10H12 0220
Address 72: Door, Rear Right (J389)       Labels: 4F0-959-795.clb
   Component: TSG HR        H11 0362
   Revision:             Serial number: 0000020674306
   Part No SW: 4L0 910 283 E    HW: 4L0 919 283 E
   Component: Parkhilfe 8-Kan H03 0100
   Revision: 00H03000    Serial number: 37361200300925
   Coding: 0221066
   VCID: 2C570B9A8F80FD7E17F-8079
Honeyridges
C?ID=210401
Thanks for this info Andy - I appreciate it. It's disappointing to learn that the more modern Q7 can't be tweaked in the same way as the older A5, but that's life I suppose - there are people with worse problems!
Thanks again.
Brian
Uh, the Audi Q7 was introduced in 2005. Mechanically, it was derived from the 7L Touareg/Cayenne platform, and from a electronics perspective, the systems in it are fairly closely related to the 4E A8 and 4F A6, which are also somewhat older. The Audi A5 was introduced in 2007, the first of Audi's new modular longitudinal platform, and many of the system in it were brand new at that point.
Honeyridges
C?ID=210401
Interesting - thanks for that extra information. I suppose once a model is introduced they don't radically change the design - even the electronics systems - throughout the model lifespan, even for 'facelift' models, so what you're saying makes a lot of sense.
Do you know - are the various Coding and Adaptation tweaks that "become widely known" the result of trial and error by either Ross-Tech or independent enthusiasts, or are they obtained from the manufacturer somehow? I mean, Audi themselves must know the purpose of each and every bit of every byte in each module they use in their vehicles, but presumably they guard that information quite jealously? I would guess they have no reason to make it public.
Anyway, thanks again for the information - it explains why the Q7 doesn't lend itself to VCDS tweaking as well as some of the other vehicles from VW/Audi.
Some stuff (but by no means all) is documented within the factory's tools, some is obtained through trial and error, and some stuff leaks from the factory in other ways.
Right -- they see no benefit in making it public.
Honeyridges
C?ID=210401
Thanks again for the info - very helpful.
