2017 GTI 2.0 TSI MQB CXCB (Performance Pack)
Royski
I did get
No ASAM data for: "EV_ECM20TFS0205G0906259L" (VW37)
but haven't yet tried the beta version of the software.
I wonder if the "Function Restricted due to Interrupted Communications" fault might be because I had the radio playing? Everything seems fine despite that. The other error is because I did not pay to continue the satellite radio :p
Thursday,29,December,2016,12:17:29:04963
VCDS Version: 16.8.4.2 (x64)
VIN: 3VW547AU6HM005309   License Plate:
Mileage: 2708km-1682mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 03 05 08 09 15 16 17 19 2B 32 42 44 52 55 5F 75 A9
VIN: 3VW547AU6HM005309   Mileage: 2708km-1682miles
Address 01: Engine (J623-CXCB)       Labels: None
   Part No SW: 5G0 906 259 L    HW: 06K 907 425 B
   Component: 2.0l R4 TFSI  H13 0001
   Revision: --H13---
   Coding: 091900122424002F1000
   Shop #: WSC 00066 790 00226
   ASAM Dataset: EV_ECM20TFS0205G0906259L 001003
   ROD: N/A
   VCID: 3753C5178E5EE7FA38-8062
   Part No SW: 5Q0 614 517 AF    HW: 5Q0 614 517 AF
   Component: ESC           H62 0398
   Revision: 00000000    Serial number: 51646000002091
   Coding: 01FA6BA154200971407A020041CC6880D62A90024082163600430051C00903
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
   ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
   VCID: 75CF0F1FD4D255EAEA-8020
   Part No SW: 5Q0 959 435 B    HW: 5Q0 959 435
   Component: VWKESSYMQB    021 0710
   Revision: 00021000    Serial number: 0407733847
   Coding: 032C0C
   VCID: 3B5BD927B276C39ADC-806E
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5GM 907 426 C    HW: 5GM 907 426 C
   Component: AC Manuell    H03 1601
   Revision: 00001K03
   Coding: 00020004200100000000000000000002
   ASAM Dataset: EV_ACManueBHBVW37X 004132
   ROD: EV_ACManueBHBVW37X_002_VW37.rod
   VCID: 48B1B6EBF3A0980241-801C
Address 09: Cent. Elect. (J519)       Labels: 5Q0-937-08X-MV1.clb
   Part No SW: 5Q0 937 087 AA    HW: 5Q0 937 087 AA
   Revision: --------    Serial number: 865801071600E6
   Coding: 00010A464041A04169E44000001407201800000000000000000000000000
   ROD: EV_BCMBOSCH_016_AU37.rod
   VCID: 7AD51C23FDCC3A9287-802E
   Component: WWS    160422  043 0581
   Serial number:         160716120133
   Serial number: 003GCR0539G5
   VCID: 47B3B5D7FEBE977A48-8012
   Occupant Detection:
   Component: BF-Gewichtss.  H12 0021
   Serial number: IBH000000000005GSFF$
   Coding: 30305A
   Subsystem 2 - Part No SW: -----------    HW: 480 000 306 16
   Serial number: 3570000000063D61AB1N
   Subsystem 3 - Part No SW: -----------    HW: 480 000 306 16
   Serial number: 358000000004F051AB1K
   Subsystem 4 - Part No SW: -----------    HW: 480 403 105 16
   Serial number: 3510002C9205729281C.
   Subsystem 5 - Part No SW: -----------    HW: 480 403 105 16
   Serial number: 3520002C92057292437V
   Subsystem 6 - Part No SW: -----------    HW: 480 401 406 16
   Serial number: 3550002BB21160C3223Q
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 401 406 16
   Serial number: 3560002BB21160C352F%
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 AT    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0195
   Revision: FF033033    Serial number: 20160607400210
   Coding: 0400
   Shop #: WSC 66564 385 16448
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 042962DB8F087C62ED-8050
   Part No SW: 5G1 920 856 B    HW: 5G1 920 856 B
   Component: KOMBI         344 8311
   Coding: 0BAD0912A980CF0502086A001000000000000000
   VCID: 2D7FE77F7C025D2A52-8078
          U1110 00 [008] - -
                    Fault Frequency: 33
                    Reset counter: 183
                    Mileage: 25 km
                    Date: 2016.08.31
                    Time: 12:09:21
   Part No SW: 5Q0 907 530 AM    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2265
   Revision: --------    Serial number: 09061610520172
   Coding: 0101000830085900FB00002B080F00000001050000000000000000000000
   Shop #: WSC 00066 790 00199
   ROD: EV_GatewConti_013.rod
   VCID: 7CD91A3BF7F804A295-8028
   Subsystem 2 - Part No SW: 5G0 959 442 Q    HW: 5G0 959 442 Q
   Component: E221__MFL-DC1  H11 0103
   Serial number: 29160000854240026172
   Coding: 30FFFF
   Revision: 00000000    Serial number: 16000096317009
   Coding: 5500000000000000
   ROD: EV_ELVMarquMQB_SK25.rod
   VCID: 3449F21B9F280CE21D-8060
Address 32: Differential Locks (J492)       Labels: 0CQ-907-554.clb
   Part No SW: 0CQ 907 554 E    HW: 0CQ 907 554 E
   Component: Quersperre    H52 8042
   Serial number: HA1-00009.05.16
   Coding: 0001
   ASAM Dataset: EV_LockElectHA1VW37X 001007
   ROD: EV_LockElectHA1VW37X.rod
   Serial number: 08071606050160
   Coding: 003E13200000020000000000
   VCID: 43ABA1C7CA86BB5A94-8016
   Subsystem 1 - Part No SW: 5Q4 959 811 D    HW: 5Q4 959 811 D
   Serial number: 00000000000013099692
   Coding: 011000
   Coding: 8102
   ROD: EV_SteerAssisMQB_013.rod
   VCID: 3A55DC23BD4CFA92C7-806E
   Serial number: 28061606050A3W
   VCID: 42A5A4C3D59CB2529F-8016
   Subsystem 1 - Part No SW: 5Q4 959 812 D    HW: 5Q4 959 812 D
   Serial number: 00000000000003696844
   Coding: 091000
   Coding: 021801010B000400
   VCID: 40A1AECBDB90A04289-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD2.clb
   Part No SW: 3Q0 035 844 A    HW: 3Q0 035 844 A
   Component: MU-S-S-US     710 0751
   Coding: 02730000FF00000051220001001808009F0203D40120010002
   ROD: EV_MUStd4CDELP_VW26.rod
   Subsystem 1 - Part No SW: 3G0 919 605 H    HW: 3G0 919 605 H
   Component: ABT_Std-2  H53 1031
   Serial number: VWZ8Z9SJW00RCA
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 132
                    Mileage: 1987 km
                    Date: 2016.12.02
                    Time: 08:52:54
                    Voltage terminal 30: 14.4 V
                    SDARS_tuner_status_2-Satellite radio antenna status: Electrical OK
                    SDARS_tuner_status_2-Audio Signal: Available
                    SDARS_tuner_status_2-Antenna current: 135 mA
                    SDARS_tuner_status_2-Reception quality: optimum_signal
                    SDARS_tuner_status_2-Tuner fr Satellitenradio: Status der Voraktivierung: 05
                    SDARS_tuner_status_2-Tuner fr Satellitenradio: Wert der Voraktivierung: 05
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Component: OCULowMQBUS   007 0568
   Coding: 02730002C2821A017F1E06000000
   ROD: EV_OCULowMQB.rod
   Component: SAS-GEN 2     H06 0014
   Serial number: 160505201506
   VCID: 6BFB29678296931A0C-803E
End-------------------------(Elapsed Time: 03:18)--------------------------
We're working on updated data for some of these 2017 ECUs. Can't promise a date though.
