OEM Bi Xenon Retrofit Golf 7 mk7 TDI
   #41
m87a
Bosnia and Herzegovina
C?ID=156900
first you need to code properly AFS, because you have dtc 13636608 - Control Module Incorrectly Coded, it will never code headlights, thus you have dtc's Power Output Module for Left/Right Headlamp, missing basic settings will be cleared after you do basic settings but in order to perform basic settings you need properly coded afs module and headlights.
9574144/9574400 - Bulb for Low Beam Headlamp Left/Rights tell's me that you still have coded halogen bulb's instead xenon, thus dtc
databus missing message, did you check in gateway is extended can activated? also you seem to be missing basic settings in gateway? don't have any idea about that one, didn't play with mk7 gateway
GDM8085
C?ID=86403
Sorry for my ignorance. How do I check this?
Thanks-you for your help. It is very much appreciated
   #43
m87a
C?ID=156900
in mk6 it was adaptation -> channel 17 extended can dissabled/activated, can tell if it's same in mk7, could be
   #44
GDM8085
C?ID=86403
OK, as mentioned before, any progress is GOOD progress! Thanks to everyone for all your help with this. After much time and coding, I have been slowly eliminating one DTC at a time. I am at a bit of a roadblock with the current DTCs though. The right headlight high beam shutter still does not function. I did test it with 12v and it does work. I have it wired to pin 11 on plug B of the BCM. (I think this is correct) Also, i now have the headlights coded to the point that they come back on by themselves when the flicker out about every 50 seconds. Before they would flicker out and stay out.
Thanks to m87a for this information:
This cleared a few more DTCs.
Here is another AutoScan. Please feel free to say if I am posting too many autoscans...lol
Thursday,12,January,2017,14:28:18:54491
VCDS Version: 16.8.4.2 (x64)
VIN: 3VWRA7AU4FM012217   License Plate:
Chassis Type: AU (5Q0)
Scan: 01 03 08 09 15 16 17 19 42 44 52 55 5F 75
VIN: 3VWRA7AU4FM012217   Mileage: 85838km-53337miles
Address 01: Engine (J623-CRUA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8412
   Revision: 85H23---
   Coding: 01190012032410080000
   Shop #: WSC 44642 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021C 001012
   ROD: EV_ECM20TDI01104L906021C.rod
   VCID: 254192032435DD6A9A-8070
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [167] - -
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    Engine speed: 0.00 /min
                    Coolant temperature: 24 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.240 V
                    ACC variants-Bit 0: 0
                    CCS Switch-Bit 0: 1
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 32
                    ACC variants (coding)-Bit 0: 1
                    Acceleration: 0.000 m/s²
Readiness: 0 0 0 1 1
   Part No SW: 5Q0 907 379 K    HW: 5Q0 907 379 F
   Component: ESC           H31 0371
   Revision: 00000000    Serial number: 51534000001113
   Coding: 01FA6AA12421096E0079020181CA2580562490004081A4B200630050C002
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 44872F87CF4F0462AD-8010
Address 08: Auto HVAC (J301)       Labels: 5G0-907-426.clb
   Part No SW: 5G0 907 426 Q    HW: 5G0 907 426 Q
   Component: AC Manuell    H02 0907
   Revision: 00001K06
   Coding: 00020104200100000000000000000000
   ROD: EV_ACManueBHBVW37X_SK48.rod
   VCID: 39794E73B88D498ACE-806C
   Part No SW: 5Q0 937 087 S    HW: 5Q0 937 087 S
   Revision: --------    Serial number: 86582111142168
   Coding: 00000A024041A14169E44000000403001000000000000000000000000000
   ROD: EV_BCMBOSCH_014.rod
   VCID: 4B9504BBE211CB1A6C-801E
   Component: WWS    140528  043 0581
   Serial number:         140627183908
9994 - Bulb for Right Parking Lamp
          B12E9 15 [009] - Open or Short to Plus
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
9738 - Bulb for Left Parking Lamp
          B12E8 15 [009] - Open or Short to Plus
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
919810 - Dimmer Control for Instrument Panel Illumination
          B1201 21 [009] - Signal Amplitude Too Low
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
   Part No SW: 5Q0 959 655 T    HW: 5Q0 959 655 T
   Serial number: 003MHM00CRR1
   VCID: 51A916D3003DE1CA16-8004
   Occupant Detection:
   Subsystem 1 - Part No SW: 4M0 959 339 A    HW: 4M0 959 339 A
   Component: BF-Gewichtss.  H05 0016
   Serial number: IBH0000J140000VAMU0Y
   Coding: 303338
   Subsystem 2 - Part No SW: -----------    HW: 480 002 904 14
   Serial number: 35700000000F55FCBF07
   Subsystem 3 - Part No SW: -----------    HW: 480 000 705 14
   Serial number: 358000000002F461BF0R
   Subsystem 4 - Part No SW: -----------    HW: 480 401 704 14
   Serial number: 3510002AB1529DF430B9
   Subsystem 5 - Part No SW: -----------    HW: 480 402 304 14
   Serial number: 3520002A7157E991C39D
   Subsystem 6 - Part No SW: -----------    HW: 480 400 205 14
   Serial number: 3550002BF157E995B17O
   Front Sensor Passenger:
   Subsystem 7 - Part No SW: -----------    HW: 480 400 205 14
   Serial number: 3560002B715C4211A1D+
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 569 A    HW: 5Q0 953 569 A
   Revision: --------    Serial number: 20140826400751
   Coding: 0400
   ASAM Dataset: EV_SMLSVALEOMQB 001010
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 3C775767B7BF7CA2D5-8068
   Part No SW: 5G1 920 841     HW: 5G1 920 841
   Component: KOMBI         243 4270
   Coding: 0BB41A022980CF05020868001000000000000000
   Shop #: WSC 48614 001 1048576
   VCID: 65C1D20364B51D6A5A-8030
   Revision: --------    Serial number: 01101410802759
   Coding: 01010008000873008000000A080100000000050000000000000000000000
   ROD: EV_GatewConti_011.rod
   VCID: 72EBB95FA57BFAD2CF-8026
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P
   Component: E221__MFL-DC1  H14 0101
   Serial number: 29140000815270014193
   Coding: 28FFFF
   Part No SW: 5Q0 959 393 B    HW: 5Q0 959 393 B
   Serial number: 08061406050535
   Coding: 003003200000040000000000
   VCID: 3E735D6FA1A36EB2FB-806A
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000002833084
   Coding: 011000
   Component: EPS_MQB_ZFLS  122 1043
   Coding: 0102
   Shop #: WSC 00066 790 00221
   ROD: EV_SteerAssisMQB_010.rod
   VCID: 41892693D05D114A86-8014
   Part No SW: 5Q0 959 392 B    HW: 5Q0 959 392 B
   Serial number: 090614060503R1
   VCID: 3D715A63ACA575AAE2-8068
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000002671145
   Coding: 191000
   Coding: 029A00000B000200
   VCID: 408F2397DB57184289-8014
   Subsystem 1 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H01 0004
   Coding: 2E0000
   Subsystem 2 - Part No SW: 5N0 941 329     HW: 5N0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H01 0004
   Coding: 2E0000
13705478 - Databus
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:35
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-STD1.clb
   Part No SW: 5G0 035 844     HW: 5G0 035 844
   Component: MU-S-S-US     013 0645
   Serial number: V7B00905142012
   Coding: 02730000FF00000021220001001800001F0100040100010002
   Shop #: WSC 00066 790 07025
   ROD: EV_MUStd4CPASE_VW37.rod
   VCID: 64C7CF076F8F64624D-8030
   Subsystem 1 - Part No SW: 5G0 919 605 H    HW: 5G0 919 605 H
   Component: ABT_Std_Plus  H60 0030
   Serial number: VWZ8Z9PS50076E
0020 - Tuner for Satelite Radio
          B11CF 53 [009] - Deactivated
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    Voltage terminal 30: 13.0 V
                    Satellite radio tuner status-Satellite radio antenna status: Electrical OK
                    Satellite radio tuner status-SDARS Flash Regional code: US_Audio_Traffic_Travellink
Address 75: Telematics (J949)       Labels: 5QE-035-285.clb
   Part No SW: 5QE 035 285     HW: 5QE 035 285
   Component: OCULowMQBUS   006 0528
   Coding: 02730002C2821A017F1E06000000
   Shop #: WSC 00066 790 00020
   ROD: EV_OCULowMQB.rod
   VCID: 020BE99F95DBCA52DF-8056
End-------------------------(Elapsed Time: 03:34)--------------------------
m87a
C?ID=156900
ok so i have founded some coding for bi xenon, it's not mine nor tested, so first save your values and give it a try ;)
Left Low Beam:
(1)-Leuchte6ABL LC5-Lasttyp 6 --> 3 - Xenon Abblendlicht
(5)-Leuchte6ABL LC5-Lichtfunktion B 6 --> Lichthupe generell
(6)-Leuchte6ABL LC5-Dimmwert AB 6 --> 127
Right low beam:
(1)-Leuchte7ABL RB1-Lasttyp 7 --> 3 - Xenon Abblendlicht
(5)-Leuchte7ABL RB1-Lichtfunktion B 7 --> Lichthupe generell
(6)-Leuchte7ABL RB1-Dimmwert AB 7 --> 127
Left high beam (Shutter):
(1)-Leuchte8FL LB39-Lasttyp 8 --> 2 - Shutter; Diagnosesensierung für 'LED low'
(6)-Leuchte8FL LB39-Dimmwert AB 8 --> 127
Right high beam (Shutter):
(1)-Leuchte9FL RB2-Lasttyp 9 --> 2 - Shutter; Diagnosesensierung für 'LED low'
(6)-Leuchte9FL RB2-Dimmwert AB 9 --> 127
ps. also shutters are connected Front right B22, front left B23
GDM8085
C?ID=86403
Left Low Beam:
Right low beam:
I verified again that these are all set as recommended:
Left Low Beam:
Right low beam:
You are correct sir. I was thinking pin B22 and said pin 11 (this is the headlight plug pin) I did double check this as well. Thank-you for finding this information for me.
   #47
GDM8085
C?ID=86403
Does anyone have an idea where to correct this fault? In BCM, CAN Gateway, etc? I thought maybe in the BCM but I am not sure what bit designates the engine type as my BCM does not support long coding helper. i am not sure if the BCM would trip a DTC in the ECU though. This fact leads me to the CAN Gateway? It is annoying as it causes a flashing glow plug light.
          P1647 00 [167] - -
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    CCS Switch-Bit 0: 1
   #48
GDM8085
C?ID=86403
I have forgotten to mention that because my BCM is not supported by Long Coding helper I am not able to find which byte/bit is for BiXenon shutter installed. Maybe this is the problem with the headlights flickering and shutting off and the right shutter not functioning? I guess if I understand this correctly the MK7s require a combination of adaptation channels changed as well as the older style long coding changes (which I have not done)
   #49
m87a
C?ID=156900
yep, you need to code for bi xenon bcm also check this
Byte 6, Bit 5-6 has a value of binary 01 xenon, this should at least stop lights from flickering
LED DRL:
(1)-Leuchte4TFL LB4-Lasttyp 4 --> 6 - LED Lichtmodul
(4)-Leuchte4TFL LB4-Lichtfunktion A 4 --> Daytime running lights
(6)-Leuchte4TFL LB4-Dimmwert AB 4 --> 127
(8)-Leuchte4TFL LB4-Lichtfunktion C 4 --> Standlicht allgemein (Schlusslicht, Begrenzungslicht)
(9)-Leuchte4TFL LB4-Lichtfunktion D 4 --> Parklicht links (beidseitiges Parklicht aktiviert li & re)
(10)-Leuchte4TFL LB4-Dimmwert CD 4 --> 127
(1)-Leuchte5 TFL RB32-Lasttyp 5 --> 6 - LED Lichtmodul
(4)-Leuchte5 TFL RB32-Lichtfunktion A 5 --> Daytime running lights
(6)-Leuchte5 TFL RB32-Dimmwert AB 5 --> 127
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5 --> Standlicht allgemein (Schlusslicht, Begrenzungslicht)
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5 --> Parklicht rechts
(10)-Leuchte5 TFL RB32-Dimmwert CD 5 --> 127
GDM8085
C?ID=86403
LED DRL:
I just verified that all my settings are as mentioned.
My BCM has two variations though:
recommended:
Mine:
(8)-Leuchte4TFL LB4-Lichtfunktion C 4 --> Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
(8)-Leuchte5 TFL RB32-Lichtfunktion C 5 --> Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
(9)-Leuchte5 TFL RB32-Lichtfunktion D 5 --> Park lights right
GDM8085
C?ID=86403
Now we have a few more codes after several key cycles.
Thursday,12,January,2017,16:56:05:54491
VCDS Version: Release 16.8.4 (x64) Running on Windows 7 x64
                Address 09: Cent. Elect.       Labels: None
Control Module Part Number: 5Q0 937 087 S    HW: 5Q0 937 087 S
  Component and/or Version: BCM PQ37BOSCH 028 0145
           Software Coding: 00000A024041A14169E44000000403001000000000000000000000000000
            Work Shop Code: WSC 12345 123 12345
              ASAM Dataset: EV_BodyContrModul1UDSBosc 014004 (VW37)
7 Faults Found:
137217 - Outside temperature sensor
          B103F 1B [136] - Resistance Too High
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 23:16:33
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
18698 - Left LED Module for DRL and Parking Lights
          B12EC F2 [008] - Voltage Supply Open or Short to Plus
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 23:16:31
19210 - Right LED Module for DRL and Parking Lights
          B12ED F2 [008] - Voltage Supply Open or Short to Plus
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 23:16:31
395273 - Control Circuit for Signal Horn
          B1344 14 [008] - Open or Short to Ground
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 23:16:31
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
   #53
GDM8085
C?ID=86403
Check your .net email account
Thank you very much. I took a quick glance at this. I will need some time to figure it out but it looks like you have put a lot of time into this.
   #54
GM8085: Narrrhh..... nothing too difficult that MS Access and a fast-declining senile brain can't handle with ease! My suggestion is that you adopt the settings for your new car that are most often quoted for the range of NAR series cars listed in the table. I also included settings for a number of the RoW models more out of interest and for my benefit.
The one factor that I omitted to mention was the columns with the headings Old RT SW Channel No and New RT SW Tags. Some time ago, the guys/gals @ RT changed the way that adaptation channels were reported. In previous SW versions, channel names with many children were preceded by a number in parenthesis. But these descriptors were changed to what RT calls "Tags" in later SW releases. For example - the old RT SW reported (4)-Leuchte 0 BLK VL B36-Lichtfunktion A 0 whereas the new RT SW changed this descriptor to ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0
Unfortunately, Tags mess-up the natural flow of the 19 x adaptation channels in a Leuchte-set in that they break-up the alpha-channel groupings. As you will see, I have ordered the adaptation channels in the table according to the old RT SW nomenclature - because this makes more sense when trying to understand how the lighting functions operate within a particular Leuchte-set (I think). Nevertheless, if you want to view the members of the Leuchte-set in the order that they are reported by the later RT SW version, simply sort by the column New RT SW Tags.
I have also taken the liberty of including a column showing the position and the general function of all the lamps in the headlight fittings. This was done on the assumption that you weren't familiar with this aspect of Leuchte-sets (my apology if my assumption is in error - in which case, simply ignore this column in the table)
As I said in my email, something definitely wrong with the setting for Leuchte11SHUTTER RB22-Dimmwert AB 11 - which may help explain why your right-side high beam doesn't operate. In general, the BCM values appear to be RoW based - was this module purchased in a RoW country?
GDM8085
C?ID=86403
I did check and this part was ordered from Germany.
Thank you so much for the document. I followed it all the way through and now my right headlight shutter is working. Thanks so much!!!!
The headlights themselves are still flickering and flashing off randomly then coming back on. Also something thinks that my parking bulbs are missing, and they do not light up (are there to be lights inside the amber reflectors on the side?). Also I have never had my DRL on with key on and headlight switch in the "off" position. Is this correct? It seems not. Maybe this is in my long coding?
   #56
GDM8085
C?ID=86403
Just realized that there are 3 small LEDs below the amber reflector on these headlights that I have never seen come on.
   #57
GDM8085
C?ID=86403
We finally took the headlight apart to check the bulbs and they had cheap Chinese bulbs in them. We replaced them with genuine Osram bulbs and no more flickering or shutting off. Everything is working good enough for my satisfaction at the moment (side markers in front and rear lights are not working neither are DLRs) but I need to get rid of this fault:
          P1647 00 [175] - -
                    Fault Frequency: 17
                    Mileage: 85770 km
                    Date: 2017.01.10
                    Time: 00:09:12
                    Coolant temperature: 17 °C
                    Intake air temperature: 17 °C
                    Voltage terminal 30: 13.260 V
                    CCS Switch-Bit 0: 1
And here is the latest Autoscan:
Friday,13,January,2017,12:15:13:54491
VCDS Version: 17.1.1.0 (x64)
Data version: 20170106 DS267.0
   Revision: 85H23---
   VCID: 254192032435DD6986-8070
          P1647 00 [175] - -
                    Fault Frequency: 14
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    CCS Switch-Bit 0: 1
   VCID: 44872F87CF4F0461B1-8010
   Revision: 00001K06
   VCID: 39794E73B88D4989D2-806C
   VCID: 4B9504BBE211CB1970-801E
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.11
                    Time: 18:55:12
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.11
                    Time: 18:52:45
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.11
                    Time: 18:41:00
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.11
                    Time: 18:55:10
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.11
                    Time: 17:50:09
   VCID: 51A916D3003DE1C90A-8004
   Occupant Detection:
   Coding: 303338
   Coding: 0400
   VCID: 3C775767B7BF7CA1C9-8068
   VCID: 65C1D20364B51D6946-8030
13639936 - Databus
                    Reset counter: 84
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 23:16:34
   VCID: 72EBB95FA57BFAD1D3-8026
   Subsystem 2 - Part No SW: 5G0 959 442 P    HW: 5G0 959 442 P  Labels: 3C8-959-537.CLB
   Coding: 28FFFF
   VCID: 3E735D6FA1A36EB1E7-806A
   Coding: 011000
   Coding: 0102
   VCID: 41892693D05D11499A-8014
   VCID: 3D715A63ACA575A9FE-8068
   Coding: 191000
   Coding: 020C000009000400
   VCID: 408F2397DB57184195-8014
   Coding: 2E0000
   Coding: 2E0000
   VCID: 64C7CF076F8F646151-8030
                    Reset counter: 44
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
   VCID: 020BE99F95DBCA51C3-8056
   #59
Hi guys,
Firstly I just read through this entire thread and appreciate the level of assistance provided to Les (GDM8085). Don, if you want the original maps from my Alltrack (rather than the text data) just let me know. I'll shoot them off via e-mail.
Next, this is the map condition from the Golf in this thread as of Jan 3rd:
;SW:5Q0-937-087-S   HW:5Q0-937-087-S ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0145	 Coding:000008424041804169E44000000403001000000000000000000000000000
;EV_BodyContrModul1UDSBosc	14004	EV_BCMBOSCH_014.rod
;Tuesday	3	January	2017	03:57:51:54491
;VCDS Version: Release 16.8.4 (x64)  Data version: 20161129 DS267.0
;VCID: 4B9504BBE211CB1A6C-801E
IDE00001-ENG99061-Production mode-Access control	not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00002-Transport mode	not active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Not deactivated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	320 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	320 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
IDE01550-Service position	170.49 °
IDE02152-Characteristics in production mode	2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	double sided
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	SAE J582
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	not active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	Parklichtfunktion USA und Kanada
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	manual
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik	active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	10
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	20
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	1C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	35
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	3F
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	0
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	35
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	35
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	127
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	89
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	127
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	26
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	35
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	35
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	26
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	0
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	0
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2F
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	0
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	26
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	27
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12	10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13	10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
IDE05145-ENG116176-Light configuration-Lasttyp 16	not active
IDE05145-ENG116195-Light configuration-Lasttyp 17	not active
IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20	13 - Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21	13 - Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte
IDE05145-ENG116309-Light configuration-Lasttyp 23	3 - Xenon Abblendlicht
IDE05145-ENG116328-Light configuration-Lasttyp 24	3 - Xenon Abblendlicht
IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED
IDE05145-ENG116366-Light configuration-Lasttyp 26	3 - Xenon Abblendlicht
IDE05145-ENG116385-Light configuration-Lasttyp 27	not active
IDE05145-ENG116404-Light configuration-Lasttyp 28	3 - Xenon Abblendlicht
IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30	36 - LED Kleinleistung
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
IDE05145-ENG115948-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8	36 - LED Kleinleistung
IDE05145-ENG116043-Light configuration-Lasttyp 9	36 - LED Kleinleistung
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	only_if_closed
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	only_if_closed
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	only_if_closed
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	only_if_closed
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	0
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	0
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	28
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	8
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	8
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	9
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	10
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	8
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	8
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	8
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	8
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	8
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	8
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	9
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	9
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	10
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	10
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	9
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	10
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	0
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	0
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	0
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	0
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	0 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	0.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	0.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	0.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	0.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	0.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	0.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	0.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	0.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	0.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	0.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	0.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	0.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	not active
IDE07356-Position during interval mode	31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	not active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	non sensitive
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE09595-ENG115658-Characteristic curve-x0	0 lx
IDE09595-ENG101574-Characteristic curve-X1	2000 lx
IDE09595-ENG99557-Characteristic curve-X2	4000 lx
IDE09595-ENG102140-Characteristic curve-X3	6000 lx
IDE09595-ENG102936-Characteristic curve-X4	8000 lx
IDE09595-ENG103548-Characteristic curve-X5	10200 lx
IDE09595-ENG17883-Characteristic curve-y1_0	0
IDE09595-ENG17884-Characteristic curve-y1_1	40
IDE09595-ENG17885-Characteristic curve-y1_2	90
IDE09595-ENG17886-Characteristic curve-y1_3	140
IDE09595-ENG17887-Characteristic curve-y1_4	190
IDE09595-ENG17888-Characteristic curve-y1_5	245
IDE09595-ENG17889-Characteristic curve-y2_0	0
IDE09595-ENG17890-Characteristic curve-y2_1	60
IDE09595-ENG17891-Characteristic curve-y2_2	110
IDE09595-ENG17892-Characteristic curve-y2_3	160
IDE09595-ENG17893-Characteristic curve-y2_4	210
IDE09595-ENG17894-Characteristic curve-y2_5	255
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed
IDE09733-ENG16335-LED bar setting values-Filterzeit Anpassung	3000 ms
IDE09733-ENG16334-LED bar setting values-Filterzeit Umgebungshelligkeit	1000 ms
IDE09733-ENG17895-LED bar setting values-Maximale Dauer fuer konstante Anzeige	0 s
IDE09733-ENG17896-LED bar setting values-Maximale Helligkeitsdifferenz	25
IDE09733-ENG17899-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor	0
IDE09733-ENG17897-LED bar setting values-Schwellwert Plausibilisierung RLS	393210 lx
IDE09733-ENG17898-LED bar setting values-Schwellwert Plausibilisierung SLS	393210 lx
IDE09733-ENG16333-LED bar setting values-Sperrzeit	0 s
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
IDE10298-Alternating park position 1	7.49 °
IDE10299-Alternating park position 2	29.49 °
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0
MAS01490-Energy management	active
MAS05055-lower turn position	31.49 °
MAS05056-upper turn position	170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed
ENG126647-ENG98399-debug_light_function-Activation	0
ENG126647-ENG101417-debug_light_function-Adresse	0
ENG126647-ENG126820-debug_light_function-Bitmask	0
ENG126647-ENG126821-debug_light_function-Divisor	0
ENG126647-ENG98827-debug_light_function-Offset	0
ENG126647-ENG126822-debug_light_function-Polaritaet	0
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0
ENG99457-ENG117394-Head area heater-blower_speed	1
ENG99457-ENG98971-Head area heater-Temperature	-2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	not active
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	not active
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	35
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	10
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	35
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	20
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	Parking light right
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	35
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	3 - Xenon Abblendlicht
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	35
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	3 - Xenon Abblendlicht
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	3 - Xenon Abblendlicht
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	3 - Xenon Abblendlicht
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	26
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	26
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Parking light right
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	Parking light right
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active
ENG126648-ENG17940-LIN-Mirrormode-Bitmaske	63
ENG126648-ENG17792-LIN-Mirrormode-Stage	0
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar	not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv	not active
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
Elapsed Time: 02:06
;SW:5Q0-937-087-S   HW:5Q0-937-087-S ---  Cent. Elect.
;Component:BCM PQ37BOSCH 028 0145	 Coding:000008424041804169E44000000403001000000000000000000000000000
;EV_BodyContrModul1UDSBosc	14004	EV_BCMBOSCH_014.rod
;Tuesday	3	January	2017	04:02:26:54491
;VCDS Version: Release 16.8.4 (x64)  Data version: 20161129 DS267.0
;VCID: 4B9504BBE211CB1A6C-801E
IDE00001-ENG99061-Production mode-Access control	not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00002-Transport mode	not active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	10
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Not deactivated
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	320 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	320 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant	0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
IDE01550-Service position	170.49 °
IDE02152-Characteristics in production mode	2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	80%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	80%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	80%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 °
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.00 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	double sided
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.00 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.00 °C
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.00 °C
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 °
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.00 °C
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 °
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.00 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	SAE J582
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separte
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.1
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	not active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	Parklichtfunktion USA und Kanada
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus	active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	manual
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung	35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung	35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik	active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	10 Alarme
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster	active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang	not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein	not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschließfunktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung	Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden	Always
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe	not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	10
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	20
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	1C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	35
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	3F
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	0
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	35
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	35
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	127
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	89
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	127
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	26
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	35
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	35
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	26
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	0
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	0
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2F
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	0
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	26
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	27
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12	10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13	10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
IDE05145-ENG116176-Light configuration-Lasttyp 16	not active
IDE05145-ENG116195-Light configuration-Lasttyp 17	not active
IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20	13 - Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21	13 - Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte
IDE05145-ENG116309-Light configuration-Lasttyp 23	3 - Xenon Abblendlicht
IDE05145-ENG116328-Light configuration-Lasttyp 24	3 - Xenon Abblendlicht
IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED
IDE05145-ENG116366-Light configuration-Lasttyp 26	3 - Xenon Abblendlicht
IDE05145-ENG116385-Light configuration-Lasttyp 27	not active
IDE05145-ENG116404-Light configuration-Lasttyp 28	3 - Xenon Abblendlicht
IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30	36 - LED Kleinleistung
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
IDE05145-ENG115948-Light configuration-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8	36 - LED Kleinleistung
IDE05145-ENG116043-Light configuration-Lasttyp 9	36 - LED Kleinleistung
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	only_if_closed
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	only_if_closed
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	only_if_closed
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	only_if_closed
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	0
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	0
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	28
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	8
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	8
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	9
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	10
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	8
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	8
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	8
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	8
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	8
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	8
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	9
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	9
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	10
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	10
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	9
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	10
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	0
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	0
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	0
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	0
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	0 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	0.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	0.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	0.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	0.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	0.00 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	0.00 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	0.00 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	0.00 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	0.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	0.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	0.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	0.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	not active
IDE07356-Position during interval mode	31.49 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten nach der Nachlaufzeit
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	not active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv	not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf	not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel	active
IDE08542-ENG125656-Access control 2-Regenschliessen_art	once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus	not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock	not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung	active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal	not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar	not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach	not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig	kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	non sensitive
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe	not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	not active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte	not active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE09595-ENG115658-Characteristic curve-x0	0 lx
IDE09595-ENG101574-Characteristic curve-X1	2000 lx
IDE09595-ENG99557-Characteristic curve-X2	4000 lx
IDE09595-ENG102140-Characteristic curve-X3	6000 lx
IDE09595-ENG102936-Characteristic curve-X4	8000 lx
IDE09595-ENG103548-Characteristic curve-X5	10200 lx
IDE09595-ENG17883-Characteristic curve-y1_0	0
IDE09595-ENG17884-Characteristic curve-y1_1	40
IDE09595-ENG17885-Characteristic curve-y1_2	90
IDE09595-ENG17886-Characteristic curve-y1_3	140
IDE09595-ENG17887-Characteristic curve-y1_4	190
IDE09595-ENG17888-Characteristic curve-y1_5	245
IDE09595-ENG17889-Characteristic curve-y2_0	0
IDE09595-ENG17890-Characteristic curve-y2_1	60
IDE09595-ENG17891-Characteristic curve-y2_2	110
IDE09595-ENG17892-Characteristic curve-y2_3	160
IDE09595-ENG17893-Characteristic curve-y2_4	210
IDE09595-ENG17894-Characteristic curve-y2_5	255
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit	0.10 s
IDE09731-ENG125024-Int. light: 2nd generation-BAP Farbwert Farbe 1	0
IDE09731-ENG125025-Int. light: 2nd generation-BAP Farbwert Farbe 2	0
IDE09731-ENG125026-Int. light: 2nd generation-BAP Farbwert Farbe 3	0
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1	225
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2	225
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3	225
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig	not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig	not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach	80%
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe	0
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole	80%
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen	active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1	225
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2	225
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3	225
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen	active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen	active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen	active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen	active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen	active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen	active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen	not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig	not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig	not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren	not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig	not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1	225
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2	225
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3	225
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig	not active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel	not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel	not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel	installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher	not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen	not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus	not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung	not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung	not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil	not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI	not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting	installed
IDE09732-ENG126834-Interior light: light configuration-LIN-Dachkonsole lokal aktivierbar	not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung	not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung	not installed
IDE09733-ENG16335-LED bar setting values-Filterzeit Anpassung	3000 ms
IDE09733-ENG16334-LED bar setting values-Filterzeit Umgebungshelligkeit	1000 ms
IDE09733-ENG17895-LED bar setting values-Maximale Dauer fuer konstante Anzeige	0 s
IDE09733-ENG17896-LED bar setting values-Maximale Helligkeitsdifferenz	25
IDE09733-ENG17899-LED bar setting values-Schwellwert Plausibilisierung Kombi-Fototransistor	0
IDE09733-ENG17897-LED bar setting values-Schwellwert Plausibilisierung RLS	393210 lx
IDE09733-ENG17898-LED bar setting values-Schwellwert Plausibilisierung SLS	393210 lx
IDE09733-ENG16333-LED bar setting values-Sperrzeit	0 s
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne	30%
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz	25%
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne	30%
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz	25%
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne	58%
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz	53%
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne	58%
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz	53%
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne	85%
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz	80%
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne	85%
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz	80%
IDE10298-Alternating park position 1	7.49 °
IDE10299-Alternating park position 2	29.49 °
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit	1
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach	1
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum	0.2
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel	1
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher	1
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko	1
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd	1
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer	0.6
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI	0
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2	0
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3	0
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4	0
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI	0
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2	0
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3	0
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4	0
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab	1
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf	1
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI	0
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay	0
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel	100%
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren	96%
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel	100%
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren	96%
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach	100%
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel	100%
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko	100%
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd	100%
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren	96%
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach	100%
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum	70%
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel	100%
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko	100%
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd	100%
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren	96%
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit	100%
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach	100%
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum	70%
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht	100%
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel	100%
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher	100%
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko	100%
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd	100%
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren	96%
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit	100%
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach	100%
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum	0%
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht	100%
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel	100%
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher	100%
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko	100%
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd	100%
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren	0%
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel	100%
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren	96%
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit	100%
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach	100%
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum	127%
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht	100%
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel	100%
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher	100%
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko	100%
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd	100%
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren	127%
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit	126%
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach	126%
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum	126%
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht	0%
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel	126%
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher	126%
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko	126%
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd	126%
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren	126%
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum	127%
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel	100%
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren	127%
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit	100%
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach	100%
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum	126%
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht	100%
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel	100%
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher	100%
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko	100%
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd	100%
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren	126%
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit	100%
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach	100%
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum	70%
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht	100%
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel	100%
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher	100%
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko	100%
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd	100%
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren	96%
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit	100%
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach	100%
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum	70%
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht	100%
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel	100%
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher	100%
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko	100%
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd	100%
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren	96%
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit	100%
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach	100%
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum	70%
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht	100%
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel	100%
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher	100%
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko	100%
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd	100%
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren	96%
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit	100%
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach	100%
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum	70%
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht	100%
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel	100%
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher	100%
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko	100%
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd	100%
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren	96%
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit	0.0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach	0.0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum	0.0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht	0.0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko	0.0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren	0.0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit	0.0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach	0.0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum	2.0 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht	0.0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko	0.0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren	0.5 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit	0.0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach	0.0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum	0.0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht	0.0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko	0.0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren	0.0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit	0.0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach	0.0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum	0.0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht	0.0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko	0.0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren	0.0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit	0.0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach	0.0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum	0.0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht	0.0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko	0.0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren	0.0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit	0.0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach	0.0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum	0.0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht	0.0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko	0.0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren	0.0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit	0.0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach	0.0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum	0.0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht	0.0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko	0.0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren	0.0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen	0
MAS01490-Energy management	active
MAS05055-lower turn position	31.49 °
MAS05056-upper turn position	170.49 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen	active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen	not active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung	active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy	active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder	active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein	not active
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1	1
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10	1
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11	1
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12	1
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13	1
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14	1
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15	1
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2	1
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3	1
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4	1
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5	1
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6	1
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7	1
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8	1
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9	1
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1	door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10	door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11	door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12	door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13	door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14	door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15	door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2	door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3	door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4	door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5	door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6	door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7	door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8	door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9	door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1	not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10	not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11	not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12	not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13	not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14	not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15	not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2	not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3	not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4	not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5	not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6	not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7	not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8	not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9	not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12	0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1	0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10	0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11	0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13	0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14	0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15	0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16	0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17	0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18	0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19	0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2	0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20	0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3	0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4	0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5	0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6	0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7	0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8	0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9	0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1	0
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10	0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11	0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12	0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13	0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14	0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15	0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16	0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17	0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18	0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19	0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2	0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20	0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3	0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4	0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5	0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6	0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7	0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9	0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8	0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1	not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10	not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11	not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12	not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13	not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14	not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15	not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16	not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17	not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18	not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19	not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2	not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20	not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3	not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4	not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5	not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6	not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7	not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9	not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8	not installed
ENG126647-ENG98399-debug_light_function-Activation	0
ENG126647-ENG101417-debug_light_function-Adresse	0
ENG126647-ENG126820-debug_light_function-Bitmask	0
ENG126647-ENG126821-debug_light_function-Divisor	0
ENG126647-ENG98827-debug_light_function-Offset	0
ENG126647-ENG126822-debug_light_function-Polaritaet	0
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe	0
ENG99457-ENG117394-Head area heater-blower_speed	1
ENG99457-ENG98971-Head area heater-Temperature	-2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0	0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1	8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2	50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3	500 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0	6
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1	6
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2	100
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3	100
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	0
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	not active
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	not active
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	35
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	10
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	35
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	20
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	Parking light right
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	35
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	3 - Xenon Abblendlicht
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	35
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	3 - Xenon Abblendlicht
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	3 - Xenon Abblendlicht
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	3 - Xenon Abblendlicht
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	26
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	26
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Parking light right
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	Parking light right
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active
ENG126648-ENG17940-LIN-Mirrormode-Bitmaske	63
ENG126648-ENG17792-LIN-Mirrormode-Stage	0
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0.00%
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	5.00%
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	50.00%
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	75.00%
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	110
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	126.5
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar	not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar	not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv	not active
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar	not active
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt	active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung	active
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
Elapsed Time: 01:54
Les, Ping me if you want that map pulled out of forum - but I figured you posted so many scans that the Adp info doesn't matter at this point. Getting it finished does :-)
Lastly, I sent a tester redirect for this BCM (pointed to 5Q0-937-08X-HV1.CLB) so he has some coding info to work with.
Internal ref: FS#1260
We finally took the headlight apart to check the bulbs and they had cheap Chinese bulbs in them. We replaced them with genuine Osram bulbs and no more flickering or shutting off. Everything is working good enough for my satisfaction at the moment (side markers in front and rear lights are not working neither are DLRs) but I need to get rid of this fault:
Address 01: Engine (J623-CRUA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 C    HW: 04L 907 309
   Component: R4 2,0L EDC   H23 8412
   Revision: 85H23---
   Coding: [B][COLOR="#0000FF"]01190012032410080000[/COLOR][/B]
   Shop #: WSC 44642 001 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021C 001012
   ROD: EV_ECM20TDI01104L906021C.rod
   VCID: 254192032435DD6986-8070
17149 - Check Coding of ECUs on Powertrain Data Bus
          P1647 00 [175] - -
                    Fault Frequency: 14
                    Mileage: 85838 km
                    Date: 2017.01.10
                    Time: 22:25:37
                    Engine speed: 0.00 /min
                    Coolant temperature: 24 °C
                    Intake air temperature: 24 °C
                    Voltage terminal 30: 13.240 V
                    ACC variants-Bit 0: 0
                    CCS Switch-Bit 0: 1
                    Cruise control switch actuation-Bit 0: 0
                    Cruise control switch actuation-Bit 8: 32
                    ACC variants (coding)-Bit 0: 1
                    Acceleration: 0.000 m/s²
Hello again. Progress reads like an interesting novel with each of your successive posts opening a new and exciting chapter for forum colleagues! But importantly, it sounds like you are moving inexorably forward - which is always a good thing!!
Hmm..................... interesting DTC!
Fortuitously, a compatriot of yours has posted an auto-scan with an extremely similar Engine module HERE - see extract below
Address 01: Engine (J623-CRUA) Labels: None
Component: R4 2,0L EDC H23 8277
Revision: 85H23---
Coding:[B][COLOR="#0000FF"] 01190012032410080000[/COLOR][/B]
Shop #: WSC 00066 790 00221
ASAM Dataset: EV_ECM20TDI01104L906021C 001011
VCID: 256F008B242DFF093D6-8070
The identical code-strings between the 2 x vehicles strongly suggest that the DTC is emanating not from the engine module, but from another module in the Powertrain bus. Here are a list of those Powertrain modules:
E313 Selector lever
J234 Airbag control unit
J533 Data bus diagnostic interface
J583 Control unit for NOx sender
J623 Engine control unit
J743 Mechatronic unit for dual clutch gearbox
J854 Control unit for front right belt tensioner
J855 Control unit for front left belt tensioner
J869 Control unit for structure-borne sound
J881 Control unit for NOx sender 2
So, here's the killer question - I note that you had a CP error on the instrument module (not part of the Powertrain bus), suggesting that you have replaced the dashboard panel. So work other than retro-fitting the BCM has clearly happened. To help put a context to the Engine DTC, can you describe precisely what if anything has been done to any of the components in the list above on the car?
