Wednesday,16,November,2016,14:53:01:58336
VCDS Version: 16.8.3.1
Workshop Code: 210 00152 091233
Chassis Type: NE (5Q0)
Scan: 01 03 08 09 10 13 15 16 17 19 20 42 44 52 5F
VIN: TMBBG7NEXG007???? Mileage: 6309km-3920miles
Address 01: Engine (2D2D2-CXXB) Labels: 04L-907-309-V1.clb
Part No SW: 04L 906 056 CL HW: 04L 907 445 B
Component: R4 1.6l TDI H06 2370
Revision: 22004001
Coding: 01114012432519090000
Shop #: WSC 73430 031 00000
ASAM Dataset: EV_ECM16TDI03004L906056CL 002005
ROD: EV_ECM16TDI03004L906056CL_VW37.rod
VCID: 79F3CA9BF83AB28AFB-802C
Readiness: N/A
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 3Q0 907 379 T HW: 3Q0 907 379 C
Component: ESC H32 0393
Revision: 00000000 Serial number: 52135000000741
Coding: 1A078A911427096F0079060541CA245851289000608224F210430070C002
Shop #: WSC 73430 031 00063
ROD: EV_Brake1UDSContiMK100ESP_034_SK37.rod
VCID: 4B9F4053E226F01A19-801E
16401 - Tire Pressure Warning
C102D 00 [008] - -
Reset counter: 172
Mileage: 5370 km
Date: 2016.11.06
Time: 16:51:36
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5E0 907 044 Q HW: 5E0 907 044 Q
Component: Climatronic H04 1002
Revision: 00001K07
Coding: 01110104000100011005000000101000
ROD: EV_ACClimaBHBVW37X_004_VW48.rod
VCID: 336F38B39AD688DA71-8066
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-HV1.clb
Part No SW: 5Q0 937 084 AS HW: 5Q0 937 084 AN
Component: BCM MQBAB H H24 0175
Serial number: 01061522900710
Coding: 0F000942424702FB07A04082B10C07280000000000000000000000000000
Shop #: WSC 73430 790 00000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 0913BA5BA8DAA20AEB-805C
Subsystem 1 - Part No SW: 5E2 955 119 HW: 5E2 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS371 150623 041 0570
Serial number: 150724082733
Coding: 065DDD
Component: RLHS 037 0059
Serial number: S5Y15M08D25H13M26S45
Coding: 00885D
Subsystem 3 - Part No SW: 5Q0 951 171 HW: 5Q0 951 171
Serial number: 000000000ZY151532CKT
Serial number: 00000000000033191193
Address 10: Park/Steer Assist (J446) Labels: 5Q0-919-283.clb
Part No SW: 5Q0 919 283 F HW: 5Q0 919 283
Component: PARKHILFE 4K H10 0054
Revision: -------- Serial number: 39231523302179
Coding: 0001050001
ROD: EV_EPHVA14AU3700000_SK25.rod
VCID: 3C7D138FB78847A2A0-8068
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 F HW: 5Q0 907 572 F
Component: ACC Bosch MQB H05 0400
Serial number: 24071503270393
Coding: 00000200FE0339
ASAM Dataset: EV_ACCMRRBoschVW372 001016
VCID: 3A711597BDBC7992B2-806E
Part No SW: 3Q0 959 655 AS HW: 3Q0 959 655 AS
Component: Airbag VW20 013 0200
Revision: -------- Serial number: 003SQPFWNHWT
Coding: 98CCC000000000005C5400CC008800000065
ROD: EV_AirbaVW20TS6VW48X.rod
VCID: 0F279443D6BE8C3A35-805A
Subsystem 1 - Part No SW: ----------- HW: 454 001 108 15
Serial number: 3576U0000001C79CB51N
Subsystem 2 - Part No SW: ----------- HW: 454 001 108 15
Serial number: 3586U000000CD221B51D
Subsystem 3 - Part No SW: ----------- HW: 454 801 907 15
Serial number: 3516R5868A2070000002
Subsystem 4 - Part No SW: ----------- HW: 454 800 608 15
Serial number: 3526RCD60E307000000C
Subsystem 5 - Part No SW: ----------- HW: 454 802 306 15
Serial number: 3556V3FFC6107000000N
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 M HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0195
Revision: FF033033 Serial number: 20150822400305
Coding: 1400
ROD: EV_SMLSVALEOMQB.rod
Part No SW: 5E0 920 951 B HW: 5E0 920 951 B
Component: KOMBI 312 6420
Coding: 27A402002180A60001886A011000000000000000
ROD: EV_DashBoardVDDMQBAB_009_SK37.rod
VCID: 2649D1E75904ED72E6-8072
Part No SW: 5Q0 907 530 AF HW: 5Q0 907 530 F
Component: GW MQB High 128 1223
Revision: -------- Serial number: 0003818182
Coding: 030100040F087300EB000248080F00010001050000000000000000000000
ROD: EV_GatewLear_013.rod
VCID: 75EBC6ABD422D6EA9F-8020
Subsystem 2 - Part No SW: 3V0 919 719 A HW: 3V0 919 719 A
Component: E221__MFL-PR6 H02 0150
Serial number: 000000000C1288110815
Subsystem 3 - Part No SW: 5Q0 915 181 F HW: 5Q0 915 181 F
Component: J367-BDM H08 0223
Serial number: 52225627024291494508
Address 20: High Beam Assist. (J844) Labels: 8X0-857-511.clb
Part No SW: 5G0 857 511 D HW: 5G0 857 511
Component: FLA H04 0002
Revision: AA001001
Coding: 01028F6B76765D525220343E01
ASAM Dataset: EV_HighBeamAssisAU37X 001009
ROD: EV_HighBeamAssisAU37X.rod
VCID: 2B5F20D342E6D01A39-807E
Part No SW: 5Q4 959 593 E HW: 5Q4 959 593 B
Component: TSG FS 010 0031
Serial number: 0000163586258
Coding: 00150020D001040000001100
VCID: 47977C63FE4E147A3D-8012
Subsystem 1 - Part No SW: 5Q0 959 812 A HW: 5Q0 959 812 A
Serial number: 00000000000007029443
Coding: 1D0200
Part No SW: 5Q0 909 144 R HW: 5Q0 909 144 R
Component: EPS_MQB_ZFLS 125 1061
Coding: 8103
VCID: 438F6873CA76385AE1-8016
Part No SW: 5Q4 959 592 E HW: 5Q4 959 592 B
Component: TSG BFS 010 0031
Serial number: 0000164193214
VCID: 46897167F9440D72C6-8012
Subsystem 1 - Part No SW: 5Q0 959 811 A HW: 5Q0 959 811 A
Serial number: 00000000000006923069
Coding: 050200
Address 5F: Information Electr. (J794) Labels: 3V0-035-MIB-STD2.clb
Part No SW: 5Q0 035 874 A HW: 5Q0 035 874 A
Component: MU-S-ND-ER H24 0241
Serial number: SKZAZ2R8781941
Coding: 03730101FF00000011111201008800002F0200C601200100C6
Shop #: WSC 73430 790 00063
ROD: EV_MUStd4CTSAT_SK26.rod
VCID: 32613DB765CC81D27A-8066
Subsystem 1 - Part No SW: 5E0 919 605 J HW: 5E0 919 605 J
Component: ABT_Std-2_Nav H41 1028
Serial number: SKZ8Z9RBT00J4U
Subsystem 2 - Part No SW: 5L0 051 236 H HW: -----------
Component: ECE 2016 --- 0521
