adpmap-01-04E-906-027-HD
;SW:04E-906-027-HD HW:04E-907-309-BH --- Engine
;Component:R4 1.4l TFS H25 2603, Coding:01190032232419080000
;EV_ECM14TFS01104E906027HD,001006,EV_ECM14TFS01104E906027HD.rod
;Saturday,24,December,2016,12:22:53:57018
; Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: EDDB8CB83C4FC42A92-80B8
IDE00001-Production mode,00 00 00
IDE01945-Engine run-in oil pressure,not active
IDE02248-Individually adjustable maximum speed limit,300.0 km/h
IDE02332-Deactivate production mode,00 00 00
IDE02632-Activation of static maximum speed limit,OFF
IDE02633-Deactivation of static maximum speed limit,00 00
IDE04158-Activation of start-stop function,active
IDE04617-Protective function,Enabled
IDE06425-Roller test bench mode: functional,not activated
IDE06648-Activation of interior auxil. heating,active
adpmap-03-5Q0-614-517-AF
;SW:5Q0-614-517-AF HW:5Q0-614-517-AF --- Brakes
;Component:ESC H62 0398, Coding:1C076A912429196E407D060041CC2438562498026082247200200070C00203
;EV_Brake1UDSContiMK100ESP,035019,EV_Brake1UDSContiMK100ESP_035_SK37.rod
;Saturday,24,December,2016,12:23:27:57018
;VCID: F5EBA4D8541F0CEA6A-80A0
IDE00001-Production mode,not active
IDE00252-Brake system vacuum pump,5
IDE00820-Activating and deactivating all development messages,0
IDE02332-Deactivate production mode,Deactivating
IDE03659-Roller test bench mode,Manual activation: possible
IDE04456-Brake disk drying,Medium
IDE04508-Hydraulic brake booster,8
IDE04643-Overboost in brake system,activated
IDE04774-Vehicle and trailer stabilization,not activated
IDE04939-Tire pressure monitoring display,2
IDE04949-Engine drag torque control,activated
IDE04951-Brake booster,4
IDE04952-Braking torque boost for distance regulation,3
IDE05055-Hydraulic brake assistant,normal
IDE05057-Brake prefill,activated
IDE05161-Straight ahead brake stabilization,activated
IDE05337-IDE05337-Starting vibration reduction-,Strong
IDE05337-MAS02653-Starting vibration reduction-Torque limitation,Deactivated
IDE07006-Tire pressure monitoring display: tire selection,1
IDE07292-Bremsenvorbefüllung,not completed successfully
IDE07565- in lower speed range,activated
IDE07848-Thresholds for brake performance,activated
IDE12030-Schlechtwegoptimierung,activated
MAS00122-Electronic Stability Program,not activated
MAS00194-tbd,Standard
MAS00970-Running manufacturer number,activated
MAS01299-Offroad,0
MAS02080- calibration protocol,not activated
MAS02138-Hill-start assistant,normal
ENG118148-Developer_Function_1,0
ENG130301-Developer_Function_121,not activated
adpmap-08-5E0-907-044-AC
;SW:5E0-907-044-AC HW:5E0-907-044-AC --- Auto HVAC
;Component:Climatronic H04 1601, Coding:02010004000110011005000000101002
;EV_ACClimaBHBVW37X,006142,EV_ACClimaBHBVW37X_005_SK37.rod
;Saturday,24,December,2016,12:24:11:57018
;VCID: E6C9F39419B9F772D3-80B2
IDE00001-Production mode,Deactivating
IDE01067-Retention of driver's seat heater level,active for 10 minutes
IDE01478-Ignore compressor switch-off by Engine Control Module,Do not ignore
IDE01479-Gear ratio of engine - A/C compressor,0.00
IDE01483-Blower voltage for voice operation,not activated
IDE01488-Retrofitting of parking heater without CAN,not installed
IDE01493-Air quality sensor sensitivity,Maximum
IDE01503-Runtime for compressor run-in basic setting,60 s
IDE01536-Post-heating of parking heater,0 min
IDE02155-Reset all counters,not activated
IDE03176-Duration of compressor run in,0 s
IDE03251-Stop release for start-stop function,According to function requirements
IDE04159-Deactivation of start-stop function,not active
IDE06544-Speed switch-off threshold for compressor run-in (engine speed),1500 /min
IDE06545-Blower voltage for production routines,11.0 V
IDE06546-Interior target temperature for production routines,22 °C
IDE06547-Air distribution for production routines,No effect
IDE06593-Recirculation air for production routines,No effect
IDE07108-Climate modes,Matching coding
IDE07160-MAS01155-Control module switch-off: switch-off time-Control module,20 min
IDE07160-MAS05583-Control module switch-off: switch-off time-Data bus,30 min
IDE07398-Blower logic for manual adjustment,Matching coding
IDE07585-Hand heater function during cold start,active
IDE07865-Automatic Activation of front windshield heater at MAX-Defrost,not active
IDE07948-Retention of frt.pass. seat heater level,not active
IDE80006-Analysis 6,not activated
IDE80007-Analysis 7,00000000 00000000
IDE80008-Analysis 8,not active
MAS05739-CO2 compressor on-time reduction,Matching coding
MAS06564-Window condensation exterior reduction at high humidity,Matching coding
MAS07251-Cut-in behavior,Matching coding
ENG122844-ENG101574-dimming_characteristic_1-X1,0
ENG122844-ENG99557-dimming_characteristic_1-X2,6
ENG122844-ENG102140-dimming_characteristic_1-X3,40
ENG122844-ENG102936-dimming_characteristic_1-X4,60
ENG122844-ENG103548-dimming_characteristic_1-X5,80
ENG122844-ENG113992-dimming_characteristic_1-X6,100
ENG122844-ENG99777-dimming_characteristic_1-Y1,0 %
ENG122844-ENG100480-dimming_characteristic_1-Y2,6 %
ENG122844-ENG100773-dimming_characteristic_1-Y3,40 %
ENG122844-ENG100631-dimming_characteristic_1-Y4,60 %
ENG122844-ENG102174-dimming_characteristic_1-Y5,80 %
ENG122844-ENG113993-dimming_characteristic_1-Y6,100 %
ENG122845-ENG101574-dimming_characteristic_2-X1,0
ENG122845-ENG99557-dimming_characteristic_2-X2,10
ENG122845-ENG102140-dimming_characteristic_2-X3,50
ENG122845-ENG102936-dimming_characteristic_2-X4,100
ENG122845-ENG103548-dimming_characteristic_2-X5,220
ENG122845-ENG113992-dimming_characteristic_2-X6,253
ENG122845-ENG99777-dimming_characteristic_2-Y1,2 %
ENG122845-ENG100480-dimming_characteristic_2-Y2,2 %
ENG122845-ENG100773-dimming_characteristic_2-Y3,10 %
ENG122845-ENG100631-dimming_characteristic_2-Y4,21 %
ENG122845-ENG102174-dimming_characteristic_2-Y5,85 %
ENG122845-ENG113993-dimming_characteristic_2-Y6,100 %
ENG122846-ENG101574-dimming_characteristic_3-X1,0
ENG122846-ENG99557-dimming_characteristic_3-X2,10
ENG122846-ENG102140-dimming_characteristic_3-X3,50
ENG122846-ENG102936-dimming_characteristic_3-X4,100
ENG122846-ENG103548-dimming_characteristic_3-X5,220
ENG122846-ENG113992-dimming_characteristic_3-X6,253
ENG122846-ENG99777-dimming_characteristic_3-Y1,3 %
ENG122846-ENG100480-dimming_characteristic_3-Y2,3 %
ENG122846-ENG100773-dimming_characteristic_3-Y3,6 %
ENG122846-ENG100631-dimming_characteristic_3-Y4,12 %
ENG122846-ENG102174-dimming_characteristic_3-Y5,100 %
ENG122846-ENG113993-dimming_characteristic_3-Y6,100 %
ENG122847-ENG101574-dimming_characteristic_4-X1,0
ENG122847-ENG99557-dimming_characteristic_4-X2,10
ENG122847-ENG102140-dimming_characteristic_4-X3,50
ENG122847-ENG102936-dimming_characteristic_4-X4,100
ENG122847-ENG103548-dimming_characteristic_4-X5,220
ENG122847-ENG113992-dimming_characteristic_4-X6,253
ENG122847-ENG99777-dimming_characteristic_4-Y1,2 %
ENG122847-ENG100480-dimming_characteristic_4-Y2,2 %
ENG122847-ENG100773-dimming_characteristic_4-Y3,5 %
ENG122847-ENG100631-dimming_characteristic_4-Y4,10 %
ENG122847-ENG102174-dimming_characteristic_4-Y5,85 %
ENG122847-ENG113993-dimming_characteristic_4-Y6,100 %
ENG122848-ENG101574-dimming_characteristic_5-X1,0
ENG122848-ENG99557-dimming_characteristic_5-X2,10
ENG122848-ENG102140-dimming_characteristic_5-X3,50
ENG122848-ENG102936-dimming_characteristic_5-X4,100
ENG122848-ENG103548-dimming_characteristic_5-X5,220
ENG122848-ENG113992-dimming_characteristic_5-X6,253
ENG122848-ENG99777-dimming_characteristic_5-Y1,2 %
ENG122848-ENG100480-dimming_characteristic_5-Y2,2 %
ENG122848-ENG100773-dimming_characteristic_5-Y3,5 %
ENG122848-ENG100631-dimming_characteristic_5-Y4,10 %
ENG122848-ENG102174-dimming_characteristic_5-Y5,85 %
ENG122848-ENG113993-dimming_characteristic_5-Y6,100 %
ENG130577-Knockout_timer_activation,not activated
adpmap-09-5Q0-937-086-AK
;SW:5Q0-937-086-AK HW:5Q0-937-086-AK --- Cent. Elect.
;Component: PQ37BOSCH 028 0162, Coding:0C000A46424722FB47E04000001C07280000000000000000000000000000
;EV_BodyContrModul1UDSBosc,015002,EV_BCMBOSCH_016_AU37.rod
;Saturday,24,December,2016,12:24:45:57018
;VCID: 830FCA000ACB225A54-80D6
IDE00001-ENG99061-Production mode-Access control,not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung,not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren,not active
IDE00001-ENG112304-Production mode-Heckwischer,not active
IDE00001-ENG98647-Production mode-Interior lighting,not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung,not active
IDE00001-ENG115731-Production mode-Virtuel_pedal,not active
IDE00002-Transport mode,active
IDE00820-Activating and deactivating all development messages,not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA,not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung,10
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm,active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf,active
IDE01268-ENG02322-Windshield wiper-Frontwischer_Abtauposition,not active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung,active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer,not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren,Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel,not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit,2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit,1100 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit,0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit,0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit,600 ms
IDE01268-ENG02321-Windshield wiper-Tippendes_Frontwaschen,not active
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz,active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status,not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung,active
IDE01268-ENG126844-Windshield wiper-Washer_Tipwiping_Variant,0
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube,not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus,active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube,not active
IDE01550-Service position,166.51 °
IDE02152-Characteristics in production mode,2000 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking,Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln,not active
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global,not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn,not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln,not active
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn,kurz
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung,not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte,not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen,not active
IDE02269-ENG02272-Acknowledgement signals-Quittierton bei zweitem ZV-AUF-Befehl,not active
IDE02269-ENG02273-Acknowledgement signals-Quittierton bei zweitem ZV-ZU-Befehl,not active
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen,active
IDE02711-ENG02325-Rear Window Wiper-Einzelansteuerung Heckintervallwischen,not active
IDE02711-ENG02323-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 1,0 s
IDE02711-ENG02324-Rear Window Wiper-Einzelansteuerung Heckintervallwischen Zeitintervall 2,0.0 s
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf,not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken,not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck,active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1,5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2,3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik,7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall,7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW,active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck,not active
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum,20 %
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer,40 %
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn,40 %
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung,not enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel,not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel,not installed
IDE03638-IDE04231-static light-Steering wheel angle: offset,0.25 °
IDE03638-ENG116677-static light-Abdimmgeschwindigkeit,50.00 %/s
IDE03638-ENG116673-static light-bei Rueckwaertsfahrt,both sides
IDE03638-ENG116675-static light-Lower speed threshold,0.00 km/h
IDE03638-ENG116682-static light-Maximaltemperatur,100.00 °C
IDE03638-ENG116679-static light-obere Grenztemperatur,95.00 °C
IDE03638-ENG116681-static light-Oberer Lenkradwinkel,90 °
IDE03638-ENG116680-static light-untere Grenztemperatur,80.00 °C
IDE03638-ENG116678-static light-Unterer Lenkradwinkel,30 °
IDE03638-ENG116676-static light-Upper speed threshold,40.00 km/h
IDE03638-ENG116674-static light-Vorschrift,ECE R119
IDE04923-ENG02307-Turn signal control-Abbruch Komfortblinken,active
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger,separte
IDE04923-ENG115774-Turn signal control-Komfortblinken,active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen,3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker,SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen,not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung,not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung,Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor,0.10
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert,20.00 %
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze,50 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze,50 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht,integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich,active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten,klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO,Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit,0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert,One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion,not active
IDE04924-ENG126816-Driving light and parking light-Standlicht aus,active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht,active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht,not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren,in Betrieb lassen
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht,15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten,Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus,automatic
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis,Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,46400 lx
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,12 lx
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus,Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome,10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per ,10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung,active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per ,active
IDE04927-IDE01446-Window heater-Running time of heated front window,600 s
IDE04927-ENG126847-Window heater-Abschalttemperatur fuer Frontscheibenheizung,35.00 °C
IDE04927-ENG126846-Window heater-Abschalttemperatur fuer Heckscheibenheizung,35.00 °C
IDE04927-ENG126845-Window heater-FSH Automatik,active
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert,600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH,not active
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH,not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn,not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal,frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung,not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus,not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl,10 Alarme
IDE04928-ENG126842-Anti-theft device-Ueberwachung Innenentriegelungshebel,not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm,keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck,active
IDE05142-ENG116621-Access control-automatisches Entriegeln,active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit,active
IDE05142-ENG116706-Access control-Autounlock ,not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB,not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung,active
IDE05142-ENG02315-Access control-Deaktivierung_Laderaumschliessung_extern,not active
IDE05142-ENG125653-Access control-Deaktivierung_SAFE_ueber_DWA_Deaktivierungstaster,active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels,active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung,not active
IDE05142-ENG126839-Access control-Entriegelungwunsch_verzoegert_waehrend_Zuziehvorgang,not active
IDE05142-ENG126837-Access control-Entsafen mit autorisierte Klemme 15 Ein,not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber -Funktaster,not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein,not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung,not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren,active
IDE05142-ENG02314-Access control-Heckfreigabe_Ohne_Verzoegerung,not active
IDE05142-ENG02316-Access control-LS_Taster_Togglefunktion,not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung,active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock,adjustable
IDE05142-ENG06090-Access control-Mindestbetaetigung_HDF_Innentaster,0.00 s
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt,not active
IDE05142-ENG115755-Access control-Notschließfunktion,active
IDE05142-ENG02317-Access control-Nutzfahrzeug_Schliessung,not active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung,active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe,not active
IDE05142-ENG125652-Access control-Servoheck Schlossansteuerung,Always
IDE05142-ENG126838-Access control-Softtouch-Betaetigung senden,Always
IDE05142-ENG115758-Access control-Valet Parking,not active
IDE05142-ENG126840-Access control-Vorrastenhaenger_Freigabe,not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT,not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer,not active
IDE05142-ENG02318-Access control-Wiederverriegelung_Laderaum,Freigabe_Softtouch
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel,active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen,not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung,Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash,not active
IDE05143-MAS02985-Writing parameter-Value,130
IDE05143-MAS04381-Writing parameter-Parameter address,FE 00 00
IDE05144-Read parameter address,FE 00 00
IDE05145-ENG115874-Light configuration- Bitposition 0,34
IDE05145-ENG115893-Light configuration- Bitposition 1,3E
IDE05145-ENG116063-Light configuration- Bitposition 10,37
IDE05145-ENG116082-Light configuration- Bitposition 11,41
IDE05145-ENG116101-Light configuration- Bitposition 12,38
IDE05145-ENG116120-Light configuration- Bitposition 13,42
IDE05145-ENG116139-Light configuration- Bitposition 14,00
IDE05145-ENG116158-Light configuration- Bitposition 15,00
IDE05145-ENG116177-Light configuration- Bitposition 16,35
IDE05145-ENG116196-Light configuration- Bitposition 17,3F
IDE05145-ENG116215-Light configuration- Bitposition 18,08
IDE05145-ENG116234-Light configuration- Bitposition 19,18
IDE05145-ENG115911-Light configuration- Bitposition 2,48
IDE05145-ENG116253-Light configuration- Bitposition 20,09
IDE05145-ENG116272-Light configuration- Bitposition 21,19
IDE05145-ENG116291-Light configuration- Bitposition 22,29
IDE05145-ENG116310-Light configuration- Bitposition 23,0A
IDE05145-ENG116329-Light configuration- Bitposition 24,1A
IDE05145-ENG116348-Light configuration- Bitposition 25,28
IDE05145-ENG116367-Light configuration- Bitposition 26,0C
IDE05145-ENG116386-Light configuration- Bitposition 27,1C
IDE05145-ENG116405-Light configuration- Bitposition 28,0B
IDE05145-ENG116424-Light configuration- Bitposition 29,1B
IDE05145-ENG115930-Light configuration- Bitposition 3,4C
IDE05145-ENG116443-Light configuration- Bitposition 30,00
IDE05145-ENG116462-Light configuration- Bitposition 31,00
IDE05145-ENG116481-Light configuration- Bitposition 32,00
IDE05145-ENG116500-Light configuration- Bitposition 33,00
IDE05145-ENG116519-Light configuration- Bitposition 34,00
IDE05145-ENG115949-Light configuration- Bitposition 4,3A
IDE05145-ENG115968-Light configuration- Bitposition 5,44
IDE05145-ENG115987-Light configuration- Bitposition 6,36
IDE05145-ENG116006-Light configuration- Bitposition 7,40
IDE05145-ENG116025-Light configuration- Bitposition 8,00
IDE05145-ENG116044-Light configuration- Bitposition 9,00
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0,maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1,maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10,maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11,maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12,maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13,maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14,maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15,maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16,maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17,maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18,maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19,maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2,maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20,maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21,maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22,maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23,maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24,maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25,maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26,maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27,maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28,maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29,maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3,maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30,maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31,maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32,maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33,maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34,maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4,maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5,maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6,maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7,maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8,maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9,maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0,maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1,maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10,maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11,maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12,maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13,maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14,maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15,maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16,maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17,maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18,maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19,maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2,maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20,maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21,maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22,maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23,maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24,maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25,maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26,maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27,maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28,maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29,maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3,maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30,maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31,maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32,maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33,maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34,maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4,maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5,maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6,maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7,maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8,maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9,maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0,maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1,maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10,maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11,maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12,maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13,maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14,maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15,maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16,maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17,maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18,maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19,maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2,maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20,maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21,maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22,maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23,maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24,maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25,maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26,maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27,maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28,maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29,maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3,maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30,maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31,maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32,maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33,maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34,maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4,maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5,maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6,maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7,maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8,maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9,maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0,100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1,100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10,127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11,127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12,100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13,100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14,0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15,0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16,100
IDE05145-ENG116200-Light configuration-Dimmwert AB 17,100
IDE05145-ENG116219-Light configuration-Dimmwert AB 18,100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19,100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2,35
IDE05145-ENG116257-Light configuration-Dimmwert AB 20,100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21,100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22,100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23,100
IDE05145-ENG116333-Light configuration-Dimmwert AB 24,100
IDE05145-ENG116352-Light configuration-Dimmwert AB 25,100
IDE05145-ENG116371-Light configuration-Dimmwert AB 26,100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27,0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28,100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29,100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3,35
IDE05145-ENG116447-Light configuration-Dimmwert AB 30,100
IDE05145-ENG116466-Light configuration-Dimmwert AB 31,100
IDE05145-ENG116485-Light configuration-Dimmwert AB 32,100
IDE05145-ENG116504-Light configuration-Dimmwert AB 33,100
IDE05145-ENG116523-Light configuration-Dimmwert AB 34,100
IDE05145-ENG115953-Light configuration-Dimmwert AB 4,127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5,127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6,127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7,127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8,0
IDE05145-ENG116048-Light configuration-Dimmwert AB 9,0
IDE05145-ENG115882-Light configuration-Dimmwert CD 0,0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1,0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10,0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11,0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12,0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13,0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14,0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15,0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16,0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17,0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18,0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19,0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2,35
IDE05145-ENG116261-Light configuration-Dimmwert CD 20,0
IDE05145-ENG116280-Light configuration-Dimmwert CD 21,0
IDE05145-ENG116299-Light configuration-Dimmwert CD 22,0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23,100
IDE05145-ENG116337-Light configuration-Dimmwert CD 24,100
IDE05145-ENG116356-Light configuration-Dimmwert CD 25,0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26,0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27,0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28,0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29,0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3,35
IDE05145-ENG116451-Light configuration-Dimmwert CD 30,0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31,0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32,0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33,0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34,0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4,127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5,127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6,127
IDE05145-ENG116014-Light configuration-Dimmwert CD 7,127
IDE05145-ENG116033-Light configuration-Dimmwert CD 8,0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9,0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0,0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1,0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10,0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11,0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12,0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13,0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14,0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15,0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16,0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17,0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18,0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19,0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2,100
IDE05145-ENG116265-Light configuration-Dimmwert EF 20,0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21,0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22,0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23,0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24,0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25,0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26,0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27,0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28,0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29,0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3,100
IDE05145-ENG116455-Light configuration-Dimmwert EF 30,0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31,0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32,0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33,0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34,0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4,127
IDE05145-ENG115980-Light configuration-Dimmwert EF 5,127
IDE05145-ENG115999-Light configuration-Dimmwert EF 6,0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7,0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8,0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9,0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0,0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1,0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10,0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11,0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12,0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13,0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14,0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15,0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16,0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17,0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18,0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19,0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2,0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20,0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21,0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22,0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23,0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24,0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25,0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26,0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27,0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28,0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29,0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3,0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30,0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31,0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32,0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33,0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34,0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4,0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5,0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6,0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7,0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8,0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9,0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte -DFCC 0,14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte -DFCC 1,15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte -DFCC 10,1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte -DFCC 11,1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte -DFCC 12,22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte -DFCC 13,23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte -DFCC 14,00
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte -DFCC 15,00
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte -DFCC 16,17
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte -DFCC 17,19
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte -DFCC 18,16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte -DFCC 19,18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte -DFCC 2,4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte -DFCC 20,2B
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte -DFCC 21,2D
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte -DFCC 22,2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte -DFCC 23,29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte -DFCC 24,2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte -DFCC 25,30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte -DFCC 26,2E
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte -DFCC 27,2F
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte -DFCC 28,31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte -DFCC 29,32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte -DFCC 3,4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte -DFCC 30,02
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte -DFCC 31,03
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte -DFCC 32,04
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte -DFCC 33,05
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte -DFCC 34,06
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte -DFCC 4,49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte -DFCC 5,4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte -DFCC 6,1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte -DFCC 7,1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte -DFCC 8,00
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte -DFCC 9,00
IDE05145-ENG115873-Light configuration-Lasttyp 0,12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1,12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12,10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13,10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14,not active
IDE05145-ENG116157-Light configuration-Lasttyp 15,not active
IDE05145-ENG116176-Light configuration-Lasttyp 16,8 - allgemeine Glühlampe 12W
IDE05145-ENG116195-Light configuration-Lasttyp 17,8 - allgemeine Glühlampe 12W
IDE05145-ENG116214-Light configuration-Lasttyp 18,12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19,12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20,34 - LED Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21,34 - LED Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22,34 - LED Bremsleuchten
IDE05145-ENG116309-Light configuration-Lasttyp 23,32 - allgemeine LED bis 12W
IDE05145-ENG116328-Light configuration-Lasttyp 24,32 - allgemeine LED bis 12W
IDE05145-ENG116347-Light configuration-Lasttyp 25,18 - 2* 5W
IDE05145-ENG116366-Light configuration-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116385-Light configuration-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116404-Light configuration-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30,20 - 4* 5W
IDE05145-ENG116461-Light configuration-Lasttyp 31,not active
IDE05145-ENG116480-Light configuration-Lasttyp 32,not active
IDE05145-ENG116499-Light configuration-Lasttyp 33,not active
IDE05145-ENG116518-Light configuration-Lasttyp 34,not active
IDE05145-ENG115948-Light configuration-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115967-Light configuration-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
IDE05145-ENG115986-Light configuration-Lasttyp 6,3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7,3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8,not active
IDE05145-ENG116043-Light configuration-Lasttyp 9,not active
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0,Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1,Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10,Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11,Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12,Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13,Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14,Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15,Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16,Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17,Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18,Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19,Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2,Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20,Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21,Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22,Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23,Always
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24,Always
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25,Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26,Always
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27,Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28,Always
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29,Always
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3,Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30,Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31,Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32,Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33,Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34,Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4,Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5,Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6,Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7,Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8,Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9,Always
IDE05145-ENG116199-Light configuration-Lichtfunktion B 17,10
IDE05145-ENG116126-Light configuration-Lichtfunktion C 13,0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0,2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1,4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10,13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11,14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12,18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13,19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14,0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15,0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16,8
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17,8
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18,2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19,4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2,8
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20,24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21,24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22,24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23,8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24,8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25,8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26,26
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27,0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28,25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29,25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3,8
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30,43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31,45
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32,46
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33,47
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34,48
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4,8
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5,8
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6,11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7,12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8,0
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9,0
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0,0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1,0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10,15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11,15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12,0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13,0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14,0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15,0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16,9
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18,0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19,0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2,9
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20,0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21,0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22,0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23,9
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24,10
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25,30
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26,0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27,0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28,0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29,0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3,10
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30,0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31,0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32,0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33,0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34,0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4,9
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5,10
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6,15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7,15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8,0
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9,0
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0,0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1,0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10,0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11,0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12,0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14,0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15,0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16,0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17,0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18,0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19,0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2,30
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20,0
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21,0
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22,0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23,30
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24,30
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25,0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26,0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27,0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28,0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29,0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3,30
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30,0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31,0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32,0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33,0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34,0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4,30
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5,30
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6,30
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7,30
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8,0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9,0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0,0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1,0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10,0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11,0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12,0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13,0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14,0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15,0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16,0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17,0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18,0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19,0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2,0
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20,0
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21,0
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22,0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23,0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24,0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25,0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26,0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27,0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28,0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29,0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3,0
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30,0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31,0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32,0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33,0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34,0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4,0
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5,0
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6,0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7,0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8,0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9,0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0,0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1,0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10,0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11,0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12,0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13,0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14,0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15,0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16,0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17,0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18,0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19,0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2,20
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20,30
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21,30
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22,0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23,0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24,0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25,0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26,0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27,0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28,0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29,0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3,20
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30,0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31,0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32,0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33,0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34,0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4,20
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5,20
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6,0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7,0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8,0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9,0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0,0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1,0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10,0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11,0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12,0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13,0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14,0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15,0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16,0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17,0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18,0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19,0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2,0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20,0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21,0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22,0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23,0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24,0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25,0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26,0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27,0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28,0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29,0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30,0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31,0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32,0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33,0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34,0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4,0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6,0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7,0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8,0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9,0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3,0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5,0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0,0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1,0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10,0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11,0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12,0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13,0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14,0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15,0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16,0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17,0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18,0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19,0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2,0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20,0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21,0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22,0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23,0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24,0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25,0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26,0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27,0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28,0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29,0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3,0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30,0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31,0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32,0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33,0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34,0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4,0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5,0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6,0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7,0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8,0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9,0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0,0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1,0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10,0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11,0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12,0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13,0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14,0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15,0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16,0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17,0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18,0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19,0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2,0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20,0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21,0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22,0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23,0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24,0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25,0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26,0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27,0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28,0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29,0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3,0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30,0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31,0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32,0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33,0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34,0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4,0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5,0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6,0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7,0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8,0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9,0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss,30 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss,1.10 °C
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle,33.00 °C
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle,32.00 °C
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle,33.00 °C
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle,32.00 °C
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle,37.50 °C
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle,36.50 °C
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle,37.50 °C
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle,36.50 °C
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle,41.00 °C
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle,40.00 °C
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle,41.00 °C
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle,40.00 °C
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten,active
IDE06096-ENG116597-Interior lighting-KL30G ohne ,not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe,not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten,not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung,active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert,60 %
IDE06425-Roller test bench mode: functional,not active
IDE06507-MAS13125-Button in center console-Funktion Taster 1,Start-stop
IDE06507-MAS13129-Button in center console-Funktion Taster 2,Laderaumschließung
IDE06507-MAS13132-Button in center console-Funktion Taster 3,Driving program
IDE06507-MAS13135-Button in center console-Funktion Taster 4,Steering wheel heater
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag,Daytime running lights
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht,not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht,not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch oder Bedienfolge moeglich,active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten,not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO,not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht,not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte,not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung / Bedienfolge,active
IDE07356-Position during interval mode,25.51 °
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs,abschalten nach der Nachlaufzeit
IDE07470-ENG02309-After-run for park light-Bedingungen zur Parklichtbegrenzung,abschaltbar über Energiemanagement
IDE07470-ENG02308-After-run for park light-Bedingungen zur Standlichtbegrenzung,abschaltbar über Energiemanagement
IDE07470-ENG02310-After-run for park light-Faktor fuer Verfügbarkeitstimer,Faktor fuer x5 Minuten
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit,30 min
IDE07470-ENG02311-After-run for park light-Standlicht-Verfügbarkeit,24 s
IDE08542-IDE02021-Access control 2-Comfort closing,active
IDE08542-IDE02022-Access control 2-Comfort opening,active
IDE08542-ENG128459-Access control 2-easycloselight_aktiv,not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen,active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen,active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit,600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus,active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen,active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen,active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen,active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen,active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus,by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen,not active
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen,active
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung,not active
IDE08542-ENG115670-Access control 2-Komfortbedienung global,active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer,not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen,active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar,adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen,not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung,not active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung,active
IDE08542-ENG125654-Access control 2-Nachsaven_nach_Verdecklauf,not active
IDE08542-ENG126841-Access control 2-Profilfunktion fuer Anklappung der Aussenspiegel,not active
IDE08542-ENG125656-Access control 2-Regenschliessen_art,once
IDE08542-ENG125655-Access control 2-Regenschliessen_ein_aus,not active
IDE08542-ENG125657-Access control 2-Remote_Unlock_Lock,not_active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen,not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen,not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen,not active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen,tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen,active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen,active
IDE08542-ENG126610-Access control 2-Signalisierung_Spiegelanklappung,active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt,not active
IDE08542-ENG02339-Access control 2-Spiegelanklappen_bei_Wiederverriegelung,active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron,active
IDE08542-ENG115869-Access control 2-Virtuelles_Pedal,not active
IDE08542-ENG126611-Access control 2-virtuelles_pedal_HMI_einstellbar,not active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung,2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen,active
IDE08786-ENG130581-Assistance light functions-Fahrlicht_Hinweis_mehrfach,not active
IDE08786-ENG126818-Assistance light functions-Fahrlichtwarnung_Hinweis_Konfig,kein_Hinweis
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset,active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert,0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit,normal
IDE08786-ENG126628-Assistance light functions-LS_Error_Ausgabe,not active
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent,Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung,Not Present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA,active
IDE08786-ENG126817-Assistance light functions-Umfeldleuchte als Manoevrierleuchte,not active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben,active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15,active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren,not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT,not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken,not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing,not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken,not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung,not active
IDE08788-ENG126819-Dyn. turn signal modes-Emergency_alert_blinken,not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken,not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2,not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing,not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links,not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts,not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken,not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing,not active
IDE08788-ENG126629-Dyn. turn signal modes-Telematikblinken1_STS_Blinken Telematikblinken2_OCU_Blinken,not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken,not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS,not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN,not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf,not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu,not active
IDE09731-ENG125014-Int. light: 2nd generation-Aufloesung Dimmzeit,0.25 s
IDE09731-ENG125024-Int. light: 2nd generation- Farbwert Farbe 1,2
IDE09731-ENG125025-Int. light: 2nd generation- Farbwert Farbe 2,3
IDE09731-ENG125026-Int. light: 2nd generation- Farbwert Farbe 3,1
IDE09731-ENG126827-Int. light: 2nd generation-Blauwert Farbe 1,225
IDE09731-ENG126830-Int. light: 2nd generation-Blauwert Farbe 2,225
IDE09731-ENG126833-Int. light: 2nd generation-Blauwert Farbe 3,225
IDE09731-ENG125018-Int. light: 2nd generation-Cockpitbeleuchtung mehrfarbig,not active
IDE09731-ENG125021-Int. light: 2nd generation-Dachbeleuchtung mehrfarbig,not active
IDE09731-ENG125028-Int. light: 2nd generation-Defaultwert Ambienteprofil Dach,80 %
IDE09731-ENG125029-Int. light: 2nd generation-Defaultwert Ambienteprofil Farbe,2
IDE09731-ENG125027-Int. light: 2nd generation-Defaultwert Ambienteprofil Mittelkonsole,80 %
IDE09731-ENG125641-Int. light: 2nd generation-Farbausgabe Cockpitbeleuchtung nicht berechnen,active
IDE09731-ENG125644-Int. light: 2nd generation-Farbausgabe Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125640-Int. light: 2nd generation-Farbausgabe Instrumententafelbeleuchtung nicht berechnen,active
IDE09731-ENG125642-Int. light: 2nd generation-Farbausgabe Lautsprecherbeleuchtung nicht berechnen,active
IDE09731-ENG125643-Int. light: 2nd generation-Farbausgabe Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125645-Int. light: 2nd generation-Farbausgabe Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG125639-Int. light: 2nd generation-Farbausgabe Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG126826-Int. light: 2nd generation-Gruenwert Farbe 1,225
IDE09731-ENG126829-Int. light: 2nd generation-Gruenwert Farbe 2,225
IDE09731-ENG126832-Int. light: 2nd generation-Gruenwert Farbe 3,225
IDE09731-ENG125634-Int. light: 2nd generation-Helligkeit Cockpitbeleuchtung nicht berechnen,not active
IDE09731-ENG125637-Int. light: 2nd generation-Helligkeit Dachbeleuchtung nicht berechnen,active
IDE09731-ENG125633-Int. light: 2nd generation-Helligkeit Instrumententafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125635-Int. light: 2nd generation-Helligkeit Lautsprecherbeleuchtung nicht berechnen,not active
IDE09731-ENG125636-Int. light: 2nd generation-Helligkeit Mittelkonsolenbeleuchtung nicht berechnen,active
IDE09731-ENG125638-Int. light: 2nd generation-Helligkeit Panoramaschiebedachbeleuchtung nicht berechnen,active
IDE09731-ENG126824-Int. light: 2nd generation-Helligkeit Tuertafelbeleuchtung nicht berechnen,not active
IDE09731-ENG125017-Int. light: 2nd generation-Instrumententafelbeleuchtung mehrfarbig,not active
IDE09731-ENG125019-Int. light: 2nd generation-Lautsprecherbeleuchtung mehrfarbig,not active
IDE09731-ENG125020-Int. light: 2nd generation-Mittelkonsolenbeleuchtung mehrfarbig,not active
IDE09731-ENG125023-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung bei geoeffnetem Rollo deaktivieren,not active
IDE09731-ENG125022-Int. light: 2nd generation-Panoramaschiebedachbeleuchtung mehrfarbig,not active
IDE09731-ENG126825-Int. light: 2nd generation-Rotwert Farbe 1,225
IDE09731-ENG126828-Int. light: 2nd generation-Rotwert Farbe 2,225
IDE09731-ENG126831-Int. light: 2nd generation-Rotwert Farbe 3,225
IDE09731-ENG125016-Int. light: 2nd generation-Tuertafelbeleuchtung mehrfarbig,active
IDE09731-ENG125015-Int. light: 2nd generation-weicher Farbwechsel,not active
IDE09732-ENG02312-Interior light: light configuration-Ambient_Farbliste_HMI,not active
IDE09732-ENG115870-Interior light: light configuration-Ambiente_Applikationsleisten_in_Instrumententafel,not installed
IDE09732-ENG115871-Interior light: light configuration-Ambiente_Applikationsleisten_in_Tuertafel,not installed
IDE09732-ENG115872-Interior light: light configuration-Ambiente_Lautsprecher,not installed
IDE09732-ENG126836-Interior light: light configuration-Ambientemenue mit alle Zonen,not active
IDE09732-ENG126835-Interior light: light configuration-Ambientemenue mit globalem aus,not active
IDE09732-ENG125646-Interior light: light configuration-Cockpitbeleuchtung,not installed
IDE09732-ENG125648-Interior light: light configuration-Dachbeleuchtung,not installed
IDE09732-ENG125651-Interior light: light configuration-Farbwahl ueber Fahrprofil,not installed
IDE09732-ENG125650-Interior light: light configuration-Farbwahl ueber HMI,not installed
IDE09732-ENG114629-Interior light: light configuration-Foot well lighting,installed
IDE09732-ENG02313-Interior light: light configuration-Frei_Farbwahl_ueber_HMI,not active
IDE09732-ENG126834-Interior light: light configuration--Dachkonsole lokal aktivierbar,not active
IDE09732-ENG125647-Interior light: light configuration-Mittelkonsolenbeleuchtung,not installed
IDE09732-ENG125649-Interior light: light configuration-Panoramaschiebedachbeleuchtung,not installed
IDE09761-ENG126617-Seat fan charac. curve-Level_1_Lehne,30 %
IDE09761-ENG126616-Seat fan charac. curve-Level_1_Sitz,25 %
IDE09761-ENG126619-Seat fan charac. curve-Level_2_Lehne,30 %
IDE09761-ENG126618-Seat fan charac. curve-Level_2_Sitz,25 %
IDE09761-ENG126621-Seat fan charac. curve-Level_3_Lehne,58 %
IDE09761-ENG126620-Seat fan charac. curve-Level_3_Sitz,53 %
IDE09761-ENG126623-Seat fan charac. curve-Level_4_Lehne,58 %
IDE09761-ENG126622-Seat fan charac. curve-Level_4_Sitz,53 %
IDE09761-ENG126625-Seat fan charac. curve-Level_5_Lehne,85 %
IDE09761-ENG126624-Seat fan charac. curve-Level_5_Sitz,80 %
IDE09761-ENG126627-Seat fan charac. curve-Level_6_Lehne,85 %
IDE09761-ENG126626-Seat fan charac. curve-Level_6_Sitz,80 %
IDE10298-Alternating park position 1,8.51 °
IDE10299-Alternating park position 2,22.51 °
IDE11477-ENG128587-Interior lighting: parameter-p_adaption_kundenwunsch_cockpit,64
IDE11477-ENG128619-Interior lighting: parameter-p_adaption_kundenwunsch_dach,64
IDE11477-ENG128539-Interior lighting: parameter-p_adaption_kundenwunsch_fussraum,64
IDE11477-ENG128571-Interior lighting: parameter-p_adaption_kundenwunsch_itafel,64
IDE11477-ENG128555-Interior lighting: parameter-p_adaption_kundenwunsch_lautsprecher,64
IDE11477-ENG128603-Interior lighting: parameter-p_adaption_kundenwunsch_miko,64
IDE11477-ENG128635-Interior lighting: parameter-p_adaption_kundenwunsch_psd,64
IDE11477-ENG128523-Interior lighting: parameter-p_adaption_kundenwunsch_tuer,64
IDE11477-ENG128659-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI,00
IDE11477-ENG128660-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_2,00
IDE11477-ENG128661-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_3,00
IDE11477-ENG128662-Interior lighting: parameter-p_ambientelicht_verbauinformation_HMI_4,00
IDE11477-ENG128655-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI,00
IDE11477-ENG128656-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_2,00
IDE11477-ENG128657-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_3,00
IDE11477-ENG128658-Interior lighting: parameter-p_ambienteumfang_mehrfarbig_HMI_4,00
IDE11477-ENG128652-Interior lighting: parameter-p_dimmfaktor_farbwechsel_ab,01
IDE11477-ENG128651-Interior lighting: parameter-p_dimmfaktor_farbwechsel_auf,01
IDE11477-ENG128654-Interior lighting: parameter-p_farbauswahl_HMI,00
IDE11477-ENG128653-Interior lighting: parameter-p_farbwechsel_delay,00
IDE11477-ENG128596-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128628-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_dach,100 %
IDE11477-ENG128548-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128516-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128580-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128564-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128612-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_miko,100 %
IDE11477-ENG128644-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_psd,100 %
IDE11477-ENG128532-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128593-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128625-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_dach,100 %
IDE11477-ENG128545-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128513-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128577-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128561-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128609-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_miko,100 %
IDE11477-ENG128641-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_psd,100 %
IDE11477-ENG128529-Interior lighting: parameter-p_helligkeit_andereTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128595-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128627-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_dach,100 %
IDE11477-ENG128547-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_fussraum,100 %
IDE11477-ENG128515-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128579-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128563-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128611-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_miko,100 %
IDE11477-ENG128643-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_psd,100 %
IDE11477-ENG128531-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128592-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128624-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_dach,100 %
IDE11477-ENG128544-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_fussraum,100 %
IDE11477-ENG128512-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128576-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128560-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128608-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_miko,100 %
IDE11477-ENG128640-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_psd,100 %
IDE11477-ENG128528-Interior lighting: parameter-p_helligkeit_dieseTuer_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128597-Interior lighting: parameter-p_helligkeit_einausstieg_cockpit,100 %
IDE11477-ENG128629-Interior lighting: parameter-p_helligkeit_einausstieg_dach,100 %
IDE11477-ENG128549-Interior lighting: parameter-p_helligkeit_einausstieg_fussraum,100 %
IDE11477-ENG128517-Interior lighting: parameter-p_helligkeit_einausstieg_innenlicht,100 %
IDE11477-ENG128581-Interior lighting: parameter-p_helligkeit_einausstieg_itafel,100 %
IDE11477-ENG128565-Interior lighting: parameter-p_helligkeit_einausstieg_lautsprecher,100 %
IDE11477-ENG128613-Interior lighting: parameter-p_helligkeit_einausstieg_miko,100 %
IDE11477-ENG128645-Interior lighting: parameter-p_helligkeit_einausstieg_psd,100 %
IDE11477-ENG128533-Interior lighting: parameter-p_helligkeit_einausstieg_tueren,100 %
IDE11477-ENG128588-Interior lighting: parameter-p_helligkeit_entriegelt_cockpit,100 %
IDE11477-ENG128620-Interior lighting: parameter-p_helligkeit_entriegelt_dach,100 %
IDE11477-ENG128540-Interior lighting: parameter-p_helligkeit_entriegelt_fussraum,100 %
IDE11477-ENG128508-Interior lighting: parameter-p_helligkeit_entriegelt_innenlicht,100 %
IDE11477-ENG128572-Interior lighting: parameter-p_helligkeit_entriegelt_itafel,100 %
IDE11477-ENG128556-Interior lighting: parameter-p_helligkeit_entriegelt_lautsprecher,100 %
IDE11477-ENG128604-Interior lighting: parameter-p_helligkeit_entriegelt_miko,100 %
IDE11477-ENG128636-Interior lighting: parameter-p_helligkeit_entriegelt_psd,100 %
IDE11477-ENG128524-Interior lighting: parameter-p_helligkeit_entriegelt_tueren,100 %
IDE11477-ENG128602-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_cockpit,100 %
IDE11477-ENG128634-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_dach,100 %
IDE11477-ENG128554-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128522-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128586-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_itafel,100 %
IDE11477-ENG128570-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_lautsprecher,100 %
IDE11477-ENG128618-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_miko,100 %
IDE11477-ENG128650-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_psd,100 %
IDE11477-ENG128538-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG128598-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_cockpit,100 %
IDE11477-ENG128630-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_dach,100 %
IDE11477-ENG128550-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_fussraum,127 %
IDE11477-ENG128518-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_innenlicht,100 %
IDE11477-ENG128582-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_itafel,100 %
IDE11477-ENG128566-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128614-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_miko,100 %
IDE11477-ENG128646-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_psd,100 %
IDE11477-ENG128534-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_aus_tueren,100 %
IDE11477-ENG128594-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_cockpit,126 %
IDE11477-ENG128626-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_dach,126 %
IDE11477-ENG128546-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_fussraum,126 %
IDE11477-ENG128514-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_innenlicht,0 %
IDE11477-ENG128578-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_itafel,126 %
IDE11477-ENG128562-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_lautsprecher,126 %
IDE11477-ENG128610-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_miko,126 %
IDE11477-ENG128642-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_psd,126 %
IDE11477-ENG128530-Interior lighting: parameter-p_helligkeit_Fzg_geschlossen_zuendung_ein_tueren,126 %
IDE11477-ENG128591-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128623-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_dach,100 %
IDE11477-ENG128543-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_fussraum,127 %
IDE11477-ENG128511-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128575-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128559-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128607-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_miko,100 %
IDE11477-ENG128639-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_psd,100 %
IDE11477-ENG128527-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128590-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_cockpit,100 %
IDE11477-ENG128622-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_dach,100 %
IDE11477-ENG128542-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_fussraum,126 %
IDE11477-ENG128510-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_innenlicht,100 %
IDE11477-ENG128574-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_itafel,100 %
IDE11477-ENG128558-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_lautsprecher,100 %
IDE11477-ENG128606-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_miko,100 %
IDE11477-ENG128638-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_psd,100 %
IDE11477-ENG128526-Interior lighting: parameter-p_helligkeit_HD_auf_zuendung_ein_tueren,100 %
IDE11477-ENG128589-Interior lighting: parameter-p_helligkeit_max_cockpit,100 %
IDE11477-ENG128621-Interior lighting: parameter-p_helligkeit_max_dach,100 %
IDE11477-ENG128541-Interior lighting: parameter-p_helligkeit_max_fussraum,100 %
IDE11477-ENG128509-Interior lighting: parameter-p_helligkeit_max_innenlicht,100 %
IDE11477-ENG128573-Interior lighting: parameter-p_helligkeit_max_itafel,100 %
IDE11477-ENG128557-Interior lighting: parameter-p_helligkeit_max_lautsprecher,100 %
IDE11477-ENG128605-Interior lighting: parameter-p_helligkeit_max_miko,100 %
IDE11477-ENG128637-Interior lighting: parameter-p_helligkeit_max_psd,100 %
IDE11477-ENG128525-Interior lighting: parameter-p_helligkeit_max_tueren,100 %
IDE11477-ENG128599-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_cockpit,100 %
IDE11477-ENG128631-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_dach,100 %
IDE11477-ENG128551-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_fussraum,127 %
IDE11477-ENG128519-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_innenlicht,100 %
IDE11477-ENG128583-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_itafel,100 %
IDE11477-ENG128567-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128615-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_miko,100 %
IDE11477-ENG128647-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_psd,100 %
IDE11477-ENG128535-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_auf_zuendung_aus_tueren,100 %
IDE11477-ENG128600-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_cockpit,100 %
IDE11477-ENG128632-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_dach,100 %
IDE11477-ENG128552-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_fussraum,127 %
IDE11477-ENG128520-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_innenlicht,100 %
IDE11477-ENG128584-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_itafel,100 %
IDE11477-ENG128568-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_lautsprecher,100 %
IDE11477-ENG128616-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_miko,100 %
IDE11477-ENG128648-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_psd,100 %
IDE11477-ENG128536-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_HD_zu_zuendung_aus_tueren,100 %
IDE11477-ENG128601-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_cockpit,100 %
IDE11477-ENG128633-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_dach,100 %
IDE11477-ENG128553-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_fussraum,100 %
IDE11477-ENG128521-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_innenlicht,100 %
IDE11477-ENG128585-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_itafel,100 %
IDE11477-ENG128569-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_lautsprecher,100 %
IDE11477-ENG128617-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_miko,100 %
IDE11477-ENG128649-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_psd,100 %
IDE11477-ENG128537-Interior lighting: parameter-p_helligkeit_Tueren_geschlossen_schluessel_ab_tueren,100 %
IDE11477-ENG06093-Interior lighting: parameter-p_t_HMI_verzoegerung_helligkeitswerte,100 ms
IDE11477-ENG128488-Interior lighting: parameter-p_t_verzoegerung_ausstieg_cockpit,0 s
IDE11477-ENG128502-Interior lighting: parameter-p_t_verzoegerung_ausstieg_dach,0 s
IDE11477-ENG128481-Interior lighting: parameter-p_t_verzoegerung_ausstieg_fussraum,0 s
IDE11477-ENG128467-Interior lighting: parameter-p_t_verzoegerung_ausstieg_innenlicht,0 s
IDE11477-ENG128495-Interior lighting: parameter-p_t_verzoegerung_ausstieg_miko,0 s
IDE11477-ENG128474-Interior lighting: parameter-p_t_verzoegerung_ausstieg_tueren,0 s
IDE11477-ENG128487-Interior lighting: parameter-p_t_verzoegerung_einstieg_cockpit,0 s
IDE11477-ENG128501-Interior lighting: parameter-p_t_verzoegerung_einstieg_dach,0 s
IDE11477-ENG128480-Interior lighting: parameter-p_t_verzoegerung_einstieg_fussraum,20 s
IDE11477-ENG128466-Interior lighting: parameter-p_t_verzoegerung_einstieg_innenlicht,0 s
IDE11477-ENG128494-Interior lighting: parameter-p_t_verzoegerung_einstieg_miko,0 s
IDE11477-ENG128473-Interior lighting: parameter-p_t_verzoegerung_einstieg_tueren,0 s
IDE11477-ENG128490-Interior lighting: parameter-p_t_verzoegerung_entriegelt_cockpit,0 s
IDE11477-ENG128504-Interior lighting: parameter-p_t_verzoegerung_entriegelt_dach,0 s
IDE11477-ENG128483-Interior lighting: parameter-p_t_verzoegerung_entriegelt_fussraum,0 s
IDE11477-ENG128469-Interior lighting: parameter-p_t_verzoegerung_entriegelt_innenlicht,0 s
IDE11477-ENG128497-Interior lighting: parameter-p_t_verzoegerung_entriegelt_miko,0 s
IDE11477-ENG128476-Interior lighting: parameter-p_t_verzoegerung_entriegelt_tueren,0 s
IDE11477-ENG128489-Interior lighting: parameter-p_t_verzoegerung_oeffnen_cockpit,0 s
IDE11477-ENG128503-Interior lighting: parameter-p_t_verzoegerung_oeffnen_dach,0 s
IDE11477-ENG128482-Interior lighting: parameter-p_t_verzoegerung_oeffnen_fussraum,0 s
IDE11477-ENG128468-Interior lighting: parameter-p_t_verzoegerung_oeffnen_innenlicht,0 s
IDE11477-ENG128496-Interior lighting: parameter-p_t_verzoegerung_oeffnen_miko,0 s
IDE11477-ENG128475-Interior lighting: parameter-p_t_verzoegerung_oeffnen_tueren,0 s
IDE11477-ENG128491-Interior lighting: parameter-p_t_verzoegerung_schliessen_cockpit,0 s
IDE11477-ENG128505-Interior lighting: parameter-p_t_verzoegerung_schliessen_dach,0 s
IDE11477-ENG128484-Interior lighting: parameter-p_t_verzoegerung_schliessen_fussraum,0 s
IDE11477-ENG128470-Interior lighting: parameter-p_t_verzoegerung_schliessen_innenlicht,0 s
IDE11477-ENG128498-Interior lighting: parameter-p_t_verzoegerung_schliessen_miko,0 s
IDE11477-ENG128477-Interior lighting: parameter-p_t_verzoegerung_schliessen_tueren,0 s
IDE11477-ENG128492-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_cockpit,0 s
IDE11477-ENG128506-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_dach,0 s
IDE11477-ENG128485-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_fussraum,0 s
IDE11477-ENG128471-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_innenlicht,0 s
IDE11477-ENG128499-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_miko,0 s
IDE11477-ENG128478-Interior lighting: parameter-p_t_verzoegerung_schluessel_ab_tueren,0 s
IDE11477-ENG128493-Interior lighting: parameter-p_t_verzoegerung_verriegelt_cockpit,0 s
IDE11477-ENG128507-Interior lighting: parameter-p_t_verzoegerung_verriegelt_dach,0 s
IDE11477-ENG128486-Interior lighting: parameter-p_t_verzoegerung_verriegelt_fussraum,0 s
IDE11477-ENG128472-Interior lighting: parameter-p_t_verzoegerung_verriegelt_innenlicht,0 s
IDE11477-ENG128500-Interior lighting: parameter-p_t_verzoegerung_verriegelt_miko,0 s
IDE11477-ENG128479-Interior lighting: parameter-p_t_verzoegerung_verriegelt_tueren,0 s
IDE11477-ENG128663-Interior lighting: parameter-p_verzoegerung_berechnen,00
IDE11714-ENG02360-Ambientelicht Farbliste-Blauwert Farbe 10,E1
IDE11714-ENG02342-Ambientelicht Farbliste-Blauwert Farbe 4,E1
IDE11714-ENG02345-Ambientelicht Farbliste-Blauwert Farbe 5,E1
IDE11714-ENG02348-Ambientelicht Farbliste-Blauwert Farbe 6,E1
IDE11714-ENG02351-Ambientelicht Farbliste-Blauwert Farbe 7,E1
IDE11714-ENG02354-Ambientelicht Farbliste-Blauwert Farbe 8,E1
IDE11714-ENG02357-Ambientelicht Farbliste-Blauwert Farbe 9,E1
IDE11714-ENG02359-Ambientelicht Farbliste-Gruenwert Farbe 10,E1
IDE11714-ENG02341-Ambientelicht Farbliste-Gruenwert Farbe 4,E1
IDE11714-ENG02344-Ambientelicht Farbliste-Gruenwert Farbe 5,E1
IDE11714-ENG02347-Ambientelicht Farbliste-Gruenwert Farbe 6,E1
IDE11714-ENG02350-Ambientelicht Farbliste-Gruenwert Farbe 7,E1
IDE11714-ENG02353-Ambientelicht Farbliste-Gruenwert Farbe 8,E1
IDE11714-ENG02356-Ambientelicht Farbliste-Gruenwert Farbe 9,E1
IDE11714-ENG02358-Ambientelicht Farbliste-Rotwert Farbe 10,E1
IDE11714-ENG02340-Ambientelicht Farbliste-Rotwert Farbe 4,E1
IDE11714-ENG02343-Ambientelicht Farbliste-Rotwert Farbe 5,E1
IDE11714-ENG02346-Ambientelicht Farbliste-Rotwert Farbe 6,E1
IDE11714-ENG02349-Ambientelicht Farbliste-Rotwert Farbe 7,E1
IDE11714-ENG02352-Ambientelicht Farbliste-Rotwert Farbe 8,E1
IDE11714-ENG02355-Ambientelicht Farbliste-Rotwert Farbe 9,E1
MAS01490-ENG116830-Energy management-Energy_Management_Adaptation,Energy management active
MAS01490-ENG02328-Energy management-Praediktives_Energiemanagement,not active
MAS05055-lower turn position,25.51 °
MAS05056-upper turn position,166.51 °
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck,active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb,not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG,not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global,active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen,active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schließen,active
MAS05934-ENG126630-Convert. top oper.-Reichweitenbegrenzung fuer Servoheck schliessen,not active
MAS05934-ENG02319-Convert. top oper.-Remote Lock Unlock Timer s1,80 s
MAS05934-ENG02320-Convert. top oper.-Remote Lock Unlock Timer s3,20.000 ms
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach,not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung,active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy,active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder,active
MAS05934-ENG116714-Convert. top oper.-Verdeck schließen via Funkfernbedienung,active
MAS05934-ENG116715-Convert. top oper.-Verdeck schließen via Kessy,active
MAS05934-ENG116713-Convert. top oper.-Verdeck schließen via Schließzylinder,active
MAS05934-ENG126843-Convert. top oper.-ZV verriegeln bei Klemme 15 Ein,not active
MAS08228-ENG02362-Light sensor-Daemmerungsgrenze: Hysterese_obergrenze,60 lx
MAS08228-ENG02363-Light sensor-Daemmerungsgrenze_Hysterese_untergrenze,110 lx
MAS08228-ENG02372-Light sensor-ECE_Lichteinschaltschwelle,1000 lx
MAS08228-ENG02361-Light sensor-Einschaltgrenze_CHO_LHO,30 lx
MAS08228-ENG02365-Light sensor-Helligkeitsgrenze_Licht__einschalten,60 lx
MAS08228-ENG02366-Light sensor-Helligkeitsgrenze_Licht_ausschalten,110 lx
MAS08228-ENG02373-Light sensor-Helligkeitsgrenze_Licht_ausschalten_red,80
MAS08228-ENG02364-Light sensor-Helligkeitsgrenze_sehr_hell,100 lx
MAS08228-ENG02370-Light sensor-Maximale_Ausgangsspannung,4500
MAS08228-ENG02368-Light sensor-Maximale_Beleuchtungsstaerke,300 lx
MAS08228-ENG02369-Light sensor-Minimale_Ausgangsspannung,2000
MAS08228-ENG02367-Light sensor-Minimale_Beleuchtungsstaerke,0 lx
MAS08228-ENG02371-Light sensor-Tunnel_einschalt_verzoegerung,02
ENG126649-ENG126874-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_1,1.00
ENG126649-ENG126901-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_10,1.00
ENG126649-ENG126904-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_11,1.00
ENG126649-ENG126907-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_12,1.00
ENG126649-ENG126910-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_13,1.00
ENG126649-ENG126913-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_14,1.00
ENG126649-ENG126916-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_15,1.00
ENG126649-ENG126877-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_2,1.00
ENG126649-ENG126880-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_3,1.00
ENG126649-ENG126883-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_4,1.00
ENG126649-ENG126886-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_5,1.00
ENG126649-ENG126889-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_6,1.00
ENG126649-ENG126892-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_7,1.00
ENG126649-ENG126895-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_8,1.00
ENG126649-ENG126898-ambient_lighting_lin_slaves_groups-pa_korrekturfaktor_gruppe_9,1.00
ENG126649-ENG126873-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_1,door
ENG126649-ENG126900-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_10,door
ENG126649-ENG126903-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_11,door
ENG126649-ENG126906-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_12,door
ENG126649-ENG126909-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_13,door
ENG126649-ENG126912-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_14,door
ENG126649-ENG126915-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_15,door
ENG126649-ENG126876-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_2,door
ENG126649-ENG126879-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_3,door
ENG126649-ENG126882-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_4,door
ENG126649-ENG126885-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_5,door
ENG126649-ENG126888-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_6,door
ENG126649-ENG126891-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_7,door
ENG126649-ENG126894-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_8,door
ENG126649-ENG126897-ambient_lighting_lin_slaves_groups-pa_lichtfunktion_gruppe_9,door
ENG126649-ENG126872-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_1,not installed
ENG126649-ENG126899-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_10,not installed
ENG126649-ENG126902-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_11,not installed
ENG126649-ENG126905-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_12,not installed
ENG126649-ENG126908-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_13,not installed
ENG126649-ENG126911-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_14,not installed
ENG126649-ENG126914-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_15,not installed
ENG126649-ENG126875-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_2,not installed
ENG126649-ENG126878-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_3,not installed
ENG126649-ENG126881-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_4,not installed
ENG126649-ENG126884-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_5,not installed
ENG126649-ENG126887-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_6,not installed
ENG126649-ENG126890-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_7,not installed
ENG126649-ENG126893-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_8,not installed
ENG126649-ENG126896-ambient_lighting_lin_slaves_groups-pa_verbauinfo_gruppe_9,not installed
ENG128379-ENG128424-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_:12,0
ENG128379-ENG128391-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_1,0
ENG128379-ENG128418-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_10,0
ENG128379-ENG128421-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_11,0
ENG128379-ENG128427-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_13,0
ENG128379-ENG128430-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_14,0
ENG128379-ENG128433-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_15,0
ENG128379-ENG128436-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_16,0
ENG128379-ENG128439-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_17,0
ENG128379-ENG128442-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_18,0
ENG128379-ENG128445-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_19,0
ENG128379-ENG128394-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_2,0
ENG128379-ENG128448-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_20,0
ENG128379-ENG128397-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_3,0
ENG128379-ENG128400-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_4,0
ENG128379-ENG128403-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_5,0
ENG128379-ENG128406-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_6,0
ENG128379-ENG128409-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_7,0
ENG128379-ENG128412-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_8,0
ENG128379-ENG128415-ambient_lighting_lin_slaves_modules-pa_einzeladresse_slave_9,0
ENG128379-ENG128393-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_1,00
ENG128379-ENG128420-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_10,0
ENG128379-ENG128423-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_11,0
ENG128379-ENG128426-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_12,0
ENG128379-ENG128429-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_13,0
ENG128379-ENG128432-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_14,0
ENG128379-ENG128435-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_15,0
ENG128379-ENG128438-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_16,0
ENG128379-ENG128441-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_17,0
ENG128379-ENG128444-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_18,0
ENG128379-ENG128447-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_19,0
ENG128379-ENG128396-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_2,0
ENG128379-ENG128450-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_20,0
ENG128379-ENG128399-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_3,0
ENG128379-ENG128402-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_4,0
ENG128379-ENG128405-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_5,0
ENG128379-ENG128408-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_6,0
ENG128379-ENG128411-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_7,0
ENG128379-ENG128417-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave_9,0
ENG128379-ENG128414-ambient_lighting_lin_slaves_modules-pa_fehlerort_slave8,0
ENG128379-ENG128392-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_1,not installed
ENG128379-ENG128419-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_10,not installed
ENG128379-ENG128422-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_11,not installed
ENG128379-ENG128425-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_12,not installed
ENG128379-ENG128428-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_13,not installed
ENG128379-ENG128431-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_14,not installed
ENG128379-ENG128434-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_15,not installed
ENG128379-ENG128437-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_16,not installed
ENG128379-ENG128440-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_17,not installed
ENG128379-ENG128443-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_18,not installed
ENG128379-ENG128446-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_19,not installed
ENG128379-ENG128395-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_2,not installed
ENG128379-ENG128449-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_20,not installed
ENG128379-ENG128398-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_3,not installed
ENG128379-ENG128401-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_4,not installed
ENG128379-ENG128404-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_5,not installed
ENG128379-ENG128407-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_6,not installed
ENG128379-ENG128410-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_7,not installed
ENG128379-ENG128416-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave_9,not installed
ENG128379-ENG128413-ambient_lighting_lin_slaves_modules-pa_verbauinfo_slave8,not installed
ENG126647-ENG98399-debug_light_function-Activation,0
ENG126647-ENG101417-debug_light_function-Adresse,0
ENG126647-ENG126820-debug_light_function-Bitmask,0
ENG126647-ENG126821-debug_light_function-Divisor,0
ENG126647-ENG98827-debug_light_function-Offset,0
ENG126647-ENG126822-debug_light_function-Polaritaet,0
ENG126647-ENG126823-debug_light_function-WBT-Ausgabe,0
ENG99457-ENG117394-Head area heater-blower_speed,1
ENG99457-ENG98971-Head area heater-Temperature,-2
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0,0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1,200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10,2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2,400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3,600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4,800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5,1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6,1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7,1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8,1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9,1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0,100.00 %
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1,72.00 %
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10,0.00 %
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2,48.00 %
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3,33.00 %
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4,18.00 %
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5,12.00 %
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6,8.00 %
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7,6.00 %
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8,4.00 %
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9,2.00 %
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0,0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1,50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10,0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2,100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3,200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4,253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5,0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6,0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7,0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8,0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9,0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0,0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1,50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10,0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2,100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3,200
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4,500
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5,0
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6,0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7,0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8,0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9,0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0,0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1,200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10,2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2,400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3,600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4,800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5,1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6,1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7,1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8,1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9,1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0,0.00 %
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1,1.00 %
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10,100.00 %
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2,3.00 %
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3,5.00 %
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4,11.00 %
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5,22.00 %
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6,40.00 %
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7,80.00 %
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8,95.00 %
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9,100.00 %
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0,0.00 %
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1,6.00 %
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2,16.00 %
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3,30.00 %
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4,60.00 %
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5,100.00 %
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0,10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1,10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2,100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3,150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4,220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5,253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0,0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1,8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2,200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3,300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4,500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0,16.00
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1,16.00
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2,100.00
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3,100.00
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4,100.00
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0,0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1,8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2,220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3,300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4,500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0,6.00
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1,6.00
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2,100.00
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3,100.00
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4,100.00
ENG116979-ENG115658-Innenbeleuchtung KL 58xd -x0,0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd -X1,10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd -X2,50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd -X3,100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd -X4,220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd -X5,253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd -y0,2.00 %
ENG116979-ENG99777-Innenbeleuchtung KL 58xd -Y1,2.00 %
ENG116979-ENG100480-Innenbeleuchtung KL 58xd -Y2,6.00 %
ENG116979-ENG100773-Innenbeleuchtung KL 58xd -Y3,10.00 %
ENG116979-ENG100631-Innenbeleuchtung KL 58xd -Y4,80.00 %
ENG116979-ENG102174-Innenbeleuchtung KL 58xd -Y5,100.00 %
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0,0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1,8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2,50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3,500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0,100.00
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1,100.00
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2,100.00
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3,100.00
ENG126561-ENG115658-Innenbeleuchtung KL 58xs min-x0,0 lx
ENG126561-ENG101574-Innenbeleuchtung KL 58xs min-X1,8 lx
ENG126561-ENG99557-Innenbeleuchtung KL 58xs min-X2,50 lx
ENG126561-ENG102140-Innenbeleuchtung KL 58xs min-X3,510 lx
ENG126561-ENG115659-Innenbeleuchtung KL 58xs min-y0,6.00
ENG126561-ENG99777-Innenbeleuchtung KL 58xs min-Y1,6.00
ENG126561-ENG100480-Innenbeleuchtung KL 58xs min-Y2,100.00
ENG126561-ENG100773-Innenbeleuchtung KL 58xs min-Y3,100.00
ENG116977-ENG115658-Innenbeleuchtung KL 58xs -x0,0.00 %
ENG116977-ENG101574-Innenbeleuchtung KL 58xs -X1,50.00 %
ENG116977-ENG99557-Innenbeleuchtung KL 58xs -X2,100.00 %
ENG116977-ENG115659-Innenbeleuchtung KL 58xs -y0,0.00 %
ENG116977-ENG99777-Innenbeleuchtung KL 58xs -Y1,50.00 %
ENG116977-ENG100480-Innenbeleuchtung KL 58xs -Y2,100.00 %
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0,0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1,8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2,50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3,500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0,100.00
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1,100.00
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2,100.00
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3,100.00
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0,0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1,8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2,50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3,500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0,6.00
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1,6.00
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2,100.00
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3,100.00
ENG116978-ENG115658-Innenbeleuchtung KL 58xt -x0,0.00 %
ENG116978-ENG101574-Innenbeleuchtung KL 58xt -X1,50.00 %
ENG116978-ENG99557-Innenbeleuchtung KL 58xt -X2,100.00 %
ENG116978-ENG115659-Innenbeleuchtung KL 58xt -y0,0.00 %
ENG116978-ENG99777-Innenbeleuchtung KL 58xt -Y1,50.00 %
ENG116978-ENG100480-Innenbeleuchtung KL 58xt -Y2,100.00 %
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0,0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1,2000 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2,3000 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3,4000 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4,5100 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0,1.00 %
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1,5.00
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2,15.00
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3,40.00
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4,100.00
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0,maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0,maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0,maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0,100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0,0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0,0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0,0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte -DFCC 0,14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0,34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0,12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0,Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0,Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0,not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0,not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0,not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0,not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0,not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0,not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0,not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10,maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10,maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10,maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10,127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10,0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10,0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10,0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte -DFCC 10,1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10,37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10,Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10,Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10,Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10,not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10,not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10,not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10,not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10,not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10,not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11,maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11,maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11,maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11,127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11,0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11,0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11,0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte -DFCC 11,1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11,41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11,2 - Shutter: Diagnosesensierung für 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11,Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11,Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11,Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11,not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11,not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11,not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11,not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11,not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11,not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12,maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12,maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12,maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12,100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12,0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12,0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12,0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte -DFCC 12,22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12,38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12,10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12,Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12,Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12,not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12,not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12,not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12,not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12,not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12,not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12,not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13,maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13,maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13,maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13,100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13,0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13,0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13,0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte -DFCC 13,23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13,42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13,10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13,Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13,Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13,not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13,not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13,not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13,not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13,not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13,not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13,not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15,maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15,maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15,maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15,0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15,0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15,0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15,0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte -DFCC 15,00
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15,00
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15,not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15,Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15,not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15,not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15,not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15,not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15,not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15,not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15,not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15,not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16,maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16,maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16,maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16,100
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16,0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16,0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16,0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte -DFCC 16,17
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16,35
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16,8 - allgemeine Glühlampe 12W
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16,Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16,not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16,not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16,not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16,not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16,not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16,not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17,maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17,maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17,maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17,100
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17,0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17,0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17,0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte -DFCC 17,19
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17,3F
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17,8 - allgemeine Glühlampe 12W
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17,Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17,Parking light right
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17,not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17,not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17,not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17,not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17,not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17,not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18,maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18,maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18,maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18,100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18,0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18,0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18,0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte -DFCC 18,16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18,08
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18,12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18,Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18,Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18,not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18,not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18,not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18,not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18,not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18,not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18,not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19,maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19,maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19,maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19,100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19,0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19,0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19,0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte -DFCC 19,18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19,18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19,12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19,Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19,Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19,not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19,not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19,not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19,not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19,not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19,not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19,not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1,maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1,maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1,maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1,100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1,0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1,0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1,0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte -DFCC 1,15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1,3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1,12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1,Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1,Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1,not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1,not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1,not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1,not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1,not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1,not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1,not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20,maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20,maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20,maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20,100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20,0
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20,0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20,0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte -DFCC 20,2B
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20,09
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20,34 - LED Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20,Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20,Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20,not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20,not active
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20,not active
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20,Coming Home oder Leaving Home aktiv
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20,not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20,not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20,not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21,maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21,maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21,maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21,100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21,0
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21,0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21,0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte -DFCC 21,2D
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21,19
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21,34 - LED Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21,Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21,Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21,not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21,not active
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21,not active
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21,Coming Home oder Leaving Home aktiv
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21,not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21,not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21,not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22,maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22,maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22,maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22,100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22,0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22,0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22,0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte -DFCC 22,2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22,29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22,34 - LED Bremsleuchten
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22,Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22,Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22,not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22,not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22,not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22,not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22,not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22,not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22,not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23,maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23,maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23,maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23,100
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23,100
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23,0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23,0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte -DFCC 23,29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23,0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23,32 - allgemeine LED bis 12W
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23,Always
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23,Coming Home oder Leaving Home aktiv
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23,not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23,not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23,not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23,not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23,not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24,maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24,maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24,maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24,100
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24,100
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24,0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24,0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte -DFCC 24,2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24,1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24,32 - allgemeine LED bis 12W
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24,Always
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24,Parking light right
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24,Coming Home oder Leaving Home aktiv
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24,not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24,not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24,not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24,not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24,not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25,maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25,maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25,maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25,100
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25,0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25,0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25,0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte -DFCC 25,30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25,28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25,18 - 2* 5W
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25,Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25,Coming Home oder Leaving Home aktiv
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25,not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25,not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25,not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25,not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25,not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25,not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26,maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26,maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26,maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26,100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26,0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26,0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26,0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte -DFCC 26,2E
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26,0C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26,9 - allgemeine Glühlampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26,Always
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26,Nebelschlusslicht wenn kein Anhaenger gesteckt
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26,not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26,not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26,not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26,not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26,not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26,not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26,not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27,maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27,maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27,maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27,0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27,0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27,0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27,0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte -DFCC 27,2F
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27,1C
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27,9 - allgemeine Glühlampe 27W: auch H15
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27,Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27,not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27,not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27,not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27,not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27,not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27,not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27,not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27,not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28,maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28,maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28,maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28,100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28,0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28,0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28,0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte -DFCC 28,31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28,0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28,9 - allgemeine Glühlampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28,Always
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28,Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28,not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28,not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28,not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28,not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28,not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28,not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28,not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29,maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29,maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29,maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29,100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29,0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29,0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29,0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte -DFCC 29,32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29,1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29,9 - allgemeine Glühlampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29,Always
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29,Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29,not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29,not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29,not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29,not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29,not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29,not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29,not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2,maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2,maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2,maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2,35
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2,35
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2,100
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2,0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte -DFCC 2,4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2,48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2,4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2,Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2,Coming Home oder Leaving Home aktiv
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2,not active
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2,Daytime running lights
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2,not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2,not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2,not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30,maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30,maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30,maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30,100
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30,0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30,0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30,0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte -DFCC 30,02
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30,00
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30,20 - 4* 5W
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30,Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30,Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30,not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30,not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30,not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30,not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30,not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30,not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30,not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31,maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31,maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31,maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31,100
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31,0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31,0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31,0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte -DFCC 31,03
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31,00
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31,not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31,Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31,Ambientelicht 1
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31,not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31,not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31,not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31,not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31,not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31,not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31,not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32,maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32,maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32,maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32,100
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32,0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32,0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32,0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte -DFCC 32,04
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32,00
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32,not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32,Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32,Ambientelicht 2
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32,not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32,not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32,not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32,not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32,not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32,not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32,not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33,maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33,maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33,maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33,100
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33,0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33,0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33,0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte -DFCC 33,05
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33,00
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33,not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33,Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33,Ambientelicht 3
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33,not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33,not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33,not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33,not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33,not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33,not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33,not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34,maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34,maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34,maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34,100
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34,0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34,0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34,0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte -DFCC 34,06
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34,00
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34,not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34,Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34,Ambientelicht 4
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34,not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34,not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34,not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34,not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34,not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34,not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34,not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3,maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3,maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3,maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3,35
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3,35
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3,100
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3,0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte -DFCC 3,4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3,4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3,4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3,Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3,Parking light right
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3,Coming Home oder Leaving Home aktiv
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3,not active
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3,Daytime running lights
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3,not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3,not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3,not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4,maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4,maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4,maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4,127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4,127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4,127
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4,0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte -DFCC 4,49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4,3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4,1 - LED Tagfahrlichtmodul Versorgung
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4,Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4,Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4,Coming Home oder Leaving Home aktiv
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4,not active
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4,Daytime running lights
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4,not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4,not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4,not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5,maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5,maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5,maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5,127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5,127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5,127
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5,0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte -DFCC 5,4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5,44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5,1 - LED Tagfahrlichtmodul Versorgung
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5,Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5,Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5,Parking light right
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5,Coming Home oder Leaving Home aktiv
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5,not active
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5,Daytime running lights
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5,not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5,not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5,not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6,maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6,maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6,maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6,127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6,127
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6,0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6,0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte -DFCC 6,1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6,36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6,3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6,Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6,Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6,Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6,Coming Home oder Leaving Home aktiv
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6,not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6,not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6,not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6,not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6,not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7,maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7,maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7,maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7,127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7,127
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7,0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7,0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte -DFCC 7,1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7,40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7,3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7,Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7,Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7,Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7,Coming Home oder Leaving Home aktiv
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7,not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7,not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7,not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7,not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7,not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8,maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8,maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8,maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8,0
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8,0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8,0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8,0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte -DFCC 8,00
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8,00
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8,not active
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8,Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8,not active
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8,not active
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8,not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8,not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8,not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8,not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8,not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8,not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9,maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9,maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9,maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9,0
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9,0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9,0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9,0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte -DFCC 9,00
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9,00
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9,not active
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9,Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9,not active
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9,not active
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9,not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9,not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9,not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9,not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9,not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9,not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14,maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14,maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14,maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14,0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14,0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14,0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14,0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte -DFCC 14,00
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14,00
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14,not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14,Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14,not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14,not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14,not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14,not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14,not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14,not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14,not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14,not active
ENG126648-MAS10452--Mirrormode-Data bus 1,active
ENG126648-MAS10453--Mirrormode-Data bus 2,active
ENG126648-MAS10454--Mirrormode-Data bus 3,active
ENG126648-MAS12782--Mirrormode-Data bus 4,active
ENG126648-MAS12783--Mirrormode-Data bus 5,active
ENG126648-MAS12784--Mirrormode-Data bus 6,active
ENG126648-ENG118465--Mirrormode-mirror_mode_typ,not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0,0.00 %
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1,5.00 %
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2,50.00 %
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3,75.00 %
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4,110.00
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5,126.50
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0,0.00 %
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1,6.00 %
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2,16.00 %
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3,30.00 %
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4,60.00 %
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5,100.00 %
ENG98831-ENG126849-Personalisierung-Aktivierungsoption_im_HMI-Menue_sichtbar,not active
ENG98831-ENG02329-Personalisierung-Anzahl_Benutzerkonten,1
ENG98831-ENG02330-Personalisierung-Automatische_ Schluesselzuordnung,not active
ENG98831-ENG126850-Personalisierung-Benutzerkontenverwaltung_in_HMI-Menue_sichtbar,not active
ENG98831-ENG126848-Personalisierung-Personalisierung_aktiv,not active
ENG98831-ENG126851-Personalisierung-Personalisierungsfunktionen_in_HMI-Menue_sichtbar,not active
ENG98831-ENG02331-Personalisierung-PSO_FSG_Setup2_Bit_0,not active
ENG98831-ENG02332-Personalisierung-PSO_FSG_Setup2_Bit_1,not active
ENG98831-ENG02333-Personalisierung-PSO_FSG_Setup2_Bit_2,not active
ENG98831-ENG02334-Personalisierung-PSO_FSG_Setup2_Bit_3,not active
ENG98831-ENG02335-Personalisierung-PSO_FSG_Setup2_Bit_4,not active
ENG98831-ENG02336-Personalisierung-PSO_FSG_Setup2_Bit_5,not active
ENG98831-ENG02337-Personalisierung-PSO_FSG_Setup2_Bit_6,not active
ENG98831-ENG02338-Personalisierung-PSO_FSG_Setup2_Bit_7,not active
ENG122976-ENG128461-Remote_Start_Adaption-Kombi_Fahrerhinweis_m_Uebernahme_RSt,not active
ENG122976-ENG128460-Remote_Start_Adaption-Rueckmeldung_bei_Aktivierung,active
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can 1,00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can 2,00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can 3,00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can 4,00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen- 1,00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen- 2,00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen- 3,00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen- 4,00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen- 5,00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen- 6,00 00
adpmap-10-5Q0-919-283-F
;SW:5Q0-919-283-F HW:5Q0-919-283 --- Park/Steer Assist
;Component:PARKHILFE 4K H10 0054, Coding:0001050001
;EV_EPHVA14AU3700000,002024,EV_EPHVA14AU3700000_SK25.rod
;Saturday,24,December,2016,12:27:18:57018
; Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: BC7D71FC37B59DA255-80E8
IDE00001-Production mode,Deactivating
IDE01165-Park assist activation tone,On
IDE01169-Audio reduction request,On
IDE02332-Deactivate production mode,0
IDE03782-Switch-off speed for parking assist,15 km/h
MAS01426-Speaker volume for rear park assist,Stage 6
MAS01427-Speaker frequency for rear park assist,Stage 3
adpmap-15-3Q0-959-655-AS
;SW:3Q0-959-655-AS HW:3Q0-959-655-AS --- Airbags
;Component:Airbag VW20 013 0200, Coding:98CCC000000000005C5400CC000800000065
;EV_AirbaVW20TS6VW48X,001116,EV_AirbaVW20TS6VW48X.rod
;Saturday,24,December,2016,12:27:38:57018
;VCID: 8F27F6305683563AC0-80DA
IDE06314-Calibration data: pre-crash,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE06527-IDE06311-Adaptation pre-crash-Seat belt tensioner: left,not defined
IDE06527-IDE06312-Adaptation pre-crash-Seat belt tensioner: right,not defined
MAS00975-IDE01755-Airbag adaptations-Rollover protection system,not defined
MAS00975-IDE02852-Airbag adaptations-Igniter for battery interrupt: high voltage battery,not defined
MAS00975-MAS00001-Airbag adaptations-Driver airbag igniter,activated
MAS00975-MAS00003-Airbag adaptations-Passenger airbag igniter,activated
MAS00975-MAS00005-Airbag adaptations-Driver thorax airbag igniter,activated
MAS00975-MAS00006-Airbag adaptations-Front passenger side airbag igniter,activated
MAS00975-MAS00007-Airbag adaptations-Driver side rear thorax airbag igniter,not defined
MAS00975-MAS00008-Airbag adaptations-Passenger side rear thorax airbag igniter,not defined
MAS00975-MAS00009-Airbag adaptations-Driver head curtain airbag igniter,activated
MAS00975-MAS00010-Airbag adaptations-Front passenger head curtain airbag igniter,activated
MAS00975-MAS00011-Airbag adaptations-Driver knee airbag igniter,activated
MAS00975-MAS00012-Airbag adaptations-Front passenger knee airbag igniter,not defined
MAS00975-MAS00013-Airbag adaptations-Driver side seat belt tension igniter,activated
MAS00975-MAS00014-Airbag adaptations-Front passenger side seat belt tension igniter,activated
MAS00975-MAS00019-Airbag adaptations-Driver side rear safety belt tension igniter,not defined
MAS00975-MAS00020-Airbag adaptations-Passenger side rear safety belt tension igniter,not defined
MAS00975-MAS00022-Airbag adaptations-Igniter for battery interrupt,not defined
MAS00975-MAS00030-Airbag adaptations-Seat occupied recognition,activated
MAS00975-MAS00079-Airbag adaptations-Key switch,Airbag deactivation key switch installed
MAS00975-MAS01503-Airbag adaptations-Pedestrian protection igniter engine hood,not defined
adpmap-16-5Q0-953-507-GD
;SW:5Q0-953-507-GD HW:5Q0-953-549-F --- Steering wheel
;Component:Lenks. Modul 003 0140, Coding:1400
;EV_SMLSKLOMQB,020002,EV_SMLSKLOMQB_SK48.rod
;Saturday,24,December,2016,12:27:54:57018
;VCID: FEF9BBF461294FB23B-80AA
ENG126411-p_k_i,0.040 %/s
ENG126415-p_k_i_offset,4 K
ENG126410-p_k_p,13.0 %
ENG126419-p_leistung_lrh,110 W
ENG126417-p_n_fehler_p_verriegelt,250
ENG120504-p_s_NWDF_spg,00000000
ENG102189-p_t_blinker_entprellen,40 ms
ENG102332-p_t_blinker_err_el_kurzschluss,200 ms
ENG104011-p_t_blinker_err_el_unterbrechung,1000 ms
ENG120503-p_t_blinker_err_fernlicht_haengt_aus,5000 ms
ENG120502-p_t_blinker_err_fernlicht_haengt_ein,300 s
ENG104185-p_t_blinker_err_gra_haengt_aus,5000 ms
ENG100988-p_t_blinker_err_gra_haengt_ein,300 s
ENG103202-p_t_blinker_err_lichthupe_haengt_aus,5000 ms
ENG100154-p_t_blinker_err_lichthupe_haengt_ein,300 s
ENG100923-p_t_blinker_err_unplausibel,200 ms
ENG103471-p_t_blinker_gra_entprellen,40 ms
ENG101294-p_t_blinker_sperrzeit,100 ms
ENG127114-p_t_entprellung_p_unplausibel,400 ms
ENG104033-p_t_entprellzeit_ueberspannung,90000 ms
ENG101392-p_t_entprellzeit_unterspannung,90000 ms
ENG102689-p_t_fas_entprellen,40 ms
ENG120505-p_t_gra_ea_error,200 ms
ENG101014-p_t_grahebel_entprellen,40 ms
ENG104117-p_t_grahebel_err_el_kurzschluss,200 ms
ENG102950-p_t_grahebel_err_el_unterbrechung,1000 ms
ENG103784-p_t_grahebel_err_gra_haengt_aus,5000 ms
ENG102546-p_t_grahebel_err_gra_haengt_ein,300 s
ENG103536-p_t_grahebel_err_unplausibel,200 ms
ENG126416-p_t_grenze_v,10 km/h
ENG99436-p_t_hupe_entprellen,40 ms
ENG102496-p_t_hupe_err_hinweis,2000 ms
ENG101071-p_t_hupe_err_hupe_haengt_aus,5000 ms
ENG101518-p_t_hupe_err_hupe_haengt_ein,60 s
ENG101702-p_t_hupe_indien_entprellen,500 ms
ENG126421-p_t_lrh_kurzschluss_entprellen,200 ms
ENG126422-p_t_lrh_unterbrechung_entprellen,1000 ms
ENG103999-p_t_p_verriegelt_entprellen,40 ms
ENG126412-p_t_soll_0,39 °C
ENG126413-p_t_soll_1,43 °C
ENG126414-p_t_soll_2,47 °C
ENG100796-p_t_spannung_obere_schwelle,16.7 V
ENG102338-p_t_spannung_untere_schwelle,8.5 V
ENG100559-p_t_wischer_entprellen,40 ms
ENG103039-p_t_wischer_err_el_kurzschluss,200 ms
ENG101343-p_t_wischer_err_el_unterbrechung,1000 ms
ENG108143-p_t_wischer_err_intervallpoti_haengt_aus,5000 ms
ENG102443-p_t_wischer_err_intervallpoti_haengt_ein,300 s
ENG101059-p_t_wischer_err_mfa_haengt_aus,5000 ms
ENG100346-p_t_wischer_err_mfa_haengt_ein,300 s
ENG103464-p_t_wischer_err_waschen_haengt_aus,5000 ms
ENG100423-p_t_wischer_err_waschen_haengt_ein,300 s
ENG99933-p_t_wischer_err_wischen_haengt_aus,5000 ms
ENG102586-p_t_wischer_err_wischen_haengt_ein,300 s
ENG101592-p_t_wischer_intervall_entprellen,40 ms
ENG103607-p_t_wischer_winterstellung,60 s
ENG126423-p_temp_lenkradheizung_aus,50 °C
ENG126420-p_zeit_temperatur_statisch_lrh,300 s
adpmap-17-5E0-920-780-C
;SW:5E0-920-780-C HW:5E0-920-780-C --- Instruments
;Component:KOMBI 202 9630, Coding:07A40A002980000801082A001000000000000000
;EV_DashBoardJCIMQBAB,009007,EV_DashBoardJCIMQBAB_VW48.rod
;Saturday,24,December,2016,12:28:38:57018
;VCID: A757BE90DE332E7A28-80F2
IDE00295-Oil temperature display,On
IDE00301-Distance,295 km
IDE00342-ESI: Resetting ESI,no warning
IDE00343-Language version,romanian
IDE00345-MAS00234-MFA3-Reset-MFI button RESET / OK,Manual reset: not possible
IDE00345-MAS05463-MFA3-Reset-Refuel detection gasoline / diesel,MFA3-Reset
IDE00345-MAS05464-MFA3-Reset-Refuel detection gas,MFA3-Reset
IDE00499-Display correction of consumptions and operating range,100 %
IDE00500-Hour,12 H
IDE00501-Minute,27 min
IDE00502-Year,2016 yr
IDE00503-Month,12 mon
IDE00504-Day,24 d
IDE00510-ESI: distance driven from inspection,200 km
IDE00511-ESI: time from inspection,60 d
IDE00512-ESI: minimum value km-driving distance/inspection,15000 km
IDE00513-ESI: maximum value km-driving distance/inspection,30000 km
IDE00514-ESI: maximum value of time between inspections,730 d
IDE00515-ESI: oil quality,good oil quality
IDE00517-ESI: soot entry,0 km
IDE00518-ESI: thermal load,300 km
IDE00819-Day counter,78 d
IDE00820-Activating and deactivating all development messages,not active
IDE00827-ESI: minimum value of time between inspections,365 d
IDE01153-: maximum value of distance to service,15000 km
IDE01154-: maximum value of time to service,365 d
IDE02489-Display depiction,Not available
IDE02818-IDE02689-Offset for tank calibration values-Complete tank calibration,-12.8 l
IDE02818-MAS02376-Offset for tank calibration values-Offset sensor 1,-12.8 l
IDE02818-MAS02377-Offset for tank calibration values-Offset sensor 2,12.7 l
IDE02818-MAS02378-Offset for tank calibration values-Offset sensor 3,12.7 l
IDE02818-MAS02379-Offset for tank calibration values-Offset sensor 4,12.7 l
IDE03329-Driving profiled for range remaining,5.6 l/100km
IDE03346-IDE00301-Units adjusted-Distance,Kilometers
IDE03346-MAS01230-Units adjusted-Date,dd_mm_yy
IDE03346-MAS01456-Units adjusted-Speed,Kilometers per hour
IDE03346-MAS02201-Units adjusted-Temperature,°C
IDE03346-MAS02957-Units adjusted-Time,24h
IDE03346-MAS03032-Units adjusted-Volume,Liter
IDE03346-MAS03034-Units adjusted-Pressure,bar
IDE03346-MAS05637-Units adjusted-Operating range consumption: CNG (compressed natural gas),kg per 100 km
IDE03346-MAS05638-Units adjusted-Consumption gasoline / diesel - LPG (liquefied petroleum gas),Liters per 100 km
IDE03348-MAS01456-Speed warning-Speed,0
IDE03348-MAS01561-Speed warning-Unit,Kilometers per hour
IDE03348-IDE03348-Speed warning-,not active
IDE03349-FIX: Max. distance until next mileage-related inspection,30000 km
IDE03350-FIX: Maximum time until next time-dependent inspection,730 d
IDE03351-FIX: Distance covered since last mileage-dependent inspection,200 km
IDE03352-FIX: Time since last time-dependent inspection,60 d
IDE03372-Source for synchronization of time,internal clock
IDE03568-ENG119828-Service-key settings-p_deactivate_SK_Function,On
IDE03568-ENG99943-Service-key settings-p_forcewrite_qual_time,10 s
IDE03568-ENG119827-Service-key settings-p_main_switch_Basic,On
IDE03568-ENG102414-Service-key settings-p_main_switch_keyless,On
IDE03568-ENG102611-Service-key settings-p_write_delay_speed,20 km/h
IDE03568-ENG103545-Service-key settings-p_write_delay_time,40 s
IDE03568-ENG104099-Service-key settings-p_write_distance,20 km
IDE03867-Deactivate seat belt warning,No
IDE05930-Service notification in days,30 d
IDE05931-FIX: Reset value for next mileage-dependent inspection,30000 km
IDE05932-FIX: Reset value for next time-dependent inspections,1095 d
IDE06425-Roller test bench mode: functional,not activated
IDE06588-Ignition active message: actuator,Driver door
IDE07221-Cylinder shut-off,Display
IDE11086-Service notification,30 d
MAS03555-Lap counter,Not available
MAS03685-Digital speedometer,Display
ENG117917-BAP_Debug_Mode_Release,not_released
ENG119877-ENG98401-Configuration of Development CAN-Messages-Block 1,OFF
ENG119877-ENG98402-Configuration of Development CAN-Messages-Block 10,OFF
ENG119877-ENG98445-Configuration of Development CAN-Messages-Block 11,OFF
ENG119877-ENG98403-Configuration of Development CAN-Messages-Block 12,OFF
ENG119877-ENG98446-Configuration of Development CAN-Messages-Block 13,OFF
ENG119877-ENG98447-Configuration of Development CAN-Messages-Block 14,OFF
ENG119877-ENG98448-Configuration of Development CAN-Messages-Block 15,OFF
ENG119877-ENG98404-Configuration of Development CAN-Messages-Block 16,OFF
ENG119877-ENG98449-Configuration of Development CAN-Messages-Block 17,OFF
ENG119877-ENG98450-Configuration of Development CAN-Messages-Block 18,OFF
ENG119877-ENG98451-Configuration of Development CAN-Messages-Block 19,OFF
ENG119877-ENG98452-Configuration of Development CAN-Messages-Block 2,OFF
ENG119877-ENG98405-Configuration of Development CAN-Messages-Block 20,OFF
ENG119877-ENG98453-Configuration of Development CAN-Messages-Block 21,OFF
ENG119877-ENG98406-Configuration of Development CAN-Messages-Block 22,OFF
ENG119877-ENG98454-Configuration of Development CAN-Messages-Block 23,OFF
ENG119877-ENG98455-Configuration of Development CAN-Messages-Block 24,OFF
ENG119877-ENG98456-Configuration of Development CAN-Messages-Block 25,OFF
ENG119877-ENG98407-Configuration of Development CAN-Messages-Block 26,OFF
ENG119877-ENG98457-Configuration of Development CAN-Messages-Block 27,OFF
ENG119877-ENG98458-Configuration of Development CAN-Messages-Block 28,OFF
ENG119877-ENG98459-Configuration of Development CAN-Messages-Block 29,OFF
ENG119877-ENG98408-Configuration of Development CAN-Messages-Block 3,OFF
ENG119877-ENG98409-Configuration of Development CAN-Messages-Block 30,OFF
ENG119877-ENG125180-Configuration of Development CAN-Messages-Block 31,OFF
ENG119877-ENG125181-Configuration of Development CAN-Messages-Block 32,OFF
ENG119877-ENG125182-Configuration of Development CAN-Messages-Block 33,OFF
ENG119877-ENG125183-Configuration of Development CAN-Messages-Block 34,OFF
ENG119877-ENG125184-Configuration of Development CAN-Messages-Block 35,OFF
ENG119877-ENG125185-Configuration of Development CAN-Messages-Block 36,OFF
ENG119877-ENG125186-Configuration of Development CAN-Messages-Block 37,OFF
ENG119877-ENG125187-Configuration of Development CAN-Messages-Block 38,OFF
ENG119877-ENG125188-Configuration of Development CAN-Messages-Block 39,OFF
ENG119877-ENG98410-Configuration of Development CAN-Messages-Block 4,OFF
ENG119877-ENG98460-Configuration of Development CAN-Messages-Block 5,OFF
ENG119877-ENG98461-Configuration of Development CAN-Messages-Block 6,OFF
ENG119877-ENG98462-Configuration of Development CAN-Messages-Block 7,OFF
ENG119877-ENG98411-Configuration of Development CAN-Messages-Block 8,OFF
ENG119877-ENG98463-Configuration of Development CAN-Messages-Block 9,OFF
ENG119875-defuel_threshold,9 l
ENG105831-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_day-X1,00
ENG105831-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_day-X2,32
ENG105831-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_day-X3,66
ENG105831-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_day-X4,96
ENG105831-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_day-X5,DC
ENG105831-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_day-X6,FD
ENG105831-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_day-Y1,00
ENG105831-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_day-Y2,00
ENG105831-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_day-Y3,00
ENG105831-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_day-Y4,0A
ENG105831-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_day-Y5,32
ENG105831-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_day-Y6,64
ENG105832-ENG101574-dimming_characteristic_curve_adjustment_clock_dial_night-X1,00
ENG105832-ENG99557-dimming_characteristic_curve_adjustment_clock_dial_night-X2,0A
ENG105832-ENG102140-dimming_characteristic_curve_adjustment_clock_dial_night-X3,46
ENG105832-ENG102936-dimming_characteristic_curve_adjustment_clock_dial_night-X4,64
ENG105832-ENG103548-dimming_characteristic_curve_adjustment_clock_dial_night-X5,DC
ENG105832-ENG113992-dimming_characteristic_curve_adjustment_clock_dial_night-X6,FD
ENG105832-ENG99777-dimming_characteristic_curve_adjustment_clock_dial_night-Y1,03
ENG105832-ENG100480-dimming_characteristic_curve_adjustment_clock_dial_night-Y2,03
ENG105832-ENG100773-dimming_characteristic_curve_adjustment_clock_dial_night-Y3,11
ENG105832-ENG100631-dimming_characteristic_curve_adjustment_clock_dial_night-Y4,1F
ENG105832-ENG102174-dimming_characteristic_curve_adjustment_clock_dial_night-Y5,5A
ENG105832-ENG113993-dimming_characteristic_curve_adjustment_clock_dial_night-Y6,64
ENG105834-ENG101574-dimming_characteristic_curve_adjustment_gauge-X1,00
ENG105834-ENG99557-dimming_characteristic_curve_adjustment_gauge-X2,0A
ENG105834-ENG102140-dimming_characteristic_curve_adjustment_gauge-X3,46
ENG105834-ENG102936-dimming_characteristic_curve_adjustment_gauge-X4,64
ENG105834-ENG103548-dimming_characteristic_curve_adjustment_gauge-X5,DC
ENG105834-ENG113992-dimming_characteristic_curve_adjustment_gauge-X6,FD
ENG105834-ENG99777-dimming_characteristic_curve_adjustment_gauge-Y1,03
ENG105834-ENG100480-dimming_characteristic_curve_adjustment_gauge-Y2,03
ENG105834-ENG100773-dimming_characteristic_curve_adjustment_gauge-Y3,11
ENG105834-ENG100631-dimming_characteristic_curve_adjustment_gauge-Y4,1E
ENG105834-ENG102174-dimming_characteristic_curve_adjustment_gauge-Y5,5A
ENG105834-ENG113993-dimming_characteristic_curve_adjustment_gauge-Y6,64
ENG105835-ENG101574-dimming_characteristic_curve_adjustment_indicator_lights-X1,00
ENG105835-ENG99557-dimming_characteristic_curve_adjustment_indicator_lights-X2,0A
ENG105835-ENG102140-dimming_characteristic_curve_adjustment_indicator_lights-X3,32
ENG105835-ENG102936-dimming_characteristic_curve_adjustment_indicator_lights-X4,64
ENG105835-ENG103548-dimming_characteristic_curve_adjustment_indicator_lights-X5,96
ENG105835-ENG113992-dimming_characteristic_curve_adjustment_indicator_lights-X6,FD
ENG105835-ENG99777-dimming_characteristic_curve_adjustment_indicator_lights-Y1,05
ENG105835-ENG100480-dimming_characteristic_curve_adjustment_indicator_lights-Y2,05
ENG105835-ENG100773-dimming_characteristic_curve_adjustment_indicator_lights-Y3,0C
ENG105835-ENG100631-dimming_characteristic_curve_adjustment_indicator_lights-Y4,17
ENG105835-ENG102174-dimming_characteristic_curve_adjustment_indicator_lights-Y5,32
ENG105835-ENG113993-dimming_characteristic_curve_adjustment_indicator_lights-Y6,64
ENG119878-ENG101574-dimming_characteristic_curve_adjustment_internal_phototransistor-X1,00 00
ENG119878-ENG99557-dimming_characteristic_curve_adjustment_internal_phototransistor-X2,00 32
ENG119878-ENG102140-dimming_characteristic_curve_adjustment_internal_phototransistor-X3,00 64
ENG119878-ENG102936-dimming_characteristic_curve_adjustment_internal_phototransistor-X4,00 C8
ENG119878-ENG103548-dimming_characteristic_curve_adjustment_internal_phototransistor-X5,01 F4
ENG119878-ENG99777-dimming_characteristic_curve_adjustment_internal_phototransistor-Y1,00 00
ENG119878-ENG100480-dimming_characteristic_curve_adjustment_internal_phototransistor-Y2,00 3C
ENG119878-ENG100773-dimming_characteristic_curve_adjustment_internal_phototransistor-Y3,00 B4
ENG119878-ENG100631-dimming_characteristic_curve_adjustment_internal_phototransistor-Y4,00 DC
ENG119878-ENG102174-dimming_characteristic_curve_adjustment_internal_phototransistor-Y5,00 FD
ENG105836-ENG101574-dimming_characteristic_curve_adjustment_middle_display_main_field-X1,00
ENG105836-ENG99557-dimming_characteristic_curve_adjustment_middle_display_main_field-X2,0A
ENG105836-ENG102140-dimming_characteristic_curve_adjustment_middle_display_main_field-X3,46
ENG105836-ENG102936-dimming_characteristic_curve_adjustment_middle_display_main_field-X4,64
ENG105836-ENG103548-dimming_characteristic_curve_adjustment_middle_display_main_field-X5,DC
ENG105836-ENG113992-dimming_characteristic_curve_adjustment_middle_display_main_field-X6,FD
ENG105836-ENG99777-dimming_characteristic_curve_adjustment_middle_display_main_field-Y1,01
ENG105836-ENG100480-dimming_characteristic_curve_adjustment_middle_display_main_field-Y2,01
ENG105836-ENG100773-dimming_characteristic_curve_adjustment_middle_display_main_field-Y3,06
ENG105836-ENG100631-dimming_characteristic_curve_adjustment_middle_display_main_field-Y4,0C
ENG105836-ENG102174-dimming_characteristic_curve_adjustment_middle_display_main_field-Y5,46
ENG105836-ENG113993-dimming_characteristic_curve_adjustment_middle_display_main_field-Y6,64
ENG125906-ENG126933-Illumination_algorithm-Pointer_illumination_algorithm,terminal_58xd_log_bus_parkinglight
ENG125906-ENG126396-Illumination_algorithm-Scale_switching_algorithm,parking_light
ENG119882-init_fuel_algorithm,No
ENG130585-Leaving_warning_delay,1.6 s
ENG102605-ENG103211-outside_temperature-p_blocking_time_after_v_bigger_0,15 s
ENG102605-ENG100239-outside_temperature-p_ice_warning_entry_temperature,4 °C
ENG102605-ENG103023-outside_temperature-p_ice_warning_exit_temperature,6 °C
ENG102605-ENG102658-outside_temperature-p_kmt_at_delta,25
ENG102605-ENG99866-outside_temperature-p_mileage_after_v_bigger_0,50 km
ENG102605-ENG103631-outside_temperature-P_speed_threshold,20
ENG102605-ENG99450-outside_temperature-p_storage_time_engine_off,180 min
ENG102605-ENG104179-outside_temperature-p_tendency_damping,15
ENG102605-ENG103335-outside_temperature-p_tendency_threshold,1.0 °C
ENG102605-ENG100500-outside_temperature-p_time_constant_pt1,40
ENG102605-ENG103256-outside_temperature-p_time_constant_slow_damping,20
ENG119825-Picture_Upload_Download,not active
ENG119876-Service_Key_Clear_All_Counter,No
ENG109442-ENG119793-time_parameter_display-hmi_t_Dreiter_ms,0.00 s
ENG109442-ENG119794-time_parameter_display-hmi_t_dummyMenuTimeout_ms,0 s
ENG109442-ENG119802-time_parameter_display-hmi_t_FondGurt,30 s
ENG109442-ENG119804-time_parameter_display-hmi_t_FTuerAUF,300 s
ENG109442-ENG119796-time_parameter_display-hmi_t_MenuTimeout_ms,0 s
ENG109442-ENG119799-time_parameter_display-hmi_t_NextServiceAnz_ms,0 s
ENG109442-ENG119798-time_parameter_display-hmi_t_NextWarning_ms,0 s
ENG109442-ENG119805-time_parameter_display-hmi_t_P1Pause_ms,0 s
ENG109442-ENG119800-time_parameter_display-hmi_t_P2Pause_ms,0 s
ENG109442-ENG119801-time_parameter_display-hmi_t_Quit_ms,0 s
ENG109442-ENG119797-time_parameter_display-hmi_t_TWSAnz_ms,0 s
ENG109442-ENG119795-time_parameter_display-hmi_t_UhrTimeout_ms,0 s
ENG109442-ENG119803-time_parameter_display-hmi_t_USZ,0.00 s
ENG109442-ENG119806-time_parameter_display-rollierblockgroesse,0
ENG109442-ENG101663-time_parameter_display-tDD15_off,0.15 s
ENG109442-ENG103975-time_parameter_display-tDD15_on,0.00 s
ENG109442-ENG100026-time_parameter_display-tDDWUP,1.55 s
adpmap-19-5Q0-907-530-AM
;SW:5Q0-907-530-AM HW:5Q0-907-530-F --- CAN Gateway
;Component:GW High 128 1265, Coding:030100047F085700EB00024A080F00010001050000000000000000000000
;EV_GatewLear,013020,EV_GatewLear_013.rod
;Saturday,24,December,2016,12:29:25:57018
;VCID: FCFDB1FC77355DA215-80A8
IDE00001-ENG124491-Production mode-p_mode_deactivate_mfl_keys,Deactivating
IDE00001-ENG118694-Production mode-p_mode_deactivate_recuperation,Deactivating
IDE00002-Transport mode,not active
IDE00945-ENG118688-Hysteresis voltage-Voltage_elevation,12.1 V
IDE00945-ENG118687-Hysteresis voltage-Voltage_lowering,12.1 V
IDE01211-Static current measuring mode,not activated
IDE01457-Energy management deactivation stage,Mode not active
IDE01459-Energy management heat output control status,Mode not active
IDE01844-Increase idle speed request,Mode not active
IDE01847-ENG118685-Auxiliary heater activation restriction request-Set_point_target_time,--
IDE01847-ENG118684-Auxiliary heater activation restriction request-Switch_on_ban_activation,Mode not active
IDE01860-Generator specified voltage value variable,10.6 V
IDE01996-SFT00001-Installation list: specified installations-Engine Control Module 1,coded
IDE01996-SFT00002-Installation list: specified installations-Transmission Control Module,Not coded
IDE01996-SFT00003-Installation list: specified installations-Brakes 1,coded
IDE01996-SFT00006-Installation list: specified installations-Seat Adjustment Passenger Side,Not coded
IDE01996-SFT00008-Installation list: specified installations-Air Conditioning,coded
IDE01996-SFT00009-Installation list: specified installations-Central Electrics,coded
IDE01996-SFT00011-Installation list: specified installations-Auxiliary Air Heater,Not coded
IDE01996-SFT00014-Installation list: specified installations-Media Player Position 1,Not coded
IDE01996-SFT00019-Installation list: specified installations-Adaptive Cruise Control,Not coded
IDE01996-SFT00020-Installation list: specified installations-Wheel Dampening Electronics,Not coded
IDE01996-SFT00021-Installation list: specified installations-Airbag,coded
IDE01996-SFT00022-Installation list: specified installations-Steering Column Electronics,coded
IDE01996-SFT00023-Installation list: specified installations-Dash Board,coded
IDE01996-SFT00024-Installation list: specified installations-Auxiliary Parking Heater,Not coded
IDE01996-SFT00025-Installation list: specified installations-Gateway,1
IDE01996-SFT00028-Installation list: specified installations-Vehicle Position Detection,Not coded
IDE01996-SFT00032-Installation list: specified installations-High Beam Assistance,Not coded
IDE01996-SFT00034-Installation list: specified installations-All Wheel Control,Not coded
IDE01996-SFT00035-Installation list: specified installations-Brake Boost,Not coded
IDE01996-SFT00038-Installation list: specified installations-Electronic Roof Control,Not coded
IDE01996-SFT00043-Installation list: specified installations-Steering Column Locking,Not coded
IDE01996-SFT00048-Installation list: specified installations-Special Function 2,Not coded
IDE01996-SFT00050-Installation list: specified installations-Lock Electronics,Not coded
IDE01996-SFT00054-Installation list: specified installations-Seat Adjustment Driver Side,Not coded
IDE01996-SFT00060-Installation list: specified installations-Lane Change Assistant,Not coded
IDE01996-SFT00061-Installation list: specified installations-Special Function,Not coded
IDE01996-SFT00064-Installation list: specified installations-Air Conditioning Compressor,Not coded
IDE01996-SFT00066-Installation list: specified installations-Door Electronics Driver Side,coded
IDE01996-SFT00068-Installation list: specified installations-Steering Assistance,coded
IDE01996-SFT00071-Installation list: specified installations-Sound System,Not coded
IDE01996-SFT00075-Installation list: specified installations-Multifunction module,Not coded
IDE01996-SFT00081-Installation list: specified installations-Drive Motor Control Module,Not coded
IDE01996-SFT00082-Installation list: specified installations-Door Electronics Passenger Side,coded
IDE01996-SFT00085-Installation list: specified installations-Headlight Regulation,coded
IDE01996-SFT00086-Installation list: specified installations-Radio,Not coded
IDE01996-SFT00087-Installation list: specified installations-TV Tuner,Not coded
IDE01996-SFT00095-Installation list: specified installations-Information Control Unit 1,coded
IDE01996-SFT00096-Installation list: specified installations-Tachograph,Not coded
IDE01996-SFT00101-Installation list: specified installations-Tire Pressure Monitoring 1,Not coded
IDE01996-SFT00105-Installation list: specified installations-Trailer Function,Not coded
IDE01996-SFT00108-Installation list: specified installations-Camera System Rear View,Not coded
IDE01996-SFT00109-Installation list: specified installations-Deck Lid Control Unit,Not coded
IDE01996-SFT00117-Installation list: specified installations-Telematics Communication Unit,Not coded
IDE01996-SFT00118-Installation list: specified installations-Parking Assistance,coded
IDE01996-SFT00128-Installation list: specified installations-Batterieregelung Zusatzspeicher 1,Not coded
IDE01996-SFT00130-Installation list: specified installations-Head Up Display,Not coded
IDE01996-SFT00140-Installation list: specified installations-Battery Energy Control Module,Not coded
IDE01996-SFT00165-Installation list: specified installations-Front Sensors Driver Assistance System,Not coded
IDE01996-SFT00166-Installation list: specified installations-Microphone Control Unit,Not coded
IDE01996-SFT00169-Installation list: specified installations-Actuator For Structure-borne Sound,Not coded
IDE01996-SFT00183-Installation list: specified installations-Access Startsystem Interface,Not coded
IDE01996-SFT00187-Installation list: specified installations-Door Electronics Rear Driver Side,Not coded
IDE01996-SFT00188-Installation list: specified installations-Door Electronics Rear Passenger Side,Not coded
IDE01996-SFT00189-Installation list: specified installations-High Voltage Battery Charge Management,Not coded
IDE01996-SFT00190-Installation list: specified installations-Sliding Door Rear Left,Not coded
IDE01996-SFT00191-Installation list: specified installations-Sliding Door Rear Right,Not coded
IDE01996-SFT00192-Installation list: specified installations-Actuator For Exterior Noise,Not coded
IDE01996-SFT00197-Installation list: specified installations-Thermal management,Not coded
IDE01996-SFT00198-Installation list: specified installations-Battery Charger Control Module,Not coded
IDE01996-SFT00202-Installation list: specified installations-Control module for sunroof,Not coded
IDE01996-SFT00207-Installation list: specified installations-Control Unit Lane Change Assistant 2,Not coded
IDE01996-ENG118226-Installation list: specified installations-Node_0x01,Not coded
IDE01996-ENG118227-Installation list: specified installations-Node_0x02,Not coded
IDE01996-ENG118228-Installation list: specified installations-Node_0x03,Not coded
IDE01996-ENG118229-Installation list: specified installations-Node_0x04,Not coded
IDE01996-ENG118230-Installation list: specified installations-Node_0x05,Not coded
IDE01996-ENG118231-Installation list: specified installations-Node_0x06,Not coded
IDE01996-ENG118232-Installation list: specified installations-Node_0x07,Not coded
IDE01996-ENG118233-Installation list: specified installations-Node_0x08,Not coded
IDE01996-ENG118234-Installation list: specified installations-Node_0x09,Not coded
IDE01996-ENG118235-Installation list: specified installations-Node_0x0D,Not coded
IDE01996-ENG118236-Installation list: specified installations-Node_0x11,Not coded
IDE01996-ENG118237-Installation list: specified installations-Node_0x16,Not coded
IDE01996-ENG118238-Installation list: specified installations-Node_0x17,Not coded
IDE01996-ENG118239-Installation list: specified installations-Node_0x1A,Not coded
IDE01996-ENG118241-Installation list: specified installations-Node_0x1D,Not coded
IDE01996-ENG118242-Installation list: specified installations-Node_0x1F,Not coded
IDE01996-ENG118243-Installation list: specified installations-Node_0x20,Not coded
IDE01996-ENG118244-Installation list: specified installations-Node_0x21,Not coded
IDE01996-ENG118245-Installation list: specified installations-Node_0x22,Not coded
IDE01996-ENG118246-Installation list: specified installations-Node_0x24,Not coded
IDE01996-ENG118247-Installation list: specified installations-Node_0x25,Not coded
IDE01996-ENG118248-Installation list: specified installations-Node_0x26,Not coded
IDE01996-ENG118249-Installation list: specified installations-Node_0x27,Not coded
IDE01996-ENG118250-Installation list: specified installations-Node_0x28,Not coded
IDE01996-ENG118251-Installation list: specified installations-Node_0x29,Not coded
IDE01996-ENG118252-Installation list: specified installations-Node_0x2A,Not coded
IDE01996-ENG118253-Installation list: specified installations-Node_0x2E,Not coded
IDE01996-ENG118254-Installation list: specified installations-Node_0x2F,Not coded
IDE01996-ENG118255-Installation list: specified installations-Node_0x35,Not coded
IDE01996-ENG118256-Installation list: specified installations-Node_0x36,Not coded
IDE01996-ENG118257-Installation list: specified installations-Node_0x37,Not coded
IDE01996-ENG118258-Installation list: specified installations-Node_0x38,Not coded
IDE01996-ENG118259-Installation list: specified installations-Node_0x39,Not coded
IDE01996-ENG118260-Installation list: specified installations-Node_0x3A,Not coded
IDE01996-ENG118261-Installation list: specified installations-Node_0x3C,Not coded
IDE01996-ENG118262-Installation list: specified installations-Node_0x3D,Not coded
IDE01996-ENG118263-Installation list: specified installations-Node_0x40,Not coded
IDE01996-ENG118264-Installation list: specified installations-Node_0x41,Not coded
IDE01996-ENG118265-Installation list: specified installations-Node_0x43,Not coded
IDE01996-ENG118266-Installation list: specified installations-Node_0x45,Not coded
IDE01996-ENG118267-Installation list: specified installations-Node_0x48,Not coded
IDE01996-ENG118268-Installation list: specified installations-Node_0x49,Not coded
IDE01996-ENG118269-Installation list: specified installations-Node_0x51,Not coded
IDE01996-ENG118270-Installation list: specified installations-Node_0x52,Not coded
IDE01996-ENG118271-Installation list: specified installations-Node_0x53,Not coded
IDE01996-ENG118272-Installation list: specified installations-Node_0x55,Not coded
IDE01996-ENG118273-Installation list: specified installations-Node_0x56,Not coded
IDE01996-ENG118274-Installation list: specified installations-Node_0x58,Not coded
IDE01996-ENG118275-Installation list: specified installations-Node_0x59,Not coded
IDE01996-ENG118276-Installation list: specified installations-Node_0x5A,Not coded
IDE01996-ENG118277-Installation list: specified installations-Node_0x5B,Not coded
IDE01996-ENG118278-Installation list: specified installations-Node_0x5C,Not coded
IDE01996-ENG118279-Installation list: specified installations-Node_0x5D,Not coded
IDE01996-ENG118280-Installation list: specified installations-Node_0x5E,Not coded
IDE01996-ENG118281-Installation list: specified installations-Node_0x5F,Not coded
IDE01996-ENG118282-Installation list: specified installations-Node_0x60,Not coded
IDE01996-ENG118283-Installation list: specified installations-Node_0x61,Not coded
IDE01996-ENG118284-Installation list: specified installations-Node_0x62,Not coded
IDE01996-ENG118285-Installation list: specified installations-Node_0x66,Not coded
IDE01996-ENG118286-Installation list: specified installations-Node_0x68,Not coded
IDE01996-ENG118287-Installation list: specified installations-Node_0x6B,Not coded
IDE01996-ENG118288-Installation list: specified installations-Node_0x6C,Not coded
IDE01996-ENG118289-Installation list: specified installations-Node_0x6E,Not coded
IDE01996-ENG118290-Installation list: specified installations-Node_0x74,Not coded
IDE01996-ENG118291-Installation list: specified installations-Node_0x75,Not coded
IDE01996-ENG118292-Installation list: specified installations-Node_0x78,Not coded
IDE01996-ENG118293-Installation list: specified installations-Node_0x79,Not coded
IDE01996-ENG118294-Installation list: specified installations-Node_0x7A,Not coded
IDE01996-ENG118295-Installation list: specified installations-Node_0x7D,Not coded
IDE01996-ENG118296-Installation list: specified installations-Node_0x7E,Not coded
IDE01996-ENG118297-Installation list: specified installations-Node_0x7F,Not coded
IDE01996-ENG118298-Installation list: specified installations-Node_0x80,Not coded
IDE01996-ENG118299-Installation list: specified installations-Node_0x81,Not coded
IDE01996-ENG118300-Installation list: specified installations-Node_0x82,Not coded
IDE01996-ENG118301-Installation list: specified installations-Node_0x83,Not coded
IDE01996-ENG118302-Installation list: specified installations-Node_0x85,Not coded
IDE01996-ENG118303-Installation list: specified installations-Node_0x86,Not coded
IDE01996-ENG118304-Installation list: specified installations-Node_0x87,Not coded
IDE01996-ENG118305-Installation list: specified installations-Node_0x88,Not coded
IDE01996-ENG118306-Installation list: specified installations-Node_0x89,Not coded
IDE01996-ENG118307-Installation list: specified installations-Node_0x8B,Not coded
IDE01996-ENG118308-Installation list: specified installations-Node_0x8C,Not coded
IDE01996-ENG118309-Installation list: specified installations-Node_0x8D,Not coded
IDE01996-ENG118310-Installation list: specified installations-Node_0x8E,Not coded
IDE01996-ENG118311-Installation list: specified installations-Node_0x8F,Not coded
IDE01996-ENG118312-Installation list: specified installations-Node_0x90,Not coded
IDE01996-ENG118313-Installation list: specified installations-Node_0x91,Not coded
IDE01996-ENG118314-Installation list: specified installations-Node_0x92,Not coded
IDE01996-ENG118315-Installation list: specified installations-Node_0x93,Not coded
IDE01996-ENG118316-Installation list: specified installations-Node_0x94,Not coded
IDE01996-ENG118317-Installation list: specified installations-Node_0x95,Not coded
IDE01996-ENG118318-Installation list: specified installations-Node_0x96,Not coded
IDE01996-ENG118319-Installation list: specified installations-Node_0x97,Not coded
IDE01996-ENG118320-Installation list: specified installations-Node_0x98,Not coded
IDE01996-ENG118321-Installation list: specified installations-Node_0x99,Not coded
IDE01996-ENG118322-Installation list: specified installations-Node_0x9A,Not coded
IDE01996-ENG118323-Installation list: specified installations-Node_0x9B,Not coded
IDE01996-ENG118324-Installation list: specified installations-Node_0x9C,Not coded
IDE01996-ENG118325-Installation list: specified installations-Node_0x9D,Not coded
IDE01996-ENG118326-Installation list: specified installations-Node_0x9E,Not coded
IDE01996-ENG118327-Installation list: specified installations-Node_0x9F,Not coded
IDE01996-ENG118328-Installation list: specified installations-Node_0xA0,Not coded
IDE01996-ENG118329-Installation list: specified installations-Node_0xA1,Not coded
IDE01996-ENG118330-Installation list: specified installations-Node_0xA2,Not coded
IDE01996-ENG118331-Installation list: specified installations-Node_0xA3,Not coded
IDE01996-ENG118333-Installation list: specified installations-Node_0xA5,Not coded
IDE01996-ENG118334-Installation list: specified installations-Node_0xA6,Not coded
IDE01996-ENG118335-Installation list: specified installations-Node_0xA7,Not coded
IDE01996-ENG118336-Installation list: specified installations-Node_0xA8,Not coded
IDE01996-ENG118338-Installation list: specified installations-Node_0xAA,Not coded
IDE01996-ENG118339-Installation list: specified installations-Node_0xAB,Not coded
IDE01996-ENG118340-Installation list: specified installations-Node_0xAC,Not coded
IDE01996-ENG118341-Installation list: specified installations-Node_0xAD,Not coded
IDE01996-ENG118343-Installation list: specified installations-Node_0xAF,Not coded
IDE01996-ENG118344-Installation list: specified installations-Node_0xB0,Not coded
IDE01996-ENG118345-Installation list: specified installations-Node_0xB1,Not coded
IDE01996-ENG118346-Installation list: specified installations-Node_0xB2,Not coded
IDE01996-ENG118347-Installation list: specified installations-Node_0xB3,Not coded
IDE01996-ENG118348-Installation list: specified installations-Node_0xB4,Not coded
IDE01996-ENG118349-Installation list: specified installations-Node_0xB5,Not coded
IDE01996-ENG118350-Installation list: specified installations-Node_0xB6,Not coded
IDE01996-ENG118351-Installation list: specified installations-Node_0xB7,Not coded
IDE01996-ENG118352-Installation list: specified installations-Node_0xB8,Not coded
IDE01996-ENG118353-Installation list: specified installations-Node_0xB9,Not coded
IDE01996-ENG118354-Installation list: specified installations-Node_0xBA,Not coded
IDE01996-ENG118355-Installation list: specified installations-Node_0xBB,Not coded
IDE01996-ENG118356-Installation list: specified installations-Node_0xBC,Not coded
IDE01996-ENG118357-Installation list: specified installations-Node_0xBD,Not coded
IDE01996-ENG118358-Installation list: specified installations-Node_0xBE,Not coded
IDE01996-ENG118359-Installation list: specified installations-Node_0xBF,Not coded
IDE01996-ENG118360-Installation list: specified installations-Node_0xC0,Not coded
IDE01996-ENG118361-Installation list: specified installations-Node_0xC1,Not coded
IDE01996-ENG118362-Installation list: specified installations-Node_0xC2,Not coded
IDE01996-ENG118363-Installation list: specified installations-Node_0xC3,Not coded
IDE01996-ENG118364-Installation list: specified installations-Node_0xC4,Not coded
IDE01996-ENG118365-Installation list: specified installations-Node_0xC5,Not coded
IDE01996-ENG118366-Installation list: specified installations-Node_0xC6,Not coded
IDE01996-ENG118367-Installation list: specified installations-Node_0xC7,Not coded
IDE01996-ENG118368-Installation list: specified installations-Node_0xC8,Not coded
IDE01996-ENG118369-Installation list: specified installations-Node_0xC9,Not coded
IDE01996-ENG118370-Installation list: specified installations-Node_0xCA,Not coded
IDE01996-ENG118371-Installation list: specified installations-Node_0xCB,Not coded
IDE01996-ENG118372-Installation list: specified installations-Node_0xCC,Not coded
IDE01996-ENG118373-Installation list: specified installations-Node_0xCD,Not coded
IDE01996-ENG118374-Installation list: specified installations-Node_0xCE,Not coded
IDE01996-ENG118375-Installation list: specified installations-Node_0xCF,Not coded
IDE01996-ENG118376-Installation list: specified installations-Node_0xD0,Not coded
IDE01996-ENG118377-Installation list: specified installations-Node_0xD1,Not coded
IDE01996-ENG118378-Installation list: specified installations-Node_0xD2,Not coded
IDE01996-ENG118379-Installation list: specified installations-Node_0xD3,Not coded
IDE01996-ENG118380-Installation list: specified installations-Node_0xD4,Not coded
IDE01996-ENG118381-Installation list: specified installations-Node_0xD5,Not coded
IDE01996-ENG118382-Installation list: specified installations-Node_0xD6,Not coded
IDE01996-ENG118383-Installation list: specified installations-Node_0xD7,Not coded
IDE01996-ENG118384-Installation list: specified installations-Node_0xD8,Not coded
IDE01996-ENG118385-Installation list: specified installations-Node_0xD9,Not coded
IDE01996-ENG118386-Installation list: specified installations-Node_0xDA,Not coded
IDE01996-ENG118387-Installation list: specified installations-Node_0xDB,Not coded
IDE01996-ENG118388-Installation list: specified installations-Node_0xDC,Not coded
IDE01996-ENG118389-Installation list: specified installations-Node_0xDD,Not coded
IDE01996-ENG118390-Installation list: specified installations-Node_0xDE,Not coded
IDE01996-ENG118391-Installation list: specified installations-Node_0xDF,Not coded
IDE01996-ENG118392-Installation list: specified installations-Node_0xE0,Not coded
IDE01996-ENG118393-Installation list: specified installations-Node_0xE1,Not coded
IDE01996-ENG118394-Installation list: specified installations-Node_0xE2,Not coded
IDE01996-ENG118395-Installation list: specified installations-Node_0xE3,Not coded
IDE01996-ENG118396-Installation list: specified installations-Node_0xE4,Not coded
IDE01996-ENG118397-Installation list: specified installations-Node_0xE5,Not coded
IDE01996-ENG118398-Installation list: specified installations-Node_0xE6,Not coded
IDE01996-ENG118399-Installation list: specified installations-Node_0xE7,Not coded
IDE01996-ENG118400-Installation list: specified installations-Node_0xE8,Not coded
IDE01996-ENG118401-Installation list: specified installations-Node_0xE9,Not coded
IDE01996-ENG118402-Installation list: specified installations-Node_0xEA,Not coded
IDE01996-ENG118403-Installation list: specified installations-Node_0xEB,Not coded
IDE01996-ENG118404-Installation list: specified installations-Node_0xEC,Not coded
IDE01996-ENG118405-Installation list: specified installations-Node_0xED,Not coded
IDE01996-ENG118406-Installation list: specified installations-Node_0xEE,Not coded
IDE01996-ENG118407-Installation list: specified installations-Node_0xEF,Not coded
IDE01996-ENG118408-Installation list: specified installations-Node_0xF0,Not coded
IDE01996-ENG118409-Installation list: specified installations-Node_0xF1,Not coded
IDE01996-ENG118410-Installation list: specified installations-Node_0xF2,Not coded
IDE01996-ENG118411-Installation list: specified installations-Node_0xF3,Not coded
IDE01996-ENG118412-Installation list: specified installations-Node_0xF4,Not coded
IDE01996-ENG118413-Installation list: specified installations-Node_0xF5,Not coded
IDE01996-ENG118414-Installation list: specified installations-Node_0xF6,Not coded
IDE01996-ENG118415-Installation list: specified installations-Node_0xF7,Not coded
IDE01996-ENG118416-Installation list: specified installations-Node_0xF8,Not coded
IDE01996-ENG118417-Installation list: specified installations-Node_0xF9,Not coded
IDE01996-ENG118418-Installation list: specified installations-Node_0xFA,Not coded
IDE01996-ENG118419-Installation list: specified installations-Node_0xFB,Not coded
IDE01996-ENG118420-Installation list: specified installations-Node_0xFC,Not coded
IDE01996-ENG118421-Installation list: specified installations-Node_0xFD,Not coded
IDE01996-ENG118422-Installation list: specified installations-Node_0xFE,Not coded
IDE01996-ENG118423-Installation list: specified installations-Node_0xFF,Not coded
IDE02200-Component protection showroom mode,not active
IDE03256-MAS06105-Battery adaptation-Rated battery capacity,59 Ah
IDE03256-MAS06106-Battery adaptation-Battery technology,EFB
IDE03256-MAS06107-Battery adaptation-Battery manufacturer,JCB
IDE03256-MAS06108-Battery adaptation-Battery Serial Number,1111111111
IDE03903-Production process data 1,00 00
IDE04159-Deactivation of start-stop function,Mode not active
IDE04186-Battery terminal recognition,connected
IDE04330-Transfer of release code for a SWaP function,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE04331-Selection of release codes for a SWaP function,FF FF FF FF
IDE06425-MAS06026-Roller test bench mode: functional-Activation stages,not activated
IDE06425-MAS06277-Roller test bench mode: functional-Malfunction states,no error
IDE06530-Distance left for deactivation of static current measuring mode,2
IDE06541-Distance left for deactivation of transport mode,50
IDE06753-MAS06278-Efficiency program display-Live tip air resistance: close window/sunroof,activated
IDE06753-MAS06279-Efficiency program display-Live tip engine brake: uncouple not until below 1300 RPM,activated
IDE06753-MAS06280-Efficiency program display-Live tip do not operate gas pedal during engine start,activated
IDE06753-MAS06281-Efficiency program display-Live tip adhere to switch display (only manual switch),activated
IDE06753-MAS06282-Efficiency program display-Live tip use start-stop-system,activated
IDE06753-MAS06283-Efficiency program display-Live tip switch on start-stop-system,activated
IDE06753-MAS06284-Efficiency program display-Live tip air conditioning: close window/sunroof,activated
IDE06753-MAS06285-Efficiency program display-Live tip use gearshift position D,activated
IDE06753-MAS06286-Efficiency program display-Live tip Do not press accelerator pedal at standstill,activated
IDE06753-MAS06287-Efficiency program display-Live tip sunroof open: switch of A/C (AC button),activated
IDE06753-MAS06288-Efficiency program display-Live tip avoid engine warm-up at standstill,activated
IDE06753-MAS06289-Efficiency program display-Comfort use A/C,activated
IDE06753-MAS06290-Efficiency program display-Comfort use parking heater,activated
IDE06753-MAS06291-Efficiency program display-Comfort use rear window heater,activated
IDE06753-MAS06292-Efficiency program display-Comfort use front seat heater,activated
IDE06753-MAS06293-Efficiency program display-Comfort use front seat ventilation,activated
IDE06753-MAS06294-Efficiency program display-Comfort use rear heater,activated
IDE06753-MAS06295-Efficiency program display-Comfort use fog light,activated
IDE06753-MAS06296-Efficiency program display-Comfort use rear fog light,not activated
IDE06753-MAS06297-Efficiency program display-Comfort use parking heater consumption emission,activated
IDE06753-MAS06298-Efficiency program display-Comfort use windshield heater,activated
IDE06753-MAS06299-Efficiency program display-Comfort use steering wheel heater,activated
IDE06753-MAS06300-Efficiency program display-Comfort use mirror heater,activated
IDE06753-MAS06301-Efficiency program display-Comfort use rear seat heater,not activated
IDE06753-MAS06302-Efficiency program display-Comfort use rear seat ventilation,activated
IDE07838-Counter for inconsistent states,0
IDE08348-Start/stop start voltage limit,7.6 V
IDE08624-MKE Check box,activated
IDE10736-Cyclization limitation request battery service,0
IDE10748-MAS11262-Range gain-Range gain AC system,activated
IDE10748-MAS11263-Range gain-Range gain auxiliary heater,activated
IDE10748-MAS11264-Range gain-Range gain window defogger,activated
IDE10748-MAS11265-Range gain-Range gain seat heater front,activated
IDE10748-MAS11266-Range gain-Range gain front set ventilation,activated
IDE10748-MAS11267-Range gain-Range gain rear heater,activated
IDE10748-MAS11268-Range gain-Range gain fog light,activated
IDE10748-MAS11269-Range gain-Range gain rear fog light,activated
IDE10748-MAS11270-Range gain-Range gain windshield heating,activated
IDE10748-MAS11271-Range gain-Range gain steering wheel heater,activated
IDE10748-MAS11272-Range gain-Range gain mirror heater,activated
IDE10748-MAS11273-Range gain-Range gain rear seat heater,activated
IDE10748-MAS11274-Range gain-Range gain rear seat heater,activated
IDE10748-MAS11275-Range gain-Windshield heater consumption in AC system,not activated
IDE10748-MAS11276-Range gain-Windshield heater range gain in AC system,not activated
IDE10748-MAS11277-Range gain-(low voltage) consumption,not activated
IDE10748-MAS11278-Range gain-(low voltage) range gain,not activated
IDE10748-MAS11279-Range gain-List at engine still stand,activated
IDE10748-MAS12689-Range gain-Catalogue range display,activated
IDE10748-MAS12690-Range gain-Loading condition catalogue range display,activated
IDE10748-MAS13161-Range gain-Listendarstellung Absolutwerte mit Gewichtung,not activated
ENG125878-ENG125896-AGW_Calibration-AGW_Brightness_Start_Sequence,100 %
ENG125878-ENG126255-AGW_Calibration-AGW_fade_in_deactivation_threshold,100
ENG125878-ENG125890-AGW_Calibration-AGW_Time_Fade_In,0 ms
ENG125878-ENG125892-AGW_Calibration-AGW_Time_Fade_In_Start,0 ms
ENG125878-ENG125891-AGW_Calibration-AGW_Time_Fade_Out,0 ms
ENG125878-ENG125893-AGW_Calibration-AGW_Time_Fade_Out_Start,0 ms
ENG125878-ENG125895-AGW_Calibration-AGW_Time_Start_Delay,0 ms
ENG125878-ENG125894-AGW_Calibration-AGW_Time_Start_Sequence,0 ms
ENG125879-ENG125897-AGW_Function_Releases-AGW_Enabling_Brightness,active
ENG125879-ENG125898-AGW_Function_Releases-AGW_Enabling_Flash_Frequency,active
ENG125879-ENG125899-AGW_Function_Releases-AGW_Enabling_Supression_Symbol,active
ENG118777-ENG118712-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Counter_Master_Reset,active
ENG118777-ENG118710-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Limit_Adaptation,100
ENG118777-ENG118711-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Lock_Adaptation,60000 ms
ENG118777-ENG118709-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Fiddle_Proofing_Time_Adaptation,10000 ms
ENG118777-ENG118705-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Indication_Control_Adaption,3000 ms
ENG118777-ENG118706-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Kombi_Offset_Adaption,0 ms
ENG118777-ENG118708-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Request_Repetition_Time_Adaptation,180000 ms
ENG118777-ENG118707-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Sync_Time_Adaptation,1500 ms
ENG118777-ENG118703-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Toogle_Time_Adaptation,800 ms
ENG118777-ENG118704-Driving_Profile_Selection_Parameter-Driving_Profile_Selection_Touch_Contact_Time_Adaption,2500 ms
ENG05988-ENG113874-EM_energy_management_warning_displays-Batteriemeldungen,Mode not active
ENG05988-ENG98711-EM_energy_management_warning_displays-Charge level,Mode not active
ENG05988-ENG113873-EM_energy_management_warning_displays-Generatormeldungen,Mode not active
ENG05988-ENG118686-EM_energy_management_warning_displays- Vorwarnungen,Mode not active
ENG06003-EM_heating_power_quota_adjustment,1000 W
ENG05989-EM_nominal_voltage_limitation_low_beams,12.1 V
ENG05992-EM_requirement_cyclic_time_voltage_measurement,0 s
ENG05991-EM_requirement_reduction_air_blowers,Mode not active
ENG05990-ENG100689-EM_start_stop_requirement_ambient_temperature-Maximum_temperature,-50.0 °C
ENG05990-ENG06027-EM_start_stop_requirement_ambient_temperature-Minimum_temperature,-50.0 °C
ENG05986-SFT00001-GW_Enable_CAN_Timeout_DTC-Engine Control Module 1,Enabled
ENG05986-SFT00002-GW_Enable_CAN_Timeout_DTC-Transmission Control Module,Enabled
ENG05986-SFT00003-GW_Enable_CAN_Timeout_DTC-Brakes 1,not enabled
ENG05986-SFT00006-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Passenger Side,Enabled
ENG05986-SFT00008-GW_Enable_CAN_Timeout_DTC-Air Conditioning,Enabled
ENG05986-SFT00009-GW_Enable_CAN_Timeout_DTC-Central Electrics,Enabled
ENG05986-SFT00014-GW_Enable_CAN_Timeout_DTC-Media Player Position 1,Enabled
ENG05986-SFT00019-GW_Enable_CAN_Timeout_DTC-Adaptive Cruise Control,Enabled
ENG05986-SFT00020-GW_Enable_CAN_Timeout_DTC-Wheel Dampening Electronics,Enabled
ENG05986-SFT00021-GW_Enable_CAN_Timeout_DTC-Airbag,not enabled
ENG05986-SFT00022-GW_Enable_CAN_Timeout_DTC-Steering Column Electronics,Enabled
ENG05986-SFT00023-GW_Enable_CAN_Timeout_DTC-Dash Board,Enabled
ENG05986-SFT00024-GW_Enable_CAN_Timeout_DTC-Auxiliary Parking Heater,Enabled
ENG05986-SFT00025-GW_Enable_CAN_Timeout_DTC-Gateway,Enabled
ENG05986-SFT00028-GW_Enable_CAN_Timeout_DTC-Vehicle Position Detection,Enabled
ENG05986-SFT00032-GW_Enable_CAN_Timeout_DTC-High Beam Assistance,Enabled
ENG05986-SFT00034-GW_Enable_CAN_Timeout_DTC-All Wheel Control,Enabled
ENG05986-SFT00035-GW_Enable_CAN_Timeout_DTC-Brake Boost,Enabled
ENG05986-SFT00038-GW_Enable_CAN_Timeout_DTC-Electronic Roof Control,Enabled
ENG05986-SFT00043-GW_Enable_CAN_Timeout_DTC-Steering Column Locking,Enabled
ENG05986-SFT00048-GW_Enable_CAN_Timeout_DTC-Special Function 2,Enabled
ENG05986-SFT00050-GW_Enable_CAN_Timeout_DTC-Lock Electronics,Enabled
ENG05986-SFT00054-GW_Enable_CAN_Timeout_DTC-Seat Adjustment Driver Side,Enabled
ENG05986-SFT00060-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant,Enabled
ENG05986-SFT00061-GW_Enable_CAN_Timeout_DTC-Special Function,Enabled
ENG05986-SFT00064-GW_Enable_CAN_Timeout_DTC-Air Conditioning Compressor,Enabled
ENG05986-SFT00066-GW_Enable_CAN_Timeout_DTC-Door Electronics Driver Side,Enabled
ENG05986-SFT00068-GW_Enable_CAN_Timeout_DTC-Steering Assistance,Enabled
ENG05986-SFT00071-GW_Enable_CAN_Timeout_DTC-Sound System,Enabled
ENG05986-SFT00081-GW_Enable_CAN_Timeout_DTC-Drive Motor Control Module,Enabled
ENG05986-SFT00082-GW_Enable_CAN_Timeout_DTC-Door Electronics Passenger Side,Enabled
ENG05986-SFT00085-GW_Enable_CAN_Timeout_DTC-Headlight Regulation,Enabled
ENG05986-SFT00086-GW_Enable_CAN_Timeout_DTC-Radio,Enabled
ENG05986-SFT00087-GW_Enable_CAN_Timeout_DTC-TV Tuner,Enabled
ENG05986-SFT00095-GW_Enable_CAN_Timeout_DTC-Information Control Unit 1,Enabled
ENG05986-SFT00096-GW_Enable_CAN_Timeout_DTC-Tachograph,Enabled
ENG05986-SFT00101-GW_Enable_CAN_Timeout_DTC-Tire Pressure Monitoring 1,Enabled
ENG05986-SFT00105-GW_Enable_CAN_Timeout_DTC-Trailer Function,Enabled
ENG05986-SFT00108-GW_Enable_CAN_Timeout_DTC-Camera System Rear View,Enabled
ENG05986-SFT00109-GW_Enable_CAN_Timeout_DTC-Deck Lid Control Unit,Enabled
ENG05986-SFT00117-GW_Enable_CAN_Timeout_DTC-Telematics Communication Unit,Enabled
ENG05986-SFT00118-GW_Enable_CAN_Timeout_DTC-Parking Assistance,Enabled
ENG05986-SFT00140-GW_Enable_CAN_Timeout_DTC-Battery Energy Control Module,Enabled
ENG05986-SFT00165-GW_Enable_CAN_Timeout_DTC-Front Sensors Driver Assistance System,Enabled
ENG05986-SFT00166-GW_Enable_CAN_Timeout_DTC-Microphone Control Unit,Enabled
ENG05986-SFT00169-GW_Enable_CAN_Timeout_DTC-Actuator For Structure-borne Sound,Enabled
ENG05986-SFT00183-GW_Enable_CAN_Timeout_DTC-Access Startsystem Interface,Enabled
ENG05986-SFT00187-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Driver Side,Enabled
ENG05986-SFT00188-GW_Enable_CAN_Timeout_DTC-Door Electronics Rear Passenger Side,Enabled
ENG05986-SFT00189-GW_Enable_CAN_Timeout_DTC-High Voltage Battery Charge Management,Enabled
ENG05986-SFT00190-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Left,Enabled
ENG05986-SFT00191-GW_Enable_CAN_Timeout_DTC-Sliding Door Rear Right,Enabled
ENG05986-SFT00192-GW_Enable_CAN_Timeout_DTC-Actuator For Exterior Noise,Enabled
ENG05986-SFT00197-GW_Enable_CAN_Timeout_DTC-Thermal management,Enabled
ENG05986-SFT00198-GW_Enable_CAN_Timeout_DTC-Battery Charger Control Module,Enabled
ENG05986-SFT00202-GW_Enable_CAN_Timeout_DTC-Control module for sunroof,Enabled
ENG05986-SFT09787-GW_Enable_CAN_Timeout_DTC-Lane Change Assistant 2,Enabled
ENG05986-ENG118664-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x00,Enabled
ENG05986-ENG118466-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x01,Enabled
ENG05986-ENG118467-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x02,Enabled
ENG05986-ENG118468-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x03,Enabled
ENG05986-ENG118469-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x04,Enabled
ENG05986-ENG118470-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x05,Enabled
ENG05986-ENG118471-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x06,Enabled
ENG05986-ENG118472-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x07,Enabled
ENG05986-ENG118473-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x08,Enabled
ENG05986-ENG118474-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x09,Enabled
ENG05986-ENG118475-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x0D,Enabled
ENG05986-ENG118476-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x11,Enabled
ENG05986-ENG118477-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x16,Enabled
ENG05986-ENG118478-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x17,Enabled
ENG05986-ENG118479-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1A,Enabled
ENG05986-ENG118480-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1B,Enabled
ENG05986-ENG118481-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1D,Enabled
ENG05986-ENG118482-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x1F,Enabled
ENG05986-ENG118483-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x20,Enabled
ENG05986-ENG118484-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x21,Enabled
ENG05986-ENG118485-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x22,Enabled
ENG05986-ENG118486-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x24,Enabled
ENG05986-ENG118487-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x25,Enabled
ENG05986-ENG118488-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x26,Enabled
ENG05986-ENG118489-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x27,Enabled
ENG05986-ENG118490-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x28,Enabled
ENG05986-ENG118491-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x29,Enabled
ENG05986-ENG118492-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2A,Enabled
ENG05986-ENG118493-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2E,Enabled
ENG05986-ENG118494-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x2F,Enabled
ENG05986-ENG118495-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x35,Enabled
ENG05986-ENG118496-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x36,Enabled
ENG05986-ENG118497-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x37,Enabled
ENG05986-ENG118498-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x38,Enabled
ENG05986-ENG118499-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x39,Enabled
ENG05986-ENG118500-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3A,Enabled
ENG05986-ENG118501-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3C,Enabled
ENG05986-ENG118502-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x3D,Enabled
ENG05986-ENG118503-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x40,Enabled
ENG05986-ENG118504-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x41,Enabled
ENG05986-ENG118505-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x43,Enabled
ENG05986-ENG118506-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x45,Enabled
ENG05986-ENG118507-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x48,Enabled
ENG05986-ENG118508-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x49,Enabled
ENG05986-ENG118509-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x51,Enabled
ENG05986-ENG118510-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x52,Enabled
ENG05986-ENG118511-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x53,Enabled
ENG05986-ENG118512-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x55,Enabled
ENG05986-ENG118513-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x56,Enabled
ENG05986-ENG118514-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x58,Enabled
ENG05986-ENG118515-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x59,Enabled
ENG05986-ENG118516-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5A,Enabled
ENG05986-ENG118517-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5B,Enabled
ENG05986-ENG118518-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5C,Enabled
ENG05986-ENG118519-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5D,Enabled
ENG05986-ENG118520-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5E,Enabled
ENG05986-ENG118521-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x5F,Enabled
ENG05986-ENG118522-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x60,Enabled
ENG05986-ENG118523-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x61,Enabled
ENG05986-ENG118524-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x62,Enabled
ENG05986-ENG118525-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x66,Enabled
ENG05986-ENG118526-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x68,Enabled
ENG05986-ENG118527-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6B,Enabled
ENG05986-ENG118528-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6C,Enabled
ENG05986-ENG118529-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x6E,Enabled
ENG05986-ENG118530-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x74,Enabled
ENG05986-ENG118531-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x75,Enabled
ENG05986-ENG118532-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x78,Enabled
ENG05986-ENG118533-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x79,Enabled
ENG05986-ENG118534-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7A,Enabled
ENG05986-ENG118535-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7D,Enabled
ENG05986-ENG118536-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7E,Enabled
ENG05986-ENG118537-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x7F,Enabled
ENG05986-ENG118538-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x80,Enabled
ENG05986-ENG118539-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x81,Enabled
ENG05986-ENG118540-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x82,Enabled
ENG05986-ENG118541-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x83,Enabled
ENG05986-ENG118542-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x85,Enabled
ENG05986-ENG118543-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x86,Enabled
ENG05986-ENG118544-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x87,Enabled
ENG05986-ENG118545-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x88,Enabled
ENG05986-ENG118546-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x89,Enabled
ENG05986-ENG118547-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8B,Enabled
ENG05986-ENG118548-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8C,Enabled
ENG05986-ENG118549-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8D,Enabled
ENG05986-ENG118550-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8E,Enabled
ENG05986-ENG118551-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x8F,Enabled
ENG05986-ENG118552-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x90,Enabled
ENG05986-ENG118553-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x91,Enabled
ENG05986-ENG118554-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x92,Enabled
ENG05986-ENG118555-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x93,Enabled
ENG05986-ENG118556-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x94,Enabled
ENG05986-ENG118557-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x95,Enabled
ENG05986-ENG118558-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x96,Enabled
ENG05986-ENG118559-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x97,Enabled
ENG05986-ENG118560-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x98,Enabled
ENG05986-ENG118561-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x99,Enabled
ENG05986-ENG118562-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9A,Enabled
ENG05986-ENG118563-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9B,Enabled
ENG05986-ENG118564-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9C,Enabled
ENG05986-ENG118565-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9D,Enabled
ENG05986-ENG118566-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9E,Enabled
ENG05986-ENG118567-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0x9F,Enabled
ENG05986-ENG118568-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA0,Enabled
ENG05986-ENG118569-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA1,Enabled
ENG05986-ENG118570-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA2,Enabled
ENG05986-ENG118571-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA3,Enabled
ENG05986-ENG118572-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA4,Enabled
ENG05986-ENG118573-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA5,Enabled
ENG05986-ENG118574-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA6,Enabled
ENG05986-ENG118575-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA7,Enabled
ENG05986-ENG118576-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA8,Enabled
ENG05986-ENG118577-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xA9,Enabled
ENG05986-ENG118578-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAA,Enabled
ENG05986-ENG118579-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAB,Enabled
ENG05986-ENG118580-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAC,Enabled
ENG05986-ENG118581-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAD,Enabled
ENG05986-ENG118582-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAE,Enabled
ENG05986-ENG118583-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xAF,Enabled
ENG05986-ENG118584-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB0,Enabled
ENG05986-ENG118585-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB1,Enabled
ENG05986-ENG118586-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB2,Enabled
ENG05986-ENG118587-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB3,Enabled
ENG05986-ENG118588-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB4,Enabled
ENG05986-ENG118589-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB5,Enabled
ENG05986-ENG118590-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB6,Enabled
ENG05986-ENG118591-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB7,Enabled
ENG05986-ENG118592-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB8,Enabled
ENG05986-ENG118593-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xB9,Enabled
ENG05986-ENG118594-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBA,Enabled
ENG05986-ENG118595-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBB,Enabled
ENG05986-ENG118596-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBC,Enabled
ENG05986-ENG118597-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBD,Enabled
ENG05986-ENG118598-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBE,Enabled
ENG05986-ENG118599-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xBF,Enabled
ENG05986-ENG118600-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC0,Enabled
ENG05986-ENG118601-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC1,Enabled
ENG05986-ENG118602-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC2,Enabled
ENG05986-ENG118603-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC3,Enabled
ENG05986-ENG118604-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC4,Enabled
ENG05986-ENG118605-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC5,Enabled
ENG05986-ENG118606-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC6,Enabled
ENG05986-ENG118607-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC7,Enabled
ENG05986-ENG118608-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC8,Enabled
ENG05986-ENG118609-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xC9,Enabled
ENG05986-ENG118610-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCA,Enabled
ENG05986-ENG118611-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCB,Enabled
ENG05986-ENG118612-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCC,Enabled
ENG05986-ENG118613-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCD,Enabled
ENG05986-ENG118614-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCE,Enabled
ENG05986-ENG118615-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xCF,Enabled
ENG05986-ENG118616-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD0,Enabled
ENG05986-ENG118617-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD1,Enabled
ENG05986-ENG118618-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD2,Enabled
ENG05986-ENG118619-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD3,Enabled
ENG05986-ENG118620-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD4,Enabled
ENG05986-ENG118621-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD5,Enabled
ENG05986-ENG118622-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD6,Enabled
ENG05986-ENG118623-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD7,Enabled
ENG05986-ENG118624-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD8,Enabled
ENG05986-ENG118625-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xD9,Enabled
ENG05986-ENG118626-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDA,Enabled
ENG05986-ENG118627-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDB,Enabled
ENG05986-ENG118628-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDC,Enabled
ENG05986-ENG118629-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDD,Enabled
ENG05986-ENG118630-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDE,Enabled
ENG05986-ENG118631-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xDF,Enabled
ENG05986-ENG118632-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE0,Enabled
ENG05986-ENG118633-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE1,Enabled
ENG05986-ENG118634-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE2,Enabled
ENG05986-ENG118635-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE3,Enabled
ENG05986-ENG118636-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE4,Enabled
ENG05986-ENG118637-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE5,Enabled
ENG05986-ENG118638-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE6,Enabled
ENG05986-ENG118639-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE7,Enabled
ENG05986-ENG118640-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE8,Enabled
ENG05986-ENG118641-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xE9,Enabled
ENG05986-ENG118642-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEA,Enabled
ENG05986-ENG118643-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEB,Enabled
ENG05986-ENG118644-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEC,Enabled
ENG05986-ENG118645-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xED,Enabled
ENG05986-ENG118646-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEE,Enabled
ENG05986-ENG118647-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xEF,Enabled
ENG05986-ENG118648-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF0,Enabled
ENG05986-ENG118649-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF1,Enabled
ENG05986-ENG118650-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF2,Enabled
ENG05986-ENG118651-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF3,Enabled
ENG05986-ENG118652-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF4,Enabled
ENG05986-ENG118653-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF5,Enabled
ENG05986-ENG118654-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF6,Enabled
ENG05986-ENG118655-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF7,Enabled
ENG05986-ENG118656-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF8,Enabled
ENG05986-ENG118657-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xF9,Enabled
ENG05986-ENG118658-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFA,Enabled
ENG05986-ENG118659-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFB,Enabled
ENG05986-ENG118660-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFC,Enabled
ENG05986-ENG118661-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFD,Enabled
ENG05986-ENG118662-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFE,Enabled
ENG05986-ENG118663-GW_Enable_CAN_Timeout_DTC-Gateway_Component_List_Failure_Mask_Node_0xFF,Enabled
ENG05987-ENG118464-GW_mirror_mode-mirror_mode_bus,Databus drivetrain
ENG05987-ENG118465-GW_mirror_mode-mirror_mode_typ,not active
ENG05993-GW_routing_0,00 00 00 00 00 00 00 00 00 00 00 00
ENG05994-GW_routing_1,00 00 00 00 00 00 00 00 00 00 00 00
ENG05995-GW_routing_2,00 00 00 00 00 00 00 00 00 00 00 00
ENG05996-GW_routing_3,00 00 00 00 00 00 00 00 00 00 00 00
ENG05997-GW_routing_4,00 00 00 00 00 00 00 00 00 00 00 00
ENG05998-GW_routing_5,00 00 00 00 00 00 00 00 00 00 00 00
ENG05999-GW_routing_6,00 00 00 00 00 00 00 00 00 00 00 00
ENG06000-GW_routing_7,00 00 00 00 00 00 00 00 00 00 00 00
ENG06001-GW_routing_8,00 00 00 00 00 00 00 00 00 00 00 00
ENG06002-GW_routing_9,00 00 00 00 00 00 00 00 00 00 00 00
ENG118774-WakeUpMonitor_Activation,activated
ENG118773-ENG99074-WakeUpMonitor_Configuration-Max_Num_Keeping_Awake_Events,100
ENG118773-ENG103852-WakeUpMonitor_Configuration-Sample_Time_Keeping_Awake_Events,12 s
ENG118773-ENG127936-WakeUpMonitor_Configuration-WakeUpMonitor_Start_Delay,0 s
adpmap-42-5Q4-959-593-E
;SW:5Q4-959-593-E HW:5Q4-959-593-B --- Door Elect, Driver
;Component: FS 010 0031, Coding:00110120D000040000001100
;EV_DCUDriveSideEWMAXCONT,006001,EV_DCUDriveSideEWMAXCONT.rod
;Saturday,24,December,2016,12:30:12:57018
; Version: Release 16.8.4 (x64) Data version: 20161129 DS267.0
;VCID: C7971E107E73CE7AC8-8092
IDE00001-Production mode,00000000 00000000 00000000
IDE02332-Deactivate production mode,00000000 00000000 00000000
ENG117304-Patch_Code_Driver_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117297-Reversing_Threshold_Driver_Side_Front,90 %
ENG117299-Reversing_Threshold_Driver_Side_Rear,90 %
ENG117302-Window_Regulator_Supplier_Settings_Driver_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 AF 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 9D 42
ENG117303-Window_Regulator_Supplier_Settings_Driver_Side_Rear_2,02 8A 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 02 12 19 0A 00 05 F6 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 32 03 19 0B 12 10 64 EC D8 FB F6 1E 14 32 05 0B 00 00 82 02 19 0D 16 14 64 D8 C4 F6 F1 28 1E 32 05 0D 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 97 8E
ENG117301-Window_Regulator_VW_Settings_Driver_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 1E 00 32 32 01 90 00 00 00 00 00 00 00 AF 00 00 32 3C C8 00 4E 00 4D 79 64 64 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 31 30 36 01 00 00 00 00 00 00 00 00 00 D3 27
adpmap-44-5Q0-909-144-T
;SW:5Q0-909-144-T HW:5Q0-909-144-R --- Steering Assist
;Component:EPS_MQB_ZFLS 129 1072, Coding:8107
;EV_SteerAssisMQB,013144,EV_SteerAssisMQB_013.rod
;Saturday,24,December,2016,12:30:32:57018
;VCID: C58B1418447FDC6A3A-8090
IDE00820-Activating and deactivating all development messages,not active
IDE03724-Straight line running,active
IDE03734-Support power,100%
IDE04130-Characteristic curve of steering assistance,Driving profile selection button
IDE04555-Activation of pwr steering asst without engine running,not active
IDE05162-Software end stop,active
IDE06419-Driving profile switchover,Incremental: controlled over time
IDE07540-Download without rest bus,not active
IDE09571-RPM monitoring,active
MAS02080- calibration protocol,not active
adpmap-52-5Q4-959-592-E
;SW:5Q4-959-592-E HW:5Q4-959-592-B --- Door Elect, Pass.
;Component: BFS 010 0031, Coding:00110120D000040000001100
;EV_DCUPasseSideEWMAXCONT,006001,EV_DCUPasseSideEWMAXCONT.rod
;Saturday,24,December,2016,12:30:49:57018
;VCID: C68913147979D77233-8092
ENG117308-Patch_Code_Passenger_Side_Rear,00 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF 22 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
ENG117298-Reversing_Threshold_Passenger_Side_Front,90 %
ENG117300-Reversing_Threshold_Passenger_Side_Rear,90 %
ENG117306-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_1,00 00 14 83 2B 14 F0 F0 F0 00 20 00 FC 7C 00 14 00 05 06 64 01 F4 32 0F 00 07 80 00 00 07 3F 80 00 B4 00 0C 00 0C 00 27 00 50 00 89 00 D1 01 29 01 7B 04 04 03 01 03 07 03 E8 0B B8 32 05 0F 2D 50 73 04 04 9A 3C 09 1A 36 63 00 83 E0 E7 04 4E 53 70 CA 00 03 00 0C 00 0F 01 6E 5A 01 90 85 07 D0 10 10 00 14 00 14 03 84 27 10 53 6D 03 00 10 80 0C 01 FF 9F FF 00 00 00 0A 01 00 00 00 CE CA
ENG117307-Window_Regulator_Supplier_Settings_Passenger_Side_Rear_2,02 8A 02 26 14 EC FF 02 02 0A 02 01 00 0A 05 32 02 12 19 0A 00 05 F6 32 1E 0F 00 02 FE 05 05 FB 12 0D 00 00 00 00 FF 00 00 00 00 FF 00 23 00 19 1E 20 1E 64 D8 C4 F6 F1 28 1E 32 05 1E 00 00 32 03 19 0B 12 10 64 EC D8 FB F6 1E 14 32 05 0B 00 00 82 02 19 0D 16 14 64 D8 C4 F6 F1 28 1E 32 05 0D 00 0A 28 0A 0A 28 23 05 0A 28 1E 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 97 8E
ENG117305-Window_Regulator_VW_Settings_Passenger_Side_Rear,F6 00 F0 00 10 19 0F 03 F0 08 00 14 C8 00 00 00 01 A4 01 C2 09 64 23 C8 1E 00 32 32 01 90 00 00 00 00 00 00 00 AF 00 00 32 3C C8 00 4E 00 4D 79 00 00 32 60 D3 6D CF 64 1E 32 0A 0A 5B D9 6D CF 64 14 32 32 32 14 00 00 42 31 30 36 01 00 00 00 00 00 00 00 00 00 DE A1
adpmap-55-7P6-907-357-D
;SW:7P6-907-357-D HW:7P6-907-357-A --- Headlight Range
;Component:- H07 0090, Coding:03CA00003F000000
;EV_HeadlRegulVWAFSMQB,001120,EV_HeadlRegulVWAFSMQB.rod
;Saturday,24,December,2016,12:31:10:57018
;VCID: C085050C5B5DF94209-8094
IDE03641-Presentation run dynamic light,active
IDE03642-Presentation mode,not active
IDE03679-Adaptive light functions,not active
IDE03787-Activate left/right hand drive switch-over,not active
ENG100660- to Level Scaling Factor Front,3.26 mm/%
ENG103748- to Level Scaling Factor Rear,-4.08 mm/%
ENG103979-Reference_Run_Start_Condition,Engine start
adpmap-5F-5Q0-035-840-B
;SW:5Q0-035-840-B HW:5Q0-035-840-B --- Information Electr.
;Component:MU-S--ER H30 0359, Coding:03730200FF00000011110001000002002F0100C40120010002
;EV_MUStd4CTSAT,001022,EV_MUStd4CTSAT_SK26.rod
;Saturday,24,December,2016,12:31:26:57018
;VCID: AC5D41BCC7D50D22C5-80F8
IDE00001-Production mode,00 00 00
IDE00346-Summertime-automatic,manual
IDE00758-Base volume of telephone,50 %
IDE00759-Base volume of speech output,50 %
IDE00760-Microphone sensitivity,0 dB
IDE00769-Number 1 for Info call,5E 05 A1 20 21 30 82 88 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00770-Number 1 for roadside assistance,5E 05 A1 20 41 50 45 25 FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE00820-ENG117828-Activating and deactivating all development messages-Infotainment_CAN_Messages,OFF
IDE00820-ENG117829-Activating and deactivating all development messages-MIB_CAN_Messages,OFF
IDE01996-ENG99724-Installation list: specified installations- coded,Yes
IDE01996-ENG99724-Installation list: specified installations- coded,No
IDE01996-ENG06573-Installation list: specified installations- coded 2,No
IDE02122-Developer mode,not activated
IDE02330-Number 2 for Info call,5E 06 91 04 12 02 23 88 F8 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02331-Number 2 for roadside assistance,5E 06 91 04 12 04 55 54 F2 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
IDE02476-MAS03001-Electrical test of loudspeakers-Mode,manual
IDE02476-ENG117360-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Frequency,19000 Hz
IDE02476-ENG117361-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_1_Test_Volume,60
IDE02476-ENG117378-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Frequency,19000 Hz
IDE02476-ENG117379-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_10_Test_Volume,60
IDE02476-ENG117380-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Frequency,19000 Hz
IDE02476-ENG117381-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_11_Test_Volume,60
IDE02476-ENG117382-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Frequency,19000 Hz
IDE02476-ENG117383-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_12_Test_Volume,60
IDE02476-ENG117384-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Frequency,19000 Hz
IDE02476-ENG117385-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_13_Test_Volume,60
IDE02476-ENG117386-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Frequency,19000 Hz
IDE02476-ENG117387-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_14_Test_Volume,60
IDE02476-ENG117388-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Frequency,19000 Hz
IDE02476-ENG117389-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_15_Test_Volume,60
IDE02476-ENG117390-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Frequency,19000 Hz
IDE02476-ENG117391-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_16_Test_Volume,60
IDE02476-ENG117362-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Frequency,19000 Hz
IDE02476-ENG117363-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_2_Test_Volume,60
IDE02476-ENG117364-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Frequency,19000 Hz
IDE02476-ENG117365-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_3_Test_Volume,60
IDE02476-ENG117366-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Frequency,19000 Hz
IDE02476-ENG117367-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_4_Test_Volume,60
IDE02476-ENG117368-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Frequency,19000 Hz
IDE02476-ENG117369-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_5_Test_Volume,60
IDE02476-ENG117370-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Frequency,19000 Hz
IDE02476-ENG117371-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_6_Test_Volume,60
IDE02476-ENG117372-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Frequency,19000 Hz
IDE02476-ENG117373-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_7_Test_Volume,60
IDE02476-ENG117374-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Frequency,19000 Hz
IDE02476-ENG117375-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_8_Test_Volume,60
IDE02476-ENG117376-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Frequency,19000 Hz
IDE02476-ENG117377-Electrical test of loudspeakers-Parameter_AC-Diagnostics_Channel_9_Test_Volume,60
IDE02502-Confirmation of installation change,A0 1C
IDE02699-Number 1 for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE02701-Number 1 (roaming) for roadside assistance,00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
IDE03902-Automatic ring break diagnostic,No automatic start
IDE04521-Sporadic ring break detection,Visual
IDE04522-Awakening ability on optical databus,OFF
IDE04550-Bluetooth: Sniff mode,OFF
IDE05113-Infotainment Recorder,activated
IDE10221-MAS00839-Audio Management Input Gain Generation 2-TV Tuner,-128
IDE10221-MAS00846-Audio Management Input Gain Generation 2-Satellite radio,-128
IDE10221-MAS01984-Audio Management Input Gain Generation 2-Radio (FM),-128
IDE10221-MAS01985-Audio Management Input Gain Generation 2-Radio (AM),-128
IDE10221-MAS01986-Audio Management Input Gain Generation 2-Digital radio (DAB),-128
IDE10221-ENG125854-Audio Management Input Gain Generation 2-Exbox_DMB,-128
IDE10221-ENG117430-Audio Management Input Gain Generation 2-HFP,-128
IDE10221-ENG125846-Audio Management Input Gain Generation 2-Media_Airplay,-128
IDE10221-ENG125837-Audio Management Input Gain Generation 2-Media_AUX_Adapter,-128
IDE10221-ENG125836-Audio Management Input Gain Generation 2-Media_AUXIN,-128
IDE10221-ENG125843-Audio Management Input Gain Generation 2-Media_Bluray,-128
IDE10221-ENG125841-Audio Management Input Gain Generation 2-Media_BTDevice,-128
IDE10221-ENG125838-Audio Management Input Gain Generation 2-Media_CDA,-128
IDE10221-ENG125848-Audio Management Input Gain Generation 2-Media_Cloud,-128
IDE10221-ENG125839-Audio Management Input Gain Generation 2-Media_DVD,-128
IDE10221-ENG125844-Audio Management Input Gain Generation 2-Media_HDMI,-128
IDE10221-ENG125840-Audio Management Input Gain Generation 2-Media_MFP,-128
IDE10221-ENG125847-Audio Management Input Gain Generation 2-Media_UPNP,-128
IDE10221-ENG125855-Audio Management Input Gain Generation 2-Mirrorlink,-128
IDE10221-ENG125859-Audio Management Input Gain Generation 2-Phone_Ringer_MFP,-128
IDE10221-ENG125860-Audio Management Input Gain Generation 2-Phone_Ringer_OB,-128
IDE10221-ENG125858-Audio Management Input Gain Generation 2-Phone_Voice,-128
IDE10221-ENG125842-Audio Management Input Gain Generation 2-TA_Tuner_FM,-128
IDE10221-ENG125850-Audio Management Input Gain Generation 2-Tone_Beep,-128
IDE10221-ENG125853-Audio Management Input Gain Generation 2-Tone_Messaging,-128
IDE10221-ENG125852-Audio Management Input Gain Generation 2-Tone_Touchscreen,-128
IDE10221-ENG125851-Audio Management Input Gain Generation 2-Tone_Warning,-128
IDE10221-ENG125856-Audio Management Input Gain Generation 2-TTS_Nav,-128
IDE10221-ENG125857-Audio Management Input Gain Generation 2-TTS_SDS,-128
IDE10221-ENG125845-Audio Management Input Gain Generation 2-Tuner_Online,-128
IDE10221-ENG125849-Audio Management Input Gain Generation 2-Tuner_Personal,-128
IDE10221-ENG125835-Audio Management Input Gain Generation 2-Tuner_TI,-128
IDE10221-ENG125861-Audio Management Input Gain Generation 2-TV_AV_IN,-128
IDE10480-MAS10741-Interface for external media: activation-Connection 1,activated
IDE10480-MAS10742-Interface for external media: activation-Connection 2,not activated
IDE10480-MAS10743-Interface for external media: activation-Connection 3,not activated
IDE10480-MAS10744-Interface for external media: activation-Connection 4,not activated
IDE10604-Menu entries for mobile online services,not activated
IDE11122-Country identification: country of sale HMI,--
IDE11502-ENG127601-Locked menu contents-FB_CAR_0,non_blocked
IDE11502-ENG127602-Locked menu contents-FB_CAR_1,non_blocked
IDE11502-ENG127611-Locked menu contents-FB_CAR_10,non_blocked
IDE11502-ENG127612-Locked menu contents-FB_CAR_11,non_blocked
IDE11502-ENG127613-Locked menu contents-FB_CAR_12,non_blocked
IDE11502-ENG127614-Locked menu contents-FB_CAR_13,non_blocked
IDE11502-ENG127615-Locked menu contents-FB_CAR_14,non_blocked
IDE11502-ENG127616-Locked menu contents-FB_CAR_15,non_blocked
IDE11502-ENG127617-Locked menu contents-FB_CAR_16,non_blocked
IDE11502-ENG127618-Locked menu contents-FB_CAR_17,non_blocked
IDE11502-ENG127619-Locked menu contents-FB_CAR_18,non_blocked
IDE11502-ENG127620-Locked menu contents-FB_CAR_19,non_blocked
IDE11502-ENG127603-Locked menu contents-FB_CAR_2,non_blocked
IDE11502-ENG127621-Locked menu contents-FB_CAR_20,non_blocked
IDE11502-ENG127622-Locked menu contents-FB_CAR_21,non_blocked
IDE11502-ENG127623-Locked menu contents-FB_CAR_22,non_blocked
IDE11502-ENG127624-Locked menu contents-FB_CAR_23,non_blocked
IDE11502-ENG127604-Locked menu contents-FB_CAR_3,non_blocked
IDE11502-ENG127605-Locked menu contents-FB_CAR_4,non_blocked
IDE11502-ENG127606-Locked menu contents-FB_CAR_5,non_blocked
IDE11502-ENG127607-Locked menu contents-FB_CAR_6,non_blocked
IDE11502-ENG127608-Locked menu contents-FB_CAR_7,non_blocked
IDE11502-ENG127609-Locked menu contents-FB_CAR_8,non_blocked
IDE11502-ENG127610-Locked menu contents-FB_CAR_9,non_blocked
IDE11502-ENG127521-Locked menu contents-FB_MEDIA_0,non_blocked
IDE11502-ENG127522-Locked menu contents-FB_MEDIA_1,non_blocked
IDE11502-ENG127531-Locked menu contents-FB_MEDIA_10,non_blocked
IDE11502-ENG127532-Locked menu contents-FB_MEDIA_11,non_blocked
IDE11502-ENG127533-Locked menu contents-FB_MEDIA_12,non_blocked
IDE11502-ENG127534-Locked menu contents-FB_MEDIA_13,non_blocked
IDE11502-ENG127535-Locked menu contents-FB_MEDIA_14,non_blocked
IDE11502-ENG127536-Locked menu contents-FB_MEDIA_15,non_blocked
IDE11502-ENG127537-Locked menu contents-FB_MEDIA_16,non_blocked
IDE11502-ENG127538-Locked menu contents-FB_MEDIA_17,non_blocked
IDE11502-ENG127539-Locked menu contents-FB_MEDIA_18,non_blocked
IDE11502-ENG127540-Locked menu contents-FB_MEDIA_19,non_blocked
IDE11502-ENG127523-Locked menu contents-FB_MEDIA_2,non_blocked
IDE11502-ENG127541-Locked menu contents-FB_MEDIA_20,non_blocked
IDE11502-ENG127542-Locked menu contents-FB_MEDIA_21,non_blocked
IDE11502-ENG127543-Locked menu contents-FB_MEDIA_22,non_blocked
IDE11502-ENG127544-Locked menu contents-FB_MEDIA_23,non_blocked
IDE11502-ENG127524-Locked menu contents-FB_MEDIA_3,non_blocked
IDE11502-ENG127525-Locked menu contents-FB_MEDIA_4,non_blocked
IDE11502-ENG127526-Locked menu contents-FB_MEDIA_5,non_blocked
IDE11502-ENG127527-Locked menu contents-FB_MEDIA_6,non_blocked
IDE11502-ENG127528-Locked menu contents-FB_MEDIA_7,non_blocked
IDE11502-ENG127529-Locked menu contents-FB_MEDIA_8,non_blocked
IDE11502-ENG127530-Locked menu contents-FB_MEDIA_9,non_blocked
IDE11502-ENG127625-Locked menu contents-FB_MISC_0,non_blocked
IDE11502-ENG127626-Locked menu contents-FB_MISC_1,non_blocked
IDE11502-ENG127635-Locked menu contents-FB_MISC_10,non_blocked
IDE11502-ENG127636-Locked menu contents-FB_MISC_11,non_blocked
IDE11502-ENG127637-Locked menu contents-FB_MISC_12,non_blocked
IDE11502-ENG127638-Locked menu contents-FB_MISC_13,non_blocked
IDE11502-ENG127639-Locked menu contents-FB_MISC_14,non_blocked
IDE11502-ENG127640-Locked menu contents-FB_MISC_15,non_blocked
IDE11502-ENG127641-Locked menu contents-FB_MISC_16,non_blocked
IDE11502-ENG127642-Locked menu contents-FB_MISC_17,non_blocked
IDE11502-ENG127643-Locked menu contents-FB_MISC_18,non_blocked
IDE11502-ENG127644-Locked menu contents-FB_MISC_19,non_blocked
IDE11502-ENG127627-Locked menu contents-FB_MISC_2,non_blocked
IDE11502-ENG127645-Locked menu contents-FB_MISC_20,non_blocked
IDE11502-ENG127646-Locked menu contents-FB_MISC_21,non_blocked
IDE11502-ENG127647-Locked menu contents-FB_MISC_22,non_blocked
IDE11502-ENG127648-Locked menu contents-FB_MISC_23,non_blocked
IDE11502-ENG127649-Locked menu contents-FB_MISC_24,non_blocked
IDE11502-ENG127650-Locked menu contents-FB_MISC_25,non_blocked
IDE11502-ENG127651-Locked menu contents-FB_MISC_26,non_blocked
IDE11502-ENG127652-Locked menu contents-FB_MISC_27,non_blocked
IDE11502-ENG127653-Locked menu contents-FB_MISC_28,non_blocked
IDE11502-ENG127654-Locked menu contents-FB_MISC_29,non_blocked
IDE11502-ENG127628-Locked menu contents-FB_MISC_3,non_blocked
IDE11502-ENG127655-Locked menu contents-FB_MISC_30,non_blocked
IDE11502-ENG127656-Locked menu contents-FB_MISC_31,non_blocked
IDE11502-ENG127657-Locked menu contents-FB_MISC_32,non_blocked
IDE11502-ENG127658-Locked menu contents-FB_MISC_33,non_blocked
IDE11502-ENG127659-Locked menu contents-FB_MISC_34,non_blocked
IDE11502-ENG127660-Locked menu contents-FB_MISC_35,non_blocked
IDE11502-ENG127661-Locked menu contents-FB_MISC_36,non_blocked
IDE11502-ENG127662-Locked menu contents-FB_MISC_37,non_blocked
IDE11502-ENG127663-Locked menu contents-FB_MISC_38,non_blocked
IDE11502-ENG127664-Locked menu contents-FB_MISC_39,non_blocked
IDE11502-ENG127629-Locked menu contents-FB_MISC_4,non_blocked
IDE11502-ENG127665-Locked menu contents-FB_MISC_40,non_blocked
IDE11502-ENG127666-Locked menu contents-FB_MISC_41,non_blocked
IDE11502-ENG127667-Locked menu contents-FB_MISC_42,non_blocked
IDE11502-ENG127668-Locked menu contents-FB_MISC_43,non_blocked
IDE11502-ENG127669-Locked menu contents-FB_MISC_44,non_blocked
IDE11502-ENG127670-Locked menu contents-FB_MISC_45,non_blocked
IDE11502-ENG127671-Locked menu contents-FB_MISC_46,non_blocked
IDE11502-ENG127672-Locked menu contents-FB_MISC_47,non_blocked
IDE11502-ENG127630-Locked menu contents-FB_MISC_5,non_blocked
IDE11502-ENG127631-Locked menu contents-FB_MISC_6,non_blocked
IDE11502-ENG127632-Locked menu contents-FB_MISC_7,non_blocked
IDE11502-ENG127633-Locked menu contents-FB_MISC_8,non_blocked
IDE11502-ENG127634-Locked menu contents-FB_MISC_9,non_blocked
IDE11502-ENG127561-Locked menu contents-FB_NAV_0,non_blocked
IDE11502-ENG127562-Locked menu contents-FB_NAV_1,non_blocked
IDE11502-ENG127571-Locked menu contents-FB_NAV_10,non_blocked
IDE11502-ENG127572-Locked menu contents-FB_NAV_11,non_blocked
IDE11502-ENG127573-Locked menu contents-FB_NAV_12,non_blocked
IDE11502-ENG127574-Locked menu contents-FB_NAV_13,non_blocked
IDE11502-ENG127575-Locked menu contents-FB_NAV_14,non_blocked
IDE11502-ENG127576-Locked menu contents-FB_NAV_15,non_blocked
IDE11502-ENG127577-Locked menu contents-FB_NAV_16,non_blocked
IDE11502-ENG127578-Locked menu contents-FB_NAV_17,non_blocked
IDE11502-ENG127579-Locked menu contents-FB_NAV_18,non_blocked
IDE11502-ENG127580-Locked menu contents-FB_NAV_19,non_blocked
IDE11502-ENG127563-Locked menu contents-FB_NAV_2,non_blocked
IDE11502-ENG127581-Locked menu contents-FB_NAV_20,non_blocked
IDE11502-ENG127582-Locked menu contents-FB_NAV_21,non_blocked
IDE11502-ENG127583-Locked menu contents-FB_NAV_22,non_blocked
IDE11502-ENG127584-Locked menu contents-FB_NAV_23,non_blocked
IDE11502-ENG127585-Locked menu contents-FB_NAV_24,non_blocked
IDE11502-ENG127586-Locked menu contents-FB_NAV_25,non_blocked
IDE11502-ENG127587-Locked menu contents-FB_NAV_26,non_blocked
IDE11502-ENG127588-Locked menu contents-FB_NAV_27,non_blocked
IDE11502-ENG127589-Locked menu contents-FB_NAV_28,non_blocked
IDE11502-ENG127590-Locked menu contents-FB_NAV_29,non_blocked
IDE11502-ENG127564-Locked menu contents-FB_NAV_3,non_blocked
IDE11502-ENG127591-Locked menu contents-FB_NAV_30,non_blocked
IDE11502-ENG127592-Locked menu contents-FB_NAV_31,non_blocked
IDE11502-ENG127593-Locked menu contents-FB_NAV_32,non_blocked
IDE11502-ENG127594-Locked menu contents-FB_NAV_33,non_blocked
IDE11502-ENG127595-Locked menu contents-FB_NAV_34,non_blocked
IDE11502-ENG127596-Locked menu contents-FB_NAV_35,non_blocked
IDE11502-ENG127597-Locked menu contents-FB_NAV_36,non_blocked
IDE11502-ENG127598-Locked menu contents-FB_NAV_37,non_blocked
IDE11502-ENG127599-Locked menu contents-FB_NAV_38,non_blocked
IDE11502-ENG127600-Locked menu contents-FB_NAV_39,non_blocked
IDE11502-ENG127565-Locked menu contents-FB_NAV_4,non_blocked
IDE11502-ENG127566-Locked menu contents-FB_NAV_5,non_blocked
IDE11502-ENG127567-Locked menu contents-FB_NAV_6,non_blocked
IDE11502-ENG127568-Locked menu contents-FB_NAV_7,non_blocked
IDE11502-ENG127569-Locked menu contents-FB_NAV_8,non_blocked
IDE11502-ENG127570-Locked menu contents-FB_NAV_9,non_blocked
IDE11502-ENG127545-Locked menu contents-FB_PHONE_0,non_blocked
IDE11502-ENG127546-Locked menu contents-FB_PHONE_1,non_blocked
IDE11502-ENG127555-Locked menu contents-FB_PHONE_10,non_blocked
IDE11502-ENG127556-Locked menu contents-FB_PHONE_11,non_blocked
IDE11502-ENG127557-Locked menu contents-FB_PHONE_12,non_blocked
IDE11502-ENG127558-Locked menu contents-FB_PHONE_13,non_blocked
IDE11502-ENG127559-Locked menu contents-FB_PHONE_14,non_blocked
IDE11502-ENG127560-Locked menu contents-FB_PHONE_15,non_blocked
IDE11502-ENG127547-Locked menu contents-FB_PHONE_2,non_blocked
IDE11502-ENG127548-Locked menu contents-FB_PHONE_3,non_blocked
IDE11502-ENG127549-Locked menu contents-FB_PHONE_4,non_blocked
IDE11502-ENG127550-Locked menu contents-FB_PHONE_5,non_blocked
IDE11502-ENG127551-Locked menu contents-FB_PHONE_6,non_blocked
IDE11502-ENG127552-Locked menu contents-FB_PHONE_7,non_blocked
IDE11502-ENG127553-Locked menu contents-FB_PHONE_8,non_blocked
IDE11502-ENG127554-Locked menu contents-FB_PHONE_9,non_blocked
IDE11502-ENG127505-Locked menu contents-FB_TUNER_0,non_blocked
IDE11502-ENG127506-Locked menu contents-FB_TUNER_1,non_blocked
IDE11502-ENG127515-Locked menu contents-FB_TUNER_10,non_blocked
IDE11502-ENG127516-Locked menu contents-FB_TUNER_11,non_blocked
IDE11502-ENG127517-Locked menu contents-FB_TUNER_12,non_blocked
IDE11502-ENG127518-Locked menu contents-FB_TUNER_13,non_blocked
IDE11502-ENG127519-Locked menu contents-FB_TUNER_14,non_blocked
IDE11502-ENG127520-Locked menu contents-FB_TUNER_15,non_blocked
IDE11502-ENG127507-Locked menu contents-FB_TUNER_2,non_blocked
IDE11502-ENG127508-Locked menu contents-FB_TUNER_3,non_blocked
IDE11502-ENG127509-Locked menu contents-FB_TUNER_4,non_blocked
IDE11502-ENG127510-Locked menu contents-FB_TUNER_5,non_blocked
IDE11502-ENG127511-Locked menu contents-FB_TUNER_6,non_blocked
IDE11502-ENG127512-Locked menu contents-FB_TUNER_7,non_blocked
IDE11502-ENG127513-Locked menu contents-FB_TUNER_8,non_blocked
IDE11502-ENG127514-Locked menu contents-FB_TUNER_9,non_blocked
MAS00951-Bluetooth,On
MAS02809-MAS02870-Check tone frequency-High note frequency range,4000 Hz
MAS02809-MAS02871-Check tone frequency-Medium note frequency range,1000 Hz
MAS02809-MAS02872-Check tone frequency-Low note frequency range,100 Hz
ENG117917-BAP_Debug_Mode_Release,not_released
ENG104140-Bluetooth_Phonebook_Access_Profile,PBAP
ENG122227-ENG125811-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization,not activated
ENG122227-ENG125814-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_after_disclaimer,not activated
ENG122227-ENG126995-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_clamp_15_off,not activated
ENG122227-ENG125812-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_over_threshold_high,activated
ENG122227-ENG125813-Car_Function_Adaptations_Gen2-menu_auxiliary_climatization_standstill,not activated
ENG122227-ENG117486-Car_Function_Adaptations_Gen2-menu_display_ACC,not activated
ENG122227-ENG117490-Car_Function_Adaptations_Gen2-menu_display_ACC_after_disclaimer,not activated
ENG122227-ENG117487-Car_Function_Adaptations_Gen2-menu_display_ACC_operation_clamp_15_off,not activated
ENG122227-ENG117488-Car_Function_Adaptations_Gen2-menu_display_ACC_over_threshold_high,activated
ENG122227-ENG117489-Car_Function_Adaptations_Gen2-menu_display_ACC_standstill,not activated
ENG122227-ENG117646-Car_Function_Adaptations_Gen2-menu_display_adaptive_key,not activated
ENG122227-ENG117650-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_after_disclaimer,not activated
ENG122227-ENG117647-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_clamp_15_off,not activated
ENG122227-ENG117648-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_over_threshold_high,activated
ENG122227-ENG117649-Car_Function_Adaptations_Gen2-menu_display_adaptive_key_standstill,not activated
ENG122227-ENG126152-Car_Function_Adaptations_Gen2-menu_display_Adblue,not activated
ENG122227-ENG126155-Car_Function_Adaptations_Gen2-menu_display_Adblue_after_disclaimer,not activated
ENG122227-ENG127002-Car_Function_Adaptations_Gen2-menu_display_Adblue_clamp_15_off,not activated
ENG122227-ENG126153-Car_Function_Adaptations_Gen2-menu_display_Adblue_over_threshold_high,not activated
ENG122227-ENG126154-Car_Function_Adaptations_Gen2-menu_display_Adblue_standstill,not activated
ENG122227-ENG117591-Car_Function_Adaptations_Gen2-menu_display_air_damper,not activated
ENG122227-ENG117595-Car_Function_Adaptations_Gen2-menu_display_air_damper_after_disclaimer,not activated
ENG122227-ENG117592-Car_Function_Adaptations_Gen2-menu_display_air_damper_clamp_15_off,not activated
ENG122227-ENG117593-Car_Function_Adaptations_Gen2-menu_display_air_damper_over_threshold_high,activated
ENG122227-ENG117594-Car_Function_Adaptations_Gen2-menu_display_air_damper_standstill,not activated
ENG122227-ENG117491-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination,activated
ENG122227-ENG117495-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_after_disclaimer,not activated
ENG122227-ENG117492-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_clamp_15_off,not activated
ENG122227-ENG117493-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_over_threshold_high,activated
ENG122227-ENG117494-Car_Function_Adaptations_Gen2-menu_display_ambient_illumination_standstill,not activated
ENG122227-ENG122296-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope,not activated
ENG122227-ENG122300-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_after_disclaimer,not activated
ENG122227-ENG122297-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_clamp_15_off,not activated
ENG122227-ENG122298-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_over_threshold_high,activated
ENG122227-ENG122299-Car_Function_Adaptations_Gen2-menu_display_angle_of_slope_standstill,not activated
ENG122227-ENG117641-Car_Function_Adaptations_Gen2-menu_display_attention_identification,not activated
ENG122227-ENG117645-Car_Function_Adaptations_Gen2-menu_display_attention_identification_after_disclaimer,not activated
ENG122227-ENG117642-Car_Function_Adaptations_Gen2-menu_display_attention_identification_clamp_15_off,not activated
ENG122227-ENG117643-Car_Function_Adaptations_Gen2-menu_display_attention_identification_over_threshold_high,activated
ENG122227-ENG117644-Car_Function_Adaptations_Gen2-menu_display_attention_identification_standstill,not activated
ENG122227-ENG117531-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating,not activated
ENG122227-ENG117535-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_after_disclaimer,not activated
ENG122227-ENG117532-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_clamp_15_off,not activated
ENG122227-ENG117533-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_over_threshold_high,activated
ENG122227-ENG117534-Car_Function_Adaptations_Gen2-menu_display_auxiliary_heating_standstill,not activated
ENG122227-ENG117501-Car_Function_Adaptations_Gen2-menu_display_awv,not activated
ENG122227-ENG117505-Car_Function_Adaptations_Gen2-menu_display_awv_after_disclaimer,not activated
ENG122227-ENG117502-Car_Function_Adaptations_Gen2-menu_display_awv_clamp_15_off,not activated
ENG122227-ENG117503-Car_Function_Adaptations_Gen2-menu_display_awv_over_threshold_high,activated
ENG122227-ENG117504-Car_Function_Adaptations_Gen2-menu_display_awv_standstill,not activated
ENG122227-ENG122301-Car_Function_Adaptations_Gen2-menu_display_battery_management,not activated
ENG122227-ENG122305-Car_Function_Adaptations_Gen2-menu_display_battery_management_after_disclaimer,not activated
ENG122227-ENG122302-Car_Function_Adaptations_Gen2-menu_display_battery_management_clamp_15_off,not activated
ENG122227-ENG122303-Car_Function_Adaptations_Gen2-menu_display_battery_management_over_threshold_high,activated
ENG122227-ENG122304-Car_Function_Adaptations_Gen2-menu_display_battery_management_standstill,not activated
ENG122227-ENG117666-Car_Function_Adaptations_Gen2-menu_display_BCmE,activated
ENG122227-ENG117670-Car_Function_Adaptations_Gen2-menu_display_BCmE_after_disclaimer,not activated
ENG122227-ENG117667-Car_Function_Adaptations_Gen2-menu_display_BCmE_clamp_15_off,not activated
ENG122227-ENG117668-Car_Function_Adaptations_Gen2-menu_display_BCmE_over_threshold_high,activated
ENG122227-ENG117669-Car_Function_Adaptations_Gen2-menu_display_BCmE_standstill,not activated
ENG122227-ENG117536-Car_Function_Adaptations_Gen2-menu_display_board_computer,activated
ENG122227-ENG117540-Car_Function_Adaptations_Gen2-menu_display_board_computer_after_disclaimer,not activated
ENG122227-ENG117537-Car_Function_Adaptations_Gen2-menu_display_board_computer_clamp_15_off,not activated
ENG122227-ENG117538-Car_Function_Adaptations_Gen2-menu_display_board_computer_over_threshold_high,activated
ENG122227-ENG117539-Car_Function_Adaptations_Gen2-menu_display_board_computer_standstill,not activated
ENG122227-ENG117671-Car_Function_Adaptations_Gen2-menu_display_Brake_Function,activated
ENG122227-ENG117675-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_after_disclaimer,not activated
ENG122227-ENG117672-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_clamp_15_off,not activated
ENG122227-ENG117673-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_over_threshold_high,activated
ENG122227-ENG117674-Car_Function_Adaptations_Gen2-menu_display_Brake_Function_standstill,not activated
ENG122227-ENG117651-Car_Function_Adaptations_Gen2-menu_display_car_mirror,activated
ENG122227-ENG117655-Car_Function_Adaptations_Gen2-menu_display_car_mirror_after_disclaimer,not activated
ENG122227-ENG117652-Car_Function_Adaptations_Gen2-menu_display_car_mirror_clamp_15_off,not activated
ENG122227-ENG117653-Car_Function_Adaptations_Gen2-menu_display_car_mirror_over_threshold_high,activated
ENG122227-ENG117654-Car_Function_Adaptations_Gen2-menu_display_car_mirror_standstill,not activated
ENG122227-ENG117561-Car_Function_Adaptations_Gen2-menu_display_central_locking,activated
ENG122227-ENG117565-Car_Function_Adaptations_Gen2-menu_display_central_locking_after_disclaimer,not activated
ENG122227-ENG117562-Car_Function_Adaptations_Gen2-menu_display_central_locking_clamp_15_off,not activated
ENG122227-ENG117563-Car_Function_Adaptations_Gen2-menu_display_central_locking_over_threshold_high,activated
ENG122227-ENG117564-Car_Function_Adaptations_Gen2-menu_display_central_locking_standstill,not activated
ENG122227-ENG117601-Car_Function_Adaptations_Gen2-menu_display_central_unit_master,activated
ENG122227-ENG117605-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_after_disclaimer,not activated
ENG122227-ENG117602-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_clamp_15_off,not activated
ENG122227-ENG117603-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_over_threshold_high,activated
ENG122227-ENG117604-Car_Function_Adaptations_Gen2-menu_display_central_unit_master_standstill,not activated
ENG122227-ENG117571-Car_Function_Adaptations_Gen2-menu_display_charisma,activated
ENG122227-ENG117575-Car_Function_Adaptations_Gen2-menu_display_charisma_after_disclaimer,not activated
ENG122227-ENG117572-Car_Function_Adaptations_Gen2-menu_display_charisma_clamp_15_off,not activated
ENG122227-ENG117573-Car_Function_Adaptations_Gen2-menu_display_charisma_over_threshold_high,activated
ENG122227-ENG117574-Car_Function_Adaptations_Gen2-menu_display_charisma_standstill,not activated
ENG122227-ENG117526-Car_Function_Adaptations_Gen2-menu_display_clima_configuration,activated
ENG122227-ENG117530-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_after_disclaimer,not activated
ENG122227-ENG117527-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_clamp_15_off,not activated
ENG122227-ENG117528-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_over_threshold_high,activated
ENG122227-ENG117529-Car_Function_Adaptations_Gen2-menu_display_clima_configuration_standstill,not activated
ENG122227-ENG117586-Car_Function_Adaptations_Gen2-menu_display_clock,activated
ENG122227-ENG117590-Car_Function_Adaptations_Gen2-menu_display_clock_after_disclaimer,not activated
ENG122227-ENG117587-Car_Function_Adaptations_Gen2-menu_display_clock_clamp_15_off,not activated
ENG122227-ENG117588-Car_Function_Adaptations_Gen2-menu_display_clock_over_threshold_high,activated
ENG122227-ENG117589-Car_Function_Adaptations_Gen2-menu_display_clock_standstill,not activated
ENG122227-ENG117566-Car_Function_Adaptations_Gen2-menu_display_compass,not activated
ENG122227-ENG117570-Car_Function_Adaptations_Gen2-menu_display_compass_after_disclaimer,not activated
ENG122227-ENG117567-Car_Function_Adaptations_Gen2-menu_display_compass_clamp_15_off,not activated
ENG122227-ENG117568-Car_Function_Adaptations_Gen2-menu_display_compass_over_threshold_high,activated
ENG122227-ENG117569-Car_Function_Adaptations_Gen2-menu_display_compass_standstill,not activated
ENG122227-ENG125823-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist,not activated
ENG122227-ENG125826-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_after_disclaimer,not activated
ENG122227-ENG126998-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_clamp_15_off,not activated
ENG122227-ENG125824-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_over_threshold_high,activated
ENG122227-ENG125825-Car_Function_Adaptations_Gen2-menu_display_Curve_Assist_standstill,not activated
ENG122227-ENG11015-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration,not activated
ENG122227-ENG11019-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_after_disclaimer,not activated
ENG122227-ENG11016-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_clamp_15_off,not activated
ENG122227-ENG11017-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_over_threshold_high,not activated
ENG122227-ENG11018-Car_Function_Adaptations_Gen2-menu_display_Display_Configuration_standstill,not activated
ENG122227-ENG117656-Car_Function_Adaptations_Gen2-menu_display_driving_school,not activated
ENG122227-ENG117660-Car_Function_Adaptations_Gen2-menu_display_driving_school_after_disclaimer,not activated
ENG122227-ENG117657-Car_Function_Adaptations_Gen2-menu_display_driving_school_clamp_15_off,not activated
ENG122227-ENG117658-Car_Function_Adaptations_Gen2-menu_display_driving_school_over_threshold_high,activated
ENG122227-ENG117659-Car_Function_Adaptations_Gen2-menu_display_driving_school_standstill,not activated
ENG122227-ENG125034-Car_Function_Adaptations_Gen2-menu_display_Ecall,not activated
ENG122227-ENG125038-Car_Function_Adaptations_Gen2-menu_display_Ecall_after_disclaimer,not activated
ENG122227-ENG126999-Car_Function_Adaptations_Gen2-menu_display_eCall_clamp_15_off,not activated
ENG122227-ENG125036-Car_Function_Adaptations_Gen2-menu_display_Ecall_over_threshold_high,not activated
ENG122227-ENG125037-Car_Function_Adaptations_Gen2-menu_display_Ecall_standstill,not activated
ENG122227-ENG126160-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist,not activated
ENG122227-ENG126163-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_after_disclaimer,not activated
ENG122227-ENG127004-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_clamp_15_off,not activated
ENG122227-ENG126161-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_over_threshold_high,not activated
ENG122227-ENG126162-Car_Function_Adaptations_Gen2-menu_display_Efficiency_Assist_standstill,not activated
ENG122227-ENG126144-Car_Function_Adaptations_Gen2-menu_display_ENI,not activated
ENG122227-ENG126147-Car_Function_Adaptations_Gen2-menu_display_ENI_after_disclaimer,not activated
ENG122227-ENG127000-Car_Function_Adaptations_Gen2-menu_display_ENI_clamp_15_off,not activated
ENG122227-ENG126145-Car_Function_Adaptations_Gen2-menu_display_ENI_over_threshold_high,not activated
ENG122227-ENG126146-Car_Function_Adaptations_Gen2-menu_display_ENI_standstill,not activated
ENG122227-ENG117516-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination,activated
ENG122227-ENG117520-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_after_disclaimer,not activated
ENG122227-ENG117517-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_clamp_15_off,not activated
ENG122227-ENG117518-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_over_threshold_high,activated
ENG122227-ENG117519-Car_Function_Adaptations_Gen2-menu_display_exterior_illumination_standstill,not activated
ENG122227-ENG117596-Car_Function_Adaptations_Gen2-menu_display_headup_display,not activated
ENG122227-ENG117600-Car_Function_Adaptations_Gen2-menu_display_headup_display_after_disclaimer,not activated
ENG122227-ENG117597-Car_Function_Adaptations_Gen2-menu_display_headup_display_clamp_15_off,not activated
ENG122227-ENG117598-Car_Function_Adaptations_Gen2-menu_display_headup_display_over_threshold_high,activated
ENG122227-ENG117599-Car_Function_Adaptations_Gen2-menu_display_headup_display_standstill,not activated
ENG122227-ENG117606-Car_Function_Adaptations_Gen2-menu_display_hybrid,not activated
ENG122227-ENG117610-Car_Function_Adaptations_Gen2-menu_display_hybrid_after_disclaimer,not activated
ENG122227-ENG117607-Car_Function_Adaptations_Gen2-menu_display_hybrid_clamp_15_off,not activated
ENG122227-ENG117608-Car_Function_Adaptations_Gen2-menu_display_hybrid_over_threshold_high,activated
ENG122227-ENG117609-Car_Function_Adaptations_Gen2-menu_display_hybrid_standstill,not activated
ENG122227-ENG125805-Car_Function_Adaptations_Gen2-menu_display_lane_assistant,not activated
ENG122227-ENG125809-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_after_disclaimer,not activated
ENG122227-ENG125806-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_clamp_15_off,not activated
ENG122227-ENG125807-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_over_threshold_high,activated
ENG122227-ENG125808-Car_Function_Adaptations_Gen2-menu_display_lane_assistant_standstill,not activated
ENG122227-ENG117506-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning,not activated
ENG122227-ENG117510-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_after_disclaimer,not activated
ENG122227-ENG117507-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_clamp_15_off,not activated
ENG122227-ENG117508-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_over_threshold_high,activated
ENG122227-ENG117509-Car_Function_Adaptations_Gen2-menu_display_Lane_Departure_Warning_standstill,not activated
ENG122227-ENG117631-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker,not activated
ENG122227-ENG117635-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_after_disclaimer,not activated
ENG122227-ENG117632-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_clamp_15_off,not activated
ENG122227-ENG117633-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_over_threshold_high,activated
ENG122227-ENG117634-Car_Function_Adaptations_Gen2-menu_display_MFL_jocker_standstill,not activated
ENG122227-ENG117616-Car_Function_Adaptations_Gen2-menu_display_night_vision,not activated
ENG122227-ENG117620-Car_Function_Adaptations_Gen2-menu_display_night_vision_after_disclaimer,not activated
ENG122227-ENG117617-Car_Function_Adaptations_Gen2-menu_display_night_vision_clamp_15_off,not activated
ENG122227-ENG117618-Car_Function_Adaptations_Gen2-menu_display_night_vision_over_threshold_high,activated
ENG122227-ENG117619-Car_Function_Adaptations_Gen2-menu_display_night_vision_standstill,not activated
ENG122227-ENG117576-Car_Function_Adaptations_Gen2-menu_display_oil_level,not activated
ENG122227-ENG117580-Car_Function_Adaptations_Gen2-menu_display_oil_level_after_disclaimer,not activated
ENG122227-ENG117577-Car_Function_Adaptations_Gen2-menu_display_oil_level_clamp_15_off,not activated
ENG122227-ENG117578-Car_Function_Adaptations_Gen2-menu_display_oil_level_over_threshold_high,activated
ENG122227-ENG117579-Car_Function_Adaptations_Gen2-menu_display_oil_level_standstill,not activated
ENG122227-ENG117496-Car_Function_Adaptations_Gen2-menu_display_pdc,activated
ENG122227-ENG117500-Car_Function_Adaptations_Gen2-menu_display_pdc_after_disclaimer,not activated
ENG122227-ENG117497-Car_Function_Adaptations_Gen2-menu_display_pdc_clamp_15_off,not activated
ENG122227-ENG117498-Car_Function_Adaptations_Gen2-menu_display_pdc_over_threshold_high,activated
ENG122227-ENG117499-Car_Function_Adaptations_Gen2-menu_display_pdc_standstill,not activated
ENG122227-ENG125815-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist,not activated
ENG122227-ENG125818-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_after_disclaimer,not activated
ENG122227-ENG126996-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_clamp_15_off,not activated
ENG122227-ENG125816-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_over_threshold_high,activated
ENG122227-ENG125817-Car_Function_Adaptations_Gen2-menu_display_Pedestrian_Assist_standstill,not activated
ENG122227-ENG117541-Car_Function_Adaptations_Gen2-menu_display_rdk,activated
ENG122227-ENG117545-Car_Function_Adaptations_Gen2-menu_display_rdk_after_disclaimer,not activated
ENG122227-ENG117542-Car_Function_Adaptations_Gen2-menu_display_rdk_clamp_15_off,not activated
ENG122227-ENG117543-Car_Function_Adaptations_Gen2-menu_display_rdk_over_threshold_high,activated
ENG122227-ENG117544-Car_Function_Adaptations_Gen2-menu_display_rdk_standstill,not activated
ENG122227-ENG122306-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment,not activated
ENG122227-ENG122310-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_after_disclaimer,not activated
ENG122227-ENG122307-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_clamp_15_off,not activated
ENG122227-ENG122308-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_over_threshold_high,activated
ENG122227-ENG122309-Car_Function_Adaptations_Gen2-menu_display_RearSeatEntertainment_standstill,not activated
ENG122227-ENG117626-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load,not activated
ENG122227-ENG117630-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_after_disclaimer,not activated
ENG122227-ENG117627-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_clamp_15_off,not activated
ENG122227-ENG117628-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_over_threshold_high,activated
ENG122227-ENG117629-Car_Function_Adaptations_Gen2-menu_display_reversible_belt_pre_load_standstill,not activated
ENG122227-ENG117636-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification,not activated
ENG122227-ENG117640-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_after_disclaimer,not activated
ENG122227-ENG117637-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_clamp_15_off,not activated
ENG122227-ENG117638-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_over_threshold_high,activated
ENG122227-ENG117639-Car_Function_Adaptations_Gen2-menu_display_road_sign_identification_standstill,not activated
ENG122227-ENG117556-Car_Function_Adaptations_Gen2-menu_display_seat_configuration,not activated
ENG122227-ENG117560-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_after_disclaimer,not activated
ENG122227-ENG117557-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_clamp_15_off,not activated
ENG122227-ENG117558-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_over_threshold_high,activated
ENG122227-ENG117559-Car_Function_Adaptations_Gen2-menu_display_seat_configuration_standstill,not activated
ENG122227-ENG125819-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic,not activated
ENG122227-ENG125822-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_after_disclaimer,not activated
ENG122227-ENG126997-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_clamp_15_off,not activated
ENG122227-ENG125820-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_over_threshold_high,activated
ENG122227-ENG125821-Car_Function_Adaptations_Gen2-menu_display_Seat_Pneumatic_standstill,not activated
ENG122227-ENG117551-Car_Function_Adaptations_Gen2-menu_display_sia,activated
ENG122227-ENG117555-Car_Function_Adaptations_Gen2-menu_display_sia_after_disclaimer,not activated
ENG122227-ENG117552-Car_Function_Adaptations_Gen2-menu_display_sia_clamp_15_off,not activated
ENG122227-ENG117553-Car_Function_Adaptations_Gen2-menu_display_sia_over_threshold_high,activated
ENG122227-ENG117554-Car_Function_Adaptations_Gen2-menu_display_sia_standstill,not activated
ENG122227-ENG117621-Car_Function_Adaptations_Gen2-menu_display_side_view,not activated
ENG122227-ENG117625-Car_Function_Adaptations_Gen2-menu_display_side_view_after_disclaimer,not activated
ENG122227-ENG117622-Car_Function_Adaptations_Gen2-menu_display_side_view_clamp_15_off,not activated
ENG122227-ENG117623-Car_Function_Adaptations_Gen2-menu_display_side_view_over_threshold_high,activated
ENG122227-ENG117624-Car_Function_Adaptations_Gen2-menu_display_side_view_standstill,not activated
ENG122227-ENG122311-Car_Function_Adaptations_Gen2-menu_display_special_functions,not activated
ENG122227-ENG122314-Car_Function_Adaptations_Gen2-menu_display_special_functions_after_disclaimer,not activated
ENG122227-ENG125810-Car_Function_Adaptations_Gen2-menu_display_special_functions_clamp_15_off,not activated
ENG122227-ENG122312-Car_Function_Adaptations_Gen2-menu_display_special_functions_over_threshold_high,activated
ENG122227-ENG122313-Car_Function_Adaptations_Gen2-menu_display_special_functions_standstill,not activated
ENG122227-ENG11010-Car_Function_Adaptations_Gen2-menu_display_Spoiler,not activated
ENG122227-ENG11014-Car_Function_Adaptations_Gen2-menu_display_Spoiler_after_disclaimer,not activated
ENG122227-ENG11011-Car_Function_Adaptations_Gen2-menu_display_Spoiler_clamp_15_off,not activated
ENG122227-ENG11012-Car_Function_Adaptations_Gen2-menu_display_Spoiler_over_threshold_high,not activated
ENG122227-ENG11013-Car_Function_Adaptations_Gen2-menu_display_Spoiler_standstill,not activated
ENG122227-ENG126148-Car_Function_Adaptations_Gen2-menu_display_SportHMI,not activated
ENG122227-ENG126151-Car_Function_Adaptations_Gen2-menu_display_SportHMI_after_disclaimer,not activated
ENG122227-ENG127001-Car_Function_Adaptations_Gen2-menu_display_SportHMI_clamp_15_off,not activated
ENG122227-ENG126149-Car_Function_Adaptations_Gen2-menu_display_SportHMI_over_threshold_high,not activated
ENG122227-ENG126150-Car_Function_Adaptations_Gen2-menu_display_SportHMI_standstill,not activated
ENG122227-ENG117676-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons,activated
ENG122227-ENG117680-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_after_disclaimer,not activated
ENG122227-ENG117677-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_clamp_15_off,not activated
ENG122227-ENG117678-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_over_threshold_high,activated
ENG122227-ENG117679-Car_Function_Adaptations_Gen2-menu_display_Start_Stop_reasons_standstill,not activated
ENG122227-ENG122315-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant,not activated
ENG122227-ENG122319-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_after_disclaimer,not activated
ENG122227-ENG122316-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_clamp_15_off,not activated
ENG122227-ENG122317-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_over_threshold_high,activated
ENG122227-ENG122318-Car_Function_Adaptations_Gen2-menu_display_trailer_assistant_standstill,not activated
ENG122227-ENG122320-Car_Function_Adaptations_Gen2-menu_display_TV_tuner,not activated
ENG122227-ENG122324-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_after_disclaimer,not activated
ENG122227-ENG122321-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_clamp_15_off,not activated
ENG122227-ENG122322-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_over_threshold_high,activated
ENG122227-ENG122323-Car_Function_Adaptations_Gen2-menu_display_TV_tuner_standstill,not activated
ENG122227-ENG117611-Car_Function_Adaptations_Gen2-menu_display_ugdo,not activated
ENG122227-ENG117615-Car_Function_Adaptations_Gen2-menu_display_ugdo_after_disclaimer,not activated
ENG122227-ENG117612-Car_Function_Adaptations_Gen2-menu_display_ugdo_clamp_15_off,not activated
ENG122227-ENG117613-Car_Function_Adaptations_Gen2-menu_display_ugdo_over_threshold_high,activated
ENG122227-ENG117614-Car_Function_Adaptations_Gen2-menu_display_ugdo_standstill,not activated
ENG122227-ENG122291-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating,activated
ENG122227-ENG122295-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_after_disclaimer,not activated
ENG122227-ENG122292-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_clamp_15_off,not activated
ENG122227-ENG122293-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_over_threshold_high,activated
ENG122227-ENG122294-Car_Function_Adaptations_Gen2-menu_display_user_eco_rating_standstill,not activated
ENG122227-ENG117581-Car_Function_Adaptations_Gen2-menu_display_vin,activated
ENG122227-ENG117585-Car_Function_Adaptations_Gen2-menu_display_vin_after_disclaimer,not activated
ENG122227-ENG117582-Car_Function_Adaptations_Gen2-menu_display_vin_clamp_15_off,not activated
ENG122227-ENG117583-Car_Function_Adaptations_Gen2-menu_display_vin_over_threshold_high,activated
ENG122227-ENG117584-Car_Function_Adaptations_Gen2-menu_display_vin_standstill,not activated
ENG122227-ENG117661-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition,not activated
ENG122227-ENG117665-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_after_disclaimer,not activated
ENG122227-ENG117662-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_clamp_15_off,not activated
ENG122227-ENG117663-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_over_threshold_high,activated
ENG122227-ENG117664-Car_Function_Adaptations_Gen2-menu_display_weariness_recognition_standstill,not activated
ENG122227-ENG117521-Car_Function_Adaptations_Gen2-menu_display_windows,activated
ENG122227-ENG117525-Car_Function_Adaptations_Gen2-menu_display_windows_after_disclaimer,not activated
ENG122227-ENG117522-Car_Function_Adaptations_Gen2-menu_display_windows_clamp_15_off,not activated
ENG122227-ENG117523-Car_Function_Adaptations_Gen2-menu_display_windows_over_threshold_high,activated
ENG122227-ENG117524-Car_Function_Adaptations_Gen2-menu_display_windows_standstill,not activated
ENG122227-ENG117546-Car_Function_Adaptations_Gen2-menu_display_wiper,activated
ENG122227-ENG117550-Car_Function_Adaptations_Gen2-menu_display_wiper_after_disclaimer,not activated
ENG122227-ENG117547-Car_Function_Adaptations_Gen2-menu_display_wiper_clamp_15_off,not activated
ENG122227-ENG117548-Car_Function_Adaptations_Gen2-menu_display_wiper_over_threshold_high,activated
ENG122227-ENG117549-Car_Function_Adaptations_Gen2-menu_display_wiper_standstill,not activated
ENG122227-ENG11020-Car_Function_Adaptations_Gen2-menu_soundcontrol,not activated
ENG122227-ENG11024-Car_Function_Adaptations_Gen2-menu_soundcontrol_after_disclaimer,not activated
ENG122227-ENG11021-Car_Function_Adaptations_Gen2-menu_soundcontrol_clamp_15_off,not activated
ENG122227-ENG11022-Car_Function_Adaptations_Gen2-menu_soundcontrol_over_threshold_high,not activated
ENG122227-ENG11023-Car_Function_Adaptations_Gen2-menu_soundcontrol_standstill,not activated
ENG122229-ENG117700-Car_Function_List_BAP_Gen2-ACC_0x05,not activated
ENG122229-ENG117701-Car_Function_List_BAP_Gen2-ACC_0x05_msg_bus,Databus extended
ENG122229-ENG117702-Car_Function_List_BAP_Gen2-air_suspension_0x06,not activated
ENG122229-ENG117703-Car_Function_List_BAP_Gen2-air_suspension_0x06_msg_bus,Suspension data bus
ENG122229-ENG117764-Car_Function_List_BAP_Gen2-Amplifier_0x2D,not activated
ENG122229-ENG117765-Car_Function_List_BAP_Gen2-Amplifier_0x2D_msg_bus,CAB_9
ENG122229-ENG122334-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24,not activated
ENG122229-ENG122335-Car_Function_List_BAP_Gen2-Angle_Of_Slope_0x24_msg_bus,Comfort data bus
ENG122229-ENG117696-Car_Function_List_BAP_Gen2-auxilary_heating_0x03,not activated
ENG122229-ENG117697-Car_Function_List_BAP_Gen2-auxilary_heating_0x03_msg_bus,Comfort data bus
ENG122229-ENG117744-Car_Function_List_BAP_Gen2-AWV_0x1B,not activated
ENG122229-ENG117745-Car_Function_List_BAP_Gen2-AWV_0x1B_msg_bus,Terminal 15
ENG122229-ENG122336-Car_Function_List_BAP_Gen2-Battery_Management_0x25,not activated
ENG122229-ENG122337-Car_Function_List_BAP_Gen2-Battery_Management_0x25_msg_bus,Comfort data bus
ENG122229-ENG117758-Car_Function_List_BAP_Gen2-BCmE_0x23,activated
ENG122229-ENG117759-Car_Function_List_BAP_Gen2-BCmE_0x23_msg_bus,Databus Infotainment
ENG122229-ENG117760-Car_Function_List_BAP_Gen2-Brake_0x26,activated
ENG122229-ENG117761-Car_Function_List_BAP_Gen2-Brake_0x26_msg_bus,Suspension data bus
ENG122229-ENG117717-Car_Function_List_BAP_Gen2-central_locking_0x0D,activated
ENG122229-ENG117716-Car_Function_List_BAP_Gen2-central_locking_0x0D_msg_bus,Comfort data bus
ENG122229-ENG117736-Car_Function_List_BAP_Gen2-charisma_0x17,activated
ENG122229-ENG117737-Car_Function_List_BAP_Gen2-charisma_0x17_msg_bus,Databus Infotainment
ENG122229-ENG117734-Car_Function_List_BAP_Gen2-clima_slave_2_0x16,not activated
ENG122229-ENG117735-Car_Function_List_BAP_Gen2-clima_slave_2_0x16_msg_bus,Comfort data bus
ENG122229-ENG117692-Car_Function_List_BAP_Gen2-climatic_master_0x01,activated
ENG122229-ENG117693-Car_Function_List_BAP_Gen2-climatic_master_0x01_msg_bus,Comfort data bus
ENG122229-ENG117694-Car_Function_List_BAP_Gen2-climatic_slave_0x02,not activated
ENG122229-ENG117695-Car_Function_List_BAP_Gen2-climatic_slave_0x02_msg_bus,Comfort data bus
ENG122229-ENG117724-Car_Function_List_BAP_Gen2-clock_0x11,activated
ENG122229-ENG117725-Car_Function_List_BAP_Gen2-clock_0x11_msg_bus,Comfort data bus
ENG122229-ENG117732-Car_Function_List_BAP_Gen2-compass_0x15,not activated
ENG122229-ENG117733-Car_Function_List_BAP_Gen2-compass_0x15_msg_bus,Databus Infotainment
ENG122229-ENG117722-Car_Function_List_BAP_Gen2-driver_seat_0x10,not activated
ENG122229-ENG117723-Car_Function_List_BAP_Gen2-driver_seat_0x10_msg_bus,Comfort data bus
ENG122229-ENG125039-Car_Function_List_BAP_Gen2-Ecall_0x33,not activated
ENG122229-ENG125828-Car_Function_List_BAP_Gen2-eCall_0x33_msg_bus,Comfort data bus
ENG122229-ENG127500-Car_Function_List_BAP_Gen2-efficiency_assis_msg_bus_0x3C,Databus extended
ENG122229-ENG127499-Car_Function_List_BAP_Gen2-efficiency_assist_0x3C,not activated
ENG122229-ENG125829-Car_Function_List_BAP_Gen2-ENI_0x37,not activated
ENG122229-ENG125830-Car_Function_List_BAP_Gen2-ENI_0x37_msg_bus,Comfort data bus
ENG122229-ENG117708-Car_Function_List_BAP_Gen2-exterieur_light_0x09,activated
ENG122229-ENG117709-Car_Function_List_BAP_Gen2-exterieur_light_0x09_msg_bus,Comfort data bus
ENG122229-ENG117698-Car_Function_List_BAP_Gen2-headup_displ_0x04,not activated
ENG122229-ENG117699-Car_Function_List_BAP_Gen2-headup_displ_0x04_msg_bus,Comfort data bus
ENG122229-ENG117746-Car_Function_List_BAP_Gen2-Hybrid_0x1D,not activated
ENG122229-ENG117747-Car_Function_List_BAP_Gen2-Hybrid_0x1D_msg_bus,Databus drivetrain
ENG122229-ENG117706-Car_Function_List_BAP_Gen2-interieur_light_0x08,activated
ENG122229-ENG117707-Car_Function_List_BAP_Gen2-interieur_light_0x08_msg_bus,Comfort data bus
ENG122229-ENG117740-Car_Function_List_BAP_Gen2-LDW_HCA_0x19,not activated
ENG122229-ENG117741-Car_Function_List_BAP_Gen2-LDW_HCA_0x19_msg_bus,Databus extended
ENG122229-ENG117720-Car_Function_List_BAP_Gen2-MFA_0x0F,activated
ENG122229-ENG117721-Car_Function_List_BAP_Gen2-MFA_0x0F_msg_bus,Comfort data bus
ENG122229-ENG117767-Car_Function_List_BAP_Gen2-MFL_Jocker_0x34,not activated
ENG122229-ENG117766-Car_Function_List_BAP_Gen2-MFL_Jocker_msg_bus_0x34,CAB_9
ENG122229-ENG117719-Car_Function_List_BAP_Gen2-mirror_0x0E,activated
ENG122229-ENG117718-Car_Function_List_BAP_Gen2-mirror_0x0E_msg_bus,Comfort data bus
ENG122229-ENG117738-Car_Function_List_BAP_Gen2-Night_Vision_0x18,not activated
ENG122229-ENG117739-Car_Function_List_BAP_Gen2-Night_Vision_0x18_msg_bus,CAB_9
ENG122229-ENG117710-Car_Function_List_BAP_Gen2-parking_assist_0x0A,activated
ENG122229-ENG117711-Car_Function_List_BAP_Gen2-parking_assist_0x0A_msg_bus,Terminal 15
ENG122229-ENG117752-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20,not activated
ENG122229-ENG117753-Car_Function_List_BAP_Gen2-Passenger_Seat_0x20_msg_bus,Comfort data bus
ENG122229-ENG125831-Car_Function_List_BAP_Gen2-Pedestrian_Assist_0x3A,not activated
ENG122229-ENG125832-Car_Function_List_BAP_Gen2-Pedestrian_Assist_msg_bus_0x3A,Databus extended
ENG122229-ENG122333-Car_Function_List_BAP_Gen2-Range_Data_0x39,not activated
ENG122229-ENG125827-Car_Function_List_BAP_Gen2-Range_Data_msg_bus_0x39,Databus Infotainment
ENG122229-ENG122327-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E,not activated
ENG122229-ENG122328-Car_Function_List_BAP_Gen2-RearSeatEntertainment_0x2E_msg_bus,Comfort data bus
ENG122229-ENG117750-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F,not activated
ENG122229-ENG117751-Car_Function_List_BAP_Gen2-Reversible_Seat_Belt_Tightener_0x1F_msg_bus,Databus drivetrain
ENG122229-ENG125833-Car_Function_List_BAP_Gen2-Seat_Pneumatic_0x3B,not activated
ENG122229-ENG125834-Car_Function_List_BAP_Gen2-Seat_Pneumatic_msg_bus_0x3B,Comfort data bus
ENG122229-ENG08128-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_0x3F,not activated
ENG122229-ENG08129-Car_Function_List_BAP_Gen2-Seatmemory_codriver_rear_msg_bus_0x3F,Comfort data bus
ENG122229-ENG08126-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_0x3E,not activated
ENG122229-ENG08127-Car_Function_List_BAP_Gen2-Seatmemory_driver_rear_msg_bus_0x3E,Comfort data bus
ENG122229-ENG117726-Car_Function_List_BAP_Gen2-service_interval_display_0x12,activated
ENG122229-ENG117727-Car_Function_List_BAP_Gen2-service_interval_display_0x12_msg_bus,Comfort data bus
ENG122229-ENG117748-Car_Function_List_BAP_Gen2-SideView_0x1E,not activated
ENG122229-ENG117749-Car_Function_List_BAP_Gen2-SideView_0x1E_msg_bus,CAB_9
ENG122229-ENG122329-Car_Function_List_BAP_Gen2-Special_Functions_0x35,not activated
ENG122229-ENG122330-Car_Function_List_BAP_Gen2-Special_Functions_msg_bus_0x35,Databus Infotainment
ENG122229-ENG117762-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27,activated
ENG122229-ENG117763-Car_Function_List_BAP_Gen2-Start_Stop_reasons_0x27_msg_bus,Databus Infotainment
ENG122229-ENG117742-Car_Function_List_BAP_Gen2-SWA_0x1A,not activated
ENG122229-ENG117743-Car_Function_List_BAP_Gen2-SWA_0x1A_msg_bus,Databus extended
ENG122229-ENG117704-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07,activated
ENG122229-ENG117705-Car_Function_List_BAP_Gen2-tire_pressure_system_0x07_msg_bus,Suspension data bus
ENG122229-ENG117754-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21,not activated
ENG122229-ENG117755-Car_Function_List_BAP_Gen2-traffic_sign_recognition_0x21_msg_bus,Databus extended
ENG122229-ENG122331-Car_Function_List_BAP_Gen2-Trailer_Assistant_0x36,not activated
ENG122229-ENG122332-Car_Function_List_BAP_Gen2-Trailer_Assistant_msg_bus_0x36,Terminal 15
ENG122229-ENG122325-Car_Function_List_BAP_Gen2-TV_tuner_0x2C,not activated
ENG122229-ENG122326-Car_Function_List_BAP_Gen2-TV_tuner_0x2C_msg_bus,Comfort data bus
ENG122229-ENG117730-Car_Function_List_BAP_Gen2-UGDO_0x14,not activated
ENG122229-ENG117731-Car_Function_List_BAP_Gen2-UGDO_0x14_msg_bus,Terminal 15
ENG122229-ENG117728-Car_Function_List_BAP_Gen2-unit_master_0x13,activated
ENG122229-ENG117729-Car_Function_List_BAP_Gen2-unit_master_0x13_msg_bus,Comfort data bus
ENG122229-ENG117712-Car_Function_List_BAP_Gen2-VPS_0x0B,not activated
ENG122229-ENG117713-Car_Function_List_BAP_Gen2-VPS_0x0B_msg_bus,Databus Infotainment
ENG122229-ENG117756-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22,not activated
ENG122229-ENG117757-Car_Function_List_BAP_Gen2-weariness_rcognition_0x22_msg_bus,Databus Infotainment
ENG122229-ENG117714-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C,activated
ENG122229-ENG117715-Car_Function_List_BAP_Gen2-wiper_comfort_0x0C_msg_bus,Comfort data bus
ENG122228-ENG127498-Car_Function_List_CAN_Gen2-Adaptive_key,Not available
ENG122228-ENG117690-Car_Function_List_CAN_Gen2-Adaptive_key_msg_bus,Comfort data bus
ENG122228-ENG117688-Car_Function_List_CAN_Gen2-Driving_school,Not available
ENG122228-ENG117689-Car_Function_List_CAN_Gen2-Driving_school_msg_bus,Not available
ENG122228-ENG107608-Car_Function_List_CAN_Gen2-MFL,Available
ENG122228-ENG117681-Car_Function_List_CAN_Gen2-MFL_msg_bus,Databus Infotainment
ENG122228-ENG117683-Car_Function_List_CAN_Gen2-Oil_level,Not available
ENG122228-ENG117684-Car_Function_List_CAN_Gen2-Oil_level_msg_bus,Databus drivetrain
ENG122228-ENG117685-Car_Function_List_CAN_Gen2-PDC_audio_lowering,Available
ENG122228-ENG117686-Car_Function_List_CAN_Gen2-PDC_audio_lowering_msg_bus,Terminal 15
ENG122228-ENG99892-Car_Function_List_CAN_Gen2-VIN,Available
ENG122228-ENG117687-Car_Function_List_CAN_Gen2-VIN_msg_bus,Comfort data bus
ENG117913-ENG101574-Dimming_Ambient_Illumination_Information_Control_Unit-X1,0
ENG117913-ENG99557-Dimming_Ambient_Illumination_Information_Control_Unit-X2,50
ENG117913-ENG102140-Dimming_Ambient_Illumination_Information_Control_Unit-X3,100
ENG117913-ENG99777-Dimming_Ambient_Illumination_Information_Control_Unit-Y1,0
ENG117913-ENG100480-Dimming_Ambient_Illumination_Information_Control_Unit-Y2,50
ENG117913-ENG100773-Dimming_Ambient_Illumination_Information_Control_Unit-Y3,100
ENG117914-ENG101574-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X1,0
ENG117914-ENG99557-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X2,50
ENG117914-ENG102140-Dimming_Ambient_Illumination_Operating_and_Display_Unit-X3,100
ENG117914-ENG99777-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y1,0
ENG117914-ENG100480-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y2,50
ENG117914-ENG100773-Dimming_Ambient_Illumination_Operating_and_Display_Unit-Y3,100
ENG117916-ENG101574-Dimming_Illumination_for_Display_Unit-X1,0
ENG117916-ENG99557-Dimming_Illumination_for_Display_Unit-X2,10
ENG117916-ENG102140-Dimming_Illumination_for_Display_Unit-X3,100
ENG117916-ENG102936-Dimming_Illumination_for_Display_Unit-X4,150
ENG117916-ENG103548-Dimming_Illumination_for_Display_Unit-X5,220
ENG117916-ENG113992-Dimming_Illumination_for_Display_Unit-X6,253
ENG117916-ENG99777-Dimming_Illumination_for_Display_Unit-Y1,1 %
ENG117916-ENG100480-Dimming_Illumination_for_Display_Unit-Y2,1 %
ENG117916-ENG100773-Dimming_Illumination_for_Display_Unit-Y3,9 %
ENG117916-ENG100631-Dimming_Illumination_for_Display_Unit-Y4,20 %
ENG117916-ENG102174-Dimming_Illumination_for_Display_Unit-Y5,60 %
ENG117916-ENG113993-Dimming_Illumination_for_Display_Unit-Y6,100 %
ENG117921-Operating_and_Display_Unit_1_Proximity_Sensor_Basic_Adaptation,04 01 52 04 52 10 52 40 52 32 00 64 00 96 00 90 01 C8 00 96 00 14 00 14 00 14 00 14 00 FF FF FF FF FF FF FF FF 01 00 05
ENG117809-p_damping_Display,5 ms
ENG117808-p_HMI_Display,13 %
ENG122219-ENG122287-Radio_Level_Quality_Offsets-Set_AM_Quality_Level_Offset,0
ENG122219-ENG122288-Radio_Level_Quality_Offsets-Set_FM_Quality_Level_Offset,0
ENG117919-Startup_Screen_Sticker_HMI,00 00
ENG109862-ENG117847-Vehicle_configuration-advanced_range_display,OFF
ENG109862-ENG130249-Vehicle_configuration-Apple_DIO,On
ENG109862-ENG125043-Vehicle_configuration-Dtmf_without_active_call,OFF
ENG109862-ENG130248-Vehicle_configuration-Google_GAL,On
ENG109862-ENG117850-Vehicle_configuration-gracenote_local_coverarts,On
ENG109862-ENG117851-Vehicle_configuration-gracenote_local_other,On
ENG109862-ENG117848-Vehicle_configuration-gracenote_online_coverarts,OFF
ENG109862-ENG117849-Vehicle_configuration-gracenote_online_other,OFF
ENG109862-ENG125049-Vehicle_configuration-Joker_button_1,Not Present
ENG109862-ENG125050-Vehicle_configuration-Joker_button_2,Not Present
ENG109862-ENG127492-Vehicle_configuration-LGI,OFF
ENG109862-ENG130246-Vehicle_configuration-LTE_modul,activated
ENG109862-ENG07590-Vehicle_configuration-Mirror_link,function_on_hmi_on
ENG109862-ENG117843-Vehicle_configuration-my_audi,OFF
ENG109862-ENG117845-Vehicle_configuration-online_dictation,OFF
ENG109862-ENG127495-Vehicle_configuration-online_media,OFF
ENG109862-ENG117840-Vehicle_configuration-online_navigation,OFF
ENG109862-ENG117837-Vehicle_configuration-online_POI,OFF
ENG109862-ENG117838-Vehicle_configuration-online_POI_voice,OFF
ENG109862-ENG117839-Vehicle_configuration-online_portal_browser_services,OFF
ENG109862-ENG117841-Vehicle_configuration-online_street_view,OFF
ENG109862-ENG125048-Vehicle_configuration-OPS_display_in_dash_board_display_unit,OFF
ENG109862-ENG125046-Vehicle_configuration-Phone_module_operation_mode,Data & language service active
ENG109862-ENG117844-Vehicle_configuration-picture_navi,OFF
ENG109862-ENG127496-Vehicle_configuration-ProbeCar_lgi,OFF
ENG109862-ENG06574-Vehicle_configuration-ProbeCar_vzo,OFF
ENG109862-ENG125047-Vehicle_configuration-PSD_Protocol_Version,PSD_1.5
ENG109862-ENG117846-Vehicle_configuration-remote_HMI,OFF
ENG109862-ENG07589-Vehicle_configuration-RSE_software_component,activated
ENG109862-ENG126143-Vehicle_configuration-RVC_video_input,FBAS
ENG109862-ENG11009-Vehicle_configuration-sd_slot_deactivation,no restriction
ENG109862-ENG07588-Vehicle_configuration-SDS_Region_Flag,no_region
ENG109862-ENG125045-Vehicle_configuration-Sim_card_mode_switch,Not Present
ENG109862-ENG07591-Vehicle_configuration-Smartphone_interface_for_rhmi,activated
ENG109862-ENG126993-Vehicle_configuration-Station_Logo_DB_Mode,1
ENG109862-ENG125044-Vehicle_configuration-Support_for_response_and_hold,OFF
ENG109862-ENG125042-Vehicle_configuration-Support_of_threeway_calling,OFF
ENG109862-ENG130247-Vehicle_configuration-Support_second_phone,On
ENG109862-ENG126994-Vehicle_configuration-TPEG_availability,OFF
ENG109862-ENG06575-Vehicle_configuration-UOTA,OFF
ENG109862-ENG117852-Vehicle_configuration-UPnP,OFF
ENG109862-ENG117836-Vehicle_configuration-VZAPro,OFF
ENG109862-ENG127494-Vehicle_configuration-VZO,OFF
ENG109862-ENG06576-Vehicle_configuration-WiFi_Client_HMI,OFF
ENG109862-ENG117842-Vehicle_configuration-WIFI_Hotspot,OFF
