Error in label file 03G-906-021-BMM ?
Team22
DE
C?ID=287274
Just a short question from a rather new VCDS user in regard of a peculiarity in "Measuring Blocks", checking exhaust cooler control status.
This is in group 44 in my case, see attached screenshot. The engine controller number is SW: 03G 906 021 NK / HW: 03G 906 021 AB. (This is a Passat B6/3C from 2006.)
The value for the control of the exhaust cooling changes from 0 to 1, as expected, once the coolant temperature rises.
What confuses me, though, is that the Tooltip says 0 for ACTIVE and 1 for NOT ACTIVE (see attached picture) which is exactly contrary to what is expected.
Is this simply a case of an erouneous label?
I've asked the German/Swiss distributor (Kaufmann), however to no avail, unfortunately, even though I've posted a log showing the control status of the exhaust cooler and provided the same screenshot in the forum there (https://community.dieselschrauber.de/viewtopic.php?p=233213#233213).
Team22
DE
C?ID=287274
Re: my post from Dec 21 (above): Is my assumption correct, then, that the tooltip is errouneous?
Can't rule out that this is an error in the label file, but can't confirm it from this side of the pond either since that engine wasn't available here.
