problem with clearing all dtc's in auto scan...
emserg
C?ID=39273
working on 2013 passat tdi
have couple of issues...
1. trying to do auto scan with usb connected, gets stuck at access start authorization module, gets connected to it pulls the codes, and then nothing happens. when trying to exit the module and go back to auto scan , the only modules show up as scanned are engine, trans and tire press monitors. even though i see it going trough allot more modules before it gets stuck.
with wifi works fine...
2.when trying to clear all dtc's and "can command" is selected, does not clear anything.... when "can command" is deselected goes into modules and clears codes....
Which interface are you using? It looks like you have more than one kind. Are you using Release or Beta software?
emserg
C?ID=39273
sorry for lack of info...
it is the hex net 14.7 beta
i tryed over wifi and usb
did an update of the software and firmware....
same thing
here is and auto scan
VCDS Version: Beta 14.7.0 (x64)
Data version: 20140601
edge motors
Friday,11,July,2014,11:34:01:23346
Chassis Type: A3 (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 36 37 42 44 46 47 4F
          52 56 62 72 77
VIN: 1VWCN7A34DC110454   Mileage: 27180km-16888miles
Address 01: Engine (J623-CKRA)       Labels: 03L-906-012-CKR.clb
   Part No SW: 03L 906 012 BN    HW: 03L 907 309 S
   Component: R4 2,0L EDC   H24 4804
   Revision: 71H24---    Serial number:
   Coding: 001D0012042400008000
   Shop #: WSC 09003 957 00200
   ASAM Dataset: EV_ECM20TDI01103L906012BN 004007
   ROD: EV_ECM20TDI01103L906012BN.rod
   VCID: F1AA93DB20F2A8B210-80A4
Readiness: 0 0 0 1 1
   Part No SW: 02E 300 058 M    HW: 02E 927 770 AL
   Component: GSG DSG AG6     512 3527
   Revision: 05651213    Serial number: 00001212210466
   VCID: A404AA8F67804D1AAB-80F1
   Revision: 00H31001
   Coding: C54BC0F5492300FAA30F03E9921D0042A71000
   VCID: FDB2BFEB64AADCD284-80A8
Address 05: Acc/Start Auth. (J518)       Labels: 5K0-959-434.clb
   Part No SW: 5K0 959 434 B    HW: 5K0 959 434
   Revision: 00086000    Serial number: 0193663223
   Coding: 130C0C
   ROD: EV_KESSYPQ35G.rod
   VCID: B4245ACF1F60DD9A3B-80E1
65794 - Function Restricted due to Insufficient Voltage
          U1400 00 [008] - -
                    Reset counter: 8
65812 - Supply voltage
          U1012 00 [008] - Voltage too High
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 00:37:57
65813 - Supply voltage
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:29:31
1052935 - Touch Sensor on Exterior Door Grip; Driver Side
          B116B 11 [008] - Short to Ground
                    Reset counter: 8
1053191 - Touch Sensor on Exterior Door Grip; Passenger Side
          B116C 11 [008] - Short to Ground
                    Reset counter: 8
1057547 - Antenna for Keyless Entry System; Interior Antenna 1
          B1172 13 [008] - Open Circuit
                    Reset counter: 8
                    Mileage: 27022 km
                    Date: 2014.06.25
                    Time: 05:17:53
   Part No SW: -----------    HW: -----------
   Component: Climatronic   0405
   Revision: --------
   Coding: 0010001012
   ROD: EV_ACClimaBHBVW411.rod
   VCID: EFAE95A336C6BE4206-80BA
9473138 - Motor for Left Temperature Flap
          B108C 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9473394 - Motor for Right Temperature Flap
          B108D 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9474162 - Motor for Defroster Flap
          B1090 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9474418 - Motor for Front Air Distribution Flap
          B1091 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
9472882 - Motor for Fresh Air / Recirculated Air Flap
          B108B 54 [009] - Missing Calibration / Basic Setting
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:58
9477872 - AC Compressor First Run-In
          B109E F0 [009] - Not Performed
                    Reset counter: 229
                    Mileage: 27186 km
                    Date: 2014.07.11
                    Time: 23:21:57
   Part No SW: 5K0 937 087 AA    HW: 5K0 937 087 AA
   Component: BCM PQ35 H+   121 0168
   Revision: BL121001
   Coding: 6F200E1B882B2AD408880201360085480071008645A005F064806000BC70
   Shop #: WSC 07985 444 103304
   VCID: F4A49ACF57E09D9AFB-80A1
   Component: RLS 221112 05  54  0403
   Coding: 22300A
   Serial number: 003MWM00TAMB
   Coding: 00005033
   ROD: EV_AirbaVW10SMEVW360.rod
   VCID: F5A2A7CB549A8492CC-80A0
   Serial number: 6940000Y130000RBTX0S
   Coding: 303047
   Serial number: 3572MSME42481476ZZZT
   Serial number: 3582MSME13094375ZZZQ
   Serial number: 3516KSME42556821ZZZM
   Serial number: 3526KSME48686821ZZZX
   Serial number: 3556LSME61453721ZZZN
   Crash sensor for front airbag; passenger side:
   Serial number: 3566LSME49533721ZZZT
   Part No SW: 1K5 953 521 AR    HW: 5K0 953 569 E
   Revision: FF010041    Serial number: 20121214100997
   Coding: 000A140000
   ROD: EV_SMLSNGVOLWS.rod
   VCID: FDB2BFEB6CAADCD284-80A8
   Subsystem 1 - Part No SW: 3C8 959 537 D    HW: 3C8 959 537 D
   Coding: E20000
   Part No SW: 561 920 970 E    HW: 561 920 970 E
   Component: KOMBI         H07 0705
   Coding: 231E01
   ROD: EV_Kombi_UDS_VDD_RM09_SE35.rod
   VCID: 9C74926F97F075DA13-80C9
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 16021303290713
   Coding: 461000
   VCID: F6A0A0C7419C8F8AC5-80A3
   Component: IMMO          H07 0705
   Coding: 000007
   ROD: EV_Immo_UDS_VDD_RM09_SE36.rod
   VCID: EA9884B70D245B6A51-80BF
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000002993005
   Coding: 4900000000000000
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: B02C56DFEB78E1BA5F-80E5
13635840 - Supply voltage
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:24:47
13893888 - Function Restricted due to Exessive Voltage
          U1401 00 [008] - -
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 00:00:02
          U1400 00 [008] - -
                    Reset counter: 8
                    Mileage: 27172 km
                    Date: 2014.07.03
                    Time: 23:23:45
1049345 - Comfort System CAN Bus (SAE Medium Speed Bus)
          U0011 00 [008] - Performance
                    Reset counter: 8
                    Mileage: 27173 km
                    Date: 2014.07.04
                    Time: 01:28:19
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664273002
   Coding: 010100
   VCID: AA1844B7C5A49B6A91-80FF
   Part No SW: 561 959 760     HW: 561 959 760
   Component: MEM-FS        H04 0181
   Revision: AA000000    Serial number: 00000049778182
   Coding: 00581B0000000000000021010100202020202120202020
   VCID: E08CE69FF318113A8F-80B5
   Part No SW: 3C0 035 684 G    HW: 3C0 035 684 G
   Component: RNS-MID       H02 3696
   Revision: AB001001    Serial number: VWZ6Z7M7348035
   Coding: 04090042010000A6000B
   VCID: A71EBD83D6B6A6028E-80F2
   Part No SW: 561 959 701 A    HW: 3C0 959 793 C
   Revision: 12110009    Serial number: 0006115775
   Coding: 0405FD
   ROD: EV_TSGFPQ25BRFVW46X.rod
   Slave Driver:
   Subsystem 1 - Part No SW: 561 959 811     HW: 561 959 811   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG_HL  004 4472
   Coding: 800000
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 290    3305
   Revision: 00H22000
   VCID: B73E6DC3C61636821E-80E2
Address 47: Sound System (R12)       Labels: 3T0-035-456.clb
   Part No SW: 5C6 035 456 A    HW: 5C6 035 456 A
   Component: KonzernAmp10K H07 6813
   Revision: --------    Serial number: EAA098A0008458
   ROD: EV_AudioVerst10KanalSTT3.rod
   VCID: A600B087D9BCBF0AB5-80F3
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030108
   VCID: EFAE95A33EC6BE4206-80BA
   Coding: 181100
   Part No SW: 561 959 702 A    HW: 3C0 959 792 C
   Revision: 14110009    Serial number: 0006088962
   Coding: 0405FC
   ROD: EV_TSGBPQ25BRFVW46X.rod
   VCID: 9D729F6B8CEA7CD2E4-80C8
   Slave Passenger:
   Subsystem 1 - Part No SW: 561 959 812     HW: 561 959 812   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG_HR  004 4472
   Coding: 800000
   Part No SW: 7P6 035 730 K    HW: 7P6 035 730 K
   Revision: 1B001001    Serial number: 00007663990824
   Coding: 0A10040000010110
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA.rod
   VCID: BA3874F73D042BEAE1-80EF
End-------------------------(Elapsed Time: 02:30)--------------------------
OK, referring back to your original post in this thread:
1. Clearly did not happen when you made the above scan. Were you previously using older versions?
2. Is that still happening?
emserg
C?ID=39273
sorry this one was done through wifi... ill do the usb scan in a second...
