Blocked Work Shop Code (WSC) in Address 09: Cent. Elect.
ertromp
C?ID=197590
Last Saterday I read out a Skoda Octavia build 2006
First I made a autoscan and I saved the file.
Then it was the meaning to change a light setting in module 09.
When changing a bit and want to save this setting there is a fault code that the number of the WSC is incorrect.
This is a part of the scan:
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 3C0 937 049 E HW: 3C0 937 049 E
Component: Bordnetz-SG H37 1002
Revision: 00H37000 Serial number: 00000004369703
Coding: C9880F230004140000110D000000000000197F075C
Shop #: WSC 99999 999 789888
VCID: 2B55F0A48AFAF4461E5-807E
The problem is that the numer 789888 is out of range.
How can that be changed?
Hmm, I wonder what tool was used to put those values in? Importer 999 is Canada, and there are no Skodas in Canada.
Anyway, if the fields are grayed out on the Coding screen, like this:
Then the work-around is to put plausible numbers into VCDS on the Options screen, in the User Interface and Identification tab, like this:
After you do that, use [Save], then exit VCDS and restart it.
Once you do that, VCDS will always use those values. To reset it to Stealth mode, you'll have to delete its the VCDS.CFG file.
ertromp
C?ID=197590
Thanks for the solution!
I was also wondered by the WSC because I am a registrated VCDS user in Netherlands Europe. My first idee was the driver let made these codings by an user whit a not official VCDS dongle but that he couldn't tell me because he let do this coding by a person in 2012 (he said)
