Skoda Octavia 4x4 2.0TDI Combi MY14 - Light sensor issue?
Arguzen
Bergen, Norway
C?ID=152258
Hello!
New to this forum although I've been using VCDS on and off for more than 4 years. Carried out minor tweaks on my previous cars (2003 VW Passat 3BG TDI, 2007 VW Touran 1.9TDI).
Mostly been altering light settings, auto locking and other minor tweaks.
Now I got this Skoda Octavia 4x4 2.0TDI Combi MY14.
Have done some minor alterings:
- Both rear fog lights at the same time
- Enabling boot closing from the interior button and the keyfob
- Enabled lap timer i Maxidot
- Enabled needle staging
- Enabled rear lights (and instrument lights) together with DRLs
- Enabled fan speed to be displayed in AUTO mode
- Enabled DRLs (LED stripe) to dim when flashing the indicators
- Deactivated the AM band on the Columbus MMI
- Enabled automatic daylight saving time in the Columbus MMI
But, there's always a but. I have not yet been able to alter the setting/threshold/sensitivity for the light sensor controlling my lights in Auto mode on the lights switch.
Living the most western part of Norway we don't get much daylight these day, but still I would expect the sensor to light only DRLs (LED stripe) and NOT the low beam in the middle of the day. Even if it is overcast.
I do know about the early, middle and late setting in the MMI but it does not make much difference.
I have been searching and reading both this forum and others but still have not found any solution to be able to alter the sensitivity of the light sensor to keep my DRLs lit during bright daylight even these days getting close to winter solstice.
I have read that in some models you should be able to alter byte 2 in the RLFS? drop down menu in 09 Central Electric. But mine refuses to accept anything other than the default setting by selecting the proper car model in byte 1.
Any suggestions will be welcome.
Please find a complete auto scan of my car below.
Tuesday,13,December,2016,20:41:51:35231
VCDS Version: 16.8.4.2 (x64)
VIN: TMBLJ9NE6E0090779   License Plate:
Chassis Type: NE (5Q0)
Scan: 01 03 05 08 09 10 13 15 16 17 18 19 22 2B 36 42 44 47 52 55
          5F 69 6D A5
VIN: TMBLJ9NE6E0090779   Mileage: 46176km-28692miles
Address 01: Engine (J623-CKFC)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EA    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 5515
   Revision: 83H22---
   Coding: 1119003A035601091000
   Shop #: WSC 73430 031 00000
   ASAM Dataset: EV_ECM20TDI01104L906021EA 002003
   ROD: EV_ECM20TDI01104L906021DS_002.rod
   VCID: 68D58E4F93FA440261-803C
   Part No SW: 5Q0 907 379 R    HW: 5Q0 907 379 F
   Component: EMB8 EHCB     H31 0356
   Revision: 00000000    Serial number: 627530000006A1
   Coding: 1C0762912429096C007E070741CC293846249000E08294F0F4635072C009
   Shop #: WSC 73430 031 00063
   ASAM Dataset: EV_Brake1UDSContiMK100ESP 033001
   ROD: EV_Brake1UDSContiMK100ESP_033.rod
   VCID: 4B9F51C3E24C8F1A6C-801E
   Revision: 00021000    Serial number: 0194432300
   Coding: 030C0C
   Shop #: WSC 73430 790 00000
   VCID: 3A710407BDD60692C7-806E
   Part No SW: 5E0 907 044 J    HW: 5E0 907 044 J
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02010104004101011005004100100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   VCID: 2C5D325F4782A82245-8078
   Air quality sensor:
   Part No SW: 5Q0 937 084 AA    HW: 5Q0 937 084 AA
   Component: BCM MQBAB H   H14 0112
   Serial number: 00011328100404
   Coding: 0C030B76424722FB0FA44004001C17280C08000000000000000000000000
   ROD: EV_BCMBOSCH_011.rod
   VCID: 77F7DD33CE44DBFAF8-8022
   Subsystem 1 - Part No SW: 5E1 955 119     HW: 5E1 955 119   Labels: 5QX-955-119-V1.CLB
   Component: WWS371 131007  041 0570
   Serial number:         131009232124
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M10D11H01M33S24S4
   Coding: 02805D
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131328000169
   Coding: 0031061141
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_SK37.rod
   VCID: 3D7B0F1BACF831AAE2-8068
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 06091376510683
   Coding: 00000600FE0309
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 356B173B94C8E9EA2A-8060
   Part No SW: 3Q0 959 655 AA    HW: 3Q0 959 655 AA
   Component: Airbag VW20   011 0189
   Revision: --------    Serial number: 003NYPLFC9ER
   Coding: 98FCC000000000005C5400CC000800000065
   ROD: EV_AirbaVW20TS6VW48X.rod
   VCID: 7DFBCF1BEC78F1AAA2-8028
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169593B16101370656
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169592B15101370350
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 454 000 410 13
   Serial number: 3576U000000A7420DD0E
   Subsystem 4 - Part No SW: -----------    HW: 454 000 410 13
   Serial number: 3586U0000002E081DD0H
   Subsystem 5 - Part No SW: -----------    HW: 454 800 510 13
   Serial number: 3516R51690102000000N
   Subsystem 6 - Part No SW: -----------    HW: 454 800 510 13
   Serial number: 3526RC9CC0D02000000H
   Subsystem 7 - Part No SW: -----------    HW: 454 800 309 13
   Serial number: 3556VA1D2E3010000008
   Part No SW: 5Q0 953 507 CC    HW: 5Q0 953 549
   Revision: --------    Serial number: 15101308491576
   Coding: 6C00
   ROD: EV_SMLSKLOMQB_AU37.rod
   VCID: 79F3DB0BF850CD8A8E-802C
   Part No SW: 5E0 920 871 D    HW: 5E0 920 871 D
   Component: KOMBI         333 2210
   Coding: 07AD0810ED94000801887A03000000
   Shop #: WSC 73430 031 12345
   VCID: 2953CB4B4870BD0ABE-807C
Address 18: Aux. Heat (J364)       Labels: 5Q0-963-272.clb
   Part No SW: 5Q0 963 272 C    HW: 5Q0 963 272 C
   Component: STH-MQB       006 0069
   Coding: 9309
   ASAM Dataset: EV_AuxilParkiHeateWOS 002014
   VCID: 3669103789CEE2F223-8062
   Subsystem 1 - Part No SW: 5Q0 963 513     HW: 5Q0 963 513
   Component: R149 T91-LIN  003 0301
   Serial number: 00000000000000713002
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1144
   Revision: --------    Serial number: 0001117282
   Coding: 030100040B087300EF00065E080F00010001000000000000000000000000
   ROD: EV_GatewLear_009.rod
   VCID: 3B7F0103B2EC3F9ADC-806E
   Subsystem 2 - Part No SW: 5E0 919 719 A    HW: 5E0 919 719 A
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000B0613011013
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 9094991403
   Part No SW: 0CQ 907 554 D    HW: 0CQ 907 554 D
   Component: Haldex4Motion H52 7076
   Serial number: HA1-00008.08.13
   Coding: 0001
   ROD: EV_AllWheelContrHA1VW37X_SK12.rod
   VCID: 468960F7F92E7272B3-8012
   Part No SW: 5Q0 905 861     HW: 5Q0 905 861
   Component: ELV-MQBA      H06 0010
   Revision: 00000000    Serial number: 13000222573005
   Coding: 4100000000000000
   ASAM Dataset: EV_ELVMarquMQB 003008
   ROD: EV_ELVMarquMQB_003.rod
   VCID: 73EFE923DA3CB7DAC4-8026
Address 36: Seat Mem. Drvr (J810)       Labels: None
   Part No SW: 5Q0 959 760 A    HW: 5Q0 959 760 A
   Component: Sitzmemory    H06 0009
   Serial number: Y0006MIK10191
   Coding: 001000000000010001A081808080000000008181000000D4
   ASAM Dataset: EV_SeatMemorDriveSide 001015
   ROD: EV_SeatMemorDriveSide_SK37.rod
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000078538899
   Coding: 00150820DE00028000001100
   VCID: 0201BCE795868E52DF-8056
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Component: FOND_FHSG_DRV  005 0004
   Serial number: 00000000000000876870
   Coding: 010200
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 93
   ROD: EV_SteerAssisMQB_008.rod
   Part No SW: 8V0 035 223     HW: 8V0 035 223
   Component: MIBAMP1ALPINE H11 0300
   Serial number: SKZ8Z1D76009DPS
   Coding: 03730200AA002AAA00
   ASAM Dataset: EV_AMPMst16C2ALPI 004016
   ROD: EV_AMPMst16C2ALPI_SK37.rod
   VCID: 6DDBFF5BBC18612A12-8038
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000078994350
   Coding: 00150020DE00028000001100
   VCID: 0103B3EB9080954AC6-8054
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Component: FOND_FHSG_PSG  005 0004
   Serial number: 00000000000000871329
   Coding: 190200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 03EA02003F010000
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
Address 5F: Information Electr. (J794)       Labels: 5E0-035-MIB-HGH1.clb
   Part No SW: 5E0 035 020 A    HW: 5E0 035 020
   Component: MU-H-ND-EU    H41 0196
   Serial number: A313J0D7511927
   Coding: 03730201000000001111120200A802002F0000A401000100F6
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_SK37.rod
   VCID: 152BF7BBF40809EA0A-8040
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H50 0022
   Serial number: SKZ8Z9NL100547
   Subsystem 2 - Part No SW: V03 959 801 BK    HW: -----------
   Component: ECE 2017  --- 0157
Address 69: Trailer (J345)       Labels: 5Q0-907-383.clb
   Part No SW: 5Q0 907 383     HW: 5Q0 907 383
   Component: ConWysTrailer H10 0030
   Revision: 6A001003    Serial number: 00000181563668
   Coding: 0100000200000000
   ASAM Dataset: EV_TrailFunctDemouHella 001001
   ROD: EV_TrailFunctDemouHella.rod
   VCID: 74EDEA3FDF32B0E2DD-8020
Address 6D: Trunk Elect. (----)       Labels: 7N0-959-107.clb
   Part No SW: 5E0 959 107     HW: 5E0 959 107
   Component: HDSG-Modul    H01 0744
   Revision: 42001001    Serial number: 273300623
   Coding: 1233074002
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462_SK37.rod
   VCID: 69D38B4B88F07D0A7E-803C
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000130635
   Coding: 0101010001030303000400000100000101
   ROD: EV_MFKBoschAU370.rod
End-------------------------(Elapsed Time: 05:11)--------------------------
Arguzen: Hi. I thought that I would respond for no other reason than because I think that there is a weird "symmetry" between our relative positions on this fragile planet - both close to the Arctic and Antarctic repectively (happy to swap mountains of snow for long periods of sweltering heat)
Anyhow - enough of the frivolity! As to your question, I don't have your car, but I do have your particular RLFS (details of which I repeat from your auto-scan below)
   Coding: 02805D
The bytes that define the car type on my RLFS is:
which aligns with your setting for Byte 1-2, but the sensitivity values are in byte 0, not byte 2 as per your post
Try adjusting Byte 0, I guess. If the long coding helper won't permit changes, try altering the values directly in the "Open Controller screen"
Arguzen
Bergen, Norway
C?ID=152258
Hello DV52,
I have never been "down under" but it's on my bucket list.
I'm partly agree with you regarding the sensitivity being in byte 0 rather than byte 2.
In Byte 0 you may make the threshold to act earlier, not later as I want to. At least this is how I interpret the different settings in byte 0.
On some models (Golf 6 among others iirc) I've seen that you in may enter some sort of compensation factor related to the tint of the windscreen as to make the sensor less sensitive.
In my car the byte 2 is fixed and related to the model selected in byte 1.
I just might accept the fact that in my neck of the woods we just don't get enough daylight during the winter to get full use of the Auto function of the light switch.
An other downside is that the navi screen goes into night mode along with the low beams been lit.
I just have to get used to flip the light switch to "0" to turn on the DRLs and get to navi screen into day mode.
Arguzen: OK - Not sure if this will apply to your car, but I note that you have a high-end BCM (which is encouraging). Have you made an adaptation channel control module for the BCM?. If so, does the admap include the following two channels ?
(1)-RLS_Night_Sensitivity-p_lx_rs_day > 500 lx
(2)-RLS_Night_Sensitivity-p_lx_rs_dawn > 200 lx
I don't have these channels on my car (I have a medium-level BCM) but I interpret the 'day' channel to be the threshold ambient illumination to switch-on the lights at dusk (i.e. being 500 lux) and the 'dawn' number to be the switch-off illumination level. Again this is a guess, but I hypothesize that the code changes that can be made in Byte 0 of the RLFS use the number in the 'day' adaptation channel as a reference (I think).
So if you have the two channels above - then you might try experimenting with different numbers. I suspect that a SA will be needed and I hope that the magic number 31347 will apply (again, another guess).
PS: As for your bucket list -as the old Italians used to say "carp diem" because "tempus fugit"
Arguzen
Bergen, Norway
C?ID=152258
DV52: I do have those two channels, but they appear with errors stating that they are not available.
There's an other channel as well. I don't remember the title from the top of my head, but it's related to some sort of delay for when to switch between "day" and "night". I will have to dig further into this when time and opportunity make it possible.
PS: I ticked of a major point on my bucket list this summer: Route 66 from Chicago to Los Angeles on motorcycle. It still puts a big smile on my face thinking back.
Arguzen
Bergen, Norway
C?ID=152258
A short update.
Have had a day with real sun shine and no clouds in the sky. The light sensor seems to do its job. The DRLs got lit and everything looks as expected. I put my hand over the sensor and the low beam got lit. Removed my hand and after a few seconds the low beam went out and the DRLs got lit again.
It seems that the sensors and electronics in my car and myself disagree on how much light is required to light of the DRLs in stead of the low beams.
Still digging for that hidden piece of info on how to tweak the sensitivity.
barstanders
C?ID=277262
Hello Arguzen,
I had in the beginning problems with the coming home and leaving home activation.
The setting down where after retrofit the rainsensor wrong.
So i have change the valeu to this and now 95% works great and somtimes i olso have problem when i drive out of a garage the lights stay 15 min on on a clear bright day.
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung,116
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung,2
You have like me the software version H14 112 AA
You can update the BCM to AE version H14 124 AE ore 134 AJ.
I have made the update to AJ but then i had a problem with the door led lights the ilumunate when the door are open and not close.
So i downgade back but this rainsensor works better with the AJ version.
Yes when you update to AJ version you can change this valeu, and more where you see now a fehler not with version 112 AA
