07 Touareg TDI: AFS fault. Need help coding FFS
Flaps10
C?ID=219700
So the little lady's VW has the amazing headlights that self level and look around corners. They also "side light", which isn't as riveting as side boob but it's still pretty cool. It's an H3 bulb and really does add some lumens to maneuvering operations. Some of those peasants can be tricky to locate.
Until it doesn't work.
You know the drill. Right headlight looks like a really expensive aquarium one day. There's also no main beam and no side light. I remove the headlight assembly using the factory tool - the one that turns those shitty gears that might have worked for the first year after the car was made. The reason they get jacked up is because there's no indication of which direction you turn them (righty tighty doesn't apply to both lights) and being cheezy and hard to turn, well... But that's not why I'm here.
To fix the main beam I went old school. Bulbs are not cheap and neither are the control modules. I swapped modules with the left headlight and the problem remained on the right. So it was the bulb. Done.
After draining the swamp I examined the assembly and found that the AFS module resides in the very bottom of the tank, and has openings facing upward
Viola. Some genius right here
I know it actually looks pretty good in that picture, but when I shook all the water out it was fuzzy - like something old in fridge. I laughed and thought of Jack, and douched it out with oven cleaner and water followed by a thorough air dry. I installed it back in the vehicle, and of course it was tango uniform. At least the headlight and turn signals worked. We've continued to get the AFS warning on the dash which stayed on and continues still. I really just wanted the serial number off the unit so I could scrounge.
And Scrounge, I did.
$300-ish retail. Look in there. There are more components in the AFS module than my uncle's entire model T Ford. I found one brand new in Lithuania for $100 ebay and it's here. I installed it.
Cleared my codes, updated my VCDS and firmware. My coding experience is very limited. Very.
I dig this out of my scan today:
Address 09: Cent. Elect.        Labels: 7Lx-937-049-V1.clb
   Part No: 7L6 937 049 N
   Component:                     3002
   Coding: 0110815
   Shop #: WSC 05244 444 64165
   VCID: 4797FD603593F07A48-515C
00968 - Right Turn Signals
01498 - Bulb for Parking Lamps; Right (M3)
and
Address 55: Headlight Range        Labels: 7L6-907-357.lbl
   Part No SW: 7L6 907 357     HW: 7L6 907 357
   Component: AFS-Steuergeraet    0003
   Revision:   H09       Serial number:
   Coding: 0000003
   Shop #: WSC 23347 444 59343
   VCID: 78F54E9C08ED4F82F1-515C
   Subsystem 1 - Part No: 7L6 941 329   Labels: 3D0-941-329.CLB
   Component: AFS-Lst.-Modul l    X018
   Coding: 00000034
   Subsystem 2 - Part No: ID-R fehlt    Labels: ID-55-02.CLB
   Component: AFS-Lst.-Modul r    ....
   Coding: 00000255
            000 -  -  - MIL ON
                    Fault Status: 11100000
                    Reset counter: 49
02236 - Stationary Right Cornering Lamp (Right) (M52)
            007 - Short to Ground - Intermittent - MIL ON
                    Fault Status: 10100111
                    Reset counter: 7
02656 - Power Output Stage for Left Headlight (J667); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 49
02234 - Right Headlight Power Output Stage (J668)
                    Fault Status: 11100100
                    Fault Frequency: 12
                    Reset counter: 49
02657 - Power Output Stage for Right Headlight (J668); Not Coded
            000 -  -  - MIL ON
                    Reset counter: 49
                    Fault Status: 11100101
                    Reset counter: 49
A lot of "not coded" going on there. I've done a search and I don't find much on AFS errors nor digging myself out.
Any help appreciated.
Flaps10
C?ID=219700
Sorry, feeling a little retarded right now after a little RTFM
I could still probably use some tips if anyone thinks it might be of help.
NEtech
Denmark
C?ID=56995
These are your main issues:
Part number "missing" because of communication problem (see Wiki here), when that is fixed, the coding is also fixed.
Flaps10
C?ID=219700
Much obliged. I'm stuck in the area not heavily detailed in the manual.
Between it, the VW factory pages and an open session of VCDS i located the lights under 09 Central Electronics. The coding step is over arching and appears to trickle down to sub components (according to VW)
I don't understand where i enter the unit part number (same as the old)
I was blocked by security. Now i see the security code if i follow the wiki to the golf section.
Obviously the software is written to accommodate a wide range of vehicles and it is not exactly intuitive to those of us who are mostly comfortable with things that bleed oil instead of smoke.
You don't enter it. The 55 module reads it from the AFS module when there's communications between the two. Right now...
Flaps10
C?ID=219700
So, why for is it not communicating?
Possibilities:
* Defective module
* Incompatible module
* Lack of power
* Problem with wiring
Flaps10
C?ID=219700
*module brand new including part number
*and identical to old
*Does the module have its own fuse ?
*That would be surprising [/s]
Gone But Not Forgotten
"Some people you just cant reach" :D
Is it the correct part #........ not being FOD?
*module brand new
And from an overseas supplier at a price that's "too good". ;)
I'm not saying the replacement module is the problem, but I wouldn't rule it out either.
Flaps10
C?ID=219700
Always a possibility of course. Seller had >1000 reviews, all positive
Flaps10
C?ID=219700
I'm going to check fuses when she gets back with the vehicle. But diagrams don't show fuses for headlight controllers, just low beam, turn signal, etc
I triggered all the output tests it would let me do last night and the only thing not working is the AFS.
Wiring appears surprisingly non crunchy. I'll start in on the WD and see what i can eliminate with a VOM
Flaps10
C?ID=219700
I'm swinging in the dark here but I realized that the sections I scanned last night were after having a headlight full of water and prior to clearing the codes.
This is the complete autoscan taken after clearing them out.
Saturday,17,December,2016,15:08:20:15876
VCDS Version: 16.8.4.2 (x64)
VIN: WVGPT77L67D004129   License Plate:
Chassis Type: 7L (7L - VW Touareg (2003 > 11/2006))
Scan: 01 02 03 05 06 08 09 11 13 15 16 17 18 19 1C 22 29 32 34 36
          37 39 3C 46 47 55 56 57 64 65 68 69 6C 6D 6E 75 76 77
VIN: WVGPT77L67D004129   Mileage: 231510km-143853miles
   Part No SW: 070 906 016 CQ    HW: 028 101 196 2
   Component: V10 5,0L EDCG001AGMª9805
   Revision: --H02---    Serial number: VWZ3Z0F6478811
   Coding: 0060575
   Shop #: WSC 23347 444 84359
   VCID: 61C303F8BB77AE4AA6-5140
Readiness: 1 2 0 0 0
Address 02: Auto Trans        Labels: 09D-927-750.lbl
   Part No SW: 09D 927 750 DP    HW: 09D 927 750 DP
   Component: AL 750 6A           0856
   Revision: 00H37000    Serial number:
   Coding: 0004216
   Shop #: WSC 31414 000 00000
   VCID: 7F07A5802DC378BAB0-5140
Address 03: ABS Brakes        Labels: 7L0-907-379-MK25.lbl
   Part No: 7L0 907 379 G
   Component: ESP ALLRAD MK25     0203
   Coding: 0022786
   VCID: 3D7B9F88674FAAAAE2-515C
Address 05: Acc/Start Auth.        Labels: None
   Part No SW: 7L0 909 137 A    HW: 5WK 485 02
   Component: 29 Kessy            6700
   Revision: 67006015    Serial number: VWZ3Z0F6478811
   Coding: 0147688
   VCID: 3163B3B8AB175ECA76-5140
Address 06: Seat Mem. Pass        Labels: None
   Part No: 7L0 959 760
   Component: Sitzverstellung     0701
   VCID: 77F74DA005F340FAF8-5140
Address 08: Auto HVAC        Labels: 7L6-907-040.clb
   Part No: 7L6 907 040 T
   Component: CLIMAtronic R/L     4222
   Coding: 0020030
   VCID: 4183E3781BB7CE4A86-515C
   Component:                     3002
   Coding: 0110815
Address 11: Engine II        Labels: Redir Fail!
   Component: V10 5,0L EDCG001AGSª9805
   Coding: 0060575
   Part No: 3D0 909 601 H
   Component: 05 Airbag 8.4E++H01 0562
   Revision: BB38727     Serial number: 0008132:
   Coding: 0012341
   VCID: 28555EDC98CD1F02A1-5140
   Subsystem 1 - Part No: 7L0 959 339 C
   Component: BF-Gewichtsens. 006 0008
Address 16: Steering wheel        Labels: 7L6-953-549.lbl
   Part No: 7L6 953 549 H
   Coding: 0010032
   VCID: 448DEA6C04A5DB62AD-515C
Address 17: Instruments        Labels: 7L6-920-xxx-7LA.lbl
   Part No: 7L6 920 981 R
   Component: KOMBIINSTRUMENT RB8 3211
   Coding: 0005231
   VCID: 4895FE5C388DFF0241-5140
Address 18: Aux. Heat        Labels: 7L6-819-008.lbl
   Part No: 7L6 815 071 D
   Component: Standheizung E1MAC
   Coding: 0000100
   VCID: 336FB9B0510B6CDA04-5140
   Part No: 6N0 909 901
   Coding: 0000006
   Shop #: WSC 23342 444 84068
   VCID: 70E576BC609D17C239-5140
Address 1C: Position Sensing        Labels: 7L6-919-879.lbl
   Part No: 7L6 919 879 A
   Component: JCI PathPoint       2200
   VCID: 458BF7680F9FE26ABA-5140
   Part No: 0AD 927 755 AT
   Component: TRANSFERCASE        0114
   VCID: 0D1B0F48176F5A2AB2-5140
Address 34: Level Control        Labels: 7Lx-907-553-34.clb
   Part No: 7L0 907 553 H
   Component: LUFTFDR.-CDC- 3C3P1 3099
   Coding: 0015521
   VCID: 38758E9C486D8F8231-5140
   Component: Sitzverstellung     0703
   VCID: 77F74DA005F340FAF8-515C
Address 37: Navigation        Labels: 7L6-919-887-DVD.lbl
   Part No: 7L6 919 887 M
   Component:      Navigation     0047
   Coding: 0000101
   VCID: 50A5D63CC0DD37C219-5140
Address 46: Central Conv.        Labels: 7L0-959-933.lbl
   Part No: 7L0 959 933 H
   Component: YM HSG              0400
   Coding: 0000085
   VCID: 4183E3781BB7CE4A86-4B20
   Subsystem 1 - Part No: 7L0 959 701 H
   Component: Tuersteuergeraet FS 0201
   Subsystem 2 - Part No: 7L0 959 702 H
   Component: Tuersteuergeraet BF 0201
   Subsystem 3 - Part No: 7L0 959 703 D
   Component: Tuersteuergeraet HL 0201
   Subsystem 4 - Part No: 7L0 959 704 D
   Component: Tuersteuergeraet HR 0201
   Part No: 7L6 035 456
   Component: 08K Audioverst.     0105
   VCID: 70E576BC609D17C239-515C
   Subsystem 1 - Part No: 7L6 035 456
No Faults Found
   Coding: 0000003
   Coding: 00000034
   Coding: 00000255
Address 56: Radio        Labels: 7L6-035-186-DVD.lbl
   Part No: 7L6 035 186 E
   Component:        Radio        0047
   Coding: 0014042
   VCID: 356B87A85F7F72EA2A-515C
Address 68: Wiper Electr.        Labels: 7L0-955-119-V2.clb
   Part No: 7L0 955 119 K
   Component: Front Wiper         4027
   Coding: 0000341
   Shop #: WSC 31414 000 376832
   VCID: 3C7D928C7C55A3A2D5-5140
   Subsystem 2 - Part No: 1K0 955 559 T  Labels: 1K0-955-559-AF.CLB
   Component: RegenLichtSens 011  1110
   Coding: 00208933
   Shop #: WSC 31414
Address 69: Trailer        Labels: 7L0-907-383-1D2.lbl
   Part No SW: 7L0 907 383 G    HW: 7L0 907 383 G
   Component: ANHAENGERELEKTRONIK 8854
   Coding: 0000002
   VCID: 38758E9C486D8F8231-515C
   Part No SW: 7L6 907 441     HW: 7L6 907 441
   Component: J772__Rearview      0051
   Revision: 00H07000    Serial number:    PA8 J630434
   Coding: 0000101
   Shop #: WSC 31414 790 00001
   VCID: 72E17CB46E9125D2CF-515C
Address 6D: Trunk Elect.        Labels: 7L6-959-107.clb
   Part No SW: 7L6 959 107     HW: 7L6 959 107
   Component: J605  HECKKLAPPE    1110
   Revision: --H05---    Serial number: --------002637
   Coding: 0022110
Address 6E: Ctrl Head Roof        Labels: 7L6-919-044.lbl
   Part No: 7L6 919 044 T
   Component: DACHDISPLAY         0539
   Revision: 00900539    Serial number: 2009289.07
   Part No: 7L0 919 283 F
   Component: 0E Einparkhilfe     1107
   VCID: 39738B987367968ACE-5140
End-------------------------(Elapsed Time: 09:09)--------------------------
It still says:
Coding: 0000003
Coding: 00000034
Coding: 00000255
But none of the other errors are present.
Let me ask this, because I'm confused. If the module I installed were straight from the dealer and of non-questionable pedigree, would I have just been able to plug it all in and it would have recognized it already? I'm asking because if I am not there to change those values, what work is there in VCDS for me to accomplish?
I'm sorry to be so retarded but the wiki page for "02234 - Right Headlight Power Output Stage (J668)" isn't intuitive for me to follow as a newb to doing this.
Perhaps there's an easy, well documented project I could follow in order to gain some familiarity? The only thing I've played with is ditching the seat belt chime and the lawyers warning when turning on the NAV.
Other than that I've used VCDS to find busted crap, and there has never been a shortage of that.
NEtech
Denmark
C?ID=56995
You should use wiring diagram (erwin) and do measurements!
"Check Fuse(s)" (From Wiki, meaning: is there power)
4 pin connector pin 2, is there 12 volt capable of drawing amps
4 pin connector pin 4, is there ground capable of drawing amps
"Check/Repair Wiring from/to Right Headlight Power Output Stage (J668)" (From Wiki)
CAN connection are 100% okay, from 4 pin connector pin 3 / 1 to Headlight Range ECU 26 pin connector pin 5 / 4, via 2 connectors where there also can be a problem!
The other 4 pin connector should have only 3 wires (sensor)
The connector is 100% correct connected to power output stage ?
The pins in the connector are 100% okay ?
If the above is okay:
"Check/Replace Right Headlight Power Output Stage (J668)" (From Wiki)
Make a picture of the label from the old and the "new".
Flaps10
C?ID=219700
Of course no one noticed that the turbos aren't wheezed up in that scan.
:cry:
There wasn't anything wrong with the VW Touareg (7L) Headlight Aim Control (Xenon with AFS) page but it didn't include scan examples or stress the slave/subsystem communication. I grabbed #55 scan data from Uwe's (old) 2009 TDI and pasted it there so it looks more like the Passat/Golf based page.
Flaps10
C?ID=219700
