audi a4 8k steering controll long coding
raf0468
C?ID=120244
Hi have a a4 8k 2008, steering angle sensor was changed at some garage a while back with brand new one..
all is working apart from steering buttons for radio phone and display in speedometer from stalk,
steering control coding shows 000000, copied code from my b8 having cruise control coding 000017
this activated the buttons but glow-plug light came on throwing a code in engine ecu cruise control defective or similar..car does not have cruise control installed
can the coding be generated from auto scan..
thanks..
Friday,16,December,2016,14:48:50:29062
VCDS Version: 16.8.3.1
VIN: WAUZZZ8K89A043965   License Plate: AUDI A4 STEERING
Mileage: 175990km-109355mi   Repair Order:
Chassis Type: 8K (8T0)
Scan: 01 02 03 05 08 09 15 16 17 19 42 46 47 52 53 56 62 72 77
VIN: WAUZZZ8K89A043965   Mileage: 175990km-109355miles
Address 01: Engine (J623-CAGA)       Labels: 03L-906-022-CAG.clb
   Part No SW: 03L 906 022 JN    HW: 03L 906 022 B
   Component: R4 2,0L EDC   H01 3174
   Revision: 11H01---
   Coding: 0104002C02072018
   Shop #: WSC 06325 123 12345
   ASAM Dataset: EV_ECM20TDI03L906022JN A01004
   ROD: EV_ECM20TDI03L906022C.rod
   VCID: 7AFE7E4BFDAEDF92F2-802E
Address 02: Auto Trans (J217)       Labels: 0AW-927-156.clb
   Part No SW: 8K0 927 155 AF    HW: 0AW 927 156 G
   Component: 0AW 20TDI RdW H01 0007
   Revision: --H01---    Serial number: 0000000342
   Shop #: WSC 06325 000 00000
   ASAM Dataset: EV_TCMVL381 A02006
   ROD: EV_TCMVL381_AU57.rod
   VCID: 77F8677FCEBCC2FA8D-8022
Address 03: ABS Brakes (J104)       Labels: 8K0-907-379-V1.clb
   Part No SW: 8K0 907 379 AA    HW: 8K0 907 379 AA
   Component: ESP8 front    H04 0060
   Coding: 170500
   VCID: 78FA6443CBA2CD8284-802C
   Part No SW: 8K0 907 064 C    HW: 8K0 907 064 C
   Component: BCM2 1.1      H70 0134
   Coding: 011100
   VCID: 306A9C636352D5C20C-8064
   Subsystem 1 - Part No SW: 8T0 959 754 D    HW: 8T0 959 754 D
   Serial number: 0508000023794010
   Component: ELVAUDIB8  H35 0039
   Serial number: 0208000000565008
   Part No SW: 8T2 820 043 T    HW: 8T2 820 043 T
   Component: KLIMA 3 ZONEN H06 0140
   Revision: D1000000    Serial number: 0103.06.080614
   Coding: 34040000
   VCID: 4380C3AFC2E45E5AE1-8016
   Part No SW: 8K0 907 063 B    HW: 8K0 907 063 B
   Component: BCM1 1.0      H21 0253
   Revision: 03021001    Serial number: 00000000146069
   Coding: 690040B10034A7000001000300005F5F001D420800000141000000
   VCID: 2E56821B7966C3321E-807A
   Subsystem 1 - Part No SW: 8K2 955 119     HW: 8T2 955 119   Labels: 1KX-955-119.CLB
   Component: WWS 310508  H05 0060
   Serial number: SWFBIE 0000840
   Coding: 00FD11
   Component: RLS  H04 0003
   Serial number: 10149753
   Coding: 025028
   Subsystem 3 - Part No SW: 8K0 941 531 G    HW: 8K0 941 531 G
   Component: E1 - LDS  H07 0070
   Serial number: 00000000001106081142
Address 15: Airbags (J234)       Labels: 8K0-959-655.clb
   Part No SW: 8K0 959 655 B    HW: 8K0 959 655 B
   Component: AirbagVW-AU10 H26 0410
   Serial number: 0038JD169N62
   Coding: 30363434363030303030554A3052384B3053
   VCID: 3C72B853B71A21A2A0-8068
   Serial number: 6334MSME392504084
   Serial number: 6344MSME3903204A5
   Serial number: 6352QSME6A6B0B2F
   Serial number: 6362QSME720814617
   Serial number: 63732SME57293413X
   Serial number: 63832SME5729070B+
   Part No SW: 8K0 953 568 M    HW: 8K0 953 568 M
   Revision: --------    Serial number: 90372NDM0009X
   VCID: 4482C0B3C7EA5962D8-8010
            000 -  -
                    Reset counter: 39
                    Mileage: 175990 km
                    Date: 2016.12.16
                    Time: 14:30:05
00895 - Cruise Control Switch (E45)
                    Fault Status: 01101000
                    Reset counter: 39
                    Mileage: 175990 km
                    Date: 2016.12.16
                    Time: 14:40:02
Address 17: Instruments (J285)       Labels: 8T0-920-xxx-17.clb
   Part No SW: 8K0 920 980 B    HW: 8K0 920 980 B
   Component: KOMBIINSTR.   H16 0221
   Revision: 00200000    Serial number: 99527DC68
   Coding: 2F06080002002600010000
   VCID: 316C99676858DCCA03-8064
   Part No SW: 8T0 907 468 H    HW: 8T0 907 468 H
   Component: GW-BEM 5CAN   H06 0091
   Revision: GB102039    Serial number: 3900G08524827C
   Coding: 000303
   VCID: 4686DABBF1D66B72C6-8012
   Subsystem 1 - Part No SW: 8K0 915 181 B    HW: 8K0 915 181 B
   Component: J367-BDM  H04 0150
   Serial number: 18021EAD220508
            000 -  -  - Intermittent
                    Reset counter: 79
                    Mileage: 175990 km
                    Date: 2016.12.16
                    Time: 14:30:00
Address 42: Door Elect, Driver (J386)       Labels: 8K0-959-793.clb
   Part No SW: 8K0 959 793 C    HW: 8K0 959 793 A
   Component: TSG FA        H10 0170
   Revision:             Serial number: 0000007298653
   Coding: 011002204001410001
   VCID: 408ACCA3D3F24542FC-8014
   Revision: 00002001    Serial number: 0112116182
   Coding: 011B062200390400002001
Address 47: Sound System (J525)       Labels: 8T0-035-223-ASC.clb
   Part No SW: 8T0 035 223 AB    HW: 8T0 035 223
   Component: DSP STD       H07 0220
   Revision: S1900000
   Coding: 0203010102
   VCID: 6ED6421BB9E683325E-803A
   Part No SW: 8K0 959 792 C    HW: 8K0 959 792 A
   Component: TSG BF        H10 0170
   Revision:             Serial number: 0000007256446
   VCID: 3F88CF5FAE0C3ABA85-806A
   Part No SW: 8K0 907 801 E    HW: 8K0 907 801 E
   Component: EPB Audi B8   H05 0060
   Revision: 00000003    Serial number: 00000000146554
Address 56: Radio (J503)       Labels: 8Tx-035-1xx-56.clb
   Part No SW: 8T2 035 186 C    HW: 8T2 035 186 C
   Component: Concert3      H01 0210
   Revision: 00000003    Serial number: AUZ5Z6H1075605
   Coding: 0502008201018D000359070000
   VCID: 387AA4438B220D8244-806C
   Subsystem 1 - Part No SW: 8T0 919 603 A    HW: 8T0 919 603 A
   Component: Display
Address 62: Door, Rear Left (J388)       Labels: 8K0-959-795.clb
   Part No SW: 8K0 959 795 A    HW: 8K0 959 795 A
   Component: TSG HL        H06 0170
   Revision:             Serial number: 0000100047433
   Coding: 010002204001210001
Address 72: Door, Rear Right (J389)       Labels: 8K0-959-794.clb
   Part No SW: 8K0 959 794 A    HW: 8K0 959 795 A
   Component: TSG HR        H06 0170
   Revision:             Serial number: 0000100049959
   Part No SW: 8T0 862 335 A    HW: 8T0 862 335 A
   Component: FSE_256x BT     H33 0520
   Revision: 00000000    Serial number: 00000005008855
   Coding: 0010320
   VCID: 387AA4434B220D8244-806C
End-------------------------(Elapsed Time: 02:59)--------------------------
raf0468
C?ID=120244
when i get back to the car ill take a picture ..thanks
raf0468
C?ID=120244
here is sticker from car...
Try coding: 000200
raf0468
C?ID=120244
ok was back at the car ..correct coding was 000012
coding 000200 would bring up error message "coding out of range"
thanks all..
