GERMAN TEXT
senna1
C?ID=231631
Hi
I ran vcds today regarding a fan temp issue, and 2 issues the first the info half of it was looks German which i dont read or speak the second was the coolant temp outlet G83 was displaying minus - 40.5 D/c
The engine ecu temp G62 was reading sensible reading of 69 D/c
I have readings of outlet temp from other vehicle using vcds and they are in English, No fault listed for the outlet temp sensor of -40.5D/c which i know i have a problem as the fan is not being triggered (brand new sensor ) can these sensor be tested based on resistance to temp. all the wiring checks out for continuity & power inc earth. i have not checked ecu wire,
Thursday,15,December,2016,15:54:22:46146
VCDS Version: 16.8.4.2 (x64)
VIN: License Plate: 2010
Address 01: Engine (03G 906 016 LF)
15:53:59 Group 064: Engine Cooling
85.5°C Kühlmitteltemp. Motoraustritt
-40.5°C Kühlmitteltemp. Kühleraustritt
10.0 % Coolant Fan 1 Duty Cycle
15:53:59 Group 002: Idle Speed
1533 /min Engine Speed (G28)
12.2 % Accel. Pedal Pos. Sensor 1 (G79)
0 00 0 Operation Status
85.5°C Coolant Temperature (G62)
Confirmed, someone didn't translate a few things in 03G-906-016-BDJ....
Kühlmitteltemp = Coolant Temperature
Motoraustritt = Engine Outlet
Kühleraustritt = Radiator Outlet
The -40.5 °C is an indication that the sensor is open circuit, or perhaps that the car in question simply doesn't have a temperature sensor at the radiator outlet.
senna1
C?ID=231631
Full autoscan, The radiator fan outlet temp is Brand new, The Van is a o8 build, with 2010 ecu and instrument cluster and wiring list G83 sensor not f18 , & NO AIRCON
Thursday,15,December,2016,14:53:01:46146
VIN: WV1ZZZ2KZAX106915   License Plate: 2008/10
Mileage: 223260km-138727mi   Repair Order: thursday test fan
Chassis Type: 2K (1K0)
Scan: 01 03 09 15 16 17 19 25 42 46 52 56
VIN: WV1ZZZ2KZAX106915   Mileage: 223260km-138727miles
Address 01: Engine        Labels: 03G-906-016-BDJ.clb
   Part No SW: 03G 906 016 LF    HW: 03G 906 016 DR
   Component: R4 2,0L EDC 0000SG  2977
   Revision: 12345678    Serial number: VWX7Z0J23N702G
   Coding: 0003031
   Shop #: WSC 35110 377 00155
   VCID: 72EBF6F26D1B63D2CF-8026
16486 - Mass Air Flow Sensor (G70)
            P0102 - 000 - Signal too Low
                    RPM: 924 /min
                    Torque: 83.0 Nm
                    Duty Cycle: 96.0 %
                    Bin. Bits: 11000100
                    Mass Air / Rev.: 650.0 mg/str
                    Mass Air / Rev.: 0.0 mg/str
   Part No: 1K0 907 379 P
   Coding: 0017106
   Shop #: WSC 35110 377 00156
   VCID: 3F8D6FC66EC9FEBAF0-806A
Address 09: Cent. Elect.        Labels: 3C0-937-049-30-M.lbl
   Part No SW: 3C0 937 049 AH    HW: 3C0 937 049 AH
   Revision: 00H54000    Serial number: 01000007988820
   Coding: 00884F030004100047000000000000000008FB075C000100000000000000
   Shop #: WSC 35110 377 08192
   VCID: 6FEDFF867E294E3A20-803A
   Subsystem 1 - Part No: 2K2 955 119 B  Labels: 1KX-955-119.CLB
   Component: Wischer VW357  012  0402
   Coding: 00065493
   Shop #: WSC 35110
                    Fault Status: 01101100
                    Reset counter: 110
                    Mileage: 223269 km
                    Date: 2005.09.13
                    Time: 31:63:63
                    Voltage: 13.75 V
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 09 AIRBAG VW52  023 2400
   Revision: 04023000    Serial number: 0037TD0HHYVM
   Coding: 0012345
   VCID: 7DF1D5CE24452CAAA2-8028
   Part No SW: 1K0 953 549     HW: 1K0 953 549
   Component: Lenksäulenmodul 012 0030
   Coding: 0000002
   Part No SW: 2K0 920 944 C    HW: 2K0 920 944 C
   Component: KOMBIINSTRUMENT VDD 1222
   Revision: V0002000    Serial number: VWX7Z0J23N702G
   Coding: 0016401
   VCID: 2C57288A8FBF752245-8078
   Revision:   H07 01    Serial number: 120208F2001591
   Coding: 89801F020002027401
   VCID: 306F3CFAA39711C279-8064
                    Fault Frequency: 90
                    Reset counter: 150
                    Mileage: 223269 km
                    Time: 13:20:28
   Component: IMMO            VDD 1222
Address 42: Door Elect, Driver        Labels: 1K0-959-793.lbl
   Part No: 1K0 959 793
   Component: Tuersteuergeraet 02 0160
   Coding: 0000000
   VCID: 76E3CAE201737FF2E3-8022
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 CP
   Coding: 008A0C087F2D84054858030000C0
   VCID: 000FAC3A53B74142C9-8054
Address 52: Door Elect, Pass.        Labels: 1K0-959-792.lbl
   Part No: 1K0 959 792
   Coding: 0000000
   VCID: 75E1CDEE1C7574EAEA-8020
   Part No SW: 1K0 035 186 AA    HW: 1K0 035 186 AA
   Component: Radio RCD310  016 0049
   Revision: 00000000    Serial number: VWZ1Z2K8066632
   Coding: 0000020001
   VCID: 65C19DAE6CD5846A5A-8030
                    Reset counter: 150
                    Mileage: 223269 km
                    Time: 20:57:23
                    Reset counter: 150
                    Mileage: 223269 km
                    Time: 20:58:10
                    Reset counter: 71
                    Mileage: 72384 km
                    Time: 00:28:31
End-------------------------(Elapsed Time: 01:15)--------------------------
senna1
C?ID=231631
FULL AUTOSCAN
senna1
C?ID=231631
Uwe.
Can you see any issues that might not be correct in the autoscan,, It has label files for the engine i'm working with.
Can a resistance test be done on the G83 although it is new? I may try another ecu not coded to this cluster immob, just to see with ignition on if the values change for the G83, The wiring has no open circuit, so sensor fault or some coding issue from the 2010 ecu.
The Gate way all seems right,
