MultiFunction Steering Wheel octavia 2
mikutzu99
Romania
C?ID=277394
Hello, i have a steering wheel without commands and i want to put a steering wheel with controls ,commands, you have to change the control Steering wheel module. donor car is Octavia 2.0 TDI 6-speed of 2007. You think that i need anything else to change? :confused:
Tuesday,22,November,2016,17:08:08:14813
VCDS Version: 16.8.3.1 (x64)
VIN: TMBCS41ZX62232467   License Plate: PH 27 BBU
Mileage: 434570km-270029mi   Repair Order: 1
Chassis Type: 1Z (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 55 56 7D
VIN: TMBCS41ZX62232467   Mileage: 434570km-270029miles
56-Radio -- Status: Sporadic communication error 1000
Address 01: Engine        Labels: 03G-906-016-BKC.lbl
   Part No SW: 03G 906 016 DJ    HW: 028 101 188 3
   Component: R4 1,9L EDC G000SG  6250
   Revision: 12345678    Serial number: SKZ7Z0F3464767
   Coding: 0050071
   Shop #: WSC 73430 790 00000
   VCID: 6ED3BAED79AED8325E-803A
17057 - Cylinder 3 Glow Plug Circuit (Q12)
            P0673 - 000 - Electrical Fault - Intermittent
                    Torque: 134.0 Nm
                    Voltage: 12.08 V
                    Bin. Bits: 00001100
                    Temperature: 4.5°C
                    Bin. Bits: 00110000
   Part No SW: 1K0 907 379 AA    HW: 1K0 907 379 AA
   Revision: 00H13001
   Coding: 0021633
   VCID: 71E9A1916890C7CA43-8024
   Part No: 1Z0 820 047 D
   Component: Climatic PQ35   010 0301
   VCID: 346768855702B2E268-8060
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-M.lbl
   Part No SW: 3C0 937 049 D    HW: 3C0 937 049 D
   Revision: 00H37000    Serial number: 00000003938751
   Coding: 00020E131004140000110D000000000000097B065C
   Shop #: WSC 73430 790 12345
   VCID: 2A5B76FD85C6F412C2-807E
   Subsystem 1 - Part No: 1Z1 955 119 A  Labels: 1KX-955-119.CLB
   Component: Wischer SK351  012  0401
   Coding: 00065525
   Shop #: WSC 73430
Address 15: Airbags        Labels: 6Q0-909-605-VW52.lbl
   Part No SW: 6Q0 909 605 AH    HW: 6Q0 909 605 AH
   Component: 07 AIRBAG VW52  025 2400
   Revision: 06025000    Serial number: 0037TR0AJVEB
   Coding: 0012343
   Shop #: WSC 10200 599 94742
   VCID: 7DF18DA124C8B3AAD7-8028
   Part No SW: 1K0 953 549 AF    HW: 1K0 953 549 AF
   Component: Lenksäulenmodul 034 0070
   Coding: 0000042
   VCID: 76E3928D01FEE0F296-8022
   Part No: 1Z0 920 841 E
   Component: KOMBIINSTRUMENT VD1 0920
   Coding: 0004101
   Shop #: WSC 12345 012 32131
   VCID: 387F5CB54B6A568244-806C
Address 19: CAN Gateway        Labels: 1K0-907-530-V1.clb
   Part No SW: 1K0 907 530 F    HW: 1K0 907 951
   Component: Gateway         H10 0120
   Revision:   H10       Serial number: 28001062030391
   Coding: 7D0F0B40071302
00469 - Infotainment Databus in Single Wire Operation
                    Fault Frequency: 16
                    Reset counter: 206
                    Mileage: 434198 km
                    Time: 17:56:58
                    Fault Frequency: 170
                    Reset counter: 246
                    Mileage: 434198 km
                    Time: 18:21:53
01304 - Radio
                    Fault Frequency: 166
                    Reset counter: 246
                    Mileage: 434198 km
                    Time: 18:21:55
   Component: IMMO            VD1 0920
   Part No: 1T0 959 701 B
   Component: Tuer-SG         024 2345
   Coding: 0000244
   VCID: 3663528D417EA0F256-8062
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 000    3305
   Revision: 00H22000
   VCID: 377D5F89467459FA4D-8062
Address 46: Central Conv.        Labels: 1K0-959-433-MIN.clb
   Part No: 1K0 959 433 AK
   Coding: 18D002407F2D0F0FC84BC61004CC
   VCID: 79F999B130E08F8AFB-802C
   Subsystem 5 - Part No: 1Z0 951 171 A
   Component: NeigungsSensor  008 4802
   Coding: 00000000
   Subsystem 6 - Part No: 1K0 951 605 D
   Component: LIN BACKUP HORN H08 9001
   Subsystem 7 - Part No: 1Z0 951 171 A
   Component: Innenraumueberw.008 4802
   Part No: 1T0 959 702 B
   Coding: 0000244
00121 - Outside Warning Light/Door exit Light Passenger Side
   Part No: 1T0 907 357
   Coding: 0000007
   VCID: 74E7A8851782F2E2A8-8020
   Part No SW: 1Z0 035 161 B    HW: 1Z0 035 161 B
   Component: Radio FO3       013 0029
   Revision: 00013000    Serial number: SKZ7Z3F0121543
   Coding: 0000200
   Shop #: WSC 10112 599 82830
   VCID: 2D517DE1B428E32A27-8078
Address 7D: Aux. Heat        Labels: 1K0-963-235.lbl
   Part No SW: 1K0 963 235 E    HW: 1K0 963 235 E
   Component: PTC-Element         0404
   Revision: 00800000    Serial number:
End-------------------------(Elapsed Time: 01:35)--------------------------
mikutzu99
Romania
C?ID=277394
please help me!!
