- Aug 25, 2015
- 47
- 16
- Birmingham, England
- C?ID=253973
Feed with some idea's what can be done to it through VCDS
I have done first scan and saved it for future reference. So far I have activated secret menu, battery info and lap timer but when I go to vehicle DIS I don't see battery info nor lap timer option. Can anyone help. Also I can change the splash screen through secret menu but there is no option to apply it. Does it mean I can't change MMI screen when it loads up
Here is the scan:
Here is the scan:
Chassis Type: 4G (4G0)
Scan: 01 02 03 05 08 09 10 15 16 17 19 36 3B 42 44 46 52 53 55 56
5F 62 6C 72
VIN: -------------------- Mileage: 82679km-51374miles
Address 01: Engine (J623-CDUC) Labels: 059-907-401-V2.clb
Part No SW: 4G0 907 401 F HW: 4G0 907 401
Component: 3.0TDI EDC17 X37 0004
Revision: 53X37---
Coding: 0A254012052601020000
Shop #: WSC 92521 052 00000
ASAM Dataset: EV_ECM30TDI0114G0907401F 001004
ROD: EV_ECM30TDI0114G0907401F.rod
VCID: 2643A6A259844272EE-8072
Address 02: Auto Trans (J217) Labels: 0B5-927-156.clb
Part No SW: 4G1 927 156 B HW: 0B5 927 156 F
Component: 0B5 30 TDIRdW H10 0001
Revision: --H10--- Serial number: 0000001340
Shop #: WSC 02311 785 00200
ASAM Dataset: EV_TCMDL501 A02087
ROD: EV_TCMDL501.rod
VCID: 2C57548A4768782238-8078
Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
Part No SW: 4G0 907 379 F HW: 4G0 907 379 F
Component: ESP PREMIUM H09 0250
Coding: 27A68701E465E180DB00
Shop #: WSC 02391 785 00200
ASAM Dataset: EV_ESPPremiAU57X 004017
VCID: 34674CEA9F5820E260-8060
Address 05: Acc/Start Auth. (J393) Labels: 8K0-907-064-05.clb
Part No SW: 4H0 907 064 BP HW: 4H0 907 064 BP
Component: BCM2 2.0 H31 0333
Coding: 05B82F06000000000000
VCID: 78FFB8DACBB004828C-802C
Component: J764 ELV MLB H39 0046
Serial number: 2311000236227013
Address 08: Auto HVAC (J255) Labels: 4G0-820-043-2Z.clb
Part No SW: 4G0 820 043 H HW: 4G0 820 043 H
Component: KLIMA 2 ZONEN H10 0062
Serial number: 24101100040370
Coding: 3621000820
ASAM Dataset: EV_AirCondiBasisUDS 002037
ROD: EV_AirCondiBasisUDS_002.rod
VCID: 2447BCAA2FB8B062F0-8070
Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
Part No SW: 4H0 907 063 BF HW: 4H0 907 063 F
Component: BCM1 2.0 H12 0100
Revision: 20012002 Serial number: 00000001095564
Coding: 2600201040349FE00181008380001D0C0F9DC30827090101000004602100
VCID: 6DD1998EB4F2B12A6F-8038
Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
Component: WWS57X 110909 H35 0051
Serial number: 110922020435
Coding: 0045F7
Subsystem 2 - Part No SW: 8K0 955 559 HW: 8K0 955 559 Labels: 8K0-955-559.CLB
Component: RLS H04 0003
Serial number: 11726788
Coding: 02512B
Subsystem 3 - Part No SW: 4G0 941 531 AL HW: 4G0 941 531 AL
Component: E1 - LDS H07 0044
Serial number: 05 08 2015 00000345
Subsystem 4 - Part No SW: 4G0 907 658 A HW: 4G0 907 658 A
Component: Humidity_Sens H02 0002
Serial number: 252843D5000000000001
Address 10: Park/Steer Assist (J446) Labels: 4H0-919-475-7X2.clb
Part No SW: 4H0 919 475 N HW: 4H0 919 475 C
Component: PARKHILFE ACC H07 0050
Revision: 11001001 Serial number: 55901127401046
Coding: 280106
ASAM Dataset: EV_EPHVA18AU57X0000 002005
ROD: EV_EPHVA18AU57X0000.rod
VCID: 3D7169CEAC12E1AA9F-8068
Address 15: Airbags (J234) Labels: 4H0-959-655.clb
Part No SW: 4H0 959 655 C HW: 4H0 959 655 C
Component: Airbag10.43 H40 0040
Revision: -------- Serial number: 003JG004YW4Q
Coding: 30323436313330303537554A305234473053
ROD: EV_AirbaAU10BPAAU64X_AU57.rod
VCID: 366376E2892432F25E-8062
Serial number: 3575HRB405J0SM2ME18S
Serial number: 3585HRB40590SM2O5PE%
Serial number: 3515JRB40510Q8K4A16R
Serial number: 3525JRB405R0Q8K47OVD
Serial number: 3554VRB40510ODIIAPLA
Serial number: 3564VRB40510ODII719F
Address 16: Steering wheel (J527) Labels: 4H0-953-568.clb
Part No SW: 4G0 953 568 A HW: 4G0 953 568 A
Component: Lenks.Modul H05 0201
Revision: 00000000 Serial number: 20111022000145
Coding: 000034
VCID: 306F40FA63401CC204-8064
Subsystem 1 - Part No SW: 4G0 951 528 A HW: 4G0 951 528 A
Component: E221 - MFL H08 0009
Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
Part No SW: 4G8 920 981 S HW: 4G8 920 981 S
Component: TDieGb H79 0375
Revision: 26181120 Serial number: 658191011591003
Coding: 33A708000B010600010000
ASAM Dataset: EV_RBD4K 004040
ROD: EV_RBD4K.rod
VCID: 43851F36CAF6975AE9-8016
Address 19: CAN Gateway (J533) Labels: None
Part No SW: 4G0 907 468 E HW: 4G0 907 468 A
Component: J533--Gateway H08 0213
Revision: -------- Serial number: 00000000280459
Coding: 00CD077D00
ROD: EV_GatewUDS_AU57.rod
VCID: 326B4AF2654C2ED272-8066
Subsystem 1 - Part No SW: 8X0 915 181 HW: 8X0 915 181
Component: J367-BDM H07 0141
Serial number: 00000000003790807577
Voltage stabilizer:
0267 - Optical data bus
U1049 00 [008] - Open circuit
Reset counter: 88
Mileage: 82421 km
Date: 2016.12.02
Time: 09:42:03
Voltage terminal 30: 12.0 V
Voltage terminal 15: 0.0 V
Control Module temperature: 16 °C
System status: Awake_Timer_active
Engine running: OFF
IN ZAS_Te_X: OFF
Terminal 15 status via CAN: OFF
Terminal 15 status: OFF
Datenfeld: 0
U140B 00 [008] - -
Reset counter: 88
Mileage: 82421 km
Date: 2016.11.29
Time: 02:58:59
Voltage terminal 30: 12.3 V
Control Module temperature: -2 °C
IN ESP_standstill flag: no standstill detected
Engine running: OFF
IN ZAS_Te_X: OFF
Datenfeld: 1
Component: MEM-FS H03 0154
Revision: AA000000 Serial number: 00000015433347
Coding: 00781B0000006001000001010101102030303232203232
VCID: 77FDBBE6C6AE0BFA85-8022
Part No SW: 4G0 907 637 HW: 4G0 907 637
Component: SARA 3D H02 0004
Revision: -------- Serial number: EJ1BPA3200NYZ50
ASAM Dataset: EV_SARA 006014
ROD: EV_SARA_006.rod
VCID: 6BD5979682E6BF1A71-803E
Address 42: Door Elect, Driver (J386) Labels: None
Part No SW: 4G8 959 793 E HW: 4G8 959 793 A
Component: TSG FA H05 0212
Coding: 011C16205E01620002080002
Shop #: WSC 02312 785 00200
VCID: 428B1A32DDEC9E52E2-8016
Address 44: Steering Assist (J500) Labels: None
Part No SW: 4G0 909 144 L HW: 4G0 909 144 G
Component: RCEPS H35 0010
Revision: 00001000 Serial number: 0006189314
Coding: 101000010000
ASAM Dataset: EV_RCEPS 009008
ROD: EV_RCEPS_009_AU57.rod
Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
Revision: 00002001 Serial number: 0160786197
Coding: 011B0E2200B9048183200800000100000000000000000000000000000000
Subsystem 1 - Part No: 4G0 951 177
Component: DWA-Sensor H01 0010
Address 52: Door Elect, Pass. (J387) Labels: None
Part No SW: 4G8 959 792 E HW: 4G8 959 792 A
Component: TSG BF H05 0212
VCID: 4189153ED8EA854AFB-8014
Part No SW: 4H0 907 801 E HW: 4H0 907 801 A
Component: EPB-4 H03 0012
Revision: -------- Serial number: 00000000163118
ROD: EV_ParkiBrake_AU57.rod
VCID: 2A5B52924D9C6612CA-807E
Address 55: Headlight Range (J431) Labels: 8X0-907-357.clb
Part No SW: 4H0 907 357 A HW: 4H0 907 357 A
Component: ....LWR12.... H02 0013
Serial number: 111020-0004-085
Coding: 1121A6101000A300
ROD: EV_HeadlRegulBasic.rod
Part No SW: 4G0 035 056 C HW: 4G0 035 056
Component: Radio U STD H52 0079
Revision: AB001007 Serial number: 051JY0B7544128
Coding: 010003020100000001
VCID: 2149B5BE38AAA54A9B-8074
Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
Part No SW: 4G0 035 670 E HW: 4G0 035 670
Component: H-BNT-EU H47 0410
Revision: -------- Serial number: 428J50B7524929
Coding: 050101000003A1EF45008B3E00000003000001000000000000
VCID: 2541A1AE2C82496AE7-8070
Subsystem 1 - Part No: 8R0 060 884 N
Component: EUR 2011 1205
Subsystem 2 - Part No SW: 4G0 919 605 A HW: 4G0 919 605 A
Component: DU8 C7 SV H42 0021
Serial number: AUZ8ZDB1301U7V0
Subsystem 3 - Part No SW: 4G2 919 610 A HW: 4G2 919 610 A
Component: E380 BDT C7 H08 0203
Serial number: 90349KJK00025
Component: CD-Database 3371
02067 - Optical Databus; Unpermitted Wake-Up Request
Reset counter: 88
Mileage: 82421 km
Date: 2016.12.02
Time: 09:39:20
Voltage: 12.00 V
Address 62: Door, Rear Left (J388) Labels: None
Part No SW: 4G8 959 795 E HW: 4G8 959 795 A
Component: TSG HL H04 0212
Coding: 010814204001620002080002
VCID: 44871C2AC7F89062D0-8010
Address 6C: Back-up Cam. (J928) Labels: None
Part No SW: 4H0 907 428 HW: 7P6 907 441 D
Component: TopView H05 0090
Revision: 11001001 Serial number: 82330JF0013479
Coding: 0200000001000100000102000000
Shop #: WSC 02314 785 00200
ASAM Dataset: EV_CamerSysteTopViewAUDI 003019
ROD: EV_CamerSysteTopViewAUDI_003.rod
VCID: 6ADB92928D1CA6120A-803E
Address 72: Door, Rear Right (J389) Labels: None
Component: TSG HR H04 0212
End-------------------------(Elapsed Time: 04:38)--------------------------
