Micro-CAN not communicating with all modules - 2013 Jetta Hybrid
boeingpilot
C?ID=133852
Greetings
Courtesy of 'dieselgate' I've switched from my '09 TDI to a '13 Jetta Hybrid. Looking to set a baseline (for any potential issues) and also to see if I could change some coding in the RNS315, I ran an auto-scan of the vehicle
Noticed quite a few modules come back as unreachable (eg engine!!).
Could you advise if VCDS supports the Jetta Hybrid? Am I doing something wrong? Never had any issues with the Micro-CAN on my TDI or my friend's Golf R
Thanks in advance
Sunday,04,December,2016,12:39:10:22835
VCDS -- Windows Based VAG/VAS Emulator Running on Windows 7 x64(Parallels)
VCDS Version 16.8.4.2 (x64)
VIN: 3VW637AJ6DM30XXXX   License Plate: GWBXXXX
Mileage: 8184   Repair Order: nonw
Chassis Type: AJ (7N0)
Scan: 01 02 03 05 08 09 15 16 17 19 25 2B 2E 37 42 44 46 47 4F 51
          52 55 56 61 62 72 8C
Address 01: Engine
   Part No SW: 0CG 300 045 F    HW: 0AM 927 769 H
   Component: GSG DSG AG7     431 5307
   Revision: 00043014    Serial number: CU501301215272
   Shop #: WSC 51784 000 1048576
   VCID: 2C79D3628F52042245-8079
   Part No SW: 1K0 907 379 AR    HW: 1K0 907 379 AR
   Component: ESP MK60EC1   H31 0135
   Revision: 00H31001
   Coding: A14B400C492220FC850E02E7921A0440A71800
   Shop #: WSC 00066 000 00000
   VCID: 02255DDA9D562252DF-8057
Address 05: Acc/Start Auth.
Address 08: Auto HVAC
   Part No SW: 5K0 937 086 N    HW: 5K0 937 086 N
   Component: BCM PQ35 M    021 1068
   Revision: BJ021001
   Coding: 6F200A1A912F06C40088088100000D4C0104000844808DB0E4842600A043
   VCID: 3FA3942EAE248FBAF0-806B
            000 -  -  - Intermittent
                    Reset counter: 66
                    Mileage: 12695 km
                    Date: 2039.14.02
                    Time: 15:21:08
                        Term 15 Off
                    Voltage: 12.15 V
Address 15: Airbags
Address 16: Steering wheel
Address 17: Instruments
   Part No SW: 7N0 907 530 AH    HW: 7N0 907 530 AH
   Component: J533  Gateway H50 1634
   Revision:   H50       Serial number: 25041303290263
   Coding: 351002
   VCID: 76CD310AC19E0EF2E3-8023
Address 25: Immobilizer
Address 2B: Steer. Col. Lock (J764)       Labels: 5K0-905-861.clb
   Revision: 00000000    Serial number: 13000024494002
   Coding: 4900000000000000
   Shop #: WSC 00066 790 50316
   ROD: EV_ELVMarquMPVW36X.rod
   VCID: 3041C7126B7A60C279-8065
   Component: SG EXT.PLAYER H19 0550
   Revision: A1001003    Serial number: 7664395288
   Coding: 020100
   VCID: 2A75D57A45A61A12B7-807F
Address 37: Navigation
   Component: TUER-SG FT    002 0515
   Revision: 13110009    Serial number: 0006621503
   Coding: 0004B5
   Shop #: WSC 01383 790 50316
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 5B9B40BE527CB39AFC-800F
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703 C    HW: 3C0 959 795 D  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  008 1508
   Serial number: 00000007609768
   Coding: 000490
   Part No: 1K0 909 144 P
   Component: EPS_ZFLS Kl. 69     3305
   Revision: 00H22000
   Shop #: WSC 02069 000 90108
   VCID: 3753FC0E4614B7FA38-8063
Address 47: Sound System
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AH
   Component: EZE_2         H50 1634
   Coding: 01030100
   VCID: 6FC3046EBEC43F3A20-803B
   Subsystem 1 - Part No SW: 5K0 959 591     HW: 5K0 959 591
   Component: J245 PS41.022  H10 0007
   Serial number:     WRH0008JGS+
   Coding: 180000
   Part No SW: 5C0 907 080 E    HW: 5C0 907 080 E
   Component: VW361H0108000 H02 0535
   Revision: 00H02000    Serial number: 00000000000000
   Coding: 40020000000000000000
   Shop #: WSC 00066 000 00190
   ASAM Dataset: EV_DMCM04510115C0907080E 001021
   ROD: EV_DMCM04510115C0907080E.rod
   VCID: 256F264624B8356A9A-8071
Address 52: Door Elect, Pass.
Address 55: Headlight Range
Address 56: Radio
   Part No SW: 7N0 907 534     HW: 7N0 907 530 AH
   Component: Batt.regelung H50 1634
   Coding: 16667164
   VCID: 71C70216A8F029CA36-8025
   Subsystem 1 - Part No SW: 1S0 915 181 A    HW: 1S0 915 181 A
   Component: J367-BDM  H08 0181
   Serial number: 60079447362180288390
   Part No SW: 5C6 915 182 B    HW: 5C6 915 182 B
   Component: BECM          H09 0601
   Serial number: 288 SYER115B30
   ASAM Dataset: EV_BECM06020115C6915182 005021
   ROD: EV_BECM06020115C6915182_VW32.rod
   VCID: 2A75D57A4DA61A12B7-807F
End-------------------------(Elapsed Time: 02:02)--------------------------
Please try running Windows natively, either on a real PC or via Bootcamp. Running VCDS in a VM is explicitly not supported.
boeingpilot
C?ID=133852
Andy reached out to me also via email (Thanks!!). I've been running VCDS for so long on Parallels, didn't even think of it as a consideration. But.... point taken. I'll find my old netbook and load it up and advise if we're good or not. Strange though, first time I've ever had an issue.
Regards
Scott
Spacewalker
Poland
C?ID=159607
Some time when I do autoscan and try to clear all DTC's .....VCDS telling me GATEWAY Not support it .
After ignition OFF and ON - possible
