MK5 Golf GTI headlights not focusing properly after installation.
NitrousOxide
Jamaica
C?ID=269481
Greetings,
My car came with aftermarket headlights. I ordereed some OEM-like DEPO replacements (with the auto-leveling motors). I installed the pair and attempted to calibrate the beam in VCDS. I keep getting the error code below. I checked the new wiring for electrical faults and ensured that all the bulbs work. I can't perform the adaptation in VCDS as pictured below. I just wanted to know the troubleshooting steps to be taken here.
Wednesday,30,November,2016,19:32:46:39976VCDS -- Windows Based VAG/VAS Emulator Running on Windows 10 x64
VCDS Version: 16.8.3.1 (x64)
Dealer/Shop Name: Matthew Taylor
VIN: WVWZZZ1KZ8W111078   License Plate:
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 4F 52 55 56 65
VIN: WVWZZZ1KZ8W111078   Mileage: 155680km-96735miles
65-Tire Pressure -- Status: Cannot be reached 1100
Address 01: Engine        Labels: 06F-907-115-AXX.clb
   Part No SW: 1K0 907 115 R    HW: 8P0 907 115 B
   Revision: 5BH16---    Serial number: VWX7Z0G83NA8OV
   Coding: 040300101C070060
   Shop #: WSC 66565 257 00032
   VCID: 354FD8585CDD5EEA5F-8060
000256 - Mass Air Flow Sensor (G70)
               P0100 - 004 - Supply Voltage
000054 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
               P0036 - 004 - Malfunction / Open Circuit
Readiness: 0110 0101
   Part No SW: 02E 300 044 J    HW: 02E 927 770 AD
   Component: GSG DSG         082 1407
   Revision: 04808020    Serial number: 00000907050136
   Shop #: WSC 09537 809 89632
   VCID: 1C192DFCDF37EFA240-8048
   Revision: 00H11001
   Coding: 0021122
   VCID: 73CB2640122900DAB1-8026
            013 - Check DTC Memory
   Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
   Component: ClimatronicPQ35 120 1111
   Revision: 00120021    Serial number: 00000000000000
   VCID: 79D7146830457A8AFB-802C
00229 - Refrigerant Pressure
            002 - Lower Limit Exceeded
   Revision: 00H54000    Serial number: 01000007456322
   Coding: E70E8A0F000414004F14000414000080800900005C100100000000000000
   VCID: 71C72C48683532CA43-8024
   Component: Wischer 300807 021  0501
   Coding: 00038805
   Shop #: WSC 12345
   Component: RLS     130907 046  0204
   Coding: 00221517
   Shop #: WSC 12345
00924 - Relay for Headlamp Cleaning System (J39)
            009 - Open or Short to Ground
   Component: 3A AIRBAG VW8   020 2300
   Revision: 05020000    Serial number: 0038PD1FKU0T
   Coding: 0013121
   Shop #: WSC 01269 785 00200
   VCID: 3D5FC07864ED86AA97-8068
   Subsystem 1 - Serial number: 6332MSME2C406B29H
   Subsystem 2 - Serial number: 6342MSME2C42223ED
   Subsystem 3 - Serial number: 6352QSME3D213635D
   Subsystem 4 - Serial number: 6362QSME3C0B0C41L
7 Faults Found:
00654 - Seat Belt Tensioner Igniter; Driver Side (N153)
00655 - Seat Belt Tensioner Igniter; Passenger Side (N154)
            007 - Short to Ground - Intermittent - MIL ON
01228 - Airbag Cut-Off Switch for Passenger Side (E224)
02756 - Redundant signal path of Airbag cut-off switch - front passenger side (E224)
00589 - Airbag Igniter 1; Passenger Side (N131)
            001 - Upper Limit Exceeded - Intermittent - MIL ON
   Part No SW: 1K0 953 549 AQ    HW: 1K0 953 549 AQ
   Coding: 0012102
   VCID: 01277C885895224AB3-8054
01748 - Switch for Tiptronic in Steering Wheel (E438); Up
   Part No SW: 1K6 920 974     HW: 1K6 920 974
   Component: KOMBIINSTRUMENT VDD 1216
   Revision: V0002000    Serial number: VWX7Z0G83NA8OV
   Coding: 0004103
   Revision:   H07 01    Serial number: 040907F1000254
   Coding: ED811F070002030001
   VCID: 3041E94CA3BF7BC20C-8064
   Component: IMMO            VDD 1216
   Component: Tuer-SG         006 120B
   Coding: 0000564
   Shop #: WSC 00000 785 00200
   VCID: 3851D16C4BCFA38244-806C
00109 - Left Mirror Turn Signal Lamp (L131)
   Part No: 1K0 909 144 H
   Component: EPS_ZFLS Kl. 69     2901
   Revision: 00H15000
   VCID: 2F43EA30BE81643A15-807A
01312 - Powertrain Data Bus
            008 - Implausible Signal - MIL ON
Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
   Coding: 9890020851030C7F42CC0F0FF0085A26D09C40
   VCID: 032B76804289305AA1-8056
Address 4F: Centr. Electr. II (J533)       Labels: 1K0-907-532.clb
   Part No SW: 1K0 907 532     HW: 1K0 907 951
   Coding: 00000000
   VCID: 66ED4F1491FBE57226-8032
   Coding: 0000564
   VCID: 3957D46870C5BA8ABB-806C
   Part No: 1T0 907 357
   Coding: 0000003
   VCID: 74C9255C172707E2A8-8020
   Part No SW: 1K0 035 180 M    HW: 1K0 035 180 M
   Component: Radio PM6       018 0035
   Revision: 00018000    Serial number: VWZ5Z7G2174742
   Coding: 0040400
   VCID: 2A75FB2485630112C2-807E
00877 - Treble Speaker Rear Right (R16)
Address 65: Tire Pressure
End-------------------------(Elapsed Time: 01:14)--------------------------
Try Output Tests and see if they move as expected.
Oh, and guess how much faith I have that "OEM-like" headlights are likely to work properly?
NitrousOxide
Jamaica
C?ID=269481
They do move up and down as expected. What I did initially was to simply focus the beam manually using the adjustment screws.
I guess it is a permanent error message that I'll have to live with.
