2010 Q7 Parking Assist Coding
barbarmi
C?ID=217814
Parking Assist failed, quick scan with VCDS identified module 4L0 910 283 C was the culprit. Purchased the new module from Audi (with P/N from VCDS and VIN) installed new module and parking assist is working again, almost. This is where I am hoping someone can help.
I did not have an Adaptation Map for the module before the failure, and the new module does not have all of the features of the old module, showing the vehicle and sensors in silhouette on the screen, and a selection is missing from the MMI screen when park assist is on. The only info I have is the log data of the original module and the log data of the new module. Looking for some advice on what to change in adaptation to get the new module working like the old module (I am assuming the problem is due to not having the correct adaptation values.
Here is the Scan Summary for the old Module:
Part No SW: 4L0 910 283 C HW: 4L0 919 283 C
Component: Parkhilfe 8-Kan H02 0500
Revision: 00H02000 Serial number: 12631012008902
Coding: 0231266
Shop #: WSC 31414 790 00001
VCID: 2A5B19F58582767111F-807F
Here is the Scan Summary for the New Module:
Component: Parkhilfe 8-Kan H03 0500
Revision: 00H03000 Serial number: 37361420600311
Coding: 0001006
VCID: 2A5B19F585827612C2-807E
Besides the rev numbers being different, big difference is in the coding line.
Appreciate any help that can be provided.
Thanks in advacne
barbarmi
C?ID=217814
No,
Not smart enough to know how to do that. But I'll check the Ross-Tech Wiki and try that later today (after the wife comes home with the car).
barbarmi
C?ID=217814
Thanks, I'll post the outcome for everyone's enjoyment.
