golf7 Variant- long coding helper& service is not supported in active sessions
6636hiro
Japan
C?ID=282964
hi
golf7 Variant MY2014 (December 2013 registered car)
I am in trouble because I can not do some coding
I want to display all "long coding helpeer"
As a result of examining others, all the items "Leuchte" are "service is not supported in active sessions"
Wednesday,02,November,2016,18:25:25:24217
VCDS Version: 16.8.3.1
VIN: WVWZZZAUZEP519***   License Plate:
Mileage: 36846km-22895mi   Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 08 09 10 13 15 16 17 19 42 44 52 55 57 5F A5
VIN: WVWZZZAUZEP519480   Mileage: 36846km-22895miles
Address 01: Engine (J623-CHPA)       Labels: 04E-907-309-V1.clb
   Part No SW: 04E 906 016 CG    HW: 04E 907 309 A
   Component: 1.4l R4 TSI   H08 5668
   Revision: WAH08---
   Coding: 01250032236405082000
   Shop #: WSC 48129 000 1048576
   ASAM Dataset: EV_ECM14TFS01104E906016CG 002003
   ROD: EV_ECM14TFS01104E906016CG.rod
   VCID: 69D83EF488277B0A0B-803C
   Part No SW: 0CW 300 045     HW: 0AM 927 769 G
   Component: GSG DQ200-MQB H43 4530
   Revision: 00043014    Serial number: CU501308185492
   Shop #: WSC 00028 028 00023
   ROD: EV_TCMDQ200021.rod
   VCID: 76E26588C999A4F296-8022
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 6239300000026D
   Coding: 04FA8AA124212975037B060881C32920512494C0608194F3F8225038C102
   VCID: 7CF677A0F7B5FEA2E0-8028
   Part No SW: 5G0 907 044 AA    HW: 5G0 907 044 AA
   Component: Climatronic   H02 0705
   Revision: 00001K06
   Coding: 02120004100100001105000011101800
   VCID: 66C235C89939547226-8032
   Air quality sensor:
   Part No SW: 5Q0 937 087 H    HW: 5Q0 937 087 H
   Component: BCM PQ37BOSCH 020 0078
   Revision: --------    Serial number: 86580409130383
   Coding: 03001A46424122FB49E44000000C0728100A000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 011005
   ROD: EV_BCMBOSCH_011.rod
   VCID: 408EC350DBDD5A42FC-8014
   Component: WWS    130804  042 0551
   Serial number:         130820235813
   Component: RLFS  024 0042
   Serial number: Y13M09D04H07M12S51S1
   Coding: 31E8DD
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-294.clb
   Part No SW: 5Q0 919 294 C    HW: 5Q0 919 294 A
   Component: PARKHILFE 8K  H02 0033
   Revision: --------    Serial number: 94231324203365
   Coding: 0071151011
   Shop #: WSC 52677 001 1048576
   ASAM Dataset: EV_EPHVA18AU3700000 002019
   ROD: EV_EPHVA18AU3700000_VW37.rod
   VCID: 3B74B4BCB23B399AA9-806E
Address 13: Auto Dist. Reg (J428)       Labels: 5Q0-907-572.clb
   Part No SW: 5Q0 907 572 A    HW: 5Q0 907 572 A
   Component: ACC Bosch MQB H04 0150
   Serial number: 29081376510559
   Coding: 021C1700FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001013
   VCID: 3560A284941FEFEA5F-8060
1542 - Sensor for Automatic Distance Control
          C110B F0 [008] - Limited Visibility
                    Reset counter: 104
                    Mileage: 36826 km
                    Date: 2016.11.02
                    Time: 12:07:57
                    Control Module temperature: 35 ーC
                    Voltage terminal 15: 12.9 V
                    Vehicle speed: 0.00 m/s
                    Acceleration: 0.00 m/sイ
   Part No SW: 5Q0 959 655 AA    HW: 5Q0 959 655 AA
   Component: AirbagVW20    014 0386
   Serial number: 003MLR0034C6
   Coding: 98FCC0C0000000005C5400CF00C800000065
   Shop #: WSC 00028 028 00054
   VCID: 7F0C80ACE6A3E5BAC5-802A
   Belt Pretensioner left:
   Component: BeltPretRevFL  H35 0340
   Serial number: 34169677B03091340118
   Coding: 333135
   Belt Pretensioner right:
   Component: BeltPretRevFR  H35 0340
   Serial number: 34169676B02091371670
   Coding: 333135
   Subsystem 3 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35767000000A58097D0.
   Subsystem 4 - Part No SW: -----------    HW: 480 001 708 13
   Serial number: 35867000000D2C397D02
   Subsystem 5 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3516502A51088B1562E7
   Subsystem 6 - Part No SW: -----------    HW: 480 402 908 13
   Serial number: 3526502B91088B1170A4
   Subsystem 7 - Part No SW: -----------    HW: 480 403 008 13
   Serial number: 3556502BB1088B12739C
Address 16: Steering wheel (J524)       Labels: 5Q0-953-549.clb
   Part No SW: 5Q0 953 521 R    HW: 5Q0 953 569 A
   Component: Lenks.Modul   075 0085
   Revision: FF026026    Serial number: 20130809500025
   Coding: 0C00
   ASAM Dataset: EV_SMLSVALEOMQB 001011
   ROD: EV_SMLSVALEOMQB.rod
   VCID: 4188C654D0D7534AF3-8014
   Part No SW: 5G0 920 861 B    HW: 5G0 920 861 B
   Component: KOMBI         204 3390
   Coding: 27A411086F80000E02886A03040000
   ASAM Dataset: EV_DashBoardJCIMQBAB 008011
   ROD: EV_DashBoardJCIMQBAB_008.rod
   VCID: 285E7BF053AD8202D4-807C
   Part No SW: 5Q0 907 530 M    HW: 5Q0 907 530 M
   Component: GW MQB High   212 2147
   Revision: --------    Serial number: 28081310801593
   Coding: 030100042B086400EF00065E1C0F00010001000000000000000000000000
   ASAM Dataset: EV_GatewConti 009011
   ROD: EV_GatewConti_009.rod
   Subsystem 2 - Part No SW: 5G0 959 442 K    HW: 5G0 959 442 K
   Component: E221__MFL-DC1  H14 0035
   Serial number: 02130001612570113155
   Coding: 2DFFFF
   Subsystem 3 - Part No SW: 5Q0 915 181 C    HW: 5Q0 915 181 C
   Component: J367-BDMHella  H03 8042
   Serial number: 3560541103
   Part No SW: 5Q4 959 593     HW: 5Q4 959 593
   Component: TSG FS        007 0006
   Serial number: 0000071278918
   Coding: 003B0320D001028000001000
   VCID: 020A095895518852AA-8056
   Subsystem 1 - Part No SW: 5Q4 959 812 A    HW: 5Q4 959 812 A
   Serial number: 00000000000002586466
   Coding: 0D0000
   Part No SW: 5Q0 909 144 L    HW: 5Q0 909 144 M
   Component: EPS_MQB_ZFLS  127 1021
   Coding: 91
   ROD: EV_SteerAssisMQB_008.rod
   VCID: 3D70BAA4AC2F37AA97-8068
   Part No SW: 5Q4 959 592     HW: 5Q4 959 592
   Component: TSG BFS       007 0006
   Serial number: 0000071388999
   Coding: 003B0120DE01028000801000
   VCID: 010806549057934AB3-8054
   Subsystem 1 - Part No SW: 5Q4 959 811 A    HW: 5Q4 959 811 A
   Serial number: 00000000000002570050
   Coding: 050000
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 029E00000B010200
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 2E0000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 2E0000
Address 57: TV Tuner (R78)       Labels: None
   Part No SW: 8V0 919 129 K    HW: 8V0 919 129
   Component: JP-DTV        H09 1380
   Coding: 02011C0000000100000000
   ASAM Dataset: EV_TVMELC 001033
   ROD: EV_TVMELC_VW37.rod
   VCID: 489EDB70F3ED620234-801C
Address 5F: Information Electr. (J794)       Labels: 5G0-035-MIB-HGH1.clb
   Part No SW: 5G0 035 050 A    HW: 5G0 035 050
   Component: MU-H-N-JP     H41 0260
   Serial number: K5F AW74A006DP
   Coding: 02730206FF00000021330001001000001F0100360100010076
   ASAM Dataset: EV_MUHig4CAW7 001105
   ROD: EV_MUHig4CAW7_VW37.rod
   VCID: 1A3A51381DC1209252-804E
   Component: ABT_High  H42 0022
   Serial number: VWZ8Z9N2300V6D
   Subsystem 2 - Part No SW: V03 959 802 QJ    HW: -----------
   Component: JPN 2016/2017  --- 7620
   Chip Card Reader Control Module:
   Subsystem 3 - Part No SW: 8V0 919 813 B    HW: 8V0 919 813 B
   Component: DSRC UNIT  H06 0002
   Serial number: 502270016401
   Traffic Data Aerial:
   Subsystem 4 - Part No SW: 8V0 035 504 A    HW: 8V0 035 504 A
   Component: VICS Antenna  H03 0001
   Serial number: 503040039502
   Compact Disc Database:
   Subsystem 5 - Part No SW: V03 959 800 EG    HW: -----------
   Component: Gracenote  --- 2006
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 00000109554
   Coding: 0100000000020303000400000101010100
   ROD: EV_MFKBoschAU370.rod
   VCID: 3A7AB1B8BD010092B2-806E
End-------------------------(Elapsed Time: 04:43)--------------------------
;SW:5Q0-937-087-H   HW:5Q0-937-087-H ---  Cent. Elect.
;Component:BCM PQ37BOSCH 020 0078	 Coding:03001A46424122FB49E44000000C0728100A000000000000000000000000
;EV_BodyContrModul1UDSBosc	11005	EV_BCMBOSCH_011.rod
;Wednesday	2	November
;VCDS Version: Release 16.8.3  Data version: 20161010 DS267.0
;VCID: 408EC350DBDD5A42FC-8014
IDE00001-ENG99061-Production mode-Access control	not active
IDE00001-ENG115730-Production mode-Aussenbeleuchtung	not active
IDE00001-ENG116710-Production mode-Frontwischer deaktivieren	not active
IDE00001-ENG112304-Production mode-Heckwischer	not active
IDE00001-ENG98647-Production mode-Interior lighting	not active
IDE00001-ENG115729-Production mode-Scheinwerferreinigung	not active
IDE00001-ENG115731-Production mode-Virtuel_pedal	not active
IDE00002-Transport mode	active
IDE00820-Activating and deactivating all development messages	not active
IDE01268-ENG115835-Windshield wiper-Adaptives Nachwischen bei SRA	not active
IDE01268-ENG116609-Windshield wiper-Anzahl Betaetigungen Frontwaschanlage pro SRA Aktivierung	5
IDE01268-ENG115836-Windshield wiper-Frontwischer Notlaufprogramm	active
IDE01268-ENG116614-Windshield wiper-Frontwischer Referenzlauf	active
IDE01268-ENG116617-Windshield wiper-Geschwindigkeitsabhaengige Wischstufenrueckschaltung	active
IDE01268-ENG116615-Windshield wiper-Menuesteuerung Frontwischer	not active
IDE01268-ENG115771-Windshield wiper-Regensensor aktivieren	Deactivating
IDE01268-ENG115769-Windshield wiper-SRA bei Waschwassermangel	not active
IDE01268-ENG115767-Windshield wiper-SRA Einweichpausenzeit	2000 ms
IDE01268-ENG115768-Windshield wiper-SRA Nachwaschzeit	320 ms
IDE01268-ENG116611-Windshield wiper-SRA Pausenzeit	0 ms
IDE01268-ENG116610-Windshield wiper-SRA Verzoegerungszeit	0 ms
IDE01268-ENG115766-Windshield wiper-SRA Waschzeit	320 ms
IDE01268-ENG116616-Windshield wiper-Tippwischen mit erhoehter Wischfrequenz	active
IDE01268-ENG116618-Windshield wiper-Traenenwischen Front Status	not active
IDE01268-ENG115770-Windshield wiper-Variable Regensensoraktivierung	not active
IDE01268-ENG116613-Windshield wiper-Wischer abparken bei Oeffnen der Motorhaube	not active
IDE01268-ENG116612-Windshield wiper-Wischer stop bei KL15 aus	not active
IDE01268-ENG122185-Windshield wiper-Wischer Stopp bei Oeffnen der Motorhaube	not active
IDE01550-Service position	170.494336 ー
IDE02152-Characteristics in production mode	0 ms
IDE02269-MAS04382-Acknowledgement signals-Optical feedback during locking	Decelerate
IDE02269-ENG116666-Acknowledgement signals-Akustische Rueckmeldung entriegeln	No
IDE02269-ENG116669-Acknowledgement signals-Akustische Rueckmeldung global	not active
IDE02269-ENG116670-Acknowledgement signals-Akustische Rueckmeldung Signalhorn	not active
IDE02269-ENG116667-Acknowledgement signals-Akustische Rueckmeldung verriegeln	No
IDE02269-ENG122187-Acknowledgement signals-Dauer der Akustischen Rueckmeldung vom Einfachhorn	normal
IDE02269-ENG122188-Acknowledgement signals-Menuesteuerung akustische Rueckmeldung	not active
IDE02269-ENG122995-Acknowledgement signals-Optische Rueckmeldung 3.Bremsleuchte	not active
IDE02269-ENG116668-Acknowledgement signals-Optische Rueckmeldung Komfortschliessen	active
IDE02332-Deactivate production mode	0
IDE02711-ENG116690-Rear Window Wiper-Automatisches Heckwischen	not active
IDE02711-ENG114947-Rear Window Wiper-Heckwischer Weiterlauf	not active
IDE02711-ENG116692-Rear Window Wiper-Kein automatisches Abparken	not active
IDE02711-ENG114946-Rear Window Wiper-Komfortwischen Heck	active
IDE02711-ENG116695-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 1	5 s
IDE02711-ENG116696-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe 2	3 s
IDE02711-ENG116694-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Automatik	7 s
IDE02711-ENG116693-Rear Window Wiper-Komofortwischen Heck Intervallpausenzeit Stufe Intervall	7 s
IDE02711-ENG116689-Rear Window Wiper-Menuesteuerung Komfortwischen HW	active
IDE02711-ENG116691-Rear Window Wiper-Traenenwischen Heck	active
IDE02957-ENG116688-Ambient lighting-Ambientelicht mit raste heckdeckel	not enabled
IDE02957-ENG115822-Ambient lighting-Defaultwert Ambienteprofil Fussraum	50%
IDE02957-ENG116685-Ambient lighting-Defaultwert Ambienteprofil Tuer	50%
IDE02957-ENG115823-Ambient lighting-Defaultwert Ambienteprofil Vorn	50%
IDE02957-ENG115824-Ambient lighting-Innenlichtinszenierung	Enabled
IDE02957-ENG116687-Ambient lighting-Tuerinnengriff mit Tuertafel	not installed
IDE02957-ENG116686-Ambient lighting-Tuerinnengriffbeleuchtung mit I-Tafel	not installed
IDE03638-IDE04231-static AFS light-Steering wheel angle: offset	-63.75 ー
IDE03638-ENG116677-static AFS light-Abdimmgeschwindigkeit	50.0 %/s
IDE03638-ENG116673-static AFS light-bei Rueckwaertsfahrt	both sides
IDE03638-ENG116675-static AFS light-Lower speed threshold	0.0 km/h
IDE03638-ENG116682-static AFS light-Maximaltemperatur	100.0 ーC
IDE03638-ENG116679-static AFS light-obere Grenztemperatur	95.0 ーC
IDE03638-ENG116681-static AFS light-Oberer Lenkradwinkel	120 ー
IDE03638-ENG116680-static AFS light-untere Grenztemperatur	80.0 ーC
IDE03638-ENG116678-static AFS light-Unterer Lenkradwinkel	180 ー
IDE03638-ENG116676-static AFS light-Upper speed threshold	40.0 km/h
IDE03638-ENG116674-static AFS light-Vorschrift	ECE R119
IDE04923-ENG116590-Turn signal control-Blinkkontrolleuchte fuer Anhaenger	separate
IDE04923-ENG115774-Turn signal control-Komfortblinken	active
IDE04923-ENG116587-Turn signal control-Komfortblinken Blinkzyklen	3
IDE04923-ENG116589-Turn signal control-Signalprioritaet fuer Blinker	SMLS
IDE04923-ENG116588-Turn signal control-Sonderfunktionen	not enabled
IDE04923-ENG115818-Turn signal control-Warnblinken bei Verdeckentriegelung	not active
IDE04923-ENG115819-Turn signal control-Warnblinktastersuchbeleuchtung Aktivierung	Always active
IDE04923-ENG115821-Turn signal control-Warnblinktastersuchbeleuchtung Faktor	0.10%
IDE04923-ENG115820-Turn signal control-Warnblinktastersuchbeleuchtung Grundwert	10.00%
IDE04924-ENG116705-Driving light and parking light-Allwetterlicht Ausschaltgrenze	350 km/h
IDE04924-ENG116704-Driving light and parking light-Allwetterlicht Einschaltgrenze	350 km/h
IDE04924-ENG115858-Driving light and parking light-Kontrollleuchte fuer Begrenzungslicht	integriert in Suchbeleuchtung
IDE04924-ENG115861-Driving light and parking light-Lichthupe bei Zuendung aus moeglich	active
IDE04924-ENG115862-Driving light and parking light-Lichtwarnungsverhalten	klemmenabhaengig
IDE04924-ENG115863-Driving light and parking light-Menueeinstellung CHO LHO	Menuesteuerung Zeit aktivieren
IDE04924-ENG115782-Driving light and parking light-Nebelschlusslicht Warngeschwindigkeit	0 km/h
IDE04924-ENG115859-Driving light and parking light-Parklicht ueber LSS aktiviert	One-sided
IDE04924-ENG115831-Driving light and parking light-Schlusslicht mit Bremslichtfunktion	not active
IDE04924-ENG17816-Driving light and parking light-Standlicht aus bei LDS=ABL und S-Kontakt aus	active
IDE04924-ENG115829-Driving light and parking light-Standlichtreduzierung mit beidseitigem Parklicht	active
IDE04924-ENG122200-Driving light and parking light-Warnung Fahrt mit Standlicht	not active
IDE04924-ENG115860-Driving light and parking light-Zahl der aktiven Scheinwerfer auf 2 limitieren	not active
IDE04924-ENG115830-Driving light and parking light-Zeitwert Einschaltzeit Abbiegelicht	15 min
IDE04926-ENG115656-Comfort illumination-Coming Home Leuchten	Low beam
IDE04926-ENG116601-Comfort illumination-Coming Home Verbaustatus	manual
IDE04926-ENG116604-Comfort illumination-Coming-home Einschaltereignis	Driver door
IDE04926-ENG116608-Comfort illumination-Helligkeitsschwelle Forward-Messung	116
IDE04926-ENG116605-Comfort illumination-Helligkeitsschwelle Infrarot-Messung	2
IDE04926-ENG115657-Comfort illumination-Leaving-Home Verbausstatus	Enabled
IDE04926-ENG116603-Comfort illumination-Menueeinstellung Cominghome	10 s
IDE04926-ENG116607-Comfort illumination-Menueeinstellung Leaving-home Zeit per BAP	10 s
IDE04926-ENG116602-Comfort illumination-Menuesteuerung Coming Home Werkseinstellung	active
IDE04926-ENG116606-Comfort illumination-Menuesteuerung Leaving-home Freischaltung per BAP	active
IDE04927-IDE01446-Window heater-Running time of heated front window	240 s
IDE04927-ENG116709-Window heater-Abschalttemperatur f・ Frontscheibenheizung	35.0 ーC
IDE04927-ENG116708-Window heater-Abschalttemperatur f・ Heckscheibenheizung	35.0 ーC
IDE04927-ENG115736-Window heater-Heckscheibenheizung Zeitwert	600 s
IDE04927-ENG116620-Window heater-Temperaturabhaengige Einschaltzeit FSH	time value
IDE04927-ENG116619-Window heater-Temperaturabhaengige Einschaltzeit HSH	not active
IDE04928-ENG115867-Anti-theft device-Akustischer Alarm Signalhorn	not active
IDE04928-ENG115864-Anti-theft device-Alarmsignal	frequency modulated
IDE04928-ENG115865-Anti-theft device-DWA Alarmverzoegerung	not active
IDE04928-ENG115812-Anti-theft device-DWA Camper Modus	not active
IDE04928-ENG115866-Anti-theft device-Sirenen Alarmzahl	1 Alarm
IDE04928-ENG17832-Anti-theft device-ワberwachung Innenentriegelungshebel	not active
IDE04928-ENG115868-Anti-theft device-Verzoegerung Panikalarm	keine verzoegerung
IDE05142-ENG116628-Access control-Autolock Autounlock wirkt auf Heck	active
IDE05142-ENG116621-Access control-automatisches Entriegeln	active
IDE05142-ENG115756-Access control-automatisches Verriegeln bei Geschwindigkeit	not active
IDE05142-ENG116706-Access control-Autounlock NAR	not active
IDE05142-ENG116632-Access control-Bewusstes Safe mit 2. Betaetigung der FFB	not active
IDE05142-ENG116624-Access control-CAN Wecken bei Softtouchbetaetigung	not active
IDE05142-ENG115759-Access control-Direkter Auswurf des Heckdeckels	active
IDE05142-ENG115722-Access control-Elektrische Laderaumabdeckung	not active
IDE05142-ENG116707-Access control-Freigabenachlauf Heck nach Einzeloeffnung ueber HDF-Funktaster	not active
IDE05142-ENG115754-Access control-Funk bei Klemme 15 ein	not active
IDE05142-ENG116622-Access control-Geschwindigkeitsabhaengige Tankdeckelverriegelung	not active
IDE05142-ENG116627-Access control-Heckdeckel-Bedienstellen nachCrash temporaer sperren	active
IDE05142-ENG115763-Access control-Manuelle ZV Variantenprogrammierung	not active
IDE05142-ENG116633-Access control-Menuesteuerung Tuerentriegelung	active
IDE05142-ENG116634-Access control-Menuesteuerung ZV Autolock-Unlock	adjustable
IDE05142-ENG115761-Access control-Nach externer Verriegelung ist Heck noch zeitbegrenzt entriegelt	not active
IDE05142-ENG115755-Access control-Notschlie゚funktion	active
IDE05142-ENG116626-Access control-Oeffnung Heckdeckel bei Wiederentriegelung	not active
IDE05142-ENG116631-Access control-Schliessung der Schiebetuer bei geoeffneter Tankklappe	not active
IDE05142-ENG115758-Access control-Valet Parking	not active
IDE05142-ENG116630-Access control-Wiederholte Heckansteuerung beim Schliessen FT oder BT	not active
IDE05142-ENG116625-Access control-Wiederoeffnung Elektrische-Schiebetuer	not active
IDE05142-ENG115760-Access control-ZV entriegelt auch Heckdeckel	active
IDE05142-ENG116629-Access control-ZV Heck nur direkt auswerfen	not active
IDE05142-ENG116623-Access control-ZV Tuerentriegelung	Globale Entriegelung
IDE05142-ENG116635-Access control-ZV-Entriegelung nach Seitencrash	not active
IDE05143-MAS02985-Writing parameter-Value	130
IDE05143-MAS04381-Writing parameter-Parameter address	FE 00 00
IDE05144-Read parameter address	FE 00 00
IDE05145-ENG115874-Light configuration-BAP Bitposition 0	34
IDE05145-ENG115893-Light configuration-BAP Bitposition 1	3E
IDE05145-ENG116063-Light configuration-BAP Bitposition 10	37
IDE05145-ENG116082-Light configuration-BAP Bitposition 11	41
IDE05145-ENG116101-Light configuration-BAP Bitposition 12	38
IDE05145-ENG116120-Light configuration-BAP Bitposition 13	42
IDE05145-ENG116139-Light configuration-BAP Bitposition 14	0
IDE05145-ENG116158-Light configuration-BAP Bitposition 15	0
IDE05145-ENG116177-Light configuration-BAP Bitposition 16	0
IDE05145-ENG116196-Light configuration-BAP Bitposition 17	0
IDE05145-ENG116215-Light configuration-BAP Bitposition 18	8
IDE05145-ENG116234-Light configuration-BAP Bitposition 19	18
IDE05145-ENG115911-Light configuration-BAP Bitposition 2	48
IDE05145-ENG116253-Light configuration-BAP Bitposition 20	10
IDE05145-ENG116272-Light configuration-BAP Bitposition 21	20
IDE05145-ENG116291-Light configuration-BAP Bitposition 22	29
IDE05145-ENG116310-Light configuration-BAP Bitposition 23	0A
IDE05145-ENG116329-Light configuration-BAP Bitposition 24	1A
IDE05145-ENG116348-Light configuration-BAP Bitposition 25	28
IDE05145-ENG116367-Light configuration-BAP Bitposition 26	1C
IDE05145-ENG116386-Light configuration-BAP Bitposition 27	0
IDE05145-ENG116405-Light configuration-BAP Bitposition 28	0B
IDE05145-ENG116424-Light configuration-BAP Bitposition 29	1B
IDE05145-ENG115930-Light configuration-BAP Bitposition 3	4C
IDE05145-ENG116443-Light configuration-BAP Bitposition 30	0
IDE05145-ENG116462-Light configuration-BAP Bitposition 31	0
IDE05145-ENG116481-Light configuration-BAP Bitposition 32	0
IDE05145-ENG116500-Light configuration-BAP Bitposition 33	0
IDE05145-ENG116519-Light configuration-BAP Bitposition 34	0
IDE05145-ENG115949-Light configuration-BAP Bitposition 4	3A
IDE05145-ENG115968-Light configuration-BAP Bitposition 5	44
IDE05145-ENG115987-Light configuration-BAP Bitposition 6	36
IDE05145-ENG116006-Light configuration-BAP Bitposition 7	40
IDE05145-ENG116025-Light configuration-BAP Bitposition 8	35
IDE05145-ENG116044-Light configuration-BAP Bitposition 9	3F
IDE05145-ENG115883-Light configuration-Dimming Direction CD 0	maximize
IDE05145-ENG115902-Light configuration-Dimming Direction CD 1	maximize
IDE05145-ENG116072-Light configuration-Dimming Direction CD 10	maximize
IDE05145-ENG116091-Light configuration-Dimming Direction CD 11	maximize
IDE05145-ENG116110-Light configuration-Dimming Direction CD 12	maximize
IDE05145-ENG116129-Light configuration-Dimming Direction CD 13	maximize
IDE05145-ENG116148-Light configuration-Dimming Direction CD 14	maximize
IDE05145-ENG116167-Light configuration-Dimming Direction CD 15	maximize
IDE05145-ENG116186-Light configuration-Dimming Direction CD 16	maximize
IDE05145-ENG116205-Light configuration-Dimming Direction CD 17	maximize
IDE05145-ENG116224-Light configuration-Dimming Direction CD 18	maximize
IDE05145-ENG116243-Light configuration-Dimming Direction CD 19	maximize
IDE05145-ENG115920-Light configuration-Dimming Direction CD 2	maximize
IDE05145-ENG116262-Light configuration-Dimming Direction CD 20	maximize
IDE05145-ENG116281-Light configuration-Dimming Direction CD 21	maximize
IDE05145-ENG116300-Light configuration-Dimming Direction CD 22	maximize
IDE05145-ENG116319-Light configuration-Dimming Direction CD 23	maximize
IDE05145-ENG116338-Light configuration-Dimming Direction CD 24	maximize
IDE05145-ENG116357-Light configuration-Dimming Direction CD 25	maximize
IDE05145-ENG116376-Light configuration-Dimming Direction CD 26	maximize
IDE05145-ENG116395-Light configuration-Dimming Direction CD 27	maximize
IDE05145-ENG116414-Light configuration-Dimming Direction CD 28	maximize
IDE05145-ENG116433-Light configuration-Dimming Direction CD 29	maximize
IDE05145-ENG115939-Light configuration-Dimming Direction CD 3	maximize
IDE05145-ENG116452-Light configuration-Dimming Direction CD 30	maximize
IDE05145-ENG116471-Light configuration-Dimming Direction CD 31	maximize
IDE05145-ENG116490-Light configuration-Dimming Direction CD 32	maximize
IDE05145-ENG116509-Light configuration-Dimming Direction CD 33	maximize
IDE05145-ENG116528-Light configuration-Dimming Direction CD 34	maximize
IDE05145-ENG115958-Light configuration-Dimming Direction CD 4	maximize
IDE05145-ENG115977-Light configuration-Dimming Direction CD 5	maximize
IDE05145-ENG115996-Light configuration-Dimming Direction CD 6	maximize
IDE05145-ENG116015-Light configuration-Dimming Direction CD 7	maximize
IDE05145-ENG116034-Light configuration-Dimming Direction CD 8	maximize
IDE05145-ENG116053-Light configuration-Dimming Direction CD 9	maximize
IDE05145-ENG115887-Light configuration-Dimming Direction EF 0	maximize
IDE05145-ENG115906-Light configuration-Dimming Direction EF 1	maximize
IDE05145-ENG116076-Light configuration-Dimming Direction EF 10	maximize
IDE05145-ENG116095-Light configuration-Dimming Direction EF 11	maximize
IDE05145-ENG116114-Light configuration-Dimming Direction EF 12	maximize
IDE05145-ENG116133-Light configuration-Dimming Direction EF 13	maximize
IDE05145-ENG116152-Light configuration-Dimming Direction EF 14	maximize
IDE05145-ENG116171-Light configuration-Dimming Direction EF 15	maximize
IDE05145-ENG116190-Light configuration-Dimming Direction EF 16	maximize
IDE05145-ENG116209-Light configuration-Dimming Direction EF 17	maximize
IDE05145-ENG116228-Light configuration-Dimming Direction EF 18	maximize
IDE05145-ENG116247-Light configuration-Dimming Direction EF 19	maximize
IDE05145-ENG115924-Light configuration-Dimming Direction EF 2	maximize
IDE05145-ENG116266-Light configuration-Dimming Direction EF 20	maximize
IDE05145-ENG116285-Light configuration-Dimming Direction EF 21	maximize
IDE05145-ENG116304-Light configuration-Dimming Direction EF 22	maximize
IDE05145-ENG116323-Light configuration-Dimming Direction EF 23	maximize
IDE05145-ENG116342-Light configuration-Dimming Direction EF 24	maximize
IDE05145-ENG116361-Light configuration-Dimming Direction EF 25	maximize
IDE05145-ENG116380-Light configuration-Dimming Direction EF 26	maximize
IDE05145-ENG116399-Light configuration-Dimming Direction EF 27	maximize
IDE05145-ENG116418-Light configuration-Dimming Direction EF 28	maximize
IDE05145-ENG116437-Light configuration-Dimming Direction EF 29	maximize
IDE05145-ENG115943-Light configuration-Dimming Direction EF 3	maximize
IDE05145-ENG116456-Light configuration-Dimming Direction EF 30	maximize
IDE05145-ENG116475-Light configuration-Dimming Direction EF 31	maximize
IDE05145-ENG116494-Light configuration-Dimming Direction EF 32	maximize
IDE05145-ENG116513-Light configuration-Dimming Direction EF 33	maximize
IDE05145-ENG116532-Light configuration-Dimming Direction EF 34	maximize
IDE05145-ENG115962-Light configuration-Dimming Direction EF 4	maximize
IDE05145-ENG115981-Light configuration-Dimming Direction EF 5	maximize
IDE05145-ENG116000-Light configuration-Dimming Direction EF 6	maximize
IDE05145-ENG116019-Light configuration-Dimming Direction EF 7	maximize
IDE05145-ENG116038-Light configuration-Dimming Direction EF 8	maximize
IDE05145-ENG116057-Light configuration-Dimming Direction EF 9	maximize
IDE05145-ENG115891-Light configuration-Dimming Direction GH 0	maximize
IDE05145-ENG115909-Light configuration-Dimming Direction GH 1	maximize
IDE05145-ENG116080-Light configuration-Dimming Direction GH 10	maximize
IDE05145-ENG116099-Light configuration-Dimming Direction GH 11	maximize
IDE05145-ENG116118-Light configuration-Dimming Direction GH 12	maximize
IDE05145-ENG116137-Light configuration-Dimming Direction GH 13	maximize
IDE05145-ENG116156-Light configuration-Dimming Direction GH 14	maximize
IDE05145-ENG116175-Light configuration-Dimming Direction GH 15	maximize
IDE05145-ENG116194-Light configuration-Dimming Direction GH 16	maximize
IDE05145-ENG116213-Light configuration-Dimming Direction GH 17	maximize
IDE05145-ENG116232-Light configuration-Dimming Direction GH 18	maximize
IDE05145-ENG116251-Light configuration-Dimming Direction GH 19	maximize
IDE05145-ENG115928-Light configuration-Dimming Direction GH 2	maximize
IDE05145-ENG116270-Light configuration-Dimming Direction GH 20	maximize
IDE05145-ENG116289-Light configuration-Dimming Direction GH 21	maximize
IDE05145-ENG116308-Light configuration-Dimming Direction GH 22	maximize
IDE05145-ENG116327-Light configuration-Dimming Direction GH 23	maximize
IDE05145-ENG116346-Light configuration-Dimming Direction GH 24	maximize
IDE05145-ENG116365-Light configuration-Dimming Direction GH 25	maximize
IDE05145-ENG116384-Light configuration-Dimming Direction GH 26	maximize
IDE05145-ENG116403-Light configuration-Dimming Direction GH 27	maximize
IDE05145-ENG116422-Light configuration-Dimming Direction GH 28	maximize
IDE05145-ENG116441-Light configuration-Dimming Direction GH 29	maximize
IDE05145-ENG115947-Light configuration-Dimming Direction GH 3	maximize
IDE05145-ENG116460-Light configuration-Dimming Direction GH 30	maximize
IDE05145-ENG116479-Light configuration-Dimming Direction GH 31	maximize
IDE05145-ENG116498-Light configuration-Dimming Direction GH 32	maximize
IDE05145-ENG116517-Light configuration-Dimming Direction GH 33	maximize
IDE05145-ENG116536-Light configuration-Dimming Direction GH 34	maximize
IDE05145-ENG115966-Light configuration-Dimming Direction GH 4	maximize
IDE05145-ENG115985-Light configuration-Dimming Direction GH 5	maximize
IDE05145-ENG116004-Light configuration-Dimming Direction GH 6	maximize
IDE05145-ENG116023-Light configuration-Dimming Direction GH 7	maximize
IDE05145-ENG116042-Light configuration-Dimming Direction GH 8	maximize
IDE05145-ENG116061-Light configuration-Dimming Direction GH 9	maximize
IDE05145-ENG115878-Light configuration-Dimmwert AB 0	100
IDE05145-ENG115897-Light configuration-Dimmwert AB 1	100
IDE05145-ENG116067-Light configuration-Dimmwert AB 10	127
IDE05145-ENG116086-Light configuration-Dimmwert AB 11	127
IDE05145-ENG116105-Light configuration-Dimmwert AB 12	100
IDE05145-ENG116124-Light configuration-Dimmwert AB 13	100
IDE05145-ENG116143-Light configuration-Dimmwert AB 14	0
IDE05145-ENG116162-Light configuration-Dimmwert AB 15	0
IDE05145-ENG116181-Light configuration-Dimmwert AB 16	0
IDE05145-ENG116200-Light configuration-Dimmwert AB 17	0
IDE05145-ENG116219-Light configuration-Dimmwert AB 18	100
IDE05145-ENG116238-Light configuration-Dimmwert AB 19	100
IDE05145-ENG115915-Light configuration-Dimmwert AB 2	100
IDE05145-ENG116257-Light configuration-Dimmwert AB 20	100
IDE05145-ENG116276-Light configuration-Dimmwert AB 21	100
IDE05145-ENG116295-Light configuration-Dimmwert AB 22	100
IDE05145-ENG116314-Light configuration-Dimmwert AB 23	35
IDE05145-ENG116333-Light configuration-Dimmwert AB 24	35
IDE05145-ENG116352-Light configuration-Dimmwert AB 25	127
IDE05145-ENG116371-Light configuration-Dimmwert AB 26	100
IDE05145-ENG116390-Light configuration-Dimmwert AB 27	0
IDE05145-ENG116409-Light configuration-Dimmwert AB 28	100
IDE05145-ENG116428-Light configuration-Dimmwert AB 29	100
IDE05145-ENG115934-Light configuration-Dimmwert AB 3	100
IDE05145-ENG116447-Light configuration-Dimmwert AB 30	89
IDE05145-ENG116466-Light configuration-Dimmwert AB 31	0
IDE05145-ENG116485-Light configuration-Dimmwert AB 32	0
IDE05145-ENG116504-Light configuration-Dimmwert AB 33	0
IDE05145-ENG116523-Light configuration-Dimmwert AB 34	0
IDE05145-ENG115953-Light configuration-Dimmwert AB 4	127
IDE05145-ENG115972-Light configuration-Dimmwert AB 5	127
IDE05145-ENG115991-Light configuration-Dimmwert AB 6	127
IDE05145-ENG116010-Light configuration-Dimmwert AB 7	127
IDE05145-ENG116029-Light configuration-Dimmwert AB 8	127
IDE05145-ENG116048-Light configuration-Dimmwert AB 9	127
IDE05145-ENG115882-Light configuration-Dimmwert CD 0	0
IDE05145-ENG115901-Light configuration-Dimmwert CD 1	0
IDE05145-ENG116071-Light configuration-Dimmwert CD 10	0
IDE05145-ENG116090-Light configuration-Dimmwert CD 11	0
IDE05145-ENG116109-Light configuration-Dimmwert CD 12	0
IDE05145-ENG116128-Light configuration-Dimmwert CD 13	0
IDE05145-ENG116147-Light configuration-Dimmwert CD 14	0
IDE05145-ENG116166-Light configuration-Dimmwert CD 15	0
IDE05145-ENG116185-Light configuration-Dimmwert CD 16	0
IDE05145-ENG116204-Light configuration-Dimmwert CD 17	0
IDE05145-ENG116223-Light configuration-Dimmwert CD 18	0
IDE05145-ENG116242-Light configuration-Dimmwert CD 19	0
IDE05145-ENG115919-Light configuration-Dimmwert CD 2	51
IDE05145-ENG116261-Light configuration-Dimmwert CD 20	35
IDE05145-ENG116280-Light configuration-Dimmwert CD 21	35
IDE05145-ENG116299-Light configuration-Dimmwert CD 22	0
IDE05145-ENG116318-Light configuration-Dimmwert CD 23	0
IDE05145-ENG116337-Light configuration-Dimmwert CD 24	0
IDE05145-ENG116356-Light configuration-Dimmwert CD 25	0
IDE05145-ENG116375-Light configuration-Dimmwert CD 26	0
IDE05145-ENG116394-Light configuration-Dimmwert CD 27	0
IDE05145-ENG116413-Light configuration-Dimmwert CD 28	0
IDE05145-ENG116432-Light configuration-Dimmwert CD 29	0
IDE05145-ENG115938-Light configuration-Dimmwert CD 3	51
IDE05145-ENG116451-Light configuration-Dimmwert CD 30	0
IDE05145-ENG116470-Light configuration-Dimmwert CD 31	0
IDE05145-ENG116489-Light configuration-Dimmwert CD 32	0
IDE05145-ENG116508-Light configuration-Dimmwert CD 33	0
IDE05145-ENG116527-Light configuration-Dimmwert CD 34	0
IDE05145-ENG115957-Light configuration-Dimmwert CD 4	127
IDE05145-ENG115976-Light configuration-Dimmwert CD 5	127
IDE05145-ENG115995-Light configuration-Dimmwert CD 6	0
IDE05145-ENG116014-Light configuration-Dimmwert CD 7	0
IDE05145-ENG116033-Light configuration-Dimmwert CD 8	0
IDE05145-ENG116052-Light configuration-Dimmwert CD 9	0
IDE05145-ENG115886-Light configuration-Dimmwert EF 0	0
IDE05145-ENG115905-Light configuration-Dimmwert EF 1	0
IDE05145-ENG116075-Light configuration-Dimmwert EF 10	0
IDE05145-ENG116094-Light configuration-Dimmwert EF 11	0
IDE05145-ENG116113-Light configuration-Dimmwert EF 12	0
IDE05145-ENG116132-Light configuration-Dimmwert EF 13	0
IDE05145-ENG116151-Light configuration-Dimmwert EF 14	0
IDE05145-ENG116170-Light configuration-Dimmwert EF 15	0
IDE05145-ENG116189-Light configuration-Dimmwert EF 16	0
IDE05145-ENG116208-Light configuration-Dimmwert EF 17	0
IDE05145-ENG116227-Light configuration-Dimmwert EF 18	0
IDE05145-ENG116246-Light configuration-Dimmwert EF 19	0
IDE05145-ENG115923-Light configuration-Dimmwert EF 2	0
IDE05145-ENG116265-Light configuration-Dimmwert EF 20	0
IDE05145-ENG116284-Light configuration-Dimmwert EF 21	0
IDE05145-ENG116303-Light configuration-Dimmwert EF 22	0
IDE05145-ENG116322-Light configuration-Dimmwert EF 23	0
IDE05145-ENG116341-Light configuration-Dimmwert EF 24	0
IDE05145-ENG116360-Light configuration-Dimmwert EF 25	0
IDE05145-ENG116379-Light configuration-Dimmwert EF 26	0
IDE05145-ENG116398-Light configuration-Dimmwert EF 27	0
IDE05145-ENG116417-Light configuration-Dimmwert EF 28	0
IDE05145-ENG116436-Light configuration-Dimmwert EF 29	0
IDE05145-ENG115942-Light configuration-Dimmwert EF 3	0
IDE05145-ENG116455-Light configuration-Dimmwert EF 30	0
IDE05145-ENG116474-Light configuration-Dimmwert EF 31	0
IDE05145-ENG116493-Light configuration-Dimmwert EF 32	0
IDE05145-ENG116512-Light configuration-Dimmwert EF 33	0
IDE05145-ENG116531-Light configuration-Dimmwert EF 34	0
IDE05145-ENG115961-Light configuration-Dimmwert EF 4	0
IDE05145-ENG115980-Light configuration-Dimmwert EF 5	0
IDE05145-ENG115999-Light configuration-Dimmwert EF 6	0
IDE05145-ENG116018-Light configuration-Dimmwert EF 7	0
IDE05145-ENG116037-Light configuration-Dimmwert EF 8	0
IDE05145-ENG116056-Light configuration-Dimmwert EF 9	0
IDE05145-ENG115890-Light configuration-Dimmwert GH 0	0
IDE05145-ENG115908-Light configuration-Dimmwert GH 1	0
IDE05145-ENG116079-Light configuration-Dimmwert GH 10	0
IDE05145-ENG116098-Light configuration-Dimmwert GH 11	0
IDE05145-ENG116117-Light configuration-Dimmwert GH 12	0
IDE05145-ENG116136-Light configuration-Dimmwert GH 13	0
IDE05145-ENG116155-Light configuration-Dimmwert GH 14	0
IDE05145-ENG116174-Light configuration-Dimmwert GH 15	0
IDE05145-ENG116193-Light configuration-Dimmwert GH 16	0
IDE05145-ENG116212-Light configuration-Dimmwert GH 17	0
IDE05145-ENG116231-Light configuration-Dimmwert GH 18	0
IDE05145-ENG116250-Light configuration-Dimmwert GH 19	0
IDE05145-ENG115927-Light configuration-Dimmwert GH 2	0
IDE05145-ENG116269-Light configuration-Dimmwert GH 20	0
IDE05145-ENG116288-Light configuration-Dimmwert GH 21	0
IDE05145-ENG116307-Light configuration-Dimmwert GH 22	0
IDE05145-ENG116326-Light configuration-Dimmwert GH 23	0
IDE05145-ENG116345-Light configuration-Dimmwert GH 24	0
IDE05145-ENG116364-Light configuration-Dimmwert GH 25	0
IDE05145-ENG116383-Light configuration-Dimmwert GH 26	0
IDE05145-ENG116402-Light configuration-Dimmwert GH 27	0
IDE05145-ENG116421-Light configuration-Dimmwert GH 28	0
IDE05145-ENG116440-Light configuration-Dimmwert GH 29	0
IDE05145-ENG115946-Light configuration-Dimmwert GH 3	0
IDE05145-ENG116459-Light configuration-Dimmwert GH 30	0
IDE05145-ENG116478-Light configuration-Dimmwert GH 31	0
IDE05145-ENG116497-Light configuration-Dimmwert GH 32	0
IDE05145-ENG116516-Light configuration-Dimmwert GH 33	0
IDE05145-ENG116535-Light configuration-Dimmwert GH 34	0
IDE05145-ENG115965-Light configuration-Dimmwert GH 4	0
IDE05145-ENG115984-Light configuration-Dimmwert GH 5	0
IDE05145-ENG116003-Light configuration-Dimmwert GH 6	0
IDE05145-ENG116022-Light configuration-Dimmwert GH 7	0
IDE05145-ENG116041-Light configuration-Dimmwert GH 8	0
IDE05145-ENG116060-Light configuration-Dimmwert GH 9	0
IDE05145-ENG115875-Light configuration-Fehlerort mittleres Byte DTC-DFCC 0	14
IDE05145-ENG115894-Light configuration-Fehlerort mittleres Byte DTC-DFCC 1	15
IDE05145-ENG116064-Light configuration-Fehlerort mittleres Byte DTC-DFCC 10	1E
IDE05145-ENG116083-Light configuration-Fehlerort mittleres Byte DTC-DFCC 11	1F
IDE05145-ENG116102-Light configuration-Fehlerort mittleres Byte DTC-DFCC 12	22
IDE05145-ENG116121-Light configuration-Fehlerort mittleres Byte DTC-DFCC 13	23
IDE05145-ENG116140-Light configuration-Fehlerort mittleres Byte DTC-DFCC 14	0
IDE05145-ENG116159-Light configuration-Fehlerort mittleres Byte DTC-DFCC 15	0
IDE05145-ENG116178-Light configuration-Fehlerort mittleres Byte DTC-DFCC 16	0
IDE05145-ENG116197-Light configuration-Fehlerort mittleres Byte DTC-DFCC 17	0
IDE05145-ENG116216-Light configuration-Fehlerort mittleres Byte DTC-DFCC 18	16
IDE05145-ENG116235-Light configuration-Fehlerort mittleres Byte DTC-DFCC 19	18
IDE05145-ENG115912-Light configuration-Fehlerort mittleres Byte DTC-DFCC 2	4A
IDE05145-ENG116254-Light configuration-Fehlerort mittleres Byte DTC-DFCC 20	39
IDE05145-ENG116273-Light configuration-Fehlerort mittleres Byte DTC-DFCC 21	3A
IDE05145-ENG116292-Light configuration-Fehlerort mittleres Byte DTC-DFCC 22	2C
IDE05145-ENG116311-Light configuration-Fehlerort mittleres Byte DTC-DFCC 23	29
IDE05145-ENG116330-Light configuration-Fehlerort mittleres Byte DTC-DFCC 24	2A
IDE05145-ENG116349-Light configuration-Fehlerort mittleres Byte DTC-DFCC 25	30
IDE05145-ENG116368-Light configuration-Fehlerort mittleres Byte DTC-DFCC 26	2F
IDE05145-ENG116387-Light configuration-Fehlerort mittleres Byte DTC-DFCC 27	0
IDE05145-ENG116406-Light configuration-Fehlerort mittleres Byte DTC-DFCC 28	31
IDE05145-ENG116425-Light configuration-Fehlerort mittleres Byte DTC-DFCC 29	32
IDE05145-ENG115931-Light configuration-Fehlerort mittleres Byte DTC-DFCC 3	4C
IDE05145-ENG116444-Light configuration-Fehlerort mittleres Byte DTC-DFCC 30	2
IDE05145-ENG116463-Light configuration-Fehlerort mittleres Byte DTC-DFCC 31	0
IDE05145-ENG116482-Light configuration-Fehlerort mittleres Byte DTC-DFCC 32	0
IDE05145-ENG116501-Light configuration-Fehlerort mittleres Byte DTC-DFCC 33	0
IDE05145-ENG116520-Light configuration-Fehlerort mittleres Byte DTC-DFCC 34	0
IDE05145-ENG115950-Light configuration-Fehlerort mittleres Byte DTC-DFCC 4	49
IDE05145-ENG115969-Light configuration-Fehlerort mittleres Byte DTC-DFCC 5	4B
IDE05145-ENG115988-Light configuration-Fehlerort mittleres Byte DTC-DFCC 6	1A
IDE05145-ENG116007-Light configuration-Fehlerort mittleres Byte DTC-DFCC 7	1B
IDE05145-ENG116026-Light configuration-Fehlerort mittleres Byte DTC-DFCC 8	26
IDE05145-ENG116045-Light configuration-Fehlerort mittleres Byte DTC-DFCC 9	27
IDE05145-ENG115873-Light configuration-Lasttyp 0	12 - Blinkleuchten
IDE05145-ENG115892-Light configuration-Lasttyp 1	12 - Blinkleuchten
IDE05145-ENG116062-Light configuration-Lasttyp 10	2 - Shutter: Diagnosesensierung f・ 'LED low'
IDE05145-ENG116081-Light configuration-Lasttyp 11	2 - Shutter: Diagnosesensierung f・ 'LED low'
IDE05145-ENG116100-Light configuration-Lasttyp 12	10 - allgemeine Scheinwerfer
IDE05145-ENG116119-Light configuration-Lasttyp 13	10 - allgemeine Scheinwerfer
IDE05145-ENG116138-Light configuration-Lasttyp 14	not active
IDE05145-ENG116157-Light configuration-Lasttyp 15	not active
IDE05145-ENG116176-Light configuration-Lasttyp 16	not active
IDE05145-ENG116195-Light configuration-Lasttyp 17	not active
IDE05145-ENG116214-Light configuration-Lasttyp 18	12 - Blinkleuchten
IDE05145-ENG116233-Light configuration-Lasttyp 19	12 - Blinkleuchten
IDE05145-ENG115910-Light configuration-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116252-Light configuration-Lasttyp 20	13 - Bremsleuchten
IDE05145-ENG116271-Light configuration-Lasttyp 21	13 - Bremsleuchten
IDE05145-ENG116290-Light configuration-Lasttyp 22	42 - LED dritte Bremsleuchte
IDE05145-ENG116309-Light configuration-Lasttyp 23	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG116328-Light configuration-Lasttyp 24	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG116347-Light configuration-Lasttyp 25	43 - allgemeine LED
IDE05145-ENG116366-Light configuration-Lasttyp 26	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG116385-Light configuration-Lasttyp 27	not active
IDE05145-ENG116404-Light configuration-Lasttyp 28	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG116423-Light configuration-Lasttyp 29	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG115929-Light configuration-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
IDE05145-ENG116442-Light configuration-Lasttyp 30	36 - LED Kleinleistung
IDE05145-ENG116461-Light configuration-Lasttyp 31	not active
IDE05145-ENG116480-Light configuration-Lasttyp 32	not active
IDE05145-ENG116499-Light configuration-Lasttyp 33	not active
IDE05145-ENG116518-Light configuration-Lasttyp 34	not active
IDE05145-ENG115948-Light configuration-Lasttyp 4	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG115967-Light configuration-Lasttyp 5	9 - allgemeine Gl・lampe 27W: auch H15
IDE05145-ENG115986-Light configuration-Lasttyp 6	3 - Xenon Abblendlicht
IDE05145-ENG116005-Light configuration-Lasttyp 7	3 - Xenon Abblendlicht
IDE05145-ENG116024-Light configuration-Lasttyp 8	36 - LED Kleinleistung
IDE05145-ENG116043-Light configuration-Lasttyp 9	36 - LED Kleinleistung
IDE05145-ENG115879-Light configuration-Lichtansteuerung HD AB 0	Always
IDE05145-ENG115898-Light configuration-Lichtansteuerung HD AB 1	Always
IDE05145-ENG116068-Light configuration-Lichtansteuerung HD AB 10	Always
IDE05145-ENG116087-Light configuration-Lichtansteuerung HD AB 11	Always
IDE05145-ENG116106-Light configuration-Lichtansteuerung HD AB 12	Always
IDE05145-ENG116125-Light configuration-Lichtansteuerung HD AB 13	Always
IDE05145-ENG116144-Light configuration-Lichtansteuerung HD AB 14	Always
IDE05145-ENG116163-Light configuration-Lichtansteuerung HD AB 15	Always
IDE05145-ENG116182-Light configuration-Lichtansteuerung HD AB 16	Always
IDE05145-ENG116201-Light configuration-Lichtansteuerung HD AB 17	Always
IDE05145-ENG116220-Light configuration-Lichtansteuerung HD AB 18	Always
IDE05145-ENG116239-Light configuration-Lichtansteuerung HD AB 19	Always
IDE05145-ENG115916-Light configuration-Lichtansteuerung HD AB 2	Always
IDE05145-ENG116258-Light configuration-Lichtansteuerung HD AB 20	Always
IDE05145-ENG116277-Light configuration-Lichtansteuerung HD AB 21	Always
IDE05145-ENG116296-Light configuration-Lichtansteuerung HD AB 22	Always
IDE05145-ENG116315-Light configuration-Lichtansteuerung HD AB 23	only_if_closed
IDE05145-ENG116334-Light configuration-Lichtansteuerung HD AB 24	only_if_closed
IDE05145-ENG116353-Light configuration-Lichtansteuerung HD AB 25	Always
IDE05145-ENG116372-Light configuration-Lichtansteuerung HD AB 26	only_if_closed
IDE05145-ENG116391-Light configuration-Lichtansteuerung HD AB 27	Always
IDE05145-ENG116410-Light configuration-Lichtansteuerung HD AB 28	only_if_closed
IDE05145-ENG116430-Light configuration-Lichtansteuerung HD AB 29	only_if_closed
IDE05145-ENG115935-Light configuration-Lichtansteuerung HD AB 3	Always
IDE05145-ENG116448-Light configuration-Lichtansteuerung HD AB 30	Always
IDE05145-ENG116467-Light configuration-Lichtansteuerung HD AB 31	Always
IDE05145-ENG116486-Light configuration-Lichtansteuerung HD AB 32	Always
IDE05145-ENG116505-Light configuration-Lichtansteuerung HD AB 33	Always
IDE05145-ENG116524-Light configuration-Lichtansteuerung HD AB 34	Always
IDE05145-ENG115954-Light configuration-Lichtansteuerung HD AB 4	Always
IDE05145-ENG115973-Light configuration-Lichtansteuerung HD AB 5	Always
IDE05145-ENG115992-Light configuration-Lichtansteuerung HD AB 6	Always
IDE05145-ENG116011-Light configuration-Lichtansteuerung HD AB 7	Always
IDE05145-ENG116030-Light configuration-Lichtansteuerung HD AB 8	Always
IDE05145-ENG116049-Light configuration-Lichtansteuerung HD AB 9	Always
IDE05145-ENG116199-Light configuration-Lichtfunktion  B 17	0
IDE05145-ENG116126-Light configuration-Lichtfunktion  C 13	0
IDE05145-ENG115876-Light configuration-Lichtfunktion A 0	2
IDE05145-ENG115895-Light configuration-Lichtfunktion A 1	4
IDE05145-ENG116065-Light configuration-Lichtfunktion A 10	13
IDE05145-ENG116084-Light configuration-Lichtfunktion A 11	14
IDE05145-ENG116103-Light configuration-Lichtfunktion A 12	18
IDE05145-ENG116122-Light configuration-Lichtfunktion A 13	19
IDE05145-ENG116141-Light configuration-Lichtfunktion A 14	0
IDE05145-ENG116160-Light configuration-Lichtfunktion A 15	0
IDE05145-ENG116179-Light configuration-Lichtfunktion A 16	0
IDE05145-ENG116198-Light configuration-Lichtfunktion A 17	0
IDE05145-ENG116217-Light configuration-Lichtfunktion A 18	2
IDE05145-ENG116236-Light configuration-Lichtfunktion A 19	4
IDE05145-ENG115913-Light configuration-Lichtfunktion A 2	20
IDE05145-ENG116255-Light configuration-Lichtfunktion A 20	24
IDE05145-ENG116274-Light configuration-Lichtfunktion A 21	24
IDE05145-ENG116293-Light configuration-Lichtfunktion A 22	24
IDE05145-ENG116312-Light configuration-Lichtfunktion A 23	8
IDE05145-ENG116331-Light configuration-Lichtfunktion A 24	8
IDE05145-ENG116350-Light configuration-Lichtfunktion A 25	8
IDE05145-ENG116369-Light configuration-Lichtfunktion A 26	28
IDE05145-ENG116388-Light configuration-Lichtfunktion A 27	0
IDE05145-ENG116407-Light configuration-Lichtfunktion A 28	25
IDE05145-ENG116426-Light configuration-Lichtfunktion A 29	25
IDE05145-ENG115932-Light configuration-Lichtfunktion A 3	20
IDE05145-ENG116445-Light configuration-Lichtfunktion A 30	43
IDE05145-ENG116464-Light configuration-Lichtfunktion A 31	0
IDE05145-ENG116483-Light configuration-Lichtfunktion A 32	0
IDE05145-ENG116502-Light configuration-Lichtfunktion A 33	0
IDE05145-ENG116521-Light configuration-Lichtfunktion A 34	0
IDE05145-ENG115951-Light configuration-Lichtfunktion A 4	20
IDE05145-ENG115970-Light configuration-Lichtfunktion A 5	20
IDE05145-ENG115989-Light configuration-Lichtfunktion A 6	11
IDE05145-ENG116008-Light configuration-Lichtfunktion A 7	12
IDE05145-ENG116027-Light configuration-Lichtfunktion A 8	8
IDE05145-ENG116046-Light configuration-Lichtfunktion A 9	8
IDE05145-ENG115877-Light configuration-Lichtfunktion B 0	0
IDE05145-ENG115896-Light configuration-Lichtfunktion B 1	0
IDE05145-ENG116066-Light configuration-Lichtfunktion B 10	15
IDE05145-ENG116085-Light configuration-Lichtfunktion B 11	15
IDE05145-ENG116104-Light configuration-Lichtfunktion B 12	0
IDE05145-ENG116123-Light configuration-Lichtfunktion B 13	0
IDE05145-ENG116142-Light configuration-Lichtfunktion B 14	0
IDE05145-ENG116161-Light configuration-Lichtfunktion B 15	0
IDE05145-ENG116180-Light configuration-Lichtfunktion B 16	0
IDE05145-ENG116218-Light configuration-Lichtfunktion B 18	0
IDE05145-ENG116237-Light configuration-Lichtfunktion B 19	0
IDE05145-ENG115914-Light configuration-Lichtfunktion B 2	0
IDE05145-ENG116256-Light configuration-Lichtfunktion B 20	0
IDE05145-ENG116275-Light configuration-Lichtfunktion B 21	0
IDE05145-ENG116294-Light configuration-Lichtfunktion B 22	0
IDE05145-ENG116313-Light configuration-Lichtfunktion B 23	0
IDE05145-ENG116332-Light configuration-Lichtfunktion B 24	0
IDE05145-ENG116351-Light configuration-Lichtfunktion B 25	0
IDE05145-ENG116370-Light configuration-Lichtfunktion B 26	0
IDE05145-ENG116389-Light configuration-Lichtfunktion B 27	0
IDE05145-ENG116408-Light configuration-Lichtfunktion B 28	0
IDE05145-ENG116427-Light configuration-Lichtfunktion B 29	0
IDE05145-ENG115933-Light configuration-Lichtfunktion B 3	0
IDE05145-ENG116446-Light configuration-Lichtfunktion B 30	0
IDE05145-ENG116465-Light configuration-Lichtfunktion B 31	0
IDE05145-ENG116484-Light configuration-Lichtfunktion B 32	0
IDE05145-ENG116503-Light configuration-Lichtfunktion B 33	0
IDE05145-ENG116522-Light configuration-Lichtfunktion B 34	0
IDE05145-ENG115952-Light configuration-Lichtfunktion B 4	0
IDE05145-ENG115971-Light configuration-Lichtfunktion B 5	0
IDE05145-ENG115990-Light configuration-Lichtfunktion B 6	15
IDE05145-ENG116009-Light configuration-Lichtfunktion B 7	15
IDE05145-ENG116028-Light configuration-Lichtfunktion B 8	9
IDE05145-ENG116047-Light configuration-Lichtfunktion B 9	10
IDE05145-ENG115880-Light configuration-Lichtfunktion C 0	0
IDE05145-ENG115899-Light configuration-Lichtfunktion C 1	0
IDE05145-ENG116069-Light configuration-Lichtfunktion C 10	0
IDE05145-ENG116088-Light configuration-Lichtfunktion C 11	0
IDE05145-ENG116107-Light configuration-Lichtfunktion C 12	0
IDE05145-ENG116145-Light configuration-Lichtfunktion C 14	0
IDE05145-ENG116164-Light configuration-Lichtfunktion C 15	0
IDE05145-ENG116183-Light configuration-Lichtfunktion C 16	0
IDE05145-ENG116202-Light configuration-Lichtfunktion C 17	0
IDE05145-ENG116221-Light configuration-Lichtfunktion C 18	0
IDE05145-ENG116240-Light configuration-Lichtfunktion C 19	0
IDE05145-ENG115917-Light configuration-Lichtfunktion C 2	8
IDE05145-ENG116259-Light configuration-Lichtfunktion C 20	8
IDE05145-ENG116278-Light configuration-Lichtfunktion C 21	8
IDE05145-ENG116297-Light configuration-Lichtfunktion C 22	0
IDE05145-ENG116316-Light configuration-Lichtfunktion C 23	0
IDE05145-ENG116335-Light configuration-Lichtfunktion C 24	0
IDE05145-ENG116354-Light configuration-Lichtfunktion C 25	0
IDE05145-ENG116373-Light configuration-Lichtfunktion C 26	0
IDE05145-ENG116392-Light configuration-Lichtfunktion C 27	0
IDE05145-ENG116411-Light configuration-Lichtfunktion C 28	0
IDE05145-ENG116429-Light configuration-Lichtfunktion C 29	0
IDE05145-ENG115936-Light configuration-Lichtfunktion C 3	8
IDE05145-ENG116449-Light configuration-Lichtfunktion C 30	0
IDE05145-ENG116468-Light configuration-Lichtfunktion C 31	0
IDE05145-ENG116487-Light configuration-Lichtfunktion C 32	0
IDE05145-ENG116506-Light configuration-Lichtfunktion C 33	0
IDE05145-ENG116525-Light configuration-Lichtfunktion C 34	0
IDE05145-ENG115955-Light configuration-Lichtfunktion C 4	8
IDE05145-ENG115974-Light configuration-Lichtfunktion C 5	8
IDE05145-ENG115993-Light configuration-Lichtfunktion C 6	0
IDE05145-ENG116012-Light configuration-Lichtfunktion C 7	0
IDE05145-ENG116031-Light configuration-Lichtfunktion C 8	0
IDE05145-ENG116050-Light configuration-Lichtfunktion C 9	0
IDE05145-ENG115881-Light configuration-Lichtfunktion D 0	0
IDE05145-ENG115900-Light configuration-Lichtfunktion D 1	0
IDE05145-ENG116070-Light configuration-Lichtfunktion D 10	0
IDE05145-ENG116089-Light configuration-Lichtfunktion D 11	0
IDE05145-ENG116108-Light configuration-Lichtfunktion D 12	0
IDE05145-ENG116127-Light configuration-Lichtfunktion D 13	0
IDE05145-ENG116146-Light configuration-Lichtfunktion D 14	0
IDE05145-ENG116165-Light configuration-Lichtfunktion D 15	0
IDE05145-ENG116184-Light configuration-Lichtfunktion D 16	0
IDE05145-ENG116203-Light configuration-Lichtfunktion D 17	0
IDE05145-ENG116222-Light configuration-Lichtfunktion D 18	0
IDE05145-ENG116241-Light configuration-Lichtfunktion D 19	0
IDE05145-ENG115918-Light configuration-Lichtfunktion D 2	9
IDE05145-ENG116260-Light configuration-Lichtfunktion D 20	9
IDE05145-ENG116279-Light configuration-Lichtfunktion D 21	10
IDE05145-ENG116298-Light configuration-Lichtfunktion D 22	0
IDE05145-ENG116317-Light configuration-Lichtfunktion D 23	0
IDE05145-ENG116336-Light configuration-Lichtfunktion D 24	0
IDE05145-ENG116355-Light configuration-Lichtfunktion D 25	0
IDE05145-ENG116374-Light configuration-Lichtfunktion D 26	0
IDE05145-ENG116393-Light configuration-Lichtfunktion D 27	0
IDE05145-ENG116412-Light configuration-Lichtfunktion D 28	0
IDE05145-ENG116431-Light configuration-Lichtfunktion D 29	0
IDE05145-ENG115937-Light configuration-Lichtfunktion D 3	10
IDE05145-ENG116450-Light configuration-Lichtfunktion D 30	0
IDE05145-ENG116469-Light configuration-Lichtfunktion D 31	0
IDE05145-ENG116488-Light configuration-Lichtfunktion D 32	0
IDE05145-ENG116507-Light configuration-Lichtfunktion D 33	0
IDE05145-ENG116526-Light configuration-Lichtfunktion D 34	0
IDE05145-ENG115956-Light configuration-Lichtfunktion D 4	9
IDE05145-ENG115975-Light configuration-Lichtfunktion D 5	10
IDE05145-ENG115994-Light configuration-Lichtfunktion D 6	0
IDE05145-ENG116013-Light configuration-Lichtfunktion D 7	0
IDE05145-ENG116032-Light configuration-Lichtfunktion D 8	0
IDE05145-ENG116051-Light configuration-Lichtfunktion D 9	0
IDE05145-ENG115884-Light configuration-Lichtfunktion E 0	0
IDE05145-ENG115903-Light configuration-Lichtfunktion E 1	0
IDE05145-ENG116073-Light configuration-Lichtfunktion E 10	0
IDE05145-ENG116092-Light configuration-Lichtfunktion E 11	0
IDE05145-ENG116111-Light configuration-Lichtfunktion E 12	0
IDE05145-ENG116130-Light configuration-Lichtfunktion E 13	0
IDE05145-ENG116149-Light configuration-Lichtfunktion E 14	0
IDE05145-ENG116168-Light configuration-Lichtfunktion E 15	0
IDE05145-ENG116187-Light configuration-Lichtfunktion E 16	0
IDE05145-ENG116206-Light configuration-Lichtfunktion E 17	0
IDE05145-ENG116225-Light configuration-Lichtfunktion E 18	0
IDE05145-ENG116244-Light configuration-Lichtfunktion E 19	0
IDE05145-ENG115921-Light configuration-Lichtfunktion E 2	0
IDE05145-ENG116263-Light configuration-Lichtfunktion E 20	0
IDE05145-ENG116282-Light configuration-Lichtfunktion E 21	0
IDE05145-ENG116301-Light configuration-Lichtfunktion E 22	0
IDE05145-ENG116320-Light configuration-Lichtfunktion E 23	0
IDE05145-ENG116339-Light configuration-Lichtfunktion E 24	0
IDE05145-ENG116358-Light configuration-Lichtfunktion E 25	0
IDE05145-ENG116377-Light configuration-Lichtfunktion E 26	0
IDE05145-ENG116396-Light configuration-Lichtfunktion E 27	0
IDE05145-ENG116415-Light configuration-Lichtfunktion E 28	0
IDE05145-ENG116434-Light configuration-Lichtfunktion E 29	0
IDE05145-ENG115940-Light configuration-Lichtfunktion E 3	0
IDE05145-ENG116453-Light configuration-Lichtfunktion E 30	0
IDE05145-ENG116472-Light configuration-Lichtfunktion E 31	0
IDE05145-ENG116491-Light configuration-Lichtfunktion E 32	0
IDE05145-ENG116510-Light configuration-Lichtfunktion E 33	0
IDE05145-ENG116529-Light configuration-Lichtfunktion E 34	0
IDE05145-ENG115959-Light configuration-Lichtfunktion E 4	0
IDE05145-ENG115978-Light configuration-Lichtfunktion E 5	0
IDE05145-ENG115997-Light configuration-Lichtfunktion E 6	0
IDE05145-ENG116016-Light configuration-Lichtfunktion E 7	0
IDE05145-ENG116035-Light configuration-Lichtfunktion E 8	0
IDE05145-ENG116054-Light configuration-Lichtfunktion E 9	0
IDE05145-ENG115885-Light configuration-Lichtfunktion F 0	0
IDE05145-ENG115904-Light configuration-Lichtfunktion F 1	0
IDE05145-ENG116074-Light configuration-Lichtfunktion F 10	0
IDE05145-ENG116093-Light configuration-Lichtfunktion F 11	0
IDE05145-ENG116112-Light configuration-Lichtfunktion F 12	0
IDE05145-ENG116131-Light configuration-Lichtfunktion F 13	0
IDE05145-ENG116150-Light configuration-Lichtfunktion F 14	0
IDE05145-ENG116169-Light configuration-Lichtfunktion F 15	0
IDE05145-ENG116188-Light configuration-Lichtfunktion F 16	0
IDE05145-ENG116207-Light configuration-Lichtfunktion F 17	0
IDE05145-ENG116226-Light configuration-Lichtfunktion F 18	0
IDE05145-ENG116245-Light configuration-Lichtfunktion F 19	0
IDE05145-ENG115922-Light configuration-Lichtfunktion F 2	0
IDE05145-ENG116264-Light configuration-Lichtfunktion F 20	0
IDE05145-ENG116283-Light configuration-Lichtfunktion F 21	0
IDE05145-ENG116302-Light configuration-Lichtfunktion F 22	0
IDE05145-ENG116321-Light configuration-Lichtfunktion F 23	0
IDE05145-ENG116340-Light configuration-Lichtfunktion F 24	0
IDE05145-ENG116359-Light configuration-Lichtfunktion F 25	0
IDE05145-ENG116378-Light configuration-Lichtfunktion F 26	0
IDE05145-ENG116397-Light configuration-Lichtfunktion F 27	0
IDE05145-ENG116416-Light configuration-Lichtfunktion F 28	0
IDE05145-ENG116435-Light configuration-Lichtfunktion F 29	0
IDE05145-ENG116454-Light configuration-Lichtfunktion F 30	0
IDE05145-ENG116473-Light configuration-Lichtfunktion F 31	0
IDE05145-ENG116492-Light configuration-Lichtfunktion F 32	0
IDE05145-ENG116511-Light configuration-Lichtfunktion F 33	0
IDE05145-ENG116530-Light configuration-Lichtfunktion F 34	0
IDE05145-ENG115960-Light configuration-Lichtfunktion F 4	0
IDE05145-ENG115998-Light configuration-Lichtfunktion F 6	0
IDE05145-ENG116017-Light configuration-Lichtfunktion F 7	0
IDE05145-ENG116036-Light configuration-Lichtfunktion F 8	0
IDE05145-ENG116055-Light configuration-Lichtfunktion F 9	0
IDE05145-ENG115941-Light configuration-Lichtfunktion F3	0
IDE05145-ENG115979-Light configuration-Lichtfunktion F5	0
IDE05145-ENG115888-Light configuration-Lichtfunktion G 0	0
IDE05145-ENG115907-Light configuration-Lichtfunktion G 1	0
IDE05145-ENG116077-Light configuration-Lichtfunktion G 10	0
IDE05145-ENG116096-Light configuration-Lichtfunktion G 11	0
IDE05145-ENG116115-Light configuration-Lichtfunktion G 12	0
IDE05145-ENG116134-Light configuration-Lichtfunktion G 13	0
IDE05145-ENG116153-Light configuration-Lichtfunktion G 14	0
IDE05145-ENG116172-Light configuration-Lichtfunktion G 15	0
IDE05145-ENG116191-Light configuration-Lichtfunktion G 16	0
IDE05145-ENG116210-Light configuration-Lichtfunktion G 17	0
IDE05145-ENG116229-Light configuration-Lichtfunktion G 18	0
IDE05145-ENG116248-Light configuration-Lichtfunktion G 19	0
IDE05145-ENG115925-Light configuration-Lichtfunktion G 2	0
IDE05145-ENG116267-Light configuration-Lichtfunktion G 20	0
IDE05145-ENG116286-Light configuration-Lichtfunktion G 21	0
IDE05145-ENG116305-Light configuration-Lichtfunktion G 22	0
IDE05145-ENG116324-Light configuration-Lichtfunktion G 23	0
IDE05145-ENG116343-Light configuration-Lichtfunktion G 24	0
IDE05145-ENG116362-Light configuration-Lichtfunktion G 25	0
IDE05145-ENG116381-Light configuration-Lichtfunktion G 26	0
IDE05145-ENG116400-Light configuration-Lichtfunktion G 27	0
IDE05145-ENG116419-Light configuration-Lichtfunktion G 28	0
IDE05145-ENG116438-Light configuration-Lichtfunktion G 29	0
IDE05145-ENG115944-Light configuration-Lichtfunktion G 3	0
IDE05145-ENG116457-Light configuration-Lichtfunktion G 30	0
IDE05145-ENG116476-Light configuration-Lichtfunktion G 31	0
IDE05145-ENG116495-Light configuration-Lichtfunktion G 32	0
IDE05145-ENG116514-Light configuration-Lichtfunktion G 33	0
IDE05145-ENG116533-Light configuration-Lichtfunktion G 34	0
IDE05145-ENG115963-Light configuration-Lichtfunktion G 4	0
IDE05145-ENG115982-Light configuration-Lichtfunktion G 5	0
IDE05145-ENG116001-Light configuration-Lichtfunktion G 6	0
IDE05145-ENG116020-Light configuration-Lichtfunktion G 7	0
IDE05145-ENG116039-Light configuration-Lichtfunktion G 8	0
IDE05145-ENG116058-Light configuration-Lichtfunktion G 9	0
IDE05145-ENG115889-Light configuration-Lichtfunktion H 0	0
IDE05145-ENG116549-Light configuration-Lichtfunktion H 1	0
IDE05145-ENG116078-Light configuration-Lichtfunktion H 10	0
IDE05145-ENG116097-Light configuration-Lichtfunktion H 11	0
IDE05145-ENG116116-Light configuration-Lichtfunktion H 12	0
IDE05145-ENG116135-Light configuration-Lichtfunktion H 13	0
IDE05145-ENG116154-Light configuration-Lichtfunktion H 14	0
IDE05145-ENG116173-Light configuration-Lichtfunktion H 15	0
IDE05145-ENG116192-Light configuration-Lichtfunktion H 16	0
IDE05145-ENG116211-Light configuration-Lichtfunktion H 17	0
IDE05145-ENG116230-Light configuration-Lichtfunktion H 18	0
IDE05145-ENG116249-Light configuration-Lichtfunktion H 19	0
IDE05145-ENG115926-Light configuration-Lichtfunktion H 2	0
IDE05145-ENG116268-Light configuration-Lichtfunktion H 20	0
IDE05145-ENG116287-Light configuration-Lichtfunktion H 21	0
IDE05145-ENG116306-Light configuration-Lichtfunktion H 22	0
IDE05145-ENG116325-Light configuration-Lichtfunktion H 23	0
IDE05145-ENG116344-Light configuration-Lichtfunktion H 24	0
IDE05145-ENG116363-Light configuration-Lichtfunktion H 25	0
IDE05145-ENG116382-Light configuration-Lichtfunktion H 26	0
IDE05145-ENG116401-Light configuration-Lichtfunktion H 27	0
IDE05145-ENG116420-Light configuration-Lichtfunktion H 28	0
IDE05145-ENG116439-Light configuration-Lichtfunktion H 29	0
IDE05145-ENG115945-Light configuration-Lichtfunktion H 3	0
IDE05145-ENG116458-Light configuration-Lichtfunktion H 30	0
IDE05145-ENG116477-Light configuration-Lichtfunktion H 31	0
IDE05145-ENG116496-Light configuration-Lichtfunktion H 32	0
IDE05145-ENG116515-Light configuration-Lichtfunktion H 33	0
IDE05145-ENG116534-Light configuration-Lichtfunktion H 34	0
IDE05145-ENG115964-Light configuration-Lichtfunktion H 4	0
IDE05145-ENG115983-Light configuration-Lichtfunktion H 5	0
IDE05145-ENG116002-Light configuration-Lichtfunktion H 6	0
IDE05145-ENG116021-Light configuration-Lichtfunktion H 7	0
IDE05145-ENG116040-Light configuration-Lichtfunktion H 8	0
IDE05145-ENG116059-Light configuration-Lichtfunktion H 9	0
IDE06089-ENG116683-Seat heater level current consumption allocation-Sitzheizung Filterkonstante fuer Waermefluss	1 s
IDE06089-ENG116684-Seat heater level current consumption allocation-Sitzheizung Regeltemperaturkorrektur bei Waermefluss	0.00 ーC
IDE06089-ENG115738-Seat heater level current consumption allocation-Sitzheizung Stufe 1 obere Schaltschwelle	24.50 ーC
IDE06089-ENG115737-Seat heater level current consumption allocation-Sitzheizung Stufe 1 untere Schaltschwelle	23.50 ーC
IDE06089-ENG115740-Seat heater level current consumption allocation-Sitzheizung Stufe 2 obere Schaltschwelle	24.50 ーC
IDE06089-ENG115739-Seat heater level current consumption allocation-Sitzheizung Stufe 2 untere Schaltschwelle	23.50 ーC
IDE06089-ENG115742-Seat heater level current consumption allocation-Sitzheizung Stufe 3 obere Schaltschwelle	38.00 ーC
IDE06089-ENG115741-Seat heater level current consumption allocation-Sitzheizung Stufe 3 untere Schaltschwelle	37.00 ーC
IDE06089-ENG115744-Seat heater level current consumption allocation-Sitzheizung Stufe 4 obere Schaltschwelle	38.00 ーC
IDE06089-ENG115743-Seat heater level current consumption allocation-Sitzheizung Stufe 4 untere Schaltschwelle	37.00 ーC
IDE06089-ENG115746-Seat heater level current consumption allocation-Sitzheizung Stufe 5 obere Schaltschwelle	55.50 ーC
IDE06089-ENG115745-Seat heater level current consumption allocation-Sitzheizung Stufe 5 untere Schaltschwelle	54.50 ーC
IDE06089-ENG115748-Seat heater level current consumption allocation-Sitzheizung Stufe 6 obere Schaltschwelle	55.50 ーC
IDE06089-ENG115747-Seat heater level current consumption allocation-Sitzheizung Stufe 6 untere Schaltschwelle	54.50 ーC
IDE06096-ENG116596-Interior lighting-Innenlicht bei offenem Heckdeckel einschalten	active
IDE06096-ENG116597-Interior lighting-KL30G ohne PWM	not active
IDE06096-ENG116598-Interior lighting-KL58 Einschalten mit Rampe	not active
IDE06096-ENG116599-Interior lighting-KL58 Verriegelungsausschalten	not active
IDE06096-ENG116600-Interior lighting-Lichtsensor wirkt auf Suchbeleuchtung	active
IDE06096-ENG116595-Interior lighting-Menuesteuerung Ambientebeleuchtung Effektbeleuchtung	active
IDE06096-ENG115631-Interior lighting-Suchbeleuchtung Festwert	100%
IDE06425-Roller test bench mode: functional	not active
IDE06864-ENG115833-Daytime running lights-Fahrlicht bei Tag	not active
IDE06864-ENG115832-Daytime running lights-Scheinwerferferreinigungsansteuerung und Abblendlichtanzeige bei Dauerfahrlicht	not active
IDE06864-ENG116592-Daytime running lights-Standlicht aktiviert zusaetzlich Tagfahrlicht	not active
IDE06864-ENG116594-Daytime running lights-Tagfahrlicht Aktivierung durch BAP oder Bedienfolge moeglich	not active
IDE06864-ENG122184-Daytime running lights-Tagfahrlicht Dauerfahrlicht bei Handbremse abschalten	not active
IDE06864-ENG115734-Daytime running lights-Tagfahrlicht nur in Schalterstellung AUTO	not active
IDE06864-ENG116593-Daytime running lights-Tagfahrlicht-Dauerfahrlicht aktiviert zusaetzlich Standlicht	not active
IDE06864-ENG115733-Daytime running lights-Tagfahrlichtkontrollleuchte	not active
IDE06864-ENG116591-Daytime running lights-Werkseinstellung fuer Tagfahrlicht Freischaltung BAP / Bedienfolge	not active
IDE07007-ENG17819-A/C heater function via remote control-Anzahl zulaessiger Remotestarts	2
IDE07007-ENG17804-A/C heater function via remote control-RemoteStart Betrieb Dauer	10 min
IDE07356-Position during interval mode	31.494474 ー
IDE07470-ENG116719-After-run for park light-Bedingungen zur Beendigung des Standlichtnachlaufs	abschalten ・er Abschaltstufen des Energiemanagements
IDE07470-ENG116720-After-run for park light-Standlicht-Nachlaufzeit	30 min
IDE08542-IDE02021-Access control 2-Comfort closing	active
IDE08542-IDE02022-Access control 2-Comfort opening	not active
IDE08542-ENG116663-Access control 2-Fahrertuerbedienung Fensterheber oeffnen	active
IDE08542-ENG116664-Access control 2-Fahrertuerbedienung Fensterheber schliessen	active
IDE08542-ENG116662-Access control 2-FH SAD Kl15Aus Freigabezeit	600 s
IDE08542-ENG116648-Access control 2-Freigabenachlauf FH bei Kl 15 aus	active
IDE08542-ENG122993-Access control 2-Freigabenachlauf FH bei Tueroeffnen abbrechen	active
IDE08542-ENG116652-Access control 2-Funk Komfort oeffnen	active
IDE08542-ENG116651-Access control 2-Funk Komfort schliessen	active
IDE08542-ENG116658-Access control 2-Funk Spiegelanklappen	active
IDE08542-ENG116665-Access control 2-Funk Spiegelanklappung Modus	by look command via remote control key
IDE08542-ENG116653-Access control 2-Kessy Komfort oeffnen	No
IDE08542-ENG116654-Access control 2-Kessy Komfort schliessen	Yes
IDE08542-ENG116655-Access control 2-Kessy Komfortbedienung Reichweitenbegrenzung	No
IDE08542-ENG115670-Access control 2-Komfortbedienung global	active
IDE08542-ENG116642-Access control 2-Komfortoeffnen nur FH Fahrertuer	not active
IDE08542-ENG116660-Access control 2-Menuesteuerung Funk Spiegel anklappen	active
IDE08542-ENG122994-Access control 2-Menuesteuerung Komfortbedienung einstellbar	adjustable
IDE08542-ENG122186-Access control 2-Menuesteuerung Regenschliessen	not active
IDE08542-ENG116657-Access control 2-Menuesteuerung Spiegelabsenkung	active
IDE08542-ENG116659-Access control 2-Menuesteuerung synchrone Spiegelverstellung	active
IDE08542-ENG115671-Access control 2-Regenschlie゚en	not active
IDE08542-ENG116647-Access control 2-SAD Komfort oeffnen	not active
IDE08542-ENG116646-Access control 2-SAD Komfort schliessen	not active
IDE08542-ENG116661-Access control 2-SAD PreCrash Konturschliessen	active
IDE08542-ENG116645-Access control 2-SAD Richtung Komfortoeffnen	tilting
IDE08542-ENG116643-Access control 2-Schliesszylinder Komfort oeffnen	not active
IDE08542-ENG116644-Access control 2-Schliesszylinder Komfort schliessen	not active
IDE08542-ENG116650-Access control 2-Spiegelabsenkung bei Rueckwaertsfahrt	active
IDE08542-ENG116656-Access control 2-Spiegelverstellung Synchron	active
IDE08786-ENG116640-Assistance light functions-AFL Zeitverzoegerung	2000 ms
IDE08786-ENG115723-Assistance light functions-Assistenzfahrlicht bei Regen	active
IDE08786-ENG116639-Assistance light functions-Fernlichtassistent Reset	not active
IDE08786-ENG116638-Assistance light functions-Fernlichtassistent Zeitverzoegerungswert	0 ms
IDE08786-ENG115724-Assistance light functions-Lichtsensorempfindlichkeit	normal
IDE08786-ENG116637-Assistance light functions-Menuesteuerung Fernlichtassistent	Not Present
IDE08786-ENG116641-Assistance light functions-Menuesteuerung Fernlichtassistent Werkseinstellung	present
IDE08786-ENG116636-Assistance light functions-Notbremsanzeige NBA	active
IDE08787-ENG115810-Auxiliary functions-Klemmenfehler auf CAN ausgeben	active
IDE08787-ENG17821-Auxiliary functions-Menuesteuerung Garagentoroeffner	not active
IDE08787-ENG115809-Auxiliary functions-Signalhorn ohne KL15	active
IDE08787-ENG116672-Auxiliary functions-Spoiler Einfahrunterdrueckung nach manuellem Ausfahren	not active
IDE08787-ENG116671-Auxiliary functions-Spoiler Komfortsenken des Spoiler ueber Schliesszylinder FT	not active
IDE08788-ENG122212-Dyn. turn signal modes-ABBA_Blinken	not active
IDE08788-ENG121966-Dyn. turn signal modes-Crash flashing	not active
IDE08788-ENG122207-Dyn. turn signal modes-DWA_Alarm_Blinken	not active
IDE08788-ENG122206-Dyn. turn signal modes-DWA_Schaerfungsquittung	not active
IDE08788-ENG122208-Dyn. turn signal modes-Multi_kollisions_Blinken	not active
IDE08788-ENG122209-Dyn. turn signal modes-Notwarn_blinken_NBA_Phase_2	not active
IDE08788-ENG121967-Dyn. turn signal modes-Panic flashing	not active
IDE08788-ENG122211-Dyn. turn signal modes-Richtungs_blinken_links	not active
IDE08788-ENG122210-Dyn. turn signal modes-Richtungs_blinken_rechts	not active
IDE08788-ENG122201-Dyn. turn signal modes-Schluessel_Anlern_Blinken	not active
IDE08788-ENG121968-Dyn. turn signal modes-Taxi alarm flashing	not active
IDE08788-ENG122205-Dyn. turn signal modes-Telematikblinken_STS_Blinken	not active
IDE08788-ENG122202-Dyn. turn signal modes-UGDO_ Anlern_Blinken	not active
IDE08788-ENG122214-Dyn. turn signal modes-Warnblinken_Zuendung_AUS	not active
IDE08788-ENG122213-Dyn. turn signal modes-Warnblinken_Zuendung_EIN	not active
IDE08788-ENG122204-Dyn. turn signal modes-ZV_Blinken_auf	not active
IDE08788-ENG122203-Dyn. turn signal modes-ZV_Blinken_zu	not active
IDE10298-Alternating park position 1	7.494498 ー
IDE10299-Alternating park position 2	29.494476 ー
MAS00194-tbd	5 s
MAS00194-ENG123004-tbd-p_lx_regenlichtschwelle	6000 lx
MAS00194-ENG123002-tbd-p_n_regenlichtschwelle_high	12 s
MAS00194-ENG123003-tbd-p_n_regenlichtschwelle_low	6
MAS00194-ENG123005-tbd-p_t_regenlicht	30 s
MAS01490-Energy management	active
MAS05055-lower turn position	31.494474 ー
MAS05056-upper turn position	170.494336 ー
MAS05934-ENG116716-Convert. top oper.-Doppelpuls nur Verdeck	active
MAS05934-ENG116718-Convert. top oper.-Heckdeckel sperren bei Verdeckbetrieb	not active
MAS05934-ENG122193-Convert. top oper.-Heckschloss oeffnen durch Verdeck-SG	not active
MAS05934-ENG116711-Convert. top oper.-Komfortbedienung Verdeck global	active
MAS05934-ENG122189-Convert. top oper.-Komfortbedienung Verdeck oeffnen	active
MAS05934-ENG116712-Convert. top oper.-Komfortbedienung Verdeck schlie゚en	active
MAS05934-ENG116717-Convert. top oper.-Verdeck mit Schiebedach	not active
MAS05934-ENG122191-Convert. top oper.-Verdeck oeffnen via Funkfernbedienung	active
MAS05934-ENG122192-Convert. top oper.-Verdeck oeffnen via Kessy	active
MAS05934-ENG122190-Convert. top oper.-Verdeck oeffnen via Schliesszylinder	active
MAS05934-ENG116714-Convert. top oper.-Verdeck schlie゚en via Funkfernbedienung	active
MAS05934-ENG116715-Convert. top oper.-Verdeck schlie゚en via Kessy	active
MAS05934-ENG116713-Convert. top oper.-Verdeck schlie゚en via Schlie゚zylinder	active
ENG122934-erase_error_table	5570560
ENG122933-error_mask	0
ENG117283-Frontwaschfunktion	10
ENG99457-ENG117394-Head area heater-blower_speed	0
ENG99457-ENG98971-Head area heater-Temperature	-3
ENG116836-ENG115658-Innenbeleuchtung Abdimmen-x0	0 ms
ENG116836-ENG101574-Innenbeleuchtung Abdimmen-X1	200 ms
ENG116836-ENG115664-Innenbeleuchtung Abdimmen-x10	2000 ms
ENG116836-ENG99557-Innenbeleuchtung Abdimmen-X2	400 ms
ENG116836-ENG102140-Innenbeleuchtung Abdimmen-X3	600 ms
ENG116836-ENG102936-Innenbeleuchtung Abdimmen-X4	800 ms
ENG116836-ENG103548-Innenbeleuchtung Abdimmen-X5	1000 ms
ENG116836-ENG113992-Innenbeleuchtung Abdimmen-X6	1200 ms
ENG116836-ENG115661-Innenbeleuchtung Abdimmen-x7	1400 ms
ENG116836-ENG115662-Innenbeleuchtung Abdimmen-x8	1600 ms
ENG116836-ENG115663-Innenbeleuchtung Abdimmen-x9	1800 ms
ENG116836-ENG115659-Innenbeleuchtung Abdimmen-y0	100.00%
ENG116836-ENG99777-Innenbeleuchtung Abdimmen-Y1	72.00%
ENG116836-ENG115668-Innenbeleuchtung Abdimmen-y10	0.00%
ENG116836-ENG100480-Innenbeleuchtung Abdimmen-Y2	48.00%
ENG116836-ENG100773-Innenbeleuchtung Abdimmen-Y3	33.00%
ENG116836-ENG100631-Innenbeleuchtung Abdimmen-Y4	18.00%
ENG116836-ENG102174-Innenbeleuchtung Abdimmen-Y5	12.00%
ENG116836-ENG113993-Innenbeleuchtung Abdimmen-Y6	8.00%
ENG116836-ENG115665-Innenbeleuchtung Abdimmen-y7	6.00%
ENG116836-ENG115666-Innenbeleuchtung Abdimmen-y8	4.00%
ENG116836-ENG115667-Innenbeleuchtung Abdimmen-y9	2.00%
ENG116831-ENG115658-Innenbeleuchtung Fotosensor-x0	0
ENG116831-ENG101574-Innenbeleuchtung Fotosensor-X1	50
ENG116831-ENG115664-Innenbeleuchtung Fotosensor-x10	0
ENG116831-ENG99557-Innenbeleuchtung Fotosensor-X2	100
ENG116831-ENG102140-Innenbeleuchtung Fotosensor-X3	200
ENG116831-ENG102936-Innenbeleuchtung Fotosensor-X4	253
ENG116831-ENG103548-Innenbeleuchtung Fotosensor-X5	0
ENG116831-ENG113992-Innenbeleuchtung Fotosensor-X6	0
ENG116831-ENG115661-Innenbeleuchtung Fotosensor-x7	0
ENG116831-ENG115662-Innenbeleuchtung Fotosensor-x8	0
ENG116831-ENG115663-Innenbeleuchtung Fotosensor-x9	0
ENG116831-ENG115659-Innenbeleuchtung Fotosensor-y0	0 lx
ENG116831-ENG99777-Innenbeleuchtung Fotosensor-Y1	50 lx
ENG116831-ENG115668-Innenbeleuchtung Fotosensor-y10	0 lx
ENG116831-ENG100480-Innenbeleuchtung Fotosensor-Y2	100 lx
ENG116831-ENG100773-Innenbeleuchtung Fotosensor-Y3	200 lx
ENG116831-ENG100631-Innenbeleuchtung Fotosensor-Y4	500 lx
ENG116831-ENG102174-Innenbeleuchtung Fotosensor-Y5	0 lx
ENG116831-ENG113993-Innenbeleuchtung Fotosensor-Y6	0 lx
ENG116831-ENG115665-Innenbeleuchtung Fotosensor-y7	0 lx
ENG116831-ENG115666-Innenbeleuchtung Fotosensor-y8	0 lx
ENG116831-ENG115667-Innenbeleuchtung Fotosensor-y9	0 lx
ENG116835-ENG115658-Innenbeleuchtung Hochdimmen-x0	0 ms
ENG116835-ENG101574-Innenbeleuchtung Hochdimmen-X1	200 ms
ENG116835-ENG115664-Innenbeleuchtung Hochdimmen-x10	2000 ms
ENG116835-ENG99557-Innenbeleuchtung Hochdimmen-X2	400 ms
ENG116835-ENG102140-Innenbeleuchtung Hochdimmen-X3	600 ms
ENG116835-ENG102936-Innenbeleuchtung Hochdimmen-X4	800 ms
ENG116835-ENG103548-Innenbeleuchtung Hochdimmen-X5	1000 ms
ENG116835-ENG113992-Innenbeleuchtung Hochdimmen-X6	1200 ms
ENG116835-ENG115661-Innenbeleuchtung Hochdimmen-x7	1400 ms
ENG116835-ENG115662-Innenbeleuchtung Hochdimmen-x8	1600 ms
ENG116835-ENG115663-Innenbeleuchtung Hochdimmen-x9	1800 ms
ENG116835-ENG115659-Innenbeleuchtung Hochdimmen-y0	0.00%
ENG116835-ENG99777-Innenbeleuchtung Hochdimmen-Y1	1.00%
ENG116835-ENG115668-Innenbeleuchtung Hochdimmen-y10	100.00%
ENG116835-ENG100480-Innenbeleuchtung Hochdimmen-Y2	3.00%
ENG116835-ENG100773-Innenbeleuchtung Hochdimmen-Y3	5.00%
ENG116835-ENG100631-Innenbeleuchtung Hochdimmen-Y4	11.00%
ENG116835-ENG102174-Innenbeleuchtung Hochdimmen-Y5	22.00%
ENG116835-ENG113993-Innenbeleuchtung Hochdimmen-Y6	40.00%
ENG116835-ENG115665-Innenbeleuchtung Hochdimmen-y7	80.00%
ENG116835-ENG115666-Innenbeleuchtung Hochdimmen-y8	95.00%
ENG116835-ENG115667-Innenbeleuchtung Hochdimmen-y9	100.00%
ENG116975-ENG115658-Innenbeleuchtung KL 58xd log Bus-x0	0.00%
ENG116975-ENG101574-Innenbeleuchtung KL 58xd log Bus-X1	6.00%
ENG116975-ENG99557-Innenbeleuchtung KL 58xd log Bus-X2	16.00%
ENG116975-ENG102140-Innenbeleuchtung KL 58xd log Bus-X3	30.00%
ENG116975-ENG102936-Innenbeleuchtung KL 58xd log Bus-X4	60.00%
ENG116975-ENG103548-Innenbeleuchtung KL 58xd log Bus-X5	100.00%
ENG116975-ENG115659-Innenbeleuchtung KL 58xd log Bus-y0	10
ENG116975-ENG99777-Innenbeleuchtung KL 58xd log Bus-Y1	10
ENG116975-ENG100480-Innenbeleuchtung KL 58xd log Bus-Y2	100
ENG116975-ENG100773-Innenbeleuchtung KL 58xd log Bus-Y3	150
ENG116975-ENG100631-Innenbeleuchtung KL 58xd log Bus-Y4	220
ENG116975-ENG102174-Innenbeleuchtung KL 58xd log Bus-Y5	253
ENG116976-ENG115658-Innenbeleuchtung KL 58xd max-x0	0 lx
ENG116976-ENG101574-Innenbeleuchtung KL 58xd max-X1	8 lx
ENG116976-ENG99557-Innenbeleuchtung KL 58xd max-X2	200 lx
ENG116976-ENG102140-Innenbeleuchtung KL 58xd max-X3	300 lx
ENG116976-ENG102936-Innenbeleuchtung KL 58xd max-X4	500 lx
ENG116976-ENG115659-Innenbeleuchtung KL 58xd max-y0	16.00%
ENG116976-ENG99777-Innenbeleuchtung KL 58xd max-Y1	16.00%
ENG116976-ENG100480-Innenbeleuchtung KL 58xd max-Y2	100.00%
ENG116976-ENG100773-Innenbeleuchtung KL 58xd max-Y3	100.00%
ENG116976-ENG100631-Innenbeleuchtung KL 58xd max-Y4	100.00%
ENG116980-ENG115658-Innenbeleuchtung KL 58xd min-x0	0 lx
ENG116980-ENG101574-Innenbeleuchtung KL 58xd min-X1	8 lx
ENG116980-ENG99557-Innenbeleuchtung KL 58xd min-X2	220 lx
ENG116980-ENG102140-Innenbeleuchtung KL 58xd min-X3	300 lx
ENG116980-ENG102936-Innenbeleuchtung KL 58xd min-X4	500 lx
ENG116980-ENG115659-Innenbeleuchtung KL 58xd min-y0	6.00%
ENG116980-ENG99777-Innenbeleuchtung KL 58xd min-Y1	6.00%
ENG116980-ENG100480-Innenbeleuchtung KL 58xd min-Y2	100.00%
ENG116980-ENG100773-Innenbeleuchtung KL 58xd min-Y3	100.00%
ENG116980-ENG100631-Innenbeleuchtung KL 58xd min-Y4	100.00%
ENG116979-ENG115658-Innenbeleuchtung KL 58xd PWM-x0	0
ENG116979-ENG101574-Innenbeleuchtung KL 58xd PWM-X1	10
ENG116979-ENG99557-Innenbeleuchtung KL 58xd PWM-X2	50
ENG116979-ENG102140-Innenbeleuchtung KL 58xd PWM-X3	100
ENG116979-ENG102936-Innenbeleuchtung KL 58xd PWM-X4	220
ENG116979-ENG103548-Innenbeleuchtung KL 58xd PWM-X5	253
ENG116979-ENG115659-Innenbeleuchtung KL 58xd PWM-y0	2.00%
ENG116979-ENG99777-Innenbeleuchtung KL 58xd PWM-Y1	2.00%
ENG116979-ENG100480-Innenbeleuchtung KL 58xd PWM-Y2	6.00%
ENG116979-ENG100773-Innenbeleuchtung KL 58xd PWM-Y3	10.00%
ENG116979-ENG100631-Innenbeleuchtung KL 58xd PWM-Y4	80.00%
ENG116979-ENG102174-Innenbeleuchtung KL 58xd PWM-Y5	100.00%
ENG116972-ENG115658-Innenbeleuchtung KL 58xs max-x0	0 lx
ENG116972-ENG101574-Innenbeleuchtung KL 58xs max-X1	8 lx
ENG116972-ENG99557-Innenbeleuchtung KL 58xs max-X2	50 lx
ENG116972-ENG102140-Innenbeleuchtung KL 58xs max-X3	500 lx
ENG116972-ENG115659-Innenbeleuchtung KL 58xs max-y0	100.00%
ENG116972-ENG99777-Innenbeleuchtung KL 58xs max-Y1	100.00%
ENG116972-ENG100480-Innenbeleuchtung KL 58xs max-Y2	100.00%
ENG116972-ENG100773-Innenbeleuchtung KL 58xs max-Y3	100.00%
ENG116977-ENG115658-Innenbeleuchtung KL 58xs PWM-x0	0.00%
ENG116977-ENG101574-Innenbeleuchtung KL 58xs PWM-X1	50.00%
ENG116977-ENG99557-Innenbeleuchtung KL 58xs PWM-X2	100.00%
ENG116977-ENG115659-Innenbeleuchtung KL 58xs PWM-y0	0.00%
ENG116977-ENG99777-Innenbeleuchtung KL 58xs PWM-Y1	50.00%
ENG116977-ENG100480-Innenbeleuchtung KL 58xs PWM-Y2	100.00%
ENG116974-ENG115658-Innenbeleuchtung KL 58xt max-x0	0 lx
ENG116974-ENG101574-Innenbeleuchtung KL 58xt max-X1	8 lx
ENG116974-ENG99557-Innenbeleuchtung KL 58xt max-X2	50 lx
ENG116974-ENG102140-Innenbeleuchtung KL 58xt max-X3	500 lx
ENG116974-ENG115659-Innenbeleuchtung KL 58xt max-y0	100.00%
ENG116974-ENG99777-Innenbeleuchtung KL 58xt max-Y1	100.00%
ENG116974-ENG100480-Innenbeleuchtung KL 58xt max-Y2	100.00%
ENG116974-ENG100773-Innenbeleuchtung KL 58xt max-Y3	100.00%
ENG116973-ENG115658-Innenbeleuchtung KL 58xt min-x0	0 lx
ENG116973-ENG101574-Innenbeleuchtung KL 58xt min-X1	8 lx
ENG116973-ENG99557-Innenbeleuchtung KL 58xt min-X2	50 lx
ENG116973-ENG102140-Innenbeleuchtung KL 58xt min-X3	500 lx
ENG116973-ENG115659-Innenbeleuchtung KL 58xt min-y0	6.00%
ENG116973-ENG99777-Innenbeleuchtung KL 58xt min-Y1	6.00%
ENG116973-ENG100480-Innenbeleuchtung KL 58xt min-Y2	100.00%
ENG116973-ENG100773-Innenbeleuchtung KL 58xt min-Y3	100.00%
ENG116978-ENG115658-Innenbeleuchtung KL 58xt PWM-x0	0.00%
ENG116978-ENG101574-Innenbeleuchtung KL 58xt PWM-X1	50.00%
ENG116978-ENG99557-Innenbeleuchtung KL 58xt PWM-X2	100.00%
ENG116978-ENG115659-Innenbeleuchtung KL 58xt PWM-y0	0.00%
ENG116978-ENG99777-Innenbeleuchtung KL 58xt PWM-Y1	50.00%
ENG116978-ENG100480-Innenbeleuchtung KL 58xt PWM-Y2	100.00%
ENG116834-ENG115633-Innenbeleuchtung Tasterdimmung-Tasterdimmung x0	0 ms
ENG116834-ENG115634-Innenbeleuchtung Tasterdimmung-Tasterdimmung x1	100 ms
ENG116834-ENG115635-Innenbeleuchtung Tasterdimmung-Tasterdimmung x2	160 ms
ENG116834-ENG115636-Innenbeleuchtung Tasterdimmung-Tasterdimmung x3	200 ms
ENG116834-ENG115637-Innenbeleuchtung Tasterdimmung-Tasterdimmung x4	260 ms
ENG116834-ENG115638-Innenbeleuchtung Tasterdimmung-Tasterdimmung y0	1.00%
ENG116834-ENG115639-Innenbeleuchtung Tasterdimmung-Tasterdimmung y1	5
ENG116834-ENG115640-Innenbeleuchtung Tasterdimmung-Tasterdimmung y2	15
ENG116834-ENG115641-Innenbeleuchtung Tasterdimmung-Tasterdimmung y3	10
ENG116834-ENG115642-Innenbeleuchtung Tasterdimmung-Tasterdimmung y4	100
ENG17433-ENG115658-InnenbeleuchtungKL 58xs min-x0	0 lx
ENG17433-ENG101574-InnenbeleuchtungKL 58xs min-X1	8 lx
ENG17433-ENG99557-InnenbeleuchtungKL 58xs min-X2	50 lx
ENG17433-ENG102140-InnenbeleuchtungKL 58xs min-X3	500 lx
ENG17433-ENG115659-InnenbeleuchtungKL 58xs min-y0	6.00%
ENG17433-ENG99777-InnenbeleuchtungKL 58xs min-Y1	6.00%
ENG17433-ENG100480-InnenbeleuchtungKL 58xs min-Y2	100.00%
ENG17433-ENG100773-InnenbeleuchtungKL 58xs min-Y3	100.00%
ENG116936-ENG115883-Leuchte 0 BLK VL B36-Dimming Direction CD 0	maximize
ENG116936-ENG115887-Leuchte 0 BLK VL B36-Dimming Direction EF 0	maximize
ENG116936-ENG115891-Leuchte 0 BLK VL B36-Dimming Direction GH 0	maximize
ENG116936-ENG115878-Leuchte 0 BLK VL B36-Dimmwert AB 0	100
ENG116936-ENG115882-Leuchte 0 BLK VL B36-Dimmwert CD 0	0
ENG116936-ENG115886-Leuchte 0 BLK VL B36-Dimmwert EF 0	0
ENG116936-ENG115890-Leuchte 0 BLK VL B36-Dimmwert GH 0	0
ENG116936-ENG115875-Leuchte 0 BLK VL B36-Fehlerort mittleres Byte DTC-DFCC 0	14
ENG116936-ENG116547-Leuchte 0 BLK VL B36-Lampendefektbit Position 0	34
ENG116936-ENG115873-Leuchte 0 BLK VL B36-Lasttyp 0	12 - Blinkleuchten
ENG116936-ENG115879-Leuchte 0 BLK VL B36-Lichtansteuerung HD AB 0	Always
ENG116936-ENG115876-Leuchte 0 BLK VL B36-Lichtfunktion A 0	Blinken links Hellphase
ENG116936-ENG115877-Leuchte 0 BLK VL B36-Lichtfunktion B 0	not active
ENG116936-ENG115880-Leuchte 0 BLK VL B36-Lichtfunktion C 0	not active
ENG116936-ENG115881-Leuchte 0 BLK VL B36-Lichtfunktion D 0	not active
ENG116936-ENG115884-Leuchte 0 BLK VL B36-Lichtfunktion E 0	not active
ENG116936-ENG115885-Leuchte 0 BLK VL B36-Lichtfunktion F 0	not active
ENG116936-ENG115888-Leuchte 0 BLK VL B36-Lichtfunktion G 0	not active
ENG116936-ENG115889-Leuchte 0 BLK VL B36-Lichtfunktion H 0	not active
ENG116946-ENG116072-Leuchte10SHUTTER LB23-Dimming Direction CD 10	maximize
ENG116946-ENG116076-Leuchte10SHUTTER LB23-Dimming Direction EF 10	maximize
ENG116946-ENG116080-Leuchte10SHUTTER LB23-Dimming Direction GH 10	maximize
ENG116946-ENG116067-Leuchte10SHUTTER LB23-Dimmwert AB 10	127
ENG116946-ENG116071-Leuchte10SHUTTER LB23-Dimmwert CD 10	0
ENG116946-ENG116075-Leuchte10SHUTTER LB23-Dimmwert EF 10	0
ENG116946-ENG116079-Leuchte10SHUTTER LB23-Dimmwert GH 10	0
ENG116946-ENG116064-Leuchte10SHUTTER LB23-Fehlerort mittleres Byte DTC-DFCC 10	1E
ENG116946-ENG116560-Leuchte10SHUTTER LB23-Lampendefektbitposition 10	37
ENG116946-ENG116062-Leuchte10SHUTTER LB23-Lasttyp 10	2 - Shutter: Diagnosesensierung f・ 'LED low'
ENG116946-ENG116068-Leuchte10SHUTTER LB23-Lichtansteuerung HD AB 10	Always
ENG116946-ENG116065-Leuchte10SHUTTER LB23-Lichtfunktion A 10	Left high beam
ENG116946-ENG116066-Leuchte10SHUTTER LB23-Lichtfunktion B 10	Lichthupe generell
ENG116946-ENG116069-Leuchte10SHUTTER LB23-Lichtfunktion C 10	not active
ENG116946-ENG116070-Leuchte10SHUTTER LB23-Lichtfunktion D 10	not active
ENG116946-ENG116073-Leuchte10SHUTTER LB23-Lichtfunktion E 10	not active
ENG116946-ENG116074-Leuchte10SHUTTER LB23-Lichtfunktion F 10	not active
ENG116946-ENG116077-Leuchte10SHUTTER LB23-Lichtfunktion G 10	not active
ENG116946-ENG116078-Leuchte10SHUTTER LB23-Lichtfunktion H 10	not active
ENG116947-ENG116091-Leuchte11SHUTTER RB22-Dimming Direction CD 11	maximize
ENG116947-ENG116095-Leuchte11SHUTTER RB22-Dimming Direction EF 11	maximize
ENG116947-ENG116099-Leuchte11SHUTTER RB22-Dimming Direction GH 11	maximize
ENG116947-ENG116086-Leuchte11SHUTTER RB22-Dimmwert AB 11	127
ENG116947-ENG116090-Leuchte11SHUTTER RB22-Dimmwert CD 11	0
ENG116947-ENG116094-Leuchte11SHUTTER RB22-Dimmwert EF 11	0
ENG116947-ENG116098-Leuchte11SHUTTER RB22-Dimmwert GH 11	0
ENG116947-ENG116083-Leuchte11SHUTTER RB22-Fehlerort mittleres Byte DTC-DFCC 11	1F
ENG116947-ENG116561-Leuchte11SHUTTER RB22-Lampendefektbitposition 11	41
ENG116947-ENG116081-Leuchte11SHUTTER RB22-Lasttyp 11	2 - Shutter: Diagnosesensierung f・ 'LED low'
ENG116947-ENG116087-Leuchte11SHUTTER RB22-Lichtansteuerung HD AB 11	Always
ENG116947-ENG116084-Leuchte11SHUTTER RB22-Lichtfunktion A 11	Right high beam
ENG116947-ENG116085-Leuchte11SHUTTER RB22-Lichtfunktion B 11	Lichthupe generell
ENG116947-ENG116088-Leuchte11SHUTTER RB22-Lichtfunktion C 11	not active
ENG116947-ENG116089-Leuchte11SHUTTER RB22-Lichtfunktion D 11	not active
ENG116947-ENG116092-Leuchte11SHUTTER RB22-Lichtfunktion E 11	not active
ENG116947-ENG116093-Leuchte11SHUTTER RB22-Lichtfunktion F 11	not active
ENG116947-ENG116096-Leuchte11SHUTTER RB22-Lichtfunktion G 11	not active
ENG116947-ENG116097-Leuchte11SHUTTER RB22-Lichtfunktion H 11	not active
ENG116948-ENG116110-Leuchte12NL LB45-Dimming Direction CD 12	maximize
ENG116948-ENG116114-Leuchte12NL LB45-Dimming Direction EF 12	maximize
ENG116948-ENG116118-Leuchte12NL LB45-Dimming Direction GH 12	maximize
ENG116948-ENG116105-Leuchte12NL LB45-Dimmwert AB 12	100
ENG116948-ENG116109-Leuchte12NL LB45-Dimmwert CD 12	0
ENG116948-ENG116113-Leuchte12NL LB45-Dimmwert EF 12	0
ENG116948-ENG116117-Leuchte12NL LB45-Dimmwert GH 12	0
ENG116948-ENG116102-Leuchte12NL LB45-Fehlerort mittleres Byte DTC-DFCC 12	22
ENG116948-ENG116562-Leuchte12NL LB45-Lampendefektbitposition 12	38
ENG116948-ENG116100-Leuchte12NL LB45-Lasttyp 12	10 - allgemeine Scheinwerfer
ENG116948-ENG116106-Leuchte12NL LB45-Lichtansteuerung HD AB 12	Always
ENG116948-ENG116103-Leuchte12NL LB45-Lichtfunktion A 12	Nebellicht links
ENG116948-ENG116104-Leuchte12NL LB45-Lichtfunktion B 12	not active
ENG116948-ENG116107-Leuchte12NL LB45-Lichtfunktion C 12	not active
ENG116948-ENG116108-Leuchte12NL LB45-Lichtfunktion D 12	not active
ENG116948-ENG116111-Leuchte12NL LB45-Lichtfunktion E 12	not active
ENG116948-ENG116112-Leuchte12NL LB45-Lichtfunktion F 12	not active
ENG116948-ENG116115-Leuchte12NL LB45-Lichtfunktion G 12	not active
ENG116948-ENG116116-Leuchte12NL LB45-Lichtfunktion H 12	not active
ENG116949-ENG116129-Leuchte13NL RB5-Dimming Direction CD 13	maximize
ENG116949-ENG116133-Leuchte13NL RB5-Dimming Direction EF 13	maximize
ENG116949-ENG116137-Leuchte13NL RB5-Dimming Direction GH 13	maximize
ENG116949-ENG116124-Leuchte13NL RB5-Dimmwert AB 13	100
ENG116949-ENG116128-Leuchte13NL RB5-Dimmwert CD 13	0
ENG116949-ENG116132-Leuchte13NL RB5-Dimmwert EF 13	0
ENG116949-ENG116136-Leuchte13NL RB5-Dimmwert GH 13	0
ENG116949-ENG116121-Leuchte13NL RB5-Fehlerort mittleres Byte DTC-DFCC 13	23
ENG116949-ENG116563-Leuchte13NL RB5-Lampendefektbitposition 13	42
ENG116949-ENG116119-Leuchte13NL RB5-Lasttyp 13	10 - allgemeine Scheinwerfer
ENG116949-ENG116125-Leuchte13NL RB5-Lichtansteuerung HD AB 13	Always
ENG116949-ENG116122-Leuchte13NL RB5-Lichtfunktion A 13	Nebellicht rechts
ENG116949-ENG116123-Leuchte13NL RB5-Lichtfunktion B 13	not active
ENG116949-ENG116564-Leuchte13NL RB5-Lichtfunktion C 13	not active
ENG116949-ENG116127-Leuchte13NL RB5-Lichtfunktion D 13	not active
ENG116949-ENG116130-Leuchte13NL RB5-Lichtfunktion E 13	not active
ENG116949-ENG116131-Leuchte13NL RB5-Lichtfunktion F 13	not active
ENG116949-ENG116134-Leuchte13NL RB5-Lichtfunktion G 13	not active
ENG116949-ENG116135-Leuchte13NL RB5-Lichtfunktion H 13	not active
ENG116951-ENG116167-Leuchte15AL RB44-Dimming Direction CD 15	maximize
ENG116951-ENG116171-Leuchte15AL RB44-Dimming Direction EF 15	maximize
ENG116951-ENG116175-Leuchte15AL RB44-Dimming Direction GH 15	maximize
ENG116951-ENG116162-Leuchte15AL RB44-Dimmwert AB 15	0
ENG116951-ENG116166-Leuchte15AL RB44-Dimmwert CD 15	0
ENG116951-ENG116170-Leuchte15AL RB44-Dimmwert EF 15	0
ENG116951-ENG116174-Leuchte15AL RB44-Dimmwert GH 15	0
ENG116951-ENG116159-Leuchte15AL RB44-Fehlerort mittleres Byte DTC-DFCC 15	0
ENG116951-ENG116566-Leuchte15AL RB44-Lampendefektbitposition 15	0
ENG116951-ENG116157-Leuchte15AL RB44-Lasttyp 15	not active
ENG116951-ENG116163-Leuchte15AL RB44-Lichtansteuerung HD AB 15	Always
ENG116951-ENG116160-Leuchte15AL RB44-Lichtfunktion A 15	not active
ENG116951-ENG116161-Leuchte15AL RB44-Lichtfunktion B 15	not active
ENG116951-ENG116164-Leuchte15AL RB44-Lichtfunktion C 15	not active
ENG116951-ENG116165-Leuchte15AL RB44-Lichtfunktion D 15	not active
ENG116951-ENG116168-Leuchte15AL RB44-Lichtfunktion E 15	not active
ENG116951-ENG116169-Leuchte15AL RB44-Lichtfunktion F 15	not active
ENG116951-ENG116172-Leuchte15AL RB44-Lichtfunktion G 15	not active
ENG116951-ENG116173-Leuchte15AL RB44-Lichtfunktion H 15	not active
ENG116952-ENG116186-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction CD 16	maximize
ENG116952-ENG116190-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction EF 16	maximize
ENG116952-ENG116194-Leuchte16BLK SLB35BLK SL KC9-Dimming Direction GH 16	maximize
ENG116952-ENG116181-Leuchte16BLK SLB35BLK SL KC9-Dimmwert AB 16	0
ENG116952-ENG116185-Leuchte16BLK SLB35BLK SL KC9-Dimmwert CD 16	0
ENG116952-ENG116189-Leuchte16BLK SLB35BLK SL KC9-Dimmwert EF 16	0
ENG116952-ENG116193-Leuchte16BLK SLB35BLK SL KC9-Dimmwert GH 16	0
ENG116952-ENG116178-Leuchte16BLK SLB35BLK SL KC9-Fehlerort mittleres Byte DTC-DFCC 16	0
ENG116952-ENG116567-Leuchte16BLK SLB35BLK SL KC9-Lampendefektbitposition 16	0
ENG116952-ENG116176-Leuchte16BLK SLB35BLK SL KC9-Lasttyp 16	not active
ENG116952-ENG116182-Leuchte16BLK SLB35BLK SL KC9-Lichtansteuerung HD AB 16	Always
ENG116952-ENG116179-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion A 16	not active
ENG116952-ENG116180-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion B 16	not active
ENG116952-ENG116183-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion C 16	not active
ENG116952-ENG116184-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion D 16	not active
ENG116952-ENG116187-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion E 16	not active
ENG116952-ENG116188-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion F 16	not active
ENG116952-ENG116191-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion G 16	not active
ENG116952-ENG116192-Leuchte16BLK SLB35BLK SL KC9-Lichtfunktion H 16	not active
ENG116953-ENG116205-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction CD 17	maximize
ENG116953-ENG116209-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction EF 17	maximize
ENG116953-ENG116213-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimming Direction GH 17	maximize
ENG116953-ENG116200-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert AB 17	0
ENG116953-ENG116204-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert CD 17	0
ENG116953-ENG116208-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert EF 17	0
ENG116953-ENG116212-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Dimmwert GH 17	0
ENG116953-ENG116197-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Fehlerort mittleres Byte DTC-DFCC 17	0
ENG116953-ENG116568-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lampendefektbitposition 17	0
ENG116953-ENG116195-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lasttyp 17	not active
ENG116953-ENG116201-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtansteuerung HD AB 17	Always
ENG116953-ENG116198-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion A 17	not active
ENG116953-ENG116569-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion B 17	not active
ENG116953-ENG116202-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion C 17	not active
ENG116953-ENG116203-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion D 17	not active
ENG116953-ENG116206-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion E 17	not active
ENG116953-ENG116207-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion F 17	not active
ENG116953-ENG116210-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion G 17	not active
ENG116953-ENG116211-Leuchte17TFL R BLK SRB3TFL R BLK SR KC3-Lichtfunktion H 17	not active
ENG116954-ENG116224-Leuchte18BLK HLA60-Dimming Direction CD 18	maximize
ENG116954-ENG116228-Leuchte18BLK HLA60-Dimming Direction EF 18	maximize
ENG116954-ENG116232-Leuchte18BLK HLA60-Dimming Direction GH 18	maximize
ENG116954-ENG116219-Leuchte18BLK HLA60-Dimmwert AB 18	100
ENG116954-ENG116223-Leuchte18BLK HLA60-Dimmwert CD 18	0
ENG116954-ENG116227-Leuchte18BLK HLA60-Dimmwert EF 18	0
ENG116954-ENG116231-Leuchte18BLK HLA60-Dimmwert GH 18	0
ENG116954-ENG116216-Leuchte18BLK HLA60-Fehlerort mittleres Byte DTC-DFCC 18	16
ENG116954-ENG116570-Leuchte18BLK HLA60-Lampendefektbitposition 18	8
ENG116954-ENG116214-Leuchte18BLK HLA60-Lasttyp 18	12 - Blinkleuchten
ENG116954-ENG116220-Leuchte18BLK HLA60-Lichtansteuerung HD AB 18	Always
ENG116954-ENG116217-Leuchte18BLK HLA60-Lichtfunktion A 18	Blinken links Hellphase
ENG116954-ENG116218-Leuchte18BLK HLA60-Lichtfunktion B 18	not active
ENG116954-ENG116221-Leuchte18BLK HLA60-Lichtfunktion C 18	not active
ENG116954-ENG116222-Leuchte18BLK HLA60-Lichtfunktion D 18	not active
ENG116954-ENG116225-Leuchte18BLK HLA60-Lichtfunktion E 18	not active
ENG116954-ENG116226-Leuchte18BLK HLA60-Lichtfunktion F 18	not active
ENG116954-ENG116229-Leuchte18BLK HLA60-Lichtfunktion G 18	not active
ENG116954-ENG116230-Leuchte18BLK HLA60-Lichtfunktion H 18	not active
ENG116955-ENG116243-Leuchte19BLK HRC31-Dimming Direction CD 19	maximize
ENG116955-ENG116247-Leuchte19BLK HRC31-Dimming Direction EF 19	maximize
ENG116955-ENG116251-Leuchte19BLK HRC31-Dimming Direction GH 19	maximize
ENG116955-ENG116238-Leuchte19BLK HRC31-Dimmwert AB 19	100
ENG116955-ENG116242-Leuchte19BLK HRC31-Dimmwert CD 19	0
ENG116955-ENG116246-Leuchte19BLK HRC31-Dimmwert EF 19	0
ENG116955-ENG116250-Leuchte19BLK HRC31-Dimmwert GH 19	0
ENG116955-ENG116235-Leuchte19BLK HRC31-Fehlerort mittleres Byte DTC-DFCC 19	18
ENG116955-ENG116571-Leuchte19BLK HRC31-Lampendefektbitposition 19	18
ENG116955-ENG116233-Leuchte19BLK HRC31-Lasttyp 19	12 - Blinkleuchten
ENG116955-ENG116239-Leuchte19BLK HRC31-Lichtansteuerung HD AB 19	Always
ENG116955-ENG116236-Leuchte19BLK HRC31-Lichtfunktion A 19	Blinken rechts Hellphase
ENG116955-ENG116237-Leuchte19BLK HRC31-Lichtfunktion B 19	not active
ENG116955-ENG116240-Leuchte19BLK HRC31-Lichtfunktion C 19	not active
ENG116955-ENG116241-Leuchte19BLK HRC31-Lichtfunktion D 19	not active
ENG116955-ENG116244-Leuchte19BLK HRC31-Lichtfunktion E 19	not active
ENG116955-ENG116245-Leuchte19BLK HRC31-Lichtfunktion F 19	not active
ENG116955-ENG116248-Leuchte19BLK HRC31-Lichtfunktion G 19	not active
ENG116955-ENG116249-Leuchte19BLK HRC31-Lichtfunktion H 19	not active
ENG116937-ENG115902-Leuchte1BLK VRB20-Dimming Direction CD 1	maximize
ENG116937-ENG115906-Leuchte1BLK VRB20-Dimming Direction EF 1	maximize
ENG116937-ENG115909-Leuchte1BLK VRB20-Dimming Direction GH 1	maximize
ENG116937-ENG115897-Leuchte1BLK VRB20-Dimmwert AB 1	100
ENG116937-ENG115901-Leuchte1BLK VRB20-Dimmwert CD 1	0
ENG116937-ENG115905-Leuchte1BLK VRB20-Dimmwert EF 1	0
ENG116937-ENG115908-Leuchte1BLK VRB20-Dimmwert GH 1	0
ENG116937-ENG115894-Leuchte1BLK VRB20-Fehlerort mittleres Byte DTC-DFCC 1	15
ENG116937-ENG116548-Leuchte1BLK VRB20-Lampendefektbitposition 1	3E
ENG116937-ENG115892-Leuchte1BLK VRB20-Lasttyp 1	12 - Blinkleuchten
ENG116937-ENG115898-Leuchte1BLK VRB20-Lichtansteuerung HD AB 1	Always
ENG116937-ENG115895-Leuchte1BLK VRB20-Lichtfunktion A 1	Blinken rechts Hellphase
ENG116937-ENG115896-Leuchte1BLK VRB20-Lichtfunktion B 1	not active
ENG116937-ENG115899-Leuchte1BLK VRB20-Lichtfunktion C 1	not active
ENG116937-ENG115900-Leuchte1BLK VRB20-Lichtfunktion D 1	not active
ENG116937-ENG115903-Leuchte1BLK VRB20-Lichtfunktion E 1	not active
ENG116937-ENG115904-Leuchte1BLK VRB20-Lichtfunktion F 1	not active
ENG116937-ENG115907-Leuchte1BLK VRB20-Lichtfunktion G 1	not active
ENG116937-ENG116549-Leuchte1BLK VRB20-Lichtfunktion H 1	not active
ENG116956-ENG116262-Leuchte20BR LA71-Dimming Direction CD 20	maximize
ENG116956-ENG116266-Leuchte20BR LA71-Dimming Direction EF 20	maximize
ENG116956-ENG116270-Leuchte20BR LA71-Dimming Direction GH 20	maximize
ENG116956-ENG116257-Leuchte20BR LA71-Dimmwert AB 20	100
ENG116956-ENG116261-Leuchte20BR LA71-Dimmwert CD 20	35
ENG116956-ENG116265-Leuchte20BR LA71-Dimmwert EF 20	0
ENG116956-ENG116269-Leuchte20BR LA71-Dimmwert GH 20	0
ENG116956-ENG116254-Leuchte20BR LA71-Fehlerort mittleres Byte DTC-DFCC 20	39
ENG116956-ENG116572-Leuchte20BR LA71-Lampendefektbitposition 20	10
ENG116956-ENG116252-Leuchte20BR LA71-Lasttyp 20	13 - Bremsleuchten
ENG116956-ENG116258-Leuchte20BR LA71-Lichtansteuerung HD AB 20	Always
ENG116956-ENG116255-Leuchte20BR LA71-Lichtfunktion A 20	Brake light
ENG116956-ENG116256-Leuchte20BR LA71-Lichtfunktion B 20	not active
ENG116956-ENG116259-Leuchte20BR LA71-Lichtfunktion C 20	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116956-ENG116260-Leuchte20BR LA71-Lichtfunktion D 20	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116956-ENG116263-Leuchte20BR LA71-Lichtfunktion E 20	not active
ENG116956-ENG116264-Leuchte20BR LA71-Lichtfunktion F 20	not active
ENG116956-ENG116267-Leuchte20BR LA71-Lichtfunktion G 20	not active
ENG116956-ENG116268-Leuchte20BR LA71-Lichtfunktion H 20	not active
ENG116957-ENG116281-Leuchte21BR RC8-Dimming Direction CD 21	maximize
ENG116957-ENG116285-Leuchte21BR RC8-Dimming Direction EF 21	maximize
ENG116957-ENG116289-Leuchte21BR RC8-Dimming Direction GH 21	maximize
ENG116957-ENG116276-Leuchte21BR RC8-Dimmwert AB 21	100
ENG116957-ENG116280-Leuchte21BR RC8-Dimmwert CD 21	35
ENG116957-ENG116284-Leuchte21BR RC8-Dimmwert EF 21	0
ENG116957-ENG116288-Leuchte21BR RC8-Dimmwert GH 21	0
ENG116957-ENG116273-Leuchte21BR RC8-Fehlerort mittleres Byte DTC-DFCC 21	3A
ENG116957-ENG116573-Leuchte21BR RC8-Lampendefektbitposition 21	20
ENG116957-ENG116271-Leuchte21BR RC8-Lasttyp 21	13 - Bremsleuchten
ENG116957-ENG116277-Leuchte21BR RC8-Lichtansteuerung HD AB 21	Always
ENG116957-ENG116274-Leuchte21BR RC8-Lichtfunktion A 21	Brake light
ENG116957-ENG116275-Leuchte21BR RC8-Lichtfunktion B 21	not active
ENG116957-ENG116278-Leuchte21BR RC8-Lichtfunktion C 21	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116957-ENG116279-Leuchte21BR RC8-Lichtfunktion D 21	Parking light right
ENG116957-ENG116282-Leuchte21BR RC8-Lichtfunktion E 21	not active
ENG116957-ENG116283-Leuchte21BR RC8-Lichtfunktion F 21	not active
ENG116957-ENG116286-Leuchte21BR RC8-Lichtfunktion G 21	not active
ENG116957-ENG116287-Leuchte21BR RC8-Lichtfunktion H 21	not active
ENG116958-ENG116300-Leuchte22BR MA57-Dimming Direction CD 22	maximize
ENG116958-ENG116304-Leuchte22BR MA57-Dimming Direction EF 22	maximize
ENG116958-ENG116308-Leuchte22BR MA57-Dimming Direction GH 22	maximize
ENG116958-ENG116295-Leuchte22BR MA57-Dimmwert AB 22	100
ENG116958-ENG116299-Leuchte22BR MA57-Dimmwert CD 22	0
ENG116958-ENG116303-Leuchte22BR MA57-Dimmwert EF 22	0
ENG116958-ENG116307-Leuchte22BR MA57-Dimmwert GH 22	0
ENG116958-ENG116292-Leuchte22BR MA57-Fehlerort mittleres Byte DTC-DFCC 22	2C
ENG116958-ENG116574-Leuchte22BR MA57-Lampendefektbitposition 22	29
ENG116958-ENG116290-Leuchte22BR MA57-Lasttyp 22	42 - LED dritte Bremsleuchte
ENG116958-ENG116296-Leuchte22BR MA57-Lichtansteuerung HD AB 22	Always
ENG116958-ENG116293-Leuchte22BR MA57-Lichtfunktion A 22	Brake light
ENG116958-ENG116294-Leuchte22BR MA57-Lichtfunktion B 22	not active
ENG116958-ENG116297-Leuchte22BR MA57-Lichtfunktion C 22	not active
ENG116958-ENG116298-Leuchte22BR MA57-Lichtfunktion D 22	not active
ENG116958-ENG116301-Leuchte22BR MA57-Lichtfunktion E 22	not active
ENG116958-ENG116302-Leuchte22BR MA57-Lichtfunktion F 22	not active
ENG116958-ENG116305-Leuchte22BR MA57-Lichtfunktion G 22	not active
ENG116958-ENG116306-Leuchte22BR MA57-Lichtfunktion H 22	not active
ENG116959-ENG116319-Leuchte23SL HLC10-Dimming Direction CD 23	maximize
ENG116959-ENG116323-Leuchte23SL HLC10-Dimming Direction EF 23	maximize
ENG116959-ENG116327-Leuchte23SL HLC10-Dimming Direction GH 23	maximize
ENG116959-ENG116314-Leuchte23SL HLC10-Dimmwert AB 23	35
ENG116959-ENG116318-Leuchte23SL HLC10-Dimmwert CD 23	0
ENG116959-ENG116322-Leuchte23SL HLC10-Dimmwert EF 23	0
ENG116959-ENG116326-Leuchte23SL HLC10-Dimmwert GH 23	0
ENG116959-ENG116311-Leuchte23SL HLC10-Fehlerort mittleres Byte DTC-DFCC 23	29
ENG116959-ENG116575-Leuchte23SL HLC10-Lampendefektbitposition 23	0A
ENG116959-ENG116309-Leuchte23SL HLC10-Lasttyp 23	9 - allgemeine Gl・lampe 27W: auch H15
ENG116959-ENG116315-Leuchte23SL HLC10-Lichtansteuerung HD AB 23	only_if_closed
ENG116959-ENG116312-Leuchte23SL HLC10-Lichtfunktion A 23	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116959-ENG116313-Leuchte23SL HLC10-Lichtfunktion B 23	not active
ENG116959-ENG116316-Leuchte23SL HLC10-Lichtfunktion C 23	not active
ENG116959-ENG116317-Leuchte23SL HLC10-Lichtfunktion D 23	not active
ENG116959-ENG116320-Leuchte23SL HLC10-Lichtfunktion E 23	not active
ENG116959-ENG116321-Leuchte23SL HLC10-Lichtfunktion F 23	not active
ENG116959-ENG116324-Leuchte23SL HLC10-Lichtfunktion G 23	not active
ENG116959-ENG116325-Leuchte23SL HLC10-Lichtfunktion H 23	not active
ENG116960-ENG116338-Leuchte24SL HRA65-Dimming Direction CD 24	maximize
ENG116960-ENG116342-Leuchte24SL HRA65-Dimming Direction EF 24	maximize
ENG116960-ENG116346-Leuchte24SL HRA65-Dimming Direction GH 24	maximize
ENG116960-ENG116333-Leuchte24SL HRA65-Dimmwert AB 24	35
ENG116960-ENG116337-Leuchte24SL HRA65-Dimmwert CD 24	0
ENG116960-ENG116341-Leuchte24SL HRA65-Dimmwert EF 24	0
ENG116960-ENG116345-Leuchte24SL HRA65-Dimmwert GH 24	0
ENG116960-ENG116330-Leuchte24SL HRA65-Fehlerort mittleres Byte DTC-DFCC 24	2A
ENG116960-ENG116576-Leuchte24SL HRA65-Lampendefektbitposition 24	1A
ENG116960-ENG116328-Leuchte24SL HRA65-Lasttyp 24	9 - allgemeine Gl・lampe 27W: auch H15
ENG116960-ENG116334-Leuchte24SL HRA65-Lichtansteuerung HD AB 24	only_if_closed
ENG116960-ENG116331-Leuchte24SL HRA65-Lichtfunktion A 24	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116960-ENG116332-Leuchte24SL HRA65-Lichtfunktion B 24	not active
ENG116960-ENG116335-Leuchte24SL HRA65-Lichtfunktion C 24	not active
ENG116960-ENG116336-Leuchte24SL HRA65-Lichtfunktion D 24	not active
ENG116960-ENG116339-Leuchte24SL HRA65-Lichtfunktion E 24	not active
ENG116960-ENG116340-Leuchte24SL HRA65-Lichtfunktion F 24	not active
ENG116960-ENG116343-Leuchte24SL HRA65-Lichtfunktion G 24	not active
ENG116960-ENG116344-Leuchte24SL HRA65-Lichtfunktion H 24	not active
ENG116961-ENG116357-Leuchte25KZL HA59-Dimming Direction CD 25	maximize
ENG116961-ENG116361-Leuchte25KZL HA59-Dimming Direction EF 25	maximize
ENG116961-ENG116365-Leuchte25KZL HA59-Dimming Direction GH 25	maximize
ENG116961-ENG116352-Leuchte25KZL HA59-Dimmwert AB 25	127
ENG116961-ENG116356-Leuchte25KZL HA59-Dimmwert CD 25	0
ENG116961-ENG116360-Leuchte25KZL HA59-Dimmwert EF 25	0
ENG116961-ENG116364-Leuchte25KZL HA59-Dimmwert GH 25	0
ENG116961-ENG116349-Leuchte25KZL HA59-Fehlerort mittleres Byte DTC-DFCC 25	30
ENG116961-ENG116577-Leuchte25KZL HA59-Lampendefektbitposition 25	28
ENG116961-ENG116347-Leuchte25KZL HA59-Lasttyp 25	43 - allgemeine LED
ENG116961-ENG116353-Leuchte25KZL HA59-Lichtansteuerung HD AB 25	Always
ENG116961-ENG116350-Leuchte25KZL HA59-Lichtfunktion A 25	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116961-ENG116351-Leuchte25KZL HA59-Lichtfunktion B 25	not active
ENG116961-ENG116354-Leuchte25KZL HA59-Lichtfunktion C 25	not active
ENG116961-ENG116355-Leuchte25KZL HA59-Lichtfunktion D 25	not active
ENG116961-ENG116358-Leuchte25KZL HA59-Lichtfunktion E 25	not active
ENG116961-ENG116359-Leuchte25KZL HA59-Lichtfunktion F 25	not active
ENG116961-ENG116362-Leuchte25KZL HA59-Lichtfunktion G 25	not active
ENG116961-ENG116363-Leuchte25KZL HA59-Lichtfunktion H 25	not active
ENG116962-ENG116376-Leuchte26NSL LA72-Dimming Direction CD 26	maximize
ENG116962-ENG116380-Leuchte26NSL LA72-Dimming Direction EF 26	maximize
ENG116962-ENG116384-Leuchte26NSL LA72-Dimming Direction GH 26	maximize
ENG116962-ENG116371-Leuchte26NSL LA72-Dimmwert AB 26	100
ENG116962-ENG116375-Leuchte26NSL LA72-Dimmwert CD 26	0
ENG116962-ENG116379-Leuchte26NSL LA72-Dimmwert EF 26	0
ENG116962-ENG116383-Leuchte26NSL LA72-Dimmwert GH 26	0
ENG116962-ENG116368-Leuchte26NSL LA72-Fehlerort mittleres Byte DTC-DFCC 26	2F
ENG116962-ENG116578-Leuchte26NSL LA72-Lampendefektbitposition 26	1C
ENG116962-ENG116366-Leuchte26NSL LA72-Lasttyp 26	9 - allgemeine Gl・lampe 27W: auch H15
ENG116962-ENG116372-Leuchte26NSL LA72-Lichtansteuerung HD AB 26	only_if_closed
ENG116962-ENG116369-Leuchte26NSL LA72-Lichtfunktion A 26	Nebelschlusslicht wenn kein Anhaenger gesteckt und Linksverkehr
ENG116962-ENG116370-Leuchte26NSL LA72-Lichtfunktion B 26	not active
ENG116962-ENG116373-Leuchte26NSL LA72-Lichtfunktion C 26	not active
ENG116962-ENG116374-Leuchte26NSL LA72-Lichtfunktion D 26	not active
ENG116962-ENG116377-Leuchte26NSL LA72-Lichtfunktion E 26	not active
ENG116962-ENG116378-Leuchte26NSL LA72-Lichtfunktion F 26	not active
ENG116962-ENG116381-Leuchte26NSL LA72-Lichtfunktion G 26	not active
ENG116962-ENG116382-Leuchte26NSL LA72-Lichtfunktion H 26	not active
ENG116963-ENG116395-Leuchte27NSL RC6-Dimming Direction CD 27	maximize
ENG116963-ENG116399-Leuchte27NSL RC6-Dimming Direction EF 27	maximize
ENG116963-ENG116403-Leuchte27NSL RC6-Dimming Direction GH 27	maximize
ENG116963-ENG116390-Leuchte27NSL RC6-Dimmwert AB 27	0
ENG116963-ENG116394-Leuchte27NSL RC6-Dimmwert CD 27	0
ENG116963-ENG116398-Leuchte27NSL RC6-Dimmwert EF 27	0
ENG116963-ENG116402-Leuchte27NSL RC6-Dimmwert GH 27	0
ENG116963-ENG116387-Leuchte27NSL RC6-Fehlerort mittleres Byte DTC-DFCC 27	0
ENG116963-ENG116579-Leuchte27NSL RC6-Lampendefektbitposition 27	0
ENG116963-ENG116385-Leuchte27NSL RC6-Lasttyp 27	not active
ENG116963-ENG116391-Leuchte27NSL RC6-Lichtansteuerung HD AB 27	Always
ENG116963-ENG116388-Leuchte27NSL RC6-Lichtfunktion A 27	not active
ENG116963-ENG116389-Leuchte27NSL RC6-Lichtfunktion B 27	not active
ENG116963-ENG116392-Leuchte27NSL RC6-Lichtfunktion C 27	not active
ENG116963-ENG116393-Leuchte27NSL RC6-Lichtfunktion D 27	not active
ENG116963-ENG116396-Leuchte27NSL RC6-Lichtfunktion E 27	not active
ENG116963-ENG116397-Leuchte27NSL RC6-Lichtfunktion F 27	not active
ENG116963-ENG116400-Leuchte27NSL RC6-Lichtfunktion G 27	not active
ENG116963-ENG116401-Leuchte27NSL RC6-Lichtfunktion H 27	not active
ENG116964-ENG116414-Leuchte28RFL LC11-Dimming Direction CD 28	maximize
ENG116964-ENG116418-Leuchte28RFL LC11-Dimming Direction EF 28	maximize
ENG116964-ENG116422-Leuchte28RFL LC11-Dimming Direction GH 28	maximize
ENG116964-ENG116409-Leuchte28RFL LC11-Dimmwert AB 28	100
ENG116964-ENG116413-Leuchte28RFL LC11-Dimmwert CD 28	0
ENG116964-ENG116417-Leuchte28RFL LC11-Dimmwert EF 28	0
ENG116964-ENG116421-Leuchte28RFL LC11-Dimmwert GH 28	0
ENG116964-ENG116406-Leuchte28RFL LC11-Fehlerort mittleres Byte DTC-DFCC 28	31
ENG116964-ENG116580-Leuchte28RFL LC11-Lampendefektbitposition 28	0B
ENG116964-ENG116404-Leuchte28RFL LC11-Lasttyp 28	9 - allgemeine Gl・lampe 27W: auch H15
ENG116964-ENG116410-Leuchte28RFL LC11-Lichtansteuerung HD AB 28	only_if_closed
ENG116964-ENG116407-Leuchte28RFL LC11-Lichtfunktion A 28	Rueckfahrlicht
ENG116964-ENG116408-Leuchte28RFL LC11-Lichtfunktion B 28	not active
ENG116964-ENG116411-Leuchte28RFL LC11-Lichtfunktion C 28	not active
ENG116964-ENG116412-Leuchte28RFL LC11-Lichtfunktion D 28	not active
ENG116964-ENG116415-Leuchte28RFL LC11-Lichtfunktion E 28	not active
ENG116964-ENG116416-Leuchte28RFL LC11-Lichtfunktion F 28	not active
ENG116964-ENG116419-Leuchte28RFL LC11-Lichtfunktion G 28	not active
ENG116964-ENG116420-Leuchte28RFL LC11-Lichtfunktion H 28	not active
ENG116965-ENG116433-Leuchte29RFL RA64-Dimming Direction CD 29	maximize
ENG116965-ENG116437-Leuchte29RFL RA64-Dimming Direction EF 29	maximize
ENG116965-ENG116441-Leuchte29RFL RA64-Dimming Direction GH 29	maximize
ENG116965-ENG116428-Leuchte29RFL RA64-Dimmwert AB 29	100
ENG116965-ENG116432-Leuchte29RFL RA64-Dimmwert CD 29	0
ENG116965-ENG116436-Leuchte29RFL RA64-Dimmwert EF 29	0
ENG116965-ENG116440-Leuchte29RFL RA64-Dimmwert GH 29	0
ENG116965-ENG116425-Leuchte29RFL RA64-Fehlerort mittleres Byte DTC-DFCC 29	32
ENG116965-ENG116581-Leuchte29RFL RA64-Lampendefektbitposition 29	1B
ENG116965-ENG116423-Leuchte29RFL RA64-Lasttyp 29	9 - allgemeine Gl・lampe 27W: auch H15
ENG116965-ENG116430-Leuchte29RFL RA64-Lichtansteuerung HD AB 29	only_if_closed
ENG116965-ENG116426-Leuchte29RFL RA64-Lichtfunktion A 29	Rueckfahrlicht
ENG116965-ENG116427-Leuchte29RFL RA64-Lichtfunktion B 29	not active
ENG116965-ENG116429-Leuchte29RFL RA64-Lichtfunktion C 29	not active
ENG116965-ENG116431-Leuchte29RFL RA64-Lichtfunktion D 29	not active
ENG116965-ENG116434-Leuchte29RFL RA64-Lichtfunktion E 29	not active
ENG116965-ENG116435-Leuchte29RFL RA64-Lichtfunktion F 29	not active
ENG116965-ENG116438-Leuchte29RFL RA64-Lichtfunktion G 29	not active
ENG116965-ENG116439-Leuchte29RFL RA64-Lichtfunktion H 29	not active
ENG116938-ENG115920-Leuchte2SL VLB10-Dimming Direction CD 2	maximize
ENG116938-ENG115924-Leuchte2SL VLB10-Dimming Direction EF 2	maximize
ENG116938-ENG115928-Leuchte2SL VLB10-Dimming Direction GH 2	maximize
ENG116938-ENG115915-Leuchte2SL VLB10-Dimmwert AB 2	100
ENG116938-ENG115919-Leuchte2SL VLB10-Dimmwert CD 2	51
ENG116938-ENG115923-Leuchte2SL VLB10-Dimmwert EF 2	0
ENG116938-ENG115927-Leuchte2SL VLB10-Dimmwert GH 2	0
ENG116938-ENG115912-Leuchte2SL VLB10-Fehlerort mittleres Byte DTC-DFCC 2	4A
ENG116938-ENG116550-Leuchte2SL VLB10-Lampendefektbitposition 2	48
ENG116938-ENG115910-Leuchte2SL VLB10-Lasttyp 2	4 - LED Tagfahrlichtmodul Signal
ENG116938-ENG115916-Leuchte2SL VLB10-Lichtansteuerung HD AB 2	Always
ENG116938-ENG115913-Leuchte2SL VLB10-Lichtfunktion A 2	Daytime running lights
ENG116938-ENG115914-Leuchte2SL VLB10-Lichtfunktion B 2	not active
ENG116938-ENG115917-Leuchte2SL VLB10-Lichtfunktion C 2	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116938-ENG115918-Leuchte2SL VLB10-Lichtfunktion D 2	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116938-ENG115921-Leuchte2SL VLB10-Lichtfunktion E 2	not active
ENG116938-ENG115922-Leuchte2SL VLB10-Lichtfunktion F 2	not active
ENG116938-ENG115925-Leuchte2SL VLB10-Lichtfunktion G 2	not active
ENG116938-ENG115926-Leuchte2SL VLB10-Lichtfunktion H 2	not active
ENG116966-ENG116452-Leuchte30FR LC72-Dimming Direction CD 30	maximize
ENG116966-ENG116456-Leuchte30FR LC72-Dimming Direction EF 30	maximize
ENG116966-ENG116460-Leuchte30FR LC72-Dimming Direction GH 30	maximize
ENG116966-ENG116447-Leuchte30FR LC72-Dimmwert AB 30	89
ENG116966-ENG116451-Leuchte30FR LC72-Dimmwert CD 30	0
ENG116966-ENG116455-Leuchte30FR LC72-Dimmwert EF 30	0
ENG116966-ENG116459-Leuchte30FR LC72-Dimmwert GH 30	0
ENG116966-ENG116444-Leuchte30FR LC72-Fehlerort mittleres Byte DTC-DFCC 30	2
ENG116966-ENG116582-Leuchte30FR LC72-Lampendefektbitposition 30	0
ENG116966-ENG116442-Leuchte30FR LC72-Lasttyp 30	36 - LED Kleinleistung
ENG116966-ENG116448-Leuchte30FR LC72-Lichtansteuerung HD AB 30	Always
ENG116966-ENG116445-Leuchte30FR LC72-Lichtfunktion A 30	Footwell light
ENG116966-ENG116446-Leuchte30FR LC72-Lichtfunktion B 30	not active
ENG116966-ENG116449-Leuchte30FR LC72-Lichtfunktion C 30	not active
ENG116966-ENG116450-Leuchte30FR LC72-Lichtfunktion D 30	not active
ENG116966-ENG116453-Leuchte30FR LC72-Lichtfunktion E 30	not active
ENG116966-ENG116454-Leuchte30FR LC72-Lichtfunktion F 30	not active
ENG116966-ENG116457-Leuchte30FR LC72-Lichtfunktion G 30	not active
ENG116966-ENG116458-Leuchte30FR LC72-Lichtfunktion H 30	not active
ENG116967-ENG116471-Leuchte31AMBL 1C61-Dimming Direction CD 31	maximize
ENG116967-ENG116475-Leuchte31AMBL 1C61-Dimming Direction EF 31	maximize
ENG116967-ENG116479-Leuchte31AMBL 1C61-Dimming Direction GH 31	maximize
ENG116967-ENG116466-Leuchte31AMBL 1C61-Dimmwert AB 31	0
ENG116967-ENG116470-Leuchte31AMBL 1C61-Dimmwert CD 31	0
ENG116967-ENG116474-Leuchte31AMBL 1C61-Dimmwert EF 31	0
ENG116967-ENG116478-Leuchte31AMBL 1C61-Dimmwert GH 31	0
ENG116967-ENG116463-Leuchte31AMBL 1C61-Fehlerort mittleres Byte DTC-DFCC 31	0
ENG116967-ENG116583-Leuchte31AMBL 1C61-Lampendefektbitposition 31	0
ENG116967-ENG116461-Leuchte31AMBL 1C61-Lasttyp 31	not active
ENG116967-ENG116467-Leuchte31AMBL 1C61-Lichtansteuerung HD AB 31	Always
ENG116967-ENG116464-Leuchte31AMBL 1C61-Lichtfunktion A 31	not active
ENG116967-ENG116465-Leuchte31AMBL 1C61-Lichtfunktion B 31	not active
ENG116967-ENG116468-Leuchte31AMBL 1C61-Lichtfunktion C 31	not active
ENG116967-ENG116469-Leuchte31AMBL 1C61-Lichtfunktion D 31	not active
ENG116967-ENG116472-Leuchte31AMBL 1C61-Lichtfunktion E 31	not active
ENG116967-ENG116473-Leuchte31AMBL 1C61-Lichtfunktion F 31	not active
ENG116967-ENG116476-Leuchte31AMBL 1C61-Lichtfunktion G 31	not active
ENG116967-ENG116477-Leuchte31AMBL 1C61-Lichtfunktion H 31	not active
ENG116968-ENG116490-Leuchte32AMBL 2C35-Dimming Direction CD 32	maximize
ENG116968-ENG116494-Leuchte32AMBL 2C35-Dimming Direction EF 32	maximize
ENG116968-ENG116498-Leuchte32AMBL 2C35-Dimming Direction GH 32	maximize
ENG116968-ENG116485-Leuchte32AMBL 2C35-Dimmwert AB 32	0
ENG116968-ENG116489-Leuchte32AMBL 2C35-Dimmwert CD 32	0
ENG116968-ENG116493-Leuchte32AMBL 2C35-Dimmwert EF 32	0
ENG116968-ENG116497-Leuchte32AMBL 2C35-Dimmwert GH 32	0
ENG116968-ENG116482-Leuchte32AMBL 2C35-Fehlerort mittleres Byte DTC-DFCC 32	0
ENG116968-ENG116584-Leuchte32AMBL 2C35-Lampendefektbitposition 32	0
ENG116968-ENG116480-Leuchte32AMBL 2C35-Lasttyp 32	not active
ENG116968-ENG116486-Leuchte32AMBL 2C35-Lichtansteuerung HD AB 32	Always
ENG116968-ENG116483-Leuchte32AMBL 2C35-Lichtfunktion A 32	not active
ENG116968-ENG116484-Leuchte32AMBL 2C35-Lichtfunktion B 32	not active
ENG116968-ENG116487-Leuchte32AMBL 2C35-Lichtfunktion C 32	not active
ENG116968-ENG116488-Leuchte32AMBL 2C35-Lichtfunktion D 32	not active
ENG116968-ENG116491-Leuchte32AMBL 2C35-Lichtfunktion E 32	not active
ENG116968-ENG116492-Leuchte32AMBL 2C35-Lichtfunktion F 32	not active
ENG116968-ENG116495-Leuchte32AMBL 2C35-Lichtfunktion G 32	not active
ENG116968-ENG116496-Leuchte32AMBL 2C35-Lichtfunktion H 32	not active
ENG116969-ENG116509-Leuchte33AMBL 3C36-Dimming Direction CD 33	maximize
ENG116969-ENG116513-Leuchte33AMBL 3C36-Dimming Direction EF 33	maximize
ENG116969-ENG116517-Leuchte33AMBL 3C36-Dimming Direction GH 33	maximize
ENG116969-ENG116504-Leuchte33AMBL 3C36-Dimmwert AB 33	0
ENG116969-ENG116508-Leuchte33AMBL 3C36-Dimmwert CD 33	0
ENG116969-ENG116512-Leuchte33AMBL 3C36-Dimmwert EF 33	0
ENG116969-ENG116516-Leuchte33AMBL 3C36-Dimmwert GH 33	0
ENG116969-ENG116501-Leuchte33AMBL 3C36-Fehlerort mittleres Byte DTC-DFCC 33	0
ENG116969-ENG116585-Leuchte33AMBL 3C36-Lampendefektbitposition 33	0
ENG116969-ENG116499-Leuchte33AMBL 3C36-Lasttyp 33	not active
ENG116969-ENG116505-Leuchte33AMBL 3C36-Lichtansteuerung HD AB 33	Always
ENG116969-ENG116502-Leuchte33AMBL 3C36-Lichtfunktion A 33	not active
ENG116969-ENG116503-Leuchte33AMBL 3C36-Lichtfunktion B 33	not active
ENG116969-ENG116506-Leuchte33AMBL 3C36-Lichtfunktion C 33	not active
ENG116969-ENG116507-Leuchte33AMBL 3C36-Lichtfunktion D 33	not active
ENG116969-ENG116510-Leuchte33AMBL 3C36-Lichtfunktion E 33	not active
ENG116969-ENG116511-Leuchte33AMBL 3C36-Lichtfunktion F 33	not active
ENG116969-ENG116514-Leuchte33AMBL 3C36-Lichtfunktion G 33	not active
ENG116969-ENG116515-Leuchte33AMBL 3C36-Lichtfunktion H 33	not active
ENG116970-ENG116528-Leuchte34AMBL 4C37-Dimming Direction CD 34	maximize
ENG116970-ENG116532-Leuchte34AMBL 4C37-Dimming Direction EF 34	maximize
ENG116970-ENG116536-Leuchte34AMBL 4C37-Dimming Direction GH 34	maximize
ENG116970-ENG116523-Leuchte34AMBL 4C37-Dimmwert AB 34	0
ENG116970-ENG116527-Leuchte34AMBL 4C37-Dimmwert CD 34	0
ENG116970-ENG116531-Leuchte34AMBL 4C37-Dimmwert EF 34	0
ENG116970-ENG116535-Leuchte34AMBL 4C37-Dimmwert GH 34	0
ENG116970-ENG116520-Leuchte34AMBL 4C37-Fehlerort mittleres Byte DTC-DFCC 34	0
ENG116970-ENG116586-Leuchte34AMBL 4C37-Lampendefektbitposition 34	0
ENG116970-ENG116518-Leuchte34AMBL 4C37-Lasttyp 34	not active
ENG116970-ENG116524-Leuchte34AMBL 4C37-Lichtansteuerung HD AB 34	Always
ENG116970-ENG116521-Leuchte34AMBL 4C37-Lichtfunktion A 34	not active
ENG116970-ENG116522-Leuchte34AMBL 4C37-Lichtfunktion B 34	not active
ENG116970-ENG116525-Leuchte34AMBL 4C37-Lichtfunktion C 34	not active
ENG116970-ENG116526-Leuchte34AMBL 4C37-Lichtfunktion D 34	not active
ENG116970-ENG116529-Leuchte34AMBL 4C37-Lichtfunktion E 34	not active
ENG116970-ENG116530-Leuchte34AMBL 4C37-Lichtfunktion F 34	not active
ENG116970-ENG116533-Leuchte34AMBL 4C37-Lichtfunktion G 34	not active
ENG116970-ENG116534-Leuchte34AMBL 4C37-Lichtfunktion H 34	not active
ENG116939-ENG115939-Leuchte3SL VRB21-Dimming Direction CD 3	maximize
ENG116939-ENG115943-Leuchte3SL VRB21-Dimming Direction EF 3	maximize
ENG116939-ENG115947-Leuchte3SL VRB21-Dimming Direction GH 3	maximize
ENG116939-ENG115934-Leuchte3SL VRB21-Dimmwert AB 3	100
ENG116939-ENG115938-Leuchte3SL VRB21-Dimmwert CD 3	51
ENG116939-ENG115942-Leuchte3SL VRB21-Dimmwert EF 3	0
ENG116939-ENG115946-Leuchte3SL VRB21-Dimmwert GH 3	0
ENG116939-ENG115931-Leuchte3SL VRB21-Fehlerort mittleres Byte DTC-DFCC 3	4C
ENG116939-ENG116551-Leuchte3SL VRB21-Lampendefektbitposition 3	4C
ENG116939-ENG115929-Leuchte3SL VRB21-Lasttyp 3	4 - LED Tagfahrlichtmodul Signal
ENG116939-ENG115935-Leuchte3SL VRB21-Lichtansteuerung HD AB 3	Always
ENG116939-ENG115932-Leuchte3SL VRB21-Lichtfunktion A 3	Daytime running lights
ENG116939-ENG115933-Leuchte3SL VRB21-Lichtfunktion B 3	not active
ENG116939-ENG115936-Leuchte3SL VRB21-Lichtfunktion C 3	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116939-ENG115937-Leuchte3SL VRB21-Lichtfunktion D 3	Parking light right
ENG116939-ENG115940-Leuchte3SL VRB21-Lichtfunktion E 3	not active
ENG116939-ENG116552-Leuchte3SL VRB21-Lichtfunktion F 3	not active
ENG116939-ENG115944-Leuchte3SL VRB21-Lichtfunktion G 3	not active
ENG116939-ENG115945-Leuchte3SL VRB21-Lichtfunktion H 3	not active
ENG116940-ENG115958-Leuchte4TFL LB4-Dimming Direction CD 4	maximize
ENG116940-ENG115962-Leuchte4TFL LB4-Dimming Direction EF 4	maximize
ENG116940-ENG115966-Leuchte4TFL LB4-Dimming Direction GH 4	maximize
ENG116940-ENG115953-Leuchte4TFL LB4-Dimmwert AB 4	127
ENG116940-ENG115957-Leuchte4TFL LB4-Dimmwert CD 4	127
ENG116940-ENG115961-Leuchte4TFL LB4-Dimmwert EF 4	0
ENG116940-ENG115965-Leuchte4TFL LB4-Dimmwert GH 4	0
ENG116940-ENG115950-Leuchte4TFL LB4-Fehlerort mittleres Byte DTC-DFCC 4	49
ENG116940-ENG116553-Leuchte4TFL LB4-Lampendefektbitposition 4	3A
ENG116940-ENG115948-Leuchte4TFL LB4-Lasttyp 4	9 - allgemeine Gl・lampe 27W: auch H15
ENG116940-ENG115954-Leuchte4TFL LB4-Lichtansteuerung HD AB 4	Always
ENG116940-ENG115951-Leuchte4TFL LB4-Lichtfunktion A 4	Daytime running lights
ENG116940-ENG115952-Leuchte4TFL LB4-Lichtfunktion B 4	not active
ENG116940-ENG115955-Leuchte4TFL LB4-Lichtfunktion C 4	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116940-ENG115956-Leuchte4TFL LB4-Lichtfunktion D 4	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116940-ENG115959-Leuchte4TFL LB4-Lichtfunktion E 4	not active
ENG116940-ENG115960-Leuchte4TFL LB4-Lichtfunktion F 4	not active
ENG116940-ENG115963-Leuchte4TFL LB4-Lichtfunktion G 4	not active
ENG116940-ENG115964-Leuchte4TFL LB4-Lichtfunktion H 4	not active
ENG116941-ENG115977-Leuchte5 TFL RB32-Dimming Direction CD 5	maximize
ENG116941-ENG115981-Leuchte5 TFL RB32-Dimming Direction EF 5	maximize
ENG116941-ENG115985-Leuchte5 TFL RB32-Dimming Direction GH 5	maximize
ENG116941-ENG115972-Leuchte5 TFL RB32-Dimmwert AB 5	127
ENG116941-ENG115976-Leuchte5 TFL RB32-Dimmwert CD 5	127
ENG116941-ENG115980-Leuchte5 TFL RB32-Dimmwert EF 5	0
ENG116941-ENG115984-Leuchte5 TFL RB32-Dimmwert GH 5	0
ENG116941-ENG115969-Leuchte5 TFL RB32-Fehlerort mittleres Byte DTC-DFCC 5	4B
ENG116941-ENG116554-Leuchte5 TFL RB32-Lampendefektbitposition 5	44
ENG116941-ENG115967-Leuchte5 TFL RB32-Lasttyp 5	9 - allgemeine Gl・lampe 27W: auch H15
ENG116941-ENG115973-Leuchte5 TFL RB32-Lichtansteuerung HD AB 5	Always
ENG116941-ENG115970-Leuchte5 TFL RB32-Lichtfunktion A 5	Daytime running lights
ENG116941-ENG115971-Leuchte5 TFL RB32-Lichtfunktion B 5	not active
ENG116941-ENG115974-Leuchte5 TFL RB32-Lichtfunktion C 5	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116941-ENG115975-Leuchte5 TFL RB32-Lichtfunktion D 5	Parking light right
ENG116941-ENG115978-Leuchte5 TFL RB32-Lichtfunktion E 5	not active
ENG116941-ENG116555-Leuchte5 TFL RB32-Lichtfunktion F 5	not active
ENG116941-ENG115982-Leuchte5 TFL RB32-Lichtfunktion G 5	not active
ENG116941-ENG115983-Leuchte5 TFL RB32-Lichtfunktion H 5	not active
ENG116942-ENG115996-Leuchte6ABL LC5-Dimming Direction CD 6	maximize
ENG116942-ENG116000-Leuchte6ABL LC5-Dimming Direction EF 6	maximize
ENG116942-ENG116004-Leuchte6ABL LC5-Dimming Direction GH 6	maximize
ENG116942-ENG115991-Leuchte6ABL LC5-Dimmwert AB 6	127
ENG116942-ENG115995-Leuchte6ABL LC5-Dimmwert CD 6	0
ENG116942-ENG115999-Leuchte6ABL LC5-Dimmwert EF 6	0
ENG116942-ENG116003-Leuchte6ABL LC5-Dimmwert GH 6	0
ENG116942-ENG115988-Leuchte6ABL LC5-Fehlerort mittleres Byte DTC-DFCC 6	1A
ENG116942-ENG116556-Leuchte6ABL LC5-Lampendefektbitposition 6	36
ENG116942-ENG115986-Leuchte6ABL LC5-Lasttyp 6	3 - Xenon Abblendlicht
ENG116942-ENG115992-Leuchte6ABL LC5-Lichtansteuerung HD AB 6	Always
ENG116942-ENG115989-Leuchte6ABL LC5-Lichtfunktion A 6	Abblendlicht links
ENG116942-ENG115990-Leuchte6ABL LC5-Lichtfunktion B 6	Lichthupe generell
ENG116942-ENG115993-Leuchte6ABL LC5-Lichtfunktion C 6	not active
ENG116942-ENG115994-Leuchte6ABL LC5-Lichtfunktion D 6	not active
ENG116942-ENG115997-Leuchte6ABL LC5-Lichtfunktion E 6	not active
ENG116942-ENG115998-Leuchte6ABL LC5-Lichtfunktion F 6	not active
ENG116942-ENG116001-Leuchte6ABL LC5-Lichtfunktion G 6	not active
ENG116942-ENG116002-Leuchte6ABL LC5-Lichtfunktion H 6	not active
ENG116943-ENG116015-Leuchte7ABL RB1-Dimming Direction CD 7	maximize
ENG116943-ENG116019-Leuchte7ABL RB1-Dimming Direction EF 7	maximize
ENG116943-ENG116023-Leuchte7ABL RB1-Dimming Direction GH 7	maximize
ENG116943-ENG116010-Leuchte7ABL RB1-Dimmwert AB 7	127
ENG116943-ENG116014-Leuchte7ABL RB1-Dimmwert CD 7	0
ENG116943-ENG116018-Leuchte7ABL RB1-Dimmwert EF 7	0
ENG116943-ENG116022-Leuchte7ABL RB1-Dimmwert GH 7	0
ENG116943-ENG116007-Leuchte7ABL RB1-Fehlerort mittleres Byte DTC-DFCC 7	1B
ENG116943-ENG116557-Leuchte7ABL RB1-Lampendefektbitposition 7	40
ENG116943-ENG116005-Leuchte7ABL RB1-Lasttyp 7	3 - Xenon Abblendlicht
ENG116943-ENG116011-Leuchte7ABL RB1-Lichtansteuerung HD AB 7	Always
ENG116943-ENG116008-Leuchte7ABL RB1-Lichtfunktion A 7	Abblendlicht rechts
ENG116943-ENG116009-Leuchte7ABL RB1-Lichtfunktion B 7	Lichthupe generell
ENG116943-ENG116012-Leuchte7ABL RB1-Lichtfunktion C 7	not active
ENG116943-ENG116013-Leuchte7ABL RB1-Lichtfunktion D 7	not active
ENG116943-ENG116016-Leuchte7ABL RB1-Lichtfunktion E 7	not active
ENG116943-ENG116017-Leuchte7ABL RB1-Lichtfunktion F 7	not active
ENG116943-ENG116020-Leuchte7ABL RB1-Lichtfunktion G 7	not active
ENG116943-ENG116021-Leuchte7ABL RB1-Lichtfunktion H 7	not active
ENG116944-ENG116034-Leuchte8FL LB39-Dimming Direction CD 8	maximize
ENG116944-ENG116038-Leuchte8FL LB39-Dimming Direction EF 8	maximize
ENG116944-ENG116042-Leuchte8FL LB39-Dimming Direction GH 8	maximize
ENG116944-ENG116029-Leuchte8FL LB39-Dimmwert AB 8	127
ENG116944-ENG116033-Leuchte8FL LB39-Dimmwert CD 8	0
ENG116944-ENG116037-Leuchte8FL LB39-Dimmwert EF 8	0
ENG116944-ENG116041-Leuchte8FL LB39-Dimmwert GH 8	0
ENG116944-ENG116026-Leuchte8FL LB39-Fehlerort mittleres Byte DTC-DFCC 8	26
ENG116944-ENG116558-Leuchte8FL LB39-Lampendefektbitposition 8	35
ENG116944-ENG116024-Leuchte8FL LB39-Lasttyp 8	36 - LED Kleinleistung
ENG116944-ENG116030-Leuchte8FL LB39-Lichtansteuerung HD AB 8	Always
ENG116944-ENG116027-Leuchte8FL LB39-Lichtfunktion A 8	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116944-ENG116028-Leuchte8FL LB39-Lichtfunktion B 8	Parklicht links (beidseitiges Parklicht aktiviert li & re)
ENG116944-ENG116031-Leuchte8FL LB39-Lichtfunktion C 8	not active
ENG116944-ENG116032-Leuchte8FL LB39-Lichtfunktion D 8	not active
ENG116944-ENG116035-Leuchte8FL LB39-Lichtfunktion E 8	not active
ENG116944-ENG116036-Leuchte8FL LB39-Lichtfunktion F 8	not active
ENG116944-ENG116039-Leuchte8FL LB39-Lichtfunktion G 8	not active
ENG116944-ENG116040-Leuchte8FL LB39-Lichtfunktion H 8	not active
ENG116945-ENG116053-Leuchte9FL RB2-Dimming Direction CD 9	maximize
ENG116945-ENG116057-Leuchte9FL RB2-Dimming Direction EF 9	maximize
ENG116945-ENG116061-Leuchte9FL RB2-Dimming Direction GH 9	maximize
ENG116945-ENG116048-Leuchte9FL RB2-Dimmwert AB 9	127
ENG116945-ENG116052-Leuchte9FL RB2-Dimmwert CD 9	0
ENG116945-ENG116056-Leuchte9FL RB2-Dimmwert EF 9	0
ENG116945-ENG116060-Leuchte9FL RB2-Dimmwert GH 9	0
ENG116945-ENG116045-Leuchte9FL RB2-Fehlerort mittleres Byte DTC-DFCC 9	27
ENG116945-ENG116559-Leuchte9FL RB2-Lampendefektbitposition 9	3F
ENG116945-ENG116043-Leuchte9FL RB2-Lasttyp 9	36 - LED Kleinleistung
ENG116945-ENG116049-Leuchte9FL RB2-Lichtansteuerung HD AB 9	Always
ENG116945-ENG116046-Leuchte9FL RB2-Lichtfunktion A 9	Standlicht allgemein (Schlusslicht: Positionslicht: Begrenzungslicht)
ENG116945-ENG116047-Leuchte9FL RB2-Lichtfunktion B 9	Parking light right
ENG116945-ENG116050-Leuchte9FL RB2-Lichtfunktion C 9	not active
ENG116945-ENG116051-Leuchte9FL RB2-Lichtfunktion D 9	not active
ENG116945-ENG116054-Leuchte9FL RB2-Lichtfunktion E 9	not active
ENG116945-ENG116055-Leuchte9FL RB2-Lichtfunktion F 9	not active
ENG116945-ENG116058-Leuchte9FL RB2-Lichtfunktion G 9	not active
ENG116945-ENG116059-Leuchte9FL RB2-Lichtfunktion H 9	not active
ENG116950-ENG116148-Leuchten14AL LB6-Dimming Direction CD 14	maximize
ENG116950-ENG116152-Leuchten14AL LB6-Dimming Direction EF 14	maximize
ENG116950-ENG116156-Leuchten14AL LB6-Dimming Direction GH 14	maximize
ENG116950-ENG116143-Leuchten14AL LB6-Dimmwert AB 14	0
ENG116950-ENG116147-Leuchten14AL LB6-Dimmwert CD 14	0
ENG116950-ENG116151-Leuchten14AL LB6-Dimmwert EF 14	0
ENG116950-ENG116155-Leuchten14AL LB6-Dimmwert GH 14	0
ENG116950-ENG116140-Leuchten14AL LB6-Fehlerort mittleres Byte DTC-DFCC 14	0
ENG116950-ENG116565-Leuchten14AL LB6-Lampendefektbitposition 14	0
ENG116950-ENG116138-Leuchten14AL LB6-Lasttyp 14	not active
ENG116950-ENG116144-Leuchten14AL LB6-Lichtansteuerung HD AB 14	Always
ENG116950-ENG116141-Leuchten14AL LB6-Lichtfunktion A 14	not active
ENG116950-ENG116142-Leuchten14AL LB6-Lichtfunktion B 14	not active
ENG116950-ENG116145-Leuchten14AL LB6-Lichtfunktion C 14	not active
ENG116950-ENG116146-Leuchten14AL LB6-Lichtfunktion D 14	not active
ENG116950-ENG116149-Leuchten14AL LB6-Lichtfunktion E 14	not active
ENG116950-ENG116150-Leuchten14AL LB6-Lichtfunktion F 14	not active
ENG116950-ENG116153-Leuchten14AL LB6-Lichtfunktion G 14	not active
ENG116950-ENG116154-Leuchten14AL LB6-Lichtfunktion H 14	not active
ENG117284-ENG115658-LuB Lichtrouter Kennlinie 1-x0	0
ENG117284-ENG101574-LuB Lichtrouter Kennlinie 1-X1	10
ENG117284-ENG99557-LuB Lichtrouter Kennlinie 1-X2	100
ENG117284-ENG102140-LuB Lichtrouter Kennlinie 1-X3	150
ENG117284-ENG102936-LuB Lichtrouter Kennlinie 1-X4	220
ENG117284-ENG103548-LuB Lichtrouter Kennlinie 1-X5	253
ENG117284-ENG115659-LuB Lichtrouter Kennlinie 1-y0	0.00%
ENG117284-ENG99777-LuB Lichtrouter Kennlinie 1-Y1	6.00%
ENG117284-ENG100480-LuB Lichtrouter Kennlinie 1-Y2	16.00%
ENG117284-ENG100773-LuB Lichtrouter Kennlinie 1-Y3	30.00%
ENG117284-ENG100631-LuB Lichtrouter Kennlinie 1-Y4	60.00%
ENG117284-ENG102174-LuB Lichtrouter Kennlinie 1-Y5	100.00%
ENG122927-RLS_close_glazing	2.0 s
ENG122928-ENG121637-RLS_lights_for_autobahn-p_t_autobahn_delay_off	120 s
ENG122928-ENG121636-RLS_lights_for_autobahn-p_t_autobahn_delay_on	9 s
ENG122928-ENG121635-RLS_lights_for_autobahn-p_v_autobahn_off	65 km/h
ENG122928-ENG121634-RLS_lights_for_autobahn-p_v_autobahn_on	140 km/h
ENG122929-RLS_LIN_Communication	4 s
ENG122932-ENG123007-RLS_Night_Sensitivity-p_lx_rs_dawn	200 lx
ENG122932-ENG123006-RLS_Night_Sensitivity-p_lx_rs_day	500 lx
ENG122935-RLS_Washer_Front	15 s
ENG122926-RLS_wiper_position_parking	15 s
ENG116971-ENG116537-Vernetzungs- Diagnosefunktionen-can msg 1	00 00
ENG116971-ENG116538-Vernetzungs- Diagnosefunktionen-can msg 2	00 00
ENG116971-ENG116539-Vernetzungs- Diagnosefunktionen-can msg 3	00 00
ENG116971-ENG116540-Vernetzungs- Diagnosefunktionen-can msg 4	00 00
ENG116971-ENG116541-Vernetzungs- Diagnosefunktionen-lin msg 1	00 00
ENG116971-ENG116542-Vernetzungs- Diagnosefunktionen-lin msg 2	00 00
ENG116971-ENG116543-Vernetzungs- Diagnosefunktionen-lin msg 3	00 00
ENG116971-ENG116544-Vernetzungs- Diagnosefunktionen-lin msg 4	00 00
ENG116971-ENG116545-Vernetzungs- Diagnosefunktionen-lin msg 5	00 00
ENG116971-ENG116546-Vernetzungs- Diagnosefunktionen-lin msg 6	00 00
ENG116832-ENG122996-Wischgeschwindigkeiten-Dauerwischen Stufe 1 Zyklen pro Minute	40
ENG116832-ENG122997-Wischgeschwindigkeiten-Dauerwischen Stufe 2 Zyklen pro Minute	60
ENG116832-ENG116699-Wischgeschwindigkeiten-Reduzierte Wischgeschwindigkeit Zyklen pro Minute	30
Elapsed Time: 01:52
