Engine ECU soft code ?
drjohnson666
Verified VCDS-Lite User
C?ID=288030
Hi All
I'm trying to check that the engine ECU soft coding is correct but the little window with the coding options doesn't appear when I click on recode ?
The ABS & Auto Trans codes had been blanked by the last owner so I thought it wise to check the engine one is correct.
I've searched all over the web and can't find the info.
The car is Audi A3 8L 2001 1.8T AUM in the UK, the code that is in the ECU now is 11530
Thanks for your help.
Yours Dave
South Molton, UK
Without an Auto Scan any reply would probably be no more than a guess...
drjohnson666
C?ID=288030
Thanks for replying.
I don't understand why an auto scan would help as I don't have any error codes coming up ?
I'm basically looking for the list like the one for the ABS ECU on Ross Tech site that Uwe helped me calculate the ABS code from but for the engine ECU. The american forums have the options list with codes for the A4 & A6's but I can't find them for the A3.
Any help would be appriciated, thanks Dave.
drjohnson666
C?ID=288030
Sorry I'm not that clued up on this (I'm not a mechanic by trade), below is a copy of the last auto scan I did when I was trying to fix the ABS. The only changes since this one is the Auto Trans code is now 00012, the ABS code is 0019970 & the system test has completed.
VCDS-Lite Version: Release 1.2
Monday, 03 October 2016, 22:24:53:523
Chassis Type: 8L - Audi A3/S3
Scan: 01,02,03,08,15,16,17,22,35,37,45,55,56,57,75,76
Address 01: Engine       Labels: 06A-906-032-AUM.LBL
   Controller: 06A 906 032 HL
   Component: 1.8L R4/5VT         0001
   Coding: 11530
   Shop #: WSC 00186
   VCID: 6F9152B43E85
   WAUZZZ8L02A002535     AUZ5Z0A6024009
Address 02: Auto Trans       Labels: 01M-927-733.LBL
   Controller: 01M 927 733 JJ
   Component: AG4 Getriebe 01M    4827
   Coding: 00000
   VCID: 8175840C9811
Address 03: ABS Brakes       Labels: None
   Controller: 1C0 907 379 E
   Component: ESP FRONT MK60      0104
   Coding: 0000000
   Shop #: WSC 80093
   VCID: 2C2B85B8CF13
01486 -  System Function Test Activated
            000 -   -
Address 08: Auto HVAC       Labels: Redir Fail!
   Controller: 8L0 820 043 K
   Component: A3  KLIMAAUTOMAT   0105
   Coding: 00041
   Shop #: WSC 06435
   VCID: 301391C8E33B
Address 15: Airbags       Labels: 8L0-959-655-AI8.LBL
   Controller: 8L0 959 655 J
   Component: Airbag Front+Seite 5008
   Coding: 01104
   Shop #: WSC 06435
   VCID: 45FDD01C4CB9
Address 17: Instruments       Labels: 8L0-920-xxx-17.LBL
   Controller: 8L0 920 980 P
   Component: KOMBI+WEGFAHRS. M73 D07
   Coding: 00444
   Shop #: WSC 00319
   VCID: 40F3C108539B
Address 35: Centr. Locks       Labels: 8D0-862-257.LBL
   Controller: 8D0 862 257 E
   Component: CV-Pump, Alarm, RC  D17
   Coding: 15178
   Shop #: WSC 06435
   VCID: 2F1192B4FE05
01371 -  Alarm triggered by Door Contact Switch; Driver's Side
            35-00 -   -
01374 -  Alarm triggered by Terminal 15
            35-00 -   -
01370 -  Alarm triggered by Interior Monitoring
            35-00 -   -
01369 -  Alarm triggered by Hood Switch
            35-00 -   -
00955 -  Key 1
            09-00 -  Adaptation Limit Surpassed
01134 -  Alarm Horn (H12)
            49-10 -  No Communications - Intermittent
Address 45: Inter. Monitor       Labels: 4B0-951-173.LBL
   Controller: 4B0 951 173
   Component: Innenraumueberw.    D03
   Coding: 00001
   VCID: E0B3A188735B
Address 56: Radio       Labels: 8D0-035-1xx-56.LBL
   Controller: 8L0 035 195 H
   Component: symphony II NP2    0005
   Coding: 00201
   Shop #: WSC 06435
   VCID: 33199EC4122D
End   --------------------------------------------------------------------------------------------------
