Friday,02,December,2016,14:23:17:48394
VCDS Version: 16.8.4.2 HEX-NET CB: 0.4323.4
VIN: 3VWPL7AJ7BM722116 License Plate:
Mileage: 160840km-99941mi Repair Order:
Chassis Type: AJ (7N0)
Scan: 01 02 03 08 09 15 16 17 19 25 2E 37 42 44 46 4F 52 56 62 72
77
VIN: 3VWPL7AJ7BM722116 Mileage: 160840km-99941miles
Part No SW: 03L 906 019 DB HW: 03L 906 019 DA
Component: R4 2,0L EDC G000AG 9971
Revision: 12H14--- Serial number:
Coding: 0050078
Shop #: WSC 53131 001 1048576
VCID: 6E9001C5792A0F322B-803A
001025 - EGR System
P0401 - 001 - Insufficient Flow - Intermittent
Fault Status: 00100001
Mileage: 159347 km
Date: 2016.11.07
Time: 18:59:33
RPM: 2070 /min
Speed: 105.0 km/h
Voltage: 14.21 V
Load: 76.1 %
Load: 100.0 %
Mass Air / Rev.: 375.0 mg/str
Mass Air / Rev.: 380.0 mg/str
001592 - Throttle Body Actuator Bank 1 (J338)
P0638 - 000 - Implausible Signal - MIL ON
Fault Status: 11100000
Fault Frequency: 15
Mileage: 160663 km
Date: 2016.12.01
Time: 07:33:04
RPM: 1863 /min
Speed: 97.0 km/h
Voltage: 14.21 V
Lambda: 12.6 %
Bin. Bits: 00000000
P0300 - 000 - - Intermittent
Mileage: 160695 km
Date: 2016.12.01
Time: 07:51:36
RPM: 2392 /min
Speed: 112.0 km/h
Load: 51.0 %
Voltage: 14.21 V
Voltage: 14.21 V
Voltage: 14.21 V
Voltage: 14.21 V
000769 - Cylinder 1
P0301 - 000 - Misfire Detected - Intermittent
Mileage: 160695 km
Date: 2016.12.01
Time: 07:51:59
RPM: 2484 /min
Speed: 126.0 km/h
Load: 45.9 %
Bin. Bits: 00000000
Torque: 147.0 Nm
Bin. Bits: 00000000
Ign. Timing: 18.4 °ATDC
000771 - Cylinder 3
P0303 - 000 - Misfire Detected - Intermittent
Mileage: 160695 km
Date: 2016.12.01
Time: 07:51:59
RPM: 2484 /min
Speed: 126.0 km/h
Load: 45.9 %
Bin. Bits: 00000000
Torque: 147.0 Nm
Bin. Bits: 00000000
000770 - Cylinder 2
P0302 - 000 - Misfire Detected - Intermittent
Mileage: 160695 km
Date: 2016.12.01
Time: 07:51:59
RPM: 2484 /min
Speed: 126.0 km/h
Load: 45.9 %
Bin. Bits: 00000000
Torque: 150.0 Nm
Bin. Bits: 00000000
Readiness: 1 2 0 0 0
Part No SW: 02E 300 057 A HW: 02E 927 770 AL
Component: GSG DSG AG6 511 2705
Revision: 05351113 Serial number: 00001104300927
Shop #: WSC 00066 000 00000
VCID: 177E04212630AEFA18-8042
18255 - Please check DTC Memory of ABS Controller
P1847 - 000 - - Intermittent
Fault Frequency: 255
Reset counter: 1
Mileage: 159419 km
Date: 2016.11.17
Time: 13:03:17
Address 03: ABS Brakes (J104) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 BJ HW: 1K0 907 379 BJ
Component: ESP MK60EC1 H31 0121
Revision: 00H31001
Coding: 114B600C492400FC880C06E5921F0042B70000
Shop #: WSC 02428 444 12601
VCID: 7BB63891FA586A9A9C-802E
Fault Frequency: 16
Reset counter: 130
Mileage: 159464 km
Date: 2016.11.19
Time: 13:48:10
Count: 3
Count: 13
Count: 20480
Count: 128
Count: 33792
Reset counter: 61
Mileage: 159419 km
Date: 2016.11.17
Time: 13:03:26
Count: 3
Count: 12
Count: 12800
Count: 16390
Count: 51200
Fault Status: 01101100
Reset counter: 60
Mileage: 159419 km
Count: 7
Count: 13
Count: 4096
Count: 64
Count: 35072
Address 08: Auto HVAC (J301) Labels: 3C8-907-336.clb
Part No SW: 7N0 907 426 L HW: 7N0 907 426 L
Component: AC Manuell H17 0202
Revision: 00001012
Coding: 0000001002
Shop #: WSC 00066 000 00146
ROD: EV_ClimaBasis_VW36.rod
VCID: 3D32F689ACCCA4AAE2-8068
Address 09: Cent. Elect. (J519) Labels: 1K0-937-08x-09.clb
Part No SW: 5K0 937 084 G HW: 5K0 937 084 G
Component: BCM PQ35 B 011 0046
Revision: BG011001
Coding: 2F380E1F802F3EC4008800817000004441000086535D0560648020200040
VCID: 3620E9A581FA77F223-8062
Subsystem 1 - Part No: 5K1 955 119 Labels: 1KX-955-119.CLB
Component: Wischer 17061 26 0512
Coding: 009795
00984 - Left Tail Light (M4)
010 - Open or Short to Plus
Fault Status: 01101010
Reset counter: 61
Mileage: 159419 km
Date: 2016.11.17
Time: 13:03:19
Voltage: 14.25 V
Fault Status: 00101010
Reset counter: 127
Mileage: 160445 km
Date: 2016.11.30
Time: 07:34:58
Voltage: 14.40 V
Fault Frequency: 99
Reset counter: 124
Mileage: 129051 km
Date: 2016.01.26
Time: 16:52:53
Voltage: 14.20 V
Address 15: Airbags (J234) Labels: 5K0-959-655.clb
Part No SW: 5K0 959 655 B HW: 5K0 959 655 B
Component: AirbagVW10G 021 0706
Serial number: 003C4R027WJK
Coding: 00003044
ASAM Dataset: EV_AirbaVW10SMEVW360 A01012
ROD: EV_AirbaVW10SMEVW360.rod
VCID: 393AE299B8E4988ACE-806C
Subsystem 1 - Part No SW: 1KM 959 339 HW: 1KM 959 339
Component: BF-Gewichtss. 007 0001
Serial number: ---0000R--0005FF3W00
Subsystem 2 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3572MSME232A215FZZZX
Subsystem 3 - Part No SW: 1KM 955 557 HW: 1KM 955 557
Serial number: 3582MSME2351515FZZZV
Serial number: 3511HSME23311927ZZZ9
Serial number: 3521HSME0A131A27ZZZG
Serial number: 35527SME22402327ZZZ+
Serial number: 35627SME22512327ZZZ1
B10B3 00 [137] - Function Restriction due to Implausible Message(s)
Fault Frequency: 36
Reset counter: 90
Mileage: 159419 km
Date: 2016.11.17
Time: 13:03:35
Address 16: Steering wheel (J527) Labels: 5K0-953-569.clb
Part No SW: 5K0 953 507 AH HW: 5K0 953 549 B
Revision: -------- Serial number: 90422KDJ000EA
Coding: 188A140000
Shop #: WSC 00066 000 00185
ROD: EV_SMLSNGKUDS_VW32.rod
VCID: 76A029A5C97A37F2E3-8022
Subsystem 1 - Part No SW: 5K0 959 542 A HW: 5K0 959 542 A Labels: 3C8-959-537.CLB
Component: E221__MFL-TAS H09 0013
Serial number: 0317804
Coding: 820000
Part No SW: 5K0 920 971 CX HW: 5K0 920 971 CX
Component: KOMBI H20 0420
Coding: 270F01
VCID: 075E5461BE903E7A88-8052
Address 19: CAN Gateway (J533) Labels: 7N0-907-530-V2.clb
Part No SW: 7N0 907 530 D HW: 1K0 907 951
Component: J533 Gateway H35 0614
Revision: H35 Serial number: 16061101200343
Coding: 352002
VCID: 312ADAB9689450CA76-8064
Component: IMMO H20 0420
VCID: 6A980DD58DC2E31277-803E
Address 2E: Media Player 3 (J650) Labels: 5N0-035-342.lbl
Part No SW: 5N0 035 342 D HW: 5N0 035 342 D
Revision: A1001003 Serial number: 7669930071
Coding: 020000
VCID: 281C37DD5B4E1102A1-807C
Address 37: Navigation (J794) Labels: 1K0-035-27x-37.clb
Part No SW: 1K0 035 274 B HW: 1K0 035 274 B
Component: RNS315-NAR H31 0263
Serial number: VWZAZ2L8449574
Coding: 040004210400070000008000
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_RNS315NARV2UDS A01004
ROD: EV_RNS315NARV2UDS.rod
VCID: 230620F12A68F25AF4-8076
Component: NAR_V2 0002
1048669 - Tuner for Satelite Radio
B11CF 53 [009] - Deactivated
Reset counter: 70
Mileage: 108741 km
Date: 2019.07.15
Time: 18:42:20
Address 42: Door Elect, Driver (J386) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG FT 002 0501
Revision: 13110009 Serial number: 0002458526
Coding: 0004B5
ROD: EV_TSGFPQ35BRFVW46X.rod
VCID: 5BF6581152988A9AFC-800E
Slave Driver:
Subsystem 1 - Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T Labels: 1K0-959-70X-GEN4.CLB
Component: J388__TSG-HL 006 1401
Serial number: 00000005695990
Coding: 000490
Part No: 1K0 909 144 M
Component: EPS_ZFLS Kl. 70 3201
Revision: 00H20000
Shop #: WSC 02069 000 90108
VCID: 3424D3AD578665E21D-8060
013 - Check DTC Memory
Fault Status: 01101101
Reset counter: 61
Mileage: 159419 km
Date: 2016.11.17
Time: 13:03:20
Voltage: 14.38 V
DU
Temperature: 10.0°C
RPM: 986 /min
Address 4F: Centr. Electr. II (J520) Labels: 1K0-907-532.clb
Part No SW: 7N0 907 532 HW: 1K0 907 951
Component: EZE_2 H35 0614
Coding: 050B0500
VCID: 6FAE1CC1BE20063A20-803A
Subsystem 1 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J245EE20SKB13 H02 0220
Subsystem 2 - Part No SW: 8R0 959 591 A HW: 8R0 959 591
Component: J394EE20SKB13 H02 0220
Address 52: Door Elect, Pass. (J387) Labels: 3C0-959-70X-GEN4.clb
Component: TUER-SG BT 002 0501
Revision: 15110009 Serial number: 0002406876
Coding: 0004B4
ROD: EV_TSGBPQ35BRFVW46X.rod
VCID: 5CF45B0D57968DA2F5-8008
Slave Passenger:
Subsystem 1 - Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T Labels: 1K0-959-70X-GEN4.CLB
Component: J389__TSG-HR 006 1401
Serial number: 00000005601240
Coding: 000490
Address 77: Telephone (J412) Labels: 7P6-035-730.clb
Part No SW: 5K0 035 730 HW: 5K0 035 730
Component: TELEFON H09 1020
Revision: 1B001001 Serial number: 00007669851685
Coding: 0A00000000010100
ASAM Dataset: UHVNA A01009
ROD: UHVNA.rod
VCID: 628865F575F2BB52BF-8036
End----------(Elapsed Time: 01:22, VBatt start/end: 12.3V/12.3V)-----------
