Hey there -
Just picked up my 2017 GTI a couple of weeks ago and am loving it. I invested in a Ross-Tech HEX-NET to tweak ALL THE THINGS. One tweak I have been unable to do is increase the number of turn signal "comfort blinks" from the default 3 to either 4 or 5 blinks. I think I figured out where to set this within VCDS (09-Cent. Elect./Adjustment/Turn signal control-Komfortblinken Blinkzyklen), but when I set the new value to a higher number and click "Do It!", VCDS stores the higher value (5) but the car still only blinks the turn signal 3 times.
Anyone else had luck with a 2017 GTI? Perhaps this is set in another adaptation channel?
Any advice would be greatly appreciated.
Below is my auto-scan...
Monday,28,November,2016,19:22:55:22913
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86(VirtualBox)
VCDS Version 16.8.3.1 HEX-NET CB: 0.4323.4
VIN: 3VW447AU5HM0xxxxx License Plate:
Mileage: 546km-339mi Repair Order:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 13 14 15 16 17 19 2B 32 3C 42 44 47 52 55
5F 75 A9
VIN: 3VW447AU5HM0xxxxx Mileage: 546km-339miles
Address 01: Engine (J623-CXCB) Labels: None
Part No SW: 5G0 906 259 L HW: 06K 907 425 B
Component: 2.0l R4 TFSI H13 0001
Revision: --H13---
Coding: 091D00124464002F1000
Shop #: WSC 00066 790 00208
ASAM Dataset: EV_ECM20TFS0205G0906259L 001003
ROD: N/A
VCID: 373EE62D8E1405FA4D-8063
No ASAM data for: "EV_ECM20TFS0205G0906259L" (VW37)
Readiness: 1010 0101
Part No SW: 0D9 300 020 L HW: 02E 927 770 AQ
Component: DQ250-6V MQB H54 4902
Revision: 06354004 Serial number: TFK01606011445
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 1E70138901EE54B2AE-804B
Part No SW: 5Q0 614 517 BK HW: 5Q0 614 517 AH
Component: ESC H62 0736
Revision: 00000000 Serial number: 61426000000657
Coding: 01FA6BA15420096F8078020241C96880D62A900140821636164350D1C08903
Shop #: WSC 01383 790 50316
VCID: 7BB63A1DF2BCE19AE9-802F
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0406882917
Coding: 032C0C
VCID: 3B36FA1DB23C219AA9-806F
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03
Coding: 00020014200100000005000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: 44C481E1CFC25E62D8-8011
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 865809061600WH
Coding: 00111A464041A2E969E44000001407201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: 7AB83F19FD86D892F2-802F
Subsystem 1 - Part No SW: 5GM 955 119 HW: 5GM 955 119 Labels: 5QX-955-119-V1.CLB
Component: WWS 160327 043 0581
Serial number: 160705223301
Component: RLHS 042 0105
Serial number: S4Y16M07D04H16M47S06
Coding: 008F77
Sun Roof:
Subsystem 3 - Part No SW: 5GD 959 591 HW: 5GD 959 591
Component: J245 PS60.036 H06 0150
Serial number: 03691600471512150840
Coding: 181803
Address 13: Auto Dist. Reg (J428) Labels: 5Q0-907-572.clb
Part No SW: 5Q0 907 572 G HW: 5Q0 907 572 G
Component: ACC BOSCH MQB H10 0571
Coding: 3500008141FFC428949C8045000016
ASAM Dataset: EV_ACCBOSCHVW416 001005
ROD: N/A
No ASAM data for: "EV_ACCBOSCHVW416" (VW37)
Address 14: Susp. Elect. (J250) Labels: 5Q0-907-376.clb
Part No SW: 5Q0 907 376 B HW: 5Q0 907 376 A
Serial number: 28051641350334
ROD: EV_DRCONTITEMIC.rod
VCID: 383CE511830A0A8244-806D
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR04Z5T2
Shop #: WSC 00066 790 00211
VCID: 47DE96EDFEF4757A3D-8013
Occupant Detection:
Component: BF-Gewichtss. H12 0021
Serial number: IBH000000000005DELY4
Coding: 303131
Subsystem 2 - Part No SW: ----------- HW: 480 001 905 16
Serial number: 35700000000B035D9A1O
Subsystem 3 - Part No SW: ----------- HW: 480 001 905 16
Serial number: 358000000002882CCA1S
Subsystem 4 - Part No SW: ----------- HW: 480 401 805 16
Serial number: 3510002BD2076342231M
Subsystem 5 - Part No SW: ----------- HW: 480 401 805 16
Serial number: 3520002992057292025L
Subsystem 6 - Part No SW: ----------- HW: 480 400 905 16
Serial number: 3550002AF207635041C.
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 400 905 16
Component: FrontSensor_P 001 6149
Serial number: 3560002B32076354632P
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160620400008
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 044441E18F429E6298-8051
Part No SW: 5G1 920 856 B HW: 5G1 920 856 B
Component: KOMBI 344 8311
Coding: 0BAD091ABD88CF0502886A095000000000000000
VCID: 2D12C4457C48BF2A27-8079
Part No SW: 5Q0 907 530 AM HW: 5Q0 907 530 M
Component: GW MQB High 212 2265
Revision: -------- Serial number: 20041610800412
Coding: 0101000830085900FB00023B9C0F00000001050000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: 7CB43901F7B2E6A2E0-8029
Subsystem 2 - Part No SW: 5G0 959 442 S HW: 5G0 959 442 S
Component: E221__MFL-DC1 H10 0040
Serial number: 29150001449940025305
Coding: 35FFFF
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000088967007
Coding: 5D00000000000000
Shop #: WSC 00066 790 00323
ROD: EV_ELVMarquMQB_SK25.rod
VCID: 3424D1219F62EEE268-8061
Address 32: Differential Locks (J492) Labels: 0CQ-907-554.clb
Part No SW: 0CQ 907 554 E HW: 0CQ 907 554 E
Component: Quersperre H52 8042
Serial number: HA1-00003.05.16
Coding: 0001
ASAM Dataset: EV_LockElectHA1VW37X 001007
ROD: EV_LockElectHA1VW37X.rod
Address 3C: Lane Change (J1086) Labels: None
Part No SW: 5Q0 907 686 B HW: 5Q0 907 686 B
Component: HRE_Master H12 0071
Serial number: 0405608424
Coding: 01011103
ROD: EV_HREntryHella.rod
VCID: 3C34F901B73226A2A0-8069
Lane Change Assistant 2:
Component: TSG FS 020 0041
Serial number: 240616060500BU
Coding: 003E13200000020000000000
VCID: 43C682FDCACC595AE1-8017
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000012964212
Coding: 011000
Part No SW: 3Q0 909 144 J HW: 3Q0 909 144 H
Component: EPS_MQB_ZFLS 505 5063
Coding: 8102
VCID: 393AE015B800138ABB-806D
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Component: MIB2_lite_amp H20 0150
Revision: 00000001 Serial number: VWZ8Z1GBA01YZB2
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: 6D920445BCC87F2A67-8039
Component: TSG BFS 020 0041
Serial number: 230616060504GO
VCID: 42C887F9D5D65052EA-8017
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000012805495
Coding: 091000
Address 55: Headlight Range (J745) Labels: 7P6-907-357.clb
Part No SW: 7P6 907 357 D HW: 7P6 907 357 A
Component: AFS-ECU H07 0090
Coding: 021203010B000400
VCID: 40CC8DF1DBDA4242FC-8015
Subsystem 1 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo links H01 0004
Coding: 2E0000
Subsystem 2 - Part No SW: 5N0 941 329 HW: 5N0 941 329 Labels: 3D0-941-329.CLB
Component: LeiMo rechts H01 0004
Coding: 2E0000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027300020000000051220002001808009F0203F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: 3228D7396576E0D27A-8067
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX006PQ
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
ROD: EV_OCULowMQB.rod
Part No SW: 5G0 907 159 HW: 4H0 907 159 A
Component: SAS-GEN 2 H06 0014
Serial number: 160415200401
VCID: 6B960A5D82DC711A79-803F
End----------(Elapsed Time: 01:49, VBatt start/end: 14.3V/14.4V)-----------
