Hi Folks,
I am not sure if this is anything I need to worry about or not, but I just got a call from the VW Autobody shop.
(My car is currently in having some panels replaced under the VW corrosion warranty).
Apparently while welding one of the new quarter panels on, a "wire penetrated another wire".
I assume this means that the mig wire hit the wiring harness...or there was an arc somewhere?...
Anyway, this caused the passenger side curtain airbag to deploy, and apparently damaged the headliner and the airbag module.
They are going to repair these things under warranty, and the car will be sent back to the dealer to make sure all of the airbags are working properly.
Is there anything I need to worry about here?
Should anything else be investigated or checked out by me afterwards?
Should I advise the dealer to check/confirm anything else?
I just want to cover my butt here and avoid any future problems related to this repair.
I did do an Autoscan before dropping the car off, so I know there were zero codes/faults at that time.
Sunday,09,October,2016,13:18:36:24871
VCDS Version: 16.8.2.3 (x64)
Data version: 20160926 DS261.0
VIN: 3VWDT71K96M009364 License Plate:
Mileage: 192400km-119551mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 7D
VIN: 3VWDT71K96M009364 Mileage: 192400km-119551miles
Address 01: Engine Labels: 038-906-016-BEW.lbl
Part No SW: 03G 906 016 AB HW: 028 101 223 8
Component: R4 1,9L EDC G000SG 7550
Revision: --H03--- Serial number: VWZ7Z0F4255044
Coding: 0050071
Shop #: WSC 00066 000 00000
VCID: 63C580DBA2349F5AC9-8036
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC
Component: ESP FRONT MK60 0101
Revision: 00H11001
Coding: 0021122
VCID: 73E5F09B12D40FDAB9-8026
Part No: 1K0 820 047 DQ
Component: Climatic PQ35 090 0505
VCID: 76E3C98F01A61AF29E-8022
Address 09: Cent. Elect. Labels: 3C0-937-049-23-M.lbl
Part No SW: 3C0 937 049 P HW: 3C0 937 049 P
Component: Bordnetz-SG H46 1501
Revision: 00H46000 Serial number: 00000000360553
Coding: 10018E234004150007140000001400000008730B5C0000
VCID: 3663098F41265AF25E-8062
Component: Wischer 200606 020 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 1K0 909 605 Q HW: 1K0 909 605 Q
Component: 6D AIRBAG VW8R 033 7900
Revision: 04033000 Serial number: 0038LD09H1B/
Coding: 0013892
VCID: 3A7B1DBF753EBE92BA-806E
Subsystem 1 - Serial number: 6332MSME115910772
Subsystem 2 - Serial number: 6342MSME0E27140BB
Subsystem 3 - Serial number: 6351HSME096F04225
Subsystem 4 - Serial number: 6361HSME0A124206-
Subsystem 5 - Serial number: 63727SME0A02571D+
Subsystem 6 - Serial number: 63827SME0A064D50%
Part No SW: 1K0 953 549 AR HW: 1K0 953 549 AR
Component: J0527 035 0070
Coding: 0000021
VCID: 020BA55F5D6E3652A2-8056
Part No SW: 1K0 920 853 K HW: 1K0 920 853 K
Component: KOMBIINSTRUMENT 3HL 1610
Revision: V0003000 Serial number: VWZ7Z0F4255044
Coding: 0023303
Shop #: WSC 95855 999 58414
VCID: 326B359FAD4E46D272-8066
Address 19: CAN Gateway Labels: 1K0-907-530-V2.clb
Part No SW: 1K0 907 530 H HW: 1K0 907 951
Component: J533__Gateway H12 0150
Revision: H12 Serial number: 31001065160765
Coding: 3D3F0B4007001002
VCID: 2C572BE78F6A102238-8078
Component: IMMO 3HL 1610
Part No SW: 1K0 959 701 P HW: 1K0 959 793 L
Component: J386 TUER-SG FT 1125
Revision: 12006001 Serial number: 00000089468619
Coding: 0001205
VCID: 3B7518BB7A04879AA1-806E
Part No: 1K1 909 144 L
Component: EPS_ZFLS Kl.069 H07 1806
VCID: 34673387575A48E260-8060
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CA HW: 1K0 959 433 CA
Component: KSG PQ35 G2 020 0202
Revision: 00020000 Serial number: 00000000000000
Coding: 13900F880106281B0904058FB0880F0488FCA0
VCID: 71E9FA9368C83DCA4B-8024
Part No SW: 1K0 959 702 P HW: 1K0 959 792 L
Component: J387 TUER-SG BT 1125
Revision: 12006001 Serial number: 00000658168618
Coding: 0001204
VCID: 3C771BA77F0A80A2A8-8068
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 B HW: 1K0 035 161 B
Component: Radio DE2 014 0016
Revision: 00014000 Serial number: VWZ4Z7F6148617
Coding: 0040401
VCID: 1E33F12FC9D6F2B2A6-804A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 Q HW: 1K0 959 795 J
Component: J388 TUER-SG HL 1115
Revision: 12004001 Serial number: 00000000113811
Coding: 0001168
VCID: 3E7311AF691692B286-806A
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 Q HW: 1K0 959 794 J
Component: J389 TUER-SG HR 1115
Revision: 12004001 Serial number: 00000000137040
Coding: 0001168
VCID: 3F8D6CAB6E1C9BBA8D-806A
Component: PTC-Element 0404
VCID: 2D5126E3B470192A2F-8078
End-------------------------(Elapsed Time: 01:53)--------------------------
