Passat B7 ACC retrofit in progress...
m87a
Bosnia and Herzegovina
C?ID=156900
since there is little or no info or wrong info for coding acc here is guide, maybe it will help someone, it's always better to have it in one place :) i helped a friend retrofit acc well almost...
he bought used radar, cheaper and also no need to calibrate/basic settings, 3AA907567 with bracket and connector, extended cables and connected
waiting on ABS to finish retrofit, ABS supporting ACC:
3AA 614 109 E, D, Q, T, AA, AE, AJ, AN, AM, AR, AS, BB, BC, BJ, BL, BN, BS
after replacing abs code it, adjust adaptation channel 021 overboost level, then 061 Hydraulic brake pressure and basic setting well documented on vcds wiki
ps. if you need to activate or de activate PLA: security code70605 - adaptation channel 97 set to 1 or 0
acc radar pinouot:
pin1 - not used
pin2 - ground
pin3 - not used
pin4 - can bus Ext. High (gateway pin17)
pin5 - can bus Ext. Low (gateway pin17)
pin6 - not used
pin7 - not used
pin8 - to steering wheel module to pin5 keep current wire (if you have cruise control you have this wire, otherwise you will have to add it, it connects to ECU)
pin9 - ground
pin10 - fuse SC4
coding
1. can gateway mark 13 - Auto Dist. Reg. in installation list
2. code engine control unit, in b7 passat these bytes were unrecorded so had to search in order to find values, use L2Code mark byte 4 bit 5 ACC
3. code steering wheel activate assistant menu byte 0 bit 1 and acc byte 2 bit7 (also unrecorded 00-no cruise control, 20- cruise control and missing 40-acc)
4.code abs, to current value add +114688 if supported it will be accepted otherwise no, been there, done that
5. radar can be coded 10000 manual transmition or 10100 automatic (DSG) transmition but in order to recode it there is a procedure, of course we had it coded for manual instead for dsg
we need to unlock coding:
enter security code 21056
adaptation channel 2 set to 201
change coding either 10000 or 10100 after that we need to relock coding
adaptation channel 2 set to 1, recoding is safe, basic setting are not lost ;)
cycled ignition two times and you're golden or waiting for abs
i'll post a scan after we get abs ;)
m87a
C?ID=156900
ok first some correction as I have found out in VCDS label there is mistake in label for Address 13: Auto Dist. Reg, it says 10000 for manual and 101000 for automatic, actually its vice versa
10000 for automatic / DSG and
10100 for manual
in coding ECU for ACC byte 5 bits 5 and 6 were both set to 1 for ACC (drop down menu shows nothing)
here is the old scan
Saturday,21,November,2015,17:00:32:03082
VCDS Version: 15.7.1.0 (x64)
Data version: 20150904
VIN: WVWZZZ3CZCP016616   License Plate: JULE
Mileage: 115440km-71731mi   Repair Order:
Chassis Type: 3C (7N0)
Scan: 01 02 03 08 09 10 15 16 17 19 25 36 37 42 44 46 4C 4F 52 53
          55 56 61 62 69 6C 72 77
VIN: WVWZZZ3CZCP016616   Mileage: 115440km-71731miles
Address 01: Engine (J623-CFGB)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 BD    HW: 03L 907 309 N
   Component: R4 2,0L EDC   X26 9953
   Revision: 41X26---    Serial number: VWZCZ000000000
   Coding: 001D0032043401080000
   Shop #: WSC 01286 386 08256
   ASAM Dataset: EV_ECM20TDI01103L906018BD 003007
   ROD: EV_ECM20TDI01103L906018BD.rod
   VCID: 6DDB8BF1BC9DF45686-8038
   Part No SW: 02E 300 057     HW: 02E 927 770 AL
   Component: GSG DSG AG6     511 2703
   Revision: 05351113    Serial number: 00001107282491
   Coding: 0000024
   Shop #: WSC 00028 028 00001
   VCID: 56A9C41DE10B578E57-8002
   Part No SW: 3AA 614 109 AC    HW: 3AA 614 109 AC
   Component: J104   C2 450M VDB7 0022
   Revision: --H07---    Serial number: 00000004576544
   Coding: 0007612
   VCID: 6ED98CFD799B0F4EBF-803A
   Part No SW: 3AA 907 044 AK    HW: 3AA 907 044 AK
   Component: Climatronic   H03 0202
   Revision: 00001K01
   Coding: 0010004803
   Shop #: WSC 00015 115 12345
   VCID: 79F3AFA1F8D558F61A-802C
Address 09: Cent. Elect. (J519)       Labels: 3AA-937-087.clb
   Part No SW: 3AA 937 087 E    HW: 3AA 937 087 E
   Component: BCM PQ47 H+   413 0455
   Revision: BC413001
   Coding: 000800000000000000080080740029F427FD0088616C8760E488C7240041
   VCID: 3C7D76B5BF67ADDE41-8068
   Subsystem 1 - Part No SW: 3AB 955 419     HW: 3AB 955 419   Labels: 1KX-955-119.CLB
   Component: Wischer 06071  10  0603
   Coding: 00BF95
   Component: RLS 040811 05  54  0403
   Coding: 074D2A
Address 10: Park/Steer Assist (J791)       Labels: 3AA-919-475.clb
   Part No SW: 3AA 919 475 L    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0025
   Revision: --------    Serial number: 56261122200343
   Coding: 368305
   Shop #: WSC 00028 028 00020
   ASAM Dataset: EV_EPHVA2C000000000 002008
   ROD: EV_EPHVA2C000000000_SE36.rod
   VCID: 448D0E55CF97D51E39-8010
   Part No SW: 5N0 959 655 R    HW: 5N0 959 655 R
   Component: J234__101 VW10 HI   1918
   Revision: 22014000    Serial number: 003K0PELDMJ8
   Coding: 0012337
   VCID: 4C9D26752FC71D5EF1-8018
   Subsystem 1 - Serial number: 6332MTS636922081
   Subsystem 2 - Serial number: 6342MTS680482081
   Subsystem 3 - Serial number: 6351HTS6QHBECAKJ
   Subsystem 4 - Serial number: 6361HTS65C3BAAKJ
Address 16: Steering wheel (J527)       Labels: 3C0-953-569.clb
   Part No SW: 3C5 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110814300880
   Coding: 099A250000
   VCID: 6BDF85E98289FA6698-803E
   Subsystem 1 - Part No SW: 5K0 959 542 B    HW: 5K0 959 542 B  Labels: 3C8-959-537.CLB
   Component: E221__MFL-TAS  H30 0036
   Coding: 830000
Address 17: Instruments (J285)       Labels: 3C8-920-xxx-17.clb
   Part No SW: 3AA 920 880 C    HW: 3AA 920 880 C
   Component: KOMBI         H03 0407
   Coding: 160F01
   VCID: 336F5D899A3962A690-8066
   Part No SW: 7N0 907 530 L    HW: 1K0 907 951
   Component: J533  Gateway H41 1620
   Revision:   H41       Serial number: 020811F1003352
   Coding: 461006
   VCID: 39736FA1B05598F65A-806C
   Part No SW: 3AA 959 433     HW: 3AA 959 433
   Component:    IMMO         043 0400
   Revision: 00043000    Serial number: VWZCZ000000000
   VCID: 76E9A49D01CB378E77-8022
   Part No SW: 3C8 959 760 A    HW: 3C8 959 760 A
   Component: Sitzmemory    H05 2601
   Revision: 00H05000
   Coding: 000039
   VCID: 336F5D89923962A690-8066
   Part No SW: 1T0 035 680 Q    HW: 1T0 035 680 Q
   Component: RNS-MID       H08 5274
   Revision: AB001001    Serial number: VWZ6Z7M9345162
   Coding: 00000402040000A00000
   Shop #: WSC 00404 219 107220
   Subsystem 1 - Part No: 1T0 919 859 C
   Component: EU East V13  8350
   Part No SW: 3AA 959 701 A    HW: 3C0 959 793 C
   Component: TUER-SG FT    002 0533
   Revision: 12110009    Serial number: 0003355553
   Coding: 0211FF
   ROD: EV_TSGFPQ35BRFVW46X.rod
   VCID: 356B6391944D7C96BE-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3C0 959 703     HW: 3C0 959 795   Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0408
   Serial number: 00000002371085
   Coding: 0000D8
   Part No SW: 5N1 909 144 M    HW: 5N1 909 148 G
   Component: J500__APA-BS KL.311 1002
   Revision: 1AH03733    Serial number: 00112220043601
   Coding: 0000258
   VCID: 3C7D76B57F67ADDE41-8068
Address 46: Central Conv.        Labels: 3C0-959-433-46.clb
   Component:    KSG PQ47 ELV 043 0634
   Coding: 01910A0002864E76300294157C08CFCF707801
   Component: Neigungssensor  004 0611
Address 4C: Tire Pressure II
   Component: EZE_2         H41 1620
   Coding: 00000008
   VCID: 6FE791F9BE910646B4-803A
   Subsystem 1 - Part No SW: 3AA 919 204 A    HW: 3AA 919 204 A
   Component: Analoguhr  004 0003
   Part No SW: 3AA 959 702 A    HW: 3C0 959 792 C
   Component: TUER-SG BT    002 0533
   Revision: 14110009    Serial number: 0003323619
   Coding: 0211FE
   ROD: EV_TSGBPQ35BRFVW46X.rod
   VCID: 3669649D894B778EB7-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3C0 959 704     HW: 3C0 959 794   Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0408
   Serial number: 00000002366267
   Coding: 0000D8
   Part No SW: 3AA 907 801 G    HW: 3AA 907 801 G
   Component: J540 EPB4  VW-64783 0009
   Revision:   H19       Serial number: 00000000148004
   Coding: 0022157
   VCID: 356B63915C4D7C96BE-8060
Address 55: Headlight Range (J745)       Labels: 5M0-907-357-V3.clb
   Part No SW: 5M0 907 357 E    HW: 7L6 907 357 C
   Component: AFS-ECU       H04 0105
   Coding: 029200000B000200
   ASAM Dataset: EV_HeadlRegulVWAFSPt 002014
   ROD: EV_HeadlRegulVWAFSPt_SK46.rod
   Subsystem 1 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0011
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329     HW: 3D0 941 329   Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0011
   Coding: 230000
   Component: Batt.regelung H41 1620
   Coding: 030B185A
   VCID: 71E39781A8A510B6A2-8024
   Component: J367-BDM  H07 0180
Address 69: Trailer (J345)       Labels: 7N0-907-383.clb
   Part No SW: 7N0 907 383     HW: 7N0 907 383
   Component: Anhaenger     H09 0101
   Revision: 3I001002    Serial number: 00000152263536
   Coding: 4106040000000000
   VCID: 73EF9D89D2B922A650-8026
   Part No SW: 3AE 907 441     HW: 3AE 907 441
   Component: J772__Rearview      0020
   Revision: 00H09000    Serial number: 525 PA8J142846
   Coding: 0030006
   VCID: 72E1988D6DA32BAE5B-8026
   Part No SW: 7P6 035 730 E    HW: 7P6 035 730 E
   Component: TELEFON       H09 2730
   Revision: 1B001001    Serial number: 00007660210612
   Coding: 0A01000000010101
   Shop #: WSC 01383 790 50316
   ASAM Dataset: EV_UHVNA A01015
   ROD: EV_UHVNA.rod
   VCID: 346D5E959F37659E89-8060
End-------------------------(Elapsed Time: 03:39)--------------------------
new scan with full adaptive lights and couple other options :D
Saturday,21,January,2017,22:43:40:03082
VCDS Version: 17.1.0.0 (x64)
Data version: 20170106 DS267.0
Dealer/Shop Name: m87a
Workshop Code: 011 01357 012345
VIN: WVWZZZ3CZCP016616   License Plate: JULE ACC
Mileage: 159520km-99121mi   Repair Order:
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 36 37 3C 42 44 46 4C 4F
          52 53 55 56 61 62 69 6C 72 77 A5
VIN: WVWZZZ3CZCP016616   Mileage: 159520km-99121miles
   Coding: 001D0032047401080000
   Shop #: WSC 01357 011 12345
   VCID: 6DDB8BF1BC9DF42914-8038
   Coding: 0000024
   VCID: 56A9C41DE10B57F1C5-8002
   Part No SW: 3AA 614 109 AJ    HW: 3AA 614 109 AG
   Component: J104   C2 450M VE5D 0023
   Revision: --H07---    Serial number: 00000004932187
   Coding: 0122300
   VCID: 75EBA3911CCD3CE9EC-8020
   Revision: 00001K01
   Coding: 0010004803
   VCID: 79F3AFA1F8D5588988-802C
   Revision: BC413001
   Coding: 000800000000000000080088740029FC27FD0088616C8760C688C7240049
   VCID: 3C7D76B5BF67ADA1D3-8068
   Coding: 00BF95
   Component: RLS 271011 05  54  0403
   Coding: 07302A
   Coding: 368305
   ROD: EV_EPHVA2C000000000_VW41.rod
   VCID: 448D0E55CF97D561AB-8010
Address 13: Auto Dist. Reg        Labels: 3AA-907-567.clb
   Part No SW: 3AA 907 567 A    HW: 3AA 907 567
   Component: AC201  RDW A    036 0170
   Revision: 00036000    Serial number: 00000000621802
   Coding: 0010000
   VCID: 38756AA54B5F818137-806C
   Coding: 0012337
   VCID: 4C9D26752FC71D2163-8018
   Part No SW: 3C9 953 501 BL    HW: 5K0 953 569 T
   Revision: FF010040    Serial number: 20110930101467
   Coding: 299AA70003
   VCID: 74ED9E95DFB725E1DB-8020
   Coding: 830000
   Coding: 160F01
   VCID: 336F5D899A3962D902-8066
   Coding: 461006
   VCID: 39736FA1B0559889C8-806C
   VCID: 76E9A49D01CB37F1E5-8022
   Revision: 00H05000
   Coding: 000039
   VCID: 336F5D89923962D902-8066
   Part No SW: 1T0 035 686 C    HW: 1T0 035 686 C
   Component: RNS-MID       H09 5269
   Revision: AB001001    Serial number: VWZ6Z7N5079120
   Coding: 04000400040000A10000
   VCID: 346D5E95973765E11B-8060
02877 - Digital Radio Antenna (R183)
                    Reset counter: 93
                    Mileage: 159520 km
   Part No SW: 3AA 907 566 D    HW: 4G0 907 566
   Component: J769  SWA MasterH03 0030
   Revision: 00H03000    Serial number: 6PZ 010 316-09
   Coding: 0010173
   Shop #: WSC 05311 000 00001
   VCID: 3A7170AD75539391C1-806E
   Subsystem 1 - Part No: 3AA 907 568 D
   Component: J0770_SWA_Slave_H03 0030
   Subsystem 2 - Serial number: 6PZ 010 316-29
   Subsystem 3 - Serial number: 5F01.09.1400H03000AMS15108ÿ
   Subsystem 4 - Serial number: S15108ÿ
   Coding: 0211FF
   VCID: 356B6391944D7CE92C-8060
   Slave Driver:
   Coding: 0000D8
   Coding: 0000258
   VCID: 3C7D76B57F67ADA1D3-8068
   Coding: 00000009
   VCID: 6FE791F9BE91063926-803A
   Coding: 0211FE
   VCID: 3669649D894B77F125-8062
   Slave Passenger:
   Coding: 0000D8
   Coding: 0022157
   VCID: 356B63915C4D7CE92C-8060
   Component: AFS-ECU       H04 0111
   Coding: 029A00104F000200
   ROD: EV_HeadlRegulVWAFSPt_VW46.rod
   VCID: 377769998E418EF93E-8062
   Subsystem 1 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H04 0012
   Coding: 2C0000
   Subsystem 2 - Part No SW: 3D0 941 329 C    HW: 3D0 941 329 C  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H04 0012
   Coding: 2C0000
                    Reset counter: 93
                    Mileage: 159520 km
   Coding: 030B185A
   VCID: 71E39781A8A510C930-8024
   Serial number: 00000000008900911193
   VCID: 73EF9D89D2B922D9C2-8026
   Coding: 0030006
   VCID: 72E1988D6DA32BD1C9-8026
   ROD: UHVNA.rod
   VCID: 346D5E959F3765E11B-8060
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 3AA-980-654.clb
   Part No SW: 3AA 980 654 D    HW: 3AA 980 654 A
   Component: MFK_Gen1      H08 0300
   Serial number: 0156501687
   Coding: 010002000002020D0200040001010000
   ASAM Dataset: EV_47X 001639
   ROD: EV_47X.rod
   VCID: 39736FA1B8559889C8-806C
End-------------------------(Elapsed Time: 04:02)--------------------------
hopefully it'll be fixed and drop down menu updated for ecu ;)
10100 for manual
Thanks.
Internal reference: FS#1268
chillout1983
C?ID=162783
I would love to retrofit ACC however it sounds a bit of a task , do you have a parts list for it.
m87a
C?ID=156900
you need gateway which supports extended can, in installation list add 13 -Auto Dist. Reg
radar 3AA 907 567 or 3AA 907 567 A
Cable 3C0 971 206 A or build your own
VW Sign (cover) 3D0853601F JZA this one fits in old grill just slowly pull of vw sign and replace, this cover is extremely expensive
Steering column switch with ACC 3C9 953 501 BG
connector for radar 6X0 973 815
ABS you have code list in first post
also if you buy new radar you have to do basic settings with laser, it's little tricky but can be done there are diy on net but if you get used one you don't have to do this ;)
Sebastian
Magdeburg, Germany
HN0-nnnnnn
ok first some correction as I have found out in VCDS label there is mistake in label for Address 13: Auto Dist. Reg, it says 10000 for manual and 101000 for automatic, actually its vice versa [..] hopefully it'll be fixed and drop down menu updated for ecu ;)
I cannot confirm your assessment, the terminology in #10 (Park Steer Assist/Parking Aid) is clear and after checking about two dozen samples - all 02E and 0AM as well as 0BH are clearly coded to Byte 1 Bit 0 = 1.
m87a
C?ID=156900
well pop up balloon for Address 13: Auto Dist. shows wrong coding
for ECU there is no coding to select for ACC and also same with steering wheel module
i don't understand what are you trying to say with gearbox codes? dsg doesn't need to be coded
golfi_vend
Tartu, Estonia
C?ID=195131
Just yesterday i encountered the same puzzling piece about ACC coding. Clearly when i changed the coding to 10100 it started whining about implausible signal etc... .
I consider myself pretty good with ACC retrofit, because i have done now 2 of them and assisted in few other projects.
Engine needs to be coded, ABS needs to be coded, Steering column needs to be coded and Can needs to be coded.
Here is autoscan from a Alltrack, just finished yesterday. Engine is missing description for ACC, ABS coding is totally missing, and steering column also missing description for ACC. I have made myself label with coding values that have all that covered. This car was also Side-Assist retrofitted to where i made also my own label using German as base.
Sunday,19,February,2017,18:25:57:57784
VCDS Version: 17.1.3.0 (x64)  HEX-V2 CB: 0.4334.4
Data version: 20170203 DS267.2
Dealer/Shop Name: LeVWFreaks.eu
VIN: WVWZZZ3CZEE   License Plate:
Scan: 01 02 03 08 09 10 13 15 16 17 18 19 22 25 3C 42 44 46 47 4C
          4F 52 53 55 56 61 62 69 6C 6D 72 77 A5
VIN: WVWZZZ3CZEE   Mileage: 169980km-105620miles
Address 01: Engine (J623-CFGC)       Labels: 03L-906-018-CFF.clb
   Part No SW: 03L 906 018 RF    HW: 03L 907 309 AE
   Component: R4 2,0L EDC   X28 4779
   Revision: 41X28---    Serial number: 00000000000000
   Coding: 001D001A047601080000
   ASAM Dataset: EV_ECM20TDI01103L906018RF 003003
   ROD: EV_ECM20TDI01103L906018RE.rod
   VCID: 7F58095FC773677F543-802A
   Part No SW: 02E 300 016 H    HW: 02E 927 770 AL
   Component: GSG DSG AG6     521 4012
   Revision: 05652104    Serial number: 00001307310562
   Coding: 0000024
   Shop #: WSC 05311 000 00000
   VCID: 196CC7C73597A94FCA7-804C
Address 03: ABS Brakes        Labels: User\3AA-614-109.lbl
   Part No SW: 3AA 614 109 BS    HW: 3AA 614 109 N
   Component: J104   C2 450M VE4A 0061
   Revision: --H07---    Serial number: 00000004226222
   Coding: 0859409
   Shop #: WSC 00046 000 00000
   VCID: 7F58095FCBF3677F543-802A
   Part No SW: 3AA 907 044 BD    HW: 3AA 907 044 BD
   Component: Climatronic   H03 0404
   Revision: 00001K01
   Coding: 061400C803
   Shop #: WSC 00015 115 00000
   VCID: 73B0D56FFB3B331F20B-8026
9481988 - Air Quality Sensor
          B10AF 04 [008] - Internal System Fault
                    Reset counter: 110
                    Mileage: 169922 km
                    Date: 2017.02.18
                    Time: 15:11:36
Address 09: Cent. Elect. (J519)       Labels: User\3AA-937-087.lbl
   Part No SW: 3AA 937 087 R    HW: 3AA 937 087 R
   Component: BCM PQ47 H++  422 0474
   Revision: BD422001
   Coding: 000A000000000000049C0088740029F427FD4B88676DAD60E480E7240041
   Shop #: WSC 45632 456 32456
   VCID: 49CC5787C9B719CFBA7-801C
   Subsystem 1 - Part No SW: 3AB 955 419 A    HW: 3AB 955 419 A
   Component: WWS471 080813  24  0654
   Coding: 044D9D
   Component: RLS 300813 05  54  0403
   Coding: 02302A
Address 10: Park/Steer Assist (J446)       Labels: 3AE-919-475.clb
   Part No SW: 3AE 919 475 C    HW: 7N0 919 475
   Component: PARKHILFE 8K  H06 0018
   Revision: --------    Serial number: 28261324001875
   Coding: 318105
   ASAM Dataset: EV_EPHVA18VW47X0000 001006
   ROD: EV_EPHVA18VW4280000.rod
   VCID: 3FD8495F87F3A77F143-806A
Address 13: Auto Dist. Reg        Labels: User\3AA-907-567.lbl
   Revision: 00036000    Serial number: 00000000539276
   Coding: 0010000
   VCID: 382A2243AE5D9047D59-806C
   Component: J234__107 VW10 HI   2118
   Revision: 26019000    Serial number: 003L7PJ9KYY0
   Coding: 0012343
   VCID: 7CA2FE53DAE57C67711-8028
   Subsystem 1 - Serial number: 6332MTS625472183
   Subsystem 2 - Serial number: 6342MTS612452193
   Subsystem 3 - Serial number: 6351HTS607C08CKR
   Subsystem 4 - Serial number: 6361HTS6TPQB8CKR
Address 16: Steering wheel (J527)       Labels: User\3C0-953-569.lbl
   Part No SW: 3C9 953 501 BG    HW: 5K0 953 569 T
   Revision: FF010042    Serial number: 20130902200042
   Coding: 3982A50001
   VCID: 6FB8D91F971317FFC43-803A
   Component: E221__MFL-TK6  H07 0022
   Coding: E20000
   Part No SW: 3AA 920 880 R    HW: 3AA 920 880 R
   Component: KOMBI         H04 0611
   Coding: 151F01
   Shop #: WSC 05314 115 00000
   VCID: 42DE40ABF401CA977BD-8016
Address 18: Aux. Heat        Labels: 1K0-815-007.clb
   Part No: 7N0 963 272 E
   Component: Standheizer     044 4941
   Revision: 00044000    Serial number: 09028239000000
   Coding: 0031032
   Shop #: WSC 33016 002 1048576
   VCID: 3728217FA3439F3FDC3-8062
   Part No SW: 7N0 907 530 AN    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1642
   Revision:   H56       Serial number: 020913F1001460
   Coding: 462006
   VCID: 7CA2FE53D6E57C67711-8028
   Part No SW: 0BS 907 554 C    HW: 0BS 907 554 C
   Component: Haldex 4Motion      4016
   Coding: 0000005
   VCID: 46D65CBBD4A9F6B7575-8012
   Part No SW: 3AA 959 799 C    HW: 3AA 959 799 C
   Component:    IMMO         090 0407
   Revision: 00090000    Serial number: VWZCZ000000000
   VCID: 48CA5283DEBDE0C7A59-801C
Address 3C: Lane Change        Labels: User\3AA-907-566.lbl
   Component: J769  SWA MasterH02 0030
   Revision: 00H02000    Serial number: 6PZ 010 316-09
   Coding: 0010172
   VCID: 3A2E384B9051825723D-806E
   Component: J770  SWA Slave H02 0030
   Subsystem 3 - Serial number: 5F24.03.1400H02000AMS15170ÿ
   Subsystem 4 - Serial number: S15170ÿ
Address 42: Door Elect, Driver (J386)       Labels: User\3C0-959-70X-GEN4.lbl
   Revision: 12110009    Serial number: 0007429049
   Coding: 0211FF
   Shop #: WSC 05311 115 12345
   VCID: 35342B77B5CF6D2FCEF-8060
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703 B    HW: 3C8 959 794
   Component: J388__TSG-HL  004 0503
   Serial number: 00000003582400
   Coding: 0100D8
Address 44: Steering Assist        Labels: User\5N1-909-144.lbl
   Part No SW: 5N1 909 144 P    HW: 5N1 909 148 J
   Component: J500__APA-BS KL.311 1202
   Revision: 1BH04737    Serial number: 00132240253501
   Coding: 0000258
   VCID: 3FD8495F8B73A77F143-806A
Address 46: Central Conv.        Labels: User\3C0-959-799-46.lbl
   Component: 02 KESSY PQ47   090 0367
   Coding: 00900A00D2C30E76340294157E00CFCE705800030426B8
   Subsystem 4 - Part No: 3AA 962 243 D
   Component: GEB.F.Heckoef       0811
   Part No SW: 5K0 035 456 D    HW: 5K0 035 456 D
   Component: KonzernAmp 8K H07 6615
   Revision: --------    Serial number: EAA101A0011970
   ASAM Dataset: EV_AudioVerst8KanalBNO2 A01003
   ROD: EV_AudioVerst10KanalBNO1.rod
   VCID: 2B000D0F638B2BDFA8B-807E
   Part No SW: 7N0 907 532     HW: 7N0 907 530 AN
   Component: EZE_2         H56 1642
   Coding: 00000008
   VCID: 6FB8D91F979317FFC43-803A
   Component: Analoguhr  004 0004
Address 52: Door Elect, Pass. (J387)       Labels: User\3C0-959-70X-GEN4.lbl
   Revision: 14110009    Serial number: 0007465420
   Coding: 0211FE
   VCID: 36362C7BA8C96637C75-8062
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704 B    HW: 3C8 959 795
   Component: J389__TSG-HR  004 0503
   Serial number: 00000003610069
   Coding: 0100D8
   Revision:   H19       Serial number: 00000001384334
   Coding: 0022167
   VCID: 36362C7BA4496637C75-8062
Address 55: Headlight Range (J745)       Labels: User\5M0-907-357-V3.lbl
   Coding: 029A00000B000200
   Shop #: WSC 05311 115 00000
   VCID: 3728217FAFC39F3FDC3-8062
   Subsystem 1 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo links  H05 0012
   Coding: 230000
   Subsystem 2 - Part No SW: 3D0 941 329 B    HW: 3D0 941 329 B  Labels: 3D0-941-329.CLB
   Component: LeiMo rechts  H05 0012
   Coding: 230000
Address 56: Radio (J0503)       Labels: 5M0-035-1xx-56.clb
   Part No SW: 3C8 035 190 C    HW: 3C8 035 190 C
   Component: Radio RCD510  051 0213
   Revision: 00000001    Serial number: VWZ1Z3N1784058
   Coding: 05010000010011
   Shop #: WSC 05314 000 00000
   VCID: 2310E52F0BDBE39F10B-8076
   Component: Batt.regelung H56 1642
   Coding: 530F1859
   VCID: 71BCDF6781A7010FD27-8024
   Serial number: 30238234351491991731
   Component: Anhaenger     H09 0120
   Revision: 3I001003    Serial number: 00008160122586
   Coding: 4106040001000000
   VCID: 73B0D56FFBBB331F20B-8026
Address 6C: Back-up Cam.        Labels: User\5N0-907-441.lbl
   Part No SW: 3C9 907 441     HW: 3C9 907 441
   Revision: 00H12000    Serial number: 525PA8-J371091
   Coding: 0030007
   Shop #: WSC 05311 000 08193
   VCID: 688AB203BE7DC0C7859-803C
Address 6D: Trunk Elect.        Labels: None
   Part No SW: 3AF 827 383 A    HW: 3AF 827 383 A
   Component: J605  HECKDECKEL    0860
   Revision: 00H52001
   Subsystem 1 - Part No: 3AF 827 384 A
   Component: J756  HECKDECKEL    0860
   Subsystem 2 - Serial number: 1300H52001001C0117ÿ
   Part No SW: 7P6 035 730 J    HW: 7P6 035 730 J
   Revision: 1B001001    Serial number: 00007665185363
   ASAM Dataset: EV_UHVNA 002720
   ROD: EV_UHVNA_002.rod
   VCID: 392C274799D7894F2A7-806C
Address A5: Frt Sens. Drv. Assist (R242)       Labels: User\3AA-980-654.lbl
   Component: MFK_Gen1      H09 0300
   Serial number: 0195584998
   Coding: 010101000102020D0000040001010000
   ROD: EV_47X.rod
2621440 - Databus
                    Reset counter: 74
                    Mileage: 169987 km
                    Date: 2017.02.19
                    Time: 18:22:48
2686976 - Databus
                    Reset counter: 74
                    Mileage: 169987 km
                    Date: 2017.02.19
                    Time: 18:22:48
End----------(Elapsed Time: 02:17, VBatt start/end: 14.6V/14.7V)-----------
Sebastian
Magdeburg, Germany
HN0-nnnnnn
Ok, there was some miscommunication internally and I was assuming your beef was with the #10/EPH/PLA (Parking Aid/Park Steer Assist). So please ignore my statement above.
As far as the coding for #13/ACC goes, take a closer look at the PR-Codes listed in the coding table! 8T3 vs. 8T5 should give you the clue. The text description was left that way intentionally, however since it does cause confusion I have now changed that and it should be clearer in future data versions.
@golfi_vend, I also fixed the coding table for the ECM/J623/#01 as well as the one for the J527/#16. If you happen to have any other recommendations/feedback - please let me know.
Thanks to both of you for your comments.
golfi_vend
Tartu, Estonia
C?ID=195131
Could we get coding table for ABS? It's pretty simple. Only thing confusing is the Engine/Gearbox/AWD or FWD base value which also seems to differ for Alltrack and Normal. Otherwise the coding doesn't seem to be different between software version.
Following is created considering "normal" passat:
LC,00,0,Adaptive Cruise Control Installed (ACC)
LC,00,1,EcoFuel/CNG
LC,00,2,Alltrack
LC,00,3,Alltrack Offroad
LC,01,0,Passat B7 ABS sensors installed
LC,01,1,RHD
LC,01,2,TMPS installed
LC,01,3,Start/Stop installed
LC,01,4,DSG installed
LC,01,6,Front Assist Installed
LC,01,7,Follow to Stop (DSG/ACC)
LC,02,0~7,B9,Engine Code: CFGB/CFGC Manual
LC,02,0~7,BC,Engine Code: CFGB/CFGC DSG
LC,02,0~7,BF,Engine Code: CFGB/CFGC DSG 4Motion
LC,02,0~7,B6,Engine Code: CFFB Manual 4Motion
LC,02,0~7,B3,Engine Code: CFFB DSG
LC,02,0~7,B0,Engine Code: CFFB Manual
LC,02,0~7,B7,Engine Code: CAYC Manual
LC,02,0~7,A4,Engine Code: BWS DSG 4Motion
LC,02,0~7,A7,Engine Code: CAYC Manual
LC,02,0~7,68,Engine Code: CAXA Manual
LC,02,0~7,6B,Engine Code: CAXA DSG
LC,02,0~7,89,Engine Code: CCZB DSG
LC,02,0~7,86,Engine Code: CCZB Manual
LC,02,0~7,71,Engine Code: CDGA DSG
LC,02,0~7,7A,Engine Code: CDAA DSG
LC,02,0~7,6E,Engine Code: CDGA Manual
golfi_vend
Tartu, Estonia
C?ID=195131
Sebastian,
Seems like Typo in 03L-906-018-CFF.clb label file. ACC value is 60, not 40 like in updated label file.
Also, though not relevant in this case, but relevant to ACC. I have scan from Jetta GLI with 5K0 953 569 AG SWCM, which uses 5K0-953-569.clb label file.
The steering wheel label file doesn't have ACC from Steering wheel description, which is 40. I have also sent You the autoscan, but no info back about the missing bits.
Sebastian
Magdeburg, Germany
HN0-nnnnnn
We will likely publish some more ESP coding tables soon, you may notice some difference to what you posted.
Sebastian,
Not a typo, though it was incomplete: 60 = 8T3 & 40 = 8T5
Can you please re-send that? Can't find it here.
golfi_vend
Tartu, Estonia
C?ID=195131
Today finished ACC retrofit for 1.4CNG Passat. This one also needed some out-of-the box thinking. :)
First of ECU. The pop-up baloon for ACC enabling SA was wrong. Suggested 13647 didn't work. What worked was 13377, there is also 30903.
Second ABS, this abs didn't have this " LC,01,4,DSG installed " (+4096) active. Maybe because it is 7-speed DSG. I got to this conclusion while compairing similar scans i have with 1.4cng and acc.
Third ACC. - Seems like this label file has gone through massive rework. Thanks!
Fourth SWCM. The description of 60 - acc is wrong for this vechicle. Maybe some other? The correct would be A0 - Adaptive Cruise Control via separate stalk. Or something similar. Previous text was also emailed to support@.... .
Saturday,29,April,2017,17:15:50:36026
VCDS Version: 17.1.3.0 (x64)  HEX-NET CB: 0.4336.4
VIN: WVWZZZ3CZCE     License Plate: SILC ACC
Mileage: 86250km-53593mi   Repair Order:
Scan: 01 02 03 08 09 10 13 15 16 17 19 25 42 44 46 47 4F 52 53 55
          56 61 62 65 69 72 77
VIN: WVWZZZ3CZCE   Mileage: 86250km-53593miles
Address 01: Engine (CDG)       Labels: 03C-906-021-CDG.clb
   Part No SW: 03C 906 021 H    HW: 03C 907 309 D
   Component: 4414 CNG m14i83 A   9145
   Revision: E8H06---    Serial number: VWZCZ000000000
   Coding: 0000077
   VCID: A00CABCC734FD94149-80F4
Readiness: 1110 0101
   Part No SW: 0AM 300 058 P    HW: 0AM 927 769 D
   Component: GSG DSG AG7     431 5279
   Revision: 00043014    Serial number: CU501109246351
   Shop #: WSC 51156 001 1048576
   VCID: BE3075B4E9FB8FB15B-80EA
   Component: J104   C2 450M VE51 0023
   Revision: --H07---    Serial number: 00000005519400
   Coding: 0246129
   VCID: F5A2AA989C4D0CE94A-80A0
   Part No SW: 3AA 907 044 AG    HW: 3AA 907 044 AG
   Revision: 00001K02
   Coding: 0018004802
   VCID: F5A2AA98544D0CE94A-80A0
   Revision: BC413001
   Coding: 000800000000000000180280740029F423DD0088636D8D60E48046240041
   Shop #: WSC 05311 123 12345
   VCID: BC347FBC3FE79DA175-80E8
   Component: Wischer 02091  10  0603
   Coding: 00B795
   Component: RLS 240911 05  54  0403
   Coding: 060A2A
   Part No SW: 3AA 919 475 S    HW: 4H0 919 475 E
   Component: PARKHILFE PLA H06 0043
   Revision: --------    Serial number: 56261316000139
   Coding: 160106
   ASAM Dataset: EV_EPHVA2C000000000 002014
   VCID: CBD62C6062492A19CC-809E
   Revision: 00036000    Serial number: 00000000666298
   Coding: 0010000
   VCID: B83C63ACCBDFB18191-80EC
   Revision: 22014000    Serial number: 003K0PDDP8WA
   Coding: 0012337
   VCID: CCD42F7CAF472D21C5-8098
   Subsystem 1 - Serial number: 6332MTS660882451
   Subsystem 2 - Serial number: 6342MTS650762441
   Subsystem 3 - Serial number: 6351HTS6L728GAKJ
   Subsystem 4 - Serial number: 6361HTS6CMQGFAKJ
   Revision: FF010040    Serial number: 20110916100545
   Coding: 3982A50000
   VCID: EFAE98F03611363980-80BA
   Coding: E20000
   Part No SW: 3AA 920 870 E    HW: 3AA 920 870 E
   Coding: 161F01
   VCID: B424579C1FB755E1BD-80E0
   Part No SW: 7N0 907 530 BC    HW: 7N0 907 530 AN
   Component: J533  Gateway H56 1663
   Revision:   H56       Serial number: 26041600F10905
   Coding: 352002
   VCID: F2A891842D231BD16F-80A6
   VCID: F6A0AD94814B07F143-80A2
   Revision: 12110009    Serial number: 0003531640
   Coding: 0000FF
   VCID: B5226A9814CD4CE98A-80E0
   Slave Driver:
   Subsystem 1 - Part No SW: 3AA 959 703     HW: 3C0 959 794 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J388__TSG-HL  004 0407
   Serial number: 00000001579121
   Coding: 0000D8
   Component: J500__APA-BS KL.308 1002
   Revision: 1AH03734    Serial number: 00112640139601
   Coding: 0000258
   VCID: BC347FBCFFE79DA175-80E8
   Coding: 0191020052830E763004941570084FCE705801
Address 47: Sound System        Labels: 5K0-035-456.clb
   Part No SW: 5K0 035 456     HW: 5K0 035 456
   VCID: E79EF0D01EE1EE79C8-80B2
   Component: EZE_2         H56 1663
   Coding: 00000008
   VCID: EFAE98F03E11363980-80BA
   Revision: 14110009    Serial number: 0003559798
   Coding: 0000FE
   VCID: B6206D9409CB47F183-80E2
   Slave Passenger:
   Subsystem 1 - Part No SW: 3AA 959 704     HW: 3C0 959 795 B  Labels: 1K0-959-70X-GEN4.CLB
   Component: J389__TSG-HR  004 0407
   Serial number: 00000002312513
   Coding: 0000D8
   Revision:   H19       Serial number: 00000000255785
   Coding: 0022157
   VCID: B5226A98DCCD4CE98A-80E0
   Coding: 021200000B000200
   Coding: 230000
   Coding: 230000
   Part No SW: 3C8 035 195 F    HW: 3C8 035 195 F
   Component: Radio RCD510  050 0207
   Revision: 00000001    Serial number: VWZ1Z3L1545880
   Coding: 0D010000010011
   VCID: AB164CE0CA890A19EC-80FE
   Component: Batt.regelung H56 1663
   Coding: 03220864
   VCID: F1AA9E88282520C996-80A4
   Serial number: 00000000008900563909
   Part No SW: 3AA 907 273 F    HW: 5Q0 907 273
   Component: RDKBERU30     H04 0011
   Serial number: 40000000050185
   ASAM Dataset: EV_RDKBERU30 005005
   ROD: EV_RDKBERU30_VW51.rod
   VCID: B73E60900EC1BEF998-80E2
   Revision: 3I001002    Serial number: 00000158723392
   VCID: F3A69480523912D964-80A6
Address 77: Telephone (J412)       Labels: 3C8-035-730-A.clb
   Part No SW: 3C8 035 730 D    HW: 3C8 035 730 D
   Component: Telefon       022 0982
   Revision: --------    Serial number: 35502105095450
   Coding: 020100010100010000001101
   Shop #: WSC 00015 115 00001
   ASAM Dataset: EV_UHVPremi 002709
   ROD: EV_UHVPremi_002.rod
   VCID: A404A7DCAF57C5612D-80F0
End----------(Elapsed Time: 02:38, VBatt start/end: 11.9V/11.3V)-----------
NEtech
Denmark
C?ID=56995
Thank you very much.
For the record, for Engine, you write SA, you used it in [Coding II-11] and not [Secure access-16], correct ?
golfi_vend
Tartu, Estonia
C?ID=195131
Yes, correct.
Many modules today use SA instead of Coding2 so i get that mixed up sometimes. - My Bad.
NEtech
Denmark
C?ID=56995
Did you try 30903 ?
It seems 30903 is used for Automatic AG7.
golfi_vend
Tartu, Estonia
C?ID=195131
No i didn't. I just have these 3 logins written down from Bronken blog.
golfi_vend
Tartu, Estonia
C?ID=195131
UPDATE!!!
Customer complained that "Follow to Stop" didn't work. After enabling 13-ACC adaption channel 9 - Braking to Standstill the Front Assist logo disappeared from cluster and ECU gave error.
After that i tried disabling cruise control and activating it again with coding2 30903. - Success! Front Assist light stayed ON.
So my best guess is:
13647 - For older ECU-s like PD and PPD. Also for AXZ before 2008 without Front Assist
13377 - Newer ECU-s with manual gearbox and without Follow to Stop
30903 - Newer ECU-s with automatic gearbox and with Follow to Stop+Front Assist
golfi_vend
Tartu, Estonia
C?ID=195131
Well, this retrofit doesn't get completed. Customer said that after the car brakes to 0km/h, cruise won't resume after moderate accelaration.
After asking few other guys with similar CNG and ACC they said it resumes.
So is there some adaption that i have missed or is it some 4th login? :O
I'm confused.
