Anyway long story short. 2009 or 2008 Jetta...customer replaced MK6 abs module.....they bled the brakes the manual method after replacing....
As far as they can tell me...everything was air free....
So basic settings to the ABS Controller 25 and 26 is required on a cold car....
I tried for 3 days....I managed to complete basic settings 25, but for the life of me could not finish basic settings 26....half way through or toward the end it would just error out...
Anyway here are logs, and if anyone has suggestions I would appreciate it.
I was thinking of running a external vacuum line to the brake pump just to allow me to do the test with engine off...but also not sure how to go about that correctly...
Anyway what ever help you guys have...would be awesome.
Saturday,26,November,2016,10:41:43:59093
VCDS Version: 16.8.3.1 (x64) HEX-NET CB: 0.4321.4
VIN: 3VWJZ71K49M006684 License Plate:
Mileage: 109970km-68332mi Repair Order:
Chassis Type: 1K (1K0)
Scan: 01 03 08 09 15 16 17 19 25 42 44 46 52 56 62 65 72
VIN: 3VWJZ71K49M006684 Mileage: 109970km-68332miles
Address 01: Engine (CBU) Labels: 07K-906-055-CBT.clb
Part No SW: 07K 906 055 N HW: 07K 906 055 M
Component: 2,5l R5/4V G 9970
Revision: G6H01--- Serial number: VWX7Z0H524T0LH
Coding: 0000071
Shop #: WSC 08209 444 105136
VCID: 393AE58570BF478ABB-806C
Readiness: 0000 0100
Address 03: ABS Brakes (-----) Labels: 1K0-907-379-60EC1F.clb
Part No SW: 1K0 907 379 AN HW: 1K0 907 379 AN
Component: ESP MK60EC1 H45 0107
Revision: 00H45001
Coding: 113B400D49220000881102EC921D00413400
Shop #: WSC 00066 123 12345
VCID: 7EB03699E911A0B2CE-802A
00003 - Control Module
Fault Status: 01100101
Reset counter: 234
Mileage: 109979 km
Count: 3
Count: 2
Count: 12800
Count: 143
Count: 49920
Address 08: Auto HVAC Labels: None
Part No SW: --- 820 047 -- HW: яя 820 047 яя
Component: Climatic PQ35 яяя XXXX
Revision: яяяяяяяя Serial number: 00000000000000
VCID: 16600E39216148F276-8042
00229 - Refrigerant Pressure
002 - Lower Limit Exceeded
01271 - Positioning Motor for Temperature Flap (V68)
Address 09: Cent. Elect. Labels: 3C0-937-049-30-M.lbl
Part No SW: 3C0 937 049 AH HW: 3C0 937 049 AH
Component: Bordnetz-SG H54 2202
Revision: 00H54000 Serial number: 00000000997662
Coding: 14058E234004150007140000001400000008730B5C000120000000000000
Shop #: WSC 00066 000 00000
VCID: 6FAE1BDD7E7BD93A55-803A
Component: Wischer 260608 021 0501
Coding: 00038805
Shop #: WSC 00066
Part No SW: 1K0 909 605 AB HW: 1K0 909 605 AB
Component: 6A AIRBAG VW8R 034 8000
Revision: 05034000 Serial number: 003B6M05TF7C
Coding: 0013889
VCID: 6C940CD14F6D222270-8038
Subsystem 1 - Part No: 1K0 959 339 F
Component: BF-Gewichtsens. 007 0005
Subsystem 2 - Serial number: 6332MSME3174640D9
Subsystem 3 - Serial number: 6342MSME3B661764G
Subsystem 4 - Serial number: 6351HSME155C4D32C
Subsystem 5 - Serial number: 6361HSME127A3350%
Subsystem 6 - Serial number: 63727SME157D5B136
Subsystem 7 - Serial number: 63827SME157E2F18E
Part No SW: 1K0 953 549 BR HW: 1K0 953 549 BR
Component: J0527 051 0101
Coding: 0000021
VCID: 0346476D42F3CD5AA1-8056
Part No SW: 1K0 920 954 S HW: 1K0 920 954 S
Component: KOMBIINSTRUMENT 3HL 1222
Revision: V0003000 Serial number: VWX7Z0H524T0LH
Coding: 0023203
VCID: 3C34FC917F8D72A2A0-8068
Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb
Part No SW: 1K0 907 530 Q HW: 1K0 907 951
Component: J533 Gateway H07 0062
Revision: H07 01 Serial number: 110508F1001319
Coding: E9807F070002021002
VCID: 3522E9B55CA7A3EA5F-8060
Component: IMMO 3HL 1222
Shop #: WSC 08209 444 53929
Part No SW: 1K0 959 701 AC HW: 1K0 959 793 N
Component: J386 TUER-SG FT 1519
Revision: 72009005 Serial number: 00000307288617
Coding: 0001205
Part No: 1K0 909 144 C
Component: EPS_ZFLS Kl. 69 2301
Revision: 00H15000
VCID: 2A18CAC98519FC12C2-807E
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 CT HW: 1K0 959 433 CT
Component: KSG PQ35 RDK 052 0221
Revision: 00052000 Serial number: 00000000000000
Coding: 13900F880186483F6D04058FB08A0F0488DCA0
VCID: 0444447147FDCA6298-8050
Part No SW: 1K0 959 702 AC HW: 1K0 959 792 N
Component: J387 TUER-SG BT 1519
Revision: 72009005 Serial number: 00000250688620
Coding: 0001204
VCID: 70AC18A16345C6C24C-8024
Address 56: Radio Labels: 1K0-035-161.lbl
Part No SW: 1K0 035 161 D HW: 1K0 035 161 D
Component: Radio DE2 017 0021
Revision: 00017000 Serial number: VWZ4Z7H6359228
Coding: 0040401
VCID: 200C28E1F32536429C-8074
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN3.lbl
Part No SW: 1K0 959 703 AH HW: 1K0 959 795 T
Component: J388 TUER-SG HL 1401
Revision: 12006001 Serial number: 00000003255227
Coding: 0001168
VCID: 76A02EB90121E8F296-8022
Component: RDK 0450
Coding: 0100101
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN3.lbl
Part No SW: 1K0 959 704 AH HW: 1K0 959 794 T
Component: J389 TUER-SG HR 1401
Revision: 12006001 Serial number: 00000003214825
Coding: 0001168
VCID: 77BE23BD062B91FA8D-8022
End----------(Elapsed Time: 01:08, VBatt start/end: 14.1V/14.0V)-----------
