HEX-NET:
HEX-USB+CAN (HEX+CAN)
HEX-NET did the scan in 1:34 where as the HEX+CAN took 4:30 to complete.
Friday,25,November,2016,12:05:31:51346
VCDS Version: 16.8.3.1 (x64) HEX-NET CB: 0.4328.4
VIN: 3VWH17AUXHM512946 License Plate:
Chassis Type: AU (5Q0)
Scan: 01 02 03 05 08 09 15 16 17 19 22 2B 42 44 47 52 5F 75
VIN: 3VWH17AUXHM512946 Mileage: 34km-21miles
Address 01: Engine (J623-CXBB) Labels: 06K-907-425-V1.clb
Part No SW: 8V0 906 264 L HW: 06K 907 425 B
Component: 1.8l R4 TFSI H13 0002
Revision: --H13---
Coding: 311D00122426002F1000
Shop #: WSC 00066 790 00228
ASAM Dataset: EV_ECM18TFS0208V0906264L 001003
ROD: N/A
VCID: C5CD52554469F46A4F-8090
No ASAM data for: "EV_ECM18TFS0208V0906264L" (VW37)
Readiness: 0010 0001
Part No SW: 0D9 300 012 F HW: 02E 927 770 AQ
Component: DQ250-6F MQB H54 4901
Revision: 06354004 Serial number: TFK01608112164
Shop #: WSC 00066 790 00218
ROD: EV_TCMDQ250021.rod
VCID: 9975CE259851A08ADB-80CC
P1734 00 [002] - -
Address 03: ABS Brakes (J104) Labels: 5Q0-907-379-ESP-V1.clb
Part No SW: 5Q0 614 517 AF HW: 5Q0 614 517 AF
Component: ESC H62 0398
Revision: 00000000 Serial number: 52386000000053
Coding: 43FA6AA13421096E8080130481C929C2562C9001C881943C00430050E00903
Shop #: WSC 01383 790 50316
ASAM Dataset: EV_Brake1UDSContiMK100ESP 035019
ROD: EV_Brake1UDSContiMK100ESP_035_VW37.rod
VCID: F5ADE295540924EA1F-80A0
Address 05: Acc/Start Auth. (J518) Labels: 5Q0-959-435.clb
Part No SW: 5Q0 959 435 B HW: 5Q0 959 435
Component: VWKESSYMQB 021 0710
Revision: 00021000 Serial number: 0411441492
Coding: 032C0C
VCID: BB3934AD32ADB29A29-80EE
Address 08: Auto HVAC (J255) Labels: 5G0-907-044.clb
Part No SW: 5GM 907 044 C HW: 5GM 907 044 C
Component: Climatronic H04 1601
Revision: 00001K03
Coding: 02020024200100000005000012111402
ASAM Dataset: EV_ACClimaBHBVW37X 006142
VCID: C4CB4F514F53CD6258-8090
Air quality sensor:
Address 09: Cent. Elect. (J519) Labels: 5Q0-937-08X-MV1.clb
Part No SW: 5Q0 937 087 AA HW: 5Q0 937 087 AA
Revision: -------- Serial number: 8658180816018P
Coding: 00511846404182E969E44000001407201800000000000000000000000000
ROD: EV_BCMBOSCH_016_AU37.rod
VCID: FAB7F1A97D174B9272-80AE
Subsystem 1 - Part No SW: 5G1 955 119 A HW: 5G1 955 119 A Labels: 5QX-955-119-V1.CLB
Component: WWS 150616 043 0551
Serial number: 150703140738
Component: RLHS 042 0105
Serial number: S4Y16M08D24H11M37S03
Coding: 00A8DD
Sun Roof:
Subsystem 3 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J245 PS22.409 H03 0004
Serial number: 0000FST00152VQT00000
Coding: 191800
Roof Blind:
Subsystem 4 - Part No SW: 5G0 959 591 A HW: 8V3 959 591 A
Component: J394 PS22.409 H03 0004
Serial number: 0000FST001537M200000
Coding: 191800
Part No SW: 5Q0 959 655 J HW: 5Q0 959 655 J
Component: AirbagVW20 010 0830
Serial number: 003GCR05RGV8
Shop #: WSC 00066 790 07027
VCID: C7D1585D7E65E67ABD-8092
Occupant Detection:
Component: BF-Gewichtss. H13 0022
Serial number: IBH000000000005UIDK3
Coding: 303137
Subsystem 2 - Part No SW: ----------- HW: 480 002 408 16
Serial number: 35700000000F4C14BD1X
Subsystem 3 - Part No SW: ----------- HW: 480 001 708 16
Serial number: 358000000006C1B08D1P
Subsystem 4 - Part No SW: ----------- HW: 480 400 608 16
Serial number: 3510002A721FBE85E24I
Subsystem 5 - Part No SW: ----------- HW: 480 400 608 16
Serial number: 35200029F215E1C3335%
Subsystem 6 - Part No SW: ----------- HW: 480 402 708 16
Serial number: 3550002B5218C2A4119
Front Sensor Passenger:
Subsystem 7 - Part No SW: ----------- HW: 480 402 708 16
Component: FrontSensor_P 001 6149
Serial number: 3560002B5218C2A4D10%
Address 16: Steering wheel (J524) Labels: 5Q0-953-549.clb
Part No SW: 5Q0 953 521 AT HW: 5Q0 953 569 A
Component: Lenks.Modul 075 0235
Revision: FF034034 Serial number: 20160825500827
Coding: 0410
ROD: EV_SMLSVALEOMQB.rod
VCID: 844B8F510FD30D6218-80D0
Address 17: Instruments (J285) Labels: User\5G0-920-XXX-17.clb
Part No SW: 5G1 920 840 B HW: 5G1 920 840 B
Component: KOMBI 244 8311
Coding: 0BA4101DA180CF0502086A001000000000000000
VCID: A60FF5D9D92F1F7266-80F2
Part No SW: 5Q0 907 530 AL HW: 5Q0 907 530 L
Component: GW MQB Mid 211 2265
Revision: -------- Serial number: 21081610801688
Coding: 0901000830085900FB0022081E0F00000001050000000000000000000000
ROD: EV_GatewConti_013.rod
VCID: FBB9F4AD722D729A69-80AE
Subsystem 2 - Part No SW: 5G0 959 442 P HW: 5G0 959 442 P
Component: E221__MFL-DC1 H17 0103
Serial number: 29160001611290036333
Coding: 31FFFF
Power Converter DC AC:
Subsystem 3 - Part No SW: 5Q0 907 155 A HW: 5Q0 907 155 A
Component: WECHSELRICHTE H53 0041
Serial number: 0112219
Address 22: AWD (J492) Labels: 0CQ-907-554.clb
Serial number: HA1-00027.06.16
Coding: 0001
VCID: CAD761696D771B12A2-809E
Address 2B: Steer. Col. Lock (J764) Labels: 5Q0-905-861.clb
Component: ELV-MQBA H01 0120
Revision: 00000000 Serial number: 16000124742008
Coding: 5D00000000000000
Shop #: WSC 00066 790 00322
ROD: EV_ELVMarquMQB_SK25.rod
VCID: B42B1F911FF37DE2E8-80E0
Component: TSG FS 020 0041
Serial number: 240916060506IX
Coding: 003A13200000020000000000
VCID: C3C94C4D4A5DCA5A61-8096
Subsystem 1 - Part No SW: 5Q4 959 811 D HW: 5Q4 959 811 D
Component: Fond FHSG DRV 007 0002
Serial number: 00000000000013880260
Coding: 011000
Component: EPS_MQB_ZFLS 129 1072
Coding: 8102
ROD: EV_SteerAssisMQB_013.rod
Part No SW: 5Q0 035 456 HW: 5Q0 035 456
Revision: 00000001 Serial number: VWZ8Z1GBA02BW5E
Coding: 2200000000AAAAAA000000000000
ROD: EV_AMPMst12C1Gen2ALPI.rod
VCID: ED9DCAF53C59EC2AE7-80B8
Component: TSG BFS 020 0041
Serial number: 250916060502I6
VCID: C2C749495547C3526A-8096
Subsystem 1 - Part No SW: 5Q4 959 812 D HW: 5Q4 959 812 D
Component: Fond FHSG PSG 007 0002
Serial number: 00000000000014233678
Coding: 091000
Address 5F: Information Electr. (J794) Labels: 5G0-035-MIB-STD2.clb
Part No SW: 3Q0 035 876 A HW: 3Q0 035 876 A
Component: MU-S-NS-US 840 0751
Coding: 027302020000000051220002001808009F0108F401200105C6
ROD: EV_MUStd4CDELP_VW26.rod
VCID: B2271989E5E773D2FA-80E6
Subsystem 1 - Part No SW: 5GM 919 605 HW: 5GM 919 605
Component: ABT_Std-2_Nav H53 1031
Serial number: VWZ8Z9SJX00AZ4
Subsystem 2 - Part No SW: 3G0 919 866 AC HW: -----------
Component: NAR 2016/17 --- 0445
Address 75: Telematics (J949) Labels: 5QE-035-285.clb
Part No SW: 5QE 035 285 A HW: 5QE 035 285 A
Component: OCULowMQBUS 007 0568
Coding: 02730202C2823A017F1E06020000
ROD: EV_OCULowMQB.rod
End----------(Elapsed Time: 01:34, VBatt start/end: 14.4V/14.4V)-----------
Friday,25,November,2016,11:59:56:60709
Revision: --H13---
ROD: N/A
VCID: 458B2F22C44CC36ACF-8010
VCID: 1933B3521874978A5B-804C
VCID: 75EB9FE2D42C13EA9F-8020
Coding: 032C0C
VCID: 3B7F49DAB288859AA9-806E
Revision: 00001K03
VCID: 448D3226CF76FA62D8-8010
Air quality sensor:
VCID: 7AF18CDEFD327C92F2-802E
Coding: 00A8DD
Sun Roof:
Coding: 191800
Roof Blind:
Coding: 191800
VCID: 4797252AFE40D17A3D-8012
Occupant Detection:
Coding: 303137
Coding: 0410
VCID: 040DF2268FF63A6298-8050
VCID: 264988AE590A2872E6-8072
VCID: 7BFF89DAF208459AE9-802E
Coding: 31FFFF
Coding: 0001
VCID: 4A911C1EED522C1222-801E
VCID: 346D62E69FD64AE268-8060
VCID: 438F313ACA78FD5AE1-8016
Coding: 011000
Coding: 8102
VCID: 6DDBB782BC7CDB2A67-8038
VCID: 4281343ED562F452EA-8016
Coding: 091000
VCID: 326164FE65C244D27A-8066
End-------------------------(Elapsed Time: 04:30)--------------------------
