Beta 14.7.0 on MQB
andyvee
Rossendale, Lancashire, UK
C?ID=159389
Hi
Used 14.7.0 for the first time on a MQB platform today to code footwell lights as per the below
http://www.briskoda.net/forums/topic/299424-octavia-iii-vcds-adaptations-tried-and-tested/?p=3792607
and it immediately generated a fault code that won't clear on 09 BCM
565764 - Program Monitoring
          B201B 00 [009] - -
                    Reset counter: 193
                    Mileage: 12060 km
                    Date: 2014.07.04
                    Time: 15:25:28
Any ideas?? It comes back every time you clear it.
Having used 14.6.1 to code footwell lights a week or so ago, it didn't generate this fault code.
Andy
I seriously doubt that fault is due to a difference between 14.6.1 and 14.7.0. I would consider it far more likely to be due to a difference between control modules in different cars.
andyvee
C?ID=159389
Ok, thanks. It is a bit of an odd one as the time it is logged at coincides with the time I entered the security code for adaptations and altered the first adaptation channel.
Any ideas on how to clear it?
I have enabled other features on this car previously, including traffic sign recognition and have not seen this fault code before.
andyvee
C?ID=159389
Oh, as an afterthought, can you tapatalk enable the forum? Using a phone to Reply on the mobile version of the website is painful lol
andyvee
C?ID=159389
The majority being 4 against and 2 for? Hardly a representative sample is it LOL!
jakematic
NC USA
C?ID=129085
I believe you just made Sebastian's point for him. ;)
andyvee
C?ID=159389
Anyway, back on topic
I have been advised elsewhere that VCDS is reporting the fault code incorrectly and it should be
DTC_565764 LEDLeiste->kein Signal / Kommunikation
which translates as LED Bar - no Signal / Communication
I'll have to take another look at this car and see if there have been any changes made for relevant to LED Bar - not sure what that is though.
The car is a Skoda Octavia 5E vRS with Xenon headlights with the LED DRLs if that has any relevance.
Looking back through my debug log, I haven't changed anything other than the coding and adaptations for the Footwell Lights.
Please post an Auto-Scan from the car so we can see exactly what it's made of.
andyvee
C?ID=159389
Autoscan below - ignore all the other fault codes as the person who fitted the footwell lights blew a fuse LOL during the fitting by dropping a screwdriver in to the 12v accessory socket.
Friday,04,July,2014,15:35:53:16648
VCDS Version: 14.7.0.0 (x64)
Data version: 20140601
VIN: TMBKK7NE7E0119039   License Plate:
Mileage: 12060km-7493mi   Repair Order:
Chassis Type: NE (5Q0)
Scan: 01 02 03 05 08 09 10 13 15 16 17 19 2B 42 44 52 55 5F 6D A5
          A9
VIN: TMBKK7NE7E0119039   Mileage: 12060km-7493miles
Address 01: Engine (J623-CUPA)       Labels: 04L-907-309-V1.clb
   Part No SW: 04L 906 021 EM    HW: 04L 907 309 D
   Component: R4 2,0L EDC   H22 7543
   Revision: 83H22---
   Coding: 111D0032036501081000
   Shop #: WSC 13061 000 1048576
   ASAM Dataset: EV_ECM20TDI01104L906021EM 002008
   ROD: EV_ECM20TDI01104L906021EM.rod
   VCID: 74EDEAF2DFFA279A7B-8021
   Part No SW: 0D9 300 040 Q    HW: 02E 927 770 AQ
   Component: DQ250-6F MQB  H52 4303
   Revision: 05852204    Serial number: TFK01311042458
   Shop #: WSC 73430 031 00207
   ROD: EV_TCMDQ250021_SK37.rod
   VCID: 254BC7B624A00E123C-8070
Address 03: ABS Brakes (J104)       Labels: 5Q0-907-379.clb
   Part No SW: 5Q0 907 379 AB    HW: 5Q0 907 379 H
   Component: ESC           H31 0557
   Revision: 00000000    Serial number: 63073000000292
   Coding: 1C079391542109750077060341CC2938C92A9000608294F4F6615072C009
   Shop #: WSC 73430 031 00063
   ROD: EV_Brake1UDSContiMK100IPB_SE37.rod
   VCID: 7CFDC2D2F7AA6FDA33-8029
Address 05: Acc/Start Auth. (J518)       Labels: None
   Revision: 00021000    Serial number: 0194840415
   Coding: 030C0C
   Shop #: WSC 73430 790 00207
   ROD: EV_KessyHellaMQBAB_SK37.rod
   VCID: 3A7104CABD1E91EA61-806F
1069319 - Wake-Up Signal from Control Module for Access/Start Authorization
          U1093 00 [008] - Short to GND
                    Reset counter: 229
                    Mileage: 1048574 km
   Part No SW: 5E0 907 044 F    HW: 5E0 907 044 F
   Component: Climatronic   H02 0805
   Revision: 00001K06
   Coding: 02110104000100011005000000100000
   ASAM Dataset: EV_ACClimaBHBVW37X 003017
   ROD: EV_ACClimaBHBVW37X_SK37.rod
   VCID: 2855CE8253B2137A07-807D
   Air quality sensor:
   Part No SW: 5Q0 937 086 Q    HW: 5Q0 937 086 Q
   Component: BCM PQ37BOSCH 026 0095
   Revision: --------    Serial number: 86581911130444
   Coding: 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000
   ASAM Dataset: EV_BodyContrModul1UDSBosc 012003
   ROD: EV_BCMBOSCH_SK37.rod
   VCID: 48956E02F3F2F37AE7-801D
   Subsystem 1 - Part No SW: 5E2 955 119     HW: 5E2 955 119
   Component: WWS371 131104  041 0570
   Serial number:         131106134704
   Coding: 065DDD
   Component: RLFS  024 0042
   Serial number: Y13M11D19H16M29S57S6
   Coding: 02805D
   Subsystem 3 - Part No SW: 5Q0 951 171     HW: 5Q0 951 171
   Serial number: 000000000ZY131830BLF
   Serial number: 00000000000028258582
   Subsystem 5 - Part No SW: 5E9 959 591     HW: 7P0 959 591 B
   Component: J245 PS24.011  H01 0008
   Serial number:     WOO25139082
   Coding: 991800
   Subsystem 6 - Part No SW: 5E9 959 591 A    HW: 7P0 959 591 C
   Component: J394 PS24.011  H01 0008
   Serial number:     WOO2545966B
   Coding: 991800
919560 - Light Switch
          B126A 29 [136] - Signal Implausible
                    Reset counter: 229
                    Mileage: 11745 km
                    Date: 2014.07.01
                    Time: 15:28:35
939524 - No Communications with Humidity Sensor
          U10F5 00 [008] - -
                    Reset counter: 229
                    Mileage: 11745 km
                    Date: 2014.07.01
                    Time: 15:43:15
132363 - Voltage Supply; Terminal 30; Left
          B140D 13 [008] - Open Circuit
                    Reset counter: 229
                    Mileage: 11745 km
                    Date: 2014.07.01
                    Time: 15:28:35
133131 - Voltage Supply Terminal 30
          B1423 13 [008] - Open Circuit
                    Reset counter: 229
                    Mileage: 11745 km
                    Date: 2014.07.01
                    Time: 15:28:35
          B201B 00 [009] - -
                    Reset counter: 193
                    Mileage: 12060 km
                    Date: 2014.07.04
                    Time: 15:25:28
Address 10: Park/Steer Assist (J791)       Labels: 5Q0-919-298.clb
   Part No SW: 5Q0 919 298 A    HW: 5Q0 919 298
   Component: PARKHILFE PLA 011 0029
   Revision: --------    Serial number: 61131330601761
   Coding: 0131061051
   Shop #: WSC 73430 790 00063
   ASAM Dataset: EV_EPHVA2CAU3700000 003014
   ROD: EV_EPHVA2CAU3700000_AU37.rod
   VCID: 3D7B0FD6AC30A6D244-8068
Address 13: Auto Dist. Reg (J428)       Labels: None
   Part No SW: 5Q0 907 572 B    HW: 5Q0 907 572 B
   Component: ACC Bosch MQB H04 0200
   Serial number: 09111376510061
   Coding: 00081600FE0339
   ASAM Dataset: EV_ACCMRRBoschVW372 001014
   ROD: EV_ACCMRRBoschVW372_AU37.rod
   VCID: 366910FA8906758A85-8063
   Part No SW: 3Q0 959 655 AC    HW: 3Q0 959 655 AC
   Component: Airbag VW20   012 0189
   Revision: --------    Serial number: 003P4PPRBXH+
   Coding: 98CCC000000000005C5400CC008800000065
   ROD: EV_AirbaVW20TS6VW48X_SK37.rod
   VCID: 7F0735DEE6BC74C216-802A
   Subsystem 1 - Part No SW: -----------    HW: 454 000 111 13
   Serial number: 3576U000000EF9902E0S
   Subsystem 2 - Part No SW: -----------    HW: 454 000 111 13
   Serial number: 3586U0000008897CED0.
   Subsystem 3 - Part No SW: -----------    HW: 454 800 311 13
   Serial number: 3516R0CB23B02000000/
   Subsystem 4 - Part No SW: -----------    HW: 454 800 311 13
   Serial number: 3526R45B93B020000002
   Subsystem 5 - Part No SW: -----------    HW: 454 801 510 13
   Serial number: 3556V390C0002000000X
   Part No SW: 5Q0 953 507 EJ    HW: 5Q0 953 549 C
   Revision: --------    Serial number: 20111308490570
   Coding: 6C10
   ROD: EV_SMLSKLOMQB_SE37.rod
   VCID: 0201BC2A954E192A79-8057
   Part No SW: 5E0 920 971 F    HW: 5E0 920 971 F
   Component: KOMBI         333 2210
   Coding: 27A509186D90A60001886A03000000
   ROD: EV_DashBoardVDDMQBAB_SK37.rod
   VCID: 2C5D3292474A3F5AE3-8079
   Part No SW: 5Q0 907 530 Q    HW: 5Q0 907 530 F
   Component: GW MQB High   125 1164
   Revision: --------    Serial number: 0001298183
   Coding: 030100040F087300EF00067A1C0F00010001050000000000000000000000
   ASAM Dataset: EV_GatewLear 010015
   ROD: EV_GatewLear_AU37.rod
   VCID: 3F8775DEA63CB4C256-806A
   Subsystem 2 - Part No SW: 5E0 919 719 B    HW: 5E0 919 719 B
   Component: E221__MFL-PR6  H04 0120
   Serial number: 000000000B0932011113
   Serial number: 6926181803
8531970 - Quiescent Current
          U1406 00 [008] - Too High
                    Reset counter: 197
                    Mileage: 10077 km
                    Date: 2014.06.05
                    Time: 22:29:47
   Revision: 00000000    Serial number: 13000243912001
   Coding: 5D00000000000000
   ROD: EV_ELVMarquMQB.rod
   VCID: 346D2AF29F7A679ABB-8061
   Part No SW: 5Q4 959 393 B    HW: 5Q4 959 393 B
   Component: TSG FS        009 0014
   Serial number: 0000083021806
   Coding: 001C08208001040000001100
   ROD: EV_DCUDriveSideEWMAXCONT_SK37.rod
   VCID: 42817C2AD5CED92A39-8017
   Subsystem 1 - Part No SW: 5Q0 959 812 A    HW: 5Q0 959 812 A
   Serial number: 00000000000001020690
   Coding: 1D0200
   Part No SW: 3Q0 909 144 F    HW: 3Q0 909 144 F
   Component: EPS_MQB_ZFLS  503 5043
   Coding: 9303
   ROD: EV_SteerAssisMQB.rod
   VCID: 356B17F694007E928C-8060
   Part No SW: 5Q4 959 392 B    HW: 5Q4 959 392 B
   Component: TSG BFS       009 0014
   Serial number: 0000082984933
   Coding: 001C00208001040000001100
   ROD: EV_DCUPasseSideEWMAXCONT_SK37.rod
   VCID: 41837326D0C8C23220-8014
   Subsystem 1 - Part No SW: 5Q0 959 811 A    HW: 5Q0 959 811 A
   Serial number: 00000000000001125357
   Coding: 050200
   Part No SW: 7P6 907 357 A    HW: 7P6 907 357 A
   Coding: 03DE02003F010000
   Subsystem 1 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo links  H06 0009
   Coding: 3E0000
   Subsystem 2 - Part No SW: 1T0 941 329 B    HW: 1T0 941 329 B
   Component: LeiMo rechts  H06 0009
   Coding: 3E0000
   Part No SW: 5E0 035 020 B    HW: 5E0 035 020
   Component: MU-H-ND-EU    H42 0292
   Serial number: A313K0D7516561
   Coding: 03735201FF0000001111120100A800002F0001C60100010076
   ASAM Dataset: EV_MUHig6C3HBAS 001041
   ROD: EV_MUHig6C3HBAS_AU37.rod
   VCID: 1629F07AE9C6958AA5-8043
   Media Player Position 1:
   Subsystem 1 - Part No SW: 5E0 919 606     HW: 5E0 919 606
   Component: ABT_High  H50 0022
   Serial number: SKZ8Z9NL100BKE
   Engine Control Module 2:
   Subsystem 2 - Part No SW: V03 959 800 MC    HW: -----------
   Component: ECE 2014/2015  --- 0088
Address 6D: Trunk Elect. (----)       Labels: None
   Part No SW: 5E0 959 107     HW: 5E0 959 107
   Component: HDSG-Modul    H01 0744
   Revision: 42001001    Serial number: 301300305
   Coding: 1233074002
   Shop #: WSC 73430 790 00000
   ASAM Dataset: EV_HDSGSk462 301136
   ROD: EV_HDSGSk462.rod
   VCID: 69D38B868838EA72D8-803C
Address A5: Frt Sens. Drv. Assist (R242)       Labels: 5Q0-980-653.clb
   Part No SW: 5Q0 980 653 E    HW: 5Q0 980 653
   Component: MQB_MFK       H05 0051
   Serial number: 10000011176
   Coding: 0100010001030303000400000100010100
   ROD: EV_MFKBoschAU370_SK37.rod
Address A9: Struct. Borne Sound (J869)       Labels: None
   Part No SW: 5E0 907 159     HW: 4H0 907 159 A
   Component: SAS-GEN 2     H06 0001
   Serial number: 131019200641
End-------------------------(Elapsed Time: 04:33)--------------------------
Address 05: DTCs cleared
Address 09: DTCs cleared
Address 19: DTCs cleared
Address 09:5Q0 937 086 Q recoded (Long Coding) from 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000 to 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000  (73430/790/00207)
Address 09:5Q0 937 086 Q recoded (ADP-(6)-Leuchte30FR LC72-Dimmwert AB 30) from 89  to 100
andyvee
C?ID=159389
And here is my debug log from the coding of the footwell lights
Address 09:5Q0 937 086 Q recoded (ADP-(8)-Interior light; light configuration-Fussraumbeleuchtung) from not installed  to installed   Friday,04,July,2014,15:19:01:16648
Address 09:5Q0 937 086 Q recoded (ADP-(4)-Leuchte30FR LC72-Lichtfunktion A 30) from not active  to Footwell light   Friday,04,July,2014,15:20:35:16648
Address 09:5Q0 937 086 Q recoded (ADP-(1)-Leuchte30FR LC72-Lasttyp 30) from not active  to 18 - 2* 5W   Friday,04,July,2014,15:22:05:16648
Address 09:5Q0 937 086 Q recoded (ADP-(1)-Leuchte30FR LC72-Lasttyp 30) from not active  to 18 - 2* 5W   Friday,04,July,2014,15:23:24:16648
Address 09:5Q0 937 086 Q recoded (ADP-(6)-Leuchte30FR LC72-Dimmwert AB 30) from 0  to 89   Friday,04,July,2014,15:23:56:16648
Address 09:5Q0 937 086 Q recoded (Long Coding) from 0F511B46C24722FB0FA44086B10C17280800000000000000000000000000 to 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000  (73430/790/00207)  Friday,04,July,2014,15:25:27:16648
Address 09:5Q0 937 086 Q recoded (Long Coding) from 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000 to 0F511B46C2C722FB0FA44086B10C17280808000000000000000000000000  (73430/790/00207)  Friday,04,July,2014,15:39:21:16648
Address 09:5Q0 937 086 Q recoded (ADP-(6)-Leuchte30FR LC72-Dimmwert AB 30) from 89  to 100   Friday,04,July,2014,15:42:52:16648
andyvee
C?ID=159389
Actually, looking at that log it coincides with this coding change
andyvee
C?ID=159389
And having checked the coding of 09 from when this car left the factory it is the same as the starting point above. I didn't pull an adaptations map on 09 after I made the changes, which is a shame, as I have the original adaptations map from this car - is there any way of attaching a .csv file???
Thanks. We'll double-check what's up with DTC 565764 in that module, which is:
Nope, no attachments. Paste it into a message and wrap it in CODE tags, or host it wherever you want and post a link.
This is the kind of thing that makes us wanna tear our hair out, or at least turns it gray(er). The data for that BCM clearly translates that DTC to B201B, and "Program Monitoring" is the correct text for B201B, but, there's also another reference to another data structure, which has the "LED Bar: No Signal / Communications" text it it.
We just love the way that VWAG handles these things in an entirely consistent manner. NOT!
We'll have to think about how best to handle this; it looks like there are a number of BCMs that do this, for a number of different fault codes. :rolleyes:
jyoung8607
FoRT
Garrettsville, OH
C?ID=25607
Look at it like me and my coworkers do the VoIP/video stuff we work with:
If it was easy and it just worked, there wouldn't be good money in it. :)
Jason
flygteye
WI
C?ID=79663
It's nice to see some MQB info here. :D
andyvee
C?ID=159389
How much MQB info do you want, I have a few scans and adaptation maps. I'll put them all on dropbox if you want.
